[U-Boot] [PATCH] spl: add check for FIT-header when loading image
Add check for FDT_MAGIC, otherwise also legacy images will be loaded as a FIT. With this check in place, the loader works correct both with legacy and FIT images.
Signed-off-by: Tomas Melin tomas.melin@vaisala.com --- common/spl/spl_spi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index a3caafb..78b8cd1 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -99,7 +99,8 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, if (err) return err;
- if (IS_ENABLED(CONFIG_SPL_LOAD_FIT)) { + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && + image_get_magic(header) == FDT_MAGIC) { struct spl_load_info load;
debug("Found FIT\n");
Acked-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
image_get_magic(header) == FDT_MAGIC) { struct spl_load_info load; debug("Found FIT\n");
-- 2.1.4
Signed-off-by: Tomas Melin tomas.melin@vaisala.com Acked-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Simon Glass sjg@chromium.org
Lokesh Vutla
Tomas Melin
