[U-Boot] [PATCH V4] i.MX6: mx6qsabrelite: Add splash screen support
Adds support for two LVDS panels and one RGB panel to the SABRE-Lite board: Hannstar-XGA - 1024 x 768 LVDS (Freescale part number MCIMX-LVDS1) wsvga-lvds - 1024 x 600 LVDS (Boundary p/n Nit6X_1024x600) wvga-rgb - 800 x 480 RGB (Boundary p/n Nit6X_800x480)
Auto-detects panel by probing the I2C touch controller of each.
Setting 'panel' environment variable to one of the names above will override auto-detection.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 245 ++++++++++++++++++++++++- drivers/video/ipu_common.c | 2 +- include/configs/mx6qsabrelite.h | 15 ++- 3 files changed, 259 insertions(+), 3 deletions(-)
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 4b4e89b..d274d8c 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -36,6 +36,11 @@ #include <micrel.h> #include <miiphy.h> #include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/arch/crm_regs.h> +#include <i2c.h> + DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ @@ -372,14 +377,252 @@ int setup_sata(void) } #endif
+#if defined(CONFIG_VIDEO_IPUV3) +static struct fb_videomode videomodes[] = {{ + .name = "Hannstar-XGA", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, /* a.k.a. LVDS */ + .vmode = FB_VMODE_NONINTERLACED + }, { + .name = "wsvga-lvds", + .refresh = 60, + .xres = 1024, + .yres = 600, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, /* a.k.a. LVDS */ + .vmode = FB_VMODE_NONINTERLACED + }, { + .name = "wvga-rgb", + .refresh = 57, + .xres = 800, + .yres = 480, + .pixclock = 37037, + .left_margin = 40, + .right_margin = 60, + .upper_margin = 10, + .lower_margin = 10, + .hsync_len = 20, + .vsync_len = 10, + .sync = 0, + .vmode = FB_VMODE_NONINTERLACED +} }; + +#define IS_LVDS(m) (FB_SYNC_EXT & (m).sync) + +struct i2c_display { + int bus; + int addr; + char const *name; +}; + +static struct i2c_display const i2c_displays[] = { +{ + .bus = 2, + .addr = 0x4, + .name = "Hannstar-XGA", +}, { + .bus = 2, + .addr = 0x38, + .name = "wsvga-lvds", +}, { + .bus = 2, + .addr = 0x48, + .name = "wvga-rgb", +} }; + +static iomux_v3_cfg_t rgb_pads[] = { + MX6Q_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK, + MX6Q_PAD_DI0_PIN15__IPU1_DI0_PIN15, + MX6Q_PAD_DI0_PIN2__IPU1_DI0_PIN2, + MX6Q_PAD_DI0_PIN3__IPU1_DI0_PIN3, + MX6Q_PAD_DI0_PIN4__GPIO_4_20, + MX6Q_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0, + MX6Q_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1, + MX6Q_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2, + MX6Q_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3, + MX6Q_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4, + MX6Q_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5, + MX6Q_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6, + MX6Q_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7, + MX6Q_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8, + MX6Q_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9, + MX6Q_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10, + MX6Q_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11, + MX6Q_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12, + MX6Q_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13, + MX6Q_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14, + MX6Q_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15, + MX6Q_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16, + MX6Q_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17, + MX6Q_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18, + MX6Q_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19, + MX6Q_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20, + MX6Q_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21, + MX6Q_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22, + MX6Q_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23, +}; + +static iomux_v3_cfg_t backlight_pads[] = { + /* Backlight on RGB connector: J15 */ + MX6Q_PAD_SD1_DAT3__GPIO_1_21 | MUX_PAD_CTRL(NO_PAD_CTRL), +#define RGB_BACKLIGHT_GP IMX_GPIO_NR(1, 21) + + /* Backlight on LVDS connector: J6 */ + MX6Q_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), +#define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 18) +}; + +int board_video_skip(void) +{ + int i; + int ret; + char const *panel = getenv("panel"); + if (!panel) { + for (i = 0; i < ARRAY_SIZE(i2c_displays); i++) { + struct i2c_display const *dev = i2c_displays+i; + if ((0 == i2c_set_bus_num(dev->bus)) + && + (0 == i2c_probe(dev->addr))) { + panel = dev->name; + printf("auto-detected panel %s\n", panel); + break; + } + } + if (!panel) { + panel = videomodes[0].name; + printf("No panel detected: default to %s\n", panel); + } + } + for (i = 0; i < ARRAY_SIZE(videomodes); i++) { + if (!strcmp(panel, videomodes[i].name)) + break; + } + if (i < ARRAY_SIZE(videomodes)) { + ret = ipuv3_fb_init(videomodes+i, 0, IPU_PIX_FMT_RGB666); + if (!ret) { + if (IS_LVDS(videomodes[i])) + gpio_direction_output(LVDS_BACKLIGHT_GP, 1); + else { + imx_iomux_v3_setup_multiple_pads( + rgb_pads, + ARRAY_SIZE(rgb_pads)); + gpio_direction_output(RGB_BACKLIGHT_GP, 1); + } + printf("Display: %s (%ux%u)\n", + videomodes[i].name, + videomodes[i].xres, + videomodes[i].yres); + } else + printf("LCD %s cannot be configured: %d\n", + videomodes[i].name, ret); + } else { + printf("unsupported panel %s\n", panel); + ret = -EINVAL; + } + return (0 != ret); +} + +void lcd_iomux(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + int reg; + + /* Turn on LDB0,IPU,IPU DI0 clocks */ + reg = __raw_readl(&mxc_ccm->CCGR3); + reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET + |MXC_CCM_CCGR3_LDB_DI0_MASK; + writel(reg, &mxc_ccm->CCGR3); + + /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ + writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); + writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); + + /* set LDB0, LDB1 clk select to 011/011 */ + reg = readl(&mxc_ccm->cs2cdr); + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + |MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) + |(3<<MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->cs2cdr); + + reg = readl(&mxc_ccm->cscmr2); + reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; + writel(reg, &mxc_ccm->cscmr2); + + reg = readl(&mxc_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) + |(CHSCCDR_PODF_DIVIDE_BY_3 + <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) + |(CHSCCDR_IPU_PRE_CLK_540M_PFD + <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); + + reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES + |IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH + |IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW + |IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT + |IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT + |IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED + |IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; + writel(reg, &iomux->gpr[2]); + + reg = readl(&iomux->gpr[3]); + reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK) + | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 + <<IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); + writel(reg, &iomux->gpr[3]); + + /* backlights off until needed */ + imx_iomux_v3_setup_multiple_pads(backlight_pads, + ARRAY_SIZE(backlight_pads)); + gpio_direction_input(LVDS_BACKLIGHT_GP); + gpio_direction_input(RGB_BACKLIGHT_GP); +} +#endif + int board_early_init_f(void) { setup_iomux_uart(); setup_buttons(); - +#if defined(CONFIG_VIDEO_IPUV3) + lcd_iomux(); +#endif return 0; }
+/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + int board_init(void) { /* address of boot parameters */ diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index cc8f881..5f0a1a8 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -218,7 +218,7 @@ static struct clk ipu_clk = { #else .enable_reg = (u32 *)(CCM_BASE_ADDR + offsetof(struct mxc_ccm_reg, CCGR3)), - .enable_shift = MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET, + .enable_shift = MXC_CCM_CCGR3_IPU1_IPU_MASK, #endif .enable = clk_ipu_enable, .disable = clk_ipu_disable, diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 72d0154..d0c3e0a 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -39,7 +39,7 @@ #define CONFIG_REVISION_TAG
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R @@ -121,6 +121,19 @@ /* Miscellaneous commands */ #define CONFIG_CMD_BMODE
+/* Framebuffer and LCD */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
Hi Eric,
On Fri, Sep 21, 2012 at 7:53 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
That's a nice solution!
Is HDMI splash screen support also in the pipeline?
Thanks,
Fabio Estevam
On 09/22/2012 08:12 AM, Fabio Estevam wrote:
Hi Eric,
Yep.
I want to get that one done before we add a second board which uses this structure.
Interestingly, I saw U-Boot display on HDMI during my testing, so I'm pretty certain that all we need is the HDMI transmitter initialization sequence.
Hi Eric,
On Sat, Sep 22, 2012 at 1:51 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
Excellent, could you please share the HDMI transmitter init sequence?
Thanks,
Fabio Estevam
On 09/22/2012 10:02 AM, Fabio Estevam wrote:
Hi Eric,
Hi Fabio,
I haven't worked through the details, but I'm sure they're in here ;)
https://github.com/boundarydevices/linux-imx6/blob/boundary-L3.0.35_MX6DQ_ER...
Regards,
Eric
Hi Eric,
Hi Fabio,
This may be easier than I thought (a set of writes to a single register).
I did a little digging, and it seems that the power-on defaults for the HDMI transmitter work pretty well with my display (many thanks to the chip designers!).
Without some more digging, I'm not very confident that the clocks are all getting set up properly, but the attached patch allows me to get 1080P video over HDMI.
It also highlights some issues in the I2C detection structure (two parallel arrays that I hacked), but it gives me a lot more confidence that HDMI is achievable in the short term for at least one display.
Regards,
Eric
Hi Eric,
Hi Fabio,
Hi Stefano,
I have HDMI detection and display support working well.
In the process, I've refactored the display detection and activation logic to use some callbacks instead of conditionals.
I'd like to submit the new code as a V5 of the splash screen patch: http://patchwork.ozlabs.org/patch/186278/
I'm not sure which tree I should use though.
u-boot-imx/master? u-boot-imx/next?
/next will require that I revert the previous version.
Similarly, I have a couple of patches to allow passing const structures to ipuv3_fb_init() and imx_iomux_v3_setup_multiple_pads() and I'm not sure what will be easiest for you to merge.
Please let me know what works best for you.
Regards,
Eric
On 03/10/2012 02:31, Eric Nelson wrote:
Hi Stefano,
Hi Eric,
Nice !
We will do another thing. It makes no sense that the old version flows into mainline. And on the -next we are allowed to modify and rebase the tree.
I drop the previous series from next. Please then resubmit using u-boot-imx/next.
master is currently only for fixes, until the merge window will be opened again after the release.
Regards, Stefano
Hi Stefano,
Hi Eric,
Nice !
Will do.
Thanks Stefano.
I'm still seeing the old splash screen support in /next:
http://git.denx.de/u-boot-imx.git/?p=u-boot/u-boot-imx.git;a=commit;h=09d7d1...
Do you want me to revert and submit a patch set?
Please advise,
Eric
http://git.denx.de/u-boot-imx.git/?p=u-boot/u-boot-imx.git;a=commit;h=09d7d158fd281110dde8b1936684e96c8567b527
No - I dropped only the HDMI series, now I removed the "Add splash screen support", too. Now the tree should be ready for your patches.
Regards, Stefano
Between V3 and V4 you changed also ipu_common.c, and that change does not apply.
- .enable_shift = MXC_CCM_CCGR3_IPU1_IPU_MASK,
But in ipu_common.c:
.enable_reg = (u32 *)(CCM_BASE_ADDR + offsetof(struct mxc_ccm_reg, CCGR5)), .enable_shift = MXC_CCM_CCGR5_CG5_OFFSET,
I do not see another patch changing that. Am I missing something ?
Best regards, Stefano
Sorry Stefano,
Signed-off-by: Eric Nelsoneric.nelson@boundarydevices.com
CCGR5/CG5 is the IPU clock on i.MX5x, not i.MX6x.
This patch requires the previous change to name the CCGRx bitfields:
http://patchwork.ozlabs.org/patch/185856/
Regards,
Eric
On 24/09/2012 17:11, Eric Nelson wrote:
Sorry Stefano,
Right, but I see no #ifdef..
Ah, ok, I see ! Next iteration, thanks.
The patch depends also on the following patches: i.MX6: define struct iomuxc and IOMUX_GPR2 register bitfields i.MX6: Add ANATOP_PFD_480 bitfield constants define IOMUX_GPR3 register bitfields i.MX6: define bitfields for CHSCCDR register i.MX6: change register name for CCM_CHSCCDR to match ref. manual i.MX6: provide functional names for CCM_CCGR0-CCGR6 bit fields
I have applied them, with slightly rebased due to some hunks. Pusehd into u-boot-imx, next branch.
Eric Nelson
Fabio Estevam
Stefano Babic
