Re: [U-Boot] Question regarding FPGA firmware load in u-boot
Prafulla,
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Dieter Kiermaier Sent: Monday, June 22, 2009 2:30 PM To: André Schwarz Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] Question regarding FPGA firmware load in u-boot
André,
Dieter,
On Mon, 2009-06-22 at 08:19 +0200, Dieter Kiermaier wrote:
André,
Dieter,
On Fri, 2009-06-19 at 17:46 +0200, Dieter Kiermaier wrote:
Hello List,
I want to boot a (Lattice) FPGA from u-boot by using Slave Serial configuration on a Marvell Kirkwood device.
Should be no problem as long as you'll have access to GPIO.
I'm working on it :) But more likely I would have the SPI controller to do the serializing of the bitstream. But maybe this would be the
second step.
Hi Pls see my patch, hopefully this is useful for you http://lists.denx.de/pipermail/u-boot/2009-June/053605.html
Thanks for pointing to it. But as I tried to explain, the common SPI driver is useless for my board due to the kirkwood pin multiplexing. Thats why I asked for a TDM module based SPI driver in the past. (Please see my comment on the openplug wiki from today morning for a more detailed explanation)
Dieter
Regards.. Prafulla . .
Dieter Kiermaier
