[U-Boot] [PATCH v1 1/2] doc: Fix CONFIG_OF_SEPARATE description
CONFIG_OF_SEPARATE description is not in align with actual code in Makefile and thus has misleading instructions and explanation.
Make it aligned with the actual code.
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- doc/README.fdt-control | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/doc/README.fdt-control b/doc/README.fdt-control index 446401c9e9..e53cf51875 100644 --- a/doc/README.fdt-control +++ b/doc/README.fdt-control @@ -122,13 +122,14 @@ the U-Boot image (including u-boot.bin). This is suitable for debugging and development only and is not recommended for production devices.
If CONFIG_OF_SEPARATE is defined, then it will be built and placed in -a u-boot.dtb file alongside u-boot.bin. A common approach is then to +a u-boot.dtb file alongside u-boot-nodtb.bin. A common approach is then to join the two:
- cat u-boot.bin u-boot.dtb >image.bin + cat u-boot-nodtb.bin u-boot.dtb >image.bin
and then flash image.bin onto your board. Note that U-Boot creates -u-boot-dtb.bin which does the above step for you also. If you are using +u-boot-dtb.bin which does the above step for you also. Resulting +u-boot.bin is a copy of u-boot-dtb.bin in this case. If you are using CONFIG_SPL_FRAMEWORK, then u-boot.img will be built to include the device tree binary.
There is no need for Intel Edison to have CONFIG_OF_EMBED to be enabled. Replace it with CONFIG_OF_SEPARATE.
There is no functional change since u-boot.bin always contains DTB either embedded or attached.
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- configs/edison_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/edison_defconfig b/configs/edison_defconfig index e376c0cea6..dc7d86aafe 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_EMBED=y +CONFIG_OF_SEPARATE=y CONFIG_DEFAULT_DEVICE_TREE="edison" CONFIG_ENV_IS_IN_MMC=y CONFIG_CPU=y
Op 08-01-19 om 15:17 schreef Andy Shevchenko:
Tested-by: Ferry Toth ftoth@exalondelft.nl
On Tue, 8 Jan 2019 at 07:17, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
applied to u-boot-x86, thanks!
Bin, is it possible to see this for the next release?
- cat u-boot-nodtb.bin u-boot.dtb >image.bin
-- 2.19.2
On Thu, Jan 31, 2019 at 3:54 AM Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Andy Shevchenko
Bin Meng
Ferry Toth
