[PATCH 1/1] test: efi_selftest: fix pylint warnings
Fix pylint warnings:
* add missing module and function documentation * correct indentation
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/py/tests/test_efi_selftest.py | 361 +++++++++++++++-------------- 1 file changed, 187 insertions(+), 174 deletions(-)
diff --git a/test/py/tests/test_efi_selftest.py b/test/py/tests/test_efi_selftest.py index ca01542088..971c9f6053 100644 --- a/test/py/tests/test_efi_selftest.py +++ b/test/py/tests/test_efi_selftest.py @@ -1,198 +1,211 @@ # SPDX-License-Identifier: GPL-2.0 # Copyright (c) 2017, Heinrich Schuchardt xypron.glpk@gmx.de
-# Test efi API implementation +""" +Test UEFI API implementation +"""
import pytest -import u_boot_utils
@pytest.mark.buildconfigspec('cmd_bootefi_selftest') def test_efi_selftest(u_boot_console): - """Test the UEFI implementation + """Run UEFI unit tests
- :param u_boot_console: U-Boot console + :param u_boot_console: U-Boot console
- This function executes all selftests that are not marked as on request. - """ - u_boot_console.run_command(cmd='setenv efi_selftest') - u_boot_console.run_command(cmd='bootefi selftest', wait_for_prompt=False) - m = u_boot_console.p.expect(['Summary: 0 failures', 'Press any key']) - if m != 0: - raise Exception('Failures occurred during the EFI selftest') - u_boot_console.restart_uboot(); + This function executes all selftests that are not marked as on request. + """ + u_boot_console.run_command(cmd='setenv efi_selftest') + u_boot_console.run_command(cmd='bootefi selftest', wait_for_prompt=False) + m = u_boot_console.p.expect(['Summary: 0 failures', 'Press any key']) + if m != 0: + raise Exception('Failures occurred during the EFI selftest') + u_boot_console.restart_uboot()
@pytest.mark.buildconfigspec('cmd_bootefi_selftest') @pytest.mark.buildconfigspec('of_control') @pytest.mark.notbuildconfigspec('generate_acpi_table') def test_efi_selftest_device_tree(u_boot_console): - u_boot_console.run_command(cmd='setenv efi_selftest list') - output = u_boot_console.run_command('bootefi selftest') - assert ''device tree'' in output - u_boot_console.run_command(cmd='setenv efi_selftest device tree') - u_boot_console.run_command(cmd='setenv -f serial# Testing DT') - u_boot_console.run_command(cmd='bootefi selftest ${fdtcontroladdr}', wait_for_prompt=False) - m = u_boot_console.p.expect(['serial-number: Testing DT', 'U-Boot']) - if m != 0: - raise Exception('serial-number missing in device tree') - u_boot_console.restart_uboot(); + """Test the device tree support in the UEFI sub-system + + :param u_boot_console: U-Boot console + + This test executes the UEFI unit test by calling 'bootefi selftest'. + """ + u_boot_console.run_command(cmd='setenv efi_selftest list') + output = u_boot_console.run_command('bootefi selftest') + assert ''device tree'' in output + u_boot_console.run_command(cmd='setenv efi_selftest device tree') + u_boot_console.run_command(cmd='setenv -f serial# Testing DT') + u_boot_console.run_command(cmd='bootefi selftest ${fdtcontroladdr}', wait_for_prompt=False) + m = u_boot_console.p.expect(['serial-number: Testing DT', 'U-Boot']) + if m != 0: + raise Exception('serial-number missing in device tree') + u_boot_console.restart_uboot()
@pytest.mark.buildconfigspec('cmd_bootefi_selftest') def test_efi_selftest_watchdog_reboot(u_boot_console): - u_boot_console.run_command(cmd='setenv efi_selftest list') - output = u_boot_console.run_command('bootefi selftest') - assert ''watchdog reboot'' in output - u_boot_console.run_command(cmd='setenv efi_selftest watchdog reboot') - u_boot_console.run_command(cmd='bootefi selftest', wait_for_prompt=False) - m = u_boot_console.p.expect(['resetting', 'U-Boot']) - if m != 0: - raise Exception('Reset failed in 'watchdog reboot' test') - u_boot_console.restart_uboot(); + """Test the watchdog timer + + :param u_boot_console: U-Boot console + + This function executes the 'watchdog reboot' unit test. + """ + u_boot_console.run_command(cmd='setenv efi_selftest list') + output = u_boot_console.run_command('bootefi selftest') + assert ''watchdog reboot'' in output + u_boot_console.run_command(cmd='setenv efi_selftest watchdog reboot') + u_boot_console.run_command(cmd='bootefi selftest', wait_for_prompt=False) + m = u_boot_console.p.expect(['resetting', 'U-Boot']) + if m != 0: + raise Exception('Reset failed in 'watchdog reboot' test') + u_boot_console.restart_uboot()
@pytest.mark.buildconfigspec('cmd_bootefi_selftest') def test_efi_selftest_text_input(u_boot_console): - """Test the EFI_SIMPLE_TEXT_INPUT_PROTOCOL - - :param u_boot_console: U-Boot console - - This function calls the text input EFI selftest. - """ - u_boot_console.run_command(cmd='setenv efi_selftest text input') - output = u_boot_console.run_command(cmd='bootefi selftest', - wait_for_prompt=False) - m = u_boot_console.p.expect([r'To terminate type 'x'']) - if m != 0: - raise Exception('No prompt for 'text input' test') - u_boot_console.drain_console() - u_boot_console.p.timeout = 500 - # EOT - u_boot_console.run_command(cmd=chr(4), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 4 (unknown), scan code 0 (Null)']) - if m != 0: - raise Exception('EOT failed in 'text input' test') - u_boot_console.drain_console() - # BS - u_boot_console.run_command(cmd=chr(8), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 8 (BS), scan code 0 (Null)']) - if m != 0: - raise Exception('BS failed in 'text input' test') - u_boot_console.drain_console() - # TAB - u_boot_console.run_command(cmd=chr(9), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 9 (TAB), scan code 0 (Null)']) - if m != 0: - raise Exception('BS failed in 'text input' test') - u_boot_console.drain_console() - # a - u_boot_console.run_command(cmd='a', wait_for_echo=False, send_nl=False, - wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 97 ('a'), scan code 0 (Null)']) - if m != 0: - raise Exception(''a' failed in 'text input' test') - u_boot_console.drain_console() - # UP escape sequence - u_boot_console.run_command(cmd=chr(27) + '[A', wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 0 (Null), scan code 1 (Up)']) - if m != 0: - raise Exception('UP failed in 'text input' test') - u_boot_console.drain_console() - # Euro sign - u_boot_console.run_command(cmd=b'\xe2\x82\xac'.decode(), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect([r'Unicode char 8364 ('']) - if m != 0: - raise Exception('Euro sign failed in 'text input' test') - u_boot_console.drain_console() - u_boot_console.run_command(cmd='x', wait_for_echo=False, send_nl=False, - wait_for_prompt=False) - m = u_boot_console.p.expect(['Summary: 0 failures', 'Press any key']) - if m != 0: - raise Exception('Failures occurred during the EFI selftest') - u_boot_console.restart_uboot(); + """Test the EFI_SIMPLE_TEXT_INPUT_PROTOCOL + + :param u_boot_console: U-Boot console + + This function calls the text input EFI selftest. + """ + u_boot_console.run_command(cmd='setenv efi_selftest text input') + output = u_boot_console.run_command(cmd='bootefi selftest', + wait_for_prompt=False) + m = u_boot_console.p.expect([r'To terminate type 'x'']) + if m != 0: + raise Exception('No prompt for 'text input' test') + u_boot_console.drain_console() + u_boot_console.p.timeout = 500 + # EOT + u_boot_console.run_command(cmd=chr(4), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 4 (unknown), scan code 0 (Null)']) + if m != 0: + raise Exception('EOT failed in 'text input' test') + u_boot_console.drain_console() + # BS + u_boot_console.run_command(cmd=chr(8), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 8 (BS), scan code 0 (Null)']) + if m != 0: + raise Exception('BS failed in 'text input' test') + u_boot_console.drain_console() + # TAB + u_boot_console.run_command(cmd=chr(9), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 9 (TAB), scan code 0 (Null)']) + if m != 0: + raise Exception('BS failed in 'text input' test') + u_boot_console.drain_console() + # a + u_boot_console.run_command(cmd='a', wait_for_echo=False, send_nl=False, + wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 97 ('a'), scan code 0 (Null)']) + if m != 0: + raise Exception(''a' failed in 'text input' test') + u_boot_console.drain_console() + # UP escape sequence + u_boot_console.run_command(cmd=chr(27) + '[A', wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 0 (Null), scan code 1 (Up)']) + if m != 0: + raise Exception('UP failed in 'text input' test') + u_boot_console.drain_console() + # Euro sign + u_boot_console.run_command(cmd=b'\xe2\x82\xac'.decode(), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect([r'Unicode char 8364 ('']) + if m != 0: + raise Exception('Euro sign failed in 'text input' test') + u_boot_console.drain_console() + u_boot_console.run_command(cmd='x', wait_for_echo=False, send_nl=False, + wait_for_prompt=False) + m = u_boot_console.p.expect(['Summary: 0 failures', 'Press any key']) + if m != 0: + raise Exception('Failures occurred during the EFI selftest') + u_boot_console.restart_uboot()
@pytest.mark.buildconfigspec('cmd_bootefi_selftest') def test_efi_selftest_text_input_ex(u_boot_console): - """Test the EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL - - :param u_boot_console: U-Boot console - - This function calls the extended text input EFI selftest. - """ - u_boot_console.run_command(cmd='setenv efi_selftest extended text input') - output = u_boot_console.run_command(cmd='bootefi selftest', - wait_for_prompt=False) - m = u_boot_console.p.expect([r'To terminate type 'CTRL+x'']) - if m != 0: - raise Exception('No prompt for 'text input' test') - u_boot_console.drain_console() - u_boot_console.p.timeout = 500 - # EOT - u_boot_console.run_command(cmd=chr(4), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 100 ('d'), scan code 0 (CTRL+Null)']) - if m != 0: - raise Exception('EOT failed in 'text input' test') - u_boot_console.drain_console() - # BS - u_boot_console.run_command(cmd=chr(8), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 8 (BS), scan code 0 (+Null)']) - if m != 0: - raise Exception('BS failed in 'text input' test') - u_boot_console.drain_console() - # TAB - u_boot_console.run_command(cmd=chr(9), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 9 (TAB), scan code 0 (+Null)']) - if m != 0: - raise Exception('TAB failed in 'text input' test') - u_boot_console.drain_console() - # a - u_boot_console.run_command(cmd='a', wait_for_echo=False, send_nl=False, - wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 97 ('a'), scan code 0 (Null)']) - if m != 0: - raise Exception(''a' failed in 'text input' test') - u_boot_console.drain_console() - # UP escape sequence - u_boot_console.run_command(cmd=chr(27) + '[A', wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 0 (Null), scan code 1 (+Up)']) - if m != 0: - raise Exception('UP failed in 'text input' test') - u_boot_console.drain_console() - # Euro sign - u_boot_console.run_command(cmd=b'\xe2\x82\xac'.decode(), wait_for_echo=False, - send_nl=False, wait_for_prompt=False) - m = u_boot_console.p.expect([r'Unicode char 8364 ('']) - if m != 0: - raise Exception('Euro sign failed in 'text input' test') - u_boot_console.drain_console() - # SHIFT+ALT+FN 5 - u_boot_console.run_command(cmd=b'\x1b\x5b\x31\x35\x3b\x34\x7e'.decode(), - wait_for_echo=False, send_nl=False, - wait_for_prompt=False) - m = u_boot_console.p.expect( - [r'Unicode char 0 (Null), scan code 15 (SHIFT+ALT+FN 5)']) - if m != 0: - raise Exception('SHIFT+ALT+FN 5 failed in 'text input' test') - u_boot_console.drain_console() - u_boot_console.run_command(cmd=chr(24), wait_for_echo=False, send_nl=False, - wait_for_prompt=False) - m = u_boot_console.p.expect(['Summary: 0 failures', 'Press any key']) - if m != 0: - raise Exception('Failures occurred during the EFI selftest') - u_boot_console.restart_uboot(); + """Test the EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL + + :param u_boot_console: U-Boot console + + This function calls the extended text input EFI selftest. + """ + u_boot_console.run_command(cmd='setenv efi_selftest extended text input') + output = u_boot_console.run_command(cmd='bootefi selftest', + wait_for_prompt=False) + m = u_boot_console.p.expect([r'To terminate type 'CTRL+x'']) + if m != 0: + raise Exception('No prompt for 'text input' test') + u_boot_console.drain_console() + u_boot_console.p.timeout = 500 + # EOT + u_boot_console.run_command(cmd=chr(4), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 100 ('d'), scan code 0 (CTRL+Null)']) + if m != 0: + raise Exception('EOT failed in 'text input' test') + u_boot_console.drain_console() + # BS + u_boot_console.run_command(cmd=chr(8), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 8 (BS), scan code 0 (+Null)']) + if m != 0: + raise Exception('BS failed in 'text input' test') + u_boot_console.drain_console() + # TAB + u_boot_console.run_command(cmd=chr(9), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 9 (TAB), scan code 0 (+Null)']) + if m != 0: + raise Exception('TAB failed in 'text input' test') + u_boot_console.drain_console() + # a + u_boot_console.run_command(cmd='a', wait_for_echo=False, send_nl=False, + wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 97 ('a'), scan code 0 (Null)']) + if m != 0: + raise Exception(''a' failed in 'text input' test') + u_boot_console.drain_console() + # UP escape sequence + u_boot_console.run_command(cmd=chr(27) + '[A', wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 0 (Null), scan code 1 (+Up)']) + if m != 0: + raise Exception('UP failed in 'text input' test') + u_boot_console.drain_console() + # Euro sign + u_boot_console.run_command(cmd=b'\xe2\x82\xac'.decode(), wait_for_echo=False, + send_nl=False, wait_for_prompt=False) + m = u_boot_console.p.expect([r'Unicode char 8364 ('']) + if m != 0: + raise Exception('Euro sign failed in 'text input' test') + u_boot_console.drain_console() + # SHIFT+ALT+FN 5 + u_boot_console.run_command(cmd=b'\x1b\x5b\x31\x35\x3b\x34\x7e'.decode(), + wait_for_echo=False, send_nl=False, + wait_for_prompt=False) + m = u_boot_console.p.expect( + [r'Unicode char 0 (Null), scan code 15 (SHIFT+ALT+FN 5)']) + if m != 0: + raise Exception('SHIFT+ALT+FN 5 failed in 'text input' test') + u_boot_console.drain_console() + u_boot_console.run_command(cmd=chr(24), wait_for_echo=False, send_nl=False, + wait_for_prompt=False) + m = u_boot_console.p.expect(['Summary: 0 failures', 'Press any key']) + if m != 0: + raise Exception('Failures occurred during the EFI selftest') + u_boot_console.restart_uboot() -- 2.24.1
