Re: [PATCH v2] common/board_f: make sure to call fix_fdt() before reserve_fdt()
Hi Pragnesh
From: Pragnesh Patel [mailto:pragnesh.patel@sifive.com] Sent: Thursday, August 06, 2020 3:55 PM To: atish.patra@wdc.com; bmeng.cn@gmail.com; u-boot@lists.denx.de; anup.patel@wdc.com; sagar.kadam@sifive.com; Rick Jian-Zhi Chen(陳建志) Cc: paul.walmsley@sifive.com; Pragnesh Patel; Simon Glass; Ovidiu Panait; Stephen Warren; Patrick Delaunay; Joe Hershberger; Vikas Manocha; Masahiro Yamada; Ye Li Subject: [PATCH v2] common/board_f: make sure to call fix_fdt() before reserve_fdt()
There may be a chance that board specific fix_fdt() will change the size of FDT blob so it's safe to call reserve_fdt() after fix_fdt() otherwise global data (gd) will overwrite with FDT blob values.
Fixes: a8492e25ac71 ("riscv: Expand the DT size before copy reserved memory node")
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Rick Chen rick@andestech.com
common/board_f.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 88ff0424a7..7ae01e9fff 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -956,6 +956,9 @@ static const init_fnc_t init_sequence_f[] = { * - board info struct */ setup_dest_addr, +#ifdef CONFIG_OF_BOARD_FIXUP
fix_fdt,
+#endif #ifdef CONFIG_PRAM reserve_pram, #endif @@ -984,9 +987,6 @@ static const init_fnc_t init_sequence_f[] = { setup_board_part2, #endif display_new_sp, -#ifdef CONFIG_OF_BOARD_FIXUP
fix_fdt,
-#endif INIT_FUNC_WATCHDOG_RESET reloc_fdt, reloc_bootstage, -- 2.17.1
Applying: common/board_f: make sure to call fix_fdt() before reserve_fdt() error: patch failed: common/board_f.c:984 error: common/board_f.c: patch does not apply Patch failed at 0001 common/board_f: make sure to call fix_fdt() before reserve_fdt()
Thanks, Rick
Hi Rick,
-----Original Message----- From: Rick Chen rickchen36@gmail.com Sent: 13 August 2020 08:59 To: Pragnesh Patel pragnesh.patel@sifive.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Atish Patra atish.patra@wdc.com; Bin Meng bmeng.cn@gmail.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Paul Walmsley ( Sifive) paul.walmsley@sifive.com; Simon Glass sjg@chromium.org; ovpanait@gmail.com; swarren@nvidia.com; rick rick@andestech.com; Alan Kao alankao@andestech.com Subject: Re: [PATCH v2] common/board_f: make sure to call fix_fdt() before reserve_fdt()
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Hi Pragnesh
fix_fdt,
fix_fdt,
Will rebase and send it again.
Thanks, Rick
Pragnesh Patel
Rick Chen
