[U-Boot] [PATCH 0/3] board: at91sam9g20ek/at91sam9260ek: convert to support DM and DT
The purpose of the patch set is to convert the board to support the Driver Model and the Device Tree.
Wenyou Yang (3): ARM: dts: at91: add dts file for at91sam9g20/at91sam9260 board: at91sam9g20ek/at91sam9260ek: move config options to defconfig board: at91sam9260ek: clean up code
arch/arm/dts/Makefile | 5 + arch/arm/dts/at91sam9260.dtsi | 136 +++++++-------- arch/arm/dts/at91sam9260ek.dts | 211 +++++++++++++++++++++++ arch/arm/dts/at91sam9g20.dtsi | 4 +- arch/arm/dts/at91sam9g20ek.dts | 29 ++++ arch/arm/dts/at91sam9g20ek_2mmc.dts | 56 +++++++ arch/arm/dts/at91sam9g20ek_common.dtsi | 223 +++++++++++++++++++++++++ board/atmel/at91sam9260ek/at91sam9260ek.c | 73 -------- configs/at91sam9260ek_dataflash_cs0_defconfig | 15 +- configs/at91sam9260ek_dataflash_cs1_defconfig | 15 +- configs/at91sam9260ek_nandflash_defconfig | 15 +- configs/at91sam9g20ek_2mmc_defconfig | 16 +- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 16 +- configs/at91sam9g20ek_dataflash_cs0_defconfig | 15 +- configs/at91sam9g20ek_dataflash_cs1_defconfig | 15 +- configs/at91sam9g20ek_nandflash_defconfig | 16 +- include/configs/at91sam9260ek.h | 9 - 17 files changed, 705 insertions(+), 164 deletions(-) create mode 100644 arch/arm/dts/at91sam9260ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek_2mmc.dts create mode 100644 arch/arm/dts/at91sam9g20ek_common.dtsi
The device tree source files of at91sam9g20ek and at91sam9260ek boards are copied from the Linux v4.10, do the changes below. - Fix the build error for the usb0 node. - Add the reg property for the pinctrl node. - Move the gpio (pioA, pioB, pioC ...) nodes as the pinctrl's slibling nodes, instead of the child nodes. - Add the clk pinctrl of the mmc0 node. - Fix the compile warnings.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
arch/arm/dts/Makefile | 5 + arch/arm/dts/at91sam9260.dtsi | 136 ++++++++++---------- arch/arm/dts/at91sam9260ek.dts | 211 +++++++++++++++++++++++++++++++ arch/arm/dts/at91sam9g20.dtsi | 4 +- arch/arm/dts/at91sam9g20ek.dts | 29 +++++ arch/arm/dts/at91sam9g20ek_2mmc.dts | 56 +++++++++ arch/arm/dts/at91sam9g20ek_common.dtsi | 223 +++++++++++++++++++++++++++++++++ 7 files changed, 596 insertions(+), 68 deletions(-) create mode 100644 arch/arm/dts/at91sam9260ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek_2mmc.dts create mode 100644 arch/arm/dts/at91sam9g20ek_common.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fce84b4e12..76dc6562ed 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -325,6 +325,11 @@ dtb-$(CONFIG_SOC_KEYSTONE) += k2hk-evm.dtb \ k2e-evm.dtb \ k2g-evm.dtb
+dtb-$(CONFIG_TARGET_AT91SAM9260EK) += \ + at91sam9260ek.dtb \ + at91sam9g20ek.dtb \ + at91sam9g20ek_2mmc.dtb + dtb-$(CONFIG_TARGET_AT91SAM9X5EK) += \ at91sam9g15ek.dtb \ at91sam9g25ek.dtb \ diff --git a/arch/arm/dts/at91sam9260.dtsi b/arch/arm/dts/at91sam9260.dtsi index d4884dd1c2..39205e9df1 100644 --- a/arch/arm/dts/at91sam9260.dtsi +++ b/arch/arm/dts/at91sam9260.dtsi @@ -134,7 +134,7 @@ clocks = <&slow_rc_osc>, <&slow_xtal>; };
- plla: pllack { + plla: pllack@0 { compatible = "atmel,at91rm9200-clk-pll"; #clock-cells = <0>; interrupts-extended = <&pmc AT91_PMC_LOCKA>; @@ -146,7 +146,7 @@ <150000000 240000000 2 1>; };
- pllb: pllbck { + pllb: pllbck@1 { compatible = "atmel,at91rm9200-clk-pll"; #clock-cells = <0>; interrupts-extended = <&pmc AT91_PMC_LOCKB>; @@ -180,13 +180,13 @@ interrupt-parent = <&pmc>; clocks = <&clk32k>, <&main>, <&plla>, <&pllb>;
- prog0: prog0 { + prog0: prog@0 { #clock-cells = <0>; reg = <0>; interrupts = <AT91_PMC_PCKRDY(0)>; };
- prog1: prog1 { + prog1: prog@1 { #clock-cells = <0>; reg = <1>; interrupts = <AT91_PMC_PCKRDY(1)>; @@ -198,25 +198,25 @@ #address-cells = <1>; #size-cells = <0>;
- uhpck: uhpck { + uhpck: uhpck@6 { #clock-cells = <0>; reg = <6>; clocks = <&usb>; };
- udpck: udpck { + udpck: udpck@7 { #clock-cells = <0>; reg = <7>; clocks = <&usb>; };
- pck0: pck0 { + pck0: pck0@8 { #clock-cells = <0>; reg = <8>; clocks = <&prog0>; };
- pck1: pck1 { + pck1: pck1@9 { #clock-cells = <0>; reg = <9>; clocks = <&prog1>; @@ -229,127 +229,127 @@ #size-cells = <0>; clocks = <&mck>;
- pioA_clk: pioA_clk { + pioA_clk: pioA_clk@2 { #clock-cells = <0>; reg = <2>; };
- pioB_clk: pioB_clk { + pioB_clk: pioB_clk@3 { #clock-cells = <0>; reg = <3>; };
- pioC_clk: pioC_clk { + pioC_clk: pioC_clk@4 { #clock-cells = <0>; reg = <4>; };
- adc_clk: adc_clk { + adc_clk: adc_clk@5 { #clock-cells = <0>; reg = <5>; };
- usart0_clk: usart0_clk { + usart0_clk: usart0_clk@6 { #clock-cells = <0>; reg = <6>; };
- usart1_clk: usart1_clk { + usart1_clk: usart1_clk@7 { #clock-cells = <0>; reg = <7>; };
- usart2_clk: usart2_clk { + usart2_clk: usart2_clk@8 { #clock-cells = <0>; reg = <8>; };
- mci0_clk: mci0_clk { + mci0_clk: mci0_clk@9 { #clock-cells = <0>; reg = <9>; };
- udc_clk: udc_clk { + udc_clk: udc_clk@10 { #clock-cells = <0>; reg = <10>; };
- twi0_clk: twi0_clk { + twi0_clk: twi0_clk@11 { reg = <11>; #clock-cells = <0>; };
- spi0_clk: spi0_clk { + spi0_clk: spi0_clk@12 { #clock-cells = <0>; reg = <12>; };
- spi1_clk: spi1_clk { + spi1_clk: spi1_clk@13 { #clock-cells = <0>; reg = <13>; };
- ssc0_clk: ssc0_clk { + ssc0_clk: ssc0_clk@14 { #clock-cells = <0>; reg = <14>; };
- tc0_clk: tc0_clk { + tc0_clk: tc0_clk@17 { #clock-cells = <0>; reg = <17>; };
- tc1_clk: tc1_clk { + tc1_clk: tc1_clk@18 { #clock-cells = <0>; reg = <18>; };
- tc2_clk: tc2_clk { + tc2_clk: tc2_clk@19 { #clock-cells = <0>; reg = <19>; };
- ohci_clk: ohci_clk { + ohci_clk: ohci_clk@20 { #clock-cells = <0>; reg = <20>; };
- macb0_clk: macb0_clk { + macb0_clk: macb0_clk@21 { #clock-cells = <0>; reg = <21>; };
- isi_clk: isi_clk { + isi_clk: isi_clk@22 { #clock-cells = <0>; reg = <22>; };
- usart3_clk: usart3_clk { + usart3_clk: usart3_clk@23 { #clock-cells = <0>; reg = <23>; };
- uart0_clk: uart0_clk { + uart0_clk: uart0_clk@24 { #clock-cells = <0>; reg = <24>; };
- uart1_clk: uart1_clk { + uart1_clk: uart1_clk@25 { #clock-cells = <0>; reg = <25>; };
- tc3_clk: tc3_clk { + tc3_clk: tc3_clk@26 { #clock-cells = <0>; reg = <26>; };
- tc4_clk: tc4_clk { + tc4_clk: tc4_clk@27 { #clock-cells = <0>; reg = <27>; };
- tc5_clk: tc5_clk { + tc5_clk: tc5_clk@28 { #clock-cells = <0>; reg = <28>; }; @@ -395,11 +395,48 @@ clock-names = "t0_clk", "t1_clk", "t2_clk", "slow_clk"; };
+ pioA: gpio@fffff400 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + }; + + pioB: gpio@fffff600 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + }; + + pioC: gpio@fffff800 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + }; + pinctrl@fffff400 { #address-cells = <1>; #size-cells = <1>; compatible = "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x600>; + reg = <0xfffff400 0x200 /* pioA */ + 0xfffff600 0x200 /* pioB */ + 0xfffff800 0x200 /* pioC */ + >;
atmel,mux-mask = < /* A B */ @@ -719,39 +756,6 @@ atmel,pins = <AT91_PIOB 19 AT91_PERIPH_B AT91_PINCTRL_NONE>; }; }; - - pioA: gpio@fffff400 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - }; - - pioB: gpio@fffff600 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - }; - - pioC: gpio@fffff800 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - }; };
dbgu: serial@fffff200 { diff --git a/arch/arm/dts/at91sam9260ek.dts b/arch/arm/dts/at91sam9260ek.dts new file mode 100644 index 0000000000..8ce2c776f6 --- /dev/null +++ b/arch/arm/dts/at91sam9260ek.dts @@ -0,0 +1,211 @@ +/* + * Device Tree file for Atmel at91sam9260 Evaluation Kit + * + * Copyright (C) 2016 Atmel, + * 2016 Nicolas Ferre nicolas.ferre@atmel.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; +#include "at91sam9260.dtsi" + +/ { + model = "Atmel at91sam9260ek"; + compatible = "atmel,at91sam9260ek", "atmel,at91sam9260", "atmel,at91sam9"; + + chosen { + stdout-path = &dbgu; + }; + + memory { + reg = <0x20000000 0x4000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <18432000>; + }; + }; + + ahb { + apb { + usb1: gadget@fffa4000 { + atmel,vbus-gpio = <&pioC 5 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + + mmc0: mmc@fffa8000 { + pinctrl-0 = < + &pinctrl_board_mmc0_slot1 + &pinctrl_mmc0_clk + &pinctrl_mmc0_slot1_cmd_dat0 + &pinctrl_mmc0_slot1_dat1_3>; + status = "okay"; + slot@1 { + reg = <1>; + bus-width = <4>; + cd-gpios = <&pioC 9 GPIO_ACTIVE_HIGH>; + }; + }; + + usart0: serial@fffb0000 { + pinctrl-0 = + <&pinctrl_usart0 + &pinctrl_usart0_rts + &pinctrl_usart0_cts + &pinctrl_usart0_dtr_dsr + &pinctrl_usart0_dcd + &pinctrl_usart0_ri>; + status = "okay"; + }; + + usart1: serial@fffb4000 { + status = "okay"; + }; + + ssc0: ssc@fffbc000 { + status = "okay"; + pinctrl-0 = <&pinctrl_ssc0_tx>; + }; + + macb0: ethernet@fffc4000 { + phy-mode = "rmii"; + status = "okay"; + }; + + spi0: spi@fffc8000 { + cs-gpios = <0>, <&pioC 11 0>, <0>, <0>; + mtd_dataflash@0 { + compatible = "atmel,at45", "atmel,dataflash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; + }; + + dbgu: serial@fffff200 { + status = "okay"; + }; + + pinctrl@fffff400 { + board { + pinctrl_board_mmc0_slot1: mmc0_slot1-board { + atmel,pins = + <AT91_PIOC 9 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; + }; + }; + }; + + shdwc@fffffd10 { + atmel,wakeup-counter = <10>; + atmel,wakeup-rtt-timer; + }; + + rtc@fffffd20 { + atmel,rtt-rtc-time-reg = <&gpbr 0x0>; + status = "okay"; + }; + + watchdog@fffffd40 { + status = "okay"; + }; + + gpbr: syscon@fffffd50 { + status = "okay"; + }; + }; + + usb0: ohci@00500000 { + num-ports = <2>; + status = "okay"; + }; + + nand0: nand@40000000 { + nand-bus-width = <8>; + nand-ecc-mode = "soft"; + nand-on-flash-bbt; + status = "okay"; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + + btn3 { + label = "Button 3"; + gpios = <&pioA 30 GPIO_ACTIVE_LOW>; + linux,code = <0x103>; + wakeup-source; + }; + + btn4 { + label = "Button 4"; + gpios = <&pioA 31 GPIO_ACTIVE_LOW>; + linux,code = <0x104>; + wakeup-source; + }; + }; + + i2c-gpio-0 { + status = "okay"; + + 24c512@50 { + compatible = "24c512"; + reg = <0x50>; + }; + }; + + leds { + compatible = "gpio-leds"; + + ds1 { + label = "ds1"; + gpios = <&pioA 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + ds5 { + label = "ds5"; + gpios = <&pioA 6 GPIO_ACTIVE_LOW>; + }; + }; +}; diff --git a/arch/arm/dts/at91sam9g20.dtsi b/arch/arm/dts/at91sam9g20.dtsi index f593016181..e88d73ca8b 100644 --- a/arch/arm/dts/at91sam9g20.dtsi +++ b/arch/arm/dts/at91sam9g20.dtsi @@ -40,7 +40,7 @@ };
pmc: pmc@fffffc00 { - plla: pllack { + plla: pllack@0 { atmel,clk-input-range = <2000000 32000000>; atmel,pll-clk-output-ranges = <745000000 800000000 0 0>, <695000000 750000000 1 0>, @@ -52,7 +52,7 @@ <400000000 450000000 3 1>; };
- pllb: pllbck { + pllb: pllbck@1 { compatible = "atmel,at91sam9g20-clk-pllb"; atmel,clk-input-range = <2000000 32000000>; atmel,pll-clk-output-ranges = <30000000 100000000 0 0>; diff --git a/arch/arm/dts/at91sam9g20ek.dts b/arch/arm/dts/at91sam9g20ek.dts new file mode 100644 index 0000000000..bbfd753112 --- /dev/null +++ b/arch/arm/dts/at91sam9g20ek.dts @@ -0,0 +1,29 @@ +/* + * at91sam9g20ek.dts - Device Tree file for Atmel at91sam9g20ek board + * + * Copyright (C) 2012 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * Licensed under GPLv2. + */ +/dts-v1/; +#include "at91sam9g20ek_common.dtsi" + +/ { + model = "Atmel at91sam9g20ek"; + compatible = "atmel,at91sam9g20ek", "atmel,at91sam9g20", "atmel,at91sam9"; + + leds { + compatible = "gpio-leds"; + + ds1 { + label = "ds1"; + gpios = <&pioA 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + ds5 { + label = "ds5"; + gpios = <&pioA 6 GPIO_ACTIVE_LOW>; + }; + }; +}; diff --git a/arch/arm/dts/at91sam9g20ek_2mmc.dts b/arch/arm/dts/at91sam9g20ek_2mmc.dts new file mode 100644 index 0000000000..7ea83b6de8 --- /dev/null +++ b/arch/arm/dts/at91sam9g20ek_2mmc.dts @@ -0,0 +1,56 @@ +/* + * at91sam9g20ek_2mmc.dts - Device Tree file for Atmel at91sam9g20ek 2 MMC board + * + * Copyright (C) 2012 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * Licensed under GPLv2. + */ +/dts-v1/; +#include "at91sam9g20ek_common.dtsi" + +/ { + model = "Atmel at91sam9g20ek 2 mmc"; + compatible = "atmel,at91sam9g20ek_2mmc", "atmel,at91sam9g20", "atmel,at91sam9"; + + ahb { + apb{ + mmc0: mmc@fffa8000 { + /* clk already mux wuth slot0 */ + pinctrl-0 = < + &pinctrl_board_mmc0_slot0 + &pinctrl_mmc0_clk + &pinctrl_mmc0_slot0_cmd_dat0 + &pinctrl_mmc0_slot0_dat1_3>; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioC 2 GPIO_ACTIVE_HIGH>; + }; + }; + + pinctrl@fffff400 { + mmc0_slot0 { + pinctrl_board_mmc0_slot0: mmc0_slot0-board { + atmel,pins = + <AT91_PIOC 2 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PC2 gpio CD pin pull up and deglitch */ + }; + }; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + ds1 { + label = "ds1"; + gpios = <&pioB 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + ds5 { + label = "ds5"; + gpios = <&pioB 8 GPIO_ACTIVE_LOW>; + }; + }; +}; diff --git a/arch/arm/dts/at91sam9g20ek_common.dtsi b/arch/arm/dts/at91sam9g20ek_common.dtsi new file mode 100644 index 0000000000..60d1d59b5d --- /dev/null +++ b/arch/arm/dts/at91sam9g20ek_common.dtsi @@ -0,0 +1,223 @@ +/* + * at91sam9g20ek_common.dtsi - Device Tree file for Atmel at91sam9g20ek board + * + * Copyright (C) 2012 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * Licensed under GPLv2. + */ +#include "at91sam9g20.dtsi" + +/ { + chosen { + stdout-path = &dbgu; + }; + + memory { + reg = <0x20000000 0x4000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <18432000>; + }; + }; + + ahb { + apb { + pinctrl@fffff400 { + board { + pinctrl_pck0_as_mck: pck0_as_mck { + atmel,pins = + <AT91_PIOC 1 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PC1 periph B */ + }; + + }; + + mmc0_slot1 { + pinctrl_board_mmc0_slot1: mmc0_slot1-board { + atmel,pins = + <AT91_PIOC 9 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PC9 gpio CD pin pull up and deglitch */ + }; + }; + }; + + dbgu: serial@fffff200 { + status = "okay"; + }; + + usart0: serial@fffb0000 { + pinctrl-0 = + <&pinctrl_usart0 + &pinctrl_usart0_rts + &pinctrl_usart0_cts + &pinctrl_usart0_dtr_dsr + &pinctrl_usart0_dcd + &pinctrl_usart0_ri>; + status = "okay"; + }; + + usart1: serial@fffb4000 { + status = "okay"; + }; + + macb0: ethernet@fffc4000 { + phy-mode = "rmii"; + status = "okay"; + }; + + usb1: gadget@fffa4000 { + atmel,vbus-gpio = <&pioC 5 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + + mmc0: mmc@fffa8000 { + pinctrl-0 = < + &pinctrl_board_mmc0_slot1 + &pinctrl_mmc0_clk + &pinctrl_mmc0_slot1_cmd_dat0 + &pinctrl_mmc0_slot1_dat1_3>; + status = "okay"; + slot@1 { + reg = <1>; + bus-width = <4>; + cd-gpios = <&pioC 9 GPIO_ACTIVE_HIGH>; + }; + }; + + ssc0: ssc@fffbc000 { + status = "okay"; + pinctrl-0 = <&pinctrl_ssc0_tx>; + }; + + spi0: spi@fffc8000 { + cs-gpios = <0>, <&pioC 11 0>, <0>, <0>; + mtd_dataflash@0 { + compatible = "atmel,at45", "atmel,dataflash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; + }; + + shdwc@fffffd10 { + atmel,wakeup-counter = <10>; + atmel,wakeup-rtt-timer; + }; + + rtc@fffffd20 { + atmel,rtt-rtc-time-reg = <&gpbr 0x0>; + status = "okay"; + }; + + watchdog@fffffd40 { + status = "okay"; + }; + + gpbr: syscon@fffffd50 { + status = "okay"; + }; + }; + + nand0: nand@40000000 { + nand-bus-width = <8>; + nand-ecc-mode = "soft"; + nand-on-flash-bbt; + status = "okay"; + + at91bootstrap@0 { + label = "at91bootstrap"; + reg = <0x0 0x20000>; + }; + + barebox@20000 { + label = "barebox"; + reg = <0x20000 0x40000>; + }; + + bareboxenv@60000 { + label = "bareboxenv"; + reg = <0x60000 0x20000>; + }; + + bareboxenv2@80000 { + label = "bareboxenv2"; + reg = <0x80000 0x20000>; + }; + + oftree@80000 { + label = "oftree"; + reg = <0xa0000 0x20000>; + }; + + kernel@a0000 { + label = "kernel"; + reg = <0xc0000 0x400000>; + }; + + rootfs@4a0000 { + label = "rootfs"; + reg = <0x4c0000 0x7800000>; + }; + + data@7ca0000 { + label = "data"; + reg = <0x7cc0000 0x8340000>; + }; + }; + + usb0: ohci@00500000 { + num-ports = <2>; + status = "okay"; + }; + }; + + i2c-gpio-0 { + status = "okay"; + + 24c512@50 { + compatible = "24c512"; + reg = <0x50>; + }; + + wm8731: wm8731@1b { + compatible = "wm8731"; + reg = <0x1b>; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + + btn3 { + label = "Button 3"; + gpios = <&pioA 30 GPIO_ACTIVE_LOW>; + linux,code = <0x103>; + wakeup-source; + }; + + btn4 { + label = "Button 4"; + gpios = <&pioA 31 GPIO_ACTIVE_LOW>; + linux,code = <0x104>; + wakeup-source; + }; + }; + + sound { + compatible = "atmel,at91sam9g20ek-wm8731-audio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pck0_as_mck>; + + atmel,model = "wm8731 @ AT91SAMG20EK"; + + atmel,audio-routing = + "Ext Spk", "LHPOUT", + "Int Mic", "MICIN"; + + atmel,ssc-controller = <&ssc0>; + atmel,audio-codec = <&wm8731>; + }; +};
Enable CONFIG_CLK and CONFIG_PINCTRL to support at91 clock driver and at91 pinctrl driver.
Move some config options to configs/*_defconfig, and make the drivers, emac, gpio and mci to support the driver model.
configs/at91sam9260ek_dataflash_cs0_defconfig | 15 +++++++++++++-- configs/at91sam9260ek_dataflash_cs1_defconfig | 15 +++++++++++++-- configs/at91sam9260ek_nandflash_defconfig | 15 +++++++++++++-- configs/at91sam9g20ek_2mmc_defconfig | 16 +++++++++++++++- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 16 +++++++++++++++- configs/at91sam9g20ek_dataflash_cs0_defconfig | 15 +++++++++++++-- configs/at91sam9g20ek_dataflash_cs1_defconfig | 15 +++++++++++++-- configs/at91sam9g20ek_nandflash_defconfig | 16 ++++++++++++++-- include/configs/at91sam9260ek.h | 9 --------- 9 files changed, 109 insertions(+), 23 deletions(-)
diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 36423b2c73..2fe2a3908e 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 3b2817205e..cfbc87970c 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 4f88507b35..e38e9cb5a3 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 67c82326a4..4d49983dbc 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +20,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 6d2bfa1d6b..35e5b04e1b 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +20,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 4d94b84bd6..a9c42dde08 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index cbe0376b30..449837d9a3 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 1b53332759..022aa0bd99 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,17 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 022353c7fb..bed0adb269 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -45,7 +45,6 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ @@ -143,18 +142,10 @@ #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 #endif
-/* MMC */ -#ifdef CONFIG_CMD_MMC -#define CONFIG_GENERIC_ATMEL_MCI -#endif - /* NOR flash - no real flash on this board */ #define CONFIG_SYS_NO_FLASH 1
/* Ethernet */ -#define CONFIG_MACB 1 -#define CONFIG_RMII 1 -#define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R 1 #define CONFIG_AT91_WANTS_COMMON_PHY
Since the introduction of the pinctrl and clk drivers and the device tree files, remove unneeded hard coded related code from the board file.
board/atmel/at91sam9260ek/at91sam9260ek.c | 73 ------------------------------- 1 file changed, 73 deletions(-)
diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 98193bfdc6..e1bbc93924 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -13,12 +13,6 @@ #include <asm/arch/at91_common.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#include <atmel_mci.h> - -#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) -# include <net.h> -#endif -#include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -67,63 +61,8 @@ static void at91sam9260ek_nand_hw_init(void) } #endif
-#ifdef CONFIG_MACB -static void at91sam9260ek_macb_hw_init(void) -{ - struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - - at91_periph_clk_enable(ATMEL_ID_EMAC0); - - /* - * Disable pull-up on: - * RXDV (PA17) => PHY normal mode (not Test mode) - * ERX0 (PA14) => PHY ADDR0 - * ERX1 (PA15) => PHY ADDR1 - * ERX2 (PA25) => PHY ADDR2 - * ERX3 (PA26) => PHY ADDR3 - * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 - * - * PHY has internal pull-down - */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - &pioa->pudr); - - at91_phy_reset(); - - /* Re-enable pull-up */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - &pioa->puer); - - /* Initialize EMAC=MACB hardware */ - at91_macb_hw_init(); -} -#endif - -#ifdef CONFIG_GENERIC_ATMEL_MCI -int board_mmc_init(bd_t *bd) -{ - at91_mci_hw_init(); - - return atmel_mci_init((void *)ATMEL_BASE_MCI); -} -#endif - int board_early_init_f(void) { - at91_periph_clk_enable(ATMEL_ID_PIOA); - at91_periph_clk_enable(ATMEL_ID_PIOB); - at91_periph_clk_enable(ATMEL_ID_PIOC); - return 0; }
@@ -139,9 +78,6 @@ int board_init(void) #ifdef CONFIG_HAS_DATAFLASH at91_spi0_hw_init((1 << 0) | (1 << 1)); #endif -#ifdef CONFIG_MACB - at91sam9260ek_macb_hw_init(); -#endif
return 0; } @@ -159,12 +95,3 @@ void reset_phy(void) { } #endif - -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x00); -#endif - return rc; -}
Wenyou Yang
