[U-Boot-Users] [PATCH 2/2] mpc85xx: Add support for ATUM8548
Please disregard [PATCH 2/3] as there are only two patches here - resending patch 2...
Add support for Instituto Atlantico's ATUM8548 board
Signed-off-by: robert lazarski robertlazarski@gmail.com
diff --git a/board/atum8548/Makefile b/board/atum8548/Makefile new file mode 100644 index 0000000..e198062 --- /dev/null +++ b/board/atum8548/Makefile @@ -0,0 +1,56 @@ +# +# Copyright 2004 Freescale Semiconductor. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk +ifneq ($(OBJTREE),$(SRCTREE)) +$(shell mkdir -p $(obj)../common) +endif + +LIB = $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o + +SOBJS := init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atum8548/atum8548.c b/board/atum8548/atum8548.c new file mode 100644 index 0000000..4791071 --- /dev/null +++ b/board/atum8548/atum8548.c @@ -0,0 +1,431 @@ +/* + * Copyright 2007 + * Robert Lazarski, Instituto Atlantico, robertlazarski@gmail.com + * + * Copyright 2007 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/processor.h> +#include <asm/immap_85xx.h> +#include <asm/immap_fsl_pci.h> +#include <asm/io.h> +#include <spd.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +#if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) +extern void ddr_enable_ecc(unsigned int dram_size); +#endif + +extern long int spd_sdram(void); +long int fixed_sdram(void); + +int board_early_init_f (void) +{ + return 0; +} + +int checkboard (void) +{ + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + volatile ccsr_lbc_t *lbc = (void *)(CFG_MPC85xx_LBC_ADDR); + volatile ccsr_local_ecm_t *ecm = (void *)(CFG_MPC85xx_ECM_ADDR); + + if ((uint)&gur->porpllsr != 0xe00e0000) { + printf("immap size error %x\n",&gur->porpllsr); + } + printf ("Board: ATUM8548\n"); + + lbc->ltesr = 0xffffffff; /* Clear LBC error interrupts */ + lbc->lteir = 0xffffffff; /* Enable LBC error interrupts */ + ecm->eedr = 0xffffffff; /* Clear ecm errors */ + ecm->eeer = 0xffffffff; /* Enable ecm errors */ + + return 0; +} + +#if !defined(CONFIG_SPD_EEPROM) +/************************************************************************* + * fixed sdram init -- doesn't use serial presence detect. + ************************************************************************/ +long int fixed_sdram (void) +{ + volatile ccsr_ddr_t *ddr= (void *)(CFG_MPC85xx_DDR_ADDR); + + ddr->cs0_bnds = CFG_DDR_CS0_BNDS; + ddr->cs0_config = CFG_DDR_CS0_CONFIG; + ddr->timing_cfg_0 = CFG_DDR_TIMING_0; + ddr->timing_cfg_1 = CFG_DDR_TIMING_1; + ddr->timing_cfg_2 = CFG_DDR_TIMING_2; + ddr->sdram_mode = CFG_DDR_MODE; + ddr->sdram_interval = CFG_DDR_INTERVAL; + #if defined (CONFIG_DDR_ECC) + ddr->err_disable = 0x0000000D; + ddr->err_sbe = 0x00ff0000; + #endif + asm("sync;isync;msync"); + udelay(500); + #if defined (CONFIG_DDR_ECC) + /* Enable ECC checking */ + ddr->sdram_cfg = (CFG_DDR_CONTROL | 0x20000000); + #else + ddr->sdram_cfg = CFG_DDR_CONTROL; + #endif + asm("sync; isync; msync"); + udelay(500); + return CFG_SDRAM_SIZE * 1024 * 1024; +} +#endif /* !defined(CONFIG_SPD_EEPROM) */ + +long int +initdram(int board_type) +{ + long dram_size = 0; + + puts("Initializing\n"); + +#if defined(DISABLE_ICACHE) + /* + * Certain memory chips are known to have burst mode + * issues on this board, so during testing we + * allow the disabling of the instruction cache until + * a future revision of the board resolves these issues. + */ + icache_disable(); + puts("icache_disabled\n"); +#endif + +#if defined(CONFIG_SPD_EEPROM) + puts("spd_sdram\n"); + dram_size = spd_sdram (); +#else + puts("fixed_sdram\n"); + dram_size = fixed_sdram (); +#endif + +#if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) + /* + * Initialize and enable DDR ECC. + */ + ddr_enable_ecc(dram_size); +#endif + puts(" DDR: "); + return dram_size; +} + +#if defined(CFG_DRAM_TEST) +int +testdram(void) +{ + uint *pstart = (uint *) CFG_MEMTEST_START; + uint *pend = (uint *) CFG_MEMTEST_END; + uint *p; + + printf("Testing DRAM from 0x%08x to 0x%08x\n", + CFG_MEMTEST_START, + CFG_MEMTEST_END); + + printf("DRAM test phase 1:\n"); + for (p = pstart; p < pend; p++) { + printf ("DRAM test attempting to write 0xaaaaaaaa at: %08x\n", (uint) p); + *p = 0xaaaaaaaa; + } + + for (p = pstart; p < pend; p++) { + if (*p != 0xaaaaaaaa) { + printf ("DRAM test fails at: %08x\n", (uint) p); + return 1; + } + } + + printf("DRAM test phase 2:\n"); + for (p = pstart; p < pend; p++) + *p = 0x55555555; + + for (p = pstart; p < pend; p++) { + if (*p != 0x55555555) { + printf ("DRAM test fails at: %08x\n", (uint) p); + return 1; + } + } + + printf("DRAM test passed.\n"); + return 0; +} +#endif + +#ifdef CONFIG_PCI1 +static struct pci_controller pci1_hose; +#endif + +#ifdef CONFIG_PCI2 +static struct pci_controller pci2_hose; +#endif + +#ifdef CONFIG_PCIE1 +static struct pci_controller pcie1_hose; +#endif + +int first_free_busno=0; + +void +pci_init_board(void) +{ + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + + uint devdisr = gur->devdisr; + uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; + uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; + + debug (" pci_init_board: devdisr=%x, io_sel=%x, host_agent=%x\n", + devdisr, io_sel, host_agent); + + /* explicitly set 'Clock out select register' to echo SYSCLK input to our CPLD */ + gur->clkocr |= MPC85xx_ATUM_CLKOCR; + + if (io_sel & 1) { + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII1_DIS)) + printf (" eTSEC1 is in sgmii mode.\n"); + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII2_DIS)) + printf (" eTSEC2 is in sgmii mode.\n"); + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII3_DIS)) + printf (" eTSEC3 is in sgmii mode.\n"); + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII4_DIS)) + printf (" eTSEC4 is in sgmii mode.\n"); + } + +#ifdef CONFIG_PCIE1 + { + volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CFG_PCIE1_ADDR; + extern void fsl_pci_init(struct pci_controller *hose); + struct pci_controller *hose = &pcie1_hose; + int pcie_ep = (host_agent == 5); + int pcie_configured = io_sel & 6; + + if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ + printf ("\n PCIE1 connected to slot as %s (base address %x)", + pcie_ep ? "End Point" : "Root Complex", + (uint)pci); + if (pci->pme_msg_det) { + pci->pme_msg_det = 0xffffffff; + debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); + } + printf ("\n"); + + /* inbound */ + pci_set_region(hose->regions + 0, + CFG_PCI_MEMORY_BUS, + CFG_PCI_MEMORY_PHYS, + CFG_PCI_MEMORY_SIZE, + PCI_REGION_MEM | PCI_REGION_MEMORY); + + /* outbound memory */ + pci_set_region(hose->regions + 1, + CFG_PCIE1_MEM_BASE, + CFG_PCIE1_MEM_PHYS, + CFG_PCIE1_MEM_SIZE, + PCI_REGION_MEM); + + /* outbound io */ + pci_set_region(hose->regions + 2, + CFG_PCIE1_IO_BASE, + CFG_PCIE1_IO_PHYS, + CFG_PCIE1_IO_SIZE, + PCI_REGION_IO); + + hose->region_count = 3; +#ifdef CFG_PCIE1_MEM_BASE2 + /* outbound memory */ + pci_set_region(hose->regions + 3, + CFG_PCIE1_MEM_BASE2, + CFG_PCIE1_MEM_PHYS2, + CFG_PCIE1_MEM_SIZE2, + PCI_REGION_MEM); + hose->region_count++; +#endif + hose->first_busno=first_free_busno; + + pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); + + fsl_pci_init(hose); + + first_free_busno=hose->last_busno+1; + printf(" PCIE1 on bus %02x - %02x\n", + hose->first_busno,hose->last_busno); + + } else { + printf (" PCIE1: disabled\n"); + } + + } +#else + gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ +#endif + +#ifdef CONFIG_PCI1 +{ + volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CFG_PCI1_ADDR; + extern void fsl_pci_init(struct pci_controller *hose); + struct pci_controller *hose = &pci1_hose; + + uint pci_agent = (host_agent == 6); + uint pci_speed = 33333000; /*get_clock_freq (); PCI PSPEED in [4:5] */ + uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ + uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ + uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */ + + if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { + printf ("\n PCI1: %d bit, %s MHz, %s, %s, %s (base address %x)\n", + (pci_32) ? 32 : 64, + (pci_speed == 33333000) ? "33" : + (pci_speed == 66666000) ? "66" : "unknown", + pci_clk_sel ? "sync" : "async", + pci_agent ? "agent" : "host", + pci_arb ? "arbiter" : "external-arbiter", + (uint)pci + ); + + /* inbound */ + pci_set_region(hose->regions + 0, + CFG_PCI_MEMORY_BUS, + CFG_PCI_MEMORY_PHYS, + CFG_PCI_MEMORY_SIZE, + PCI_REGION_MEM | PCI_REGION_MEMORY); + + /* outbound memory */ + pci_set_region(hose->regions + 1, + CFG_PCI1_MEM_BASE, + CFG_PCI1_MEM_PHYS, + CFG_PCI1_MEM_SIZE, + PCI_REGION_MEM); + + /* outbound io */ + pci_set_region(hose->regions + 2, + CFG_PCI1_IO_BASE, + CFG_PCI1_IO_PHYS, + CFG_PCI1_IO_SIZE, + PCI_REGION_IO); + hose->region_count = 3; + hose->first_busno=first_free_busno; + pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); + + fsl_pci_init(hose); + first_free_busno=hose->last_busno+1; + printf ("PCI1 on bus %02x - %02x\n", + hose->first_busno,hose->last_busno); + } else { + printf (" PCI1: disabled\n"); + } +} +#else + gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ +#endif + +#ifdef CONFIG_PCI2 +{ + volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CFG_PCI2_ADDR; + extern void fsl_pci_init(struct pci_controller *hose); + struct pci_controller *hose = &pci2_hose; + + if (!(devdisr & MPC85xx_DEVDISR_PCI2)) { + pci_set_region(hose->regions + 0, + CFG_PCI_MEMORY_BUS, + CFG_PCI_MEMORY_PHYS, + CFG_PCI_MEMORY_SIZE, + PCI_REGION_MEM | PCI_REGION_MEMORY); + + pci_set_region(hose->regions + 1, + CFG_PCI2_MEM_BASE, + CFG_PCI2_MEM_PHYS, + CFG_PCI2_MEM_SIZE, + PCI_REGION_MEM); + + pci_set_region(hose->regions + 2, + CFG_PCI2_IO_BASE, + CFG_PCI2_IO_PHYS, + CFG_PCI2_IO_SIZE, + PCI_REGION_IO); + hose->region_count = 3; + hose->first_busno=first_free_busno; + pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); + + fsl_pci_init(hose); + first_free_busno=hose->last_busno+1; + printf ("PCI2 on bus %02x - %02x\n", + hose->first_busno,hose->last_busno); + } else { + printf (" PCI2: disabled\n"); + } +} +#else + gur->devdisr |= MPC85xx_DEVDISR_PCI2; +#endif +} + + +int last_stage_init(void) +{ + int ic = icache_status (); + printf ("icache_status: %d\n", ic); + return 0; +} + +#if defined(CONFIG_OF_BOARD_SETUP) + +void +ft_board_setup(void *blob, bd_t *bd) +{ + int node, tmp[2]; + const char *path; + + ft_cpu_setup(blob, bd); + + node = fdt_path_offset(blob, "/aliases"); + tmp[0] = 0; + if (node >= 0) { +#ifdef CONFIG_PCI1 + path = fdt_getprop(blob, node, "pci0", NULL); + if (path) { + tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } +#endif +#ifdef CONFIG_PCI2 + path = fdt_getprop(blob, node, "pci1", NULL); + if (path) { + tmp[1] = pci2_hose.last_busno - pci2_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } +#endif +#ifdef CONFIG_PCIE1 + path = fdt_getprop(blob, node, "pci2", NULL); + if (path) { + tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } +#endif + } +} +#endif diff --git a/board/atum8548/config.mk b/board/atum8548/config.mk new file mode 100644 index 0000000..9065817 --- /dev/null +++ b/board/atum8548/config.mk @@ -0,0 +1,33 @@ +# +# Copyright 2004, 2007 Freescale Semiconductor. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# +# atum8548 board +# TEXT_BASE = 0xfff80000 +# TEXT_BASE = 0xfffff000 +ifndef TEXT_BASE +TEXT_BASE = 0xfff80000 +endif + +PLATFORM_CPPFLAGS += -DCONFIG_E500=1 +PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 +PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 diff --git a/board/atum8548/init.S b/board/atum8548/init.S new file mode 100644 index 0000000..2f016ab --- /dev/null +++ b/board/atum8548/init.S @@ -0,0 +1,242 @@ +/* + * Copyright 2007 + * Robert Lazarski, Instituto Atlantico, robertlazarski@gmail.com + * Copyright 2004, 2007 Freescale Semiconductor. + * Copyright 2002,2003, Motorola Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <ppc_asm.tmpl> +#include <ppc_defs.h> +#include <asm/cache.h> +#include <asm/mmu.h> +#include <config.h> +#include <mpc85xx.h> + +#define LAWAR_TRGT_PCI1 0x00000000 +#define LAWAR_TRGT_PCI2 0x00100000 +#define LAWAR_TRGT_PCIE 0x00200000 +#define LAWAR_TRGT_DDR 0x00f00000 + +/* + * TLB0 and TLB1 Entries + * + * Out of reset, TLB1's Entry 0 maps the highest 4K for CCSRBAR. + * However, CCSRBAR is then relocated to CFG_CCSRBAR right after + * these TLB entries are established. + * + * The TLB entries for DDR are dynamically setup in spd_sdram() + * and use TLB1 Entries 8 through 15 as needed according to the + * size of DDR memory. + * + * MAS0: tlbsel, esel, nv + * MAS1: valid, iprot, tid, ts, tsize + * MAS2: epn, sharen, x0, x1, w, i, m, g, e + * MAS3: rpn, u0-u3, ux, sx, uw, sw, ur, sr + */ + +#define entry_start \ + mflr r1 ; \ + bl 0f ; + +#define entry_end \ +0: mflr r0 ; \ + mtlr r1 ; \ + blr ; + + + .section .bootpg, "ax" + .globl tlb1_entry +tlb1_entry: + entry_start + + /* + * Number of TLB0 and TLB1 entries in the following table + */ + .long (2f-1f)/16 + +1: +#if (CFG_CCSRBAR_DEFAULT != CFG_CCSRBAR) + /* + * TLB0 4K Non-cacheable, guarded + * 0xff700000 4K Initial CCSRBAR mapping + * + * This ends up at a TLB0 Index==0 entry, and must not collide + * with other TLB0 Entries. + */ + .long TLB1_MAS0(0, 0, 0) + .long TLB1_MAS1(1, 0, 0, 0, 0) + .long TLB1_MAS2(E500_TLB_EPN(CFG_CCSRBAR_DEFAULT), 0,0,0,0,1,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_CCSRBAR_DEFAULT), 0,0,0,0,0,1,0,1,0,1) +#else +#error("Update the number of table entries in tlb1_entry") +#endif + + /* + * TLB0 16K Cacheable, guarded + * Temporary Global data for initialization + * + * Use four 4K TLB0 entries. These entries must be cacheable + * as they provide the bootstrap memory before the memory + * controler and real memory have been configured. + * + * These entries end up at TLB0 Indicies 0x10, 0x14, 0x18 and 0x1c, + * and must not collide with other TLB0 entries. + */ + .long TLB1_MAS0(0, 0, 0) + .long TLB1_MAS1(1, 0, 0, 0, 0) + .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR), + 0,0,0,0,0,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR), + 0,0,0,0,0,1,0,1,0,1) + + .long TLB1_MAS0(0, 0, 0) + .long TLB1_MAS1(1, 0, 0, 0, 0) + .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 4 * 1024), + 0,0,0,0,0,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 4 * 1024), + 0,0,0,0,0,1,0,1,0,1) + + .long TLB1_MAS0(0, 0, 0) + .long TLB1_MAS1(1, 0, 0, 0, 0) + .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 8 * 1024), + 0,0,0,0,0,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 8 * 1024), + 0,0,0,0,0,1,0,1,0,1) + + .long TLB1_MAS0(0, 0, 0) + .long TLB1_MAS1(1, 0, 0, 0, 0) + .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 12 * 1024), + 0,0,0,0,0,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 12 * 1024), + 0,0,0,0,0,1,0,1,0,1) + + /* TLB 1 Initializations */ + /* + * TLB 0, 1: 128M Non-cacheable, guarded + * 0xf8000000 128M FLASH + * Out of reset this entry is only 4K. + */ + .long TLB1_MAS0(1, 0, 0) + .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) + .long TLB1_MAS2(E500_TLB_EPN(CFG_FLASH_BASE + 0x4000000), + 0,0,0,0,1,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_FLASH_BASE + 0x4000000), + 0,0,0,0,0,1,0,1,0,1) + + .long TLB1_MAS0(1, 1, 0) + .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) + .long TLB1_MAS2(E500_TLB_EPN(CFG_FLASH_BASE), 0,0,0,0,1,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_FLASH_BASE), 0,0,0,0,0,1,0,1,0,1) + + /* + * TLB 2: 1G Non-cacheable, guarded + * 0x80000000 1G PCI1/PCIE 8,9,a,b + */ + .long TLB1_MAS0(1, 2, 0) + .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_1G) + .long TLB1_MAS2(E500_TLB_EPN(CFG_PCI_PHYS), 0,0,0,0,1,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_PCI_PHYS), 0,0,0,0,0,1,0,1,0,1) + + /* + * TLB 3, 4: 512M Non-cacheable, guarded + * 0xc0000000 1G PCI2 + */ + .long TLB1_MAS0(1, 3, 0) + .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) + .long TLB1_MAS2(E500_TLB_EPN(CFG_PCI2_MEM_PHYS), + 0,0,0,0,1,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_PCI2_MEM_PHYS), 0,0,0,0,0,1,0,1,0,1) + .long TLB1_MAS0(1, 4, 0) + .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) + .long TLB1_MAS2(E500_TLB_EPN(CFG_PCI2_MEM_PHYS + 0x10000000), + 0,0,0,0,1,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_PCI2_MEM_PHYS + 0x10000000), + 0,0,0,0,0,1,0,1,0,1) + + /* + * TLB 5: 64M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + * 0xe200_0000 1M PCI1 IO + * 0xe210_0000 1M PCI2 IO + * 0xe300_0000 1M PCIe IO + */ + .long TLB1_MAS0(1, 5, 0) + .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) + .long TLB1_MAS2(E500_TLB_EPN(CFG_CCSRBAR), 0,0,0,0,1,0,1,0) + .long TLB1_MAS3(E500_TLB_RPN(CFG_CCSRBAR), 0,0,0,0,0,1,0,1,0,1) + +2: + entry_end + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x7fff_ffff DDR 2G + * 0x8000_0000 0x9fff_ffff PCI1 MEM 512M + * 0xa000_0000 0xbfff_ffff PCIe MEM 512M + * 0xc000_0000 0xdfff_ffff PCI2 MEM 512M + * 0xe000_0000 0xe000_ffff CCSR 1M + * 0xe200_0000 0xe10f_ffff PCI1 IO 1M + * 0xe280_0000 0xe20f_ffff PCI2 IO 1M + * 0xe300_0000 0xe30f_ffff PCIe IO 1M + * 0xf800_0000 0xffff_ffff FLASH (boot bank) 128M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + + .section .bootpg, "ax" + .globl law_entry +law_entry: + entry_start + + .long (4f-3f)/8 +3: + .long 0 + .long (LAWAR_TRGT_DDR | (LAWAR_SIZE & LAWAR_SIZE_1G)) & ~LAWAR_EN + + .long (CFG_PCI1_MEM_PHYS>>12) & 0xfffff + .long LAWAR_EN | LAWAR_TRGT_PCI1 | (LAWAR_SIZE & LAWAR_SIZE_512M) + + .long (CFG_PCI1_IO_PHYS>>12) & 0xfffff + .long LAWAR_EN | LAWAR_TRGT_PCI1 | (LAWAR_SIZE & LAWAR_SIZE_1M) + + .long (CFG_PCI2_MEM_PHYS>>12) & 0xfffff + .long LAWAR_EN | LAWAR_TRGT_PCI2 | (LAWAR_SIZE & LAWAR_SIZE_512M) + + .long (CFG_PCI2_IO_PHYS>>12) & 0xfffff + .long LAWAR_EN | LAWAR_TRGT_PCI2 | (LAWAR_SIZE & LAWAR_SIZE_1M) + + .long (CFG_PCIE1_MEM_PHYS>>12) & 0xfffff + .long LAWAR_EN | LAWAR_TRGT_PCIE | (LAWAR_SIZE & LAWAR_SIZE_512M) + + .long (CFG_PCIE1_IO_PHYS>>12) & 0xfffff + .long LAWAR_EN | LAWAR_TRGT_PCIE | (LAWAR_SIZE & LAWAR_SIZE_1M) + + /* LBC window - maps 256M 0xf0000000 -> 0xffffffff */ + .long (CFG_LBC_CACHE_BASE>>12) & 0xfffff + .long LAWAR_EN | LAWAR_TRGT_IF_LBC | (LAWAR_SIZE & LAWAR_SIZE_256M) + +4: + entry_end
robert lazarski
