[U-Boot] [PATCH 1/4] SPL: powerpc: expand SPL's length to 128K
1. The SPL's length of SDCARD boot has not enough,expand the SPL's length to 128K. 2. deleted unused symbol: CONFIG_SYS_RUN_INDDR
Signed-off-by: Ying Zhang b40530@freescale.com --- include/configs/P1022DS.h | 12 ++++++------ include/configs/p1_p2_rdb_pc.h | 12 ++++++------ 2 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 9c9d72b..edc8931 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -30,12 +30,12 @@ #define CONFIG_FSL_LAW /* Use common FSL init code */ #define CONFIG_SYS_TEXT_BASE 0x11001000 #define CONFIG_SPL_TEXT_BASE 0xf8f81000 -#define CONFIG_SPL_PAD_TO 0x18000 -#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SPL_PAD_TO 0x20000 +#define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_MMC_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) -#define CONFIG_SYS_MMC_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_MMC_U_BOOT_OFFS (128 << 10) #define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" #define CONFIG_SPL_MMC_BOOT @@ -60,12 +60,12 @@ #define CONFIG_FSL_LAW /* Use common FSL init code */ #define CONFIG_SYS_TEXT_BASE 0x11001000 #define CONFIG_SPL_TEXT_BASE 0xf8f81000 -#define CONFIG_SPL_PAD_TO 0x18000 -#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SPL_PAD_TO 0x20000 +#define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) -#define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (128 << 10) #define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" #define CONFIG_SPL_SPI_BOOT diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 95e23ac..4cabf04 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -159,12 +159,12 @@ #define CONFIG_FSL_LAW /* Use common FSL init code */ #define CONFIG_SYS_TEXT_BASE 0x11001000 #define CONFIG_SPL_TEXT_BASE 0xf8f81000 -#define CONFIG_SPL_PAD_TO 0x18000 -#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SPL_PAD_TO 0x20000 +#define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_MMC_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) -#define CONFIG_SYS_MMC_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_MMC_U_BOOT_OFFS (128 << 10) #define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" #define CONFIG_SPL_MMC_BOOT @@ -189,12 +189,12 @@ #define CONFIG_FSL_LAW /* Use common FSL init code */ #define CONFIG_SYS_TEXT_BASE 0x11001000 #define CONFIG_SPL_TEXT_BASE 0xf8f81000 -#define CONFIG_SPL_PAD_TO 0x18000 -#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SPL_PAD_TO 0x20000 +#define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) -#define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (128 << 10) #define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" #define CONFIG_SPL_SPI_BOOT
There was no enough stack in SPL, so the buffer needed in SPL is to malloc from memory pool and to repalce the temporary variable.
Signed-off-by: Ying Zhang b40530@freescale.com --- common/env_sf.c | 7 ++++++- include/configs/p1_p2_rdb_pc.h | 6 +++++- 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/common/env_sf.c b/common/env_sf.c index 9f806fb..be270f2 100644 --- a/common/env_sf.c +++ b/common/env_sf.c @@ -299,13 +299,16 @@ int saveenv(void)
void env_relocate_spec(void) { - char buf[CONFIG_ENV_SIZE]; int ret; + char *buf = NULL;
+ buf = (char *)malloc(CONFIG_ENV_SIZE); env_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); if (!env_flash) { set_default_env("!spi_flash_probe() failed"); + if (buf) + free(buf); return; }
@@ -321,6 +324,8 @@ void env_relocate_spec(void) gd->env_valid = 1; out: spi_flash_free(env_flash); + if (buf) + free(buf); env_flash = NULL; } #endif diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 4cabf04..f455437 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -580,11 +580,15 @@ #define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) #define CONFIG_SPL_RELOC_TEXT_BASE 0xf8f81000 +#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) #define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 128 * 1024) #define CONFIG_SPL_RELOC_STACK_SIZE (32 << 10) #define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 160 * 1024) +#if defined(CONFIG_P2020RDB) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (352 << 10) +#else #define CONFIG_SPL_RELOC_MALLOC_SIZE (96 << 10) -#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) +#endif #elif defined(CONFIG_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000
Signed-off-by: Ying Zhang b40530@freescale.com --- include/configs/P1022DS.h | 6 +++--- include/configs/p1_p2_rdb_pc.h | 8 ++++---- 2 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index edc8931..e9e7e88 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -366,10 +366,10 @@ #define CONFIG_SYS_L2_SIZE (256 << 10) #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) #define CONFIG_SPL_RELOC_TEXT_BASE 0xf8f81000 -#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 128 * 1024) +#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 116 * 1024) #define CONFIG_SPL_RELOC_STACK_SIZE (32 << 10) -#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 160 * 1024) -#define CONFIG_SPL_RELOC_MALLOC_SIZE (96 << 10) +#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 148 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (108 << 10) #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) #elif defined(CONFIG_NAND) #ifdef CONFIG_TPL_BUILD diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index f455437..1e8e617 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -581,13 +581,13 @@ #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) #define CONFIG_SPL_RELOC_TEXT_BASE 0xf8f81000 #define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) -#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 128 * 1024) +#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 116 * 1024) #define CONFIG_SPL_RELOC_STACK_SIZE (32 << 10) -#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 160 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 148 * 1024) #if defined(CONFIG_P2020RDB) -#define CONFIG_SPL_RELOC_MALLOC_SIZE (352 << 10) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (364 << 10) #else -#define CONFIG_SPL_RELOC_MALLOC_SIZE (96 << 10) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (108 << 10) #endif #elif defined(CONFIG_NAND) #ifdef CONFIG_TPL_BUILD
In the previous patches, we introduced the SPL/TPL fraamework. For SD/SPI flash booting way, we introduce the SPL to enable a loader stub. The SPL was loaded by the code from the internal on-chip ROM. The SPL initializes the DDR according to the SPD and loads the final uboot image into DDR, then jump to the DDR to begin execution.
For NAND booting way, the nand SPL has size limitation on some board(e.g. P1010RDB), it can not be more than 8KB, we can call it "minimal SPL", So the dynamic DDR driver doesn't fit into this minimum SPL. We added the TPL that is loaded by the the minimal SPL. The TPL initializes the DDR according to the SPD and loads the final uboot image into DDR,then jump to the DDR to begin execution.
This patch enabled SPL/TPL for P1010RDB to support starting from NAND/SD/SPI flash with SPL framework and initializing the DDR according to SPD in the SPL/TPL. Because the minimal SPL load the TPL to L2 SRAM and the jump to the L2 SRAM to execute, so the section .resetvec is no longer needed.
Signed-off-by: Ying Zhang b40530@freescale.com --- board/freescale/p1010rdb/Makefile | 4 + board/freescale/p1010rdb/spl.c | 108 +++++++++++++++++++++++ board/freescale/p1010rdb/spl_minimal.c | 76 ++-------------- board/freescale/p1010rdb/tlb.c | 12 ++- include/configs/P1010RDB.h | 156 +++++++++++++++++++++++++++++++-- 5 files changed, 275 insertions(+), 81 deletions(-) create mode 100644 board/freescale/p1010rdb/spl.c
diff --git a/board/freescale/p1010rdb/Makefile b/board/freescale/p1010rdb/Makefile index d6f05f3..660d1bb 100644 --- a/board/freescale/p1010rdb/Makefile +++ b/board/freescale/p1010rdb/Makefile @@ -18,6 +18,10 @@ obj-y += spl_minimal.o tlb.o law.o
else
+ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif + obj-y += p1010rdb.o obj-y += ddr.o obj-y += law.o diff --git a/board/freescale/p1010rdb/spl.c b/board/freescale/p1010rdb/spl.c new file mode 100644 index 0000000..824941e --- /dev/null +++ b/board/freescale/p1010rdb/spl.c @@ -0,0 +1,108 @@ +/* Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <ns16550.h> +#include <malloc.h> +#include <mmc.h> +#include <nand.h> +#include <i2c.h> +#include <fsl_esdhc.h> +#include <spi_flash.h> + +DECLARE_GLOBAL_DATA_PTR; + +ulong get_effective_memsize(void) +{ + return CONFIG_SYS_L2_SIZE; +} + +void board_init_f(ulong bootflag) +{ + u32 plat_ratio; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + struct fsl_ifc *ifc = (void *)CONFIG_SYS_IFC_ADDR; + + console_init_f(); + + /* Clock configuration to access CPLD using IFC(GPCM) */ + setbits_be32(&ifc->ifc_gcr, 1 << IFC_GCR_TBCTL_TRN_TIME_SHIFT); + +#ifdef CONFIG_P1010RDB_PB + setbits_be32(&gur->pmuxcr2, MPC85xx_PMUXCR2_GPIO01_DRVVBUS); +#endif + + /* initialize selected port with appropriate baud rate */ + plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; + plat_ratio >>= 1; + gd->bus_clk = CONFIG_SYS_CLK_FREQ * plat_ratio; + + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, + gd->bus_clk / 16 / CONFIG_BAUDRATE); + +#ifdef CONFIG_SPL_MMC_BOOT + puts("\nSD boot...\n"); +#elif defined(CONFIG_SPL_SPI_BOOT) + puts("\nSPI Flash boot...\n"); +#endif + /* copy code to RAM and jump to it - this should not return */ + /* NOTE - code has to be copied out of NAND buffer before + * other blocks can be read. + */ + relocate_code(CONFIG_SPL_RELOC_STACK, 0, CONFIG_SPL_RELOC_TEXT_BASE); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + /* Pointer is writable since we allocated a register for it */ + gd = (gd_t *)CONFIG_SPL_GD_ADDR; + bd_t *bd; + + memset(gd, 0, sizeof(gd_t)); + bd = (bd_t *)(CONFIG_SPL_GD_ADDR + sizeof(gd_t)); + memset(bd, 0, sizeof(bd_t)); + gd->bd = bd; + bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; + bd->bi_memsize = CONFIG_SYS_L2_SIZE; + + probecpu(); + get_clocks(); + mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, + CONFIG_SPL_RELOC_MALLOC_SIZE); + +#ifndef CONFIG_SPL_NAND_BOOT + env_init(); +#endif +#ifdef CONFIG_SPL_MMC_BOOT + mmc_initialize(bd); +#endif + + /* relocate environment function pointers etc. */ +#ifdef CONFIG_SPL_NAND_BOOT + nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (uchar *)CONFIG_ENV_ADDR); + gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + gd->env_valid = 1; +#else + env_relocate(); +#endif + + i2c_init_all(); + + gd->ram_size = initdram(0); +#ifdef CONFIG_SPL_NAND_BOOT + puts("\nTertiary program loader running in sram..."); +#else + puts("\nSecond program loader running in sram..."); +#endif + +#ifdef CONFIG_SPL_MMC_BOOT + mmc_boot(); +#elif defined(CONFIG_SPL_SPI_BOOT) + spi_boot(); +#elif defined(CONFIG_SPL_NAND_BOOT) + nand_boot(); +#endif +} diff --git a/board/freescale/p1010rdb/spl_minimal.c b/board/freescale/p1010rdb/spl_minimal.c index 39a5a0f..6079570 100644 --- a/board/freescale/p1010rdb/spl_minimal.c +++ b/board/freescale/p1010rdb/spl_minimal.c @@ -16,78 +16,16 @@
- -void sdram_init(void) -{ - struct ccsr_ddr __iomem *ddr = - (struct ccsr_ddr __iomem *)CONFIG_SYS_FSL_DDR_ADDR; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - u32 ddr_ratio; - unsigned long ddr_freq_mhz; - - ddr_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_DDR_RATIO; - ddr_ratio = ddr_ratio >> MPC85xx_PORPLLSR_DDR_RATIO_SHIFT; - ddr_freq_mhz = (CONFIG_SYS_CLK_FREQ * ddr_ratio) / 1000000; - - /* mask off E bit */ - u32 svr = SVR_SOC_VER(mfspr(SPRN_SVR)); - - __raw_writel(CONFIG_SYS_DDR_CONTROL | SDRAM_CFG_32_BE, &ddr->sdram_cfg); - __raw_writel(CONFIG_SYS_DDR_CS0_BNDS, &ddr->cs0_bnds); - __raw_writel(CONFIG_SYS_DDR_CS0_CONFIG, &ddr->cs0_config); - __raw_writel(CONFIG_SYS_DDR_CONTROL_2, &ddr->sdram_cfg_2); - __raw_writel(CONFIG_SYS_DDR_DATA_INIT, &ddr->sdram_data_init); - - if (ddr_freq_mhz < 700) { - __raw_writel(CONFIG_SYS_DDR_TIMING_3_667, &ddr->timing_cfg_3); - __raw_writel(CONFIG_SYS_DDR_TIMING_0_667, &ddr->timing_cfg_0); - __raw_writel(CONFIG_SYS_DDR_TIMING_1_667, &ddr->timing_cfg_1); - __raw_writel(CONFIG_SYS_DDR_TIMING_2_667, &ddr->timing_cfg_2); - __raw_writel(CONFIG_SYS_DDR_MODE_1_667, &ddr->sdram_mode); - __raw_writel(CONFIG_SYS_DDR_MODE_2_667, &ddr->sdram_mode_2); - __raw_writel(CONFIG_SYS_DDR_INTERVAL_667, &ddr->sdram_interval); - __raw_writel(CONFIG_SYS_DDR_CLK_CTRL_667, &ddr->sdram_clk_cntl); - __raw_writel(CONFIG_SYS_DDR_WRLVL_CONTROL_667, &ddr->ddr_wrlvl_cntl); - } else { - __raw_writel(CONFIG_SYS_DDR_TIMING_3_800, &ddr->timing_cfg_3); - __raw_writel(CONFIG_SYS_DDR_TIMING_0_800, &ddr->timing_cfg_0); - __raw_writel(CONFIG_SYS_DDR_TIMING_1_800, &ddr->timing_cfg_1); - __raw_writel(CONFIG_SYS_DDR_TIMING_2_800, &ddr->timing_cfg_2); - __raw_writel(CONFIG_SYS_DDR_MODE_1_800, &ddr->sdram_mode); - __raw_writel(CONFIG_SYS_DDR_MODE_2_800, &ddr->sdram_mode_2); - __raw_writel(CONFIG_SYS_DDR_INTERVAL_800, &ddr->sdram_interval); - __raw_writel(CONFIG_SYS_DDR_CLK_CTRL_800, &ddr->sdram_clk_cntl); - __raw_writel(CONFIG_SYS_DDR_WRLVL_CONTROL_800, &ddr->ddr_wrlvl_cntl); - } - - __raw_writel(CONFIG_SYS_DDR_TIMING_4, &ddr->timing_cfg_4); - __raw_writel(CONFIG_SYS_DDR_TIMING_5, &ddr->timing_cfg_5); - __raw_writel(CONFIG_SYS_DDR_ZQ_CONTROL, &ddr->ddr_zq_cntl); - - /* P1014 and it's derivatives support max 16bit DDR width */ - if (svr == SVR_P1014) { - __raw_writel(ddr->sdram_cfg & ~SDRAM_CFG_DBW_MASK, &ddr->sdram_cfg); - __raw_writel(ddr->sdram_cfg | SDRAM_CFG_16_BE, &ddr->sdram_cfg); - /* For CS0_BNDS we divide the start and end address by 2, so we can just - * shift the entire register to achieve the desired result and the mask - * the value so we don't write reserved fields */ - __raw_writel((CONFIG_SYS_DDR_CS0_BNDS >> 1) & 0x0fff0fff, &ddr->cs0_bnds); - } - - asm volatile("sync;isync"); - udelay(500); - - /* Let the controller go */ - out_be32(&ddr->sdram_cfg, in_be32(&ddr->sdram_cfg) | SDRAM_CFG_MEM_EN); - - set_next_law(CONFIG_SYS_NAND_DDR_LAW, LAW_SIZE_1G, LAW_TRGT_IF_DDR_1); -} - void board_init_f(ulong bootflag) { u32 plat_ratio; ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR;
+#if defined(CONFIG_SYS_NAND_BR_PRELIM) && defined(CONFIG_SYS_NAND_OR_PRELIM) + set_lbc_br(0, CONFIG_SYS_NAND_BR_PRELIM); + set_lbc_or(0, CONFIG_SYS_NAND_OR_PRELIM); +#endif + /* initialize selected port with appropriate baud rate */ plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; plat_ratio >>= 1; @@ -98,9 +36,6 @@ void board_init_f(ulong bootflag)
puts("\nNAND boot... ");
- /* Initialize the DDR3 */ - sdram_init(); - /* copy code to RAM and jump to it - this should not return */ /* NOTE - code has to be copied out of NAND buffer before * other blocks can be read. @@ -111,6 +46,7 @@ void board_init_f(ulong bootflag)
void board_init_r(gd_t *gd, ulong dest_addr) { + puts("\nSecond program loader running in sram..."); nand_boot(); }
diff --git a/board/freescale/p1010rdb/tlb.c b/board/freescale/p1010rdb/tlb.c index a3d36b3..af40f97 100644 --- a/board/freescale/p1010rdb/tlb.c +++ b/board/freescale/p1010rdb/tlb.c @@ -73,10 +73,18 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 7, BOOKE_PAGESZ_1M, 1),
-#if defined(CONFIG_SYS_RAMBOOT) || defined(CONFIG_SPL) +#if defined(CONFIG_SYS_RAMBOOT) || \ + (defined(CONFIG_SPL) && !defined(CONFIG_SPL_COMMON_INIT_DDR)) SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 8, BOOKE_PAGESZ_1G, 1) + 0, 8, BOOKE_PAGESZ_1G, 1), +#endif + +#ifdef CONFIG_SYS_INIT_L2_ADDR + /* *I*G - L2SRAM */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR, CONFIG_SYS_INIT_L2_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, + 0, 11, BOOKE_PAGESZ_256K, 1) #endif };
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 62d7a84..e4b44fa 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -21,19 +21,75 @@ #define CONFIG_NAND_FSL_IFC
#ifdef CONFIG_SDCARD -#define CONFIG_RAMBOOT_SDCARD -#define CONFIG_SYS_TEXT_BASE 0x11000000 -#define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc +#define CONFIG_SPL +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_MMC_MINIMAL +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_SYS_TEXT_BASE 0x11001000 +#define CONFIG_SPL_TEXT_BASE 0xD0001000 +#define CONFIG_SPL_PAD_TO 0x18000 +#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SYS_MMC_U_BOOT_SIZE (512 << 10) +#define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) +#define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) +#define CONFIG_SYS_MMC_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_MPC85XX_NO_RESETVEC +#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" +#define CONFIG_SPL_MMC_BOOT +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_COMMON_INIT_DDR +#endif #endif
#ifdef CONFIG_SPIFLASH +#ifdef CONFIG_SECURE_BOOT #define CONFIG_RAMBOOT_SPIFLASH #define CONFIG_SYS_TEXT_BASE 0x11000000 -#define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#else +#define CONFIG_SPL +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_FLASH_MINIMAL +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_SYS_TEXT_BASE 0x11001000 +#define CONFIG_SPL_TEXT_BASE 0xD0001000 +#define CONFIG_SPL_PAD_TO 0x18000 +#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (512 << 10) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_MPC85XX_NO_RESETVEC +#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" +#define CONFIG_SPL_SPI_BOOT +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_COMMON_INIT_DDR +#endif +#endif #endif
#ifdef CONFIG_NAND #define CONFIG_SPL +#ifdef CONFIG_SECURE_BOOT #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_SERIAL_SUPPORT #define CONFIG_SPL_NAND_SUPPORT @@ -51,8 +107,48 @@ #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_OFFS 0 #define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot-nand.lds" +#else +#define CONFIG_TPL +#ifdef CONFIG_TPL_BUILD +#define CONFIG_SPL_NAND_BOOT +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_NAND_INIT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_COMMON_INIT_DDR +#define CONFIG_SPL_MAX_SIZE (128 << 10) +#define CONFIG_SPL_TEXT_BASE 0xD0001000 +#define CONFIG_SYS_MPC85XX_NO_RESETVEC +#define CONFIG_SYS_NAND_U_BOOT_SIZE (576 << 10) +#define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000) +#define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) +#define CONFIG_SYS_NAND_U_BOOT_OFFS ((128 + 128) << 10) +#elif defined(CONFIG_SPL_BUILD) +#define CONFIG_SPL_INIT_MINIMAL +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_MINIMAL +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_TEXT_BASE 0xff800000 +#define CONFIG_SPL_MAX_SIZE 8192 +#define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) +#define CONFIG_SYS_NAND_U_BOOT_DST 0xD0000000 +#define CONFIG_SYS_NAND_U_BOOT_START 0xD0000000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS (128 << 10) +#endif +#define CONFIG_SPL_PAD_TO 0x20000 +#define CONFIG_TPL_PAD_TO 0x20000 +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SYS_TEXT_BASE 0x11001000 +#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot-nand.lds" +#endif #endif -
#ifdef CONFIG_NAND_SECBOOT /* NAND Boot */ #define CONFIG_RAMBOOT_NAND @@ -474,6 +570,43 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon*/ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc*/
+/* + * Config the L2 Cache as L2 SRAM + */ +#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) +#define CONFIG_SYS_INIT_L2_ADDR 0xD0000000 +#define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR +#define CONFIG_SYS_L2_SIZE (256 << 10) +#define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) +#define CONFIG_SPL_RELOC_TEXT_BASE 0xD0001000 +#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) +#define CONFIG_SPL_RELOC_STACK_SIZE (16 << 10) +#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 128 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (128 << 10) +#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 96 * 1024) +#elif defined(CONFIG_NAND) +#ifdef CONFIG_TPL_BUILD +#define CONFIG_SYS_INIT_L2_ADDR 0xD0000000 +#define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR +#define CONFIG_SYS_L2_SIZE (256 << 10) +#define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) +#define CONFIG_SPL_RELOC_TEXT_BASE 0xD0001000 +#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 192 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 208 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (48 << 10) +#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 176 * 1024) +#else +#define CONFIG_SYS_INIT_L2_ADDR 0xD0000000 +#define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR +#define CONFIG_SYS_L2_SIZE (256 << 10) +#define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) +#define CONFIG_SPL_RELOC_TEXT_BASE (CONFIG_SYS_INIT_L2_END - 0x3000) +#define CONFIG_SPL_RELOC_STACK ((CONFIG_SYS_INIT_L2_END - 1) & ~0xF) +#endif +#endif +#endif + /* Serial Port */ #define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO @@ -481,7 +614,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) -#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_INIT_MINIMAL) #define CONFIG_NS16550_MIN_FUNCTIONS #endif
@@ -638,12 +771,12 @@ extern unsigned long get_sdram_size(void); /* * Environment */ -#if defined(CONFIG_RAMBOOT_SDCARD) +#if defined(CONFIG_SDCARD) #define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_RAMBOOT_SPIFLASH) +#elif defined(CONFIG_SPIFLASH) #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 @@ -654,6 +787,10 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) #define CONFIG_ENV_IS_IN_NAND +#ifdef CONFIG_TPL_BUILD +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) +#else #if defined(CONFIG_P1010RDB_PA) #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) /* 3*16=48K for env */ @@ -661,7 +798,8 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_RANGE (32 * CONFIG_ENV_SIZE) /* new block size 512K */ #endif -#define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) +#endif +#define CONFIG_ENV_OFFSET (1024 * 1024) #elif defined(CONFIG_SYS_RAMBOOT) #define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000)
ying.zhang@freescale.com
