[U-Boot] [PATCH 7/8] APM82xxx: Add bluestone board support
Add support code for bluestone board wth APM82XXX processor based. This patch includes early board init, misc init, configure EBC, and initializes UIC.
Signed-off-by: Tirumala R Marri tmarri@apm.com --- arch/powerpc/include/asm/ppc4xx-ebc.h | 4 + board/amcc/bluestone/Makefile | 52 ++++++++ board/amcc/bluestone/bluestone.c | 213 ++++++++++++++++++++++++++++++++ board/amcc/bluestone/config.mk | 40 ++++++ board/amcc/bluestone/init.S | 55 ++++++++ include/configs/bluestone.h | 218 +++++++++++++++++++++++++++++++++ 6 files changed, 582 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/include/asm/ppc4xx-ebc.h b/arch/powerpc/include/asm/ppc4xx-ebc.h index 9c17e46..245e487 100644 --- a/arch/powerpc/include/asm/ppc4xx-ebc.h +++ b/arch/powerpc/include/asm/ppc4xx-ebc.h @@ -73,6 +73,10 @@ #define EBC_NUM_BANKS 3 #endif
+#if defined(CONFIG_APM82XXX) +#define EBC_NUM_BANKS 3 +#endif + /* Bank Configuration Register */ #define EBC_BXCR(n) (n) #define EBC_BXCR_BANK_SIZE(n) (0x100000 << (((n) & EBC_BXCR_BS_MASK) >> 17)) diff --git a/board/amcc/bluestone/Makefile b/board/amcc/bluestone/Makefile new file mode 100644 index 0000000..637d20d --- /dev/null +++ b/board/amcc/bluestone/Makefile @@ -0,0 +1,52 @@ +# +# Copyright (c) 2010, Applied Micro Circuits Corporation +# All rights reserved. Tirumala R Marri tmarri@apm.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y := $(BOARD).o +SOBJS := init.o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/amcc/bluestone/bluestone.c b/board/amcc/bluestone/bluestone.c new file mode 100644 index 0000000..b13e84a --- /dev/null +++ b/board/amcc/bluestone/bluestone.c @@ -0,0 +1,213 @@ +/* + * Bluestone board support + * + * Copyright (c) 2010, Applied Micro Circuits Corporation + * All rights reserved. Tirumala R Marri tmarri@apm.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <ppc440.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <i2c.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/mmu.h> +#include <asm/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define SDR_AHB_CFG 0x370 + +/* Define Boot devices */ +#define BOOT_FROM_8BIT_SRAM 0x00 +#define BOOT_FROM_8BIT_SRAM_FULL_ADDR 0x01 +#define BOOT_FROM_8BIT_NAND 0x02 +#define BOOT_FROM_8BIT_NOR 0x03 +#define BOOT_FROM_8BIT_NOR_FULL_ADDR 0x04 +#define BOOT_DEVICE_UNKNOWN 0xff + +#define APM82161_MASK (u32)(0x1 << 21) + +/* NOR Flash */ +#define EBC_BXAP_NOR (EBC_BXAP_BME_DISABLED | \ + EBC_BXAP_TWT_ENCODE(64) | \ + EBC_BXAP_BCE_DISABLE | \ + EBC_BXAP_BCT_2TRANS | \ + EBC_BXAP_CSN_ENCODE(1) | \ + EBC_BXAP_OEN_ENCODE(2) | \ + EBC_BXAP_WBN_ENCODE(2) | \ + EBC_BXAP_WBF_ENCODE(2) | \ + EBC_BXAP_TH_ENCODE(7) | \ + EBC_BXAP_SOR_DELAYED | \ + EBC_BXAP_BEM_WRITEONLY | \ + EBC_BXAP_PEN_DISABLED) +/* Peripheral Bank Configuration Register - EBC_BxCR */ +#define EBC_BXCR_8BIT_NOR \ + (EBC_BXCR_BAS_ENCODE(CONFIG_SYS_FLASH_BASE) | \ + EBC_BXCR_BS_1MB | \ + EBC_BXCR_BU_RW | \ + EBC_BXCR_BW_8BIT) + +#define EBC_BXCR_8BIT_SRAM \ + (EBC_BXCR_BAS_ENCODE(CONFIG_SYS_EXTSRAM_BASE) | \ + EBC_BXCR_BS_1MB | \ + EBC_BXCR_BU_RW | \ + EBC_BXCR_BW_8BIT) + +/* + * Get bootdevice information and + * setup EBC configuration + * NOTE: Assume that I2C had been initialized + */ +int bootdevice_selected(void) +{ + unsigned long rl; + unsigned long bootstrap_settings; + int computed_boot_device = BOOT_DEVICE_UNKNOWN; + + mfsdr(SDR0_SDSTP1, bootstrap_settings); + rl = SDR_SDSTP1_RL_DECODE(bootstrap_settings); + if (rl == SDR_SDSTP1_RL_EBC) /* Boot device is NOR */ + computed_boot_device = BOOT_FROM_8BIT_NOR; + else if (rl == SDR_SDSTP1_RL_NDFC) + computed_boot_device = BOOT_FROM_8BIT_NAND; + return computed_boot_device; +} + +void reconfigure_EBC(int computed_boot_device) +{ + switch (computed_boot_device) { + case BOOT_FROM_8BIT_NOR: + /* + * CS0: NOR + */ + /* Configure EBC CS0 - Nor Flash 1MBx8 */ + mtebc(PB0AP, EBC_BXAP_NOR); + mtebc(PB0CR, EBC_BXCR_8BIT_NOR); + break; + case BOOT_FROM_8BIT_NOR_FULL_ADDR: + /* + * CS0: NOR + * CS1: x + * CS2: x + */ + /* Configure EBC CS0 - Nor Flash 1MBx8 */ + mtebc(PB0AP, EBC_BXAP_NOR); + mtebc(PB0CR, EBC_BXCR_8BIT_NOR); + break; + default: + break; + } +} + +int board_early_init_f(void) +{ + /* + * Setup the interrupt controller polarities, triggers, etc. + */ + mtdcr(UIC0SR, 0xffffffff); /* clear all */ + mtdcr(UIC0ER, 0x00000000); /* disable all */ + mtdcr(UIC0CR, 0x00000005); /* ATI & UIC1 crit are critical */ + mtdcr(UIC0PR, 0xffffffff); /* per ref-board manual */ + mtdcr(UIC0TR, 0x00000000); /* per ref-board manual */ + mtdcr(UIC0VR, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(UIC0SR, 0xffffffff); /* clear all */ + + mtdcr(UIC1SR, 0xffffffff); /* clear all */ + mtdcr(UIC1ER, 0x00000000); /* disable all */ + mtdcr(UIC1CR, 0x00000000); /* all non-critical */ + mtdcr(UIC1PR, 0xffffffff); /* per ref-board manual */ + mtdcr(UIC1TR, 0x00000000); /* per ref-board manual */ + mtdcr(UIC1VR, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(UIC1SR, 0xffffffff); /* clear all */ + + mtdcr(UIC2SR, 0xffffffff); /* clear all */ + mtdcr(UIC2ER, 0x00000000); /* disable all */ + mtdcr(UIC2CR, 0x00000000); /* all non-critical */ + mtdcr(UIC2PR, 0xffffffff); /* per ref-board manual */ + mtdcr(UIC2TR, 0x00000000); /* per ref-board manual */ + mtdcr(UIC2VR, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(UIC2SR, 0xffffffff); /* clear all */ + + mtdcr(UIC3SR, 0xffffffff); /* clear all */ + mtdcr(UIC3ER, 0x00000000); /* disable all */ + mtdcr(UIC3CR, 0x00000000); /* all non-critical */ + mtdcr(UIC3PR, 0xffffffff); /* per ref-board manual */ + mtdcr(UIC3TR, 0x00000000); /* per ref-board manual */ + mtdcr(UIC3VR, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(UIC3SR, 0xffffffff); /* clear all */ + + /* + * Configure PFC (Pin Function Control) registers + * UART0: 2 pins + */ + mtsdr(SDR0_PFC1, 0x0000000); + + return 0; +} + +int checkboard(void) +{ + char *s = getenv("serial#"); + + printf("Board: Bluestone Evaluation Board"); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + putc('\n'); + + return 0; +} + +int board_early_init_r(void) +{ + u32 bootdevice; + + /* + * Clear potential errors resulting from auto-calibration. + * If not done, then we could get an interrupt later on when + * exceptions are enabled. + */ + set_mcsr(get_mcsr()); + + /* Reconfigure EBC here */ + bootdevice = bootdevice_selected(); + reconfigure_EBC(bootdevice); + + return 0; +} + +int misc_init_r(void) +{ + u32 sdr0_srst1 = 0; + /* Setup PLB4-AHB bridge based on the system address map */ + mtdcr(AHB_TOP, 0x8000004B); + mtdcr(AHB_BOT, 0x8000004B); + /* + * The AHB Bridge core is held in reset after power-on or reset + * so enable it now + */ + mfsdr(SDR0_SRST1, sdr0_srst1); + sdr0_srst1 &= ~SDR0_SRST1_AHB; + mtsdr(SDR0_SRST1, sdr0_srst1); + + return 0; +} diff --git a/board/amcc/bluestone/config.mk b/board/amcc/bluestone/config.mk new file mode 100644 index 0000000..dca5a9a --- /dev/null +++ b/board/amcc/bluestone/config.mk @@ -0,0 +1,40 @@ +# +# Copyright (c) 2010, Applied Micro Circuits Corporation +# All rights reserved. Tirumala R Marri tmarri@apm.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# Applied Micro APM82XXX Evaluation board. +# + +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +TEXT_BASE = 0xFFFA0000 +endif + +PLATFORM_CPPFLAGS += -DCONFIG_440=1 + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif + +ifeq ($(dbcr),1) +PLATFORM_CPPFLAGS += -DCONFIG_SYS_INIT_DBCR=0x8cff0000 +endif diff --git a/board/amcc/bluestone/init.S b/board/amcc/bluestone/init.S new file mode 100644 index 0000000..a74d75a --- /dev/null +++ b/board/amcc/bluestone/init.S @@ -0,0 +1,55 @@ +/* + * Copyright (c) 2010, Applied Micro Circuits Corporation + * All rights reserved. Tirumala R Marri tmarri@apm.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <ppc_asm.tmpl> +#include <config.h> +#include <asm/mmu.h> + +/************************************************************************** + * TLB TABLE + * + * This table is used by the cpu boot code to setup the initial tlb + * entries. Rather than make broad assumptions in the cpu source tree, + * this table lets each board set things up however they like. + * + * Pointer to the table is returned in r1 + * + *************************************************************************/ + .section .bootpg,"ax" + .globl tlbtab + +tlbtab: + tlbtab_start + + /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ + tlbentry(CONFIG_SYS_INIT_RAM_ADDR, SZ_4K, CONFIG_SYS_INIT_RAM_ADDR, + 0, AC_R|AC_W|AC_X|SA_G) + + /* TLB-entry for OCM */ + tlbentry(CONFIG_SYS_OCM_BASE, SZ_64K, 0x00040000, 4, + AC_R|AC_W|AC_X|SA_I) + + /* TLB-entry for Local Configuration registers => peripherals */ + tlbentry(CONFIG_SYS_PERIPHERAL_BASE, SZ_16K, + CONFIG_SYS_PERIPHERAL_BASE, 4, AC_R|AC_W|AC_X|SA_G|SA_I) + tlbtab_end diff --git a/include/configs/bluestone.h b/include/configs/bluestone.h new file mode 100644 index 0000000..44b2264 --- /dev/null +++ b/include/configs/bluestone.h @@ -0,0 +1,218 @@ +/* + * bluestone.h - configuration for Blouestone (APM82XXX) + * + * Copyright (c) 2010, Applied Micro Circuits Corporation + * All rights reserved. Tirumala R Marri tmarri@apm.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_APM82181 1 /* Specific APM82XXX */ +#define CONFIG_APM82XXX 1 /* APM82XXX series */ +#define CONFIG_HOSTNAME bluestone + +#define CONFIG_440 1 +#define CONFIG_4xx 1 /* ... PPC4xx family */ + +/* + * Include common defines/options for all AMCC eval boards + */ +#include "amcc-common.h" +#define CONFIG_SYS_CLK_FREQ 50000000 + +#define CONFIG_BOARD_TYPES 1 /* support board types */ +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_BOARD_EARLY_INIT_R 1 /* Call board_early_init_r */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +/* EBC stuff */ +#define CONFIG_SYS_EXTSRAM_BASE 0xE1000000 /* 2MB */ +/* later mapped to this addr */ +#define CONFIG_SYS_FLASH_BASE 0xFFF00000 +#define CONFIG_SYS_FLASH_SIZE (1 << 20) /* 1MB usable */ + +#define CONFIG_SYS_NAND0_ADDR 0xE4000000 +#define CONFIG_SYS_NAND1_ADDR 0xE5000000 +/* EBC Boot Space: 0xFF000000 */ +#define CONFIG_SYS_BOOT_BASE_ADDR 0xFF000000 +#define CONFIG_SYS_OCM_BASE 0xE3000000 /* OCM: 32k */ +#define CONFIG_SYS_SRAM_BASE 0xE8000000 /* SRAM: 256k */ +#define CONFIG_SYS_PERIPHERAL_BASE 0xEF600000 /* internal peripherals */ +#define CONFIG_SYS_AHB_BASE 0xE2000000 /* internal AHB peripherals*/ + +/* + * Initial RAM & stack pointer (placed in OCM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ +#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* + * Environment + */ +/* + * Define here the location of the environment variables (FLASH). + */ +#if !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) \ + && !defined(CONFIG_SRAM_U_BOOT) +#define CONFIG_ENV_IS_IN_FLASH 1 /* use FLASH for environment vars */ +#define CONFIG_SYS_NOR_CS 0 /* NOR chip connected to CSx */ +#define CONFIG_SYS_NAND_CS 1 /* NAND chip connected to CSx */ +#else +#define CONFIG_ENV_IS_IN_NAND 1 /* use NAND for environment vars */ +#define CONFIG_SYS_NOR_CS 2 /* NOR chip connected to CSx */ +#define CONFIG_SYS_NAND_CS 0 /* NAND chip connected to CSx */ +#define CONFIG_ENV_IS_EMBEDDED 1 /* use embedded environment */ +#endif + +#if !defined(CONFIG_NAND_U_BOOT) +/* Boot from NOR, store environment to NAND */ +#ifdef CONFIG_ENV_IS_IN_NAND + +/* + * Too big environment size (512KB) may cause system + * hang due to out of malloc space + */ +#define CONFIG_ENV_SIZE (64 << 10) +#define CONFIG_ENV_OFFSET (2 << 20) +#endif +#else /* NAND boot */ +#ifdef CONFIG_ENV_IS_IN_NAND +/* + * For NAND booting the environment is embedded in the U-Boot image. Please take + * look at the file board/amcc/canyonlands/u-boot-nand.lds for details. + */ +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET \ + (CONFIG_SYS_NAND_U_BOOT_OFFS + CONFIG_ENV_SIZE) +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#endif +#endif /* !defined(CONFIG_NAND_U_BOOT) */ +/* + * FLASH related + */ +#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ +#define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT +/* Reduce the actual size of the flash */ +#define CONFIG_SIZE_REDUCE (3 << 20) +/* Reduce the actual sectors of the flash */ +#define CONFIG_SECTOR_REDUCE 48 +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE} +/* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +/* max number of sectors on one chip */ +#define CONFIG_SYS_MAX_FLASH_SECT 80 +/* Timeout for Flash Erase (in ms) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 +/* Timeout for Flash Write (in ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 +/* use buffered writes (20x faster) */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +/* print 'E' for empty sector on flinfo */ +#define CONFIG_SYS_FLASH_EMPTY_INFO +#ifdef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#endif /* CONFIG_ENV_IS_IN_FLASH */ +/* + * NAND-FLASH related + */ +#if !defined(CONFIG_NAND_U_BOOT) +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE \ + (CONFIG_SYS_NAND_ADDR + CONFIG_SYS_NAND_CS) +#define CONFIG_SYS_NAND_MAX_CHIPS 1 +#else /* NAND boot */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE \ + {CONFIG_SYS_NAND0_ADDR + 0/*, CONFIG_SYS_NAND1_ADDR + 1*/} +#define CONFIG_SYS_NAND_MAX_CHIPS 1 +#define NOT_USE_FLASH +#endif +/* nand driver supports mutipl. chips */ +#define CONFIG_SYS_NAND_SELECT_DEVICE 1 +/* + * Use 1 byte of I2C EEPROM as a flag to force SDRAM controller + * to be configured as 16-bit + */ +#define CONFIG_SDRAM_INFO_EEPROM_ADDR 0x54 /* Board specific */ +#define CONFIG_SDRAM16BIT_OFFSET 0x20 /* Board specific */ + +#if !defined(CONFIG_NAND_U_BOOT) +/* + * NAND booting U-Boot version uses a fixed initialization, since the whole + * I2C SPD DIMM autodetection/calibration doesn't fit into the 4k of boot + * code. + */ +#define CONFIG_SPD_EEPROM 1 /* Use SPD EEPROM for setup */ +#define SPD_EEPROM_ADDRESS {0x53, 0x51} /* SPD i2c spd addresses */ +#define CONFIG_PPC4xx_DDR_AUTOCALIBRATION /* IBM DDR autocalibration */ +#define CONFIG_AUTOCALIB "silent\0" /* default is non-verbose */ +#define CONFIG_DDR_ECC 1 /* with ECC support */ +#endif /* !defined(CONFIG_NAND_U_BOOT) */ +/* + * I2C + */ +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed */ + +#define CONFIG_SYS_I2C_MULTI_EEPROMS +#define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 /* Data sheet */ +/* I2C bootstrap EEPROM */ +#define CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR 0x52 +#define CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET 0 +#define CONFIG_4xx_CONFIG_BLOCKSIZE 16 +/* + * Ethernet + */ +#define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_EMAC_PHY_MODE EMAC_PHY_MODE_NONE_RGMII +#define CONFIG_HAS_ETH0 +#define CONFIG_M88E1111_PHY +/* PHY address, See schematics */ +#define CONFIG_PHY_ADDR 0x1f +/* reset phy upon startup */ +#define CONFIG_PHY_RESET 1 +#define CONFIG_PHY_RESET_R +/* Include GbE speed/duplex detection */ +#define CONFIG_PHY_GIGE 1 +#define CONFIG_PHY_DYNAMIC_ANEG 1 +/* + * External Bus Controller (EBC) Setup + **/ +#define CONFIG_SYS_EBC_CFG 0xB8400000 /* EBC0_CFG */ + +#endif /* __CONFIG_H */
Hi Marri,
Again, some comments below.
IIRC, then this statement "All rights reserved" interferes with the GPL. Please remove it from all your files.
- $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- Bluestone board support
- Copyright (c) 2010, Applied Micro Circuits Corporation
- All rights reserved. Tirumala R Marri tmarri@apm.com
- MA 02111-1307 USA
Starting here...
- (EBC_BXCR_BAS_ENCODE(CONFIG_SYS_FLASH_BASE) | \
- EBC_BXCR_BS_1MB | \
- EBC_BXCR_BU_RW | \
- EBC_BXCR_BW_8BIT)
- (EBC_BXCR_BAS_ENCODE(CONFIG_SYS_EXTSRAM_BASE) | \
- EBC_BXCR_BW_8BIT)
... till here. Why do you add these defines to this C file? These should be located in the general header files (ppc440.h) and/or the board config header.
- Get bootdevice information and
- setup EBC configuration
- NOTE: Assume that I2C had been initialized
- unsigned long rl;
- unsigned long bootstrap_settings;
- int computed_boot_device = BOOT_DEVICE_UNKNOWN;
- mfsdr(SDR0_SDSTP1, bootstrap_settings);
- rl = SDR_SDSTP1_RL_DECODE(bootstrap_settings);
- if (rl == SDR_SDSTP1_RL_EBC) /* Boot device is NOR */
- else if (rl == SDR_SDSTP1_RL_NDFC)
- return computed_boot_device;
Don't use upper-case or camel-case for function names.
- switch (computed_boot_device) {
- case BOOT_FROM_8BIT_NOR:
* CS0: NOR
break;
- case BOOT_FROM_8BIT_NOR_FULL_ADDR:
* CS0: NOR
* CS1: x
* CS2: x
break;
Hmmm. This looks wrong. In both cases the same values are written to the EBC register. Please check again if this is want you really want.
- default:
break;
- mtdcr(UIC0SR, 0xffffffff); /* clear all */
- mtdcr(UIC0ER, 0x00000000); /* disable all */
- mtdcr(UIC0CR, 0x00000005); /* ATI & UIC1 crit are critical */
- mtdcr(UIC0PR, 0xffffffff); /* per ref-board manual */
- mtdcr(UIC0TR, 0x00000000); /* per ref-board manual */
- mtdcr(UIC0VR, 0x00000000); /* int31 highest, base=0x000 */
- mtdcr(UIC1SR, 0xffffffff); /* clear all */
- mtdcr(UIC1ER, 0x00000000); /* disable all */
- mtdcr(UIC1CR, 0x00000000); /* all non-critical */
- mtdcr(UIC1PR, 0xffffffff); /* per ref-board manual */
- mtdcr(UIC1TR, 0x00000000); /* per ref-board manual */
- mtdcr(UIC1VR, 0x00000000); /* int31 highest, base=0x000 */
- mtdcr(UIC2SR, 0xffffffff); /* clear all */
- mtdcr(UIC2ER, 0x00000000); /* disable all */
- mtdcr(UIC2CR, 0x00000000); /* all non-critical */
- mtdcr(UIC2PR, 0xffffffff); /* per ref-board manual */
- mtdcr(UIC2TR, 0x00000000); /* per ref-board manual */
- mtdcr(UIC2VR, 0x00000000); /* int31 highest, base=0x000 */
- mtdcr(UIC3SR, 0xffffffff); /* clear all */
- mtdcr(UIC3ER, 0x00000000); /* disable all */
- mtdcr(UIC3CR, 0x00000000); /* all non-critical */
- mtdcr(UIC3PR, 0xffffffff); /* per ref-board manual */
- mtdcr(UIC3TR, 0x00000000); /* per ref-board manual */
- mtdcr(UIC3VR, 0x00000000); /* int31 highest, base=0x000 */
* UART0: 2 pins
- mtsdr(SDR0_PFC1, 0x0000000);
- char *s = getenv("serial#");
- printf("Board: Bluestone Evaluation Board");
- if (s != NULL) {
puts(", serial# ");
puts(s);
- putc('\n');
- u32 bootdevice;
- set_mcsr(get_mcsr());
- /* Reconfigure EBC here */
- bootdevice = bootdevice_selected();
- reconfigure_EBC(bootdevice);
Please explain why the EBC needs to be reconfigured at this stage.
- u32 sdr0_srst1 = 0;
Add empty line here.
- /* Setup PLB4-AHB bridge based on the system address map */
- mtdcr(AHB_TOP, 0x8000004B);
- mtdcr(AHB_BOT, 0x8000004B);
Again, add empty line.
* so enable it now
- mfsdr(SDR0_SRST1, sdr0_srst1);
- sdr0_srst1 &= ~SDR0_SRST1_AHB;
- mtsdr(SDR0_SRST1, sdr0_srst1);
- project.
- MA 02111-1307 USA
- TLB TABLE
- This table is used by the cpu boot code to setup the initial tlb
- entries. Rather than make broad assumptions in the cpu source tree,
- this table lets each board set things up however they like.
- Pointer to the table is returned in r1
- .section .bootpg,"ax"
- .globl tlbtab
+tlbtab:
- tlbtab_start
- /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */
- tlbentry(CONFIG_SYS_INIT_RAM_ADDR, SZ_4K, CONFIG_SYS_INIT_RAM_ADDR,
- /* TLB-entry for OCM */
- tlbentry(CONFIG_SYS_OCM_BASE, SZ_64K, 0x00040000, 4,
- /* TLB-entry for Local Configuration registers => peripherals */
- tlbentry(CONFIG_SYS_PERIPHERAL_BASE, SZ_16K,
SA_I)
Recently I added some macros to make this TLB table a bit easier:
AC_RWX etc. Please use those macros here.
- tlbtab_end
- bluestone.h - configuration for Blouestone (APM82XXX)
- MA 02111-1307 USA
- High Level Configuration Options
- Include common defines/options for all AMCC eval boards
- Base addresses -- Note these are effective addresses where the
- actual resources get mapped (not physical addresses)
peripherals*/
- Initial RAM & stack pointer (placed in OCM)
- (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE)
- Environment
- Define here the location of the environment variables (FLASH).
- && !defined(CONFIG_SRAM_U_BOOT)
You don't add NAND-booting support for this board. Either include it or remove these NAND-booting related defines/configurations.
And even more, NAND support doesn't seem to be enabled at all. Please remove the NAND stuff completely. This will make the patch much more clear.
vars */
vars */
- Too big environment size (512KB) may cause system
- hang due to out of malloc space
- For NAND booting the environment is embedded in the U-Boot image.
- (CONFIG_SYS_NAND_U_BOOT_OFFS + CONFIG_ENV_SIZE)
- FLASH related
What are those two defines (xxx_REDUCE)? I have never seen those before. And they don't seem to be referenced in your patchset either. Please remove.
Sector */
- NAND-FLASH related
- (CONFIG_SYS_NAND_ADDR + CONFIG_SYS_NAND_CS)
- {CONFIG_SYS_NAND0_ADDR + 0/*, CONFIG_SYS_NAND1_ADDR + 1*/}
- Use 1 byte of I2C EEPROM as a flag to force SDRAM controller
- to be configured as 16-bit
Those two defines are not used in your patches. Please remove.
- NAND booting U-Boot version uses a fixed initialization, since the
- I2C
Space around ">>".
Those defines are used be the board specific "chip_config" command. Which you didn't include in this patchset. Either add it or remove these defines.
- Ethernet
What's CONFIG_PHY_RESET_R? Please remove.
- External Bus Controller (EBC) Setup
Please fix and resubmit. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Stefan:
Our legal is out at the moment. Why is this an issue, since it is on many of the files in U-Boot. Our legal indicated without the statement the Copyright would not stand.
Thanks Feng
+clean:
+distclean: clean
- MA 02111-1307 USA
Starting here...
- EBC_BXAP_TWT_ENCODE(64) | \
- EBC_BXAP_BCE_DISABLE | \
- EBC_BXAP_BCT_2TRANS | \
- EBC_BXAP_CSN_ENCODE(1) | \
- EBC_BXAP_OEN_ENCODE(2) | \
- EBC_BXAP_WBN_ENCODE(2) | \
- EBC_BXAP_WBF_ENCODE(2) | \
- EBC_BXAP_TH_ENCODE(7) | \
- EBC_BXAP_SOR_DELAYED | \
- EBC_BXAP_BEM_WRITEONLY | \
- EBC_BXAP_PEN_DISABLED)
- EBC_BXCR_BW_8BIT)
- EBC_BXCR_BW_8BIT)
- unsigned long rl;
- computed_boot_device = BOOT_FROM_8BIT_NOR;
- computed_boot_device = BOOT_FROM_8BIT_NAND;
- * CS0: NOR
- /* Configure EBC CS0 - Nor Flash 1MBx8 */
- mtebc(PB0AP, EBC_BXAP_NOR);
- mtebc(PB0CR, EBC_BXCR_8BIT_NOR);
- break;
- * CS0: NOR
- * CS1: x
- * CS2: x
- break;
- default:
- break;
- * Setup the interrupt controller polarities, triggers, etc.
- * Configure PFC (Pin Function Control) registers
- * UART0: 2 pins
- if (s != NULL) {
- puts(", serial# ");
- puts(s);
- putc('\n');
- u32 bootdevice;
- * Clear potential errors resulting from auto-calibration.
- * If not done, then we could get an interrupt later on when
- * exceptions are enabled.
- * The AHB Bridge core is held in reset after power-on or reset
- * so enable it now
- project.
- MA 02111-1307 USA
- TLB TABLE
- .globl tlbtab
+tlbtab:
- tlbtab_start
- 0, AC_R|AC_W|AC_X|SA_G)
- AC_R|AC_W|AC_X|SA_I)
- CONFIG_SYS_PERIPHERAL_BASE, 4, AC_R|AC_W|AC_X|SA_G|
SA_I)
- tlbtab_end
- MA 02111-1307 USA
peripherals*/
- Environment
vars */
vars */
- FLASH related
Sector */
- I2C
Space around ">>".
- Ethernet
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Feng Kan,
In message AANLkTikBAC7n-TwHkRzy+SkwwM88vkVNuxy8CRx-uAve@mail.gmail.com you wrote:
Please tell your legal to get a clue.
Fact is, that any files where a "All rights reserved." is found have zero chance to go into mainline. [And any existing files with such notes are already on the kill list.]
Dear tmarri@apm.com,
Entry to boards.cfg, MAINTAINERS and MAKEALL missing.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Sunday, August 29, 2010 1:57 AM To: tmarri@apm.com Cc: u-boot@lists.denx.de; open-source-review@apm.com Subject: Re: [U-Boot] [PATCH 7/8] APM82xxx: Add bluestone board support
Mr Wolfgang, Sure will fix it. Regards, Marri
participants (5)
Feng Kan
Stefan Roese
Tirumala Marri
tmarri@apm.com
