[PATCH 1/2] ARM: imx: Force DRAM regulators into FPWM mode on DH i.MX8MP DHCOM SoM
In case the Buck5 and Buck6 regulators which supply DRAM Vdd1 and Vdd2/Vddq respectively operate in automatic PWM/PFM mode, the DRAM EDAC detects more correctable errors than if the regulators operate in forced PWM only mode. Force DRAM regulators to forced PWM mode only to stop tempting the DRAM.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@dh-electronics.com --- board/dhelectronics/dh_imx8mp/spl.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/dhelectronics/dh_imx8mp/spl.c b/board/dhelectronics/dh_imx8mp/spl.c index 1b05da53c35..21b12a70c8e 100644 --- a/board/dhelectronics/dh_imx8mp/spl.c +++ b/board/dhelectronics/dh_imx8mp/spl.c @@ -94,6 +94,11 @@ static int dh_imx8mp_board_power_init(void) /* To avoid timing risk from SoC to ARM, increase VDD_ARM to OD voltage 0.95V */ pmic_reg_write(dev, PCA9450_BUCK2OUT_DVS0, 0x1c);
+ /* DRAM Vdd1 always FPWM */ + pmic_reg_write(dev, PCA9450_BUCK5CTRL, 0x0d); + /* DRAM Vdd2/Vddq always FPWM */ + pmic_reg_write(dev, PCA9450_BUCK6CTRL, 0x0d); + /* Set LDO4 and CONFIG2 to enable the I2C level translator. */ pmic_reg_write(dev, PCA9450_LDO4CTRL, 0x59); pmic_reg_write(dev, PCA9450_CONFIG2, 0x1);
Import DRAM timings generated by the DDR tool 3.31 which introduce assorted tweaks to the DRAM controller settings. Furthermore, enable DBI to improve noise resilience of the DRAM bus by reducing the number of bit changes on the bus.
Reduce the DRAM rate to 3600 MTps to remove all remaining correctable errors reported by EDAC . It is not entirely clear why the slightly faster setting does produce sporadic correctable errors, while this one does not, but this could be related to simpler PLL setting at 3600 MTps.
Enable inline ECC which is necessary to detect ECC errors and collect statistics by the EDAC driver in Linux. This reduces the DRAM size by 64 MiB for each 512 MiB of DRAM, so for a 4 GiB device the available DRAM size becomes 3.5 GiB and for 2 GiB device the available DRAM size becomes 1.8 GiB.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@dh-electronics.com --- .../dh_imx8mp/imx8mp_dhcom_pdk2.c | 5 +- board/dhelectronics/dh_imx8mp/lpddr4_timing.h | 6 + .../dh_imx8mp/lpddr4_timing_2G_32.c | 130 ++++++++------- .../dh_imx8mp/lpddr4_timing_4G_32.c | 149 +++++++++++------- board/dhelectronics/dh_imx8mp/spl.c | 28 ++++ configs/imx8mp_dhcom_pdk2_defconfig | 3 +- configs/imx8mp_dhcom_pdk3_defconfig | 3 +- 7 files changed, 208 insertions(+), 116 deletions(-)
diff --git a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c index 570d2f59ab8..5e21dfb6751 100644 --- a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c +++ b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c @@ -5,6 +5,7 @@
#include <common.h> #include <asm/arch/clock.h> +#include <asm/arch/ddr.h> #include <asm/arch/sys_proto.h> #include <asm/io.h> #include <dm.h> @@ -30,9 +31,11 @@ int mach_cpu_init(void) int board_phys_sdram_size(phys_size_t *size) { const u16 memsz[] = { 512, 1024, 1536, 2048, 3072, 4096, 6144, 8192 }; + const u8 ecc = readl(DDRC_ECCCFG0(0)) & DDRC_ECCCFG0_ECC_MODE_MASK; u8 memcfg = dh_get_memcfg();
- *size = (u64)memsz[memcfg] << 20ULL; + /* 896 kiB, i.e. 1 MiB without 12.5% reserved for in-band ECC */ + *size = (u64)memsz[memcfg] * (SZ_1M - (ecc ? (SZ_1M / 8) : 0));
return 0; } diff --git a/board/dhelectronics/dh_imx8mp/lpddr4_timing.h b/board/dhelectronics/dh_imx8mp/lpddr4_timing.h index 7894da3b918..c4d51174a33 100644 --- a/board/dhelectronics/dh_imx8mp/lpddr4_timing.h +++ b/board/dhelectronics/dh_imx8mp/lpddr4_timing.h @@ -9,6 +9,12 @@ extern struct dram_timing_info dh_imx8mp_dhcom_dram_timing_16g_x32; extern struct dram_timing_info dh_imx8mp_dhcom_dram_timing_32g_x32;
+typedef void (*scrub_func_t)(void); +extern void dh_imx8mp_dhcom_dram_scrub_16g_x32(void); +extern void dh_imx8mp_dhcom_dram_scrub_32g_x32(void); + u8 dh_get_memcfg(void);
+#define DDRC_ECCCFG0_ECC_MODE_MASK 0x7 + #endif /* __LPDDR4_TIMING_H__ */ diff --git a/board/dhelectronics/dh_imx8mp/lpddr4_timing_2G_32.c b/board/dhelectronics/dh_imx8mp/lpddr4_timing_2G_32.c index 51b8c4cf7ba..add7a0bf23b 100644 --- a/board/dhelectronics/dh_imx8mp/lpddr4_timing_2G_32.c +++ b/board/dhelectronics/dh_imx8mp/lpddr4_timing_2G_32.c @@ -14,48 +14,62 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d400030, 0x1 }, { 0x3d400000, 0xa1080020 }, { 0x3d400020, 0x1323 }, - { 0x3d400024, 0x1c79100 }, - { 0x3d400064, 0x710106 }, + { 0x3d400024, 0x1b77400 }, + { 0x3d400064, 0x6d00fc }, +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) + { 0x3d400070, 0x7027fd4 }, +#else { 0x3d400070, 0x7027f90 }, +#endif { 0x3d400074, 0x790 }, - { 0x3d4000d0, 0xc0030720 }, - { 0x3d4000d4, 0xb80000 }, + { 0x3d4000d0, 0xc00306df }, + { 0x3d4000d4, 0xb10000 }, { 0x3d4000dc, 0xe40036 }, - { 0x3d4000e0, 0x330000 }, + { 0x3d4000e0, 0xf30000 }, { 0x3d4000e8, 0x660048 }, { 0x3d4000ec, 0x160048 }, - { 0x3d400100, 0x1e262028 }, - { 0x3d400104, 0x7073b }, - { 0x3d40010c, 0xe0e000 }, - { 0x3d400110, 0x11040a11 }, + { 0x3d400100, 0x1d241e26 }, + { 0x3d400104, 0x70739 }, + { 0x3d40010c, 0xd0d000 }, + { 0x3d400110, 0x11040911 }, { 0x3d400114, 0x2050e0e }, { 0x3d400118, 0x1010008 }, { 0x3d40011c, 0x502 }, { 0x3d400130, 0x20700 }, { 0x3d400134, 0xd100002 }, - { 0x3d400138, 0x10d }, - { 0x3d400144, 0xbb005e }, - { 0x3d400180, 0x3a5001c }, - { 0x3d400184, 0x2f071e5 }, + { 0x3d400138, 0x103 }, + { 0x3d400144, 0xb4005a }, + { 0x3d400180, 0x384001b }, + { 0x3d400184, 0x2d06ddd }, { 0x3d400188, 0x0 }, - { 0x3d400190, 0x49b820c }, + { 0x3d400190, 0x49f820c }, { 0x3d400194, 0x80303 }, - { 0x3d4001b4, 0x1b0c }, + { 0x3d4001b4, 0x1f0c }, { 0x3d4001a0, 0xe0400018 }, { 0x3d4001a4, 0xdf00e4 }, { 0x3d4001a8, 0x80000000 }, { 0x3d4001b0, 0x11 }, - { 0x3d4001c0, 0x1 }, + { 0x3d4001c0, 0x7 }, { 0x3d4001c4, 0x1 }, { 0x3d4000f4, 0x799 }, - { 0x3d400108, 0x810191a }, + { 0x3d400108, 0x8121b1a }, { 0x3d400200, 0x1f }, { 0x3d400208, 0x0 }, +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) + { 0x3d40020c, 0x13131300 }, +#else { 0x3d40020c, 0x0 }, +#endif { 0x3d400210, 0x1f1f }, +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) + { 0x3d400204, 0x50505 }, + { 0x3d400214, 0x4040404 }, + { 0x3d400218, 0x4040404 }, +#else { 0x3d400204, 0x80808 }, { 0x3d400214, 0x7070707 }, { 0x3d400218, 0x7070707 }, +#endif { 0x3d40021c, 0xf0f }, { 0x3d400250, 0x1705 }, { 0x3d400254, 0x2c }, @@ -74,7 +88,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d402050, 0x20d000 }, { 0x3d402064, 0xc001c }, { 0x3d4020dc, 0x840000 }, - { 0x3d4020e0, 0x330000 }, + { 0x3d4020e0, 0xf30000 }, { 0x3d4020e8, 0x660048 }, { 0x3d4020ec, 0x160048 }, { 0x3d402100, 0xa040305 }, @@ -99,7 +113,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d403050, 0x20d000 }, { 0x3d403064, 0x30007 }, { 0x3d4030dc, 0x840000 }, - { 0x3d4030e0, 0x330000 }, + { 0x3d4030e0, 0xf30000 }, { 0x3d4030e8, 0x660048 }, { 0x3d4030ec, 0x160048 }, { 0x3d403100, 0xa010102 }, @@ -269,7 +283,7 @@ static struct dram_cfg_param ddr_ddrphy_cfg[] = { { 0x20018, 0x3 }, { 0x20075, 0x4 }, { 0x20050, 0x0 }, - { 0x20008, 0x3a5 }, + { 0x20008, 0x384 }, { 0x120008, 0x64 }, { 0x220008, 0x19 }, { 0x20088, 0x9 }, @@ -315,19 +329,15 @@ static struct dram_cfg_param ddr_ddrphy_cfg[] = { { 0x200f6, 0x0 }, { 0x200f7, 0xf000 }, { 0x20025, 0x0 }, - { 0x2002d, 0x0 }, - { 0x12002d, 0x0 }, - { 0x22002d, 0x0 }, + { 0x2002d, 0x1 }, + { 0x12002d, 0x1 }, + { 0x22002d, 0x1 }, { 0x2007d, 0x212 }, { 0x12007d, 0x212 }, { 0x22007d, 0x212 }, { 0x2007c, 0x61 }, { 0x12007c, 0x61 }, { 0x22007c, 0x61 }, - { 0x1004a, 0x500 }, - { 0x1104a, 0x500 }, - { 0x1204a, 0x500 }, - { 0x1304a, 0x500 }, { 0x2002c, 0x0 }, };
@@ -1057,7 +1067,7 @@ static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { /* P0 message block paremeter for training firmware */ static struct dram_cfg_param ddr_fsp0_cfg[] = { { 0xd0000, 0x0 }, - { 0x54003, 0xe94 }, + { 0x54003, 0xe10 }, { 0x54004, 0x2 }, { 0x54005, 0x2228 }, { 0x54006, 0x14 }, @@ -1067,25 +1077,25 @@ static struct dram_cfg_param ddr_fsp0_cfg[] = { { 0x5400f, 0x100 }, { 0x54012, 0x110 }, { 0x54019, 0x36e4 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x36e4 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x1 }, { 0x54032, 0xe400 }, - { 0x54033, 0x3336 }, + { 0x54033, 0xf336 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0xe400 }, - { 0x54039, 0x3336 }, + { 0x54039, 0xf336 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1107,25 +1117,25 @@ static struct dram_cfg_param ddr_fsp1_cfg[] = { { 0x5400f, 0x100 }, { 0x54012, 0x110 }, { 0x54019, 0x84 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x84 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x1 }, { 0x54032, 0x8400 }, - { 0x54033, 0x3300 }, + { 0x54033, 0xf300 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0x8400 }, - { 0x54039, 0x3300 }, + { 0x54039, 0xf300 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1147,25 +1157,25 @@ static struct dram_cfg_param ddr_fsp2_cfg[] = { { 0x5400f, 0x100 }, { 0x54012, 0x110 }, { 0x54019, 0x84 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x84 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x1 }, { 0x54032, 0x8400 }, - { 0x54033, 0x3300 }, + { 0x54033, 0xf300 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0x8400 }, - { 0x54039, 0x3300 }, + { 0x54039, 0xf300 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1176,7 +1186,7 @@ static struct dram_cfg_param ddr_fsp2_cfg[] = { /* P0 2D message block paremeter for training firmware */ static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { { 0xd0000, 0x0 }, - { 0x54003, 0xe94 }, + { 0x54003, 0xe10 }, { 0x54004, 0x2 }, { 0x54005, 0x2228 }, { 0x54006, 0x14 }, @@ -1187,25 +1197,25 @@ static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { { 0x54010, 0x1f7f }, { 0x54012, 0x110 }, { 0x54019, 0x36e4 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x36e4 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x1 }, { 0x54032, 0xe400 }, - { 0x54033, 0x3336 }, + { 0x54033, 0xf336 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0xe400 }, - { 0x54039, 0x3336 }, + { 0x54039, 0xf336 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1695,9 +1705,9 @@ static struct dram_cfg_param ddr_phy_pie[] = { { 0x400d7, 0x20b }, { 0x2003a, 0x2 }, { 0x200be, 0x3 }, - { 0x2000b, 0x419 }, - { 0x2000c, 0xe9 }, - { 0x2000d, 0x91c }, + { 0x2000b, 0x3f4 }, + { 0x2000c, 0xe1 }, + { 0x2000d, 0x8ca }, { 0x2000e, 0x2c }, { 0x12000b, 0x70 }, { 0x12000c, 0x19 }, @@ -1800,8 +1810,8 @@ static struct dram_cfg_param ddr_phy_pie[] = {
static struct dram_fsp_msg ddr_dram_fsp_msg[] = { { - /* P0 3733mts 1D */ - .drate = 3733, + /* P0 3600mts 1D */ + .drate = 3600, .fw_type = FW_1D_IMAGE, .fsp_cfg = ddr_fsp0_cfg, .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), @@ -1821,8 +1831,8 @@ static struct dram_fsp_msg ddr_dram_fsp_msg[] = { .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), }, { - /* P0 3733mts 2D */ - .drate = 3733, + /* P0 3600mts 2D */ + .drate = 3600, .fw_type = FW_2D_IMAGE, .fsp_cfg = ddr_fsp0_2d_cfg, .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), @@ -1841,5 +1851,19 @@ struct dram_timing_info dh_imx8mp_dhcom_dram_timing_16g_x32 = { .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), .ddrphy_pie = ddr_phy_pie, .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), - .fsp_table = { 3733, 400, 100, }, + .fsp_table = { 3600, 400, 100, }, }; + +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) +void dh_imx8mp_dhcom_dram_scrub_16g_x32(void) +{ + ddrc_inline_ecc_scrub(0x0,0x3ffffff); + ddrc_inline_ecc_scrub(0x4000000,0x7ffffff); + ddrc_inline_ecc_scrub(0x8000000,0xbffffff); + ddrc_inline_ecc_scrub(0xc000000,0xfffffff); + ddrc_inline_ecc_scrub(0x10000000,0x13ffffff); + ddrc_inline_ecc_scrub(0x14000000,0x17ffffff); + ddrc_inline_ecc_scrub(0x18000000,0x1bffffff); + ddrc_inline_ecc_scrub_end(0x0,0x1fffffff); +} +#endif diff --git a/board/dhelectronics/dh_imx8mp/lpddr4_timing_4G_32.c b/board/dhelectronics/dh_imx8mp/lpddr4_timing_4G_32.c index a4c1b121c27..41b078f6e9f 100644 --- a/board/dhelectronics/dh_imx8mp/lpddr4_timing_4G_32.c +++ b/board/dhelectronics/dh_imx8mp/lpddr4_timing_4G_32.c @@ -14,47 +14,66 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d400030, 0x1 }, { 0x3d400000, 0xa3080020 }, { 0x3d400020, 0x1323 }, - { 0x3d400024, 0x1c79100 }, - { 0x3d400064, 0x710106 }, + { 0x3d400024, 0x1b77400 }, + { 0x3d400064, 0x6d00fc }, +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) + { 0x3d400070, 0x7027fd4 }, +#else { 0x3d400070, 0x7027f90 }, +#endif { 0x3d400074, 0x790 }, - { 0x3d4000d0, 0xc0030720 }, - { 0x3d4000d4, 0xb80000 }, + { 0x3d4000d0, 0xc00306df }, + { 0x3d4000d4, 0xb10000 }, { 0x3d4000dc, 0xe40036 }, - { 0x3d4000e0, 0x330000 }, + { 0x3d4000e0, 0xf30000 }, { 0x3d4000e8, 0x660048 }, { 0x3d4000ec, 0x160048 }, - { 0x3d400100, 0x1e262028 }, - { 0x3d400104, 0x7073b }, - { 0x3d40010c, 0xe0e000 }, - { 0x3d400110, 0x11040a11 }, + { 0x3d400100, 0x1d241e26 }, + { 0x3d400104, 0x70739 }, + { 0x3d40010c, 0xd0d000 }, + { 0x3d400110, 0x11040911 }, { 0x3d400114, 0x2050e0e }, { 0x3d400118, 0x1010008 }, - { 0x3d40011c, 0x501 }, + { 0x3d40011c, 0x502 }, { 0x3d400130, 0x20700 }, - { 0x3d400134, 0xe100002 }, - { 0x3d400138, 0x10d }, - { 0x3d400144, 0xbb005e }, - { 0x3d400180, 0x3a5001c }, - { 0x3d400184, 0x2f071e5 }, + { 0x3d400134, 0xd100002 }, + { 0x3d400138, 0x103 }, + { 0x3d400144, 0xb4005a }, + { 0x3d400180, 0x384001b }, + { 0x3d400184, 0x2d06ddd }, { 0x3d400188, 0x0 }, - { 0x3d400190, 0x49b820c }, + { 0x3d400190, 0x49f820c }, { 0x3d400194, 0x80303 }, - { 0x3d4001b4, 0x1b0c }, + { 0x3d4001b4, 0x1f0c }, { 0x3d4001a0, 0xe0400018 }, { 0x3d4001a4, 0xdf00e4 }, { 0x3d4001a8, 0x80000000 }, { 0x3d4001b0, 0x11 }, - { 0x3d4001c0, 0x1 }, + { 0x3d4001c0, 0x7 }, { 0x3d4001c4, 0x1 }, - { 0x3d4000f4, 0xc99 }, - { 0x3d400108, 0x810191a }, + { 0x3d4000f4, 0x799 }, + { 0x3d400108, 0x8121b1a }, +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) + { 0x3d400200, 0x14 }, +#else { 0x3d400200, 0x17 }, +#endif + { 0x3d400208, 0x0 }, +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) + { 0x3d40020c, 0x14141400 }, +#else { 0x3d40020c, 0x0 }, +#endif { 0x3d400210, 0x1f1f }, +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) + { 0x3d400204, 0x50505 }, + { 0x3d400214, 0x4040404 }, + { 0x3d400218, 0x4040404 }, +#else { 0x3d400204, 0x80808 }, { 0x3d400214, 0x7070707 }, { 0x3d400218, 0x7070707 }, +#endif { 0x3d40021c, 0xf0f }, { 0x3d400250, 0x1705 }, { 0x3d400254, 0x2c }, @@ -73,7 +92,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d402050, 0x20d000 }, { 0x3d402064, 0xc001c }, { 0x3d4020dc, 0x840000 }, - { 0x3d4020e0, 0x330000 }, + { 0x3d4020e0, 0xf30000 }, { 0x3d4020e8, 0x660048 }, { 0x3d4020ec, 0x160048 }, { 0x3d402100, 0xa040305 }, @@ -83,7 +102,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d402110, 0x2040202 }, { 0x3d402114, 0x2030202 }, { 0x3d402118, 0x1010004 }, - { 0x3d40211c, 0x301 }, + { 0x3d40211c, 0x302 }, { 0x3d402130, 0x20300 }, { 0x3d402134, 0xa100002 }, { 0x3d402138, 0x1d }, @@ -92,13 +111,13 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d402190, 0x3818200 }, { 0x3d402194, 0x80303 }, { 0x3d4021b4, 0x100 }, - { 0x3d4020f4, 0xc99 }, + { 0x3d4020f4, 0x599 }, { 0x3d403020, 0x1021 }, { 0x3d403024, 0xc3500 }, { 0x3d403050, 0x20d000 }, { 0x3d403064, 0x30007 }, { 0x3d4030dc, 0x840000 }, - { 0x3d4030e0, 0x330000 }, + { 0x3d4030e0, 0xf30000 }, { 0x3d4030e8, 0x660048 }, { 0x3d4030ec, 0x160048 }, { 0x3d403100, 0xa010102 }, @@ -108,7 +127,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d403110, 0x2040202 }, { 0x3d403114, 0x2030202 }, { 0x3d403118, 0x1010004 }, - { 0x3d40311c, 0x301 }, + { 0x3d40311c, 0x302 }, { 0x3d403130, 0x20300 }, { 0x3d403134, 0xa100002 }, { 0x3d403138, 0x8 }, @@ -117,7 +136,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d403190, 0x3818200 }, { 0x3d403194, 0x80303 }, { 0x3d4031b4, 0x100 }, - { 0x3d4030f4, 0xc99 }, + { 0x3d4030f4, 0x599 }, { 0x3d400028, 0x0 }, };
@@ -268,7 +287,7 @@ static struct dram_cfg_param ddr_ddrphy_cfg[] = { { 0x20018, 0x3 }, { 0x20075, 0x4 }, { 0x20050, 0x0 }, - { 0x20008, 0x3a5 }, + { 0x20008, 0x384 }, { 0x120008, 0x64 }, { 0x220008, 0x19 }, { 0x20088, 0x9 }, @@ -314,19 +333,15 @@ static struct dram_cfg_param ddr_ddrphy_cfg[] = { { 0x200f6, 0x0 }, { 0x200f7, 0xf000 }, { 0x20025, 0x0 }, - { 0x2002d, 0x0 }, - { 0x12002d, 0x0 }, - { 0x22002d, 0x0 }, + { 0x2002d, 0x1 }, + { 0x12002d, 0x1 }, + { 0x22002d, 0x1 }, { 0x2007d, 0x212 }, { 0x12007d, 0x212 }, { 0x22007d, 0x212 }, { 0x2007c, 0x61 }, { 0x12007c, 0x61 }, { 0x22007c, 0x61 }, - { 0x1004a, 0x500 }, - { 0x1104a, 0x500 }, - { 0x1204a, 0x500 }, - { 0x1304a, 0x500 }, { 0x2002c, 0x0 }, };
@@ -1056,7 +1071,7 @@ static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { /* P0 message block paremeter for training firmware */ static struct dram_cfg_param ddr_fsp0_cfg[] = { { 0xd0000, 0x0 }, - { 0x54003, 0xe94 }, + { 0x54003, 0xe10 }, { 0x54004, 0x2 }, { 0x54005, 0x2228 }, { 0x54006, 0x14 }, @@ -1066,25 +1081,25 @@ static struct dram_cfg_param ddr_fsp0_cfg[] = { { 0x5400f, 0x100 }, { 0x54012, 0x310 }, { 0x54019, 0x36e4 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x36e4 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x3 }, { 0x54032, 0xe400 }, - { 0x54033, 0x3336 }, + { 0x54033, 0xf336 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0xe400 }, - { 0x54039, 0x3336 }, + { 0x54039, 0xf336 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1106,25 +1121,25 @@ static struct dram_cfg_param ddr_fsp1_cfg[] = { { 0x5400f, 0x100 }, { 0x54012, 0x310 }, { 0x54019, 0x84 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x84 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x3 }, { 0x54032, 0x8400 }, - { 0x54033, 0x3300 }, + { 0x54033, 0xf300 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0x8400 }, - { 0x54039, 0x3300 }, + { 0x54039, 0xf300 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1146,25 +1161,25 @@ static struct dram_cfg_param ddr_fsp2_cfg[] = { { 0x5400f, 0x100 }, { 0x54012, 0x310 }, { 0x54019, 0x84 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x84 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x3 }, { 0x54032, 0x8400 }, - { 0x54033, 0x3300 }, + { 0x54033, 0xf300 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0x8400 }, - { 0x54039, 0x3300 }, + { 0x54039, 0xf300 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1175,7 +1190,7 @@ static struct dram_cfg_param ddr_fsp2_cfg[] = { /* P0 2D message block paremeter for training firmware */ static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { { 0xd0000, 0x0 }, - { 0x54003, 0xe94 }, + { 0x54003, 0xe10 }, { 0x54004, 0x2 }, { 0x54005, 0x2228 }, { 0x54006, 0x14 }, @@ -1186,25 +1201,25 @@ static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { { 0x54010, 0x1f7f }, { 0x54012, 0x310 }, { 0x54019, 0x36e4 }, - { 0x5401a, 0x33 }, + { 0x5401a, 0xf3 }, { 0x5401b, 0x4866 }, { 0x5401c, 0x4800 }, { 0x5401e, 0x16 }, { 0x5401f, 0x36e4 }, - { 0x54020, 0x33 }, + { 0x54020, 0xf3 }, { 0x54021, 0x4866 }, { 0x54022, 0x4800 }, { 0x54024, 0x16 }, { 0x5402b, 0x1000 }, { 0x5402c, 0x3 }, { 0x54032, 0xe400 }, - { 0x54033, 0x3336 }, + { 0x54033, 0xf336 }, { 0x54034, 0x6600 }, { 0x54035, 0x48 }, { 0x54036, 0x48 }, { 0x54037, 0x1600 }, { 0x54038, 0xe400 }, - { 0x54039, 0x3336 }, + { 0x54039, 0xf336 }, { 0x5403a, 0x6600 }, { 0x5403b, 0x48 }, { 0x5403c, 0x48 }, @@ -1694,9 +1709,9 @@ static struct dram_cfg_param ddr_phy_pie[] = { { 0x400d7, 0x20b }, { 0x2003a, 0x2 }, { 0x200be, 0x3 }, - { 0x2000b, 0x419 }, - { 0x2000c, 0xe9 }, - { 0x2000d, 0x91c }, + { 0x2000b, 0x3f4 }, + { 0x2000c, 0xe1 }, + { 0x2000d, 0x8ca }, { 0x2000e, 0x2c }, { 0x12000b, 0x70 }, { 0x12000c, 0x19 }, @@ -1799,8 +1814,8 @@ static struct dram_cfg_param ddr_phy_pie[] = {
static struct dram_fsp_msg ddr_dram_fsp_msg[] = { { - /* P0 3733mts 1D */ - .drate = 3733, + /* P0 3600mts 1D */ + .drate = 3600, .fw_type = FW_1D_IMAGE, .fsp_cfg = ddr_fsp0_cfg, .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), @@ -1820,8 +1835,8 @@ static struct dram_fsp_msg ddr_dram_fsp_msg[] = { .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), }, { - /* P0 3733mts 2D */ - .drate = 3733, + /* P0 3600mts 2D */ + .drate = 3600, .fw_type = FW_2D_IMAGE, .fsp_cfg = ddr_fsp0_2d_cfg, .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), @@ -1840,5 +1855,19 @@ struct dram_timing_info dh_imx8mp_dhcom_dram_timing_32g_x32 = { .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), .ddrphy_pie = ddr_phy_pie, .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), - .fsp_table = { 3733, 400, 100, }, + .fsp_table = { 3600, 400, 100, }, }; + +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) +void dh_imx8mp_dhcom_dram_scrub_32g_x32(void) +{ + ddrc_inline_ecc_scrub(0x0,0x7ffffff); + ddrc_inline_ecc_scrub(0x8000000,0xfffffff); + ddrc_inline_ecc_scrub(0x10000000,0x17ffffff); + ddrc_inline_ecc_scrub(0x18000000,0x1fffffff); + ddrc_inline_ecc_scrub(0x20000000,0x27ffffff); + ddrc_inline_ecc_scrub(0x28000000,0x2fffffff); + ddrc_inline_ecc_scrub(0x30000000,0x37ffffff); + ddrc_inline_ecc_scrub_end(0x0,0x3fffffff); +} +#endif diff --git a/board/dhelectronics/dh_imx8mp/spl.c b/board/dhelectronics/dh_imx8mp/spl.c index 21b12a70c8e..7d228da8e5b 100644 --- a/board/dhelectronics/dh_imx8mp/spl.c +++ b/board/dhelectronics/dh_imx8mp/spl.c @@ -11,6 +11,7 @@ #include <asm/io.h> #include <asm-generic/gpio.h> #include <asm/arch/clock.h> +#include <asm/arch/ddr.h> #include <asm/arch/imx8mp_pins.h> #include <asm/arch/sys_proto.h> #include <asm/mach-imx/boot_mode.h> @@ -134,7 +135,34 @@ static void spl_dram_init(void) }
ddr_init(dram_timing_info[memcfg]); + + printf("DDR: Inline ECC %sabled\n", + (readl(DDRC_ECCCFG0(0)) & DDRC_ECCCFG0_ECC_MODE_MASK) ? + "en" : "dis"); +} + +#if IS_ENABLED(CONFIG_IMX8M_DRAM_INLINE_ECC) +static const scrub_func_t dram_scrub_fn[8] = { + NULL, /* 512 MiB */ + NULL, /* 1024 MiB */ + NULL, /* 1536 MiB */ + dh_imx8mp_dhcom_dram_scrub_16g_x32, /* 2048 MiB */ + NULL, /* 3072 MiB */ + dh_imx8mp_dhcom_dram_scrub_32g_x32, /* 4096 MiB */ + NULL, /* 6144 MiB */ + NULL, /* 8192 MiB */ +}; + +void board_dram_ecc_scrub(void) +{ + u8 memcfg = dh_get_memcfg(); + + if (!dram_scrub_fn[memcfg]) + return; + + dram_scrub_fn[memcfg](); } +#endif
void spl_board_init(void) { diff --git a/configs/imx8mp_dhcom_pdk2_defconfig b/configs/imx8mp_dhcom_pdk2_defconfig index 3f9b0e3733c..6e171ae39c7 100644 --- a/configs/imx8mp_dhcom_pdk2_defconfig +++ b/configs/imx8mp_dhcom_pdk2_defconfig @@ -50,7 +50,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_MAX_SIZE=0x25000 +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x96fc00 CONFIG_SPL_BSS_MAX_SIZE=0x400 @@ -166,6 +166,7 @@ CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MP=y CONFIG_CLK_IMX8MP=y CONFIG_FSL_CAAM=y +CONFIG_IMX8M_DRAM_INLINE_ECC=y CONFIG_DFU_TFTP=y CONFIG_DFU_TIMEOUT=y CONFIG_DFU_MMC=y diff --git a/configs/imx8mp_dhcom_pdk3_defconfig b/configs/imx8mp_dhcom_pdk3_defconfig index 50c21d51b8d..32233a03c1c 100644 --- a/configs/imx8mp_dhcom_pdk3_defconfig +++ b/configs/imx8mp_dhcom_pdk3_defconfig @@ -51,7 +51,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_MAX_SIZE=0x25000 +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x96fc00 CONFIG_SPL_BSS_MAX_SIZE=0x400 @@ -168,6 +168,7 @@ CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MP=y CONFIG_CLK_IMX8MP=y CONFIG_FSL_CAAM=y +CONFIG_IMX8M_DRAM_INLINE_ECC=y CONFIG_DFU_TFTP=y CONFIG_DFU_TIMEOUT=y CONFIG_DFU_MMC=y
Applied both to u-boot-imx master, thanks.
Fabio Estevam
