[U-Boot] [PATCH] dfu: free entities when parsing fails
When dfu_init_env_entities() fails part-way through, some entities may have been added to dfu_list. These are only removed by dfu_free_entities(). If that function isn't called, those stale entities will still exist the next time dfu_init_env_entities() is called, leading to confusion. Fix do_dfu() to ensure that dfu_free_entities() is always called, to avoid this confusion.
Signed-off-by: Stephen Warren swarren@nvidia.com --- common/cmd_dfu.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/cmd_dfu.c b/common/cmd_dfu.c index a03538dabb37..433bddd5d2bd 100644 --- a/common/cmd_dfu.c +++ b/common/cmd_dfu.c @@ -27,8 +27,9 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ret = dfu_init_env_entities(interface, simple_strtoul(devstring, NULL, 10)); if (ret) - return ret; + goto done;
+ ret = CMD_RET_SUCCESS; if (argc > 4 && strcmp(argv[4], "list") == 0) { dfu_show_entities(); goto done; @@ -61,7 +62,7 @@ done: if (dfu_reset()) run_command("reset", 0);
- return CMD_RET_SUCCESS; + return ret; }
U_BOOT_CMD(dfu, CONFIG_SYS_MAXARGS, 1, do_dfu,
Hi Stephen,
return ret;
goto done;
- return ret;
Acked-by: Lukasz Majewski l.majewski@samsung.com
Test HW: Exynos4412 - Trats2
Tested-by: Lukasz Majewski l.majewski@samsung.com
Lukasz Majewski
Stephen Warren
