[U-Boot] [PATCH v1 1/2] buildman: Extract environment as part of each build
As we're building the boards, extract the default U-Boot environment to uboot.env so we can interrogate it later.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
tools/buildman/builderthread.py | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index 0efe80d945..688322ced2 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -351,6 +351,16 @@ class BuilderThread(threading.Thread): lines.append(size_result.stdout.splitlines()[1] + ' ' + rodata_size)
+ # Extract the environment from U-Boot and dump it out + cmd = ['%sobjcopy' % self.toolchain.cross, '-O', 'binary', + '-j', '.rodata.default_environment', + 'env/built-in.o', 'uboot.env'] + command.RunPipe([cmd], capture=False, + capture_stderr=False, cwd=result.out_dir, + raise_on_error=False, env=env) + ubootenv = os.path.join(result.out_dir, 'uboot.env') + self.CopyFiles(result.out_dir, build_dir, '', ['uboot.env']) + # Write out the image sizes file. This is similar to the output # of binutil's 'size' utility, but it omits the header line and # adds an additional hex value at the end of each line for the
When summarising the builds, add the -U option to emit delta lines for the default environment built into U-Boot at each commit.
tools/buildman/builder.py | 128 +++++++++++++++++++++++++++++++++----- tools/buildman/cmdline.py | 2 + tools/buildman/control.py | 3 +- 3 files changed, 117 insertions(+), 16 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index 2ccdee02a3..a5a2ffdfdf 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -127,6 +127,15 @@ class Config: val = val ^ hash(key) & hash(value) return val
+class Environment: + """Holds information about environment variables for a board.""" + def __init__(self, target): + self.target = target + self.environment = {} + + def Add(self, key, value): + self.environment[key] = value + class Builder: """Class for building U-Boot for a particular commit.
@@ -199,13 +208,17 @@ class Builder: value is itself a dictionary: key: config name value: config value + environment: Dictionary keyed by environment variable, Each + value is the value of environment variable. """ - def __init__(self, rc, err_lines, sizes, func_sizes, config): + def __init__(self, rc, err_lines, sizes, func_sizes, config, + environment): self.rc = rc self.err_lines = err_lines self.sizes = sizes self.func_sizes = func_sizes self.config = config + self.environment = environment
def __init__(self, toolchains, base_dir, git_dir, num_threads, num_jobs, gnu_make='make', checkout=True, show_unknown=True, step=1, @@ -310,7 +323,8 @@ class Builder:
def SetDisplayOptions(self, show_errors=False, show_sizes=False, show_detail=False, show_bloat=False, - list_error_boards=False, show_config=False): + list_error_boards=False, show_config=False, + show_environment=False): """Setup display options for the builder.
show_errors: True to show summarised error/warning info @@ -319,6 +333,7 @@ class Builder: show_bloat: Show detail for each function list_error_boards: Show the boards which caused each error/warning show_config: Show config deltas + show_environment: Show environment deltas """ self._show_errors = show_errors self._show_sizes = show_sizes @@ -326,6 +341,7 @@ class Builder: self._show_bloat = show_bloat self._list_error_boards = list_error_boards self._show_config = show_config + self._show_environment = show_environment
def _AddTimestamp(self): """Add a new timestamp to the list and record the build period. @@ -609,8 +625,33 @@ class Builder: config[key] = value return config
+ def _ProcessEnvironment(self, fname): + """Read in a uboot.env file + + This function reads in environment variables from a file. + + Args: + fname: Filename to read + + Returns: + Dictionary: + key: environment variable (e.g. bootlimit) + value: value of environment variable (e.g. 1) + """ + environment = {} + if os.path.exists(fname): + with open(fname) as fd: + for line in fd.read().split('\0'): + try: + key, value = line.split('=', 1) + environment[key] = value + except ValueError: + # ignore lines we can't parse + pass + return environment + def GetBuildOutcome(self, commit_upto, target, read_func_sizes, - read_config): + read_config, read_environment): """Work out the outcome of a build.
Args: @@ -618,6 +659,7 @@ class Builder: target: Target board to check read_func_sizes: True to read function size information read_config: True to read .config and autoconf.h files + read_environment: True to read uboot.env files
Returns: Outcome object @@ -627,6 +669,7 @@ class Builder: sizes = {} func_sizes = {} config = {} + environment = {} if os.path.exists(done_file): with open(done_file, 'r') as fd: return_code = int(fd.readline()) @@ -676,12 +719,18 @@ class Builder: fname = os.path.join(output_dir, name) config[name] = self._ProcessConfig(fname)
- return Builder.Outcome(rc, err_lines, sizes, func_sizes, config) + if read_environment: + output_dir = self.GetBuildDir(commit_upto, target) + fname = os.path.join(output_dir, 'uboot.env') + environment = self._ProcessEnvironment(fname) + + return Builder.Outcome(rc, err_lines, sizes, func_sizes, config, + environment)
- return Builder.Outcome(OUTCOME_UNKNOWN, [], {}, {}, {}) + return Builder.Outcome(OUTCOME_UNKNOWN, [], {}, {}, {}, {})
def GetResultSummary(self, boards_selected, commit_upto, read_func_sizes, - read_config): + read_config, read_environment): """Calculate a summary of the results of building a commit.
Args: @@ -689,6 +738,7 @@ class Builder: commit_upto: Commit number to summarize (0..self.count-1) read_func_sizes: True to read function size information read_config: True to read .config and autoconf.h files + read_environment: True to read uboot.env files
Returns: Tuple: @@ -705,6 +755,9 @@ class Builder: value is itself a dictionary: key: config name value: config value + Dictionary keyed by board.target. Each value is a dictionary: + key: environment variable + value: value of environment variable """ def AddLine(lines_summary, lines_boards, line, board): line = line.rstrip() @@ -720,10 +773,12 @@ class Builder: warn_lines_summary = [] warn_lines_boards = {} config = {} + environment = {}
for board in boards_selected.itervalues(): outcome = self.GetBuildOutcome(commit_upto, board.target, - read_func_sizes, read_config) + read_func_sizes, read_config, + read_environment) board_dict[board.target] = outcome last_func = None last_was_warning = False @@ -756,8 +811,14 @@ class Builder: tconfig.Add(fname, key, value) config[board.target] = tconfig
+ tenvironment = Environment(board.target) + if outcome.environment: + for key, value in outcome.environment.iteritems(): + tenvironment.Add(key, value) + environment[board.target] = tenvironment + return (board_dict, err_lines_summary, err_lines_boards, - warn_lines_summary, warn_lines_boards, config) + warn_lines_summary, warn_lines_boards, config, environment)
def AddOutcome(self, board_dict, arch_list, changes, char, color): """Add an output to our list of outcomes for each architecture @@ -810,12 +871,14 @@ class Builder: """ self._base_board_dict = {} for board in board_selected: - self._base_board_dict[board] = Builder.Outcome(0, [], [], {}, {}) + self._base_board_dict[board] = Builder.Outcome(0, [], [], {}, {}, + {}) self._base_err_lines = [] self._base_warn_lines = [] self._base_err_line_boards = {} self._base_warn_line_boards = {} self._base_config = None + self._base_environment = None
def PrintFuncSizeDetail(self, fname, old, new): grow, shrink, add, remove, up, down = 0, 0, 0, 0, 0, 0 @@ -1010,8 +1073,8 @@ class Builder:
def PrintResultSummary(self, board_selected, board_dict, err_lines, err_line_boards, warn_lines, warn_line_boards, - config, show_sizes, show_detail, show_bloat, - show_config): + config, environment, show_sizes, show_detail, + show_bloat, show_config, show_environment): """Compare results with the base results and display delta.
Only boards mentioned in board_selected will be considered. This @@ -1036,10 +1099,13 @@ class Builder: value is itself a dictionary: key: config name value: config value + environment: Dictionary keyed by environment variable, Each + value is the value of environment variable. show_sizes: Show image size deltas show_detail: Show detail for each board show_bloat: Show detail for each function show_config: Show config changes + show_environment: Show environment changes """ def _BoardList(line, line_boards): """Helper function to get a line of boards containing a line @@ -1188,6 +1254,36 @@ class Builder: self.PrintSizeSummary(board_selected, board_dict, show_detail, show_bloat)
+ if show_environment and self._base_environment: + lines = [] + + for target in board_dict: + if target not in board_selected: + continue + + tbase = self._base_environment[target] + tenvironment = environment[target] + environment_plus = {} + environment_minus = {} + environment_change = {} + base = tbase.environment + for key, value in tenvironment.environment.iteritems(): + if key not in base: + environment_plus[key] = value + for key, value in base.iteritems(): + if key not in tenvironment.environment: + environment_minus[key] = value + for key, value in base.iteritems(): + new_value = tenvironment.environment.get(key) + if new_value and value != new_value: + desc = '%s -> %s' % (value, new_value) + environment_change[key] = desc + + _AddConfig(lines, target, environment_plus, environment_minus, + environment_change) + + _OutputConfigInfo(lines) + if show_config and self._base_config: summary = {} arch_config_plus = {} @@ -1294,6 +1390,7 @@ class Builder: self._base_err_line_boards = err_line_boards self._base_warn_line_boards = warn_line_boards self._base_config = config + self._base_environment = environment
# Get a list of boards that did not get built, if needed not_built = [] @@ -1306,10 +1403,11 @@ class Builder:
def ProduceResultSummary(self, commit_upto, commits, board_selected): (board_dict, err_lines, err_line_boards, warn_lines, - warn_line_boards, config) = self.GetResultSummary( + warn_line_boards, config, environment) = self.GetResultSummary( board_selected, commit_upto, read_func_sizes=self._show_bloat, - read_config=self._show_config) + read_config=self._show_config, + read_environment=self._show_environment) if commits: msg = '%02d: %s' % (commit_upto + 1, commits[commit_upto].subject) @@ -1317,8 +1415,8 @@ class Builder: self.PrintResultSummary(board_selected, board_dict, err_lines if self._show_errors else [], err_line_boards, warn_lines if self._show_errors else [], warn_line_boards, - config, self._show_sizes, self._show_detail, - self._show_bloat, self._show_config) + config, environment, self._show_sizes, self._show_detail, + self._show_bloat, self._show_config, self._show_environment)
def ShowSummary(self, commits, board_selected): """Show a build summary for U-Boot for a given board list. diff --git a/tools/buildman/cmdline.py b/tools/buildman/cmdline.py index b8ddd4795c..e493b1ac4a 100644 --- a/tools/buildman/cmdline.py +++ b/tools/buildman/cmdline.py @@ -92,6 +92,8 @@ def ParseArgs(): default=None, help='Number of builder threads to use') parser.add_option('-u', '--show_unknown', action='store_true', default=False, help='Show boards with unknown build result') + parser.add_option('-U', '--show-environment', action='store_true', + default=False, help='Show environment changes in summary') parser.add_option('-v', '--verbose', action='store_true', default=False, help='Show build results while the build progresses') parser.add_option('-V', '--verbose-build', action='store_true', diff --git a/tools/buildman/control.py b/tools/buildman/control.py index 4ac4386db6..bc0819784f 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -319,7 +319,8 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None, builder.SetDisplayOptions(options.show_errors, options.show_sizes, options.show_detail, options.show_bloat, options.list_error_boards, - options.show_config) + options.show_config, + options.show_environment) if options.summary: builder.ShowSummary(commits, board_selected) else:
Hi Alex,
If applicable, you may also consider using: scripts/get_default_envs.sh
script to extract default envs (to txt file).
' ' + rodata_size)
'binary',
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On Fri, May 25, 2018 at 9:05 AM Lukasz Majewski lukma@denx.de wrote:
Hi Alex,
I started with that, but then tripped over boards which have embedded newlines in their environment variables, which then made parsing the resulting text file much harder, which is why I swapped back to just using the NUL terminated blob. Of course I can't now find the one I tripped over to point at :(
' ' + rodata_size)
'binary',
Lukasz Majewski
Hi Alex,
ge_bx50v3 and mx53ppd (the failbootcmd variable)
' ' + rodata_size)
'binary',
Lukasz Majewski
-- Alex Kiernan
-- Alex Kiernan
Hi Alex,
I wonder if this should be an option? Is the file large?
Also please update the README to mention this.
On Sat, May 26, 2018 at 3:07 AM Simon Glass sjg@chromium.org wrote:
Hi Alex,
Only as big as the things that are defined - it's not the full size of CONFIG_ENV_SIZE. The biggest one I've got sitting around is just under 6k, which for that particular board is about 2.5% of the disk use for the whole result directory - doesn't feel like a huge increase.
Will do.
Hi Alex,
Hi Alex,
OK that sounds fine to me.
Will do.
-- Alex Kiernan
Alex Kiernan
Lukasz Majewski
