[PATCH] ARM: armv7: add non-SPL enable for Cortex SMPEN
Commit 2564fce7eea3 ("sunxi: move Cortex SMPEN setting into start.S") added SPL_ARMV7_SET_CORTEX_SMPEN to enable setting SMP bit. For platforms not using SPL boot, add the corresponding non-SPL config, so that CONFIG_IS_ENABLED(ARMV7_SET_CORTEX_SMPEN) works as expected.
Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org ---
arch/arm/cpu/armv7/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv7/Kconfig b/arch/arm/cpu/armv7/Kconfig index 2eeef3cba9..9f859b7c95 100644 --- a/arch/arm/cpu/armv7/Kconfig +++ b/arch/arm/cpu/armv7/Kconfig @@ -76,6 +76,11 @@ config ARMV7_LPAE Say Y here to use the long descriptor page table format. This is required if U-Boot runs in HYP mode.
+config ARMV7_SET_CORTEX_SMPEN + bool + help + Enable the ARM Cortex ACTLR.SMP enable bit in U-boot. + config SPL_ARMV7_SET_CORTEX_SMPEN bool help
- bool
- help
OK, but this doesn't do anything. Where are you select'ing the new symbol from?
It is in code for a new platform which I am going to slowly beat into shape and try to get upstreamed.
If you prefer to see everything at once, I can do that, but I figured I'd post the small stuff as I find it, to try and get it out of the way.
Ralph
OK, I'll keep it in mind for then. But in general, yes, it's OK to wait and post it as a series, if it's not some sort of general regression fix or similar stand-alone functionality.
Ralph Siemsen
