[U-Boot] Unifying device tree filenames, and U-Boot SoC name
I just posted a patch which causes U-Boot to define some variables describing which board you're running on:
http://lists.denx.de/pipermail/u-boot/2012-May/124556.html
In particular, see the description of that first patch for motivation re: U-Boot scripts.
The one issue here is that the U-Boot SoC name for Tegra20 is tegra2 (hence it will define board_soc=tegra2), whereas the kernel's device tree files are all tegra-*.dts not tegra2-*.dts.
I propose we fix this by:
a) In the kernel, renaming tegra*-${board}.dts to tegra20-${board}.dts (or tegra30-${board}.dts). This appears to better match what most other ARM sub-arches are doing anyway.
b) In U-Boot, rename the tegra2 support to tegra20 so that U-Boot ends up setting board_soc=tegra20, so this matches the .dts/.dtb filenames. This would involve renaming arch/arm/cpu/armv7/tegra2/ to ./arch/arm/cpu/armv7/tegra20/ and editing boards.cfg to match, and possibly other related changes.
This sounds like churn, but I think we could easily fold this into Allen's series that moves the tegra2 directory in order to put it in a common place for separate SPL/non-SPL builds to avoid doing this kind of thing multiple times.
Does anyone think this is a good/bad/... idea? Thanks.
I like it. It's better to have the names consistent.
Thierry
Hi Stephen,
On Mon, May 21, 2012 at 7:22 AM, Thierry Reding < thierry.reding@avionic-design.de> wrote:
Sounds good to me, too.
Thierry
On Mon, May 21, 2012 at 05:49:03PM -0700, Simon Glass wrote:
Hi Stephen,
On Mon, May 21, 2012 at 7:22 AM, Thierry Reding <thierry.reding@avionic-design.demailto:thierry.reding@avionic-design.de> wrote:
I'm fine with the proposal, I'll roll it into my SPL patch series which I need to post a new version of anyway.
-Allen
Allen Martin
Stephen Warren
Thierry Reding
