[U-Boot-Users] resend#2 [PATCH 5/8] ColdFire: Add MCF547x_8x dma code and header files
Signed-off-by: TsiChungLiew Tsi-Chung.Liew@freescale.com --- drivers/dma/MCD_tasksInit.c | 247 +++++++++++++++++++++++++++ drivers/dma/Makefile | 46 +++++ include/MCD_dma.h | 386 +++++++++++++++++++++++++++++++++++++++++++ include/MCD_progCheck.h | 27 +++ include/MCD_tasksInit.h | 60 +++++++ 5 files changed, 766 insertions(+), 0 deletions(-) create mode 100644 drivers/dma/MCD_tasksInit.c create mode 100644 drivers/dma/Makefile create mode 100644 include/MCD_dma.h create mode 100644 include/MCD_progCheck.h create mode 100644 include/MCD_tasksInit.h
diff --git a/drivers/dma/MCD_tasksInit.c b/drivers/dma/MCD_tasksInit.c new file mode 100644 index 0000000..0d28713 --- /dev/null +++ b/drivers/dma/MCD_tasksInit.c @@ -0,0 +1,247 @@ +/* + * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +/* Functions for initializing variable tables of different types of tasks. */ + +/* + * Do not edit! + */ + +#ifdef CONFIG_FSLDMAFEC + +#include <MCD_dma.h> + +extern dmaRegs *MCD_dmaBar; + +/* Task 0 */ + +void MCD_startDmaChainNoEu(int *currBD, short srcIncr, short destIncr, + int xferSize, short xferSizeIncr, int *cSave, + volatile TaskTableEntry * taskTable, int channel) +{ + volatile TaskTableEntry *taskChan = taskTable + channel; + + MCD_SET_VAR(taskChan, 2, (u32) currBD); /* var[2] */ + MCD_SET_VAR(taskChan, 25, (u32) (0xe000 << 16) | (0xffff & srcIncr)); /* inc[1] */ + MCD_SET_VAR(taskChan, 24, (u32) (0xe000 << 16) | (0xffff & destIncr)); /* inc[0] */ + MCD_SET_VAR(taskChan, 11, (u32) xferSize); /* var[11] */ + MCD_SET_VAR(taskChan, 26, (u32) (0x2000 << 16) | (0xffff & xferSizeIncr)); /* inc[2] */ + MCD_SET_VAR(taskChan, 0, (u32) cSave); /* var[0] */ + MCD_SET_VAR(taskChan, 1, (u32) 0x00000000); /* var[1] */ + MCD_SET_VAR(taskChan, 3, (u32) 0x00000000); /* var[3] */ + MCD_SET_VAR(taskChan, 4, (u32) 0x00000000); /* var[4] */ + MCD_SET_VAR(taskChan, 5, (u32) 0x00000000); /* var[5] */ + MCD_SET_VAR(taskChan, 6, (u32) 0x00000000); /* var[6] */ + MCD_SET_VAR(taskChan, 7, (u32) 0x00000000); /* var[7] */ + MCD_SET_VAR(taskChan, 8, (u32) 0x00000000); /* var[8] */ + MCD_SET_VAR(taskChan, 9, (u32) 0x00000000); /* var[9] */ + MCD_SET_VAR(taskChan, 10, (u32) 0x00000000); /* var[10] */ + MCD_SET_VAR(taskChan, 12, (u32) 0x00000000); /* var[12] */ + MCD_SET_VAR(taskChan, 13, (u32) 0x80000000); /* var[13] */ + MCD_SET_VAR(taskChan, 14, (u32) 0x00000010); /* var[14] */ + MCD_SET_VAR(taskChan, 15, (u32) 0x00000004); /* var[15] */ + MCD_SET_VAR(taskChan, 16, (u32) 0x08000000); /* var[16] */ + MCD_SET_VAR(taskChan, 27, (u32) 0x00000000); /* inc[3] */ + MCD_SET_VAR(taskChan, 28, (u32) 0x80000000); /* inc[4] */ + MCD_SET_VAR(taskChan, 29, (u32) 0x80000001); /* inc[5] */ + MCD_SET_VAR(taskChan, 30, (u32) 0x40000000); /* inc[6] */ + + /* Set the task's Enable bit in its Task Control Register */ + MCD_dmaBar->taskControl[channel] |= (u16) 0x8000; +} + +/* Task 1 */ + +void MCD_startDmaSingleNoEu(char *srcAddr, short srcIncr, char *destAddr, + short destIncr, int dmaSize, short xferSizeIncr, + int flags, int *currBD, int *cSave, + volatile TaskTableEntry * taskTable, int channel) +{ + volatile TaskTableEntry *taskChan = taskTable + channel; + + MCD_SET_VAR(taskChan, 7, (u32) srcAddr); /* var[7] */ + MCD_SET_VAR(taskChan, 25, (u32) (0xe000 << 16) | (0xffff & srcIncr)); /* inc[1] */ + MCD_SET_VAR(taskChan, 2, (u32) destAddr); /* var[2] */ + MCD_SET_VAR(taskChan, 24, (u32) (0xe000 << 16) | (0xffff & destIncr)); /* inc[0] */ + MCD_SET_VAR(taskChan, 3, (u32) dmaSize); /* var[3] */ + MCD_SET_VAR(taskChan, 26, (u32) (0x2000 << 16) | (0xffff & xferSizeIncr)); /* inc[2] */ + MCD_SET_VAR(taskChan, 5, (u32) flags); /* var[5] */ + MCD_SET_VAR(taskChan, 1, (u32) currBD); /* var[1] */ + MCD_SET_VAR(taskChan, 0, (u32) cSave); /* var[0] */ + MCD_SET_VAR(taskChan, 4, (u32) 0x00000000); /* var[4] */ + MCD_SET_VAR(taskChan, 6, (u32) 0x00000000); /* var[6] */ + MCD_SET_VAR(taskChan, 8, (u32) 0x00000000); /* var[8] */ + MCD_SET_VAR(taskChan, 9, (u32) 0x00000004); /* var[9] */ + MCD_SET_VAR(taskChan, 10, (u32) 0x08000000); /* var[10] */ + MCD_SET_VAR(taskChan, 27, (u32) 0x00000000); /* inc[3] */ + MCD_SET_VAR(taskChan, 28, (u32) 0x80000001); /* inc[4] */ + MCD_SET_VAR(taskChan, 29, (u32) 0x40000000); /* inc[5] */ + + /* Set the task's Enable bit in its Task Control Register */ + MCD_dmaBar->taskControl[channel] |= (u16) 0x8000; +} + +/* Task 2 */ + +void MCD_startDmaChainEu(int *currBD, short srcIncr, short destIncr, + int xferSize, short xferSizeIncr, int *cSave, + volatile TaskTableEntry * taskTable, int channel) +{ + volatile TaskTableEntry *taskChan = taskTable + channel; + + MCD_SET_VAR(taskChan, 3, (u32) currBD); /* var[3] */ + MCD_SET_VAR(taskChan, 25, (u32) (0xe000 << 16) | (0xffff & srcIncr)); /* inc[1] */ + MCD_SET_VAR(taskChan, 24, (u32) (0xe000 << 16) | (0xffff & destIncr)); /* inc[0] */ + MCD_SET_VAR(taskChan, 12, (u32) xferSize); /* var[12] */ + MCD_SET_VAR(taskChan, 26, (u32) (0x2000 << 16) | (0xffff & xferSizeIncr)); /* inc[2] */ + MCD_SET_VAR(taskChan, 0, (u32) cSave); /* var[0] */ + MCD_SET_VAR(taskChan, 1, (u32) 0x00000000); /* var[1] */ + MCD_SET_VAR(taskChan, 2, (u32) 0x00000000); /* var[2] */ + MCD_SET_VAR(taskChan, 4, (u32) 0x00000000); /* var[4] */ + MCD_SET_VAR(taskChan, 5, (u32) 0x00000000); /* var[5] */ + MCD_SET_VAR(taskChan, 6, (u32) 0x00000000); /* var[6] */ + MCD_SET_VAR(taskChan, 7, (u32) 0x00000000); /* var[7] */ + MCD_SET_VAR(taskChan, 8, (u32) 0x00000000); /* var[8] */ + MCD_SET_VAR(taskChan, 9, (u32) 0x00000000); /* var[9] */ + MCD_SET_VAR(taskChan, 10, (u32) 0x00000000); /* var[10] */ + MCD_SET_VAR(taskChan, 11, (u32) 0x00000000); /* var[11] */ + MCD_SET_VAR(taskChan, 13, (u32) 0x00000000); /* var[13] */ + MCD_SET_VAR(taskChan, 14, (u32) 0x80000000); /* var[14] */ + MCD_SET_VAR(taskChan, 15, (u32) 0x00000010); /* var[15] */ + MCD_SET_VAR(taskChan, 16, (u32) 0x00000001); /* var[16] */ + MCD_SET_VAR(taskChan, 17, (u32) 0x00000004); /* var[17] */ + MCD_SET_VAR(taskChan, 18, (u32) 0x08000000); /* var[18] */ + MCD_SET_VAR(taskChan, 27, (u32) 0x00000000); /* inc[3] */ + MCD_SET_VAR(taskChan, 28, (u32) 0x80000000); /* inc[4] */ + MCD_SET_VAR(taskChan, 29, (u32) 0xc0000000); /* inc[5] */ + MCD_SET_VAR(taskChan, 30, (u32) 0x80000001); /* inc[6] */ + MCD_SET_VAR(taskChan, 31, (u32) 0x40000000); /* inc[7] */ + + /* Set the task's Enable bit in its Task Control Register */ + MCD_dmaBar->taskControl[channel] |= (u16) 0x8000; +} + +/* Task 3 */ + +void MCD_startDmaSingleEu(char *srcAddr, short srcIncr, char *destAddr, + short destIncr, int dmaSize, short xferSizeIncr, + int flags, int *currBD, int *cSave, + volatile TaskTableEntry * taskTable, int channel) +{ + volatile TaskTableEntry *taskChan = taskTable + channel; + + MCD_SET_VAR(taskChan, 8, (u32) srcAddr); /* var[8] */ + MCD_SET_VAR(taskChan, 25, (u32) (0xe000 << 16) | (0xffff & srcIncr)); /* inc[1] */ + MCD_SET_VAR(taskChan, 3, (u32) destAddr); /* var[3] */ + MCD_SET_VAR(taskChan, 24, (u32) (0xe000 << 16) | (0xffff & destIncr)); /* inc[0] */ + MCD_SET_VAR(taskChan, 4, (u32) dmaSize); /* var[4] */ + MCD_SET_VAR(taskChan, 26, (u32) (0x2000 << 16) | (0xffff & xferSizeIncr)); /* inc[2] */ + MCD_SET_VAR(taskChan, 6, (u32) flags); /* var[6] */ + MCD_SET_VAR(taskChan, 2, (u32) currBD); /* var[2] */ + MCD_SET_VAR(taskChan, 0, (u32) cSave); /* var[0] */ + MCD_SET_VAR(taskChan, 1, (u32) 0x00000000); /* var[1] */ + MCD_SET_VAR(taskChan, 5, (u32) 0x00000000); /* var[5] */ + MCD_SET_VAR(taskChan, 7, (u32) 0x00000000); /* var[7] */ + MCD_SET_VAR(taskChan, 9, (u32) 0x00000000); /* var[9] */ + MCD_SET_VAR(taskChan, 10, (u32) 0x00000001); /* var[10] */ + MCD_SET_VAR(taskChan, 11, (u32) 0x00000004); /* var[11] */ + MCD_SET_VAR(taskChan, 12, (u32) 0x08000000); /* var[12] */ + MCD_SET_VAR(taskChan, 27, (u32) 0x00000000); /* inc[3] */ + MCD_SET_VAR(taskChan, 28, (u32) 0xc0000000); /* inc[4] */ + MCD_SET_VAR(taskChan, 29, (u32) 0x80000000); /* inc[5] */ + MCD_SET_VAR(taskChan, 30, (u32) 0x80000001); /* inc[6] */ + MCD_SET_VAR(taskChan, 31, (u32) 0x40000000); /* inc[7] */ + + /* Set the task's Enable bit in its Task Control Register */ + MCD_dmaBar->taskControl[channel] |= (u16) 0x8000; +} + +/* Task 4 */ + +void MCD_startDmaENetRcv(char *bDBase, char *currBD, char *rcvFifoPtr, + volatile TaskTableEntry * taskTable, int channel) +{ + volatile TaskTableEntry *taskChan = taskTable + channel; + + MCD_SET_VAR(taskChan, 0, (u32) bDBase); /* var[0] */ + MCD_SET_VAR(taskChan, 3, (u32) currBD); /* var[3] */ + MCD_SET_VAR(taskChan, 6, (u32) rcvFifoPtr); /* var[6] */ + MCD_SET_VAR(taskChan, 1, (u32) 0x00000000); /* var[1] */ + MCD_SET_VAR(taskChan, 2, (u32) 0x00000000); /* var[2] */ + MCD_SET_VAR(taskChan, 4, (u32) 0x00000000); /* var[4] */ + MCD_SET_VAR(taskChan, 5, (u32) 0x00000000); /* var[5] */ + MCD_SET_VAR(taskChan, 7, (u32) 0x00000000); /* var[7] */ + MCD_SET_VAR(taskChan, 8, (u32) 0x00000000); /* var[8] */ + MCD_SET_VAR(taskChan, 9, (u32) 0x0000ffff); /* var[9] */ + MCD_SET_VAR(taskChan, 10, (u32) 0x30000000); /* var[10] */ + MCD_SET_VAR(taskChan, 11, (u32) 0x0fffffff); /* var[11] */ + MCD_SET_VAR(taskChan, 12, (u32) 0x00000008); /* var[12] */ + MCD_SET_VAR(taskChan, 24, (u32) 0x00000000); /* inc[0] */ + MCD_SET_VAR(taskChan, 25, (u32) 0x60000000); /* inc[1] */ + MCD_SET_VAR(taskChan, 26, (u32) 0x20000004); /* inc[2] */ + MCD_SET_VAR(taskChan, 27, (u32) 0x40000000); /* inc[3] */ + + /* Set the task's Enable bit in its Task Control Register */ + MCD_dmaBar->taskControl[channel] |= (u16) 0x8000; +} + +/* Task 5 */ + +void MCD_startDmaENetXmit(char *bDBase, char *currBD, char *xmitFifoPtr, + volatile TaskTableEntry * taskTable, int channel) +{ + volatile TaskTableEntry *taskChan = taskTable + channel; + + MCD_SET_VAR(taskChan, 0, (u32) bDBase); /* var[0] */ + MCD_SET_VAR(taskChan, 3, (u32) currBD); /* var[3] */ + MCD_SET_VAR(taskChan, 11, (u32) xmitFifoPtr); /* var[11] */ + MCD_SET_VAR(taskChan, 1, (u32) 0x00000000); /* var[1] */ + MCD_SET_VAR(taskChan, 2, (u32) 0x00000000); /* var[2] */ + MCD_SET_VAR(taskChan, 4, (u32) 0x00000000); /* var[4] */ + MCD_SET_VAR(taskChan, 5, (u32) 0x00000000); /* var[5] */ + MCD_SET_VAR(taskChan, 6, (u32) 0x00000000); /* var[6] */ + MCD_SET_VAR(taskChan, 7, (u32) 0x00000000); /* var[7] */ + MCD_SET_VAR(taskChan, 8, (u32) 0x00000000); /* var[8] */ + MCD_SET_VAR(taskChan, 9, (u32) 0x00000000); /* var[9] */ + MCD_SET_VAR(taskChan, 10, (u32) 0x00000000); /* var[10] */ + MCD_SET_VAR(taskChan, 12, (u32) 0x00000000); /* var[12] */ + MCD_SET_VAR(taskChan, 13, (u32) 0x0000ffff); /* var[13] */ + MCD_SET_VAR(taskChan, 14, (u32) 0xffffffff); /* var[14] */ + MCD_SET_VAR(taskChan, 15, (u32) 0x00000004); /* var[15] */ + MCD_SET_VAR(taskChan, 16, (u32) 0x00000008); /* var[16] */ + MCD_SET_VAR(taskChan, 24, (u32) 0x00000000); /* inc[0] */ + MCD_SET_VAR(taskChan, 25, (u32) 0x60000000); /* inc[1] */ + MCD_SET_VAR(taskChan, 26, (u32) 0x40000000); /* inc[2] */ + MCD_SET_VAR(taskChan, 27, (u32) 0xc000fffc); /* inc[3] */ + MCD_SET_VAR(taskChan, 28, (u32) 0xe0000004); /* inc[4] */ + MCD_SET_VAR(taskChan, 29, (u32) 0x80000000); /* inc[5] */ + MCD_SET_VAR(taskChan, 30, (u32) 0x4000ffff); /* inc[6] */ + MCD_SET_VAR(taskChan, 31, (u32) 0xe0000001); /* inc[7] */ + + /* Set the task's Enable bit in its Task Control Register */ + MCD_dmaBar->taskControl[channel] |= (u16) 0x8000; +} + +#endif /* CONFIG_FSLDMAFEC */ + diff --git a/drivers/dma/Makefile b/drivers/dma/Makefile new file mode 100644 index 0000000..2dd5a0e --- /dev/null +++ b/drivers/dma/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libdma.a + +COBJS-y += MCD_tasksInit.o MCD_dmaApi.o MCD_tasks.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/include/MCD_dma.h b/include/MCD_dma.h new file mode 100644 index 0000000..2d6bc00 --- /dev/null +++ b/include/MCD_dma.h @@ -0,0 +1,386 @@ +/* + * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _MCD_API_H +#define _MCD_API_H + +/* Turn Execution Unit tasks ON (#define) or OFF (#undef) */ +#undef MCD_INCLUDE_EU + +/* Number of DMA channels */ +#define NCHANNELS 16 + +/* Total number of variants */ +#ifdef MCD_INCLUDE_EU +#define NUMOFVARIANTS 6 +#else +#define NUMOFVARIANTS 4 +#endif + +/* Define sizes of the various tables */ +#define TASK_TABLE_SIZE (NCHANNELS*32) +#define VAR_TAB_SIZE (128) +#define CONTEXT_SAVE_SIZE (128) +#define FUNCDESC_TAB_SIZE (256) + +#ifdef MCD_INCLUDE_EU +#define FUNCDESC_TAB_NUM 16 +#else +#define FUNCDESC_TAB_NUM 1 +#endif + +#ifndef DEFINESONLY + +/* Portability typedefs */ +#if 1 +#include "common.h" +#else +#ifndef s32 +typedef int s32; +#endif +#ifndef u32 +typedef unsigned int u32; +#endif +#ifndef s16 +typedef short s16; +#endif +#ifndef u16 +typedef unsigned short u16; +#endif +#ifndef s8 +typedef char s8; +#endif +#ifndef u8 +typedef unsigned char u8; +#endif +#endif + +/* + * These structures represent the internal registers of the + * multi-channel DMA + */ +struct dmaRegs_s { + u32 taskbar; /* task table base address */ + u32 currPtr; + u32 endPtr; + u32 varTablePtr; + u16 dma_rsvd0; + u16 ptdControl; /* ptd control */ + u32 intPending; /* interrupt pending */ + u32 intMask; /* interrupt mask */ + u16 taskControl[16]; /* task control */ + u8 priority[32]; /* priority */ + u32 initiatorMux; /* initiator mux control */ + u32 taskSize0; /* task size control 0. */ + u32 taskSize1; /* task size control 1. */ + u32 dma_rsvd1; /* reserved */ + u32 dma_rsvd2; /* reserved */ + u32 debugComp1; /* debug comparator 1 */ + u32 debugComp2; /* debug comparator 2 */ + u32 debugControl; /* debug control */ + u32 debugStatus; /* debug status */ + u32 ptdDebug; /* priority task decode debug */ + u32 dma_rsvd3[31]; /* reserved */ +}; +typedef volatile struct dmaRegs_s dmaRegs; + +#endif + +/* PTD contrl reg bits */ +#define PTD_CTL_TSK_PRI 0x8000 +#define PTD_CTL_COMM_PREFETCH 0x0001 + +/* Task Control reg bits and field masks */ +#define TASK_CTL_EN 0x8000 +#define TASK_CTL_VALID 0x4000 +#define TASK_CTL_ALWAYS 0x2000 +#define TASK_CTL_INIT_MASK 0x1f00 +#define TASK_CTL_ASTRT 0x0080 +#define TASK_CTL_HIPRITSKEN 0x0040 +#define TASK_CTL_HLDINITNUM 0x0020 +#define TASK_CTL_ASTSKNUM_MASK 0x000f + +/* Priority reg bits and field masks */ +#define PRIORITY_HLD 0x80 +#define PRIORITY_PRI_MASK 0x07 + +/* Debug Control reg bits and field masks */ +#define DBG_CTL_BLOCK_TASKS_MASK 0xffff0000 +#define DBG_CTL_AUTO_ARM 0x00008000 +#define DBG_CTL_BREAK 0x00004000 +#define DBG_CTL_COMP1_TYP_MASK 0x00003800 +#define DBG_CTL_COMP2_TYP_MASK 0x00000070 +#define DBG_CTL_EXT_BREAK 0x00000004 +#define DBG_CTL_INT_BREAK 0x00000002 + +/* + * PTD Debug reg selector addresses + * This reg must be written with a value to show the contents of + * one of the desired internal register. + */ +#define PTD_DBG_REQ 0x00 /* shows the state of 31 initiators */ +#define PTD_DBG_TSK_VLD_INIT 0x01 /* shows which 16 tasks are valid and + have initiators asserted */ + +/* General return values */ +#define MCD_OK 0 +#define MCD_ERROR -1 +#define MCD_TABLE_UNALIGNED -2 +#define MCD_CHANNEL_INVALID -3 + +/* MCD_initDma input flags */ +#define MCD_RELOC_TASKS 0x00000001 +#define MCD_NO_RELOC_TASKS 0x00000000 +#define MCD_COMM_PREFETCH_EN 0x00000002 /* MCF547x/548x ONLY */ + +/* + * MCD_dmaStatus Status Values for each channel: + * MCD_NO_DMA - No DMA has been requested since reset + * MCD_IDLE - DMA active, but the initiator is currently inactive + * MCD_RUNNING - DMA active, and the initiator is currently active + * MCD_PAUSED - DMA active but it is currently paused + * MCD_HALTED - the most recent DMA has been killed with MCD_killTask() + * MCD_DONE - the most recent DMA has completed + */ +#define MCD_NO_DMA 1 +#define MCD_IDLE 2 +#define MCD_RUNNING 3 +#define MCD_PAUSED 4 +#define MCD_HALTED 5 +#define MCD_DONE 6 + +/* MCD_startDma parameter defines */ + +/* Constants for the funcDesc parameter */ +/* + * MCD_NO_BYTE_SWAP - to disable byte swapping + * MCD_BYTE_REVERSE - to reverse the bytes of each u32 of the DMAed data + * MCD_U16_REVERSE - to reverse the 16-bit halves of each 32-bit data + * value being DMAed + * MCD_U16_BYTE_REVERSE - to reverse the byte halves of each 16-bit half of + * each 32-bit data value DMAed + * MCD_NO_BIT_REV - do not reverse the bits of each byte DMAed + * MCD_BIT_REV - reverse the bits of each byte DMAed + * MCD_CRC16 - to perform CRC-16 on DMAed data + * MCD_CRCCCITT - to perform CRC-CCITT on DMAed data + * MCD_CRC32 - to perform CRC-32 on DMAed data + * MCD_CSUMINET - to perform internet checksums on DMAed data + * MCD_NO_CSUM - to perform no checksumming + */ +#define MCD_NO_BYTE_SWAP 0x00045670 +#define MCD_BYTE_REVERSE 0x00076540 +#define MCD_U16_REVERSE 0x00067450 +#define MCD_U16_BYTE_REVERSE 0x00054760 +#define MCD_NO_BIT_REV 0x00000000 +#define MCD_BIT_REV 0x00088880 +/* CRCing: */ +#define MCD_CRC16 0xc0100000 +#define MCD_CRCCCITT 0xc0200000 +#define MCD_CRC32 0xc0300000 +#define MCD_CSUMINET 0xc0400000 +#define MCD_NO_CSUM 0xa0000000 + +#define MCD_FUNC_NOEU1 (MCD_NO_BYTE_SWAP | MCD_NO_BIT_REV | \ + MCD_NO_CSUM) +#define MCD_FUNC_NOEU2 (MCD_NO_BYTE_SWAP | MCD_NO_CSUM) + +/* Constants for the flags parameter */ +#define MCD_TT_FLAGS_RL 0x00000001 /* Read line */ +#define MCD_TT_FLAGS_CW 0x00000002 /* Combine Writes */ +#define MCD_TT_FLAGS_SP 0x00000004 /* MCF547x/548x ONLY */ +#define MCD_TT_FLAGS_MASK 0x000000ff +#define MCD_TT_FLAGS_DEF (MCD_TT_FLAGS_RL | MCD_TT_FLAGS_CW) + +#define MCD_SINGLE_DMA 0x00000100 /* Unchained DMA */ +#define MCD_CHAIN_DMA /* TBD */ +#define MCD_EU_DMA /* TBD */ +#define MCD_FECTX_DMA 0x00001000 /* FEC TX ring DMA */ +#define MCD_FECRX_DMA 0x00002000 /* FEC RX ring DMA */ + +/* these flags are valid for MCD_startDma and the chained buffer descriptors */ +/* + * MCD_BUF_READY - indicates that this buf is now under the DMA's ctrl + * MCD_WRAP - to tell the FEC Dmas to wrap to the first BD + * MCD_INTERRUPT - to generate an interrupt after completion of the DMA + * MCD_END_FRAME - tell the DMA to end the frame when transferring + * last byte of data in buffer + * MCD_CRC_RESTART - to empty out the accumulated checksum prior to + * performing the DMA + */ +#define MCD_BUF_READY 0x80000000 +#define MCD_WRAP 0x20000000 +#define MCD_INTERRUPT 0x10000000 +#define MCD_END_FRAME 0x08000000 +#define MCD_CRC_RESTART 0x40000000 + +/* Defines for the FEC buffer descriptor control/status word*/ +#define MCD_FEC_BUF_READY 0x8000 +#define MCD_FEC_WRAP 0x2000 +#define MCD_FEC_INTERRUPT 0x1000 +#define MCD_FEC_END_FRAME 0x0800 + +/* Defines for general intuitiveness */ + +#define MCD_TRUE 1 +#define MCD_FALSE 0 + +/* Three different cases for destination and source. */ +#define MINUS1 -1 +#define ZERO 0 +#define PLUS1 1 + +#ifndef DEFINESONLY + +/* Task Table Entry struct*/ +typedef struct { + u32 TDTstart; /* task descriptor table start */ + u32 TDTend; /* task descriptor table end */ + u32 varTab; /* variable table start */ + u32 FDTandFlags; /* function descriptor table start & flags */ + volatile u32 descAddrAndStatus; + volatile u32 modifiedVarTab; + u32 contextSaveSpace; /* context save space start */ + u32 literalBases; +} TaskTableEntry; + +/* Chained buffer descriptor: + * flags - flags describing the DMA + * csumResult - checksum performed since last checksum reset + * srcAddr - the address to move data from + * destAddr - the address to move data to + * lastDestAddr - the last address written to + * dmaSize - the no of bytes to xfer independent of the xfer sz + * next - next buffer descriptor in chain + * info - private info about this descriptor; DMA does not affect it + */ +typedef volatile struct MCD_bufDesc_struct MCD_bufDesc; +struct MCD_bufDesc_struct { + u32 flags; + u32 csumResult; + s8 *srcAddr; + s8 *destAddr; + s8 *lastDestAddr; + u32 dmaSize; + MCD_bufDesc *next; + u32 info; +}; + +/* Progress Query struct: + * lastSrcAddr - the most-recent or last, post-increment source address + * lastDestAddr - the most-recent or last, post-increment destination address + * dmaSize - the amount of data transferred for the current buffer + * currBufDesc - pointer to the current buffer descriptor being DMAed + */ + +typedef volatile struct MCD_XferProg_struct { + s8 *lastSrcAddr; + s8 *lastDestAddr; + u32 dmaSize; + MCD_bufDesc *currBufDesc; +} MCD_XferProg; + +/* FEC buffer descriptor */ +typedef volatile struct MCD_bufDescFec_struct { + u16 statCtrl; + u16 length; + u32 dataPointer; +} MCD_bufDescFec; + +/*************************************************************************/ +/* API function Prototypes - see MCD_dmaApi.c for further notes */ + +/* MCD_startDma starts a particular kind of DMA: + * srcAddr - the channel on which to run the DMA + * srcIncr - the address to move data from, or buffer-descriptor address + * destAddr - the amount to increment the source address per transfer + * destIncr - the address to move data to + * dmaSize - the amount to increment the destination address per transfer + * xferSize - the number bytes in of each data movement (1, 2, or 4) + * initiator - what device initiates the DMA + * priority - priority of the DMA + * flags - flags describing the DMA + * funcDesc - description of byte swapping, bit swapping, and CRC actions + */ +int MCD_startDma(int channel, s8 * srcAddr, s16 srcIncr, s8 * destAddr, + s16 destIncr, u32 dmaSize, u32 xferSize, u32 initiator, + int priority, u32 flags, u32 funcDesc); + +/* + * MCD_initDma() initializes the DMA API by setting up a pointer to the DMA + * registers, relocating and creating the appropriate task structures, and + * setting up some global settings + */ +int MCD_initDma(dmaRegs * sDmaBarAddr, void *taskTableDest, u32 flags); + +/* MCD_dmaStatus() returns the status of the DMA on the requested channel. */ +int MCD_dmaStatus(int channel); + +/* MCD_XferProgrQuery() returns progress of DMA on requested channel */ +int MCD_XferProgrQuery(int channel, MCD_XferProg * progRep); + +/* + * MCD_killDma() halts the DMA on the requested channel, without any + * intention of resuming the DMA. + */ +int MCD_killDma(int channel); + +/* + * MCD_continDma() continues a DMA which as stopped due to encountering an + * unready buffer descriptor. + */ +int MCD_continDma(int channel); + +/* + * MCD_pauseDma() pauses the DMA on the given channel ( if any DMA is + * running on that channel). + */ +int MCD_pauseDma(int channel); + +/* + * MCD_resumeDma() resumes the DMA on a given channel (if any DMA is + * running on that channel). + */ +int MCD_resumeDma(int channel); + +/* MCD_csumQuery provides the checksum/CRC after performing a non-chained DMA */ +int MCD_csumQuery(int channel, u32 * csum); + +/* + * MCD_getCodeSize provides the packed size required by the microcoded task + * and structures. + */ +int MCD_getCodeSize(void); + +/* + * MCD_getVersion provides a pointer to a version string and returns a + * version number. + */ +int MCD_getVersion(char **longVersion); + +/* macro for setting a location in the variable table */ +#define MCD_SET_VAR(taskTab,idx,value) ((u32 *)(taskTab)->varTab)[idx] = value +/* Note that MCD_SET_VAR() is invoked many times in firing up a DMA function, + so I'm avoiding surrounding it with "do {} while(0)" */ + +#endif /* DEFINESONLY */ + +#endif /* _MCD_API_H */ diff --git a/include/MCD_progCheck.h b/include/MCD_progCheck.h new file mode 100644 index 0000000..55f7574 --- /dev/null +++ b/include/MCD_progCheck.h @@ -0,0 +1,27 @@ +/* + * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + /* This file is autogenerated. Do not change */ +#define CURRBD 4 +#define DCOUNT 6 +#define DESTPTR 5 +#define SRCPTR 7 diff --git a/include/MCD_tasksInit.h b/include/MCD_tasksInit.h new file mode 100644 index 0000000..684d5aa --- /dev/null +++ b/include/MCD_tasksInit.h @@ -0,0 +1,60 @@ +/* + * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef MCD_TSK_INIT_H +#define MCD_TSK_INIT_H 1 + +/* + * Do not edit! + */ + +/* Task 0 */ +void MCD_startDmaChainNoEu(int *currBD, short srcIncr, short destIncr, + int xferSize, short xferSizeIncr, int *cSave, + volatile TaskTableEntry * taskTable, int channel); + +/* Task 1 */ +void MCD_startDmaSingleNoEu(char *srcAddr, short srcIncr, char *destAddr, + short destIncr, int dmaSize, short xferSizeIncr, + int flags, int *currBD, int *cSave, + volatile TaskTableEntry * taskTable, int channel); + +/* Task 2 */ +void MCD_startDmaChainEu(int *currBD, short srcIncr, short destIncr, + int xferSize, short xferSizeIncr, int *cSave, + volatile TaskTableEntry * taskTable, int channel); + +/* Task 3 */ +void MCD_startDmaSingleEu(char *srcAddr, short srcIncr, char *destAddr, + short destIncr, int dmaSize, short xferSizeIncr, + int flags, int *currBD, int *cSave, + volatile TaskTableEntry * taskTable, int channel); + +/* Task 4 */ +void MCD_startDmaENetRcv(char *bDBase, char *currBD, char *rcvFifoPtr, + volatile TaskTableEntry * taskTable, int channel); + +/* Task 5 */ +void MCD_startDmaENetXmit(char *bDBase, char *currBD, char *xmitFifoPtr, + volatile TaskTableEntry * taskTable, int channel); + +#endif /* MCD_TSK_INIT_H */
Tsi-Chung Liew
