[PATCH v3 0/4] Conclusive KSTR-SAMA5D27 support
Hi all,
this is v3 of the Conclusive KSTR-SAMA5D27 support series.
Patch [1/4] now takes a different approach at reading the EEPROM serial. An existing CONFIG_ID_EEPROM option provides a mechanism for reading EEPROM embedded MAC addresses at init. As this option is meant for reading various identifying features, not just MACs, I've decided to expand it by the ability of reading serial number, adding a generic serial_read_from_eeprom(). For tlv eeprom, this wraps around existing populate_serial_number(), which now becomes local to tlv_eeprom.c. Other boards which enable CONFIG_ID_EEPROM, but don't store EEPROM data as tlv, will need to provide their own implementations of serial_read_from_eeprom(). A dummy weak function has been provided to prevent compilation issues on such boards.
Simon, you've already accepted the solution from v2, however changes required for [4/4] have forced me to go with this new approach.
Patch [2/4] is new. CONFIG_ID_EEPROM requires that the do_mac() command exists, however implementation of this function has been missing from tlv_eeprom. This patch adds a bare minimum support for it - only handling the "mac read" flag. KSTR-SAMA5D27 is supposed to use EEPROM embedded MAC addresses, however this feature has been overlooked in previous versions of this series.
Patch [3/4] remains unchanged.
Patch [4/4] now uses CONFIG_DISPLAY_BOARDINFO_LATE in order to display the board model and S/N. As a side effect of that, serial access has been moved to CONFIG_ID_EEPROM (see patch [1/4]) and BOARD_LATE_INIT mechanism dropped as unnecessary.
The kstr_sama5d27_defconfig has also been re-generated with savedefconfig, which got rid of some redundant flags.
Artur Rojek (4): common: Add generic function for reading serial number cmd: tlv_eeprom: Add support for do_mac() command arm: dts: at91: sama5: Add flexcom4 node board: Add support for Conclusive KSTR-SAMA5D27
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-kstr-sama5d27.dts | 131 ++++++++++ arch/arm/dts/sama5d2.dtsi | 20 ++ arch/arm/mach-at91/Kconfig | 12 + board/conclusive/kstr-sama5d27/Kconfig | 15 ++ board/conclusive/kstr-sama5d27/MAINTAINERS | 8 + board/conclusive/kstr-sama5d27/Makefile | 5 + .../conclusive/kstr-sama5d27/kstr-sama5d27.c | 230 ++++++++++++++++++ cmd/tlv_eeprom.c | 76 ++++-- common/board_r.c | 8 + configs/kstr_sama5d27_defconfig | 74 ++++++ include/configs/kstr-sama5d27.h | 15 ++ include/init.h | 14 ++ 13 files changed, 595 insertions(+), 16 deletions(-) create mode 100644 arch/arm/dts/at91-kstr-sama5d27.dts create mode 100644 board/conclusive/kstr-sama5d27/Kconfig create mode 100644 board/conclusive/kstr-sama5d27/MAINTAINERS create mode 100644 board/conclusive/kstr-sama5d27/Makefile create mode 100644 board/conclusive/kstr-sama5d27/kstr-sama5d27.c create mode 100644 configs/kstr_sama5d27_defconfig create mode 100644 include/configs/kstr-sama5d27.h
Provide a generic way for boards to read their serial number from EEPROM at init.
If CONFIG_ID_EEPROM is set, the new serial_read_from_eeprom() function will now be called during the post-relocation part of the board init.
Provided is the tlv eeprom implementation of the above function, making use of the existing, yet never utilized, populate_serial_number(). Boards which use custom logic for interaction with their EEPROMs need to supply their own implementation.
Signed-off-by: Artur Rojek artur@conclusive.pl ---
v3: - restore original function name and make it static - provide a generic function for reading EEPROM serial number and wrap it around the existing tlv logic - move the env var check out of populate_serial_number() and into the new serial_read_from_eeprom() in order to stay consistent with the documentation
v2: - rename the function - move function documentation from .c file to the prototype location
cmd/tlv_eeprom.c | 25 +++++++++---------------- common/board_r.c | 8 ++++++++ include/init.h | 14 ++++++++++++++ 3 files changed, 31 insertions(+), 16 deletions(-)
diff --git a/cmd/tlv_eeprom.c b/cmd/tlv_eeprom.c index 79796394c5c8..9aa9b070473e 100644 --- a/cmd/tlv_eeprom.c +++ b/cmd/tlv_eeprom.c @@ -1088,27 +1088,12 @@ int mac_read_from_eeprom(void) return 0; }
-/** - * populate_serial_number - read the serial number from EEPROM - * - * This function reads the serial number from the EEPROM and sets the - * appropriate environment variable. - * - * The environment variable is only set if it has not been set - * already. This ensures that any user-saved variables are never - * overwritten. - * - * This function must be called after relocation. - */ -int populate_serial_number(int devnum) +static int populate_serial_number(int devnum) { char serialstr[257]; int eeprom_index; struct tlvinfo_tlv *eeprom_tlv;
- if (env_get("serial#")) - return 0; - if (read_eeprom(devnum, eeprom)) { printf("Read failed.\n"); return -1; @@ -1123,3 +1108,11 @@ int populate_serial_number(int devnum)
return 0; } + +int serial_read_from_eeprom(void) +{ + if (env_get("serial#")) + return 0; + + return populate_serial_number(0); +} diff --git a/common/board_r.c b/common/board_r.c index 4aaa89403117..0f2cbf7bd741 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -121,6 +121,13 @@ __weak int fixup_cpu(void) return 0; }
+#if defined(CONFIG_ID_EEPROM) +__weak int serial_read_from_eeprom(void) +{ + return 0; +} +#endif + static int initr_reloc_global_data(void) { #ifdef __ARM__ @@ -714,6 +721,7 @@ static init_fnc_t init_sequence_r[] = { cpu_secondary_init_r, #if defined(CONFIG_ID_EEPROM) mac_read_from_eeprom, + serial_read_from_eeprom, #endif INIT_FUNC_WATCHDOG_RESET #if defined(CONFIG_PCI_INIT_R) && !defined(CONFIG_SYS_EARLY_PCI_INIT) diff --git a/include/init.h b/include/init.h index 3bf30476a2e0..df218c95de42 100644 --- a/include/init.h +++ b/include/init.h @@ -283,6 +283,20 @@ void board_init_r(struct global_data *id, ulong dest_addr) int cpu_init_r(void); int last_stage_init(void); int mac_read_from_eeprom(void); + +/** + * serial_read_from_eeprom - read the serial number from EEPROM + * + * This function reads the serial number from the EEPROM and sets the + * appropriate environment variable. + * + * The environment variable is only set if it has not been set + * already. This ensures that any user-saved variables are never + * overwritten. + * + * This function must be called after relocation. + */ +int serial_read_from_eeprom(void); int set_cpu_clk_info(void); int update_flash_size(int flash_size); int arch_early_init_r(void);
Hi Artur,
Can you please use events for this? Something like EVT_SETTINGS_R ?
See the one recently added for how to do this:
INITCALL_EVENT(EVT_LAST_STAGE_INIT),
Hi Artur,
I like this approach, but just to be clear with your intention - you want me to move both serial_read_from_eeprom AND mac_read_from_eeprom into a separate function, defined for each affected board? To do this for mac_read_from_eeprom becomes slightly cumbersome, because there are this many of them, depending on the current scheme:
$ grep -r "ID_EEPROM" ./configs/ | wc -l 55
If each of them needs to contain something like this:
static int settings_r(void) { #if defined(CONFIG_ID_EEPROM) mac_read_from_eeprom(); #endif return 0; } EVENT_SPY_SIMPLE(EVT_SETTINGS_R, settings_r);
then this strays very far from the original intention of this series, which is to add support for a single board :) Unless you only care about serial_read_from_eeprom, then I don't need to modify any of the existing boards.
Cheers, Artur
Hi Artur,
On Wed, 4 Oct 2023 at 06:47, Artur Rojek artur@conclusive.pl wrote:
Hi Artur,
As per irc, you don't need to adjust the mac_read_from_eeprom(). Just start your own thing (read_settings() or whatever) - i.e. don't make it any worse. People do appreciate cleanup, but sometimes it can be a big task
The existing mac_read_from_eeprom() is supposed to be used in conjunction with CONFIG_ID_EEPROM=y. However, when this config option is enabled, it also expects the do_mac() command to be implemented.
Provide tlv_eeprom's implementation of the do_mac() command. At this point only the "read" option is supported.
v3: new patch
cmd/tlv_eeprom.c | 51 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/cmd/tlv_eeprom.c b/cmd/tlv_eeprom.c index 9aa9b070473e..3e9972e506b6 100644 --- a/cmd/tlv_eeprom.c +++ b/cmd/tlv_eeprom.c @@ -1088,6 +1088,57 @@ int mac_read_from_eeprom(void) return 0; }
+#if defined(CONFIG_ID_EEPROM) +int do_mac(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct tlvinfo_tlv *eeprom_tlv; + int i, eeprom_index, maccount, devnum = 0; + u8 macbase[6], *octet_p; + + /* Only the "read" command supported for now. */ + if (argc > 1 && strcmp(argv[1], "read")) { + printf(""%s" command not supported\n", argv[1]); + return 0; + } + + if (read_eeprom(devnum, eeprom)) + return 0; + + maccount = 1; + if (tlvinfo_find_tlv(eeprom, TLV_CODE_MAC_SIZE, &eeprom_index)) { + eeprom_tlv = to_entry(&eeprom[eeprom_index]); + maccount = (eeprom_tlv->value[0] << 8) | eeprom_tlv->value[1]; + } + + memcpy(macbase, "\0\0\0\0\0\0", 6); + if (tlvinfo_find_tlv(eeprom, TLV_CODE_MAC_BASE, &eeprom_index)) { + eeprom_tlv = to_entry(&eeprom[eeprom_index]); + memcpy(macbase, eeprom_tlv->value, 6); + } + + if (!is_valid_ethaddr(macbase)) + return 0; + + for (i = 0; i < maccount; i++) { + printf("EEPROM MAC Address #%d: %02X:%02X:%02X:%02X:%02X:%02X\n", + i, macbase[0], macbase[1], macbase[2], macbase[3], + macbase[4], macbase[5]); + + /* Increment next MAC address. */ + for (octet_p = &macbase[5]; ++*octet_p == 0; octet_p--) { + if (octet_p == &macbase[3]) { + macbase[2] = 0; + macbase[1] = 0; + macbase[0] = 0; + break; + } + } + } + + return 0; +} +#endif + static int populate_serial_number(int devnum) { char serialstr[257];
Set up flexcom4 for Microchip SAMA5D27 SoC and prepare it for usage in I2C mode.
v3: no change
v2: new patch
arch/arm/dts/sama5d2.dtsi | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/arch/arm/dts/sama5d2.dtsi b/arch/arm/dts/sama5d2.dtsi index dd6468ed96aa..819564fdd5bb 100644 --- a/arch/arm/dts/sama5d2.dtsi +++ b/arch/arm/dts/sama5d2.dtsi @@ -781,6 +781,26 @@ status = "disabled"; };
+ flx4: flexcom@fc018000 { + compatible = "atmel,sama5d2-flexcom"; + reg = <0xfc018000 0x200>; + clocks = <&flx4_clk>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xfc018000 0x800>; + status = "disabled"; + + i2c6: i2c@600 { + compatible = "atmel,sama5d2-i2c"; + reg = <0x600 0x200>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&flx4_clk>; + clock-names = "i2c6_clk"; + status = "disabled"; + }; + }; + aic: interrupt-controller@fc020000 { #interrupt-cells = <3>; compatible = "atmel,sama5d2-aic";
Introduce support for Conclusive KSTR-SAMA5D27 Single Board Computer.
Co-developed-by: Jakub Klama jakub@conclusive.pl Signed-off-by: Jakub Klama jakub@conclusive.pl Co-developed-by: Marcin Jabrzyk marcin@conclusive.pl Signed-off-by: Marcin Jabrzyk marcin@conclusive.pl Signed-off-by: Artur Rojek artur@conclusive.pl ---
v3: - use CONFIG_ID_EEPROM to read serial number - as side-effect of using CONFIG_ID_EEPROM, KSTR-SAMA5D27 now also correctly uses EEPROM embedded MAC addresses (overlooked in v1-v2) - use CONFIG_DISPLAY_BOARDINFO_LATE for printing the board model and serial number, and provide the required checkboard() call - drop CONFIG_BOARD_LATE_INIT, as not needed anymore - defconfig cleanup
v2: - remove redundant license text from at91-kstr-sama5d27.dts - when defining properties in .dts, reference nodes by labels - drop nodes for usb0 and pmic, as these aren't used by drivers - switch i2c to flexcom driver and make the necessary dts changes - sort includes in at91-kstr-sama5d27.dts alphabetically
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-kstr-sama5d27.dts | 131 ++++++++++ arch/arm/mach-at91/Kconfig | 12 + board/conclusive/kstr-sama5d27/Kconfig | 15 ++ board/conclusive/kstr-sama5d27/MAINTAINERS | 8 + board/conclusive/kstr-sama5d27/Makefile | 5 + .../conclusive/kstr-sama5d27/kstr-sama5d27.c | 230 ++++++++++++++++++ configs/kstr_sama5d27_defconfig | 74 ++++++ include/configs/kstr-sama5d27.h | 15 ++ 9 files changed, 493 insertions(+) create mode 100644 arch/arm/dts/at91-kstr-sama5d27.dts create mode 100644 board/conclusive/kstr-sama5d27/Kconfig create mode 100644 board/conclusive/kstr-sama5d27/MAINTAINERS create mode 100644 board/conclusive/kstr-sama5d27/Makefile create mode 100644 board/conclusive/kstr-sama5d27/kstr-sama5d27.c create mode 100644 configs/kstr_sama5d27_defconfig create mode 100644 include/configs/kstr-sama5d27.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 85fd5b1157b1..8e4d33c01912 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1198,6 +1198,9 @@ dtb-$(CONFIG_TARGET_SAMA5D27_SOM1_EK) += \ dtb-$(CONFIG_TARGET_SAMA5D27_WLSOM1_EK) += \ at91-sama5d27_wlsom1_ek.dtb
+dtb-$(CONFIG_TARGET_KSTR_SAMA5D27) += \ + at91-kstr-sama5d27.dtb + dtb-$(CONFIG_TARGET_SAMA5D2_ICP) += \ at91-sama5d2_icp.dtb
diff --git a/arch/arm/dts/at91-kstr-sama5d27.dts b/arch/arm/dts/at91-kstr-sama5d27.dts new file mode 100644 index 000000000000..fe9ec7e5bbc3 --- /dev/null +++ b/arch/arm/dts/at91-kstr-sama5d27.dts @@ -0,0 +1,131 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * at91-kstr-sama5d27.dts - Device Tree file for Conclusive KSTR-SAMA5D27 board + * + * Copyright (C) 2019-2023 Conclusive Engineering Sp. z o. o. + * + */ +/dts-v1/; + +#include "sama5d2.dtsi" +#include "sama5d2-pinfunc.h" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/mfd/atmel-flexcom.h> + +/ { + model = "Conclusive KSTR-SAMA5D27"; + compatible = "conclusive,kstr-sama5d27", "atmel,sama5d2", "atmel,sama5"; + + chosen { + bootph-all; + stdout-path = &uart1; + }; +}; + +&main_xtal { + clock-frequency = <12000000>; +}; + +&sdmmc0 { + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdmmc0_cmd_dat_default &pinctrl_sdmmc0_ck_cd_default>; + status = "okay"; + bootph-all; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1_default>; + status = "okay"; + bootph-all; +}; + +&macb0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_macb0_rmii &pinctrl_macb0_phy_irq>; + phy-mode = "rmii"; + status = "okay"; + + ethernet-phy@0 { + reg = <0x0>; + reset-gpios = <&pioA 44 GPIO_ACTIVE_LOW>; + }; +}; + +&flx4 { + atmel,flexcom-mode = <ATMEL_FLEXCOM_MODE_TWI>; + status = "okay"; +}; + +&i2c6 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flx4_i2c>; + status = "okay"; + + eeprom: eeprom@50 { + compatible = "microchip,24c32", "atmel,24c32"; + reg = <0x50>; + read-only; + pagesize = <32>; + status = "okay"; + }; +}; + +&pioA { + pinctrl { + pinctrl_uart1_default: uart1_default { + pinmux = <PIN_PD2__URXD1>, + <PIN_PD3__UTXD1>; + bias-disable; + bootph-all; + }; + + pinctrl_macb0_phy_irq: macb0_phy_irq { + pinmux = <PIN_PB13__GPIO>; + bias-disable; + bootph-all; + }; + + pinctrl_macb0_rmii: macb0_rmii { + pinmux = <PIN_PB14__GTXCK>, + <PIN_PB15__GTXEN>, + <PIN_PB16__GRXDV>, + <PIN_PB17__GRXER>, + <PIN_PB18__GRX0>, + <PIN_PB19__GRX1>, + <PIN_PB20__GTX0>, + <PIN_PB21__GTX1>, + <PIN_PB22__GMDC>, + <PIN_PB23__GMDIO>; + bias-disable; + bootph-all; + }; + + pinctrl_sdmmc0_cmd_dat_default: sdmmc0_cmd_dat_default { + pinmux = <PIN_PA1__SDMMC0_CMD>, + <PIN_PA2__SDMMC0_DAT0>, + <PIN_PA3__SDMMC0_DAT1>, + <PIN_PA4__SDMMC0_DAT2>, + <PIN_PA5__SDMMC0_DAT3>; + bias-pull-up; + bootph-all; + }; + + pinctrl_sdmmc0_ck_cd_default: sdmmc0_ck_cd_default { + pinmux = <PIN_PA0__SDMMC0_CK>, + <PIN_PA11__SDMMC0_VDDSEL>, + <PIN_PA13__SDMMC0_CD>; + bias-disable; + bootph-all; + }; + + pinctrl_flx4_i2c: flx4_i2c { + pinmux = <PIN_PC28__FLEXCOM4_IO0>, + <PIN_PC29__FLEXCOM4_IO1>; + bias-disable; + }; + }; +}; diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 7c2e4ebbdb0f..79435be1b907 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -204,6 +204,17 @@ config TARGET_SAMA5D27_WLSOM1_EK processor-based SAMA5D2 MPU with 2 Gbit LPDDR2-SDRAM in a single package.
+config TARGET_KSTR_SAMA5D27 + bool "Conclusive KSTR-SAMA5D27 board" + select BOARD_EARLY_INIT_F + select SAMA5D2 + help + The KSTR-SAMA5D27 embeds SAMA5D27 SoC, together with + 256 MiB SDRAM, 10/100 Mbit/s Ethernet, 96 Mbit/s Wi-Fi b/g/n, + Bluetooth 4.1 LE, USB OTG controller w/ type-C USB connector + and stackable GPIO headers in an all-in-one SBC form factor: + https://conclusive.pl/products/kstr-sama5d27-sbc/ + config TARGET_SAMA5D2_ICP bool "SAMA5D2 Industrial Connectivity Platform (ICP)" select SAMA5D2 @@ -352,6 +363,7 @@ source "board/atmel/sama5d4_xplained/Kconfig" source "board/atmel/sama5d4ek/Kconfig" source "board/bluewater/gurnard/Kconfig" source "board/calao/usb_a9263/Kconfig" +source "board/conclusive/kstr-sama5d27/Kconfig" source "board/egnite/ethernut5/Kconfig" source "board/esd/meesc/Kconfig" source "board/gardena/smart-gateway-at91sam/Kconfig" diff --git a/board/conclusive/kstr-sama5d27/Kconfig b/board/conclusive/kstr-sama5d27/Kconfig new file mode 100644 index 000000000000..572551cfda98 --- /dev/null +++ b/board/conclusive/kstr-sama5d27/Kconfig @@ -0,0 +1,15 @@ +if TARGET_KSTR_SAMA5D27 + +config SYS_BOARD + default "kstr-sama5d27" + +config SYS_VENDOR + default "conclusive" + +config SYS_SOC + default "at91" + +config SYS_CONFIG_NAME + default "kstr-sama5d27" + +endif diff --git a/board/conclusive/kstr-sama5d27/MAINTAINERS b/board/conclusive/kstr-sama5d27/MAINTAINERS new file mode 100644 index 000000000000..cb1635cdd280 --- /dev/null +++ b/board/conclusive/kstr-sama5d27/MAINTAINERS @@ -0,0 +1,8 @@ +CONCLUSIVE KSTR-SAMA5D27 BOARD +M: Jakub Klama jakub@conclusive.pl +M: Artur Rojek artur@conclusive.pl +S: Maintained +F: board/conclusive/kstr-sama5d27 +F: include/configs/kstr-sama5d27.h +F: configs/kstr_sama5d27_defconfig +F: arch/arm/dts/at91-kstr-sama5d27.dts diff --git a/board/conclusive/kstr-sama5d27/Makefile b/board/conclusive/kstr-sama5d27/Makefile new file mode 100644 index 000000000000..edf7d1c93441 --- /dev/null +++ b/board/conclusive/kstr-sama5d27/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019-2023 Conclusive Engineering Sp. z o. o. + +obj-y += kstr-sama5d27.o diff --git a/board/conclusive/kstr-sama5d27/kstr-sama5d27.c b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c new file mode 100644 index 000000000000..15484eb24321 --- /dev/null +++ b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c @@ -0,0 +1,230 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * kstr-sama5d27.c - Board init file for Conclusive KSTR-SAMA5D27 board + * Copyright (C) 2021-2023 Conclusive Engineering Sp. z o. o. + */ + +#include <common.h> +#include <debug_uart.h> +#include <init.h> +#include <env.h> +#include <fdt_support.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/atmel_pio4.h> +#include <asm/arch/atmel_mpddrc.h> +#include <asm/arch/atmel_sdhci.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/sama5d2.h> +#include <linux/delay.h> + +#ifdef CONFIG_USB_GADGET_ATMEL_USBA +#include <asm/arch/atmel_usba_udc.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +static void board_uart1_hw_init(void) +{ + /* URXD1 */ + atmel_pio4_set_a_periph(AT91_PIO_PORTD, 2, ATMEL_PIO_PUEN_MASK); + /* UTXD1 */ + atmel_pio4_set_a_periph(AT91_PIO_PORTD, 3, 0); + at91_periph_clk_enable(ATMEL_ID_UART1); +} + +void board_debug_uart_init(void) +{ + board_uart1_hw_init(); +} +#endif + +void board_lan8720a_init(void) +{ + /* LAN8720A_nRST */ + atmel_pio4_set_pio_output(AT91_PIO_PORTB, 12, 0); + /* + * Force 0 on RXER/PHYAD0. LAN8720A chipset will latch with address 0 on + * MDIO bus. + */ + atmel_pio4_set_pio_output(AT91_PIO_PORTB, 17, 0); + /* Minimal delay of reset signal is 25 ms */ + mdelay(30); + /* LAN8720A_nRST */ + atmel_pio4_set_pio_output(AT91_PIO_PORTB, 12, 1); +} + +void board_usba_init(void) +{ +#ifdef CONFIG_USB_GADGET_ATMEL_USBA + /* USB device peripheral initialization: sama5d2_devices.c */ + at91_udp_hw_init(); + /* USB device controller drivers/usb/gadget/atmel_usba_udc.c */ + usba_udc_probe(&pdata); +#endif +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif + + return 0; +} +#endif + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + char *wlanaddr = env_get("eth1addr"); + + if (wlanaddr) + do_fixup_by_compat(blob, "brcm,bcm4329-fmac", "local-mac-address", + wlanaddr, strlen(wlanaddr), 1); + else + printf("Not setting WIFI mac address. Check if EEPROM TLV is correctly set up.\n"); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = CFG_SYS_SDRAM_BASE + 0x100; + + board_usba_init(); + board_lan8720a_init(); + + return 0; +} + +#if defined(CONFIG_DISPLAY_BOARDINFO_LATE) +int checkboard(void) +{ + const char *serial_number; + + serial_number = env_get("serial#"); + if (!serial_number) + printf("Warning: unknown serial number.\n"); + else + printf("S/N: %s\n", serial_number); + + return 0; +} +#endif + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + return 0; +} +#endif + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CFG_SYS_SDRAM_BASE, + CFG_SYS_SDRAM_SIZE); + return 0; +} + +/* SPL */ +#ifdef CONFIG_SPL_BUILD +void spl_board_init(void) +{ +} + +static void ddrc_conf(struct atmel_mpddrc_config *ddrc) +{ + ddrc->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddrc->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_13 | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | + ATMEL_MPDDRC_CR_DIC_DS | + ATMEL_MPDDRC_CR_ZQ_LONG | + ATMEL_MPDDRC_CR_NB_8BANKS | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED | + ATMEL_MPDDRC_CR_UNAL_SUPPORTED); + + ddrc->rtr = 0x511; + + ddrc->tpr0 = ((7 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TWR_OFFSET) | + (9 << ATMEL_MPDDRC_TPR0_TRC_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TRP_OFFSET) | + (4 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET) | + (4 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET) | + (2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET)); + + ddrc->tpr1 = ((22 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET) | + (23 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET) | + (200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET) | + (3 << ATMEL_MPDDRC_TPR1_TXP_OFFSET)); + + ddrc->tpr2 = ((2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET) | + (8 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET) | + (4 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET) | + (4 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET) | + (8 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET)); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; + struct atmel_mpddrc_config ddrc_config; + u32 reg; + + ddrc_conf(&ddrc_config); + + at91_periph_clk_enable(ATMEL_ID_MPDDRC); + writel(AT91_PMC_DDR, &pmc->scer); + + reg = readl(&mpddrc->io_calibr); + reg &= ~ATMEL_MPDDRC_IO_CALIBR_RDIV; + reg |= ATMEL_MPDDRC_IO_CALIBR_DDR3_RZQ_55; + reg &= ~ATMEL_MPDDRC_IO_CALIBR_TZQIO; + reg |= ATMEL_MPDDRC_IO_CALIBR_TZQIO_(101); + writel(reg, &mpddrc->io_calibr); + + writel(ATMEL_MPDDRC_RD_DATA_PATH_SHIFT_ONE_CYCLE, + &mpddrc->rd_data_path); + + ddr3_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddrc_config); + + writel(0x3, &mpddrc->cal_mr4); + writel(64, &mpddrc->tim_cal); +} + +void at91_pmc_init(void) +{ + u32 tmp; + + /* + * While coming from the ROM code, we run on PLLA @ 492 MHz / 164 MHz, + * so we need to slow down and configure MCKR accordingly. + * This is why we have a special flavor of the switching function. + */ + tmp = AT91_PMC_MCKR_PLLADIV_2 | + AT91_PMC_MCKR_MDIV_3 | + AT91_PMC_MCKR_CSS_MAIN; + at91_mck_init_down(tmp); + + tmp = AT91_PMC_PLLAR_29 | + AT91_PMC_PLLXR_PLLCOUNT(0x3f) | + AT91_PMC_PLLXR_MUL(40) | + AT91_PMC_PLLXR_DIV(1); + at91_plla_init(tmp); + + tmp = AT91_PMC_MCKR_H32MXDIV | + AT91_PMC_MCKR_PLLADIV_2 | + AT91_PMC_MCKR_MDIV_3 | + AT91_PMC_MCKR_CSS_PLLA; + at91_mck_init(tmp); +} +#endif diff --git a/configs/kstr_sama5d27_defconfig b/configs/kstr_sama5d27_defconfig new file mode 100644 index 000000000000..a7217110a416 --- /dev/null +++ b/configs/kstr_sama5d27_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_TEXT_BASE=0x26f00000 +CONFIG_TARGET_KSTR_SAMA5D27=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20003ee0 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="at91-kstr-sama5d27" +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y +CONFIG_SYS_MONITOR_LEN=524288 +CONFIG_SYS_LOAD_ADDR=0x24000000 +CONFIG_FIT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" +# CONFIG_USE_BOOTCOMMAND is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_ID_EEPROM=y +CONFIG_CMD_TLV_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_I2C_EEPROM=y +CONFIG_MICROCHIP_FLEXCOM=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_PHY_MICREL=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_RESET_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_AT91=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x16c0 +CONFIG_USB_GADGET_PRODUCT_NUM=0x03e9 +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_USB_GADGET_DOWNLOAD=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/kstr-sama5d27.h b/include/configs/kstr-sama5d27.h new file mode 100644 index 000000000000..772a073ba209 --- /dev/null +++ b/include/configs/kstr-sama5d27.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2021-2023 Conclusive Engineering Sp. z o. o. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "at91-sama5_common.h" + +/* SDRAM */ +#define CFG_SYS_SDRAM_BASE 0x20000000 +#define CFG_SYS_SDRAM_SIZE 0x10000000 + +#endif
Artur Rojek
