[U-Boot] [PATCH v2 0/4] board: at91sam9x5ek: convert board to support DM and DT
The purpose of the patch set is to convert the board to support Driver Model and Device Tree. It is based on the patch set: [PATCH v5 0/2] pinctrl: at91: Add pinctrl driver http://lists.denx.de/pipermail/u-boot/2017-February/280463.html
Changes in v2: - rebase on the patch set: [RESEND PATCH v2] ARM: at91: add default config file for sama5d36ek CMP board http://lists.denx.de/pipermail/u-boot/2017-February/280525.html
Wenyou Yang (4): board: at91sam9x5ek: move config options to defconfig board: at91sam9x5ek: clean up code board: at91sam9x5ek: enable early debug UART configs: at91sam9x5ek: move SYS_NO_FLASH to defconfig
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 80 ++++++-------------------------- configs/at91sam9x5ek_dataflash_defconfig | 27 ++++++++++- configs/at91sam9x5ek_mmc_defconfig | 27 ++++++++++- configs/at91sam9x5ek_nandflash_defconfig | 27 ++++++++++- configs/at91sam9x5ek_spiflash_defconfig | 34 ++++++++++---- include/configs/at91sam9x5ek.h | 22 +-------- 6 files changed, 119 insertions(+), 98 deletions(-)
Enable CONFIG_CLK and CONFIG_PINCTRL to support at91 clock driver and at91 pinctrl driver.
Move some config options to configs/sama5d4ek_*_defconfig, and make the drivers, spi, emac, gpio, serial and ehci usb to support the driver model.
Due to the limitation of internal SRAM size, disable the SPL option for the spi flash configuration.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 ++ configs/at91sam9x5ek_dataflash_defconfig | 20 +++++++++++++++++++- configs/at91sam9x5ek_mmc_defconfig | 20 +++++++++++++++++++- configs/at91sam9x5ek_nandflash_defconfig | 20 +++++++++++++++++++- configs/at91sam9x5ek_spiflash_defconfig | 27 +++++++++++++++++++-------- include/configs/at91sam9x5ek.h | 19 +------------------ 6 files changed, 79 insertions(+), 29 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index cc81776f9b..0ae42dd158 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -205,6 +205,7 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif /* CONFIG_LCD */
+#ifndef CONFIG_DM_SPI /* SPI chip select control */ #ifdef CONFIG_ATMEL_SPI int spi_cs_is_valid(unsigned int bus, unsigned int cs) @@ -238,6 +239,7 @@ void spi_cs_deactivate(struct spi_slave *slave) } } #endif /* CONFIG_ATMEL_SPI */ +#endif
#ifdef CONFIG_GENERIC_ATMEL_MCI int board_mmc_init(bd_t *bd) diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index e07e2175e0..c3feca28bc 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -21,9 +22,26 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 9a95a0496a..f4b0edd4ca 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -21,9 +22,26 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 05907b7859..5c3463260e 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -27,9 +28,26 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 5fc512b998..939a6bbd4a 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -1,18 +1,12 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y @@ -28,9 +22,26 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 897ffa9a0a..a11d5748da 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -26,10 +26,8 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO
/* serial console */ -#define CONFIG_ATMEL_USART #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS
@@ -73,12 +71,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
-/* DataFlash */ -#ifdef CONFIG_CMD_SF -#define CONFIG_ATMEL_SPI -#define CONFIG_SF_DEFAULT_SPEED 30000000 -#endif - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL @@ -113,18 +105,9 @@ #define CONFIG_GENERIC_ATMEL_MCI #endif
-/* Ethernet */ -#define CONFIG_MACB -#define CONFIG_RMII -#define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_MACB_SEARCH_PHY - /* USB */ #ifdef CONFIG_CMD_USB -#ifdef CONFIG_USB_EHCI -#define CONFIG_USB_EHCI_ATMEL -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#else +#ifndef CONFIG_USB_EHCI #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_UPLL #define CONFIG_USB_OHCI_NEW
Since the introduction of the pinctrl and clk driver and the dts file, remove unneeded hard coded related code from the board file
Changes in v2: None
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 68 --------------------------------- 1 file changed, 68 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 0ae42dd158..9bd5eaf363 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -15,17 +15,10 @@ #include <lcd.h> #include <atmel_hlcdc.h> #include <atmel_mci.h> -#ifdef CONFIG_MACB -#include <net.h> -#endif -#include <netdev.h> #ifdef CONFIG_LCD_INFO #include <nand.h> #include <version.h> #endif -#ifdef CONFIG_ATMEL_SPI -#include <spi.h> -#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -92,21 +85,6 @@ static void at91sam9x5ek_nand_hw_init(void) } #endif
-int board_eth_init(bd_t *bis) -{ - int rc = 0; - -#ifdef CONFIG_MACB - if (has_emac0()) - rc = macb_eth_initialize(0, - (void *)ATMEL_BASE_EMAC0, 0x00); - if (has_emac1()) - rc = macb_eth_initialize(1, - (void *)ATMEL_BASE_EMAC1, 0x00); -#endif - return rc; -} - #ifdef CONFIG_LCD vidinfo_t panel_info = { .vl_col = 800, @@ -205,42 +183,6 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif /* CONFIG_LCD */
-#ifndef CONFIG_DM_SPI -/* SPI chip select control */ -#ifdef CONFIG_ATMEL_SPI -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return bus == 0 && cs < 2; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - switch (slave->cs) { - case 1: - at91_set_pio_output(AT91_PIO_PORTA, 7, 0); - break; - case 0: - default: - at91_set_pio_output(AT91_PIO_PORTA, 14, 0); - break; - } -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - switch (slave->cs) { - case 1: - at91_set_pio_output(AT91_PIO_PORTA, 7, 1); - break; - case 0: - default: - at91_set_pio_output(AT91_PIO_PORTA, 14, 1); - break; - } -} -#endif /* CONFIG_ATMEL_SPI */ -#endif - #ifdef CONFIG_GENERIC_ATMEL_MCI int board_mmc_init(bd_t *bd) { @@ -268,14 +210,6 @@ int board_init(void) at91sam9x5ek_nand_hw_init(); #endif
-#ifdef CONFIG_ATMEL_SPI - at91_spi0_hw_init(1 << 4); -#endif - -#ifdef CONFIG_MACB - at91_macb_hw_init(); -#endif - #if defined(CONFIG_USB_OHCI_NEW) || defined(CONFIG_USB_EHCI) at91_uhp_hw_init(); #endif @@ -302,8 +236,6 @@ void at91_spl_board_init(void) at91_mci_hw_init(); #elif CONFIG_SYS_USE_NANDFLASH at91sam9x5ek_nand_hw_init(); -#elif CONFIG_SYS_USE_SPIFLASH - at91_spi0_hw_init(1 << 4); #endif }
Enable early debug UART to debug problems when an ICE or other debug mechanism is not available.
Changes in v2: None
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 14 ++++++++++++++ configs/at91sam9x5ek_dataflash_defconfig | 6 ++++++ configs/at91sam9x5ek_mmc_defconfig | 6 ++++++ configs/at91sam9x5ek_nandflash_defconfig | 6 ++++++ configs/at91sam9x5ek_spiflash_defconfig | 6 ++++++ 5 files changed, 38 insertions(+)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 9bd5eaf363..77714db3e7 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -12,6 +12,7 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> +#include <debug_uart.h> #include <lcd.h> #include <atmel_hlcdc.h> #include <atmel_mci.h> @@ -192,11 +193,24 @@ int board_mmc_init(bd_t *bd) } #endif
+#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + at91_seriald_hw_init(); +} +#endif + +#ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#else at91_seriald_hw_init(); +#endif return 0; } +#endif
int board_init(void) { diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index c3feca28bc..d7408e8b29 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -37,6 +37,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=0 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index f4b0edd4ca..07f62fc38b 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -37,6 +37,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=0 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 5c3463260e..15ac465abd 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -44,6 +44,12 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y CONFIG_ATMEL_USART=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=0 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y CONFIG_USB=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 939a6bbd4a..d44d851848 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -37,6 +37,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=0 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y
Move CONFIG_SYS_NO_FLASH to the configs/sama5d4*_defconfig file.
configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + include/configs/at91sam9x5ek.h | 3 --- 5 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index d7408e8b29..8351281a79 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_NO_FLASH=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 07f62fc38b..6d212d40e8 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_NO_FLASH=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 15ac465abd..d90481ec1c 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_NO_FLASH=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index d44d851848..b9fbf39d08 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_NO_FLASH=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index a11d5748da..c133eb85ab 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -50,9 +50,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* no NOR flash */ -#define CONFIG_SYS_NO_FLASH - /* * Command line configuration. */
2017-02-07 18:11 GMT+09:00 Wenyou Yang wenyou.yang@atmel.com:
We do not this kind of patch. Partial move is not helpful at all.
this one conflicts with e856bdcfb49291d30b19603fc101bea096c48196, just drop it from the series.
Andreas
Changes in v2:
- Command line configuration.
Andreas Bießmann
Masahiro Yamada
Wenyou Yang
