[U-Boot] Adds driver for Xilinx' xps_spi SPI controller
Adds a driver for Xilinx' xps_spi controller. This code differs in only trivial ways from the altera_spi driver. It plays nice with Thomas Chou's mmc_spi driver, as well as with SPI flash.
Documentation for the SPI core is available here:
http://www.xilinx.com/support/documentation/ip_documentation/xps_spi.pdf
--- drivers/spi/Makefile | 1 + drivers/spi/xilinx_spi.c | 171 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 172 insertions(+), 0 deletions(-) create mode 100644 drivers/spi/xilinx_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index dfcbb8b..34e0f31 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libspi.a
COBJS-$(CONFIG_ALTERA_SPI) += altera_spi.o +COBJS-$(CONFIG_XILINX_SPI) += xilinx_spi.o COBJS-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o COBJS-$(CONFIG_ATMEL_SPI) += atmel_spi.o COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c new file mode 100644 index 0000000..99ce661 --- /dev/null +++ b/drivers/spi/xilinx_spi.c @@ -0,0 +1,171 @@ +/* + * Xilinx SPI driver + * + * based on bfin_spi.c, by way of altera_spi.c + * Copyright (c) 2005-2008 Analog Devices Inc. + * Copyright (c) 2010 Thomas Chou thomas@wytron.com.tw + * Copyright (c) 2010 Graeme Smecher graeme.smecher@mail.mcgill.ca + * + * Licensed under the GPL-2 or later. + */ +#include <common.h> +#include <asm/io.h> +#include <malloc.h> +#include <spi.h> + +#define debug printf + +#define XILINX_SPI_RR 0x6c +#define XILINX_SPI_TR 0x68 +#define XILINX_SPI_SR 0x64 +#define XILINX_SPI_CR 0x60 +#define XILINX_SPI_SSR 0x70 + +#define XILINX_SPI_SR_RX_EMPTY_MSK 0x01 + +#define XILINX_SPI_CR_DEFAULT (0x0086) + +#if XPAR_XSPI_NUM_INSTANCES > 4 +# warning "The xilinx_spi driver will ignore some of your SPI peripherals!" +#endif + +static ulong xilinx_spi_base_list[] = { +#ifdef XPAR_SPI_0_BASEADDR + XPAR_SPI_0_BASEADDR, +#endif +#ifdef XPAR_SPI_1_BASEADDR + XPAR_SPI_1_BASEADDR, +#endif +#ifdef XPAR_SPI_2_BASEADDR + XPAR_SPI_2_BASEADDR, +#endif +#ifdef XPAR_SPI_3_BASEADDR + XPAR_SPI_3_BASEADDR, +#endif +}; + +struct xilinx_spi_slave { + struct spi_slave slave; + ulong base; +}; +#define to_xilinx_spi_slave(s) container_of(s, struct xilinx_spi_slave, slave) + +__attribute__((weak)) +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus < ARRAY_SIZE(xilinx_spi_base_list) && cs < 32; +} + +__attribute__((weak)) +void spi_cs_activate(struct spi_slave *slave) +{ + struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + writel(~(1 << slave->cs), xilspi->base + XILINX_SPI_SSR); +} + +__attribute__((weak)) +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + writel(~0, xilspi->base + XILINX_SPI_SSR); +} + +void spi_init(void) +{ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct xilinx_spi_slave *xilspi; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + xilspi = malloc(sizeof(*xilspi)); + if (!xilspi) + return NULL; + + xilspi->slave.bus = bus; + xilspi->slave.cs = cs; + xilspi->base = xilinx_spi_base_list[bus]; + debug("%s: bus:%i cs:%i base:%lx\n", __func__, + bus, cs, xilspi->base); + + writel(XILINX_SPI_CR_DEFAULT, xilspi->base + XILINX_SPI_CR); + + return &xilspi->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + free(xilspi); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + writel(~0, xilspi->base + XILINX_SPI_SSR); + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + writel(~0, xilspi->base + XILINX_SPI_SSR); +} + +#ifndef CONFIG_XILINX_SPI_IDLE_VAL +# define CONFIG_XILINX_SPI_IDLE_VAL 0xff +#endif + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); + /* assume spi core configured to do 8 bit transfers */ + uint bytes = bitlen / 8; + const uchar *txp = dout; + uchar *rxp = din; + + debug("%s: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", __func__, + slave->bus, slave->cs, bitlen, bytes, flags); + if (bitlen == 0) + goto done; + + if (bitlen % 8) { + flags |= SPI_XFER_END; + goto done; + } + + /* empty read buffer */ + while (!(readl(xilspi->base + XILINX_SPI_SR) & + XILINX_SPI_SR_RX_EMPTY_MSK)) + readl(xilspi->base + XILINX_SPI_RR); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + while (bytes--) { + uchar d = txp ? *txp++ : CONFIG_XILINX_SPI_IDLE_VAL; + debug("%s: tx:%x ", __func__, d); + writel(d, xilspi->base + XILINX_SPI_TR); + while (readl(xilspi->base + XILINX_SPI_SR) & + XILINX_SPI_SR_RX_EMPTY_MSK) + ; + d = readl(xilspi->base + XILINX_SPI_RR); + if (rxp) + *rxp++ = d; + debug("rx:%x\n", d); + } + done: + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +}
Hi all,
I neglected to point out that this driver has been tested with Thomas Chou's mmc_spi patches, and appears to work with SPI flash (Winbond w25q64) as well.
A quick diff shows this driver is nearly identical to the altera_spi driver. The only differences are:
* the CS register is active-low here, and * the control register requires some additional setup.
cheers, Graeme Smecher
- Xilinx SPI driver
- based on bfin_spi.c, by way of altera_spi.c
- Copyright (c) 2005-2008 Analog Devices Inc.
- Copyright (c) 2010 Thomas Chouthomas@wytron.com.tw
- Copyright (c) 2010 Graeme Smechergraeme.smecher@mail.mcgill.ca
- Licensed under the GPL-2 or later.
+#include<common.h> +#include<asm/io.h> +#include<malloc.h> +#include<spi.h>
+#if XPAR_XSPI_NUM_INSTANCES> 4 +# warning "The xilinx_spi driver will ignore some of your SPI peripherals!" +#endif
- XPAR_SPI_0_BASEADDR,
- XPAR_SPI_1_BASEADDR,
- XPAR_SPI_2_BASEADDR,
- XPAR_SPI_3_BASEADDR,
+#endif +};
- struct spi_slave slave;
- ulong base;
- return bus< ARRAY_SIZE(xilinx_spi_base_list)&& cs< 32;
- struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave);
- writel(~(1<< slave->cs), xilspi->base + XILINX_SPI_SSR);
- writel(~0, xilspi->base + XILINX_SPI_SSR);
- struct xilinx_spi_slave *xilspi;
- if (!spi_cs_is_valid(bus, cs))
return NULL;
- xilspi = malloc(sizeof(*xilspi));
- if (!xilspi)
return NULL;
- xilspi->slave.bus = bus;
- xilspi->slave.cs = cs;
- xilspi->base = xilinx_spi_base_list[bus];
- debug("%s: bus:%i cs:%i base:%lx\n", __func__,
- writel(XILINX_SPI_CR_DEFAULT, xilspi->base + XILINX_SPI_CR);
- return&xilspi->slave;
- free(xilspi);
- debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs);
- /* assume spi core configured to do 8 bit transfers */
- uint bytes = bitlen / 8;
- const uchar *txp = dout;
- uchar *rxp = din;
- debug("%s: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", __func__,
- if (bitlen == 0)
goto done;
- if (bitlen % 8) {
goto done;
- /* empty read buffer */
- while (!(readl(xilspi->base + XILINX_SPI_SR)&
- if (flags& SPI_XFER_BEGIN)
- while (bytes--) {
while (readl(xilspi->base + XILINX_SPI_SR)&
if (rxp)
*rxp++ = d;
- done:
- if (flags& SPI_XFER_END)
Graeme Smecher
