[PATCH v3] net: Add NIC controller driver for OcteonTX2
Adds support for Network Interface controllers found on OcteonTX2 SoC platforms.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Signed-off-by: Stefan Roese sr@denx.de Cc: Joe Hershberger joe.hershberger@ni.com --- Series-changes: 3 - Add SoB from Stefan - Remove spdx.org line from comment - Remove inclusion of common.h header - Order header file inclusion - Misc minor checkpatch fixes
Series-changes: 1 - Change patch subject - Rebased on latest TOT - Removed inclusion of common.h
drivers/net/Kconfig | 17 + drivers/net/Makefile | 2 + drivers/net/octeontx2/Makefile | 8 + drivers/net/octeontx2/cgx.c | 296 ++++++++ drivers/net/octeontx2/cgx.h | 105 +++ drivers/net/octeontx2/cgx_intf.c | 715 ++++++++++++++++++ drivers/net/octeontx2/cgx_intf.h | 448 +++++++++++ drivers/net/octeontx2/lmt.h | 49 ++ drivers/net/octeontx2/nix.c | 831 +++++++++++++++++++++ drivers/net/octeontx2/nix.h | 353 +++++++++ drivers/net/octeontx2/nix_af.c | 1102 ++++++++++++++++++++++++++++ drivers/net/octeontx2/npc.h | 90 +++ drivers/net/octeontx2/rvu.h | 119 +++ drivers/net/octeontx2/rvu_af.c | 171 +++++ drivers/net/octeontx2/rvu_common.c | 71 ++ drivers/net/octeontx2/rvu_pf.c | 116 +++ 16 files changed, 4493 insertions(+) create mode 100644 drivers/net/octeontx2/Makefile create mode 100644 drivers/net/octeontx2/cgx.c create mode 100644 drivers/net/octeontx2/cgx.h create mode 100644 drivers/net/octeontx2/cgx_intf.c create mode 100644 drivers/net/octeontx2/cgx_intf.h create mode 100644 drivers/net/octeontx2/lmt.h create mode 100644 drivers/net/octeontx2/nix.c create mode 100644 drivers/net/octeontx2/nix.h create mode 100644 drivers/net/octeontx2/nix_af.c create mode 100644 drivers/net/octeontx2/npc.h create mode 100644 drivers/net/octeontx2/rvu.h create mode 100644 drivers/net/octeontx2/rvu_af.c create mode 100644 drivers/net/octeontx2/rvu_common.c create mode 100644 drivers/net/octeontx2/rvu_pf.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 26ea53d346..6e758f5581 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -414,6 +414,15 @@ config NET_OCTEONTX help You must select Y to enable network device support for OcteonTX SoCs. If unsure, say n + +config NET_OCTEONTX2 + bool "OcteonTX2 Ethernet support" + depends on ARCH_OCTEONTX2 + select OCTEONTX2_CGX_INTF + help + You must select Y to enable network device support for + OcteonTX2 SoCs. If unsure, say n + config OCTEONTX_SMI bool "OcteonTX SMI Device support" depends on ARCH_OCTEONTX || ARCH_OCTEONTX2 @@ -421,6 +430,14 @@ config OCTEONTX_SMI You must select Y to enable SMI controller support for OcteonTX or OcteonTX2 SoCs. If unsure, say n
+config OCTEONTX2_CGX_INTF + bool "OcteonTX2 CGX ATF interface support" + depends on ARCH_OCTEONTX2 + default y if ARCH_OCTEONTX2 + help + You must select Y to enable CGX ATF interface support for + OcteonTX2 SoCs. If unsure, say n + config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI diff --git a/drivers/net/Makefile b/drivers/net/Makefile index bee9680f76..c07b5ad698 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -66,7 +66,9 @@ obj-$(CONFIG_SMC91111) += smc91111.o obj-$(CONFIG_SMC911X) += smc911x.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o obj-$(CONFIG_NET_OCTEONTX) += octeontx/ +obj-$(CONFIG_NET_OCTEONTX2) += octeontx2/ obj-$(CONFIG_OCTEONTX_SMI) += octeontx/smi.o +obj-$(CONFIG_OCTEONTX2_CGX_INTF) += octeontx2/cgx_intf.o obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o obj-$(CONFIG_ULI526X) += uli526x.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o diff --git a/drivers/net/octeontx2/Makefile b/drivers/net/octeontx2/Makefile new file mode 100644 index 0000000000..c9300727ae --- /dev/null +++ b/drivers/net/octeontx2/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Copyright (C) 2018 Marvell International Ltd. +# + +obj-$(CONFIG_NET_OCTEONTX2) += cgx.o nix_af.o nix.o rvu_pf.o \ + rvu_af.o rvu_common.o + diff --git a/drivers/net/octeontx2/cgx.c b/drivers/net/octeontx2/cgx.c new file mode 100644 index 0000000000..ff2ebc25ce --- /dev/null +++ b/drivers/net/octeontx2/cgx.c @@ -0,0 +1,296 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <linux/list.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-cgx.h> +#include <asm/io.h> + +#include "cgx.h" + +char lmac_type_to_str[][8] = { + "SGMII", + "XAUI", + "RXAUI", + "10G_R", + "40G_R", + "RGMII", + "QSGMII", + "25G_R", + "50G_R", + "100G_R", + "USXGMII", +}; + +char lmac_speed_to_str[][8] = { + "0", + "10M", + "100M", + "1G", + "2.5G", + "5G", + "10G", + "20G", + "25G", + "40G", + "50G", + "80G", + "100G", +}; + +/** + * Given an LMAC/PF instance number, return the lmac + * Per design, each PF has only one LMAC mapped. + * + * @param instance instance to find + * + * @return pointer to lmac data structure or NULL if not found + */ +struct lmac *nix_get_cgx_lmac(int lmac_instance) +{ + struct cgx *cgx; + struct udevice *dev; + int i, idx, err; + + for (i = 0; i < CGX_PER_NODE; i++) { + err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM, + PCI_DEVICE_ID_OCTEONTX2_CGX, i, + &dev); + if (err) + continue; + + cgx = dev_get_priv(dev); + debug("%s udev %p cgx %p instance %d\n", __func__, dev, cgx, + lmac_instance); + for (idx = 0; idx < cgx->lmac_count; idx++) { + if (cgx->lmac[idx]->instance == lmac_instance) + return cgx->lmac[idx]; + } + } + return NULL; +} + +void cgx_lmac_mac_filter_clear(struct lmac *lmac) +{ + union cgxx_cmrx_rx_dmac_ctl0 dmac_ctl0; + union cgxx_cmr_rx_dmacx_cam0 dmac_cam0; + void *reg_addr; + + dmac_cam0.u = 0x0; + reg_addr = lmac->cgx->reg_base + + CGXX_CMR_RX_DMACX_CAM0(lmac->lmac_id * 8); + writeq(dmac_cam0.u, reg_addr); + debug("%s: reg %p dmac_cam0 %llx\n", __func__, reg_addr, dmac_cam0.u); + + dmac_ctl0.u = 0x0; + dmac_ctl0.s.bcst_accept = 1; + dmac_ctl0.s.mcst_mode = 1; + dmac_ctl0.s.cam_accept = 0; + reg_addr = lmac->cgx->reg_base + + CGXX_CMRX_RX_DMAC_CTL0(lmac->lmac_id); + writeq(dmac_ctl0.u, reg_addr); + debug("%s: reg %p dmac_ctl0 %llx\n", __func__, reg_addr, dmac_ctl0.u); +} + +void cgx_lmac_mac_filter_setup(struct lmac *lmac) +{ + union cgxx_cmrx_rx_dmac_ctl0 dmac_ctl0; + union cgxx_cmr_rx_dmacx_cam0 dmac_cam0; + u64 mac, tmp; + void *reg_addr; + + memcpy((void *)&tmp, lmac->mac_addr, 6); + debug("%s: tmp %llx\n", __func__, tmp); + debug("%s: swab tmp %llx\n", __func__, swab64(tmp)); + mac = swab64(tmp) >> 16; + debug("%s: mac %llx\n", __func__, mac); + dmac_cam0.u = 0x0; + dmac_cam0.s.id = lmac->lmac_id; + dmac_cam0.s.adr = mac; + dmac_cam0.s.en = 1; + reg_addr = lmac->cgx->reg_base + + CGXX_CMR_RX_DMACX_CAM0(lmac->lmac_id * 8); + writeq(dmac_cam0.u, reg_addr); + debug("%s: reg %p dmac_cam0 %llx\n", __func__, reg_addr, dmac_cam0.u); + dmac_ctl0.u = 0x0; + dmac_ctl0.s.bcst_accept = 1; + dmac_ctl0.s.mcst_mode = 0; + dmac_ctl0.s.cam_accept = 1; + reg_addr = lmac->cgx->reg_base + + CGXX_CMRX_RX_DMAC_CTL0(lmac->lmac_id); + writeq(dmac_ctl0.u, reg_addr); + debug("%s: reg %p dmac_ctl0 %llx\n", __func__, reg_addr, dmac_ctl0.u); +} + +int cgx_lmac_set_pkind(struct lmac *lmac, u8 lmac_id, int pkind) +{ + cgx_write(lmac->cgx, lmac_id, CGXX_CMRX_RX_ID_MAP(0), + (pkind & 0x3f)); + return 0; +} + +int cgx_lmac_link_status(struct lmac *lmac, int lmac_id, u64 *status) +{ + int ret = 0; + + ret = cgx_intf_get_link_sts(lmac->cgx->cgx_id, lmac_id, status); + if (ret) { + debug("%s request failed for cgx%d lmac%d\n", + __func__, lmac->cgx->cgx_id, lmac->lmac_id); + ret = -1; + } + return ret; +} + +int cgx_lmac_rx_tx_enable(struct lmac *lmac, int lmac_id, bool enable) +{ + struct cgx *cgx = lmac->cgx; + union cgxx_cmrx_config cmrx_config; + + if (!cgx || lmac_id >= cgx->lmac_count) + return -ENODEV; + + cmrx_config.u = cgx_read(cgx, lmac_id, CGXX_CMRX_CONFIG(0)); + cmrx_config.s.data_pkt_rx_en = + cmrx_config.s.data_pkt_tx_en = enable ? 1 : 0; + cgx_write(cgx, lmac_id, CGXX_CMRX_CONFIG(0), cmrx_config.u); + return 0; +} + +int cgx_lmac_link_enable(struct lmac *lmac, int lmac_id, bool enable, + u64 *status) +{ + int ret = 0; + + ret = cgx_intf_link_up_dwn(lmac->cgx->cgx_id, lmac_id, enable, + status); + if (ret) { + debug("%s request failed for cgx%d lmac%d\n", + __func__, lmac->cgx->cgx_id, lmac->lmac_id); + ret = -1; + } + return ret; +} + +int cgx_lmac_internal_loopback(struct lmac *lmac, int lmac_id, bool enable) +{ + struct cgx *cgx = lmac->cgx; + union cgxx_cmrx_config cmrx_cfg; + union cgxx_gmp_pcs_mrx_control mrx_control; + union cgxx_spux_control1 spux_control1; + enum lmac_type lmac_type; + + if (!cgx || lmac_id >= cgx->lmac_count) + return -ENODEV; + + cmrx_cfg.u = cgx_read(cgx, lmac_id, CGXX_CMRX_CONFIG(0)); + lmac_type = cmrx_cfg.s.lmac_type; + if (lmac_type == LMAC_MODE_SGMII || lmac_type == LMAC_MODE_QSGMII) { + mrx_control.u = cgx_read(cgx, lmac_id, + CGXX_GMP_PCS_MRX_CONTROL(0)); + mrx_control.s.loopbck1 = enable ? 1 : 0; + cgx_write(cgx, lmac_id, CGXX_GMP_PCS_MRX_CONTROL(0), + mrx_control.u); + } else { + spux_control1.u = cgx_read(cgx, lmac_id, + CGXX_SPUX_CONTROL1(0)); + spux_control1.s.loopbck = enable ? 1 : 0; + cgx_write(cgx, lmac_id, CGXX_SPUX_CONTROL1(0), + spux_control1.u); + } + return 0; +} + +static int cgx_lmac_init(struct cgx *cgx) +{ + struct lmac *lmac; + union cgxx_cmrx_config cmrx_cfg; + static int instance = 1; + int i; + + cgx->lmac_count = cgx_read(cgx, 0, CGXX_CMR_RX_LMACS()); + debug("%s: Found %d lmacs for cgx %d@%p\n", __func__, cgx->lmac_count, + cgx->cgx_id, cgx->reg_base); + + for (i = 0; i < cgx->lmac_count; i++) { + lmac = calloc(1, sizeof(*lmac)); + if (!lmac) + return -ENOMEM; + lmac->instance = instance++; + snprintf(lmac->name, sizeof(lmac->name), "cgx_fwi_%d_%d", + cgx->cgx_id, i); + /* Get LMAC type */ + cmrx_cfg.u = cgx_read(cgx, i, CGXX_CMRX_CONFIG(0)); + lmac->lmac_type = cmrx_cfg.s.lmac_type; + + lmac->lmac_id = i; + lmac->cgx = cgx; + cgx->lmac[i] = lmac; + debug("%s: map id %d to lmac %p (%s), type:%d instance %d\n", + __func__, i, lmac, lmac->name, lmac->lmac_type, + lmac->instance); + lmac->init_pend = 1; + printf("CGX%d LMAC%d [%s]\n", lmac->cgx->cgx_id, + lmac->lmac_id, lmac_type_to_str[lmac->lmac_type]); + octeontx2_board_get_mac_addr((lmac->instance - 1), + lmac->mac_addr); + debug("%s: MAC %pM\n", __func__, lmac->mac_addr); + cgx_lmac_mac_filter_setup(lmac); + } + return 0; +} + +int cgx_probe(struct udevice *dev) +{ + struct cgx *cgx = dev_get_priv(dev); + int err; + + cgx->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + cgx->dev = dev; + cgx->cgx_id = ((u64)(cgx->reg_base) >> 24) & 0x7; + + debug("%s CGX BAR %p, id: %d\n", __func__, cgx->reg_base, + cgx->cgx_id); + debug("%s CGX %p, udev: %p\n", __func__, cgx, dev); + + err = cgx_lmac_init(cgx); + + return err; +} + +int cgx_remove(struct udevice *dev) +{ + struct cgx *cgx = dev_get_priv(dev); + int i; + + debug("%s: cgx remove reg_base %p cgx_id %d", + __func__, cgx->reg_base, cgx->cgx_id); + for (i = 0; i < cgx->lmac_count; i++) + cgx_lmac_mac_filter_clear(cgx->lmac[i]); + + return 0; +} + +U_BOOT_DRIVER(cgx) = { + .name = "cgx", + .id = UCLASS_MISC, + .probe = cgx_probe, + .remove = cgx_remove, + .priv_auto_alloc_size = sizeof(struct cgx), +}; + +static struct pci_device_id cgx_supported[] = { + {PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_CGX) }, + {} +}; + +U_BOOT_PCI_DEVICE(cgx, cgx_supported); diff --git a/drivers/net/octeontx2/cgx.h b/drivers/net/octeontx2/cgx.h new file mode 100644 index 0000000000..f287692712 --- /dev/null +++ b/drivers/net/octeontx2/cgx.h @@ -0,0 +1,105 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef __CGX_H__ +#define __CGX_H__ + +#include "cgx_intf.h" + +#define PCI_DEVICE_ID_OCTEONTX2_CGX 0xA059 + +#define MAX_LMAC_PER_CGX 4 +#define CGX_PER_NODE 3 + +enum lmac_type { + LMAC_MODE_SGMII = 0, + LMAC_MODE_XAUI = 1, + LMAC_MODE_RXAUI = 2, + LMAC_MODE_10G_R = 3, + LMAC_MODE_40G_R = 4, + LMAC_MODE_QSGMII = 6, + LMAC_MODE_25G_R = 7, + LMAC_MODE_50G_R = 8, + LMAC_MODE_100G_R = 9, + LMAC_MODE_USXGMII = 10, +}; + +extern char lmac_type_to_str[][8]; + +extern char lmac_speed_to_str[][8]; + +struct lmac_priv { + u8 enable:1; + u8 full_duplex:1; + u8 speed:4; + u8 mode:1; + u8 rsvd:1; + u8 mac_addr[6]; +}; + +struct cgx; +struct nix; +struct nix_af; + +struct lmac { + struct cgx *cgx; + struct nix *nix; + char name[16]; + enum lmac_type lmac_type; + bool init_pend; + u8 instance; + u8 lmac_id; + u8 pknd; + u8 link_num; + u32 chan_num; + u8 mac_addr[6]; +}; + +struct cgx { + struct nix_af *nix_af; + void __iomem *reg_base; + struct udevice *dev; + struct lmac *lmac[MAX_LMAC_PER_CGX]; + u8 cgx_id; + u8 lmac_count; +}; + +static inline void cgx_write(struct cgx *cgx, u8 lmac, u64 offset, u64 val) +{ + writeq(val, cgx->reg_base + CMR_SHIFT(lmac) + offset); +} + +static inline u64 cgx_read(struct cgx *cgx, u8 lmac, u64 offset) +{ + return readq(cgx->reg_base + CMR_SHIFT(lmac) + offset); +} + +/** + * Given an LMAC/PF instance number, return the lmac + * Per design, each PF has only one LMAC mapped. + * + * @param instance instance to find + * + * @return pointer to lmac data structure or NULL if not found + */ +struct lmac *nix_get_cgx_lmac(int lmac_instance); + +int cgx_lmac_set_pkind(struct lmac *lmac, u8 lmac_id, int pkind); +int cgx_lmac_internal_loopback(struct lmac *lmac, int lmac_id, bool enable); +int cgx_lmac_rx_tx_enable(struct lmac *lmac, int lmac_id, bool enable); +int cgx_lmac_link_enable(struct lmac *lmac, int lmac_id, bool enable, + u64 *status); +int cgx_lmac_link_status(struct lmac *lmac, int lmac_id, u64 *status); +void cgx_lmac_mac_filter_setup(struct lmac *lmac); + +int cgx_intf_get_link_sts(u8 cgx, u8 lmac, u64 *lnk_sts); +int cgx_intf_link_up_dwn(u8 cgx, u8 lmac, u8 up_dwn, u64 *lnk_sts); +int cgx_intf_get_mac_addr(u8 cgx, u8 lmac, u8 *mac); +int cgx_intf_set_macaddr(struct udevice *dev); +int cgx_intf_prbs(u8 qlm, u8 mode, u32 time, u8 lane); +int cgx_intf_display_eye(u8 qlm, u8 lane); +int cgx_intf_display_serdes(u8 qlm, u8 lane); + +#endif /* __CGX_H__ */ diff --git a/drivers/net/octeontx2/cgx_intf.c b/drivers/net/octeontx2/cgx_intf.c new file mode 100644 index 0000000000..37d9a2bb73 --- /dev/null +++ b/drivers/net/octeontx2/cgx_intf.c @@ -0,0 +1,715 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> + +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/list.h> + +#include <asm/arch/board.h> +#include <asm/io.h> + +#include "cgx_intf.h" +#include "cgx.h" +#include "nix.h" + +static u64 cgx_rd_scrx(u8 cgx, u8 lmac, u8 index) +{ + u64 addr; + + addr = (index == 1) ? CGX_CMR_SCRATCH1 : CGX_CMR_SCRATCH0; + addr += CGX_SHIFT(cgx) + CMR_SHIFT(lmac); + return readq(addr); +} + +static void cgx_wr_scrx(u8 cgx, u8 lmac, u8 index, u64 val) +{ + u64 addr; + + addr = (index == 1) ? CGX_CMR_SCRATCH1 : CGX_CMR_SCRATCH0; + addr += CGX_SHIFT(cgx) + CMR_SHIFT(lmac); + writeq(val, addr); +} + +static u64 cgx_rd_scr0(u8 cgx, u8 lmac) +{ + return cgx_rd_scrx(cgx, lmac, 0); +} + +static u64 cgx_rd_scr1(u8 cgx, u8 lmac) +{ + return cgx_rd_scrx(cgx, lmac, 1); +} + +static void cgx_wr_scr0(u8 cgx, u8 lmac, u64 val) +{ + return cgx_wr_scrx(cgx, lmac, 0, val); +} + +static void cgx_wr_scr1(u8 cgx, u8 lmac, u64 val) +{ + return cgx_wr_scrx(cgx, lmac, 1, val); +} + +static inline void set_ownership(u8 cgx, u8 lmac, u8 val) +{ + union cgx_scratchx1 scr1; + + scr1.u = cgx_rd_scr1(cgx, lmac); + scr1.s.own_status = val; + cgx_wr_scr1(cgx, lmac, scr1.u); +} + +static int wait_for_ownership(u8 cgx, u8 lmac) +{ + union cgx_scratchx1 scr1; + union cgx_scratchx0 scr0; + u64 cmrx_int; + int timeout = 5000; + + do { + scr1.u = cgx_rd_scr1(cgx, lmac); + scr0.u = cgx_rd_scr0(cgx, lmac); + /* clear async events if any */ + if (scr0.s.evt_sts.evt_type == CGX_EVT_ASYNC && + scr0.s.evt_sts.ack) { + /* clear interrupt */ + cmrx_int = readq(CGX_CMR_INT + + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + cmrx_int |= 0x2; // Overflw bit + writeq(cmrx_int, CGX_CMR_INT + + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + + /* clear ack */ + scr0.s.evt_sts.ack = 0; + cgx_wr_scr0(cgx, lmac, scr0.u); + } + + if (timeout-- < 0) { + debug("timeout waiting for ownership\n"); + return -ETIMEDOUT; + } + mdelay(1); + } while ((scr1.s.own_status == CGX_OWN_FIRMWARE) && + scr0.s.evt_sts.ack); + + return 0; +} + +int cgx_intf_req(u8 cgx, u8 lmac, union cgx_cmd_s cmd_args, u64 *rsp, + int use_cmd_id_only) +{ + union cgx_scratchx1 scr1; + union cgx_scratchx0 scr0; + u64 cmrx_int; + int timeout = 500; + int err = 0; + u8 cmd = cmd_args.cmd.id; + + if (wait_for_ownership(cgx, lmac)) { + err = -ETIMEDOUT; + goto error; + } + + /* send command */ + scr1.u = cgx_rd_scr1(cgx, lmac); + + if (use_cmd_id_only) { + scr1.s.cmd.id = cmd; + } else { + cmd_args.own_status = scr1.s.own_status; + scr1.s = cmd_args; + } + cgx_wr_scr1(cgx, lmac, scr1.u); + + set_ownership(cgx, lmac, CGX_OWN_FIRMWARE); + + /* wait for response and ownership */ + do { + scr0.u = cgx_rd_scr0(cgx, lmac); + scr1.u = cgx_rd_scr1(cgx, lmac); + mdelay(10); + } while (timeout-- && (!scr0.s.evt_sts.ack) && + (scr1.s.own_status == CGX_OWN_FIRMWARE)); + if (timeout < 0) { + debug("%s timeout waiting for ack\n", __func__); + err = -ETIMEDOUT; + goto error; + } + + if (cmd == CGX_CMD_INTF_SHUTDOWN) + goto error; + + if (scr0.s.evt_sts.evt_type != CGX_EVT_CMD_RESP) { + debug("%s received async event instead of cmd resp event\n", + __func__); + err = -1; + goto error; + } + if (scr0.s.evt_sts.id != cmd) { + debug("%s received resp for cmd %d expected cmd %d\n", + __func__, scr0.s.evt_sts.id, cmd); + err = -1; + goto error; + } + if (scr0.s.evt_sts.stat != CGX_STAT_SUCCESS) { + debug("%s cmd%d failed on cgx%u lmac%u with errcode %d\n", + __func__, cmd, cgx, lmac, scr0.s.link_sts.err_type); + err = -1; + } + +error: + /* clear interrupt */ + cmrx_int = readq(CGX_CMR_INT + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + cmrx_int |= 0x2; // Overflw bit + writeq(cmrx_int, CGX_CMR_INT + CGX_SHIFT(cgx) + CMR_SHIFT(lmac)); + + /* clear ownership and ack */ + scr0.s.evt_sts.ack = 0; + cgx_wr_scr0(cgx, lmac, scr0.u); + + *rsp = err ? 0 : scr0.u; + + return err; +} + +int cgx_intf_get_mac_addr(u8 cgx, u8 lmac, u8 *mac) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_MAC_ADDR; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + memcpy(mac, &scr0.u, 6); + + return 0; +} + +int cgx_intf_get_ver(u8 cgx, u8 lmac, u8 *ver) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_FW_VER; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + *ver = scr0.u & 0xFFFF; + + return 0; +} + +int cgx_intf_get_link_sts(u8 cgx, u8 lmac, u64 *lnk_sts) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + /* pass the same format as cgx_lnk_sts_s + * err_type:10, speed:4, full_duplex:1, link_up:1 + */ + *lnk_sts = scr0.u & 0xFFFF; + return 0; +} + +int cgx_intf_link_up_dwn(u8 cgx, u8 lmac, u8 up_dwn, u64 *lnk_sts) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = up_dwn ? CGX_CMD_LINK_BRING_UP : CGX_CMD_LINK_BRING_DOWN; + + ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1); + if (ret) + return -1; + + scr0.u >>= 9; + /* pass the same format as cgx_lnk_sts_s + * err_type:10, speed:4, full_duplex:1, link_up:1 + */ + *lnk_sts = scr0.u & 0xFFFF; + return 0; +} + +void cgx_intf_shutdown(void) +{ + union cgx_scratchx0 scr0; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_INTF_SHUTDOWN; + + cgx_intf_req(0, 0, cmd, &scr0.u, 1); +} + +int cgx_intf_prbs(u8 qlm, u8 mode, u32 time, u8 lane) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_PRBS; + + cmd.prbs_args.qlm = qlm; + cmd.prbs_args.mode = mode; + cmd.prbs_args.time = time; + cmd.prbs_args.lane = lane; + + ret = cgx_intf_req(0, 0, cmd, &scr0.u, 0); + if (ret) + return -1; + + return 0; +} + +enum cgx_mode { + MODE_10G_C2C, + MODE_10G_C2M, + MODE_10G_KR, + MODE_25G_C2C, + MODE_25G_2_C2C, + MODE_50G_C2C, + MODE_50G_4_C2C +}; + +static char intf_speed_to_str[][8] = { + "10M", + "100M", + "1G", + "2.5G", + "5G", + "10G", + "20G", + "25G", + "40G", + "50G", + "80G", + "100G", +}; + +static void mode_to_args(int mode, struct cgx_mode_change_args *args) +{ + args->an = 0; + args->duplex = 0; + args->port = 0; + + switch (mode) { + case MODE_10G_C2C: + args->speed = CGX_LINK_10G; + args->mode = BIT_ULL(CGX_MODE_10G_C2C_BIT); + break; + case MODE_10G_C2M: + args->speed = CGX_LINK_10G; + args->mode = BIT_ULL(CGX_MODE_10G_C2M_BIT); + break; + case MODE_10G_KR: + args->speed = CGX_LINK_10G; + args->mode = BIT_ULL(CGX_MODE_10G_KR_BIT); + args->an = 1; + break; + case MODE_25G_C2C: + args->speed = CGX_LINK_25G; + args->mode = BIT_ULL(CGX_MODE_25G_C2C_BIT); + break; + case MODE_25G_2_C2C: + args->speed = CGX_LINK_25G; + args->mode = BIT_ULL(CGX_MODE_25G_2_C2C_BIT); + break; + case MODE_50G_C2C: + args->speed = CGX_LINK_50G; + args->mode = BIT_ULL(CGX_MODE_50G_C2C_BIT); + break; + case MODE_50G_4_C2C: + args->speed = CGX_LINK_50G; + args->mode = BIT_ULL(CGX_MODE_50G_4_C2C_BIT); + } +} + +int cgx_intf_set_mode(struct udevice *ethdev, int mode) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_MODE_CHANGE; + + mode_to_args(mode, &cmd.mode_change_args); + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Mode change command failed for %s\n", ethdev->name); + return -1; + } + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get Link Status failed for %s\n", ethdev->name); + return -1; + } + + printf("Current Link Status: "); + if (scr0.s.link_sts.speed) { + printf("%s\n", intf_speed_to_str[scr0.s.link_sts.speed]); + switch (scr0.s.link_sts.fec) { + case 0: + printf("FEC_NONE\n"); + break; + case 1: + printf("FEC_BASE_R\n"); + break; + case 2: + printf("FEC_RS\n"); + break; + } + printf("Auto Negotiation %sabled\n", + scr0.s.link_sts.an ? "En" : "Dis"); + printf("%s Duplex\n", + scr0.s.link_sts.full_duplex ? "Full" : "Half"); + } else { + printf("Down\n"); + } + return 0; +} + +int cgx_intf_get_mode(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get link status failed for %s\n", ethdev->name); + return -1; + } + printf("Current Interface Mode: "); + switch (scr0.s.link_sts.mode) { + case CGX_MODE_10G_C2C_BIT: + printf("10G_C2C\n"); + break; + case CGX_MODE_10G_C2M_BIT: + printf("10G_C2M\n"); + break; + case CGX_MODE_10G_KR_BIT: + printf("10G_KR\n"); + break; + case CGX_MODE_25G_C2C_BIT: + printf("25G_C2C\n"); + break; + case CGX_MODE_25G_2_C2C_BIT: + printf("25G_2_C2C\n"); + break; + case CGX_MODE_50G_C2C_BIT: + printf("50G_C2C\n"); + break; + case CGX_MODE_50G_4_C2C_BIT: + printf("50G_4_C2C\n"); + break; + default: + printf("Unknown\n"); + break; + } + return 0; +} + +int cgx_intf_get_fec(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_SUPPORTED_FEC; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get supported FEC failed for %s\n", ethdev->name); + return -1; + } + + printf("Supported FEC type: "); + switch (scr0.s.supported_fec.fec) { + case 0: + printf("FEC_NONE\n"); + break; + case 1: + printf("FEC_BASE_R\n"); + break; + case 2: + printf("FEC_RS\n"); + break; + case 3: + printf("FEC_BASE_R FEC_RS\n"); + break; + } + + cmd.cmd.id = CGX_CMD_GET_LINK_STS; + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get active fec failed for %s\n", ethdev->name); + return -1; + } + printf("Active FEC type: "); + switch (scr0.s.link_sts.fec) { + case 0: + printf("FEC_NONE\n"); + break; + case 1: + printf("FEC_BASE_R\n"); + break; + case 2: + printf("FEC_RS\n"); + break; + } + return 0; +} + +int cgx_intf_set_fec(struct udevice *ethdev, int type) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_SET_FEC; + cmd.fec_args.fec = type; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set FEC type %d failed for %s\n", type, ethdev->name); + return -1; + } + return 0; +} + +int cgx_intf_get_phy_mod_type(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_GET_PHY_MOD_TYPE; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 1); + if (ret) { + printf("Get PHYMOD type failed for %s\n", ethdev->name); + return -1; + } + printf("Current phy mod type %s\n", + scr0.s.phy_mod_type.mod ? "PAM4" : "NRZ"); + return 0; +} + +int cgx_intf_set_phy_mod_type(struct udevice *ethdev, int type) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_SET_PHY_MOD_TYPE; + cmd.phy_mod_args.mod = type; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set PHYMOD type %d failed for %s\n", type, + ethdev->name); + return -1; + } + + return 0; +} + +int cgx_intf_set_an_lbk(struct udevice *ethdev, int enable) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_AN_LOOPBACK; + cmd.cmd_args.enable = enable; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set AN loopback command failed on %s\n", ethdev->name); + return -1; + } + printf("AN loopback %s for %s\n", enable ? "set" : "clear", + ethdev->name); + + return 0; +} + +int cgx_intf_get_ignore(struct udevice *ethdev, int cgx, int lmac) +{ + struct rvu_pf *rvu; + struct nix *nix; + union cgx_scratchx0 scr0; + int ret, cgx_id = cgx, lmac_id = lmac; + union cgx_cmd_s cmd; + + if (ethdev) { + rvu = dev_get_priv(ethdev); + nix = rvu->nix; + cgx_id = nix->lmac->cgx->cgx_id; + lmac_id = nix->lmac->lmac_id; + } + cmd.cmd.id = CGX_CMD_GET_PERSIST_IGNORE; + + ret = cgx_intf_req(cgx_id, lmac_id, cmd, &scr0.u, 1); + if (ret) { + if (ethdev) + printf("Get ignore command failed for %s\n", + ethdev->name); + else + printf("Get ignore command failed for CGX%d LMAC%d\n", + cgx_id, lmac_id); + return -1; + } + if (ethdev) + printf("Persist settings %signored for %s\n", + scr0.s.persist.ignore ? "" : "not ", ethdev->name); + else + printf("Persist settings %signored for CGX%d LMAC%d\n", + scr0.s.persist.ignore ? "" : "not ", cgx_id, lmac_id); + + return 0; +} + +int cgx_intf_set_ignore(struct udevice *ethdev, int cgx, int lmac, int ignore) +{ + struct rvu_pf *rvu; + struct nix *nix; + union cgx_scratchx0 scr0; + int ret, cgx_id = cgx, lmac_id = lmac; + union cgx_cmd_s cmd; + + if (ethdev) { + rvu = dev_get_priv(ethdev); + nix = rvu->nix; + cgx_id = nix->lmac->cgx->cgx_id; + lmac_id = nix->lmac->lmac_id; + } + cmd.cmd.id = CGX_CMD_SET_PERSIST_IGNORE; + cmd.persist_args.ignore = ignore; + + ret = cgx_intf_req(cgx_id, lmac_id, cmd, &scr0.u, 0); + if (ret) { + if (ethdev) + printf("Set ignore command failed for %s\n", + ethdev->name); + else + printf("Set ignore command failed for CGX%d LMAC%d\n", + cgx_id, lmac_id); + return -1; + } + + return 0; +} + +int cgx_intf_set_macaddr(struct udevice *ethdev) +{ + struct rvu_pf *rvu = dev_get_priv(ethdev); + struct nix *nix = rvu->nix; + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + u64 mac, tmp; + + memcpy((void *)&tmp, nix->lmac->mac_addr, 6); + mac = swab64(tmp) >> 16; + cmd.cmd.id = CGX_CMD_SET_MAC_ADDR; + cmd.mac_args.addr = mac; + cmd.mac_args.pf_id = rvu->pfid; + + ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id, + cmd, &scr0.u, 0); + if (ret) { + printf("Set user mac addr failed for %s\n", ethdev->name); + return -1; + } + + return 0; +} + +int cgx_intf_display_eye(u8 qlm, u8 lane) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_DISPLAY_EYE; + + cmd.dsp_eye_args.qlm = qlm; + cmd.dsp_eye_args.lane = lane; + + ret = cgx_intf_req(0, 0, cmd, &scr0.u, 0); + if (ret) + return -1; + + return 0; +} + +int cgx_intf_display_serdes(u8 qlm, u8 lane) +{ + union cgx_scratchx0 scr0; + int ret; + union cgx_cmd_s cmd; + + cmd.cmd.id = CGX_CMD_DISPLAY_SERDES; + + cmd.dsp_eye_args.qlm = qlm; + cmd.dsp_eye_args.lane = lane; + + ret = cgx_intf_req(0, 0, cmd, &scr0.u, 0); + if (ret) + return -1; + + return 0; +} diff --git a/drivers/net/octeontx2/cgx_intf.h b/drivers/net/octeontx2/cgx_intf.h new file mode 100644 index 0000000000..62a7203ad8 --- /dev/null +++ b/drivers/net/octeontx2/cgx_intf.h @@ -0,0 +1,448 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef __CGX_INTF_H__ +#define __CGX_INTF_H__ + +#define CGX_FIRMWARE_MAJOR_VER 1 +#define CGX_FIRMWARE_MINOR_VER 0 + +/* Register offsets */ +#define CGX_CMR_INT 0x87e0e0000040 +#define CGX_CMR_SCRATCH0 0x87e0e0001050 +#define CGX_CMR_SCRATCH1 0x87e0e0001058 + +#define CGX_SHIFT(x) (0x1000000 * ((x) & 0x3)) +#define CMR_SHIFT(x) (0x40000 * ((x) & 0x3)) + +/* CGX error types. set for cmd response status as CGX_STAT_FAIL */ +enum cgx_error_type { + CGX_ERR_NONE, + CGX_ERR_LMAC_NOT_ENABLED, + CGX_ERR_LMAC_MODE_INVALID, + CGX_ERR_REQUEST_ID_INVALID, + CGX_ERR_PREV_ACK_NOT_CLEAR, + CGX_ERR_PHY_LINK_DOWN, + CGX_ERR_PCS_RESET_FAIL, + CGX_ERR_AN_CPT_FAIL, + CGX_ERR_TX_NOT_IDLE, + CGX_ERR_RX_NOT_IDLE, + CGX_ERR_SPUX_BR_BLKLOCK_FAIL, + CGX_ERR_SPUX_RX_ALIGN_FAIL, + CGX_ERR_SPUX_TX_FAULT, + CGX_ERR_SPUX_RX_FAULT, + CGX_ERR_SPUX_RESET_FAIL, + CGX_ERR_SPUX_AN_RESET_FAIL, + CGX_ERR_SPUX_USX_AN_RESET_FAIL, + CGX_ERR_SMUX_RX_LINK_NOT_OK, + CGX_ERR_PCS_LINK_FAIL, + CGX_ERR_TRAINING_FAIL, + CGX_ERR_RX_EQU_FAIL, + CGX_ERR_SPUX_BER_FAIL, + CGX_ERR_SPUX_RSFEC_ALGN_FAIL, + CGX_ERR_SPUX_MARKER_LOCK_FAIL, + CGX_ERR_SET_FEC_INVALID, + CGX_ERR_SET_FEC_FAIL, + CGX_ERR_MODULE_INVALID, + CGX_ERR_MODULE_NOT_PRESENT, + CGX_ERR_SPEED_CHANGE_INVALID, /* = 28 */ + /* FIXME : add more error types when adding support for new modes */ +}; + +/* LINK speed types */ +enum cgx_link_speed { + CGX_LINK_NONE, + CGX_LINK_10M, + CGX_LINK_100M, + CGX_LINK_1G, + CGX_LINK_2HG, /* 2.5 Gbps */ + CGX_LINK_5G, + CGX_LINK_10G, + CGX_LINK_20G, + CGX_LINK_25G, + CGX_LINK_40G, + CGX_LINK_50G, + CGX_LINK_80G, + CGX_LINK_100G, + CGX_LINK_MAX, +}; + +/* REQUEST ID types. Input to firmware */ +enum cgx_cmd_id { + CGX_CMD_NONE = 0, + CGX_CMD_GET_FW_VER, + CGX_CMD_GET_MAC_ADDR, + CGX_CMD_SET_MTU, + CGX_CMD_GET_LINK_STS, /* optional to user */ + CGX_CMD_LINK_BRING_UP, /* = 5 */ + CGX_CMD_LINK_BRING_DOWN, + CGX_CMD_INTERNAL_LBK, + CGX_CMD_EXTERNAL_LBK, + CGX_CMD_HIGIG, + CGX_CMD_LINK_STAT_CHANGE, /* = 10 */ + CGX_CMD_MODE_CHANGE, /* hot plug support */ + CGX_CMD_INTF_SHUTDOWN, + CGX_CMD_GET_MKEX_SIZE, + CGX_CMD_GET_MKEX_PROFILE, + CGX_CMD_GET_FWD_BASE, /* get base address of shared FW data */ + CGX_CMD_GET_LINK_MODES, /* Supported Link Modes */ + CGX_CMD_SET_LINK_MODE, + CGX_CMD_GET_SUPPORTED_FEC, + CGX_CMD_SET_FEC, + CGX_CMD_GET_AN, /* = 20 */ + CGX_CMD_SET_AN, + CGX_CMD_GET_ADV_LINK_MODES, + CGX_CMD_GET_ADV_FEC, + CGX_CMD_GET_PHY_MOD_TYPE, /* line-side modulation type: NRZ or PAM4 */ + CGX_CMD_SET_PHY_MOD_TYPE, /* = 25 */ + CGX_CMD_PRBS, + CGX_CMD_DISPLAY_EYE, + CGX_CMD_GET_PHY_FEC_STATS, + CGX_CMD_DISPLAY_SERDES, + CGX_CMD_AN_LOOPBACK, /* = 30 */ + CGX_CMD_GET_PERSIST_IGNORE, + CGX_CMD_SET_PERSIST_IGNORE, + CGX_CMD_SET_MAC_ADDR, +}; + +/* async event ids */ +enum cgx_evt_id { + CGX_EVT_NONE, + CGX_EVT_LINK_CHANGE, +}; + +/* event types - cause of interrupt */ +enum cgx_evt_type { + CGX_EVT_ASYNC, + CGX_EVT_CMD_RESP +}; + +enum cgx_stat { + CGX_STAT_SUCCESS, + CGX_STAT_FAIL +}; + +enum cgx_cmd_own { + /* default ownership with kernel/uefi/u-boot */ + CGX_OWN_NON_SECURE_SW, + /* set by kernel/uefi/u-boot after posting a new request to ATF */ + CGX_OWN_FIRMWARE, +}; + +/* Supported LINK MODE enums + * Each link mode is a bit mask of these + * enums which are represented as bits + */ +enum cgx_mode_t { + CGX_MODE_SGMII_BIT = 0, + CGX_MODE_1000_BASEX_BIT, + CGX_MODE_QSGMII_BIT, + CGX_MODE_10G_C2C_BIT, + CGX_MODE_10G_C2M_BIT, + CGX_MODE_10G_KR_BIT, + CGX_MODE_20G_C2C_BIT, + CGX_MODE_25G_C2C_BIT, + CGX_MODE_25G_C2M_BIT, + CGX_MODE_25G_2_C2C_BIT, + CGX_MODE_25G_CR_BIT, + CGX_MODE_25G_KR_BIT, + CGX_MODE_40G_C2C_BIT, + CGX_MODE_40G_C2M_BIT, + CGX_MODE_40G_CR4_BIT, + CGX_MODE_40G_KR4_BIT, + CGX_MODE_40GAUI_C2C_BIT, + CGX_MODE_50G_C2C_BIT, + CGX_MODE_50G_C2M_BIT, + CGX_MODE_50G_4_C2C_BIT, + CGX_MODE_50G_CR_BIT, + CGX_MODE_50G_KR_BIT, + CGX_MODE_80GAUI_C2C_BIT, + CGX_MODE_100G_C2C_BIT, + CGX_MODE_100G_C2M_BIT, + CGX_MODE_100G_CR4_BIT, + CGX_MODE_100G_KR4_BIT, + CGX_MODE_MAX_BIT /* = 29 */ +}; + +/* scratchx(0) CSR used for ATF->non-secure SW communication. + * This acts as the status register + * Provides details on command ack/status, link status, error details + */ + +/* CAUTION : below structures are placed in order based on the bit positions + * For any updates/new bitfields, corresponding structures needs to be updated + */ +struct cgx_evt_sts_s { /* start from bit 0 */ + u64 ack:1; + u64 evt_type:1; /* cgx_evt_type */ + u64 stat:1; /* cgx_stat */ + u64 id:6; /* cgx_evt_id/cgx_cmd_id */ + u64 reserved:55; +}; + +/* all the below structures are in the same memory location of SCRATCHX(0) + * value can be read/written based on command ID + */ + +/* Resp to command IDs with command status as CGX_STAT_FAIL + * Not applicable for commands : + * CGX_CMD_LINK_BRING_UP/DOWN/CGX_EVT_LINK_CHANGE + * check struct cgx_lnk_sts_s comments + */ +struct cgx_err_sts_s { /* start from bit 9 */ + u64 reserved1:9; + u64 type:10; /* cgx_error_type */ + u64 reserved2:35; +}; + +/* Resp to cmd ID as CGX_CMD_GET_FW_VER with cmd status as CGX_STAT_SUCCESS */ +struct cgx_ver_s { /* start from bit 9 */ + u64 reserved1:9; + u64 major_ver:4; + u64 minor_ver:4; + u64 reserved2:47; +}; + +/* Resp to cmd ID as CGX_CMD_GET_MAC_ADDR with cmd status as CGX_STAT_SUCCESS + * Returns each byte of MAC address in a separate bit field + */ +struct cgx_mac_addr_s { /* start from bit 9 */ + u64 reserved1:9; + u64 addr_0:8; + u64 addr_1:8; + u64 addr_2:8; + u64 addr_3:8; + u64 addr_4:8; + u64 addr_5:8; + u64 reserved2:7; +}; + +/* Resp to cmd ID - CGX_CMD_LINK_BRING_UP/DOWN, event ID CGX_EVT_LINK_CHANGE + * status can be either CGX_STAT_FAIL or CGX_STAT_SUCCESS + * In case of CGX_STAT_FAIL, it indicates CGX configuration failed when + * processing link up/down/change command. Both err_type and current link status + * will be updated + * In case of CGX_STAT_SUCCESS, err_type will be CGX_ERR_NONE and current + * link status will be updated + */ +struct cgx_lnk_sts_s { + u64 reserved1:9; + u64 link_up:1; + u64 full_duplex:1; + u64 speed:4; /* cgx_link_speed */ + u64 err_type:10; + u64 an:1; /* Current AN state : enabled/disabled */ + u64 fec:2; /* Current FEC type if enabled, if not 0 */ + u64 port:8; /* Share the current port info if required */ + u64 mode:8; /* cgx_mode_t enum integer value */ + u64 reserved2:20; +}; + +struct sh_fwd_base_s { + u64 reserved1:9; + u64 addr:55; +}; + +struct cgx_link_modes_s { + u64 reserved1:9; + u64 modes:55; +}; + +/* Resp to cmd ID - CGX_CMD_GET_ADV_FEC/CGX_CMD_GET_SUPPORTED_FEC + * fec : 2 bits + * typedef enum cgx_fec_type { + * CGX_FEC_NONE, + * CGX_FEC_BASE_R, + * CGX_FEC_RS + * } fec_type_t; + */ +struct cgx_fec_types_s { + u64 reserved1:9; + u64 fec:2; + u64 reserved2:53; +}; + +/* Resp to cmd ID - CGX_CMD_GET_AN */ +struct cgx_get_an_s { + u64 reserved1:9; + u64 an:1; + u64 reserved2:54; +}; + +/* Resp to cmd ID - CGX_CMD_GET_PHY_MOD_TYPE */ +struct cgx_get_phy_mod_type_s { + u64 reserved1:9; + u64 mod:1; /* 0=NRZ, 1=PAM4 */ + u64 reserved2:54; +}; + +/* Resp to cmd ID - CGX_CMD_GET_PERSIST_IGNORE */ +struct cgx_get_flash_ignore_s { + uint64_t reserved1:9; + uint64_t ignore:1; + uint64_t reserved2:54; +}; + +union cgx_rsp_sts { + /* Fixed, applicable for all commands/events */ + struct cgx_evt_sts_s evt_sts; + /* response to CGX_CMD_LINK_BRINGUP/DOWN/LINK_CHANGE */ + struct cgx_lnk_sts_s link_sts; + /* response to CGX_CMD_GET_FW_VER */ + struct cgx_ver_s ver; + /* response to CGX_CMD_GET_MAC_ADDR */ + struct cgx_mac_addr_s mac_s; + /* response to CGX_CMD_GET_FWD_BASE */ + struct sh_fwd_base_s fwd_base_s; + /* response if evt_status = CMD_FAIL */ + struct cgx_err_sts_s err; + /* response to CGX_CMD_GET_SUPPORTED_FEC */ + struct cgx_fec_types_s supported_fec; + /* response to CGX_CMD_GET_LINK_MODES */ + struct cgx_link_modes_s supported_modes; + /* response to CGX_CMD_GET_ADV_LINK_MODES */ + struct cgx_link_modes_s adv_modes; + /* response to CGX_CMD_GET_ADV_FEC */ + struct cgx_fec_types_s adv_fec; + /* response to CGX_CMD_GET_AN */ + struct cgx_get_an_s an; + /* response to CGX_CMD_GET_PHY_MOD_TYPE */ + struct cgx_get_phy_mod_type_s phy_mod_type; + /* response to CGX_CMD_GET_PERSIST_IGNORE */ + struct cgx_get_flash_ignore_s persist; +#ifdef NT_FW_CONFIG + /* response to CGX_CMD_GET_MKEX_SIZE */ + struct cgx_mcam_profile_sz_s prfl_sz; + /* response to CGX_CMD_GET_MKEX_PROFILE */ + struct cgx_mcam_profile_addr_s prfl_addr; +#endif +}; + +union cgx_scratchx0 { + u64 u; + union cgx_rsp_sts s; +}; + +/* scratchx(1) CSR used for non-secure SW->ATF communication + * This CSR acts as a command register + */ +struct cgx_cmd { /* start from bit 2 */ + u64 reserved1:2; + u64 id:6; /* cgx_request_id */ + u64 reserved2:56; +}; + +/* all the below structures are in the same memory location of SCRATCHX(1) + * corresponding arguments for command Id needs to be updated + */ + +/* Any command using enable/disable as an argument need + * to pass the option via this structure. + * Ex: Loopback, HiGig... + */ +struct cgx_ctl_args { /* start from bit 8 */ + u64 reserved1:8; + u64 enable:1; + u64 reserved2:55; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_MTU */ +struct cgx_mtu_args { + u64 reserved1:8; + u64 size:16; + u64 reserved2:40; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_MODE_CHANGE */ +struct cgx_mode_change_args { + uint64_t reserved1:8; + uint64_t speed:4; /* cgx_link_speed enum */ + uint64_t duplex:1; /* 0 - full duplex, 1 - half duplex */ + uint64_t an:1; /* 0 - disable AN, 1 - enable AN */ + uint64_t port:8; /* device port */ + uint64_t mode:42; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_LINK_CHANGE */ +struct cgx_link_change_args { /* start from bit 8 */ + u64 reserved1:8; + u64 link_up:1; + u64 full_duplex:1; + u64 speed:4; /* cgx_link_speed */ + u64 reserved2:50; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_LINK_MODE */ +struct cgx_set_mode_args { + u64 reserved1:8; + u64 mode:56; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_FEC */ +struct cgx_set_fec_args { + u64 reserved1:8; + u64 fec:2; + u64 reserved2:54; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_PHY_MOD_TYPE */ +struct cgx_set_phy_mod_args { + u64 reserved1:8; + u64 mod:1; /* 0=NRZ, 1=PAM4 */ + u64 reserved2:55; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_PERSIST_IGNORE */ +struct cgx_set_flash_ignore_args { + uint64_t reserved1:8; + uint64_t ignore:1; + uint64_t reserved2:55; +}; + +/* command argument to be passed for cmd ID - CGX_CMD_SET_MAC_ADDR */ +struct cgx_mac_addr_args { + uint64_t reserved1:8; + uint64_t addr:48; + uint64_t pf_id:8; +}; + +struct cgx_prbs_args { + u64 reserved1:8; /* start from bit 8 */ + u64 lane:8; + u64 qlm:8; + u64 stop_on_error:1; + u64 mode:8; + u64 time:31; +}; + +struct cgx_display_eye_args { + u64 reserved1:8; /* start from bit 8 */ + u64 qlm:8; + u64 lane:47; +}; + +union cgx_cmd_s { + u64 own_status:2; /* cgx_cmd_own */ + struct cgx_cmd cmd; + struct cgx_ctl_args cmd_args; + struct cgx_mtu_args mtu_size; + struct cgx_link_change_args lnk_args; /* Input to CGX_CMD_LINK_CHANGE */ + struct cgx_set_mode_args mode_args; + struct cgx_mode_change_args mode_change_args; + struct cgx_set_fec_args fec_args; + struct cgx_set_phy_mod_args phy_mod_args; + struct cgx_set_flash_ignore_args persist_args; + struct cgx_mac_addr_args mac_args; + /* any other arg for command id * like : mtu, dmac filtering control */ + struct cgx_prbs_args prbs_args; + struct cgx_display_eye_args dsp_eye_args; +}; + +union cgx_scratchx1 { + u64 u; + union cgx_cmd_s s; +}; + +#endif /* __CGX_INTF_H__ */ diff --git a/drivers/net/octeontx2/lmt.h b/drivers/net/octeontx2/lmt.h new file mode 100644 index 0000000000..84a7eab814 --- /dev/null +++ b/drivers/net/octeontx2/lmt.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + */ + +/** + * Atomically adds a signed value to a 64 bit (aligned) memory location, + * and returns previous value. + * + * This version does not perform 'sync' operations to enforce memory + * operations. This should only be used when there are no memory operation + * ordering constraints. (This should NOT be used for reference counting - + * use the standard version instead.) + * + * @param ptr address in memory to add incr to + * @param incr amount to increment memory location by (signed) + * + * @return Value of memory location before increment + */ +static inline s64 atomic_fetch_and_add64_nosync(s64 *ptr, s64 incr) +{ + s64 result; + /* Atomic add with no ordering */ + asm volatile("ldadd %x[i], %x[r], [%[b]]" + : [r] "=r" (result), "+m" (*ptr) + : [i] "r" (incr), [b] "r" (ptr) + : "memory"); + return result; +} + +static inline void lmt_cancel(const struct nix *nix) +{ + writeq(0, nix->lmt_base + LMT_LF_LMTCANCEL()); +} + +static inline u64 *lmt_store_ptr(struct nix *nix) +{ + return (u64 *)((u8 *)(nix->lmt_base) + + LMT_LF_LMTLINEX(0)); +} + +static inline s64 lmt_submit(u64 io_address) +{ + s64 result = 0; + + asm volatile("ldeor xzr, %x[rf],[%[rs]]" + : [rf] "=r"(result) : [rs] "r"(io_address)); + return result; +} diff --git a/drivers/net/octeontx2/nix.c b/drivers/net/octeontx2/nix.c new file mode 100644 index 0000000000..0a3e8e4af0 --- /dev/null +++ b/drivers/net/octeontx2/nix.c @@ -0,0 +1,831 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <dm.h> +#include <errno.h> +#include <log.h> +#include <malloc.h> +#include <memalign.h> +#include <misc.h> +#include <net.h> +#include <pci.h> +#include <watchdog.h> + +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-lmt.h> +#include <asm/io.h> +#include <asm/types.h> + +#include <linux/delay.h> +#include <linux/log2.h> +#include <linux/types.h> + +#include "nix.h" +#include "lmt.h" +#include "cgx.h" + +/** + * NIX needs a lot of memory areas. Rather than handle all the failure cases, + * we'll use a wrapper around alloc that prints an error if a memory + * allocation fails. + * + * @param num_elements + * Number of elements to allocate + * @param elem_size Size of each element + * @param msg Text string to show when allocation fails + * + * @return A valid memory location or NULL on failure + */ +static void *nix_memalloc(int num_elements, size_t elem_size, const char *msg) +{ + size_t alloc_size = num_elements * elem_size; + void *base = memalign(CONFIG_SYS_CACHELINE_SIZE, alloc_size); + + if (!base) + printf("NIX: Mem alloc failed for %s (%d * %zu = %zu bytes)\n", + msg ? msg : __func__, num_elements, elem_size, + alloc_size); + else + memset(base, 0, alloc_size); + + debug("NIX: Memory alloc for %s (%d * %zu = %zu bytes) at %p\n", + msg ? msg : __func__, num_elements, elem_size, alloc_size, base); + return base; +} + +int npc_lf_setup(struct nix *nix) +{ + int err; + + err = npc_lf_admin_setup(nix); + if (err) { + printf("%s: Error setting up npc lf admin\n", __func__); + return err; + } + + return 0; +} + +static int npa_setup_pool(struct npa *npa, u32 pool_id, + size_t buffer_size, u32 queue_length, void *buffers[]) +{ + struct { + union npa_lf_aura_op_free0 f0; + union npa_lf_aura_op_free1 f1; + } aura_descr; + int index; + + for (index = 0; index < queue_length; index++) { + buffers[index] = memalign(CONFIG_SYS_CACHELINE_SIZE, + buffer_size); + if (!buffers[index]) { + printf("%s: Out of memory %d, size: %zu\n", + __func__, index, buffer_size); + return -ENOMEM; + } + debug("%s: allocating buffer %d, addr %p size: %zu\n", + __func__, index, buffers[index], buffer_size); + + /* Add the newly obtained pointer to the pool. 128 bit + * writes only. + */ + aura_descr.f0.s.addr = (u64)buffers[index]; + aura_descr.f1.u = 0; + aura_descr.f1.s.aura = pool_id; + st128(npa->npa_base + NPA_LF_AURA_OP_FREE0(), + aura_descr.f0.u, aura_descr.f1.u); + } + + return 0; +} + +int npa_lf_setup(struct nix *nix) +{ + struct rvu_pf *rvu = dev_get_priv(nix->dev); + struct nix_af *nix_af = nix->nix_af; + struct npa *npa; + union npa_af_const npa_af_const; + union npa_aura_s *aura; + union npa_pool_s *pool; + union rvu_func_addr_s block_addr; + int idx; + int stack_page_pointers; + int stack_page_bytes; + int err; + + npa = (struct npa *)calloc(1, sizeof(struct npa)); + if (!npa) { + printf("%s: out of memory for npa instance\n", __func__); + return -ENOMEM; + } + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPA; + npa->npa_base = rvu->pf_base + block_addr.u; + npa->npa_af = nix_af->npa_af; + nix->npa = npa; + + npa_af_const.u = npa_af_reg_read(npa->npa_af, NPA_AF_CONST()); + stack_page_pointers = npa_af_const.s.stack_page_ptrs; + stack_page_bytes = npa_af_const.s.stack_page_bytes; + + npa->stack_pages[NPA_POOL_RX] = (RQ_QLEN + stack_page_pointers - 1) / + stack_page_pointers; + npa->stack_pages[NPA_POOL_TX] = (SQ_QLEN + stack_page_pointers - 1) / + stack_page_pointers; + npa->stack_pages[NPA_POOL_SQB] = (SQB_QLEN + stack_page_pointers - 1) / + stack_page_pointers; + npa->pool_stack_pointers = stack_page_pointers; + + npa->q_len[NPA_POOL_RX] = RQ_QLEN; + npa->q_len[NPA_POOL_TX] = SQ_QLEN; + npa->q_len[NPA_POOL_SQB] = SQB_QLEN; + + npa->buf_size[NPA_POOL_RX] = MAX_MTU + CONFIG_SYS_CACHELINE_SIZE; + npa->buf_size[NPA_POOL_TX] = MAX_MTU + CONFIG_SYS_CACHELINE_SIZE; + npa->buf_size[NPA_POOL_SQB] = nix_af->sqb_size; + + npa->aura_ctx = nix_memalloc(NPA_POOL_COUNT, + sizeof(union npa_aura_s), + "aura context"); + if (!npa->aura_ctx) { + printf("%s: Out of memory for aura context\n", __func__); + return -ENOMEM; + } + + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + npa->pool_ctx[idx] = nix_memalloc(1, + sizeof(union npa_pool_s), + "pool context"); + if (!npa->pool_ctx[idx]) { + printf("%s: Out of memory for pool context\n", + __func__); + return -ENOMEM; + } + npa->pool_stack[idx] = nix_memalloc(npa->stack_pages[idx], + stack_page_bytes, + "pool stack"); + if (!npa->pool_stack[idx]) { + printf("%s: Out of memory for pool stack\n", __func__); + return -ENOMEM; + } + } + + err = npa_lf_admin_setup(npa, nix->lf, (dma_addr_t)npa->aura_ctx); + if (err) { + printf("%s: Error setting up NPA LF admin for lf %d\n", + __func__, nix->lf); + return err; + } + + /* Set up the auras */ + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + aura = npa->aura_ctx + (idx * sizeof(union npa_aura_s)); + pool = npa->pool_ctx[idx]; + debug("%s aura %p pool %p\n", __func__, aura, pool); + memset(aura, 0, sizeof(union npa_aura_s)); + aura->s.fc_ena = 0; + aura->s.pool_addr = (u64)npa->pool_ctx[idx]; + debug("%s aura.s.pool_addr %llx pool_addr %p\n", __func__, + aura->s.pool_addr, npa->pool_ctx[idx]); + aura->s.shift = 64 - __builtin_clzll(npa->q_len[idx]) - 8; + aura->s.count = npa->q_len[idx]; + aura->s.limit = npa->q_len[idx]; + aura->s.ena = 1; + err = npa_attach_aura(nix_af, nix->lf, aura, idx); + if (err) + return err; + + memset(pool, 0, sizeof(*pool)); + pool->s.fc_ena = 0; + pool->s.nat_align = 1; + pool->s.stack_base = (u64)(npa->pool_stack[idx]); + debug("%s pool.s.stack_base %llx stack_base %p\n", __func__, + pool->s.stack_base, npa->pool_stack[idx]); + pool->s.buf_size = + npa->buf_size[idx] / CONFIG_SYS_CACHELINE_SIZE; + pool->s.stack_max_pages = npa->stack_pages[idx]; + pool->s.shift = + 64 - __builtin_clzll(npa->pool_stack_pointers) - 8; + pool->s.ptr_start = 0; + pool->s.ptr_end = (1ULL << 40) - 1; + pool->s.ena = 1; + err = npa_attach_pool(nix_af, nix->lf, pool, idx); + if (err) + return err; + } + + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + npa->buffers[idx] = nix_memalloc(npa->q_len[idx], + sizeof(void *), + "buffers"); + if (!npa->buffers[idx]) { + printf("%s: Out of memory\n", __func__); + return -ENOMEM; + } + } + + for (idx = 0; idx < NPA_POOL_COUNT; idx++) { + err = npa_setup_pool(npa, idx, npa->buf_size[idx], + npa->q_len[idx], npa->buffers[idx]); + if (err) { + printf("%s: Error setting up pool %d\n", + __func__, idx); + return err; + } + } + return 0; +} + +int npa_lf_shutdown(struct nix *nix) +{ + struct npa *npa = nix->npa; + int err; + int pool; + + err = npa_lf_admin_shutdown(nix->nix_af, nix->lf, NPA_POOL_COUNT); + if (err) { + printf("%s: Error %d shutting down NPA LF admin\n", + __func__, err); + return err; + } + free(npa->aura_ctx); + npa->aura_ctx = NULL; + + for (pool = 0; pool < NPA_POOL_COUNT; pool++) { + free(npa->pool_ctx[pool]); + npa->pool_ctx[pool] = NULL; + free(npa->pool_stack[pool]); + npa->pool_stack[pool] = NULL; + free(npa->buffers[pool]); + npa->buffers[pool] = NULL; + } + + return 0; +} + +int nix_lf_setup(struct nix *nix) +{ + struct nix_af *nix_af = nix->nix_af; + int idx; + int err = -1; + + /* Alloc NIX RQ HW context memory */ + nix->rq_ctx_base = nix_memalloc(nix->rq_cnt, nix_af->rq_ctx_sz, + "RQ CTX"); + if (!nix->rq_ctx_base) + goto error; + memset(nix->rq_ctx_base, 0, nix_af->rq_ctx_sz); + + /* Alloc NIX SQ HW context memory */ + nix->sq_ctx_base = nix_memalloc(nix->sq_cnt, nix_af->sq_ctx_sz, + "SQ CTX"); + if (!nix->sq_ctx_base) + goto error; + memset(nix->sq_ctx_base, 0, nix_af->sq_ctx_sz); + + /* Alloc NIX CQ HW context memory */ + nix->cq_ctx_base = nix_memalloc(nix->cq_cnt, nix_af->cq_ctx_sz, + "CQ CTX"); + if (!nix->cq_ctx_base) + goto error; + memset(nix->cq_ctx_base, 0, nix_af->cq_ctx_sz * NIX_CQ_COUNT); + /* Alloc NIX CQ Ring memory */ + for (idx = 0; idx < NIX_CQ_COUNT; idx++) { + err = qmem_alloc(&nix->cq[idx], CQ_ENTRIES, CQ_ENTRY_SIZE); + if (err) + goto error; + } + + /* Alloc memory for Qints HW contexts */ + nix->qint_base = nix_memalloc(nix_af->qints, nix_af->qint_ctx_sz, + "Qint CTX"); + if (!nix->qint_base) + goto error; + /* Alloc memory for CQints HW contexts */ + nix->cint_base = nix_memalloc(nix_af->cints, nix_af->cint_ctx_sz, + "Cint CTX"); + if (!nix->cint_base) + goto error; + /* Alloc NIX RSS HW context memory and config the base */ + nix->rss_base = nix_memalloc(nix->rss_grps, nix_af->rsse_ctx_sz, + "RSS CTX"); + if (!nix->rss_base) + goto error; + + err = nix_lf_admin_setup(nix); + if (err) { + printf("%s: Error setting up LF\n", __func__); + goto error; + } + + return 0; + +error: + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->sq_ctx_base) + free(nix->sq_ctx_base); + nix->sq_ctx_base = NULL; + if (nix->cq_ctx_base) + free(nix->cq_ctx_base); + nix->cq_ctx_base = NULL; + + for (idx = 0; idx < NIX_CQ_COUNT; idx++) + qmem_free(&nix->cq[idx]); + + return err; +} + +int nix_lf_shutdown(struct nix *nix) +{ + struct nix_af *nix_af = nix->nix_af; + int index; + int err; + + err = nix_lf_admin_shutdown(nix_af, nix->lf, nix->cq_cnt, + nix->rq_cnt, nix->sq_cnt); + if (err) { + printf("%s: Error shutting down LF admin\n", __func__); + return err; + } + + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->rq_ctx_base) + free(nix->rq_ctx_base); + nix->rq_ctx_base = NULL; + if (nix->sq_ctx_base) + free(nix->sq_ctx_base); + nix->sq_ctx_base = NULL; + if (nix->cq_ctx_base) + free(nix->cq_ctx_base); + nix->cq_ctx_base = NULL; + + for (index = 0; index < NIX_CQ_COUNT; index++) + qmem_free(&nix->cq[index]); + + debug("%s: nix lf %d reset --\n", __func__, nix->lf); + return 0; +} + +struct nix *nix_lf_alloc(struct udevice *dev) +{ + union rvu_func_addr_s block_addr; + struct nix *nix; + struct rvu_pf *rvu = dev_get_priv(dev); + struct rvu_af *rvu_af = dev_get_priv(rvu->afdev); + union rvu_pf_func_s pf_func; + int err; + + debug("%s(%s )\n", __func__, dev->name); + + nix = (struct nix *)calloc(1, sizeof(*nix)); + if (!nix) { + printf("%s: Out of memory for nix instance\n", __func__); + return NULL; + } + nix->nix_af = rvu_af->nix_af; + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NIXX(0); + nix->nix_base = rvu->pf_base + block_addr.u; + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPC; + nix->npc_base = rvu->pf_base + block_addr.u; + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_LMT; + nix->lmt_base = rvu->pf_base + block_addr.u; + + pf_func.u = 0; + pf_func.s.pf = rvu->pfid; + nix->pf_func = pf_func.u; + nix->lf = rvu->nix_lfid; + nix->pf = rvu->pfid; + nix->dev = dev; + nix->sq_cnt = 1; + nix->rq_cnt = 1; + nix->rss_grps = 1; + nix->cq_cnt = 2; + nix->xqe_sz = NIX_CQE_SIZE_W16; + + nix->lmac = nix_get_cgx_lmac(nix->pf); + if (!nix->lmac) { + printf("%s: Error: could not find lmac for pf %d\n", + __func__, nix->pf); + free(nix); + return NULL; + } + nix->lmac->link_num = + NIX_LINK_E_CGXX_LMACX(nix->lmac->cgx->cgx_id, + nix->lmac->lmac_id); + nix->lmac->chan_num = + NIX_CHAN_E_CGXX_LMACX_CHX(nix->lmac->cgx->cgx_id, + nix->lmac->lmac_id, 0); + /* This is rx pkind in 1:1 mapping to NIX_LINK_E */ + nix->lmac->pknd = nix->lmac->link_num; + + cgx_lmac_set_pkind(nix->lmac, nix->lmac->lmac_id, nix->lmac->pknd); + debug("%s(%s CGX%x LMAC%x)\n", __func__, dev->name, + nix->lmac->cgx->cgx_id, nix->lmac->lmac_id); + debug("%s(%s Link %x Chan %x Pknd %x)\n", __func__, dev->name, + nix->lmac->link_num, nix->lmac->chan_num, nix->lmac->pknd); + + err = npa_lf_setup(nix); + if (err) + return NULL; + + err = npc_lf_setup(nix); + if (err) + return NULL; + + err = nix_lf_setup(nix); + if (err) + return NULL; + + return nix; +} + +u64 npa_aura_op_alloc(struct npa *npa, u64 aura_id) +{ + union npa_lf_aura_op_allocx op_allocx; + + op_allocx.u = atomic_fetch_and_add64_nosync(npa->npa_base + + NPA_LF_AURA_OP_ALLOCX(0), aura_id); + return op_allocx.s.addr; +} + +u64 nix_cq_op_status(struct nix *nix, u64 cq_id) +{ + union nixx_lf_cq_op_status op_status; + s64 *reg = nix->nix_base + NIXX_LF_CQ_OP_STATUS(); + + op_status.u = atomic_fetch_and_add64_nosync(reg, cq_id << 32); + return op_status.u; +} + +/* TX */ +static inline void nix_write_lmt(struct nix *nix, void *buffer, + int num_words) +{ + int i; + + u64 *lmt_ptr = lmt_store_ptr(nix); + u64 *ptr = buffer; + + debug("%s lmt_ptr %p %p\n", __func__, nix->lmt_base, lmt_ptr); + for (i = 0; i < num_words; i++) { + debug("%s data %llx lmt_ptr %p\n", __func__, ptr[i], + lmt_ptr + i); + lmt_ptr[i] = ptr[i]; + } +} + +void nix_cqe_tx_pkt_handler(struct nix *nix, void *cqe) +{ + union nix_cqe_hdr_s *txcqe = (union nix_cqe_hdr_s *)cqe; + + debug("%s: txcqe: %p\n", __func__, txcqe); + + if (txcqe->s.cqe_type != NIX_XQE_TYPE_E_SEND) { + printf("%s: Error: Unsupported CQ header type %d\n", + __func__, txcqe->s.cqe_type); + return; + } + nix_pf_reg_write(nix, NIXX_LF_CQ_OP_DOOR(), + (NIX_CQ_TX << 32) | 1); +} + +void nix_lf_flush_tx(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + union nixx_lf_cq_op_status op_status; + u32 head, tail; + void *cq_tx_base = nix->cq[NIX_CQ_TX].base; + union nix_cqe_hdr_s *cqe; + + /* ack tx cqe entries */ + op_status.u = nix_cq_op_status(nix, NIX_CQ_TX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_TX].qsize - 1); + tail &= (nix->cq[NIX_CQ_TX].qsize - 1); + + debug("%s cq tx head %d tail %d\n", __func__, head, tail); + while (head != tail) { + cqe = cq_tx_base + head * nix->cq[NIX_CQ_TX].entry_sz; + nix_cqe_tx_pkt_handler(nix, cqe); + op_status.u = nix_cq_op_status(nix, NIX_CQ_TX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_TX].qsize - 1); + tail &= (nix->cq[NIX_CQ_TX].qsize - 1); + debug("%s cq tx head %d tail %d\n", __func__, head, tail); + } +} + +int nix_lf_xmit(struct udevice *dev, void *pkt, int pkt_len) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct nix_tx_dr tx_dr; + int dr_sz = (sizeof(struct nix_tx_dr) + 15) / 16 - 1; + s64 result; + void *packet; + + nix_lf_flush_tx(dev); + memset((void *)&tx_dr, 0, sizeof(struct nix_tx_dr)); + /* Dump TX packet in to NPA buffer */ + packet = (void *)npa_aura_op_alloc(nix->npa, NPA_POOL_TX); + if (!packet) { + printf("%s TX buffers unavailable\n", __func__); + return -1; + } + memcpy(packet, pkt, pkt_len); + debug("%s TX buffer %p\n", __func__, packet); + + tx_dr.hdr.s.aura = NPA_POOL_TX; + tx_dr.hdr.s.df = 0; + tx_dr.hdr.s.pnc = 1; + tx_dr.hdr.s.sq = 0; + tx_dr.hdr.s.total = pkt_len; + tx_dr.hdr.s.sizem1 = dr_sz - 2; /* FIXME - for now hdr+sg+sg1addr */ + debug("%s dr_sz %d\n", __func__, dr_sz); + + tx_dr.tx_sg.s.segs = 1; + tx_dr.tx_sg.s.subdc = NIX_SUBDC_E_SG; + tx_dr.tx_sg.s.seg1_size = pkt_len; + tx_dr.tx_sg.s.ld_type = NIX_SENDLDTYPE_E_LDT; + tx_dr.sg1_addr = (dma_addr_t)packet; + +#define DEBUG_PKT +#ifdef DEBUG_PKT + debug("TX PKT Data\n"); + for (int i = 0; i < pkt_len; i++) { + if (i && (i % 8 == 0)) + debug("\n"); + debug("%02x ", *((u8 *)pkt + i)); + } + debug("\n"); +#endif + do { + nix_write_lmt(nix, &tx_dr, (dr_sz - 1) * 2); + __iowmb(); + result = lmt_submit((u64)(nix->nix_base + + NIXX_LF_OP_SENDX(0))); + WATCHDOG_RESET(); + } while (result == 0); + + return 0; +} + +/* RX */ +void nix_lf_flush_rx(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + union nixx_lf_cq_op_status op_status; + void *cq_rx_base = nix->cq[NIX_CQ_RX].base; + struct nix_rx_dr *rx_dr; + union nix_rx_parse_s *rxparse; + u32 head, tail; + u32 rx_cqe_sz = nix->cq[NIX_CQ_RX].entry_sz; + u64 *seg; + + /* flush rx cqe entries */ + op_status.u = nix_cq_op_status(nix, NIX_CQ_RX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_RX].qsize - 1); + tail &= (nix->cq[NIX_CQ_RX].qsize - 1); + + debug("%s cq rx head %d tail %d\n", __func__, head, tail); + while (head != tail) { + rx_dr = (struct nix_rx_dr *)cq_rx_base + head * rx_cqe_sz; + rxparse = &rx_dr->rx_parse; + + debug("%s: rx parse: %p\n", __func__, rxparse); + debug("%s: rx parse: desc_sizem1 %x pkt_lenm1 %x\n", + __func__, rxparse->s.desc_sizem1, rxparse->s.pkt_lenm1); + + seg = (dma_addr_t *)(&rx_dr->rx_sg + 1); + + st128(nix->npa->npa_base + NPA_LF_AURA_OP_FREE0(), + seg[0], (1ULL << 63) | NPA_POOL_RX); + + debug("%s return %llx to NPA\n", __func__, seg[0]); + nix_pf_reg_write(nix, NIXX_LF_CQ_OP_DOOR(), + (NIX_CQ_RX << 32) | 1); + + op_status.u = nix_cq_op_status(nix, NIX_CQ_RX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_RX].qsize - 1); + tail &= (nix->cq[NIX_CQ_RX].qsize - 1); + debug("%s cq rx head %d tail %d\n", __func__, head, tail); + } +} + +int nix_lf_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + + /* Return rx packet to NPA */ + debug("%s return %p to NPA\n", __func__, pkt); + st128(nix->npa->npa_base + NPA_LF_AURA_OP_FREE0(), (u64)pkt, + (1ULL << 63) | NPA_POOL_RX); + nix_pf_reg_write(nix, NIXX_LF_CQ_OP_DOOR(), + (NIX_CQ_RX << 32) | 1); + + nix_lf_flush_tx(dev); + return 0; +} + +int nix_lf_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + union nixx_lf_cq_op_status op_status; + void *cq_rx_base = nix->cq[NIX_CQ_RX].base; + struct nix_rx_dr *rx_dr; + union nix_rx_parse_s *rxparse; + void *pkt, *cqe; + int pkt_len = 0; + u64 *addr; + u32 head, tail; + + /* fetch rx cqe entries */ + op_status.u = nix_cq_op_status(nix, NIX_CQ_RX); + head = op_status.s.head; + tail = op_status.s.tail; + head &= (nix->cq[NIX_CQ_RX].qsize - 1); + tail &= (nix->cq[NIX_CQ_RX].qsize - 1); + debug("%s cq rx head %d tail %d\n", __func__, head, tail); + if (head == tail) + return -EAGAIN; + + debug("%s: rx_base %p head %d sz %d\n", __func__, cq_rx_base, head, + nix->cq[NIX_CQ_RX].entry_sz); + cqe = cq_rx_base + head * nix->cq[NIX_CQ_RX].entry_sz; + rx_dr = (struct nix_rx_dr *)cqe; + rxparse = &rx_dr->rx_parse; + + debug("%s: rx completion: %p\n", __func__, cqe); + debug("%s: rx dr: %p\n", __func__, rx_dr); + debug("%s: rx parse: %p\n", __func__, rxparse); + debug("%s: rx parse: desc_sizem1 %x pkt_lenm1 %x\n", + __func__, rxparse->s.desc_sizem1, rxparse->s.pkt_lenm1); + debug("%s: rx parse: pkind %x chan %x\n", + __func__, rxparse->s.pkind, rxparse->s.chan); + + if (rx_dr->hdr.s.cqe_type != NIX_XQE_TYPE_E_RX) { + printf("%s: Error: Unsupported CQ header type in Rx %d\n", + __func__, rx_dr->hdr.s.cqe_type); + return -1; + } + + pkt_len = rxparse->s.pkt_lenm1 + 1; + addr = (dma_addr_t *)(&rx_dr->rx_sg + 1); + pkt = (void *)addr[0]; + + debug("%s: segs: %d (%d@0x%llx, %d@0x%llx, %d@0x%llx)\n", __func__, + rx_dr->rx_sg.s.segs, rx_dr->rx_sg.s.seg1_size, addr[0], + rx_dr->rx_sg.s.seg2_size, addr[1], + rx_dr->rx_sg.s.seg3_size, addr[2]); + if (pkt_len < rx_dr->rx_sg.s.seg1_size + rx_dr->rx_sg.s.seg2_size + + rx_dr->rx_sg.s.seg3_size) { + debug("%s: Error: rx buffer size too small\n", __func__); + return -1; + } + + __iowmb(); +#define DEBUG_PKT +#ifdef DEBUG_PKT + debug("RX PKT Data\n"); + for (int i = 0; i < pkt_len; i++) { + if (i && (i % 8 == 0)) + debug("\n"); + debug("%02x ", *((u8 *)pkt + i)); + } + debug("\n"); +#endif + + *packetp = (uchar *)pkt; + + return pkt_len; +} + +int nix_lf_setup_mac(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct eth_pdata *pdata = dev_get_platdata(dev); + + /* If lower level firmware fails to set proper MAC + * u-boot framework updates MAC to random address. + * Use this hook to update mac address in cgx lmac + * and call mac filter setup to update new address. + */ + if (memcmp(nix->lmac->mac_addr, pdata->enetaddr, ARP_HLEN)) { + memcpy(nix->lmac->mac_addr, pdata->enetaddr, 6); + eth_env_set_enetaddr_by_index("eth", rvu->dev->seq, + pdata->enetaddr); + cgx_lmac_mac_filter_setup(nix->lmac); + /* Update user given MAC address to ATF for update + * in sh_fwdata to use in Linux. + */ + cgx_intf_set_macaddr(dev); + debug("%s: lMAC %pM\n", __func__, nix->lmac->mac_addr); + debug("%s: pMAC %pM\n", __func__, pdata->enetaddr); + } + debug("%s: setupMAC %pM\n", __func__, pdata->enetaddr); + return 0; +} + +void nix_lf_halt(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + + cgx_lmac_rx_tx_enable(nix->lmac, nix->lmac->lmac_id, false); + + mdelay(1); + + /* Flush tx and rx descriptors */ + nix_lf_flush_rx(dev); + nix_lf_flush_tx(dev); +} + +int nix_lf_init(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct lmac *lmac = nix->lmac; + int ret; + u64 link_sts; + u8 link, speed; + u16 errcode; + + printf("Waiting for CGX%d LMAC%d [%s] link status...", + lmac->cgx->cgx_id, lmac->lmac_id, + lmac_type_to_str[lmac->lmac_type]); + + if (lmac->init_pend) { + /* Bring up LMAC */ + ret = cgx_lmac_link_enable(lmac, lmac->lmac_id, + true, &link_sts); + lmac->init_pend = 0; + } else { + ret = cgx_lmac_link_status(lmac, lmac->lmac_id, &link_sts); + } + + if (ret) { + printf(" [Down]\n"); + return -1; + } + + link = link_sts & 0x1; + speed = (link_sts >> 2) & 0xf; + errcode = (link_sts >> 6) & 0x2ff; + debug("%s: link %x speed %x errcode %x\n", + __func__, link, speed, errcode); + + /* Print link status */ + printf(" [%s]\n", link ? lmac_speed_to_str[speed] : "Down"); + if (!link) + return -1; + + if (!lmac->init_pend) + cgx_lmac_rx_tx_enable(lmac, lmac->lmac_id, true); + + return 0; +} + +void nix_get_cgx_lmac_id(struct udevice *dev, int *cgxid, int *lmacid) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct lmac *lmac = nix->lmac; + + *cgxid = lmac->cgx->cgx_id; + *lmacid = lmac->lmac_id; +} + +void nix_print_mac_info(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + struct nix *nix = rvu->nix; + struct lmac *lmac = nix->lmac; + + printf(" CGX%d LMAC%d [%s]", lmac->cgx->cgx_id, lmac->lmac_id, + lmac_type_to_str[lmac->lmac_type]); +} + diff --git a/drivers/net/octeontx2/nix.h b/drivers/net/octeontx2/nix.h new file mode 100644 index 0000000000..03260dddb3 --- /dev/null +++ b/drivers/net/octeontx2/nix.h @@ -0,0 +1,353 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef __NIX_H__ +#define __NIX_H__ + +#include <asm/arch/csrs/csrs-npa.h> +#include <asm/arch/csrs/csrs-nix.h> +#include "rvu.h" + +/** Maximum number of LMACs supported */ +#define MAX_LMAC 12 + +/* NIX RX action operation*/ +#define NIX_RX_ACTIONOP_DROP (0x0ull) +#define NIX_RX_ACTIONOP_UCAST (0x1ull) +#define NIX_RX_ACTIONOP_UCAST_IPSEC (0x2ull) +#define NIX_RX_ACTIONOP_MCAST (0x3ull) +#define NIX_RX_ACTIONOP_RSS (0x4ull) + +/* NIX TX action operation*/ +#define NIX_TX_ACTIONOP_DROP (0x0ull) +#define NIX_TX_ACTIONOP_UCAST_DEFAULT (0x1ull) +#define NIX_TX_ACTIONOP_UCAST_CHAN (0x2ull) +#define NIX_TX_ACTIONOP_MCAST (0x3ull) +#define NIX_TX_ACTIONOP_DROP_VIOL (0x5ull) + +#define NIX_INTF_RX 0 +#define NIX_INTF_TX 1 + +#define NIX_INTF_TYPE_CGX 0 +#define NIX_INTF_TYPE_LBK 1 +#define NIX_MAX_HW_MTU 9212 +#define NIX_MIN_HW_MTU 40 +#define MAX_MTU 1536 + +#define NPA_POOL_COUNT 3 +#define NPA_AURA_COUNT(x) (1ULL << ((x) + 6)) +#define NPA_POOL_RX 0ULL +#define NPA_POOL_TX 1ULL +#define NPA_POOL_SQB 2ULL +#define RQ_QLEN Q_COUNT(Q_SIZE_1K) +#define SQ_QLEN Q_COUNT(Q_SIZE_1K) +#define SQB_QLEN Q_COUNT(Q_SIZE_16) + +#define NIX_CQ_RX 0ULL +#define NIX_CQ_TX 1ULL +#define NIX_CQ_COUNT 2ULL +#define NIX_CQE_SIZE_W16 (16 * sizeof(u64)) +#define NIX_CQE_SIZE_W64 (64 * sizeof(u64)) + +/** Size of aura hardware context */ +#define NPA_AURA_HW_CTX_SIZE 48 +/** Size of pool hardware context */ +#define NPA_POOL_HW_CTX_SIZE 64 + +#define NPA_DEFAULT_PF_FUNC 0xffff + +#define NIX_CHAN_CGX_LMAC_CHX(a, b, c) (0x800 + 0x100 * (a) + 0x10 * (b) + (c)) +#define NIX_LINK_CGX_LMAC(a, b) (0 + 4 * (a) + (b)) +#define NIX_LINK_LBK(a) (12 + (a)) +#define NIX_CHAN_LBK_CHX(a, b) (0 + 0x100 * (a) + (b)) +#define MAX_LMAC_PKIND 12 + +/** Number of Admin queue entries */ +#define AQ_RING_SIZE Q_COUNT(Q_SIZE_16) + +/** Each completion queue contains 256 entries, see NIC_CQ_CTX_S[qsize] */ +#define CQS_QSIZE Q_SIZE_256 +#define CQ_ENTRIES Q_COUNT(CQS_QSIZE) +/** + * Each completion queue entry contains 128 bytes, see + * NIXX_AF_LFX_CFG[xqe_size] + */ +#define CQ_ENTRY_SIZE NIX_CQE_SIZE_W16 + +enum npa_aura_size { + NPA_AURA_SZ_0, + NPA_AURA_SZ_128, + NPA_AURA_SZ_256, + NPA_AURA_SZ_512, + NPA_AURA_SZ_1K, + NPA_AURA_SZ_2K, + NPA_AURA_SZ_4K, + NPA_AURA_SZ_8K, + NPA_AURA_SZ_16K, + NPA_AURA_SZ_32K, + NPA_AURA_SZ_64K, + NPA_AURA_SZ_128K, + NPA_AURA_SZ_256K, + NPA_AURA_SZ_512K, + NPA_AURA_SZ_1M, + NPA_AURA_SZ_MAX, +}; + +#define NPA_AURA_SIZE_DEFAULT NPA_AURA_SZ_128 + +/* NIX Transmit schedulers */ +enum nix_scheduler { + NIX_TXSCH_LVL_SMQ = 0x0, + NIX_TXSCH_LVL_MDQ = 0x0, + NIX_TXSCH_LVL_TL4 = 0x1, + NIX_TXSCH_LVL_TL3 = 0x2, + NIX_TXSCH_LVL_TL2 = 0x3, + NIX_TXSCH_LVL_TL1 = 0x4, + NIX_TXSCH_LVL_CNT = 0x5, +}; + +struct cgx; + +struct nix_stats { + u64 num_packets; + u64 num_bytes; +}; + +struct nix; +struct lmac; + +struct npa_af { + void __iomem *npa_af_base; + struct admin_queue aq; + u32 aura; +}; + +struct npa { + struct npa_af *npa_af; + void __iomem *npa_base; + void __iomem *npc_base; + void __iomem *lmt_base; + /** Hardware aura context */ + void *aura_ctx; + /** Hardware pool context */ + void *pool_ctx[NPA_POOL_COUNT]; + void *pool_stack[NPA_POOL_COUNT]; + void **buffers[NPA_POOL_COUNT]; + u32 pool_stack_pages[NPA_POOL_COUNT]; + u32 pool_stack_pointers; + u32 q_len[NPA_POOL_COUNT]; + u32 buf_size[NPA_POOL_COUNT]; + u32 stack_pages[NPA_POOL_COUNT]; +}; + +struct nix_af { + struct udevice *dev; + struct nix *lmacs[MAX_LMAC]; + struct npa_af *npa_af; + void __iomem *nix_af_base; + void __iomem *npc_af_base; + struct admin_queue aq; + u8 num_lmacs; + s8 index; + u8 xqe_size; + u32 sqb_size; + u32 qints; + u32 cints; + u32 sq_ctx_sz; + u32 rq_ctx_sz; + u32 cq_ctx_sz; + u32 rsse_ctx_sz; + u32 cint_ctx_sz; + u32 qint_ctx_sz; +}; + +struct nix_tx_dr { + union nix_send_hdr_s hdr; + union nix_send_sg_s tx_sg; + dma_addr_t sg1_addr; + dma_addr_t sg2_addr; + dma_addr_t sg3_addr; + u64 in_use; +}; + +struct nix_rx_dr { + union nix_cqe_hdr_s hdr; + union nix_rx_parse_s rx_parse; + union nix_rx_sg_s rx_sg; +}; + +struct nix { + struct udevice *dev; + struct eth_device *netdev; + struct nix_af *nix_af; + struct npa *npa; + struct lmac *lmac; + union nix_cint_hw_s *cint_base; + union nix_cq_ctx_s *cq_ctx_base; + union nix_qint_hw_s *qint_base; + union nix_rq_ctx_s *rq_ctx_base; + union nix_rsse_s *rss_base; + union nix_sq_ctx_s *sq_ctx_base; + void *cqe_base; + struct qmem sq; + struct qmem cq[NIX_CQ_COUNT]; + struct qmem rq; + struct qmem rss; + struct qmem cq_ints; + struct qmem qints; + char name[16]; + void __iomem *nix_base; /** PF reg base */ + void __iomem *npc_base; + void __iomem *lmt_base; + struct nix_stats tx_stats; + struct nix_stats rx_stats; + u32 aura; + int pknd; + int lf; + int pf; + u16 pf_func; + u32 rq_cnt; /** receive queues count */ + u32 sq_cnt; /** send queues count */ + u32 cq_cnt; /** completion queues count */ + u16 rss_sz; + u16 sqb_size; + u8 rss_grps; + u8 xqe_sz; +}; + +struct nix_aq_cq_dis { + union nix_aq_res_s resp ALIGNED; + union nix_cq_ctx_s cq ALIGNED; + union nix_cq_ctx_s mcq ALIGNED; +}; + +struct nix_aq_rq_dis { + union nix_aq_res_s resp ALIGNED; + union nix_rq_ctx_s rq ALIGNED; + union nix_rq_ctx_s mrq ALIGNED; +}; + +struct nix_aq_sq_dis { + union nix_aq_res_s resp ALIGNED; + union nix_sq_ctx_s sq ALIGNED; + union nix_sq_ctx_s msq ALIGNED; +}; + +struct nix_aq_cq_request { + union nix_aq_res_s resp ALIGNED; + union nix_cq_ctx_s cq ALIGNED; +}; + +struct nix_aq_rq_request { + union nix_aq_res_s resp ALIGNED; + union nix_rq_ctx_s rq ALIGNED; +}; + +struct nix_aq_sq_request { + union nix_aq_res_s resp ALIGNED; + union nix_sq_ctx_s sq ALIGNED; +}; + +static inline u64 nix_af_reg_read(struct nix_af *nix_af, u64 offset) +{ + u64 val = readq(nix_af->nix_af_base + offset); + + debug("%s reg %p val %llx\n", __func__, nix_af->nix_af_base + offset, + val); + return val; +} + +static inline void nix_af_reg_write(struct nix_af *nix_af, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, nix_af->nix_af_base + offset, + val); + writeq(val, nix_af->nix_af_base + offset); +} + +static inline u64 nix_pf_reg_read(struct nix *nix, u64 offset) +{ + u64 val = readq(nix->nix_base + offset); + + debug("%s reg %p val %llx\n", __func__, nix->nix_base + offset, + val); + return val; +} + +static inline void nix_pf_reg_write(struct nix *nix, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, nix->nix_base + offset, + val); + writeq(val, nix->nix_base + offset); +} + +static inline u64 npa_af_reg_read(struct npa_af *npa_af, u64 offset) +{ + u64 val = readq(npa_af->npa_af_base + offset); + + debug("%s reg %p val %llx\n", __func__, npa_af->npa_af_base + offset, + val); + return val; +} + +static inline void npa_af_reg_write(struct npa_af *npa_af, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, npa_af->npa_af_base + offset, + val); + writeq(val, npa_af->npa_af_base + offset); +} + +static inline u64 npc_af_reg_read(struct nix_af *nix_af, u64 offset) +{ + u64 val = readq(nix_af->npc_af_base + offset); + + debug("%s reg %p val %llx\n", __func__, nix_af->npc_af_base + offset, + val); + return val; +} + +static inline void npc_af_reg_write(struct nix_af *nix_af, u64 offset, + u64 val) +{ + debug("%s reg %p val %llx\n", __func__, nix_af->npc_af_base + offset, + val); + writeq(val, nix_af->npc_af_base + offset); +} + +int npa_attach_aura(struct nix_af *nix_af, int lf, + const union npa_aura_s *desc, u32 aura_id); +int npa_attach_pool(struct nix_af *nix_af, int lf, + const union npa_pool_s *desc, u32 pool_id); +int npa_af_setup(struct npa_af *npa_af); +int npa_af_shutdown(struct npa_af *npa_af); +int npa_lf_setup(struct nix *nix); +int npa_lf_shutdown(struct nix *nix); +int npa_lf_admin_setup(struct npa *npa, int lf, dma_addr_t aura_base); +int npa_lf_admin_shutdown(struct nix_af *nix_af, int lf, u32 pool_count); + +int npc_lf_admin_setup(struct nix *nix); +int npc_af_shutdown(struct nix_af *nix_af); + +int nix_af_setup(struct nix_af *nix_af); +int nix_af_shutdown(struct nix_af *nix_af); +int nix_lf_setup(struct nix *nix); +int nix_lf_shutdown(struct nix *nix); +struct nix *nix_lf_alloc(struct udevice *dev); +int nix_lf_admin_setup(struct nix *nix); +int nix_lf_admin_shutdown(struct nix_af *nix_af, int lf, + u32 cq_count, u32 rq_count, u32 sq_count); +struct rvu_af *get_af(void); + +int nix_lf_setup_mac(struct udevice *dev); +int nix_lf_read_rom_mac(struct udevice *dev); +void nix_lf_halt(struct udevice *dev); +int nix_lf_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len); +int nix_lf_recv(struct udevice *dev, int flags, uchar **packetp); +int nix_lf_init(struct udevice *dev); +int nix_lf_xmit(struct udevice *dev, void *pkt, int pkt_len); + +#endif /* __NIX_H__ */ diff --git a/drivers/net/octeontx2/nix_af.c b/drivers/net/octeontx2/nix_af.c new file mode 100644 index 0000000000..d513917ee7 --- /dev/null +++ b/drivers/net/octeontx2/nix_af.c @@ -0,0 +1,1102 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <memalign.h> +#include <misc.h> +#include <net.h> +#include <pci.h> +#include <watchdog.h> +#include <linux/types.h> +#include <linux/list.h> +#include <linux/log2.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-npc.h> +#include <asm/arch/csrs/csrs-lmt.h> +#include <asm/io.h> + +#include "nix.h" +#include "lmt.h" +#include "cgx.h" + +static struct nix_aq_cq_dis cq_dis ALIGNED; +static struct nix_aq_rq_dis rq_dis ALIGNED; +static struct nix_aq_sq_dis sq_dis ALIGNED; + +/*************** + * NPA API + ***************/ +int npa_attach_aura(struct nix_af *nix_af, int lf, + const union npa_aura_s *desc, u32 aura_id) +{ + struct npa_af *npa = nix_af->npa_af; + union npa_aq_inst_s *inst; + union npa_aq_res_s *res; + union npa_af_aq_status aq_stat; + union npa_aura_s *context; + u64 head; + ulong start; + + debug("%s(%p, %d, %p, %u)\n", __func__, nix_af, lf, desc, aura_id); + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = (union npa_aq_res_s *)(npa->aq.res.base); + + memset(inst, 0, sizeof(*inst)); + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_AURA; + inst->s.op = NPA_AQ_INSTOP_E_INIT; + inst->s.res_addr = npa->aq.res.iova; + inst->s.cindex = aura_id; + + context = (union npa_aura_s *)(npa->aq.res.base + + CONFIG_SYS_CACHELINE_SIZE); + memset(npa->aq.res.base, 0, npa->aq.res.entry_sz); + memcpy(context, desc, sizeof(union npa_aura_s)); + __iowmb(); + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good\n", + __func__, res->s.compcode); + return -1; + } + + return 0; +} + +int npa_attach_pool(struct nix_af *nix_af, int lf, + const union npa_pool_s *desc, u32 pool_id) +{ + union npa_aq_inst_s *inst; + union npa_aq_res_s *res; + union npa_af_aq_status aq_stat; + struct npa_af *npa = nix_af->npa_af; + union npa_aura_s *context; + u64 head; + ulong start; + + debug("%s(%p, %d, %p, %u)\n", __func__, nix_af, lf, desc, pool_id); + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = (union npa_aq_res_s *)(npa->aq.res.base); + + memset(inst, 0, sizeof(*inst)); + inst->s.cindex = pool_id; + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_POOL; + inst->s.op = NPA_AQ_INSTOP_E_INIT; + inst->s.res_addr = npa->aq.res.iova; + + context = (union npa_aura_s *)(npa->aq.res.base + + CONFIG_SYS_CACHELINE_SIZE); + memset(npa->aq.res.base, 0, npa->aq.res.entry_sz); + memcpy(context, desc, sizeof(union npa_aura_s)); + __iowmb(); + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good\n", + __func__, res->s.compcode); + return -1; + } + + return 0; +} + +int npa_lf_admin_setup(struct npa *npa, int lf, dma_addr_t aura_base) +{ + union npa_af_lf_rst lf_rst; + union npa_af_lfx_auras_cfg auras_cfg; + struct npa_af *npa_af = npa->npa_af; + + debug("%s(%p, %d, 0x%llx)\n", __func__, npa_af, lf, aura_base); + lf_rst.u = 0; + lf_rst.s.exec = 1; + lf_rst.s.lf = lf; + npa_af_reg_write(npa_af, NPA_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = npa_af_reg_read(npa_af, NPA_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + /* Set Aura size and enable caching of contexts */ + auras_cfg.u = npa_af_reg_read(npa_af, NPA_AF_LFX_AURAS_CFG(lf)); + auras_cfg.s.loc_aura_size = NPA_AURA_SIZE_DEFAULT; //FIXME aura_size; + auras_cfg.s.caching = 1; + auras_cfg.s.rmt_aura_size = 0; + auras_cfg.s.rmt_aura_offset = 0; + auras_cfg.s.rmt_lf = 0; + npa_af_reg_write(npa_af, NPA_AF_LFX_AURAS_CFG(lf), auras_cfg.u); + /* Configure aura HW context base */ + npa_af_reg_write(npa_af, NPA_AF_LFX_LOC_AURAS_BASE(lf), + aura_base); + + return 0; +} + +int npa_lf_admin_shutdown(struct nix_af *nix_af, int lf, u32 pool_count) +{ + int pool_id; + u32 head; + union npa_aq_inst_s *inst; + union npa_aq_res_s *res; + struct npa_aq_pool_request { + union npa_aq_res_s resp ALIGNED; + union npa_pool_s p0 ALIGNED; + union npa_pool_s p1 ALIGNED; + } pool_req ALIGNED; + struct npa_aq_aura_request { + union npa_aq_res_s resp ALIGNED; + union npa_aura_s a0 ALIGNED; + union npa_aura_s a1 ALIGNED; + } aura_req ALIGNED; + union npa_af_aq_status aq_stat; + union npa_af_lf_rst lf_rst; + struct npa_af *npa = nix_af->npa_af; + ulong start; + + for (pool_id = 0; pool_id < pool_count; pool_id++) { + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = &pool_req.resp; + + memset(inst, 0, sizeof(*inst)); + inst->s.cindex = pool_id; + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_POOL; + inst->s.op = NPA_AQ_INSTOP_E_WRITE; + inst->s.res_addr = (u64)&pool_req.resp; + + memset((void *)&pool_req, 0, sizeof(pool_req)); + pool_req.p0.s.ena = 0; + pool_req.p1.s.ena = 1; /* Write mask */ + __iowmb(); + + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good for lf %d\n" + " aura id %d", __func__, res->s.compcode, lf, + pool_id); + return -1; + } + debug("%s(LF %d, pool id %d) disabled\n", __func__, lf, + pool_id); + } + + for (pool_id = 0; pool_id < pool_count; pool_id++) { + aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS()); + head = aq_stat.s.head_ptr; + inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head; + res = &aura_req.resp; + + memset(inst, 0, sizeof(*inst)); + inst->s.cindex = pool_id; + inst->s.lf = lf; + inst->s.doneint = 0; + inst->s.ctype = NPA_AQ_CTYPE_E_AURA; + inst->s.op = NPA_AQ_INSTOP_E_WRITE; + inst->s.res_addr = (u64)&aura_req.resp; + + memset((void *)&aura_req, 0, sizeof(aura_req)); + aura_req.a0.s.ena = 0; + aura_req.a1.s.ena = 1; /* Write mask */ + __iowmb(); + + npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1); + + start = get_timer(0); + while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) && + (get_timer(start) < 1000)) + WATCHDOG_RESET(); + + if (res->s.compcode != NPA_AQ_COMP_E_GOOD) { + printf("%s: Error: result 0x%x not good for lf %d\n" + " aura id %d", __func__, res->s.compcode, lf, + pool_id); + return -1; + } + debug("%s(LF %d, aura id %d) disabled\n", __func__, lf, + pool_id); + } + + /* Reset the LF */ + lf_rst.u = 0; + lf_rst.s.exec = 1; + lf_rst.s.lf = lf; + npa_af_reg_write(npa, NPA_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = npa_af_reg_read(npa, NPA_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + return 0; +} + +int npa_af_setup(struct npa_af *npa_af) +{ + int err; + union npa_af_gen_cfg npa_cfg; + union npa_af_ndc_cfg ndc_cfg; + union npa_af_aq_cfg aq_cfg; + union npa_af_blk_rst blk_rst; + + err = rvu_aq_alloc(&npa_af->aq, Q_COUNT(AQ_SIZE), + sizeof(union npa_aq_inst_s), + sizeof(union npa_aq_res_s)); + if (err) { + printf("%s: Error %d allocating admin queue\n", __func__, err); + return err; + } + debug("%s: NPA admin queue allocated at %p %llx\n", __func__, + npa_af->aq.inst.base, npa_af->aq.inst.iova); + + blk_rst.u = 0; + blk_rst.s.rst = 1; + npa_af_reg_write(npa_af, NPA_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = npa_af_reg_read(npa_af, NPA_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + /* Set little Endian */ + npa_cfg.u = npa_af_reg_read(npa_af, NPA_AF_GEN_CFG()); + npa_cfg.s.af_be = 0; + npa_af_reg_write(npa_af, NPA_AF_GEN_CFG(), npa_cfg.u); + /* Enable NDC cache */ + ndc_cfg.u = npa_af_reg_read(npa_af, NPA_AF_NDC_CFG()); + ndc_cfg.s.ndc_bypass = 0; + npa_af_reg_write(npa_af, NPA_AF_NDC_CFG(), ndc_cfg.u); + /* Set up queue size */ + aq_cfg.u = npa_af_reg_read(npa_af, NPA_AF_AQ_CFG()); + aq_cfg.s.qsize = AQ_SIZE; + npa_af_reg_write(npa_af, NPA_AF_AQ_CFG(), aq_cfg.u); + /* Set up queue base address */ + npa_af_reg_write(npa_af, NPA_AF_AQ_BASE(), npa_af->aq.inst.iova); + + return 0; +} + +int npa_af_shutdown(struct npa_af *npa_af) +{ + union npa_af_blk_rst blk_rst; + + blk_rst.u = 0; + blk_rst.s.rst = 1; + npa_af_reg_write(npa_af, NPA_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = npa_af_reg_read(npa_af, NPA_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + rvu_aq_free(&npa_af->aq); + + debug("%s: npa af reset --\n", __func__); + + return 0; +} + +/*************** + * NIX API + ***************/ +/** + * Setup SMQ -> TL4 -> TL3 -> TL2 -> TL1 -> MAC mapping + * + * @param nix Handle to setup + * + * @return 0, or negative on failure + */ +static int nix_af_setup_sq(struct nix *nix) +{ + union nixx_af_tl1x_schedule tl1_sched; + union nixx_af_tl2x_parent tl2_parent; + union nixx_af_tl3x_parent tl3_parent; + union nixx_af_tl3_tl2x_cfg tl3_tl2_cfg; + union nixx_af_tl3_tl2x_linkx_cfg tl3_tl2_link_cfg; + union nixx_af_tl4x_parent tl4_parent; + union nixx_af_tl4x_sdp_link_cfg tl4_sdp_link_cfg; + union nixx_af_smqx_cfg smq_cfg; + union nixx_af_mdqx_schedule mdq_sched; + union nixx_af_mdqx_parent mdq_parent; + union nixx_af_rx_linkx_cfg link_cfg; + int tl1_index = nix->lmac->link_num; /* NIX_LINK_E enum */ + int tl2_index = tl1_index; + int tl3_index = tl2_index; + int tl4_index = tl3_index; + int smq_index = tl4_index; + struct nix_af *nix_af = nix->nix_af; + u64 offset = 0; + + tl1_sched.u = nix_af_reg_read(nix_af, + NIXX_AF_TL1X_SCHEDULE(tl1_index)); + tl1_sched.s.rr_quantum = MAX_MTU; + nix_af_reg_write(nix_af, NIXX_AF_TL1X_SCHEDULE(tl1_index), + tl1_sched.u); + + tl2_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_TL2X_PARENT(tl2_index)); + tl2_parent.s.parent = tl1_index; + nix_af_reg_write(nix_af, NIXX_AF_TL2X_PARENT(tl2_index), + tl2_parent.u); + + tl3_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_TL3X_PARENT(tl3_index)); + tl3_parent.s.parent = tl2_index; + nix_af_reg_write(nix_af, NIXX_AF_TL3X_PARENT(tl3_index), + tl3_parent.u); + tl3_tl2_cfg.u = nix_af_reg_read(nix_af, + NIXX_AF_TL3_TL2X_CFG(tl3_index)); + tl3_tl2_cfg.s.express = 0; + nix_af_reg_write(nix_af, NIXX_AF_TL3_TL2X_CFG(tl3_index), + tl3_tl2_cfg.u); + + offset = NIXX_AF_TL3_TL2X_LINKX_CFG(tl3_index, + nix->lmac->link_num); + tl3_tl2_link_cfg.u = nix_af_reg_read(nix_af, offset); + tl3_tl2_link_cfg.s.bp_ena = 1; + tl3_tl2_link_cfg.s.ena = 1; + tl3_tl2_link_cfg.s.relchan = 0; + offset = NIXX_AF_TL3_TL2X_LINKX_CFG(tl3_index, + nix->lmac->link_num); + nix_af_reg_write(nix_af, offset, tl3_tl2_link_cfg.u); + + tl4_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_TL4X_PARENT(tl4_index)); + tl4_parent.s.parent = tl3_index; + nix_af_reg_write(nix_af, NIXX_AF_TL4X_PARENT(tl4_index), + tl4_parent.u); + + offset = NIXX_AF_TL4X_SDP_LINK_CFG(tl4_index); + tl4_sdp_link_cfg.u = nix_af_reg_read(nix_af, offset); + tl4_sdp_link_cfg.s.bp_ena = 0; + tl4_sdp_link_cfg.s.ena = 0; + tl4_sdp_link_cfg.s.relchan = 0; + offset = NIXX_AF_TL4X_SDP_LINK_CFG(tl4_index); + nix_af_reg_write(nix_af, offset, tl4_sdp_link_cfg.u); + + smq_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_SMQX_CFG(smq_index)); + smq_cfg.s.express = 0; + smq_cfg.s.lf = nix->lf; + smq_cfg.s.desc_shp_ctl_dis = 1; + smq_cfg.s.maxlen = MAX_MTU; + smq_cfg.s.minlen = NIX_MIN_HW_MTU; + nix_af_reg_write(nix_af, NIXX_AF_SMQX_CFG(smq_index), smq_cfg.u); + + mdq_sched.u = nix_af_reg_read(nix_af, + NIXX_AF_MDQX_SCHEDULE(smq_index)); + mdq_sched.s.rr_quantum = MAX_MTU; + offset = NIXX_AF_MDQX_SCHEDULE(smq_index); + nix_af_reg_write(nix_af, offset, mdq_sched.u); + mdq_parent.u = nix_af_reg_read(nix_af, + NIXX_AF_MDQX_PARENT(smq_index)); + mdq_parent.s.parent = tl4_index; + nix_af_reg_write(nix_af, NIXX_AF_MDQX_PARENT(smq_index), + mdq_parent.u); + + link_cfg.u = 0; + link_cfg.s.maxlen = NIX_MAX_HW_MTU; + link_cfg.s.minlen = NIX_MIN_HW_MTU; + nix_af_reg_write(nix->nix_af, + NIXX_AF_RX_LINKX_CFG(nix->lmac->link_num), + link_cfg.u); + + return 0; +} + +/** + * Issue a command to the NIX AF Admin Queue + * + * @param nix nix handle + * @param lf Logical function number for command + * @param op Operation + * @param ctype Context type + * @param cindex Context index + * @param resp Result pointer + * + * @return 0 for success, -EBUSY on failure + */ +static int nix_aq_issue_command(struct nix_af *nix_af, + int lf, + int op, + int ctype, + int cindex, union nix_aq_res_s *resp) +{ + union nixx_af_aq_status aq_status; + union nix_aq_inst_s *aq_inst; + union nix_aq_res_s *result = resp; + ulong start; + + debug("%s(%p, 0x%x, 0x%x, 0x%x, 0x%x, %p)\n", __func__, nix_af, lf, + op, ctype, cindex, resp); + aq_status.u = nix_af_reg_read(nix_af, NIXX_AF_AQ_STATUS()); + aq_inst = (union nix_aq_inst_s *)(nix_af->aq.inst.base) + + aq_status.s.head_ptr; + aq_inst->u[0] = 0; + aq_inst->u[1] = 0; + aq_inst->s.op = op; + aq_inst->s.ctype = ctype; + aq_inst->s.lf = lf; + aq_inst->s.cindex = cindex; + aq_inst->s.doneint = 0; + aq_inst->s.res_addr = (u64)resp; + debug("%s: inst@%p: 0x%llx 0x%llx\n", __func__, aq_inst, + aq_inst->u[0], aq_inst->u[1]); + __iowmb(); + + /* Ring doorbell and wait for result */ + nix_af_reg_write(nix_af, NIXX_AF_AQ_DOOR(), 1); + + start = get_timer(0); + /* Wait for completion */ + do { + WATCHDOG_RESET(); + dsb(); + } while (result->s.compcode == 0 && get_timer(start) < 2); + + if (result->s.compcode != NIX_AQ_COMP_E_GOOD) { + printf("NIX:AQ fail or time out with code %d after %ld ms\n", + result->s.compcode, get_timer(start)); + return -EBUSY; + } + return 0; +} + +static int nix_attach_receive_queue(struct nix_af *nix_af, int lf) +{ + struct nix_aq_rq_request rq_req ALIGNED; + int err; + + debug("%s(%p, %d)\n", __func__, nix_af, lf); + + memset(&rq_req, 0, sizeof(struct nix_aq_rq_request)); + + rq_req.rq.s.ena = 1; + rq_req.rq.s.spb_ena = 1; + rq_req.rq.s.ipsech_ena = 0; + rq_req.rq.s.ena_wqwd = 0; + rq_req.rq.s.cq = NIX_CQ_RX; + rq_req.rq.s.substream = 0; /* FIXME: Substream IDs? */ + rq_req.rq.s.wqe_aura = -1; /* No WQE aura */ + rq_req.rq.s.spb_aura = NPA_POOL_RX; + rq_req.rq.s.lpb_aura = NPA_POOL_RX; + /* U-Boot doesn't use WQE group for anything */ + rq_req.rq.s.pb_caching = 1; + rq_req.rq.s.xqe_drop_ena = 0; /* Disable RED dropping */ + rq_req.rq.s.spb_drop_ena = 0; + rq_req.rq.s.lpb_drop_ena = 0; + rq_req.rq.s.spb_sizem1 = (MAX_MTU / (3 * 8)) - 1; /* 512 bytes */ + rq_req.rq.s.lpb_sizem1 = (MAX_MTU / 8) - 1; + rq_req.rq.s.first_skip = 0; + rq_req.rq.s.later_skip = 0; + rq_req.rq.s.xqe_imm_copy = 0; + rq_req.rq.s.xqe_hdr_split = 0; + rq_req.rq.s.xqe_drop = 0; + rq_req.rq.s.xqe_pass = 0; + rq_req.rq.s.wqe_pool_drop = 0; /* No WQE pool */ + rq_req.rq.s.wqe_pool_pass = 0; /* No WQE pool */ + rq_req.rq.s.spb_aura_drop = 255; + rq_req.rq.s.spb_aura_pass = 255; + rq_req.rq.s.spb_pool_drop = 0; + rq_req.rq.s.spb_pool_pass = 0; + rq_req.rq.s.lpb_aura_drop = 255; + rq_req.rq.s.lpb_aura_pass = 255; + rq_req.rq.s.lpb_pool_drop = 0; + rq_req.rq.s.lpb_pool_pass = 0; + rq_req.rq.s.qint_idx = 0; + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_INIT, + NIX_AQ_CTYPE_E_RQ, + 0, &rq_req.resp); + if (err) { + printf("%s: Error requesting send queue\n", __func__); + return err; + } + + return 0; +} + +static int nix_attach_send_queue(struct nix *nix) +{ + struct nix_af *nix_af = nix->nix_af; + struct nix_aq_sq_request sq_req ALIGNED; + int err; + + debug("%s(%p)\n", __func__, nix_af); + err = nix_af_setup_sq(nix); + + memset(&sq_req, 0, sizeof(sq_req)); + + sq_req.sq.s.ena = 1; + sq_req.sq.s.cq_ena = 1; + sq_req.sq.s.max_sqe_size = NIX_MAXSQESZ_E_W16; + sq_req.sq.s.substream = 0; // FIXME: Substream IDs? + sq_req.sq.s.sdp_mcast = 0; + sq_req.sq.s.cq = NIX_CQ_TX; + sq_req.sq.s.cq_limit = 0; + sq_req.sq.s.smq = nix->lmac->link_num; // scheduling index + sq_req.sq.s.sso_ena = 0; + sq_req.sq.s.smq_rr_quantum = MAX_MTU / 4; + sq_req.sq.s.default_chan = nix->lmac->chan_num; + sq_req.sq.s.sqe_stype = NIX_STYPE_E_STP; + sq_req.sq.s.qint_idx = 0; + sq_req.sq.s.sqb_aura = NPA_POOL_SQB; + + err = nix_aq_issue_command(nix_af, nix->lf, + NIX_AQ_INSTOP_E_INIT, + NIX_AQ_CTYPE_E_SQ, + 0, &sq_req.resp); + if (err) { + printf("%s: Error requesting send queue\n", __func__); + return err; + } + + return 0; +} + +static int nix_attach_completion_queue(struct nix *nix, int cq_idx) +{ + struct nix_af *nix_af = nix->nix_af; + struct nix_aq_cq_request cq_req ALIGNED; + int err; + + debug("%s(%p)\n", __func__, nix_af); + memset(&cq_req, 0, sizeof(cq_req)); + cq_req.cq.s.ena = 1; + cq_req.cq.s.bpid = nix->lmac->pknd; + cq_req.cq.s.substream = 0; /* FIXME: Substream IDs? */ + cq_req.cq.s.drop_ena = 0; + cq_req.cq.s.caching = 1; + cq_req.cq.s.qsize = CQS_QSIZE; + cq_req.cq.s.drop = 255 * 7 / 8; + cq_req.cq.s.qint_idx = 0; + cq_req.cq.s.cint_idx = 0; + cq_req.cq.s.base = nix->cq[cq_idx].iova; + debug("%s: CQ(%d) base %p\n", __func__, cq_idx, + nix->cq[cq_idx].base); + + err = nix_aq_issue_command(nix_af, nix->lf, + NIX_AQ_INSTOP_E_INIT, + NIX_AQ_CTYPE_E_CQ, + cq_idx, &cq_req.resp); + if (err) { + printf("%s: Error requesting completion queue\n", __func__); + return err; + } + debug("%s: CQ(%d) allocated, base %p\n", __func__, cq_idx, + nix->cq[cq_idx].base); + + return 0; +} + +int nix_lf_admin_setup(struct nix *nix) +{ + union nixx_af_lfx_rqs_cfg rqs_cfg; + union nixx_af_lfx_sqs_cfg sqs_cfg; + union nixx_af_lfx_cqs_cfg cqs_cfg; + union nixx_af_lfx_rss_cfg rss_cfg; + union nixx_af_lfx_cints_cfg cints_cfg; + union nixx_af_lfx_qints_cfg qints_cfg; + union nixx_af_lfx_rss_grpx rss_grp; + union nixx_af_lfx_tx_cfg2 tx_cfg2; + union nixx_af_lfx_cfg lfx_cfg; + union nixx_af_lf_rst lf_rst; + u32 index; + struct nix_af *nix_af = nix->nix_af; + int err; + + /* Reset the LF */ + lf_rst.u = 0; + lf_rst.s.lf = nix->lf; + lf_rst.s.exec = 1; + nix_af_reg_write(nix_af, NIXX_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = nix_af_reg_read(nix_af, NIXX_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + /* Config NIX RQ HW context and base*/ + nix_af_reg_write(nix_af, NIXX_AF_LFX_RQS_BASE(nix->lf), + (u64)nix->rq_ctx_base); + /* Set caching and queue count in HW */ + rqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_RQS_CFG(nix->lf)); + rqs_cfg.s.caching = 1; + rqs_cfg.s.max_queuesm1 = nix->rq_cnt - 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_RQS_CFG(nix->lf), rqs_cfg.u); + + /* Config NIX SQ HW context and base*/ + nix_af_reg_write(nix_af, NIXX_AF_LFX_SQS_BASE(nix->lf), + (u64)nix->sq_ctx_base); + sqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_SQS_CFG(nix->lf)); + sqs_cfg.s.caching = 1; + sqs_cfg.s.max_queuesm1 = nix->sq_cnt - 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_SQS_CFG(nix->lf), sqs_cfg.u); + + /* Config NIX CQ HW context and base*/ + nix_af_reg_write(nix_af, NIXX_AF_LFX_CQS_BASE(nix->lf), + (u64)nix->cq_ctx_base); + cqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_CQS_CFG(nix->lf)); + cqs_cfg.s.caching = 1; + cqs_cfg.s.max_queuesm1 = nix->cq_cnt - 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_CQS_CFG(nix->lf), cqs_cfg.u); + + /* Config NIX RSS HW context and base */ + nix_af_reg_write(nix_af, NIXX_AF_LFX_RSS_BASE(nix->lf), + (u64)nix->rss_base); + rss_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_RSS_CFG(nix->lf)); + rss_cfg.s.ena = 1; + rss_cfg.s.size = ilog2(nix->rss_sz) / 256; + nix_af_reg_write(nix_af, NIXX_AF_LFX_RSS_CFG(nix->lf), rss_cfg.u); + + for (index = 0; index < nix->rss_grps; index++) { + rss_grp.u = 0; + rss_grp.s.sizem1 = 0x7; + rss_grp.s.offset = nix->rss_sz * index; + nix_af_reg_write(nix_af, + NIXX_AF_LFX_RSS_GRPX(nix->lf, index), + rss_grp.u); + } + + /* Config CQints HW contexts and base */ + nix_af_reg_write(nix_af, NIXX_AF_LFX_CINTS_BASE(nix->lf), + (u64)nix->cint_base); + cints_cfg.u = nix_af_reg_read(nix_af, + NIXX_AF_LFX_CINTS_CFG(nix->lf)); + cints_cfg.s.caching = 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_CINTS_CFG(nix->lf), + cints_cfg.u); + + /* Config Qints HW context and base */ + nix_af_reg_write(nix_af, NIXX_AF_LFX_QINTS_BASE(nix->lf), + (u64)nix->qint_base); + qints_cfg.u = nix_af_reg_read(nix_af, + NIXX_AF_LFX_QINTS_CFG(nix->lf)); + qints_cfg.s.caching = 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_QINTS_CFG(nix->lf), + qints_cfg.u); + + debug("%s(%p, %d, %d)\n", __func__, nix_af, nix->lf, nix->pf); + + /* Enable LMTST for this NIX LF */ + tx_cfg2.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_TX_CFG2(nix->lf)); + tx_cfg2.s.lmt_ena = 1; + nix_af_reg_write(nix_af, NIXX_AF_LFX_TX_CFG2(nix->lf), tx_cfg2.u); + + /* Use 16-word XQEs, write the npa pf_func number only */ + lfx_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_CFG(nix->lf)); + lfx_cfg.s.xqe_size = NIX_XQESZ_E_W16; + lfx_cfg.s.npa_pf_func = nix->pf_func; + nix_af_reg_write(nix_af, NIXX_AF_LFX_CFG(nix->lf), lfx_cfg.u); + + nix_af_reg_write(nix_af, NIXX_AF_LFX_RX_CFG(nix->lf), 0); + + for (index = 0; index < nix->cq_cnt; index++) { + err = nix_attach_completion_queue(nix, index); + if (err) { + printf("%s: Error attaching completion queue %d\n", + __func__, index); + return err; + } + } + + for (index = 0; index < nix->rq_cnt; index++) { + err = nix_attach_receive_queue(nix_af, nix->lf); + if (err) { + printf("%s: Error attaching receive queue %d\n", + __func__, index); + return err; + } + } + + for (index = 0; index < nix->sq_cnt; index++) { + err = nix_attach_send_queue(nix); + if (err) { + printf("%s: Error attaching send queue %d\n", + __func__, index); + return err; + } + } + + return 0; +} + +int nix_lf_admin_shutdown(struct nix_af *nix_af, int lf, + u32 cq_count, u32 rq_count, u32 sq_count) +{ + union nixx_af_rx_sw_sync sw_sync; + union nixx_af_lf_rst lf_rst; + int index, err; + + /* Flush all tx packets */ + sw_sync.u = 0; + sw_sync.s.ena = 1; + nix_af_reg_write(nix_af, NIXX_AF_RX_SW_SYNC(), sw_sync.u); + + do { + sw_sync.u = nix_af_reg_read(nix_af, NIXX_AF_RX_SW_SYNC()); + WATCHDOG_RESET(); + } while (sw_sync.s.ena); + + for (index = 0; index < rq_count; index++) { + memset((void *)&rq_dis, 0, sizeof(rq_dis)); + rq_dis.rq.s.ena = 0; /* Context */ + rq_dis.mrq.s.ena = 1; /* Mask */ + __iowmb(); + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_WRITE, + NIX_AQ_CTYPE_E_RQ, + index, &rq_dis.resp); + if (err) { + printf("%s: Error disabling LF %d RQ(%d)\n", + __func__, lf, index); + return err; + } + debug("%s: LF %d RQ(%d) disabled\n", __func__, lf, index); + } + + for (index = 0; index < sq_count; index++) { + memset((void *)&sq_dis, 0, sizeof(sq_dis)); + sq_dis.sq.s.ena = 0; /* Context */ + sq_dis.msq.s.ena = 1; /* Mask */ + __iowmb(); + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_WRITE, + NIX_AQ_CTYPE_E_SQ, + index, &sq_dis.resp); + if (err) { + printf("%s: Error disabling LF %d SQ(%d)\n", + __func__, lf, index); + return err; + } + debug("%s: LF %d SQ(%d) disabled\n", __func__, lf, index); + } + + for (index = 0; index < cq_count; index++) { + memset((void *)&cq_dis, 0, sizeof(cq_dis)); + cq_dis.cq.s.ena = 0; /* Context */ + cq_dis.mcq.s.ena = 1; /* Mask */ + __iowmb(); + + err = nix_aq_issue_command(nix_af, lf, + NIX_AQ_INSTOP_E_WRITE, + NIX_AQ_CTYPE_E_CQ, + index, &cq_dis.resp); + if (err) { + printf("%s: Error disabling LF %d CQ(%d)\n", + __func__, lf, index); + return err; + } + debug("%s: LF %d CQ(%d) disabled\n", __func__, lf, index); + } + + /* Reset the LF */ + lf_rst.u = 0; + lf_rst.s.lf = lf; + lf_rst.s.exec = 1; + nix_af_reg_write(nix_af, NIXX_AF_LF_RST(), lf_rst.u); + + do { + lf_rst.u = nix_af_reg_read(nix_af, NIXX_AF_LF_RST()); + WATCHDOG_RESET(); + } while (lf_rst.s.exec); + + return 0; +} + +int npc_lf_admin_setup(struct nix *nix) +{ + union npc_af_const af_const; + union npc_af_pkindx_action0 action0; + union npc_af_pkindx_action1 action1; + union npc_af_intfx_kex_cfg kex_cfg; + union npc_af_intfx_miss_stat_act intfx_stat_act; + union npc_af_mcamex_bankx_camx_intf camx_intf; + union npc_af_mcamex_bankx_camx_w0 camx_w0; + union npc_af_mcamex_bankx_cfg bankx_cfg; + union npc_af_mcamex_bankx_stat_act mcamex_stat_act; + + union nix_rx_action_s rx_action; + union nix_tx_action_s tx_action; + + struct nix_af *nix_af = nix->nix_af; + u32 kpus; + int pkind = nix->lmac->link_num; + int index; + u64 offset; + + debug("%s(%p, pkind 0x%x)\n", __func__, nix_af, pkind); + af_const.u = npc_af_reg_read(nix_af, NPC_AF_CONST()); + kpus = af_const.s.kpus; + + action0.u = 0; + action0.s.parse_done = 1; + npc_af_reg_write(nix_af, NPC_AF_PKINDX_ACTION0(pkind), action0.u); + + action1.u = 0; + npc_af_reg_write(nix_af, NPC_AF_PKINDX_ACTION1(pkind), action1.u); + + kex_cfg.u = 0; + kex_cfg.s.keyw = NPC_MCAMKEYW_E_X1; + kex_cfg.s.parse_nibble_ena = 0x7; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_KEX_CFG(NPC_INTF_E_NIXX_RX(0)), + kex_cfg.u); + + /* HW Issue */ + kex_cfg.u = 0; + kex_cfg.s.parse_nibble_ena = 0x7; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_KEX_CFG(NPC_INTF_E_NIXX_TX(0)), + kex_cfg.u); + + camx_intf.u = 0; + camx_intf.s.intf = ~NPC_INTF_E_NIXX_RX(0); + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_INTF(pkind, 0, 0), + camx_intf.u); + + camx_intf.u = 0; + camx_intf.s.intf = NPC_INTF_E_NIXX_RX(0); + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_INTF(pkind, 0, 1), + camx_intf.u); + + camx_w0.u = 0; + camx_w0.s.md = ~(nix->lmac->chan_num) & (~((~0x0ull) << 12)); + debug("NPC LF ADMIN camx_w0.u %llx\n", camx_w0.u); + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_W0(pkind, 0, 0), + camx_w0.u); + + camx_w0.u = 0; + camx_w0.s.md = nix->lmac->chan_num; + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_CAMX_W0(pkind, 0, 1), + camx_w0.u); + + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CAMX_W1(pkind, 0, 0), + 0); + + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CAMX_W1(pkind, 0, 1), + 0); + + /* Enable stats for NPC INTF RX */ + mcamex_stat_act.u = 0; + mcamex_stat_act.s.ena = 1; + mcamex_stat_act.s.stat_sel = pkind; + npc_af_reg_write(nix_af, + NPC_AF_MCAMEX_BANKX_STAT_ACT(pkind, 0), + mcamex_stat_act.u); + intfx_stat_act.u = 0; + intfx_stat_act.s.ena = 1; + intfx_stat_act.s.stat_sel = 16; + offset = NPC_AF_INTFX_MISS_STAT_ACT(NPC_INTF_E_NIXX_RX(0)); + npc_af_reg_write(nix_af, offset, intfx_stat_act.u); + rx_action.u = 0; + rx_action.s.pf_func = nix->pf_func; + rx_action.s.op = NIX_RX_ACTIONOP_E_UCAST; + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_ACTION(pkind, 0), + rx_action.u); + + for (index = 0; index < kpus; index++) + npc_af_reg_write(nix_af, NPC_AF_KPUX_CFG(index), 0); + + rx_action.u = 0; + rx_action.s.pf_func = nix->pf_func; + rx_action.s.op = NIX_RX_ACTIONOP_E_DROP; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_MISS_ACT(NPC_INTF_E_NIXX_RX(0)), + rx_action.u); + bankx_cfg.u = 0; + bankx_cfg.s.ena = 1; + npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CFG(pkind, 0), + bankx_cfg.u); + + tx_action.u = 0; + tx_action.s.op = NIX_TX_ACTIONOP_E_UCAST_DEFAULT; + npc_af_reg_write(nix_af, + NPC_AF_INTFX_MISS_ACT(NPC_INTF_E_NIXX_TX(0)), + tx_action.u); + +#ifdef DEBUG + /* Enable debug capture on RX intf */ + npc_af_reg_write(nix_af, NPC_AF_DBG_CTL(), 0x4); +#endif + + return 0; +} + +int npc_af_shutdown(struct nix_af *nix_af) +{ + union npc_af_blk_rst blk_rst; + + blk_rst.u = 0; + blk_rst.s.rst = 1; + npc_af_reg_write(nix_af, NPC_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = npc_af_reg_read(nix_af, NPC_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + debug("%s: npc af reset --\n", __func__); + + return 0; +} + +int nix_af_setup(struct nix_af *nix_af) +{ + int err; + union nixx_af_const2 af_const2; + union nixx_af_const3 af_const3; + union nixx_af_sq_const sq_const; + union nixx_af_cfg af_cfg; + union nixx_af_status af_status; + union nixx_af_ndc_cfg ndc_cfg; + union nixx_af_aq_cfg aq_cfg; + union nixx_af_blk_rst blk_rst; + + debug("%s(%p)\n", __func__, nix_af); + err = rvu_aq_alloc(&nix_af->aq, Q_COUNT(AQ_SIZE), + sizeof(union nix_aq_inst_s), + sizeof(union nix_aq_res_s)); + if (err) { + printf("%s: Error allocating nix admin queue\n", __func__); + return err; + } + + blk_rst.u = 0; + blk_rst.s.rst = 1; + nix_af_reg_write(nix_af, NIXX_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = nix_af_reg_read(nix_af, NIXX_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + /* Put in LE mode */ + af_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_CFG()); + if (af_cfg.s.force_cond_clk_en || af_cfg.s.calibrate_x2p || + af_cfg.s.force_intf_clk_en) { + printf("%s: Error: Invalid NIX_AF_CFG value 0x%llx\n", + __func__, af_cfg.u); + return -1; + } + af_cfg.s.af_be = 0; + af_cfg.u |= 0x5E; /* HW Issue */ + nix_af_reg_write(nix_af, NIXX_AF_CFG(), af_cfg.u); + + /* Perform Calibration */ + af_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_CFG()); + af_cfg.s.calibrate_x2p = 1; + nix_af_reg_write(nix_af, NIXX_AF_CFG(), af_cfg.u); + + /* Wait for calibration to complete */ + do { + af_status.u = nix_af_reg_read(nix_af, NIXX_AF_STATUS()); + WATCHDOG_RESET(); + } while (af_status.s.calibrate_done == 0); + + af_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_CFG()); + af_cfg.s.calibrate_x2p = 0; + nix_af_reg_write(nix_af, NIXX_AF_CFG(), af_cfg.u); + + /* Enable NDC cache */ + ndc_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_NDC_CFG()); + ndc_cfg.s.ndc_ign_pois = 0; + ndc_cfg.s.byp_sq = 0; + ndc_cfg.s.byp_sqb = 0; + ndc_cfg.s.byp_cqs = 0; + ndc_cfg.s.byp_cints = 0; + ndc_cfg.s.byp_dyno = 0; + ndc_cfg.s.byp_mce = 0; + ndc_cfg.s.byp_rqc = 0; + ndc_cfg.s.byp_rsse = 0; + ndc_cfg.s.byp_mc_data = 0; + ndc_cfg.s.byp_mc_wqe = 0; + ndc_cfg.s.byp_mr_data = 0; + ndc_cfg.s.byp_mr_wqe = 0; + ndc_cfg.s.byp_qints = 0; + nix_af_reg_write(nix_af, NIXX_AF_NDC_CFG(), ndc_cfg.u); + + /* Set up queue size */ + aq_cfg.u = 0; + aq_cfg.s.qsize = AQ_SIZE; + nix_af_reg_write(nix_af, NIXX_AF_AQ_CFG(), aq_cfg.u); + + /* Set up queue base address */ + nix_af_reg_write(nix_af, NIXX_AF_AQ_BASE(), nix_af->aq.inst.iova); + + af_const3.u = nix_af_reg_read(nix_af, NIXX_AF_CONST3()); + af_const2.u = nix_af_reg_read(nix_af, NIXX_AF_CONST2()); + sq_const.u = nix_af_reg_read(nix_af, NIXX_AF_SQ_CONST()); + nix_af->rq_ctx_sz = 1ULL << af_const3.s.rq_ctx_log2bytes; + nix_af->sq_ctx_sz = 1ULL << af_const3.s.sq_ctx_log2bytes; + nix_af->cq_ctx_sz = 1ULL << af_const3.s.cq_ctx_log2bytes; + nix_af->rsse_ctx_sz = 1ULL << af_const3.s.rsse_log2bytes; + nix_af->qints = af_const2.s.qints; + nix_af->cints = af_const2.s.cints; + nix_af->cint_ctx_sz = 1ULL << af_const3.s.cint_log2bytes; + nix_af->qint_ctx_sz = 1ULL << af_const3.s.qint_log2bytes; + nix_af->sqb_size = sq_const.s.sqb_size; + + return 0; +} + +int nix_af_shutdown(struct nix_af *nix_af) +{ + union nixx_af_blk_rst blk_rst; + + blk_rst.u = 0; + blk_rst.s.rst = 1; + nix_af_reg_write(nix_af, NIXX_AF_BLK_RST(), blk_rst.u); + + /* Wait for reset to complete */ + do { + blk_rst.u = nix_af_reg_read(nix_af, NIXX_AF_BLK_RST()); + WATCHDOG_RESET(); + } while (blk_rst.s.busy); + + rvu_aq_free(&nix_af->aq); + + debug("%s: nix af reset --\n", __func__); + + return 0; +} diff --git a/drivers/net/octeontx2/npc.h b/drivers/net/octeontx2/npc.h new file mode 100644 index 0000000000..6e645cd32e --- /dev/null +++ b/drivers/net/octeontx2/npc.h @@ -0,0 +1,90 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef __NPC_H__ +#define __NPC_H__ + +#define RSVD_MCAM_ENTRIES_PER_PF 2 /** Ucast and Bcast */ +#define RSVD_MCAM_ENTRIES_PER_NIXLF 1 /** Ucast for VFs */ + +struct npc_kpu_profile_cam { + u8 state; + u8 state_mask; + u16 dp0; + u16 dp0_mask; + u16 dp1; + u16 dp1_mask; + u16 dp2; + u16 dp2_mask; +}; + +struct npc_kpu_profile_action { + u8 errlev; + u8 errcode; + u8 dp0_offset; + u8 dp1_offset; + u8 dp2_offset; + u8 bypass_count; + u8 parse_done; + u8 next_state; + u8 ptr_advance; + u8 cap_ena; + u8 lid; + u8 ltype; + u8 flags; + u8 offset; + u8 mask; + u8 right; + u8 shift; +}; + +struct npc_kpu_profile { + int cam_entries; + int action_entries; + struct npc_kpu_profile_cam *cam; + struct npc_kpu_profile_action *action; +}; + +struct npc_pkind { + struct rsrc_bmap rsrc; + u32 *pfchan_map; +}; + +struct npc_mcam { + struct rsrc_bmap rsrc; + u16 *pfvf_map; + u16 total_entries; /* Total number of MCAM entries */ + u16 entries; /* Total - reserved for NIX LFs */ + u8 banks_per_entry; /* Number of keywords in key */ + u8 keysize; + u8 banks; /* Number of MCAM banks */ + u16 banksize; /* Number of MCAM entries in each bank */ + u16 counters; /* Number of match counters */ + u16 nixlf_offset; + u16 pf_offset; +}; + +struct nix_af_handle; +struct nix_handle; +struct rvu_hwinfo; + +struct npc_af { + struct nix_af_handle *nix_af; + struct npc_pkind pkind; + void __iomem *npc_af_base; + u8 npc_kpus; /** Number of parser units */ + struct npc_mcam mcam; + struct rvu_block block; + struct rvu_hwinfo *hw; +}; + +struct npc { + struct npc_af *npc_af; + void __iomem *npc_base; + struct nix_handle *nix; +} + +#endif /* __NPC_H__ */ + diff --git a/drivers/net/octeontx2/rvu.h b/drivers/net/octeontx2/rvu.h new file mode 100644 index 0000000000..f455260a6f --- /dev/null +++ b/drivers/net/octeontx2/rvu.h @@ -0,0 +1,119 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef __RVU_H__ +#define __RVU_H__ + +#include <asm/arch/csrs/csrs-rvu.h> + +#define ALIGNED __aligned(CONFIG_SYS_CACHELINE_SIZE) + +#define Q_SIZE_16 0ULL /* 16 entries */ +#define Q_SIZE_64 1ULL /* 64 entries */ +#define Q_SIZE_256 2ULL +#define Q_SIZE_1K 3ULL +#define Q_SIZE_4K 4ULL +#define Q_SIZE_16K 5ULL +#define Q_SIZE_64K 6ULL +#define Q_SIZE_256K 7ULL +#define Q_SIZE_1M 8ULL /* Million entries */ +#define Q_SIZE_MIN Q_SIZE_16 +#define Q_SIZE_MAX Q_SIZE_1M + +#define Q_COUNT(x) (16ULL << (2 * (x))) +#define Q_SIZE(x, n) ((ilog2(x) - (n)) / 2) + +/* Admin queue info */ + +/* Since we intend to add only one instruction at a time, + * keep queue size to it's minimum. + */ +#define AQ_SIZE Q_SIZE_16 +/* HW head & tail pointer mask */ +#define AQ_PTR_MASK 0xFFFFF + +struct qmem { + void *base; + dma_addr_t iova; + size_t alloc_sz; + u32 qsize; + u8 entry_sz; +}; + +struct admin_queue { + struct qmem inst; + struct qmem res; +}; + +struct rvu_af { + struct udevice *dev; + void __iomem *af_base; + struct nix_af *nix_af; +}; + +struct rvu_pf { + struct udevice *dev; + struct udevice *afdev; + void __iomem *pf_base; + struct nix *nix; + u8 pfid; + int nix_lfid; + int npa_lfid; +}; + +/** + * Store 128 bit value + * + * @param[out] dest pointer to destination address + * @param val0 first 64 bits to write + * @param val1 second 64 bits to write + */ +static inline void st128(void *dest, u64 val0, u64 val1) +{ + __asm__ __volatile__("stp %x[x0], %x[x1], [%[pm]]" : + : [x0]"r"(val0), [x1]"r"(val1), [pm]"r"(dest) + : "memory"); +} + +/** + * Load 128 bit value + * + * @param[in] source pointer to 128 bits of data to load + * @param[out] val0 first 64 bits of data + * @param[out] val1 second 64 bits of data + */ +static inline void ld128(const u64 *src, u64 *val0, u64 *val1) +{ + __asm__ __volatile__ ("ldp %x[x0], %x[x1], [%[pm]]" : + : [x0]"r"(*val0), [x1]"r"(*val1), [pm]"r"(src)); +} + +void qmem_free(struct qmem *q); +int qmem_alloc(struct qmem *q, u32 qsize, size_t entry_sz); + +/** + * Allocates an admin queue for instructions and results + * + * @param aq admin queue to allocate for + * @param qsize Number of entries in the queue + * @param inst_size Size of each instruction + * @param res_size Size of each result + * + * @return -ENOMEM on error, 0 on success + */ +int rvu_aq_alloc(struct admin_queue *aq, unsigned int qsize, + size_t inst_size, size_t res_size); + +/** + * Frees an admin queue + * + * @param aq Admin queue to free + */ +void rvu_aq_free(struct admin_queue *aq); + +void rvu_get_lfid_for_pf(int pf, int *nixid, int *npaid); + +#endif /* __RVU_H__ */ + diff --git a/drivers/net/octeontx2/rvu_af.c b/drivers/net/octeontx2/rvu_af.c new file mode 100644 index 0000000000..7750089a20 --- /dev/null +++ b/drivers/net/octeontx2/rvu_af.c @@ -0,0 +1,171 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <linux/list.h> +#include <asm/io.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-npa.h> + +#include "nix.h" + +struct udevice *rvu_af_dev; + +inline struct rvu_af *get_af(void) +{ + return rvu_af_dev ? dev_get_priv(rvu_af_dev) : NULL; +} + +void rvu_get_lfid_for_pf(int pf, int *nixid, int *npaid) +{ + union nixx_af_rvu_lf_cfg_debug nix_lf_dbg; + union npa_af_rvu_lf_cfg_debug npa_lf_dbg; + union rvu_pf_func_s pf_func; + struct rvu_af *af = dev_get_priv(rvu_af_dev); + struct nix_af *nix_af = af->nix_af; + + pf_func.u = 0; + pf_func.s.pf = pf; + + nix_lf_dbg.u = 0; + nix_lf_dbg.s.pf_func = pf_func.u & 0xFFFF; + nix_lf_dbg.s.exec = 1; + nix_af_reg_write(nix_af, NIXX_AF_RVU_LF_CFG_DEBUG(), + nix_lf_dbg.u); + do { + nix_lf_dbg.u = nix_af_reg_read(nix_af, + NIXX_AF_RVU_LF_CFG_DEBUG()); + } while (nix_lf_dbg.s.exec); + + if (nix_lf_dbg.s.lf_valid) + *nixid = nix_lf_dbg.s.lf; + + debug("%s: nix lf_valid %d lf %d nixid %d\n", __func__, + nix_lf_dbg.s.lf_valid, nix_lf_dbg.s.lf, *nixid); + + npa_lf_dbg.u = 0; + npa_lf_dbg.s.pf_func = pf_func.u & 0xFFFF; + npa_lf_dbg.s.exec = 1; + npa_af_reg_write(nix_af->npa_af, NPA_AF_RVU_LF_CFG_DEBUG(), + npa_lf_dbg.u); + do { + npa_lf_dbg.u = npa_af_reg_read(nix_af->npa_af, + NPA_AF_RVU_LF_CFG_DEBUG()); + } while (npa_lf_dbg.s.exec); + + if (npa_lf_dbg.s.lf_valid) + *npaid = npa_lf_dbg.s.lf; + debug("%s: npa lf_valid %d lf %d npaid %d\n", __func__, + npa_lf_dbg.s.lf_valid, npa_lf_dbg.s.lf, *npaid); +} + +struct nix_af *rvu_af_init(struct rvu_af *rvu_af) +{ + struct nix_af *nix_af; + union rvu_af_addr_s block_addr; + int err; + + nix_af = (struct nix_af *)calloc(1, sizeof(struct nix_af)); + if (!nix_af) { + printf("%s: out of memory\n", __func__); + goto error; + } + + nix_af->dev = rvu_af->dev; + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NIXX(0); + nix_af->nix_af_base = rvu_af->af_base + block_addr.u; + + nix_af->npa_af = (struct npa_af *)calloc(1, sizeof(struct npa_af)); + if (!nix_af->npa_af) { + printf("%s: out of memory\n", __func__); + goto error; + } + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPA; + nix_af->npa_af->npa_af_base = rvu_af->af_base + block_addr.u; + + block_addr.u = 0; + block_addr.s.block = RVU_BLOCK_ADDR_E_NPC; + nix_af->npc_af_base = rvu_af->af_base + block_addr.u; + + debug("%s: Setting up npa admin\n", __func__); + err = npa_af_setup(nix_af->npa_af); + if (err) { + printf("%s: Error %d setting up NPA admin\n", __func__, err); + goto error; + } + debug("%s: Setting up nix af\n", __func__); + err = nix_af_setup(nix_af); + if (err) { + printf("%s: Error %d setting up NIX admin\n", __func__, err); + goto error; + } + debug("%s: nix_af: %p\n", __func__, nix_af); + return nix_af; + +error: + if (nix_af->npa_af) { + free(nix_af->npa_af); + memset(nix_af, 0, sizeof(*nix_af)); + } + if (nix_af) + free(nix_af); + return NULL; +} + +int rvu_af_probe(struct udevice *dev) +{ + struct rvu_af *af_ptr = dev_get_priv(dev); + + af_ptr->af_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + debug("%s RVU AF BAR %p\n", __func__, af_ptr->af_base); + af_ptr->dev = dev; + rvu_af_dev = dev; + + af_ptr->nix_af = rvu_af_init(af_ptr); + if (!af_ptr->nix_af) { + printf("%s: Error: could not initialize NIX AF\n", __func__); + return -1; + } + debug("%s: Done\n", __func__); + + return 0; +} + +int rvu_af_remove(struct udevice *dev) +{ + struct rvu_af *rvu_af = dev_get_priv(dev); + + nix_af_shutdown(rvu_af->nix_af); + npa_af_shutdown(rvu_af->nix_af->npa_af); + npc_af_shutdown(rvu_af->nix_af); + + debug("%s: rvu af down --\n", __func__); + return 0; +} + +U_BOOT_DRIVER(rvu_af) = { + .name = "rvu_af", + .id = UCLASS_MISC, + .probe = rvu_af_probe, + .remove = rvu_af_remove, + .priv_auto_alloc_size = sizeof(struct rvu_af), +}; + +static struct pci_device_id rvu_af_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_RVU_AF) }, + {} +}; + +U_BOOT_PCI_DEVICE(rvu_af, rvu_af_supported); diff --git a/drivers/net/octeontx2/rvu_common.c b/drivers/net/octeontx2/rvu_common.c new file mode 100644 index 0000000000..173b28ba4b --- /dev/null +++ b/drivers/net/octeontx2/rvu_common.c @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <asm/io.h> + +#include "rvu.h" + +int qmem_alloc(struct qmem *q, u32 qsize, size_t entry_sz) +{ + q->base = memalign(CONFIG_SYS_CACHELINE_SIZE, qsize * entry_sz); + if (!q->base) + return -ENOMEM; + q->entry_sz = entry_sz; + q->qsize = qsize; + q->alloc_sz = (size_t)qsize * entry_sz; + q->iova = (dma_addr_t)(q->base); + debug("NIX: qmem alloc for (%d * %d = %ld bytes) at %p\n", + q->qsize, q->entry_sz, q->alloc_sz, q->base); + return 0; +} + +void qmem_free(struct qmem *q) +{ + if (q->base) + free(q->base); + memset(q, 0, sizeof(*q)); +} + +/** + * Allocates an admin queue for instructions and results + * + * @param aq admin queue to allocate for + * @param qsize Number of entries in the queue + * @param inst_size Size of each instruction + * @param res_size Size of each result + * + * @return -ENOMEM on error, 0 on success + */ +int rvu_aq_alloc(struct admin_queue *aq, unsigned int qsize, + size_t inst_size, size_t res_size) +{ + int err; + + err = qmem_alloc(&aq->inst, qsize, inst_size); + if (err) + return err; + err = qmem_alloc(&aq->res, qsize, res_size); + if (err) + qmem_free(&aq->inst); + + return err; +} + +/** + * Frees an admin queue + * + * @param aq Admin queue to free + */ +void rvu_aq_free(struct admin_queue *aq) +{ + qmem_free(&aq->inst); + qmem_free(&aq->res); + memset(aq, 0, sizeof(*aq)); +} diff --git a/drivers/net/octeontx2/rvu_pf.c b/drivers/net/octeontx2/rvu_pf.c new file mode 100644 index 0000000000..201ecf2c16 --- /dev/null +++ b/drivers/net/octeontx2/rvu_pf.c @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/arch/board.h> +#include "cgx.h" +#include "nix.h" + +extern struct udevice *rvu_af_dev; + +int rvu_pf_init(struct rvu_pf *rvu) +{ + struct nix *nix; + struct eth_pdata *pdata = dev_get_platdata(rvu->dev); + + debug("%s: Allocating nix lf\n", __func__); + nix = nix_lf_alloc(rvu->dev); + if (!nix) { + printf("%s: Error allocating lf for pf %d\n", + __func__, rvu->pfid); + return -1; + } + rvu->nix = nix; + + /* to make post_probe happy */ + if (is_valid_ethaddr(nix->lmac->mac_addr)) { + memcpy(pdata->enetaddr, nix->lmac->mac_addr, 6); + eth_env_set_enetaddr_by_index("eth", rvu->dev->seq, + pdata->enetaddr); + } + + return 0; +} + +static const struct eth_ops nix_eth_ops = { + .start = nix_lf_init, + .send = nix_lf_xmit, + .recv = nix_lf_recv, + .free_pkt = nix_lf_free_pkt, + .stop = nix_lf_halt, + .write_hwaddr = nix_lf_setup_mac, +}; + +int rvu_pf_probe(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + int err; + char name[16]; + + debug("%s: name: %s\n", __func__, dev->name); + + rvu->pf_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_2, PCI_REGION_MEM); + rvu->pfid = dev->seq + 1; // RVU PF's start from 1; + rvu->dev = dev; + if (!rvu_af_dev) { + printf("%s: Error: Could not find RVU AF device\n", + __func__); + return -1; + } + rvu->afdev = rvu_af_dev; + + debug("RVU PF %u BAR2 %p\n", rvu->pfid, rvu->pf_base); + + rvu_get_lfid_for_pf(rvu->pfid, &rvu->nix_lfid, &rvu->npa_lfid); + + err = rvu_pf_init(rvu); + if (err) + printf("%s: Error %d adding nix\n", __func__, err); + + /* + * modify device name to include index/sequence number, + * for better readability, this is 1:1 mapping with eth0/1/2.. names. + */ + sprintf(name, "rvu_pf#%d", dev->seq); + device_set_name(dev, name); + debug("%s: name: %s\n", __func__, dev->name); + return err; +} + +int rvu_pf_remove(struct udevice *dev) +{ + struct rvu_pf *rvu = dev_get_priv(dev); + + nix_lf_shutdown(rvu->nix); + npa_lf_shutdown(rvu->nix); + + debug("%s: rvu pf%d down --\n", __func__, rvu->pfid); + + return 0; +} + +U_BOOT_DRIVER(rvu_pf) = { + .name = "rvu_pf", + .id = UCLASS_ETH, + .probe = rvu_pf_probe, + .remove = rvu_pf_remove, + .ops = &nix_eth_ops, + .priv_auto_alloc_size = sizeof(struct rvu_pf), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +static struct pci_device_id rvu_pf_supported[] = { + { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_RVU_PF) }, + {} +}; + +U_BOOT_PCI_DEVICE(rvu_pf, rvu_pf_supported);
On 26.08.20 14:37, Stefan Roese wrote:
Adds support for Network Interface controllers found on OcteonTX2 SoC platforms.
Signed-off-by: Suneel Garapati sgarapati@marvell.com Signed-off-by: Stefan Roese sr@denx.de Cc: Joe Hershberger joe.hershberger@ni.com
Series-changes: 3
- Add SoB from Stefan
- Remove spdx.org line from comment
- Remove inclusion of common.h header
- Order header file inclusion
- Misc minor checkpatch fixes
Series-changes: 1
- Change patch subject
- Rebased on latest TOT
- Removed inclusion of common.h
Applied to u-boot-marvell/master
Thanks, Stefan
drivers/net/Kconfig | 17 + drivers/net/Makefile | 2 + drivers/net/octeontx2/Makefile | 8 + drivers/net/octeontx2/cgx.c | 296 ++++++++ drivers/net/octeontx2/cgx.h | 105 +++ drivers/net/octeontx2/cgx_intf.c | 715 ++++++++++++++++++ drivers/net/octeontx2/cgx_intf.h | 448 +++++++++++ drivers/net/octeontx2/lmt.h | 49 ++ drivers/net/octeontx2/nix.c | 831 +++++++++++++++++++++ drivers/net/octeontx2/nix.h | 353 +++++++++ drivers/net/octeontx2/nix_af.c | 1102 ++++++++++++++++++++++++++++ drivers/net/octeontx2/npc.h | 90 +++ drivers/net/octeontx2/rvu.h | 119 +++ drivers/net/octeontx2/rvu_af.c | 171 +++++ drivers/net/octeontx2/rvu_common.c | 71 ++ drivers/net/octeontx2/rvu_pf.c | 116 +++ 16 files changed, 4493 insertions(+) create mode 100644 drivers/net/octeontx2/Makefile create mode 100644 drivers/net/octeontx2/cgx.c create mode 100644 drivers/net/octeontx2/cgx.h create mode 100644 drivers/net/octeontx2/cgx_intf.c create mode 100644 drivers/net/octeontx2/cgx_intf.h create mode 100644 drivers/net/octeontx2/lmt.h create mode 100644 drivers/net/octeontx2/nix.c create mode 100644 drivers/net/octeontx2/nix.h create mode 100644 drivers/net/octeontx2/nix_af.c create mode 100644 drivers/net/octeontx2/npc.h create mode 100644 drivers/net/octeontx2/rvu.h create mode 100644 drivers/net/octeontx2/rvu_af.c create mode 100644 drivers/net/octeontx2/rvu_common.c create mode 100644 drivers/net/octeontx2/rvu_pf.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 26ea53d346..6e758f5581 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -414,6 +414,15 @@ config NET_OCTEONTX help You must select Y to enable network device support for OcteonTX SoCs. If unsure, say n
+config NET_OCTEONTX2
- bool "OcteonTX2 Ethernet support"
- depends on ARCH_OCTEONTX2
- select OCTEONTX2_CGX_INTF
- help
OcteonTX2 SoCs. If unsure, say n
- config OCTEONTX_SMI bool "OcteonTX SMI Device support" depends on ARCH_OCTEONTX || ARCH_OCTEONTX2
@@ -421,6 +430,14 @@ config OCTEONTX_SMI You must select Y to enable SMI controller support for OcteonTX or OcteonTX2 SoCs. If unsure, say n
+config OCTEONTX2_CGX_INTF
- bool "OcteonTX2 CGX ATF interface support"
- default y if ARCH_OCTEONTX2
- help
You must select Y to enable CGX ATF interface support for
- config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" depends on DM_ETH && DM_PCI
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index bee9680f76..c07b5ad698 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -66,7 +66,9 @@ obj-$(CONFIG_SMC91111) += smc91111.o obj-$(CONFIG_SMC911X) += smc911x.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o obj-$(CONFIG_NET_OCTEONTX) += octeontx/ +obj-$(CONFIG_NET_OCTEONTX2) += octeontx2/ obj-$(CONFIG_OCTEONTX_SMI) += octeontx/smi.o +obj-$(CONFIG_OCTEONTX2_CGX_INTF) += octeontx2/cgx_intf.o obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o obj-$(CONFIG_ULI526X) += uli526x.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o diff --git a/drivers/net/octeontx2/Makefile b/drivers/net/octeontx2/Makefile new file mode 100644 index 0000000000..c9300727ae --- /dev/null +++ b/drivers/net/octeontx2/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Copyright (C) 2018 Marvell International Ltd. +#
+obj-$(CONFIG_NET_OCTEONTX2) += cgx.o nix_af.o nix.o rvu_pf.o \
rvu_af.o rvu_common.o
diff --git a/drivers/net/octeontx2/cgx.c b/drivers/net/octeontx2/cgx.c new file mode 100644 index 0000000000..ff2ebc25ce --- /dev/null +++ b/drivers/net/octeontx2/cgx.c @@ -0,0 +1,296 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright (C) 2018 Marvell International Ltd.
+#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <linux/list.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-cgx.h> +#include <asm/io.h>
+#include "cgx.h"
+char lmac_type_to_str[][8] = {
- "SGMII",
- "XAUI",
- "RXAUI",
- "10G_R",
- "40G_R",
- "RGMII",
- "QSGMII",
- "25G_R",
- "50G_R",
- "100G_R",
- "USXGMII",
+char lmac_speed_to_str[][8] = {
- "0",
- "10M",
- "100M",
- "1G",
- "2.5G",
- "5G",
- "10G",
- "20G",
- "25G",
- "40G",
- "50G",
- "80G",
- "100G",
- Given an LMAC/PF instance number, return the lmac
- Per design, each PF has only one LMAC mapped.
- @param instance instance to find
- @return pointer to lmac data structure or NULL if not found
+struct lmac *nix_get_cgx_lmac(int lmac_instance) +{
- struct cgx *cgx;
- struct udevice *dev;
- int i, idx, err;
- for (i = 0; i < CGX_PER_NODE; i++) {
err = dm_pci_find_device(PCI_VENDOR_ID_CAVIUM,
PCI_DEVICE_ID_OCTEONTX2_CGX, i,
&dev);
if (err)
continue;
cgx = dev_get_priv(dev);
debug("%s udev %p cgx %p instance %d\n", __func__, dev, cgx,
lmac_instance);
for (idx = 0; idx < cgx->lmac_count; idx++) {
if (cgx->lmac[idx]->instance == lmac_instance)
return cgx->lmac[idx];
- return NULL;
+void cgx_lmac_mac_filter_clear(struct lmac *lmac) +{
- union cgxx_cmrx_rx_dmac_ctl0 dmac_ctl0;
- union cgxx_cmr_rx_dmacx_cam0 dmac_cam0;
- void *reg_addr;
- dmac_cam0.u = 0x0;
- reg_addr = lmac->cgx->reg_base +
CGXX_CMR_RX_DMACX_CAM0(lmac->lmac_id * 8);
- writeq(dmac_cam0.u, reg_addr);
- debug("%s: reg %p dmac_cam0 %llx\n", __func__, reg_addr, dmac_cam0.u);
- dmac_ctl0.u = 0x0;
- dmac_ctl0.s.bcst_accept = 1;
- dmac_ctl0.s.mcst_mode = 1;
- dmac_ctl0.s.cam_accept = 0;
CGXX_CMRX_RX_DMAC_CTL0(lmac->lmac_id);
- writeq(dmac_ctl0.u, reg_addr);
- debug("%s: reg %p dmac_ctl0 %llx\n", __func__, reg_addr, dmac_ctl0.u);
+void cgx_lmac_mac_filter_setup(struct lmac *lmac) +{
- u64 mac, tmp;
- void *reg_addr;
- memcpy((void *)&tmp, lmac->mac_addr, 6);
- debug("%s: tmp %llx\n", __func__, tmp);
- debug("%s: swab tmp %llx\n", __func__, swab64(tmp));
- mac = swab64(tmp) >> 16;
- debug("%s: mac %llx\n", __func__, mac);
- dmac_cam0.s.id = lmac->lmac_id;
- dmac_cam0.s.adr = mac;
- dmac_cam0.s.en = 1;
- dmac_ctl0.s.mcst_mode = 0;
- dmac_ctl0.s.cam_accept = 1;
+int cgx_lmac_set_pkind(struct lmac *lmac, u8 lmac_id, int pkind) +{
- cgx_write(lmac->cgx, lmac_id, CGXX_CMRX_RX_ID_MAP(0),
(pkind & 0x3f));
+int cgx_lmac_link_status(struct lmac *lmac, int lmac_id, u64 *status) +{
- int ret = 0;
- ret = cgx_intf_get_link_sts(lmac->cgx->cgx_id, lmac_id, status);
- if (ret) {
debug("%s request failed for cgx%d lmac%d\n",
__func__, lmac->cgx->cgx_id, lmac->lmac_id);
ret = -1;
- return ret;
+int cgx_lmac_rx_tx_enable(struct lmac *lmac, int lmac_id, bool enable) +{
- struct cgx *cgx = lmac->cgx;
- union cgxx_cmrx_config cmrx_config;
- if (!cgx || lmac_id >= cgx->lmac_count)
return -ENODEV;
- cmrx_config.u = cgx_read(cgx, lmac_id, CGXX_CMRX_CONFIG(0));
- cmrx_config.s.data_pkt_rx_en =
- cmrx_config.s.data_pkt_tx_en = enable ? 1 : 0;
- cgx_write(cgx, lmac_id, CGXX_CMRX_CONFIG(0), cmrx_config.u);
+int cgx_lmac_link_enable(struct lmac *lmac, int lmac_id, bool enable,
u64 *status)
- int ret = 0;
- ret = cgx_intf_link_up_dwn(lmac->cgx->cgx_id, lmac_id, enable,
status);
- if (ret) {
ret = -1;
- return ret;
+int cgx_lmac_internal_loopback(struct lmac *lmac, int lmac_id, bool enable) +{
- union cgxx_cmrx_config cmrx_cfg;
- union cgxx_gmp_pcs_mrx_control mrx_control;
- union cgxx_spux_control1 spux_control1;
- enum lmac_type lmac_type;
return -ENODEV;
- cmrx_cfg.u = cgx_read(cgx, lmac_id, CGXX_CMRX_CONFIG(0));
- lmac_type = cmrx_cfg.s.lmac_type;
- if (lmac_type == LMAC_MODE_SGMII || lmac_type == LMAC_MODE_QSGMII) {
mrx_control.u = cgx_read(cgx, lmac_id,
CGXX_GMP_PCS_MRX_CONTROL(0));
mrx_control.s.loopbck1 = enable ? 1 : 0;
cgx_write(cgx, lmac_id, CGXX_GMP_PCS_MRX_CONTROL(0),
mrx_control.u);
- } else {
spux_control1.u = cgx_read(cgx, lmac_id,
CGXX_SPUX_CONTROL1(0));
spux_control1.s.loopbck = enable ? 1 : 0;
cgx_write(cgx, lmac_id, CGXX_SPUX_CONTROL1(0),
spux_control1.u);
+static int cgx_lmac_init(struct cgx *cgx) +{
- struct lmac *lmac;
- static int instance = 1;
- int i;
- cgx->lmac_count = cgx_read(cgx, 0, CGXX_CMR_RX_LMACS());
- debug("%s: Found %d lmacs for cgx %d@%p\n", __func__, cgx->lmac_count,
cgx->cgx_id, cgx->reg_base);
- for (i = 0; i < cgx->lmac_count; i++) {
lmac = calloc(1, sizeof(*lmac));
if (!lmac)
return -ENOMEM;
lmac->instance = instance++;
snprintf(lmac->name, sizeof(lmac->name), "cgx_fwi_%d_%d",
cgx->cgx_id, i);
/* Get LMAC type */
cmrx_cfg.u = cgx_read(cgx, i, CGXX_CMRX_CONFIG(0));
lmac->lmac_type = cmrx_cfg.s.lmac_type;
lmac->lmac_id = i;
lmac->cgx = cgx;
cgx->lmac[i] = lmac;
debug("%s: map id %d to lmac %p (%s), type:%d instance %d\n",
__func__, i, lmac, lmac->name, lmac->lmac_type,
lmac->instance);
lmac->init_pend = 1;
printf("CGX%d LMAC%d [%s]\n", lmac->cgx->cgx_id,
lmac->lmac_id, lmac_type_to_str[lmac->lmac_type]);
octeontx2_board_get_mac_addr((lmac->instance - 1),
lmac->mac_addr);
debug("%s: MAC %pM\n", __func__, lmac->mac_addr);
cgx_lmac_mac_filter_setup(lmac);
+int cgx_probe(struct udevice *dev) +{
- struct cgx *cgx = dev_get_priv(dev);
- int err;
- cgx->reg_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0,
PCI_REGION_MEM);
- cgx->dev = dev;
- cgx->cgx_id = ((u64)(cgx->reg_base) >> 24) & 0x7;
- debug("%s CGX BAR %p, id: %d\n", __func__, cgx->reg_base,
cgx->cgx_id);
- debug("%s CGX %p, udev: %p\n", __func__, cgx, dev);
- err = cgx_lmac_init(cgx);
- return err;
+int cgx_remove(struct udevice *dev) +{
- int i;
- debug("%s: cgx remove reg_base %p cgx_id %d",
__func__, cgx->reg_base, cgx->cgx_id);
cgx_lmac_mac_filter_clear(cgx->lmac[i]);
+U_BOOT_DRIVER(cgx) = {
- .name = "cgx",
- .id = UCLASS_MISC,
- .probe = cgx_probe,
- .remove = cgx_remove,
- .priv_auto_alloc_size = sizeof(struct cgx),
+static struct pci_device_id cgx_supported[] = {
- {PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_CGX) },
+U_BOOT_PCI_DEVICE(cgx, cgx_supported); diff --git a/drivers/net/octeontx2/cgx.h b/drivers/net/octeontx2/cgx.h new file mode 100644 index 0000000000..f287692712 --- /dev/null +++ b/drivers/net/octeontx2/cgx.h @@ -0,0 +1,105 @@ +/* SPDX-License-Identifier: GPL-2.0
+#ifndef __CGX_H__ +#define __CGX_H__
+#include "cgx_intf.h"
+#define PCI_DEVICE_ID_OCTEONTX2_CGX 0xA059
+#define MAX_LMAC_PER_CGX 4 +#define CGX_PER_NODE 3
+enum lmac_type {
- LMAC_MODE_SGMII = 0,
- LMAC_MODE_XAUI = 1,
- LMAC_MODE_RXAUI = 2,
- LMAC_MODE_10G_R = 3,
- LMAC_MODE_40G_R = 4,
- LMAC_MODE_QSGMII = 6,
- LMAC_MODE_25G_R = 7,
- LMAC_MODE_50G_R = 8,
- LMAC_MODE_100G_R = 9,
- LMAC_MODE_USXGMII = 10,
+extern char lmac_type_to_str[][8];
+extern char lmac_speed_to_str[][8];
+struct lmac_priv {
- u8 enable:1;
- u8 full_duplex:1;
- u8 speed:4;
- u8 mode:1;
- u8 rsvd:1;
- u8 mac_addr[6];
+struct cgx; +struct nix; +struct nix_af;
+struct lmac {
- struct cgx *cgx;
- struct nix *nix;
- char name[16];
- bool init_pend;
- u8 instance;
- u8 lmac_id;
- u8 pknd;
- u8 link_num;
- u32 chan_num;
- u8 mac_addr[6];
+struct cgx {
- struct nix_af *nix_af;
- void __iomem *reg_base;
- struct lmac *lmac[MAX_LMAC_PER_CGX];
- u8 cgx_id;
- u8 lmac_count;
+static inline void cgx_write(struct cgx *cgx, u8 lmac, u64 offset, u64 val) +{
- writeq(val, cgx->reg_base + CMR_SHIFT(lmac) + offset);
+static inline u64 cgx_read(struct cgx *cgx, u8 lmac, u64 offset) +{
- return readq(cgx->reg_base + CMR_SHIFT(lmac) + offset);
+struct lmac *nix_get_cgx_lmac(int lmac_instance);
+int cgx_lmac_set_pkind(struct lmac *lmac, u8 lmac_id, int pkind); +int cgx_lmac_internal_loopback(struct lmac *lmac, int lmac_id, bool enable); +int cgx_lmac_rx_tx_enable(struct lmac *lmac, int lmac_id, bool enable); +int cgx_lmac_link_enable(struct lmac *lmac, int lmac_id, bool enable,
u64 *status);
+int cgx_lmac_link_status(struct lmac *lmac, int lmac_id, u64 *status); +void cgx_lmac_mac_filter_setup(struct lmac *lmac);
+int cgx_intf_get_link_sts(u8 cgx, u8 lmac, u64 *lnk_sts); +int cgx_intf_link_up_dwn(u8 cgx, u8 lmac, u8 up_dwn, u64 *lnk_sts); +int cgx_intf_get_mac_addr(u8 cgx, u8 lmac, u8 *mac); +int cgx_intf_set_macaddr(struct udevice *dev); +int cgx_intf_prbs(u8 qlm, u8 mode, u32 time, u8 lane); +int cgx_intf_display_eye(u8 qlm, u8 lane); +int cgx_intf_display_serdes(u8 qlm, u8 lane);
+#endif /* __CGX_H__ */ diff --git a/drivers/net/octeontx2/cgx_intf.c b/drivers/net/octeontx2/cgx_intf.c new file mode 100644 index 0000000000..37d9a2bb73 --- /dev/null +++ b/drivers/net/octeontx2/cgx_intf.c @@ -0,0 +1,715 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/list.h>
+#include <asm/arch/board.h> +#include <asm/io.h>
+#include "cgx_intf.h" +#include "cgx.h" +#include "nix.h"
+static u64 cgx_rd_scrx(u8 cgx, u8 lmac, u8 index) +{
- u64 addr;
- addr = (index == 1) ? CGX_CMR_SCRATCH1 : CGX_CMR_SCRATCH0;
- addr += CGX_SHIFT(cgx) + CMR_SHIFT(lmac);
- return readq(addr);
+static void cgx_wr_scrx(u8 cgx, u8 lmac, u8 index, u64 val) +{
- u64 addr;
- writeq(val, addr);
+static u64 cgx_rd_scr0(u8 cgx, u8 lmac) +{
- return cgx_rd_scrx(cgx, lmac, 0);
+static u64 cgx_rd_scr1(u8 cgx, u8 lmac) +{
- return cgx_rd_scrx(cgx, lmac, 1);
+static void cgx_wr_scr0(u8 cgx, u8 lmac, u64 val) +{
- return cgx_wr_scrx(cgx, lmac, 0, val);
+static void cgx_wr_scr1(u8 cgx, u8 lmac, u64 val) +{
- return cgx_wr_scrx(cgx, lmac, 1, val);
+static inline void set_ownership(u8 cgx, u8 lmac, u8 val) +{
- union cgx_scratchx1 scr1;
- scr1.u = cgx_rd_scr1(cgx, lmac);
- scr1.s.own_status = val;
- cgx_wr_scr1(cgx, lmac, scr1.u);
+static int wait_for_ownership(u8 cgx, u8 lmac) +{
- union cgx_scratchx0 scr0;
- u64 cmrx_int;
- int timeout = 5000;
- do {
scr0.u = cgx_rd_scr0(cgx, lmac);
/* clear async events if any */
if (scr0.s.evt_sts.evt_type == CGX_EVT_ASYNC &&
scr0.s.evt_sts.ack) {
/* clear interrupt */
cmrx_int = readq(CGX_CMR_INT +
CGX_SHIFT(cgx) + CMR_SHIFT(lmac));
cmrx_int |= 0x2; // Overflw bit
writeq(cmrx_int, CGX_CMR_INT +
/* clear ack */
scr0.s.evt_sts.ack = 0;
cgx_wr_scr0(cgx, lmac, scr0.u);
if (timeout-- < 0) {
debug("timeout waiting for ownership\n");
return -ETIMEDOUT;
mdelay(1);
- } while ((scr1.s.own_status == CGX_OWN_FIRMWARE) &&
scr0.s.evt_sts.ack);
+int cgx_intf_req(u8 cgx, u8 lmac, union cgx_cmd_s cmd_args, u64 *rsp,
int use_cmd_id_only)
- u64 cmrx_int;
- int timeout = 500;
- int err = 0;
- u8 cmd = cmd_args.cmd.id;
- if (wait_for_ownership(cgx, lmac)) {
err = -ETIMEDOUT;
goto error;
- /* send command */
- if (use_cmd_id_only) {
scr1.s.cmd.id = cmd;
- } else {
cmd_args.own_status = scr1.s.own_status;
scr1.s = cmd_args;
- set_ownership(cgx, lmac, CGX_OWN_FIRMWARE);
- /* wait for response and ownership */
- do {
mdelay(10);
- } while (timeout-- && (!scr0.s.evt_sts.ack) &&
(scr1.s.own_status == CGX_OWN_FIRMWARE));
- if (timeout < 0) {
debug("%s timeout waiting for ack\n", __func__);
err = -ETIMEDOUT;
goto error;
- if (cmd == CGX_CMD_INTF_SHUTDOWN)
goto error;
- if (scr0.s.evt_sts.evt_type != CGX_EVT_CMD_RESP) {
debug("%s received async event instead of cmd resp event\n",
__func__);
err = -1;
goto error;
- if (scr0.s.evt_sts.id != cmd) {
debug("%s received resp for cmd %d expected cmd %d\n",
__func__, scr0.s.evt_sts.id, cmd);
err = -1;
goto error;
- if (scr0.s.evt_sts.stat != CGX_STAT_SUCCESS) {
debug("%s cmd%d failed on cgx%u lmac%u with errcode %d\n",
__func__, cmd, cgx, lmac, scr0.s.link_sts.err_type);
err = -1;
+error:
- /* clear interrupt */
- cmrx_int = readq(CGX_CMR_INT + CGX_SHIFT(cgx) + CMR_SHIFT(lmac));
- cmrx_int |= 0x2; // Overflw bit
- writeq(cmrx_int, CGX_CMR_INT + CGX_SHIFT(cgx) + CMR_SHIFT(lmac));
- /* clear ownership and ack */
- scr0.s.evt_sts.ack = 0;
- cgx_wr_scr0(cgx, lmac, scr0.u);
- *rsp = err ? 0 : scr0.u;
- return err;
+int cgx_intf_get_mac_addr(u8 cgx, u8 lmac, u8 *mac) +{
- int ret;
- union cgx_cmd_s cmd;
- cmd.cmd.id = CGX_CMD_GET_MAC_ADDR;
- ret = cgx_intf_req(cgx, lmac, cmd, &scr0.u, 1);
- if (ret)
return -1;
- scr0.u >>= 9;
- memcpy(mac, &scr0.u, 6);
+int cgx_intf_get_ver(u8 cgx, u8 lmac, u8 *ver) +{
- int ret;
- cmd.cmd.id = CGX_CMD_GET_FW_VER;
- if (ret)
return -1;
- scr0.u >>= 9;
- *ver = scr0.u & 0xFFFF;
+int cgx_intf_get_link_sts(u8 cgx, u8 lmac, u64 *lnk_sts) +{
- int ret;
- cmd.cmd.id = CGX_CMD_GET_LINK_STS;
- if (ret)
return -1;
- scr0.u >>= 9;
- /* pass the same format as cgx_lnk_sts_s
* err_type:10, speed:4, full_duplex:1, link_up:1
- *lnk_sts = scr0.u & 0xFFFF;
+int cgx_intf_link_up_dwn(u8 cgx, u8 lmac, u8 up_dwn, u64 *lnk_sts) +{
- int ret;
- cmd.cmd.id = up_dwn ? CGX_CMD_LINK_BRING_UP : CGX_CMD_LINK_BRING_DOWN;
- if (ret)
return -1;
- scr0.u >>= 9;
+void cgx_intf_shutdown(void) +{
- cmd.cmd.id = CGX_CMD_INTF_SHUTDOWN;
- cgx_intf_req(0, 0, cmd, &scr0.u, 1);
+int cgx_intf_prbs(u8 qlm, u8 mode, u32 time, u8 lane) +{
- int ret;
- cmd.cmd.id = CGX_CMD_PRBS;
- cmd.prbs_args.qlm = qlm;
- cmd.prbs_args.mode = mode;
- cmd.prbs_args.time = time;
- cmd.prbs_args.lane = lane;
- ret = cgx_intf_req(0, 0, cmd, &scr0.u, 0);
- if (ret)
return -1;
+enum cgx_mode {
- MODE_10G_C2C,
- MODE_10G_C2M,
- MODE_10G_KR,
- MODE_25G_C2C,
- MODE_25G_2_C2C,
- MODE_50G_C2C,
- MODE_50G_4_C2C
+static char intf_speed_to_str[][8] = {
- "10M",
- "100M",
- "1G",
- "2.5G",
- "5G",
- "10G",
- "20G",
- "25G",
- "40G",
- "50G",
- "80G",
- "100G",
+static void mode_to_args(int mode, struct cgx_mode_change_args *args) +{
- args->an = 0;
- args->duplex = 0;
- args->port = 0;
- switch (mode) {
- case MODE_10G_C2C:
args->speed = CGX_LINK_10G;
args->mode = BIT_ULL(CGX_MODE_10G_C2C_BIT);
break;
- case MODE_10G_C2M:
args->mode = BIT_ULL(CGX_MODE_10G_C2M_BIT);
break;
- case MODE_10G_KR:
args->mode = BIT_ULL(CGX_MODE_10G_KR_BIT);
args->an = 1;
break;
- case MODE_25G_C2C:
args->speed = CGX_LINK_25G;
args->mode = BIT_ULL(CGX_MODE_25G_C2C_BIT);
break;
- case MODE_25G_2_C2C:
args->mode = BIT_ULL(CGX_MODE_25G_2_C2C_BIT);
break;
- case MODE_50G_C2C:
args->speed = CGX_LINK_50G;
args->mode = BIT_ULL(CGX_MODE_50G_C2C_BIT);
break;
- case MODE_50G_4_C2C:
args->mode = BIT_ULL(CGX_MODE_50G_4_C2C_BIT);
+int cgx_intf_set_mode(struct udevice *ethdev, int mode) +{
- struct rvu_pf *rvu = dev_get_priv(ethdev);
- struct nix *nix = rvu->nix;
- int ret;
- cmd.cmd.id = CGX_CMD_MODE_CHANGE;
- mode_to_args(mode, &cmd.mode_change_args);
- ret = cgx_intf_req(nix->lmac->cgx->cgx_id, nix->lmac->lmac_id,
cmd, &scr0.u, 0);
- if (ret) {
printf("Mode change command failed for %s\n", ethdev->name);
return -1;
cmd, &scr0.u, 1);
- if (ret) {
printf("Get Link Status failed for %s\n", ethdev->name);
return -1;
- printf("Current Link Status: ");
- if (scr0.s.link_sts.speed) {
printf("%s\n", intf_speed_to_str[scr0.s.link_sts.speed]);
switch (scr0.s.link_sts.fec) {
case 0:
printf("FEC_NONE\n");
break;
case 1:
printf("FEC_BASE_R\n");
break;
case 2:
printf("FEC_RS\n");
break;
printf("Auto Negotiation %sabled\n",
scr0.s.link_sts.an ? "En" : "Dis");
printf("%s Duplex\n",
scr0.s.link_sts.full_duplex ? "Full" : "Half");
- } else {
printf("Down\n");
+int cgx_intf_get_mode(struct udevice *ethdev) +{
- int ret;
cmd, &scr0.u, 1);
- if (ret) {
printf("Get link status failed for %s\n", ethdev->name);
return -1;
- printf("Current Interface Mode: ");
- switch (scr0.s.link_sts.mode) {
- case CGX_MODE_10G_C2C_BIT:
printf("10G_C2C\n");
break;
- case CGX_MODE_10G_C2M_BIT:
printf("10G_C2M\n");
break;
- case CGX_MODE_10G_KR_BIT:
printf("10G_KR\n");
break;
- case CGX_MODE_25G_C2C_BIT:
printf("25G_C2C\n");
break;
- case CGX_MODE_25G_2_C2C_BIT:
printf("25G_2_C2C\n");
break;
- case CGX_MODE_50G_C2C_BIT:
printf("50G_C2C\n");
break;
- case CGX_MODE_50G_4_C2C_BIT:
printf("50G_4_C2C\n");
break;
- default:
printf("Unknown\n");
break;
+int cgx_intf_get_fec(struct udevice *ethdev) +{
- int ret;
- cmd.cmd.id = CGX_CMD_GET_SUPPORTED_FEC;
cmd, &scr0.u, 1);
- if (ret) {
printf("Get supported FEC failed for %s\n", ethdev->name);
return -1;
- printf("Supported FEC type: ");
- switch (scr0.s.supported_fec.fec) {
- case 0:
break;
- case 1:
break;
- case 2:
printf("FEC_RS\n");
break;
- case 3:
printf("FEC_BASE_R FEC_RS\n");
break;
cmd, &scr0.u, 1);
- if (ret) {
printf("Get active fec failed for %s\n", ethdev->name);
return -1;
- printf("Active FEC type: ");
- switch (scr0.s.link_sts.fec) {
- case 0:
break;
- case 1:
break;
- case 2:
printf("FEC_RS\n");
break;
+int cgx_intf_set_fec(struct udevice *ethdev, int type) +{
- int ret;
- cmd.cmd.id = CGX_CMD_SET_FEC;
- cmd.fec_args.fec = type;
cmd, &scr0.u, 0);
- if (ret) {
printf("Set FEC type %d failed for %s\n", type, ethdev->name);
return -1;
+int cgx_intf_get_phy_mod_type(struct udevice *ethdev) +{
- int ret;
- cmd.cmd.id = CGX_CMD_GET_PHY_MOD_TYPE;
cmd, &scr0.u, 1);
- if (ret) {
printf("Get PHYMOD type failed for %s\n", ethdev->name);
return -1;
- printf("Current phy mod type %s\n",
scr0.s.phy_mod_type.mod ? "PAM4" : "NRZ");
+int cgx_intf_set_phy_mod_type(struct udevice *ethdev, int type) +{
- int ret;
- cmd.cmd.id = CGX_CMD_SET_PHY_MOD_TYPE;
- cmd.phy_mod_args.mod = type;
cmd, &scr0.u, 0);
- if (ret) {
printf("Set PHYMOD type %d failed for %s\n", type,
ethdev->name);
return -1;
+int cgx_intf_set_an_lbk(struct udevice *ethdev, int enable) +{
- int ret;
- cmd.cmd.id = CGX_CMD_AN_LOOPBACK;
- cmd.cmd_args.enable = enable;
cmd, &scr0.u, 0);
- if (ret) {
printf("Set AN loopback command failed on %s\n", ethdev->name);
return -1;
- printf("AN loopback %s for %s\n", enable ? "set" : "clear",
ethdev->name);
+int cgx_intf_get_ignore(struct udevice *ethdev, int cgx, int lmac) +{
- struct rvu_pf *rvu;
- struct nix *nix;
- int ret, cgx_id = cgx, lmac_id = lmac;
- if (ethdev) {
nix = rvu->nix;
cgx_id = nix->lmac->cgx->cgx_id;
lmac_id = nix->lmac->lmac_id;
- cmd.cmd.id = CGX_CMD_GET_PERSIST_IGNORE;
- ret = cgx_intf_req(cgx_id, lmac_id, cmd, &scr0.u, 1);
- if (ret) {
if (ethdev)
printf("Get ignore command failed for %s\n",
ethdev->name);
else
printf("Get ignore command failed for CGX%d LMAC%d\n",
cgx_id, lmac_id);
return -1;
- if (ethdev)
printf("Persist settings %signored for %s\n",
scr0.s.persist.ignore ? "" : "not ", ethdev->name);
- else
printf("Persist settings %signored for CGX%d LMAC%d\n",
scr0.s.persist.ignore ? "" : "not ", cgx_id, lmac_id);
+int cgx_intf_set_ignore(struct udevice *ethdev, int cgx, int lmac, int ignore) +{
- struct nix *nix;
- if (ethdev) {
nix = rvu->nix;
- cmd.cmd.id = CGX_CMD_SET_PERSIST_IGNORE;
- cmd.persist_args.ignore = ignore;
- ret = cgx_intf_req(cgx_id, lmac_id, cmd, &scr0.u, 0);
- if (ret) {
if (ethdev)
printf("Set ignore command failed for %s\n",
ethdev->name);
else
printf("Set ignore command failed for CGX%d LMAC%d\n",
cgx_id, lmac_id);
return -1;
+int cgx_intf_set_macaddr(struct udevice *ethdev) +{
- int ret;
- u64 mac, tmp;
- memcpy((void *)&tmp, nix->lmac->mac_addr, 6);
- cmd.cmd.id = CGX_CMD_SET_MAC_ADDR;
- cmd.mac_args.addr = mac;
- cmd.mac_args.pf_id = rvu->pfid;
cmd, &scr0.u, 0);
- if (ret) {
printf("Set user mac addr failed for %s\n", ethdev->name);
return -1;
+int cgx_intf_display_eye(u8 qlm, u8 lane) +{
- int ret;
- cmd.cmd.id = CGX_CMD_DISPLAY_EYE;
- cmd.dsp_eye_args.qlm = qlm;
- cmd.dsp_eye_args.lane = lane;
- if (ret)
return -1;
+int cgx_intf_display_serdes(u8 qlm, u8 lane) +{
- int ret;
- cmd.cmd.id = CGX_CMD_DISPLAY_SERDES;
- if (ret)
return -1;
+} diff --git a/drivers/net/octeontx2/cgx_intf.h b/drivers/net/octeontx2/cgx_intf.h new file mode 100644 index 0000000000..62a7203ad8 --- /dev/null +++ b/drivers/net/octeontx2/cgx_intf.h @@ -0,0 +1,448 @@ +/* SPDX-License-Identifier: GPL-2.0
+#ifndef __CGX_INTF_H__ +#define __CGX_INTF_H__
+#define CGX_FIRMWARE_MAJOR_VER 1 +#define CGX_FIRMWARE_MINOR_VER 0
+/* Register offsets */ +#define CGX_CMR_INT 0x87e0e0000040 +#define CGX_CMR_SCRATCH0 0x87e0e0001050 +#define CGX_CMR_SCRATCH1 0x87e0e0001058
+#define CGX_SHIFT(x) (0x1000000 * ((x) & 0x3)) +#define CMR_SHIFT(x) (0x40000 * ((x) & 0x3))
+/* CGX error types. set for cmd response status as CGX_STAT_FAIL */ +enum cgx_error_type {
- CGX_ERR_NONE,
- CGX_ERR_LMAC_NOT_ENABLED,
- CGX_ERR_LMAC_MODE_INVALID,
- CGX_ERR_REQUEST_ID_INVALID,
- CGX_ERR_PREV_ACK_NOT_CLEAR,
- CGX_ERR_PHY_LINK_DOWN,
- CGX_ERR_PCS_RESET_FAIL,
- CGX_ERR_AN_CPT_FAIL,
- CGX_ERR_TX_NOT_IDLE,
- CGX_ERR_RX_NOT_IDLE,
- CGX_ERR_SPUX_BR_BLKLOCK_FAIL,
- CGX_ERR_SPUX_RX_ALIGN_FAIL,
- CGX_ERR_SPUX_TX_FAULT,
- CGX_ERR_SPUX_RX_FAULT,
- CGX_ERR_SPUX_RESET_FAIL,
- CGX_ERR_SPUX_AN_RESET_FAIL,
- CGX_ERR_SPUX_USX_AN_RESET_FAIL,
- CGX_ERR_SMUX_RX_LINK_NOT_OK,
- CGX_ERR_PCS_LINK_FAIL,
- CGX_ERR_TRAINING_FAIL,
- CGX_ERR_RX_EQU_FAIL,
- CGX_ERR_SPUX_BER_FAIL,
- CGX_ERR_SPUX_RSFEC_ALGN_FAIL,
- CGX_ERR_SPUX_MARKER_LOCK_FAIL,
- CGX_ERR_SET_FEC_INVALID,
- CGX_ERR_SET_FEC_FAIL,
- CGX_ERR_MODULE_INVALID,
- CGX_ERR_MODULE_NOT_PRESENT,
- CGX_ERR_SPEED_CHANGE_INVALID, /* = 28 */
- /* FIXME : add more error types when adding support for new modes */
+/* LINK speed types */ +enum cgx_link_speed {
- CGX_LINK_NONE,
- CGX_LINK_10M,
- CGX_LINK_100M,
- CGX_LINK_1G,
- CGX_LINK_2HG, /* 2.5 Gbps */
- CGX_LINK_5G,
- CGX_LINK_10G,
- CGX_LINK_20G,
- CGX_LINK_25G,
- CGX_LINK_40G,
- CGX_LINK_50G,
- CGX_LINK_80G,
- CGX_LINK_100G,
- CGX_LINK_MAX,
+/* REQUEST ID types. Input to firmware */ +enum cgx_cmd_id {
- CGX_CMD_NONE = 0,
- CGX_CMD_GET_FW_VER,
- CGX_CMD_GET_MAC_ADDR,
- CGX_CMD_SET_MTU,
- CGX_CMD_GET_LINK_STS, /* optional to user */
- CGX_CMD_LINK_BRING_UP, /* = 5 */
- CGX_CMD_LINK_BRING_DOWN,
- CGX_CMD_INTERNAL_LBK,
- CGX_CMD_EXTERNAL_LBK,
- CGX_CMD_HIGIG,
- CGX_CMD_LINK_STAT_CHANGE, /* = 10 */
- CGX_CMD_MODE_CHANGE, /* hot plug support */
- CGX_CMD_INTF_SHUTDOWN,
- CGX_CMD_GET_MKEX_SIZE,
- CGX_CMD_GET_MKEX_PROFILE,
- CGX_CMD_GET_FWD_BASE, /* get base address of shared FW data */
- CGX_CMD_GET_LINK_MODES, /* Supported Link Modes */
- CGX_CMD_SET_LINK_MODE,
- CGX_CMD_GET_SUPPORTED_FEC,
- CGX_CMD_SET_FEC,
- CGX_CMD_GET_AN, /* = 20 */
- CGX_CMD_SET_AN,
- CGX_CMD_GET_ADV_LINK_MODES,
- CGX_CMD_GET_ADV_FEC,
- CGX_CMD_GET_PHY_MOD_TYPE, /* line-side modulation type: NRZ or PAM4 */
- CGX_CMD_SET_PHY_MOD_TYPE, /* = 25 */
- CGX_CMD_PRBS,
- CGX_CMD_DISPLAY_EYE,
- CGX_CMD_GET_PHY_FEC_STATS,
- CGX_CMD_DISPLAY_SERDES,
- CGX_CMD_AN_LOOPBACK, /* = 30 */
- CGX_CMD_GET_PERSIST_IGNORE,
- CGX_CMD_SET_PERSIST_IGNORE,
- CGX_CMD_SET_MAC_ADDR,
+/* async event ids */ +enum cgx_evt_id {
- CGX_EVT_NONE,
- CGX_EVT_LINK_CHANGE,
+/* event types - cause of interrupt */ +enum cgx_evt_type {
- CGX_EVT_ASYNC,
- CGX_EVT_CMD_RESP
+enum cgx_stat {
- CGX_STAT_SUCCESS,
- CGX_STAT_FAIL
+enum cgx_cmd_own {
- /* default ownership with kernel/uefi/u-boot */
- CGX_OWN_NON_SECURE_SW,
- /* set by kernel/uefi/u-boot after posting a new request to ATF */
- CGX_OWN_FIRMWARE,
+/* Supported LINK MODE enums
- Each link mode is a bit mask of these
- enums which are represented as bits
+enum cgx_mode_t {
- CGX_MODE_SGMII_BIT = 0,
- CGX_MODE_1000_BASEX_BIT,
- CGX_MODE_QSGMII_BIT,
- CGX_MODE_10G_C2C_BIT,
- CGX_MODE_10G_C2M_BIT,
- CGX_MODE_10G_KR_BIT,
- CGX_MODE_20G_C2C_BIT,
- CGX_MODE_25G_C2C_BIT,
- CGX_MODE_25G_C2M_BIT,
- CGX_MODE_25G_2_C2C_BIT,
- CGX_MODE_25G_CR_BIT,
- CGX_MODE_25G_KR_BIT,
- CGX_MODE_40G_C2C_BIT,
- CGX_MODE_40G_C2M_BIT,
- CGX_MODE_40G_CR4_BIT,
- CGX_MODE_40G_KR4_BIT,
- CGX_MODE_40GAUI_C2C_BIT,
- CGX_MODE_50G_C2C_BIT,
- CGX_MODE_50G_C2M_BIT,
- CGX_MODE_50G_4_C2C_BIT,
- CGX_MODE_50G_CR_BIT,
- CGX_MODE_50G_KR_BIT,
- CGX_MODE_80GAUI_C2C_BIT,
- CGX_MODE_100G_C2C_BIT,
- CGX_MODE_100G_C2M_BIT,
- CGX_MODE_100G_CR4_BIT,
- CGX_MODE_100G_KR4_BIT,
- CGX_MODE_MAX_BIT /* = 29 */
+/* scratchx(0) CSR used for ATF->non-secure SW communication.
- This acts as the status register
- Provides details on command ack/status, link status, error details
+/* CAUTION : below structures are placed in order based on the bit positions
- For any updates/new bitfields, corresponding structures needs to be updated
+struct cgx_evt_sts_s { /* start from bit 0 */
- u64 ack:1;
- u64 evt_type:1; /* cgx_evt_type */
- u64 stat:1; /* cgx_stat */
- u64 id:6; /* cgx_evt_id/cgx_cmd_id */
- u64 reserved:55;
+/* all the below structures are in the same memory location of SCRATCHX(0)
- value can be read/written based on command ID
+/* Resp to command IDs with command status as CGX_STAT_FAIL
- Not applicable for commands :
- CGX_CMD_LINK_BRING_UP/DOWN/CGX_EVT_LINK_CHANGE
- check struct cgx_lnk_sts_s comments
+struct cgx_err_sts_s { /* start from bit 9 */
- u64 reserved1:9;
- u64 type:10; /* cgx_error_type */
- u64 reserved2:35;
+/* Resp to cmd ID as CGX_CMD_GET_FW_VER with cmd status as CGX_STAT_SUCCESS */ +struct cgx_ver_s { /* start from bit 9 */
- u64 reserved1:9;
- u64 major_ver:4;
- u64 minor_ver:4;
- u64 reserved2:47;
+/* Resp to cmd ID as CGX_CMD_GET_MAC_ADDR with cmd status as CGX_STAT_SUCCESS
- Returns each byte of MAC address in a separate bit field
+struct cgx_mac_addr_s { /* start from bit 9 */
- u64 reserved1:9;
- u64 addr_0:8;
- u64 addr_1:8;
- u64 addr_2:8;
- u64 addr_3:8;
- u64 addr_4:8;
- u64 addr_5:8;
- u64 reserved2:7;
+/* Resp to cmd ID - CGX_CMD_LINK_BRING_UP/DOWN, event ID CGX_EVT_LINK_CHANGE
- status can be either CGX_STAT_FAIL or CGX_STAT_SUCCESS
- In case of CGX_STAT_FAIL, it indicates CGX configuration failed when
- processing link up/down/change command. Both err_type and current link status
- will be updated
- In case of CGX_STAT_SUCCESS, err_type will be CGX_ERR_NONE and current
- link status will be updated
+struct cgx_lnk_sts_s {
- u64 reserved1:9;
- u64 link_up:1;
- u64 full_duplex:1;
- u64 speed:4; /* cgx_link_speed */
- u64 err_type:10;
- u64 an:1; /* Current AN state : enabled/disabled */
- u64 fec:2; /* Current FEC type if enabled, if not 0 */
- u64 port:8; /* Share the current port info if required */
- u64 mode:8; /* cgx_mode_t enum integer value */
- u64 reserved2:20;
+struct sh_fwd_base_s {
- u64 reserved1:9;
- u64 addr:55;
+struct cgx_link_modes_s {
- u64 reserved1:9;
- u64 modes:55;
+/* Resp to cmd ID - CGX_CMD_GET_ADV_FEC/CGX_CMD_GET_SUPPORTED_FEC
- fec : 2 bits
- typedef enum cgx_fec_type {
CGX_FEC_NONE,
CGX_FEC_BASE_R,
CGX_FEC_RS
- } fec_type_t;
+struct cgx_fec_types_s {
- u64 reserved1:9;
- u64 fec:2;
- u64 reserved2:53;
+/* Resp to cmd ID - CGX_CMD_GET_AN */ +struct cgx_get_an_s {
- u64 reserved1:9;
- u64 an:1;
- u64 reserved2:54;
+/* Resp to cmd ID - CGX_CMD_GET_PHY_MOD_TYPE */ +struct cgx_get_phy_mod_type_s {
- u64 reserved1:9;
- u64 mod:1; /* 0=NRZ, 1=PAM4 */
- u64 reserved2:54;
+/* Resp to cmd ID - CGX_CMD_GET_PERSIST_IGNORE */ +struct cgx_get_flash_ignore_s {
- uint64_t reserved1:9;
- uint64_t ignore:1;
- uint64_t reserved2:54;
+union cgx_rsp_sts {
- /* Fixed, applicable for all commands/events */
- struct cgx_evt_sts_s evt_sts;
- /* response to CGX_CMD_LINK_BRINGUP/DOWN/LINK_CHANGE */
- struct cgx_lnk_sts_s link_sts;
- /* response to CGX_CMD_GET_FW_VER */
- struct cgx_ver_s ver;
- /* response to CGX_CMD_GET_MAC_ADDR */
- struct cgx_mac_addr_s mac_s;
- /* response to CGX_CMD_GET_FWD_BASE */
- struct sh_fwd_base_s fwd_base_s;
- /* response if evt_status = CMD_FAIL */
- struct cgx_err_sts_s err;
- /* response to CGX_CMD_GET_SUPPORTED_FEC */
- struct cgx_fec_types_s supported_fec;
- /* response to CGX_CMD_GET_LINK_MODES */
- struct cgx_link_modes_s supported_modes;
- /* response to CGX_CMD_GET_ADV_LINK_MODES */
- struct cgx_link_modes_s adv_modes;
- /* response to CGX_CMD_GET_ADV_FEC */
- struct cgx_fec_types_s adv_fec;
- /* response to CGX_CMD_GET_AN */
- struct cgx_get_an_s an;
- /* response to CGX_CMD_GET_PHY_MOD_TYPE */
- struct cgx_get_phy_mod_type_s phy_mod_type;
- /* response to CGX_CMD_GET_PERSIST_IGNORE */
- struct cgx_get_flash_ignore_s persist;
+#ifdef NT_FW_CONFIG
- /* response to CGX_CMD_GET_MKEX_SIZE */
- struct cgx_mcam_profile_sz_s prfl_sz;
- /* response to CGX_CMD_GET_MKEX_PROFILE */
- struct cgx_mcam_profile_addr_s prfl_addr;
+#endif +};
+union cgx_scratchx0 {
- u64 u;
- union cgx_rsp_sts s;
+/* scratchx(1) CSR used for non-secure SW->ATF communication
- This CSR acts as a command register
+struct cgx_cmd { /* start from bit 2 */
- u64 reserved1:2;
- u64 id:6; /* cgx_request_id */
- u64 reserved2:56;
+/* all the below structures are in the same memory location of SCRATCHX(1)
- corresponding arguments for command Id needs to be updated
+/* Any command using enable/disable as an argument need
- to pass the option via this structure.
- Ex: Loopback, HiGig...
+struct cgx_ctl_args { /* start from bit 8 */
- u64 reserved1:8;
- u64 enable:1;
- u64 reserved2:55;
+/* command argument to be passed for cmd ID - CGX_CMD_SET_MTU */ +struct cgx_mtu_args {
- u64 reserved1:8;
- u64 size:16;
- u64 reserved2:40;
+/* command argument to be passed for cmd ID - CGX_CMD_MODE_CHANGE */ +struct cgx_mode_change_args {
- uint64_t reserved1:8;
- uint64_t speed:4; /* cgx_link_speed enum */
- uint64_t duplex:1; /* 0 - full duplex, 1 - half duplex */
- uint64_t an:1; /* 0 - disable AN, 1 - enable AN */
- uint64_t port:8; /* device port */
- uint64_t mode:42;
+/* command argument to be passed for cmd ID - CGX_CMD_LINK_CHANGE */ +struct cgx_link_change_args { /* start from bit 8 */
- u64 reserved1:8;
- u64 link_up:1;
- u64 reserved2:50;
+/* command argument to be passed for cmd ID - CGX_CMD_SET_LINK_MODE */ +struct cgx_set_mode_args {
- u64 reserved1:8;
- u64 mode:56;
+/* command argument to be passed for cmd ID - CGX_CMD_SET_FEC */ +struct cgx_set_fec_args {
- u64 reserved1:8;
- u64 fec:2;
- u64 reserved2:54;
+/* command argument to be passed for cmd ID - CGX_CMD_SET_PHY_MOD_TYPE */ +struct cgx_set_phy_mod_args {
- u64 reserved1:8;
- u64 reserved2:55;
+/* command argument to be passed for cmd ID - CGX_CMD_SET_PERSIST_IGNORE */ +struct cgx_set_flash_ignore_args {
- uint64_t reserved2:55;
+/* command argument to be passed for cmd ID - CGX_CMD_SET_MAC_ADDR */ +struct cgx_mac_addr_args {
- uint64_t addr:48;
- uint64_t pf_id:8;
+struct cgx_prbs_args {
- u64 reserved1:8; /* start from bit 8 */
- u64 lane:8;
- u64 qlm:8;
- u64 stop_on_error:1;
- u64 mode:8;
- u64 time:31;
+struct cgx_display_eye_args {
- u64 qlm:8;
- u64 lane:47;
+union cgx_cmd_s {
- u64 own_status:2; /* cgx_cmd_own */
- struct cgx_cmd cmd;
- struct cgx_ctl_args cmd_args;
- struct cgx_mtu_args mtu_size;
- struct cgx_link_change_args lnk_args; /* Input to CGX_CMD_LINK_CHANGE */
- struct cgx_set_mode_args mode_args;
- struct cgx_mode_change_args mode_change_args;
- struct cgx_set_fec_args fec_args;
- struct cgx_set_phy_mod_args phy_mod_args;
- struct cgx_set_flash_ignore_args persist_args;
- struct cgx_mac_addr_args mac_args;
- /* any other arg for command id * like : mtu, dmac filtering control */
- struct cgx_prbs_args prbs_args;
- struct cgx_display_eye_args dsp_eye_args;
+union cgx_scratchx1 {
- u64 u;
- union cgx_cmd_s s;
+#endif /* __CGX_INTF_H__ */ diff --git a/drivers/net/octeontx2/lmt.h b/drivers/net/octeontx2/lmt.h new file mode 100644 index 0000000000..84a7eab814 --- /dev/null +++ b/drivers/net/octeontx2/lmt.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: GPL-2.0
- Atomically adds a signed value to a 64 bit (aligned) memory location,
- and returns previous value.
- This version does not perform 'sync' operations to enforce memory
- operations. This should only be used when there are no memory operation
- ordering constraints. (This should NOT be used for reference counting -
- use the standard version instead.)
- @param ptr address in memory to add incr to
- @param incr amount to increment memory location by (signed)
- @return Value of memory location before increment
+static inline s64 atomic_fetch_and_add64_nosync(s64 *ptr, s64 incr) +{
- s64 result;
- /* Atomic add with no ordering */
- asm volatile("ldadd %x[i], %x[r], [%[b]]"
: [r] "=r" (result), "+m" (*ptr)
: [i] "r" (incr), [b] "r" (ptr)
: "memory");
- return result;
+static inline void lmt_cancel(const struct nix *nix) +{
- writeq(0, nix->lmt_base + LMT_LF_LMTCANCEL());
+static inline u64 *lmt_store_ptr(struct nix *nix) +{
- return (u64 *)((u8 *)(nix->lmt_base) +
LMT_LF_LMTLINEX(0));
+static inline s64 lmt_submit(u64 io_address) +{
- s64 result = 0;
- asm volatile("ldeor xzr, %x[rf],[%[rs]]"
: [rf] "=r"(result) : [rs] "r"(io_address));
- return result;
+} diff --git a/drivers/net/octeontx2/nix.c b/drivers/net/octeontx2/nix.c new file mode 100644 index 0000000000..0a3e8e4af0 --- /dev/null +++ b/drivers/net/octeontx2/nix.c @@ -0,0 +1,831 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <dm.h> +#include <errno.h> +#include <log.h> +#include <malloc.h> +#include <memalign.h> +#include <misc.h> +#include <net.h> +#include <pci.h> +#include <watchdog.h>
+#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-lmt.h> +#include <asm/io.h> +#include <asm/types.h>
+#include <linux/delay.h> +#include <linux/log2.h> +#include <linux/types.h>
+#include "nix.h" +#include "lmt.h" +#include "cgx.h"
- NIX needs a lot of memory areas. Rather than handle all the failure cases,
- we'll use a wrapper around alloc that prints an error if a memory
- allocation fails.
- @param num_elements
Number of elements to allocate
- @param elem_size Size of each element
- @param msg Text string to show when allocation fails
- @return A valid memory location or NULL on failure
+static void *nix_memalloc(int num_elements, size_t elem_size, const char *msg) +{
- size_t alloc_size = num_elements * elem_size;
- void *base = memalign(CONFIG_SYS_CACHELINE_SIZE, alloc_size);
- if (!base)
printf("NIX: Mem alloc failed for %s (%d * %zu = %zu bytes)\n",
msg ? msg : __func__, num_elements, elem_size,
alloc_size);
- else
memset(base, 0, alloc_size);
- debug("NIX: Memory alloc for %s (%d * %zu = %zu bytes) at %p\n",
msg ? msg : __func__, num_elements, elem_size, alloc_size, base);
- return base;
+int npc_lf_setup(struct nix *nix) +{
- int err;
- err = npc_lf_admin_setup(nix);
- if (err) {
printf("%s: Error setting up npc lf admin\n", __func__);
return err;
+static int npa_setup_pool(struct npa *npa, u32 pool_id,
size_t buffer_size, u32 queue_length, void *buffers[])
- struct {
union npa_lf_aura_op_free0 f0;
union npa_lf_aura_op_free1 f1;
- } aura_descr;
- int index;
- for (index = 0; index < queue_length; index++) {
buffers[index] = memalign(CONFIG_SYS_CACHELINE_SIZE,
buffer_size);
if (!buffers[index]) {
printf("%s: Out of memory %d, size: %zu\n",
__func__, index, buffer_size);
return -ENOMEM;
debug("%s: allocating buffer %d, addr %p size: %zu\n",
__func__, index, buffers[index], buffer_size);
/* Add the newly obtained pointer to the pool. 128 bit
* writes only.
aura_descr.f0.s.addr = (u64)buffers[index];
aura_descr.f1.u = 0;
aura_descr.f1.s.aura = pool_id;
st128(npa->npa_base + NPA_LF_AURA_OP_FREE0(),
aura_descr.f0.u, aura_descr.f1.u);
+int npa_lf_setup(struct nix *nix) +{
- struct rvu_pf *rvu = dev_get_priv(nix->dev);
- struct nix_af *nix_af = nix->nix_af;
- struct npa *npa;
- union npa_af_const npa_af_const;
- union npa_aura_s *aura;
- union npa_pool_s *pool;
- union rvu_func_addr_s block_addr;
- int idx;
- int stack_page_pointers;
- int stack_page_bytes;
- int err;
- npa = (struct npa *)calloc(1, sizeof(struct npa));
- if (!npa) {
printf("%s: out of memory for npa instance\n", __func__);
return -ENOMEM;
- block_addr.u = 0;
- block_addr.s.block = RVU_BLOCK_ADDR_E_NPA;
- npa->npa_base = rvu->pf_base + block_addr.u;
- npa->npa_af = nix_af->npa_af;
- nix->npa = npa;
- npa_af_const.u = npa_af_reg_read(npa->npa_af, NPA_AF_CONST());
- stack_page_pointers = npa_af_const.s.stack_page_ptrs;
- stack_page_bytes = npa_af_const.s.stack_page_bytes;
- npa->stack_pages[NPA_POOL_RX] = (RQ_QLEN + stack_page_pointers - 1) /
- npa->stack_pages[NPA_POOL_TX] = (SQ_QLEN + stack_page_pointers - 1) /
- npa->stack_pages[NPA_POOL_SQB] = (SQB_QLEN + stack_page_pointers - 1) /
- npa->pool_stack_pointers = stack_page_pointers;
- npa->q_len[NPA_POOL_RX] = RQ_QLEN;
- npa->q_len[NPA_POOL_TX] = SQ_QLEN;
- npa->q_len[NPA_POOL_SQB] = SQB_QLEN;
- npa->buf_size[NPA_POOL_RX] = MAX_MTU + CONFIG_SYS_CACHELINE_SIZE;
- npa->buf_size[NPA_POOL_TX] = MAX_MTU + CONFIG_SYS_CACHELINE_SIZE;
- npa->buf_size[NPA_POOL_SQB] = nix_af->sqb_size;
- npa->aura_ctx = nix_memalloc(NPA_POOL_COUNT,
sizeof(union npa_aura_s),
"aura context");
- if (!npa->aura_ctx) {
printf("%s: Out of memory for aura context\n", __func__);
return -ENOMEM;
- for (idx = 0; idx < NPA_POOL_COUNT; idx++) {
npa->pool_ctx[idx] = nix_memalloc(1,
sizeof(union npa_pool_s),
"pool context");
if (!npa->pool_ctx[idx]) {
printf("%s: Out of memory for pool context\n",
__func__);
return -ENOMEM;
npa->pool_stack[idx] = nix_memalloc(npa->stack_pages[idx],
stack_page_bytes,
"pool stack");
if (!npa->pool_stack[idx]) {
printf("%s: Out of memory for pool stack\n", __func__);
return -ENOMEM;
- err = npa_lf_admin_setup(npa, nix->lf, (dma_addr_t)npa->aura_ctx);
- if (err) {
printf("%s: Error setting up NPA LF admin for lf %d\n",
__func__, nix->lf);
return err;
- /* Set up the auras */
aura = npa->aura_ctx + (idx * sizeof(union npa_aura_s));
pool = npa->pool_ctx[idx];
debug("%s aura %p pool %p\n", __func__, aura, pool);
memset(aura, 0, sizeof(union npa_aura_s));
aura->s.fc_ena = 0;
aura->s.pool_addr = (u64)npa->pool_ctx[idx];
debug("%s aura.s.pool_addr %llx pool_addr %p\n", __func__,
aura->s.pool_addr, npa->pool_ctx[idx]);
aura->s.shift = 64 - __builtin_clzll(npa->q_len[idx]) - 8;
aura->s.count = npa->q_len[idx];
aura->s.limit = npa->q_len[idx];
aura->s.ena = 1;
err = npa_attach_aura(nix_af, nix->lf, aura, idx);
if (err)
return err;
memset(pool, 0, sizeof(*pool));
pool->s.fc_ena = 0;
pool->s.nat_align = 1;
pool->s.stack_base = (u64)(npa->pool_stack[idx]);
debug("%s pool.s.stack_base %llx stack_base %p\n", __func__,
pool->s.stack_base, npa->pool_stack[idx]);
pool->s.buf_size =
npa->buf_size[idx] / CONFIG_SYS_CACHELINE_SIZE;
pool->s.stack_max_pages = npa->stack_pages[idx];
pool->s.shift =
64 - __builtin_clzll(npa->pool_stack_pointers) - 8;
pool->s.ptr_start = 0;
pool->s.ptr_end = (1ULL << 40) - 1;
pool->s.ena = 1;
err = npa_attach_pool(nix_af, nix->lf, pool, idx);
if (err)
return err;
npa->buffers[idx] = nix_memalloc(npa->q_len[idx],
sizeof(void *),
"buffers");
if (!npa->buffers[idx]) {
printf("%s: Out of memory\n", __func__);
return -ENOMEM;
err = npa_setup_pool(npa, idx, npa->buf_size[idx],
npa->q_len[idx], npa->buffers[idx]);
if (err) {
printf("%s: Error setting up pool %d\n",
__func__, idx);
return err;
+int npa_lf_shutdown(struct nix *nix) +{
- struct npa *npa = nix->npa;
- int err;
- int pool;
- err = npa_lf_admin_shutdown(nix->nix_af, nix->lf, NPA_POOL_COUNT);
- if (err) {
printf("%s: Error %d shutting down NPA LF admin\n",
__func__, err);
return err;
- free(npa->aura_ctx);
- npa->aura_ctx = NULL;
- for (pool = 0; pool < NPA_POOL_COUNT; pool++) {
free(npa->pool_ctx[pool]);
npa->pool_ctx[pool] = NULL;
free(npa->pool_stack[pool]);
npa->pool_stack[pool] = NULL;
free(npa->buffers[pool]);
npa->buffers[pool] = NULL;
+int nix_lf_setup(struct nix *nix) +{
- int idx;
- int err = -1;
- /* Alloc NIX RQ HW context memory */
- nix->rq_ctx_base = nix_memalloc(nix->rq_cnt, nix_af->rq_ctx_sz,
"RQ CTX");
- if (!nix->rq_ctx_base)
goto error;
- memset(nix->rq_ctx_base, 0, nix_af->rq_ctx_sz);
- /* Alloc NIX SQ HW context memory */
- nix->sq_ctx_base = nix_memalloc(nix->sq_cnt, nix_af->sq_ctx_sz,
"SQ CTX");
- if (!nix->sq_ctx_base)
goto error;
- memset(nix->sq_ctx_base, 0, nix_af->sq_ctx_sz);
- /* Alloc NIX CQ HW context memory */
- nix->cq_ctx_base = nix_memalloc(nix->cq_cnt, nix_af->cq_ctx_sz,
"CQ CTX");
- if (!nix->cq_ctx_base)
goto error;
- memset(nix->cq_ctx_base, 0, nix_af->cq_ctx_sz * NIX_CQ_COUNT);
- /* Alloc NIX CQ Ring memory */
- for (idx = 0; idx < NIX_CQ_COUNT; idx++) {
err = qmem_alloc(&nix->cq[idx], CQ_ENTRIES, CQ_ENTRY_SIZE);
if (err)
goto error;
- /* Alloc memory for Qints HW contexts */
- nix->qint_base = nix_memalloc(nix_af->qints, nix_af->qint_ctx_sz,
"Qint CTX");
- if (!nix->qint_base)
goto error;
- /* Alloc memory for CQints HW contexts */
- nix->cint_base = nix_memalloc(nix_af->cints, nix_af->cint_ctx_sz,
"Cint CTX");
- if (!nix->cint_base)
goto error;
- /* Alloc NIX RSS HW context memory and config the base */
- nix->rss_base = nix_memalloc(nix->rss_grps, nix_af->rsse_ctx_sz,
"RSS CTX");
- if (!nix->rss_base)
goto error;
- err = nix_lf_admin_setup(nix);
- if (err) {
printf("%s: Error setting up LF\n", __func__);
goto error;
+error:
- if (nix->rq_ctx_base)
free(nix->rq_ctx_base);
- nix->rq_ctx_base = NULL;
- if (nix->sq_ctx_base)
free(nix->sq_ctx_base);
- nix->sq_ctx_base = NULL;
- if (nix->cq_ctx_base)
free(nix->cq_ctx_base);
- nix->cq_ctx_base = NULL;
qmem_free(&nix->cq[idx]);
- return err;
+int nix_lf_shutdown(struct nix *nix) +{
- int index;
- int err;
- err = nix_lf_admin_shutdown(nix_af, nix->lf, nix->cq_cnt,
nix->rq_cnt, nix->sq_cnt);
- if (err) {
printf("%s: Error shutting down LF admin\n", __func__);
return err;
- for (index = 0; index < NIX_CQ_COUNT; index++)
qmem_free(&nix->cq[index]);
- debug("%s: nix lf %d reset --\n", __func__, nix->lf);
+struct nix *nix_lf_alloc(struct udevice *dev) +{
- struct nix *nix;
- struct rvu_pf *rvu = dev_get_priv(dev);
- struct rvu_af *rvu_af = dev_get_priv(rvu->afdev);
- union rvu_pf_func_s pf_func;
- int err;
- debug("%s(%s )\n", __func__, dev->name);
- nix = (struct nix *)calloc(1, sizeof(*nix));
- if (!nix) {
printf("%s: Out of memory for nix instance\n", __func__);
return NULL;
- nix->nix_af = rvu_af->nix_af;
- block_addr.u = 0;
- block_addr.s.block = RVU_BLOCK_ADDR_E_NIXX(0);
- nix->nix_base = rvu->pf_base + block_addr.u;
- block_addr.u = 0;
- block_addr.s.block = RVU_BLOCK_ADDR_E_NPC;
- nix->npc_base = rvu->pf_base + block_addr.u;
- block_addr.u = 0;
- block_addr.s.block = RVU_BLOCK_ADDR_E_LMT;
- nix->lmt_base = rvu->pf_base + block_addr.u;
- pf_func.u = 0;
- pf_func.s.pf = rvu->pfid;
- nix->pf_func = pf_func.u;
- nix->lf = rvu->nix_lfid;
- nix->pf = rvu->pfid;
- nix->dev = dev;
- nix->sq_cnt = 1;
- nix->rq_cnt = 1;
- nix->rss_grps = 1;
- nix->cq_cnt = 2;
- nix->xqe_sz = NIX_CQE_SIZE_W16;
- nix->lmac = nix_get_cgx_lmac(nix->pf);
- if (!nix->lmac) {
printf("%s: Error: could not find lmac for pf %d\n",
__func__, nix->pf);
free(nix);
return NULL;
- nix->lmac->link_num =
NIX_LINK_E_CGXX_LMACX(nix->lmac->cgx->cgx_id,
nix->lmac->lmac_id);
- nix->lmac->chan_num =
NIX_CHAN_E_CGXX_LMACX_CHX(nix->lmac->cgx->cgx_id,
nix->lmac->lmac_id, 0);
- /* This is rx pkind in 1:1 mapping to NIX_LINK_E */
- nix->lmac->pknd = nix->lmac->link_num;
- cgx_lmac_set_pkind(nix->lmac, nix->lmac->lmac_id, nix->lmac->pknd);
- debug("%s(%s CGX%x LMAC%x)\n", __func__, dev->name,
nix->lmac->cgx->cgx_id, nix->lmac->lmac_id);
- debug("%s(%s Link %x Chan %x Pknd %x)\n", __func__, dev->name,
nix->lmac->link_num, nix->lmac->chan_num, nix->lmac->pknd);
- err = npa_lf_setup(nix);
- if (err)
return NULL;
- err = npc_lf_setup(nix);
- if (err)
return NULL;
- err = nix_lf_setup(nix);
- if (err)
return NULL;
- return nix;
+u64 npa_aura_op_alloc(struct npa *npa, u64 aura_id) +{
- union npa_lf_aura_op_allocx op_allocx;
- op_allocx.u = atomic_fetch_and_add64_nosync(npa->npa_base +
NPA_LF_AURA_OP_ALLOCX(0), aura_id);
- return op_allocx.s.addr;
+u64 nix_cq_op_status(struct nix *nix, u64 cq_id) +{
- union nixx_lf_cq_op_status op_status;
- s64 *reg = nix->nix_base + NIXX_LF_CQ_OP_STATUS();
- op_status.u = atomic_fetch_and_add64_nosync(reg, cq_id << 32);
- return op_status.u;
+/* TX */ +static inline void nix_write_lmt(struct nix *nix, void *buffer,
int num_words)
- int i;
- u64 *lmt_ptr = lmt_store_ptr(nix);
- u64 *ptr = buffer;
- debug("%s lmt_ptr %p %p\n", __func__, nix->lmt_base, lmt_ptr);
- for (i = 0; i < num_words; i++) {
debug("%s data %llx lmt_ptr %p\n", __func__, ptr[i],
lmt_ptr + i);
lmt_ptr[i] = ptr[i];
+void nix_cqe_tx_pkt_handler(struct nix *nix, void *cqe) +{
- union nix_cqe_hdr_s *txcqe = (union nix_cqe_hdr_s *)cqe;
- debug("%s: txcqe: %p\n", __func__, txcqe);
- if (txcqe->s.cqe_type != NIX_XQE_TYPE_E_SEND) {
printf("%s: Error: Unsupported CQ header type %d\n",
__func__, txcqe->s.cqe_type);
return;
- nix_pf_reg_write(nix, NIXX_LF_CQ_OP_DOOR(),
(NIX_CQ_TX << 32) | 1);
+void nix_lf_flush_tx(struct udevice *dev) +{
- u32 head, tail;
- void *cq_tx_base = nix->cq[NIX_CQ_TX].base;
- union nix_cqe_hdr_s *cqe;
- /* ack tx cqe entries */
- op_status.u = nix_cq_op_status(nix, NIX_CQ_TX);
- head = op_status.s.head;
- tail = op_status.s.tail;
- head &= (nix->cq[NIX_CQ_TX].qsize - 1);
- tail &= (nix->cq[NIX_CQ_TX].qsize - 1);
- debug("%s cq tx head %d tail %d\n", __func__, head, tail);
- while (head != tail) {
cqe = cq_tx_base + head * nix->cq[NIX_CQ_TX].entry_sz;
nix_cqe_tx_pkt_handler(nix, cqe);
+int nix_lf_xmit(struct udevice *dev, void *pkt, int pkt_len) +{
- struct nix_tx_dr tx_dr;
- int dr_sz = (sizeof(struct nix_tx_dr) + 15) / 16 - 1;
- s64 result;
- void *packet;
- nix_lf_flush_tx(dev);
- memset((void *)&tx_dr, 0, sizeof(struct nix_tx_dr));
- /* Dump TX packet in to NPA buffer */
- packet = (void *)npa_aura_op_alloc(nix->npa, NPA_POOL_TX);
- if (!packet) {
printf("%s TX buffers unavailable\n", __func__);
return -1;
- memcpy(packet, pkt, pkt_len);
- debug("%s TX buffer %p\n", __func__, packet);
- tx_dr.hdr.s.aura = NPA_POOL_TX;
- tx_dr.hdr.s.df = 0;
- tx_dr.hdr.s.pnc = 1;
- tx_dr.hdr.s.sq = 0;
- tx_dr.hdr.s.total = pkt_len;
- tx_dr.hdr.s.sizem1 = dr_sz - 2; /* FIXME - for now hdr+sg+sg1addr */
- debug("%s dr_sz %d\n", __func__, dr_sz);
- tx_dr.tx_sg.s.segs = 1;
- tx_dr.tx_sg.s.subdc = NIX_SUBDC_E_SG;
- tx_dr.tx_sg.s.seg1_size = pkt_len;
- tx_dr.tx_sg.s.ld_type = NIX_SENDLDTYPE_E_LDT;
- tx_dr.sg1_addr = (dma_addr_t)packet;
+#define DEBUG_PKT +#ifdef DEBUG_PKT
- debug("TX PKT Data\n");
- for (int i = 0; i < pkt_len; i++) {
if (i && (i % 8 == 0))
debug("\n");
debug("%02x ", *((u8 *)pkt + i));
- debug("\n");
- do {
nix_write_lmt(nix, &tx_dr, (dr_sz - 1) * 2);
__iowmb();
result = lmt_submit((u64)(nix->nix_base +
NIXX_LF_OP_SENDX(0)));
WATCHDOG_RESET();
- } while (result == 0);
+/* RX */ +void nix_lf_flush_rx(struct udevice *dev) +{
- void *cq_rx_base = nix->cq[NIX_CQ_RX].base;
- struct nix_rx_dr *rx_dr;
- union nix_rx_parse_s *rxparse;
- u32 head, tail;
- u32 rx_cqe_sz = nix->cq[NIX_CQ_RX].entry_sz;
- u64 *seg;
- /* flush rx cqe entries */
- op_status.u = nix_cq_op_status(nix, NIX_CQ_RX);
- head &= (nix->cq[NIX_CQ_RX].qsize - 1);
- tail &= (nix->cq[NIX_CQ_RX].qsize - 1);
- debug("%s cq rx head %d tail %d\n", __func__, head, tail);
rx_dr = (struct nix_rx_dr *)cq_rx_base + head * rx_cqe_sz;
rxparse = &rx_dr->rx_parse;
debug("%s: rx parse: %p\n", __func__, rxparse);
debug("%s: rx parse: desc_sizem1 %x pkt_lenm1 %x\n",
__func__, rxparse->s.desc_sizem1, rxparse->s.pkt_lenm1);
seg = (dma_addr_t *)(&rx_dr->rx_sg + 1);
st128(nix->npa->npa_base + NPA_LF_AURA_OP_FREE0(),
seg[0], (1ULL << 63) | NPA_POOL_RX);
debug("%s return %llx to NPA\n", __func__, seg[0]);
(NIX_CQ_RX << 32) | 1);
+int nix_lf_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len) +{
- /* Return rx packet to NPA */
- debug("%s return %p to NPA\n", __func__, pkt);
- st128(nix->npa->npa_base + NPA_LF_AURA_OP_FREE0(), (u64)pkt,
+int nix_lf_recv(struct udevice *dev, int flags, uchar **packetp) +{
- void *pkt, *cqe;
- int pkt_len = 0;
- u64 *addr;
- u32 head, tail;
- /* fetch rx cqe entries */
- if (head == tail)
return -EAGAIN;
- debug("%s: rx_base %p head %d sz %d\n", __func__, cq_rx_base, head,
nix->cq[NIX_CQ_RX].entry_sz);
- cqe = cq_rx_base + head * nix->cq[NIX_CQ_RX].entry_sz;
- rx_dr = (struct nix_rx_dr *)cqe;
- rxparse = &rx_dr->rx_parse;
- debug("%s: rx completion: %p\n", __func__, cqe);
- debug("%s: rx dr: %p\n", __func__, rx_dr);
- debug("%s: rx parse: %p\n", __func__, rxparse);
- debug("%s: rx parse: desc_sizem1 %x pkt_lenm1 %x\n",
- debug("%s: rx parse: pkind %x chan %x\n",
__func__, rxparse->s.pkind, rxparse->s.chan);
- if (rx_dr->hdr.s.cqe_type != NIX_XQE_TYPE_E_RX) {
printf("%s: Error: Unsupported CQ header type in Rx %d\n",
__func__, rx_dr->hdr.s.cqe_type);
return -1;
- pkt_len = rxparse->s.pkt_lenm1 + 1;
- addr = (dma_addr_t *)(&rx_dr->rx_sg + 1);
- pkt = (void *)addr[0];
- debug("%s: segs: %d (%d@0x%llx, %d@0x%llx, %d@0x%llx)\n", __func__,
rx_dr->rx_sg.s.segs, rx_dr->rx_sg.s.seg1_size, addr[0],
rx_dr->rx_sg.s.seg2_size, addr[1],
rx_dr->rx_sg.s.seg3_size, addr[2]);
- if (pkt_len < rx_dr->rx_sg.s.seg1_size + rx_dr->rx_sg.s.seg2_size +
rx_dr->rx_sg.s.seg3_size) {
debug("%s: Error: rx buffer size too small\n", __func__);
return -1;
- __iowmb();
- debug("RX PKT Data\n");
debug("\n");
- debug("\n");
- *packetp = (uchar *)pkt;
- return pkt_len;
+int nix_lf_setup_mac(struct udevice *dev) +{
- struct eth_pdata *pdata = dev_get_platdata(dev);
- /* If lower level firmware fails to set proper MAC
* u-boot framework updates MAC to random address.
* Use this hook to update mac address in cgx lmac
* and call mac filter setup to update new address.
- if (memcmp(nix->lmac->mac_addr, pdata->enetaddr, ARP_HLEN)) {
memcpy(nix->lmac->mac_addr, pdata->enetaddr, 6);
pdata->enetaddr);
cgx_lmac_mac_filter_setup(nix->lmac);
/* Update user given MAC address to ATF for update
* in sh_fwdata to use in Linux.
cgx_intf_set_macaddr(dev);
debug("%s: lMAC %pM\n", __func__, nix->lmac->mac_addr);
debug("%s: pMAC %pM\n", __func__, pdata->enetaddr);
- debug("%s: setupMAC %pM\n", __func__, pdata->enetaddr);
+void nix_lf_halt(struct udevice *dev) +{
- cgx_lmac_rx_tx_enable(nix->lmac, nix->lmac->lmac_id, false);
- mdelay(1);
- /* Flush tx and rx descriptors */
- nix_lf_flush_rx(dev);
+int nix_lf_init(struct udevice *dev) +{
- struct lmac *lmac = nix->lmac;
- int ret;
- u64 link_sts;
- u8 link, speed;
- u16 errcode;
- printf("Waiting for CGX%d LMAC%d [%s] link status...",
lmac->cgx->cgx_id, lmac->lmac_id,
- if (lmac->init_pend) {
/* Bring up LMAC */
ret = cgx_lmac_link_enable(lmac, lmac->lmac_id,
true, &link_sts);
lmac->init_pend = 0;
- } else {
ret = cgx_lmac_link_status(lmac, lmac->lmac_id, &link_sts);
- if (ret) {
printf(" [Down]\n");
return -1;
- link = link_sts & 0x1;
- speed = (link_sts >> 2) & 0xf;
- errcode = (link_sts >> 6) & 0x2ff;
- debug("%s: link %x speed %x errcode %x\n",
__func__, link, speed, errcode);
- /* Print link status */
- printf(" [%s]\n", link ? lmac_speed_to_str[speed] : "Down");
- if (!link)
return -1;
- if (!lmac->init_pend)
cgx_lmac_rx_tx_enable(lmac, lmac->lmac_id, true);
+void nix_get_cgx_lmac_id(struct udevice *dev, int *cgxid, int *lmacid) +{
- *cgxid = lmac->cgx->cgx_id;
- *lmacid = lmac->lmac_id;
+void nix_print_mac_info(struct udevice *dev) +{
- printf(" CGX%d LMAC%d [%s]", lmac->cgx->cgx_id, lmac->lmac_id,
diff --git a/drivers/net/octeontx2/nix.h b/drivers/net/octeontx2/nix.h new file mode 100644 index 0000000000..03260dddb3 --- /dev/null +++ b/drivers/net/octeontx2/nix.h @@ -0,0 +1,353 @@ +/* SPDX-License-Identifier: GPL-2.0
+#ifndef __NIX_H__ +#define __NIX_H__
+#include <asm/arch/csrs/csrs-npa.h> +#include <asm/arch/csrs/csrs-nix.h> +#include "rvu.h"
+/** Maximum number of LMACs supported */ +#define MAX_LMAC 12
+/* NIX RX action operation*/ +#define NIX_RX_ACTIONOP_DROP (0x0ull) +#define NIX_RX_ACTIONOP_UCAST (0x1ull) +#define NIX_RX_ACTIONOP_UCAST_IPSEC (0x2ull) +#define NIX_RX_ACTIONOP_MCAST (0x3ull) +#define NIX_RX_ACTIONOP_RSS (0x4ull)
+/* NIX TX action operation*/ +#define NIX_TX_ACTIONOP_DROP (0x0ull) +#define NIX_TX_ACTIONOP_UCAST_DEFAULT (0x1ull) +#define NIX_TX_ACTIONOP_UCAST_CHAN (0x2ull) +#define NIX_TX_ACTIONOP_MCAST (0x3ull) +#define NIX_TX_ACTIONOP_DROP_VIOL (0x5ull)
+#define NIX_INTF_RX 0 +#define NIX_INTF_TX 1
+#define NIX_INTF_TYPE_CGX 0 +#define NIX_INTF_TYPE_LBK 1 +#define NIX_MAX_HW_MTU 9212 +#define NIX_MIN_HW_MTU 40 +#define MAX_MTU 1536
+#define NPA_POOL_COUNT 3 +#define NPA_AURA_COUNT(x) (1ULL << ((x) + 6)) +#define NPA_POOL_RX 0ULL +#define NPA_POOL_TX 1ULL +#define NPA_POOL_SQB 2ULL +#define RQ_QLEN Q_COUNT(Q_SIZE_1K) +#define SQ_QLEN Q_COUNT(Q_SIZE_1K) +#define SQB_QLEN Q_COUNT(Q_SIZE_16)
+#define NIX_CQ_RX 0ULL +#define NIX_CQ_TX 1ULL +#define NIX_CQ_COUNT 2ULL +#define NIX_CQE_SIZE_W16 (16 * sizeof(u64)) +#define NIX_CQE_SIZE_W64 (64 * sizeof(u64))
+/** Size of aura hardware context */ +#define NPA_AURA_HW_CTX_SIZE 48 +/** Size of pool hardware context */ +#define NPA_POOL_HW_CTX_SIZE 64
+#define NPA_DEFAULT_PF_FUNC 0xffff
+#define NIX_CHAN_CGX_LMAC_CHX(a, b, c) (0x800 + 0x100 * (a) + 0x10 * (b) + (c)) +#define NIX_LINK_CGX_LMAC(a, b) (0 + 4 * (a) + (b)) +#define NIX_LINK_LBK(a) (12 + (a)) +#define NIX_CHAN_LBK_CHX(a, b) (0 + 0x100 * (a) + (b)) +#define MAX_LMAC_PKIND 12
+/** Number of Admin queue entries */ +#define AQ_RING_SIZE Q_COUNT(Q_SIZE_16)
+/** Each completion queue contains 256 entries, see NIC_CQ_CTX_S[qsize] */ +#define CQS_QSIZE Q_SIZE_256 +#define CQ_ENTRIES Q_COUNT(CQS_QSIZE) +/**
- Each completion queue entry contains 128 bytes, see
- NIXX_AF_LFX_CFG[xqe_size]
+#define CQ_ENTRY_SIZE NIX_CQE_SIZE_W16
+enum npa_aura_size {
- NPA_AURA_SZ_0,
- NPA_AURA_SZ_128,
- NPA_AURA_SZ_256,
- NPA_AURA_SZ_512,
- NPA_AURA_SZ_1K,
- NPA_AURA_SZ_2K,
- NPA_AURA_SZ_4K,
- NPA_AURA_SZ_8K,
- NPA_AURA_SZ_16K,
- NPA_AURA_SZ_32K,
- NPA_AURA_SZ_64K,
- NPA_AURA_SZ_128K,
- NPA_AURA_SZ_256K,
- NPA_AURA_SZ_512K,
- NPA_AURA_SZ_1M,
- NPA_AURA_SZ_MAX,
+#define NPA_AURA_SIZE_DEFAULT NPA_AURA_SZ_128
+/* NIX Transmit schedulers */ +enum nix_scheduler {
- NIX_TXSCH_LVL_SMQ = 0x0,
- NIX_TXSCH_LVL_MDQ = 0x0,
- NIX_TXSCH_LVL_TL4 = 0x1,
- NIX_TXSCH_LVL_TL3 = 0x2,
- NIX_TXSCH_LVL_TL2 = 0x3,
- NIX_TXSCH_LVL_TL1 = 0x4,
- NIX_TXSCH_LVL_CNT = 0x5,
+struct cgx;
+struct nix_stats {
- u64 num_packets;
- u64 num_bytes;
+struct nix; +struct lmac;
+struct npa_af {
- void __iomem *npa_af_base;
- struct admin_queue aq;
- u32 aura;
+struct npa {
- struct npa_af *npa_af;
- void __iomem *npa_base;
- void __iomem *npc_base;
- void __iomem *lmt_base;
- /** Hardware aura context */
- void *aura_ctx;
- /** Hardware pool context */
- void *pool_ctx[NPA_POOL_COUNT];
- void *pool_stack[NPA_POOL_COUNT];
- void **buffers[NPA_POOL_COUNT];
- u32 pool_stack_pages[NPA_POOL_COUNT];
- u32 pool_stack_pointers;
- u32 q_len[NPA_POOL_COUNT];
- u32 buf_size[NPA_POOL_COUNT];
- u32 stack_pages[NPA_POOL_COUNT];
+struct nix_af {
- struct nix *lmacs[MAX_LMAC];
- void __iomem *nix_af_base;
- void __iomem *npc_af_base;
- u8 num_lmacs;
- s8 index;
- u8 xqe_size;
- u32 sqb_size;
- u32 qints;
- u32 cints;
- u32 sq_ctx_sz;
- u32 rq_ctx_sz;
- u32 cq_ctx_sz;
- u32 rsse_ctx_sz;
- u32 cint_ctx_sz;
- u32 qint_ctx_sz;
+struct nix_tx_dr {
- union nix_send_hdr_s hdr;
- union nix_send_sg_s tx_sg;
- dma_addr_t sg1_addr;
- dma_addr_t sg2_addr;
- dma_addr_t sg3_addr;
- u64 in_use;
+struct nix_rx_dr {
- union nix_cqe_hdr_s hdr;
- union nix_rx_parse_s rx_parse;
- union nix_rx_sg_s rx_sg;
+struct nix {
- struct eth_device *netdev;
- struct npa *npa;
- union nix_cint_hw_s *cint_base;
- union nix_cq_ctx_s *cq_ctx_base;
- union nix_qint_hw_s *qint_base;
- union nix_rq_ctx_s *rq_ctx_base;
- union nix_rsse_s *rss_base;
- union nix_sq_ctx_s *sq_ctx_base;
- void *cqe_base;
- struct qmem sq;
- struct qmem cq[NIX_CQ_COUNT];
- struct qmem rq;
- struct qmem rss;
- struct qmem cq_ints;
- struct qmem qints;
- char name[16];
- void __iomem *nix_base; /** PF reg base */
- struct nix_stats tx_stats;
- struct nix_stats rx_stats;
- u32 aura;
- int pknd;
- int lf;
- int pf;
- u16 pf_func;
- u32 rq_cnt; /** receive queues count */
- u32 sq_cnt; /** send queues count */
- u32 cq_cnt; /** completion queues count */
- u16 rss_sz;
- u16 sqb_size;
- u8 rss_grps;
- u8 xqe_sz;
+struct nix_aq_cq_dis {
- union nix_aq_res_s resp ALIGNED;
- union nix_cq_ctx_s cq ALIGNED;
- union nix_cq_ctx_s mcq ALIGNED;
+struct nix_aq_rq_dis {
- union nix_rq_ctx_s rq ALIGNED;
- union nix_rq_ctx_s mrq ALIGNED;
+struct nix_aq_sq_dis {
- union nix_sq_ctx_s sq ALIGNED;
- union nix_sq_ctx_s msq ALIGNED;
+struct nix_aq_cq_request {
+struct nix_aq_rq_request {
+struct nix_aq_sq_request {
+static inline u64 nix_af_reg_read(struct nix_af *nix_af, u64 offset) +{
- u64 val = readq(nix_af->nix_af_base + offset);
- debug("%s reg %p val %llx\n", __func__, nix_af->nix_af_base + offset,
val);
- return val;
+static inline void nix_af_reg_write(struct nix_af *nix_af, u64 offset,
u64 val)
val);
- writeq(val, nix_af->nix_af_base + offset);
+static inline u64 nix_pf_reg_read(struct nix *nix, u64 offset) +{
- u64 val = readq(nix->nix_base + offset);
- debug("%s reg %p val %llx\n", __func__, nix->nix_base + offset,
val);
- return val;
+static inline void nix_pf_reg_write(struct nix *nix, u64 offset,
u64 val)
val);
- writeq(val, nix->nix_base + offset);
+static inline u64 npa_af_reg_read(struct npa_af *npa_af, u64 offset) +{
- u64 val = readq(npa_af->npa_af_base + offset);
- debug("%s reg %p val %llx\n", __func__, npa_af->npa_af_base + offset,
val);
- return val;
+static inline void npa_af_reg_write(struct npa_af *npa_af, u64 offset,
u64 val)
val);
- writeq(val, npa_af->npa_af_base + offset);
+static inline u64 npc_af_reg_read(struct nix_af *nix_af, u64 offset) +{
- u64 val = readq(nix_af->npc_af_base + offset);
- debug("%s reg %p val %llx\n", __func__, nix_af->npc_af_base + offset,
val);
- return val;
+static inline void npc_af_reg_write(struct nix_af *nix_af, u64 offset,
u64 val)
val);
- writeq(val, nix_af->npc_af_base + offset);
+int npa_attach_aura(struct nix_af *nix_af, int lf,
const union npa_aura_s *desc, u32 aura_id);
+int npa_attach_pool(struct nix_af *nix_af, int lf,
const union npa_pool_s *desc, u32 pool_id);
+int npa_af_setup(struct npa_af *npa_af); +int npa_af_shutdown(struct npa_af *npa_af); +int npa_lf_setup(struct nix *nix); +int npa_lf_shutdown(struct nix *nix); +int npa_lf_admin_setup(struct npa *npa, int lf, dma_addr_t aura_base); +int npa_lf_admin_shutdown(struct nix_af *nix_af, int lf, u32 pool_count);
+int npc_lf_admin_setup(struct nix *nix); +int npc_af_shutdown(struct nix_af *nix_af);
+int nix_af_setup(struct nix_af *nix_af); +int nix_af_shutdown(struct nix_af *nix_af); +int nix_lf_setup(struct nix *nix); +int nix_lf_shutdown(struct nix *nix); +struct nix *nix_lf_alloc(struct udevice *dev); +int nix_lf_admin_setup(struct nix *nix); +int nix_lf_admin_shutdown(struct nix_af *nix_af, int lf,
u32 cq_count, u32 rq_count, u32 sq_count);
+struct rvu_af *get_af(void);
+int nix_lf_setup_mac(struct udevice *dev); +int nix_lf_read_rom_mac(struct udevice *dev); +void nix_lf_halt(struct udevice *dev); +int nix_lf_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len); +int nix_lf_recv(struct udevice *dev, int flags, uchar **packetp); +int nix_lf_init(struct udevice *dev); +int nix_lf_xmit(struct udevice *dev, void *pkt, int pkt_len);
+#endif /* __NIX_H__ */ diff --git a/drivers/net/octeontx2/nix_af.c b/drivers/net/octeontx2/nix_af.c new file mode 100644 index 0000000000..d513917ee7 --- /dev/null +++ b/drivers/net/octeontx2/nix_af.c @@ -0,0 +1,1102 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <memalign.h> +#include <misc.h> +#include <net.h> +#include <pci.h> +#include <watchdog.h> +#include <linux/types.h> +#include <linux/list.h> +#include <linux/log2.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-npc.h> +#include <asm/arch/csrs/csrs-lmt.h> +#include <asm/io.h>
+static struct nix_aq_cq_dis cq_dis ALIGNED; +static struct nix_aq_rq_dis rq_dis ALIGNED; +static struct nix_aq_sq_dis sq_dis ALIGNED;
- NPA API
- struct npa_af *npa = nix_af->npa_af;
- union npa_aq_inst_s *inst;
- union npa_aq_res_s *res;
- union npa_af_aq_status aq_stat;
- union npa_aura_s *context;
- u64 head;
- ulong start;
- debug("%s(%p, %d, %p, %u)\n", __func__, nix_af, lf, desc, aura_id);
- aq_stat.u = npa_af_reg_read(npa, NPA_AF_AQ_STATUS());
- head = aq_stat.s.head_ptr;
- inst = (union npa_aq_inst_s *)(npa->aq.inst.base) + head;
- res = (union npa_aq_res_s *)(npa->aq.res.base);
- memset(inst, 0, sizeof(*inst));
- inst->s.lf = lf;
- inst->s.doneint = 0;
- inst->s.ctype = NPA_AQ_CTYPE_E_AURA;
- inst->s.op = NPA_AQ_INSTOP_E_INIT;
- inst->s.res_addr = npa->aq.res.iova;
- inst->s.cindex = aura_id;
- context = (union npa_aura_s *)(npa->aq.res.base +
CONFIG_SYS_CACHELINE_SIZE);
- memset(npa->aq.res.base, 0, npa->aq.res.entry_sz);
- memcpy(context, desc, sizeof(union npa_aura_s));
- __iowmb();
- npa_af_reg_write(npa, NPA_AF_AQ_DOOR(), 1);
- start = get_timer(0);
- while ((res->s.compcode == NPA_AQ_COMP_E_NOTDONE) &&
(get_timer(start) < 1000))
WATCHDOG_RESET();
- if (res->s.compcode != NPA_AQ_COMP_E_GOOD) {
printf("%s: Error: result 0x%x not good\n",
__func__, res->s.compcode);
return -1;
- u64 head;
- ulong start;
- debug("%s(%p, %d, %p, %u)\n", __func__, nix_af, lf, desc, pool_id);
- inst->s.cindex = pool_id;
- inst->s.lf = lf;
- inst->s.ctype = NPA_AQ_CTYPE_E_POOL;
- __iowmb();
WATCHDOG_RESET();
return -1;
+int npa_lf_admin_setup(struct npa *npa, int lf, dma_addr_t aura_base) +{
- union npa_af_lf_rst lf_rst;
- union npa_af_lfx_auras_cfg auras_cfg;
- struct npa_af *npa_af = npa->npa_af;
- debug("%s(%p, %d, 0x%llx)\n", __func__, npa_af, lf, aura_base);
- lf_rst.u = 0;
- lf_rst.s.exec = 1;
- lf_rst.s.lf = lf;
- npa_af_reg_write(npa_af, NPA_AF_LF_RST(), lf_rst.u);
- do {
lf_rst.u = npa_af_reg_read(npa_af, NPA_AF_LF_RST());
WATCHDOG_RESET();
- } while (lf_rst.s.exec);
- /* Set Aura size and enable caching of contexts */
- auras_cfg.u = npa_af_reg_read(npa_af, NPA_AF_LFX_AURAS_CFG(lf));
- auras_cfg.s.loc_aura_size = NPA_AURA_SIZE_DEFAULT; //FIXME aura_size;
- auras_cfg.s.caching = 1;
- auras_cfg.s.rmt_aura_size = 0;
- auras_cfg.s.rmt_aura_offset = 0;
- auras_cfg.s.rmt_lf = 0;
- npa_af_reg_write(npa_af, NPA_AF_LFX_AURAS_CFG(lf), auras_cfg.u);
- /* Configure aura HW context base */
- npa_af_reg_write(npa_af, NPA_AF_LFX_LOC_AURAS_BASE(lf),
aura_base);
+int npa_lf_admin_shutdown(struct nix_af *nix_af, int lf, u32 pool_count) +{
- int pool_id;
- u32 head;
- struct npa_aq_pool_request {
union npa_aq_res_s resp ALIGNED;
union npa_pool_s p0 ALIGNED;
union npa_pool_s p1 ALIGNED;
- } pool_req ALIGNED;
- struct npa_aq_aura_request {
union npa_aura_s a0 ALIGNED;
union npa_aura_s a1 ALIGNED;
- } aura_req ALIGNED;
- ulong start;
- for (pool_id = 0; pool_id < pool_count; pool_id++) {
res = &pool_req.resp;
inst->s.lf = lf;
inst->s.op = NPA_AQ_INSTOP_E_WRITE;
inst->s.res_addr = (u64)&pool_req.resp;
memset((void *)&pool_req, 0, sizeof(pool_req));
pool_req.p0.s.ena = 0;
pool_req.p1.s.ena = 1; /* Write mask */
__iowmb();
WATCHDOG_RESET();
printf("%s: Error: result 0x%x not good for lf %d\n"
" aura id %d", __func__, res->s.compcode, lf,
pool_id);
return -1;
debug("%s(LF %d, pool id %d) disabled\n", __func__, lf,
pool_id);
res = &aura_req.resp;
inst->s.lf = lf;
inst->s.res_addr = (u64)&aura_req.resp;
memset((void *)&aura_req, 0, sizeof(aura_req));
aura_req.a0.s.ena = 0;
aura_req.a1.s.ena = 1; /* Write mask */
__iowmb();
WATCHDOG_RESET();
pool_id);
return -1;
debug("%s(LF %d, aura id %d) disabled\n", __func__, lf,
pool_id);
- /* Reset the LF */
- lf_rst.u = 0;
- lf_rst.s.lf = lf;
- npa_af_reg_write(npa, NPA_AF_LF_RST(), lf_rst.u);
- do {
lf_rst.u = npa_af_reg_read(npa, NPA_AF_LF_RST());
WATCHDOG_RESET();
+int npa_af_setup(struct npa_af *npa_af) +{
- int err;
- union npa_af_gen_cfg npa_cfg;
- union npa_af_ndc_cfg ndc_cfg;
- union npa_af_aq_cfg aq_cfg;
- union npa_af_blk_rst blk_rst;
- err = rvu_aq_alloc(&npa_af->aq, Q_COUNT(AQ_SIZE),
sizeof(union npa_aq_inst_s),
sizeof(union npa_aq_res_s));
- if (err) {
printf("%s: Error %d allocating admin queue\n", __func__, err);
return err;
- debug("%s: NPA admin queue allocated at %p %llx\n", __func__,
npa_af->aq.inst.base, npa_af->aq.inst.iova);
- blk_rst.u = 0;
- blk_rst.s.rst = 1;
- npa_af_reg_write(npa_af, NPA_AF_BLK_RST(), blk_rst.u);
- /* Wait for reset to complete */
- do {
blk_rst.u = npa_af_reg_read(npa_af, NPA_AF_BLK_RST());
WATCHDOG_RESET();
- } while (blk_rst.s.busy);
- /* Set little Endian */
- npa_cfg.u = npa_af_reg_read(npa_af, NPA_AF_GEN_CFG());
- npa_cfg.s.af_be = 0;
- npa_af_reg_write(npa_af, NPA_AF_GEN_CFG(), npa_cfg.u);
- /* Enable NDC cache */
- ndc_cfg.u = npa_af_reg_read(npa_af, NPA_AF_NDC_CFG());
- ndc_cfg.s.ndc_bypass = 0;
- npa_af_reg_write(npa_af, NPA_AF_NDC_CFG(), ndc_cfg.u);
- /* Set up queue size */
- aq_cfg.u = npa_af_reg_read(npa_af, NPA_AF_AQ_CFG());
- aq_cfg.s.qsize = AQ_SIZE;
- npa_af_reg_write(npa_af, NPA_AF_AQ_CFG(), aq_cfg.u);
- /* Set up queue base address */
- npa_af_reg_write(npa_af, NPA_AF_AQ_BASE(), npa_af->aq.inst.iova);
+int npa_af_shutdown(struct npa_af *npa_af) +{
- blk_rst.u = 0;
- do {
WATCHDOG_RESET();
- rvu_aq_free(&npa_af->aq);
- debug("%s: npa af reset --\n", __func__);
- NIX API
- Setup SMQ -> TL4 -> TL3 -> TL2 -> TL1 -> MAC mapping
- @param nix Handle to setup
- @return 0, or negative on failure
+static int nix_af_setup_sq(struct nix *nix) +{
- union nixx_af_tl1x_schedule tl1_sched;
- union nixx_af_tl2x_parent tl2_parent;
- union nixx_af_tl3x_parent tl3_parent;
- union nixx_af_tl3_tl2x_cfg tl3_tl2_cfg;
- union nixx_af_tl3_tl2x_linkx_cfg tl3_tl2_link_cfg;
- union nixx_af_tl4x_parent tl4_parent;
- union nixx_af_tl4x_sdp_link_cfg tl4_sdp_link_cfg;
- union nixx_af_smqx_cfg smq_cfg;
- union nixx_af_mdqx_schedule mdq_sched;
- union nixx_af_mdqx_parent mdq_parent;
- union nixx_af_rx_linkx_cfg link_cfg;
- int tl1_index = nix->lmac->link_num; /* NIX_LINK_E enum */
- int tl2_index = tl1_index;
- int tl3_index = tl2_index;
- int tl4_index = tl3_index;
- int smq_index = tl4_index;
- u64 offset = 0;
- tl1_sched.u = nix_af_reg_read(nix_af,
NIXX_AF_TL1X_SCHEDULE(tl1_index));
- tl1_sched.s.rr_quantum = MAX_MTU;
- nix_af_reg_write(nix_af, NIXX_AF_TL1X_SCHEDULE(tl1_index),
tl1_sched.u);
- tl2_parent.u = nix_af_reg_read(nix_af,
NIXX_AF_TL2X_PARENT(tl2_index));
- tl2_parent.s.parent = tl1_index;
- nix_af_reg_write(nix_af, NIXX_AF_TL2X_PARENT(tl2_index),
tl2_parent.u);
- tl3_parent.u = nix_af_reg_read(nix_af,
NIXX_AF_TL3X_PARENT(tl3_index));
- tl3_parent.s.parent = tl2_index;
- nix_af_reg_write(nix_af, NIXX_AF_TL3X_PARENT(tl3_index),
tl3_parent.u);
- tl3_tl2_cfg.u = nix_af_reg_read(nix_af,
NIXX_AF_TL3_TL2X_CFG(tl3_index));
- tl3_tl2_cfg.s.express = 0;
- nix_af_reg_write(nix_af, NIXX_AF_TL3_TL2X_CFG(tl3_index),
tl3_tl2_cfg.u);
- offset = NIXX_AF_TL3_TL2X_LINKX_CFG(tl3_index,
nix->lmac->link_num);
- tl3_tl2_link_cfg.u = nix_af_reg_read(nix_af, offset);
- tl3_tl2_link_cfg.s.bp_ena = 1;
- tl3_tl2_link_cfg.s.ena = 1;
- tl3_tl2_link_cfg.s.relchan = 0;
- nix_af_reg_write(nix_af, offset, tl3_tl2_link_cfg.u);
- tl4_parent.u = nix_af_reg_read(nix_af,
NIXX_AF_TL4X_PARENT(tl4_index));
- tl4_parent.s.parent = tl3_index;
- nix_af_reg_write(nix_af, NIXX_AF_TL4X_PARENT(tl4_index),
tl4_parent.u);
- offset = NIXX_AF_TL4X_SDP_LINK_CFG(tl4_index);
- tl4_sdp_link_cfg.u = nix_af_reg_read(nix_af, offset);
- tl4_sdp_link_cfg.s.bp_ena = 0;
- tl4_sdp_link_cfg.s.ena = 0;
- tl4_sdp_link_cfg.s.relchan = 0;
- nix_af_reg_write(nix_af, offset, tl4_sdp_link_cfg.u);
- smq_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_SMQX_CFG(smq_index));
- smq_cfg.s.express = 0;
- smq_cfg.s.lf = nix->lf;
- smq_cfg.s.desc_shp_ctl_dis = 1;
- smq_cfg.s.maxlen = MAX_MTU;
- smq_cfg.s.minlen = NIX_MIN_HW_MTU;
- nix_af_reg_write(nix_af, NIXX_AF_SMQX_CFG(smq_index), smq_cfg.u);
- mdq_sched.u = nix_af_reg_read(nix_af,
NIXX_AF_MDQX_SCHEDULE(smq_index));
- mdq_sched.s.rr_quantum = MAX_MTU;
- offset = NIXX_AF_MDQX_SCHEDULE(smq_index);
- nix_af_reg_write(nix_af, offset, mdq_sched.u);
- mdq_parent.u = nix_af_reg_read(nix_af,
NIXX_AF_MDQX_PARENT(smq_index));
- mdq_parent.s.parent = tl4_index;
- nix_af_reg_write(nix_af, NIXX_AF_MDQX_PARENT(smq_index),
mdq_parent.u);
- link_cfg.u = 0;
- link_cfg.s.maxlen = NIX_MAX_HW_MTU;
- link_cfg.s.minlen = NIX_MIN_HW_MTU;
- nix_af_reg_write(nix->nix_af,
NIXX_AF_RX_LINKX_CFG(nix->lmac->link_num),
link_cfg.u);
- Issue a command to the NIX AF Admin Queue
- @param nix nix handle
- @param lf Logical function number for command
- @param op Operation
- @param ctype Context type
- @param cindex Context index
- @param resp Result pointer
- @return 0 for success, -EBUSY on failure
+static int nix_aq_issue_command(struct nix_af *nix_af,
int lf,
int op,
int ctype,
int cindex, union nix_aq_res_s *resp)
- union nixx_af_aq_status aq_status;
- union nix_aq_inst_s *aq_inst;
- union nix_aq_res_s *result = resp;
- ulong start;
- debug("%s(%p, 0x%x, 0x%x, 0x%x, 0x%x, %p)\n", __func__, nix_af, lf,
op, ctype, cindex, resp);
- aq_status.u = nix_af_reg_read(nix_af, NIXX_AF_AQ_STATUS());
- aq_inst = (union nix_aq_inst_s *)(nix_af->aq.inst.base) +
aq_status.s.head_ptr;
- aq_inst->u[0] = 0;
- aq_inst->u[1] = 0;
- aq_inst->s.op = op;
- aq_inst->s.ctype = ctype;
- aq_inst->s.lf = lf;
- aq_inst->s.cindex = cindex;
- aq_inst->s.doneint = 0;
- aq_inst->s.res_addr = (u64)resp;
- debug("%s: inst@%p: 0x%llx 0x%llx\n", __func__, aq_inst,
aq_inst->u[0], aq_inst->u[1]);
- __iowmb();
- /* Ring doorbell and wait for result */
- nix_af_reg_write(nix_af, NIXX_AF_AQ_DOOR(), 1);
- /* Wait for completion */
- do {
WATCHDOG_RESET();
dsb();
- } while (result->s.compcode == 0 && get_timer(start) < 2);
- if (result->s.compcode != NIX_AQ_COMP_E_GOOD) {
printf("NIX:AQ fail or time out with code %d after %ld ms\n",
result->s.compcode, get_timer(start));
return -EBUSY;
+static int nix_attach_receive_queue(struct nix_af *nix_af, int lf) +{
- struct nix_aq_rq_request rq_req ALIGNED;
- int err;
- debug("%s(%p, %d)\n", __func__, nix_af, lf);
- memset(&rq_req, 0, sizeof(struct nix_aq_rq_request));
- rq_req.rq.s.ena = 1;
- rq_req.rq.s.spb_ena = 1;
- rq_req.rq.s.ipsech_ena = 0;
- rq_req.rq.s.ena_wqwd = 0;
- rq_req.rq.s.cq = NIX_CQ_RX;
- rq_req.rq.s.substream = 0; /* FIXME: Substream IDs? */
- rq_req.rq.s.wqe_aura = -1; /* No WQE aura */
- rq_req.rq.s.spb_aura = NPA_POOL_RX;
- rq_req.rq.s.lpb_aura = NPA_POOL_RX;
- /* U-Boot doesn't use WQE group for anything */
- rq_req.rq.s.pb_caching = 1;
- rq_req.rq.s.xqe_drop_ena = 0; /* Disable RED dropping */
- rq_req.rq.s.spb_drop_ena = 0;
- rq_req.rq.s.lpb_drop_ena = 0;
- rq_req.rq.s.spb_sizem1 = (MAX_MTU / (3 * 8)) - 1; /* 512 bytes */
- rq_req.rq.s.lpb_sizem1 = (MAX_MTU / 8) - 1;
- rq_req.rq.s.first_skip = 0;
- rq_req.rq.s.later_skip = 0;
- rq_req.rq.s.xqe_imm_copy = 0;
- rq_req.rq.s.xqe_hdr_split = 0;
- rq_req.rq.s.xqe_drop = 0;
- rq_req.rq.s.xqe_pass = 0;
- rq_req.rq.s.wqe_pool_drop = 0; /* No WQE pool */
- rq_req.rq.s.wqe_pool_pass = 0; /* No WQE pool */
- rq_req.rq.s.spb_aura_drop = 255;
- rq_req.rq.s.spb_aura_pass = 255;
- rq_req.rq.s.spb_pool_drop = 0;
- rq_req.rq.s.spb_pool_pass = 0;
- rq_req.rq.s.lpb_aura_drop = 255;
- rq_req.rq.s.lpb_aura_pass = 255;
- rq_req.rq.s.lpb_pool_drop = 0;
- rq_req.rq.s.lpb_pool_pass = 0;
- rq_req.rq.s.qint_idx = 0;
- err = nix_aq_issue_command(nix_af, lf,
NIX_AQ_INSTOP_E_INIT,
NIX_AQ_CTYPE_E_RQ,
0, &rq_req.resp);
- if (err) {
printf("%s: Error requesting send queue\n", __func__);
return err;
+static int nix_attach_send_queue(struct nix *nix) +{
- struct nix_aq_sq_request sq_req ALIGNED;
- int err;
- debug("%s(%p)\n", __func__, nix_af);
- err = nix_af_setup_sq(nix);
- memset(&sq_req, 0, sizeof(sq_req));
- sq_req.sq.s.ena = 1;
- sq_req.sq.s.cq_ena = 1;
- sq_req.sq.s.max_sqe_size = NIX_MAXSQESZ_E_W16;
- sq_req.sq.s.substream = 0; // FIXME: Substream IDs?
- sq_req.sq.s.sdp_mcast = 0;
- sq_req.sq.s.cq = NIX_CQ_TX;
- sq_req.sq.s.cq_limit = 0;
- sq_req.sq.s.smq = nix->lmac->link_num; // scheduling index
- sq_req.sq.s.sso_ena = 0;
- sq_req.sq.s.smq_rr_quantum = MAX_MTU / 4;
- sq_req.sq.s.default_chan = nix->lmac->chan_num;
- sq_req.sq.s.sqe_stype = NIX_STYPE_E_STP;
- sq_req.sq.s.qint_idx = 0;
- sq_req.sq.s.sqb_aura = NPA_POOL_SQB;
- err = nix_aq_issue_command(nix_af, nix->lf,
NIX_AQ_CTYPE_E_SQ,
0, &sq_req.resp);
- if (err) {
return err;
+static int nix_attach_completion_queue(struct nix *nix, int cq_idx) +{
- struct nix_aq_cq_request cq_req ALIGNED;
- int err;
- memset(&cq_req, 0, sizeof(cq_req));
- cq_req.cq.s.ena = 1;
- cq_req.cq.s.bpid = nix->lmac->pknd;
- cq_req.cq.s.substream = 0; /* FIXME: Substream IDs? */
- cq_req.cq.s.drop_ena = 0;
- cq_req.cq.s.caching = 1;
- cq_req.cq.s.qsize = CQS_QSIZE;
- cq_req.cq.s.drop = 255 * 7 / 8;
- cq_req.cq.s.qint_idx = 0;
- cq_req.cq.s.cint_idx = 0;
- cq_req.cq.s.base = nix->cq[cq_idx].iova;
- debug("%s: CQ(%d) base %p\n", __func__, cq_idx,
nix->cq[cq_idx].base);
NIX_AQ_CTYPE_E_CQ,
cq_idx, &cq_req.resp);
- if (err) {
printf("%s: Error requesting completion queue\n", __func__);
return err;
- debug("%s: CQ(%d) allocated, base %p\n", __func__, cq_idx,
+int nix_lf_admin_setup(struct nix *nix) +{
- union nixx_af_lfx_rqs_cfg rqs_cfg;
- union nixx_af_lfx_sqs_cfg sqs_cfg;
- union nixx_af_lfx_cqs_cfg cqs_cfg;
- union nixx_af_lfx_rss_cfg rss_cfg;
- union nixx_af_lfx_cints_cfg cints_cfg;
- union nixx_af_lfx_qints_cfg qints_cfg;
- union nixx_af_lfx_rss_grpx rss_grp;
- union nixx_af_lfx_tx_cfg2 tx_cfg2;
- union nixx_af_lfx_cfg lfx_cfg;
- union nixx_af_lf_rst lf_rst;
- u32 index;
- int err;
- lf_rst.u = 0;
- lf_rst.s.lf = nix->lf;
- nix_af_reg_write(nix_af, NIXX_AF_LF_RST(), lf_rst.u);
- do {
lf_rst.u = nix_af_reg_read(nix_af, NIXX_AF_LF_RST());
WATCHDOG_RESET();
- /* Config NIX RQ HW context and base*/
- nix_af_reg_write(nix_af, NIXX_AF_LFX_RQS_BASE(nix->lf),
(u64)nix->rq_ctx_base);
- /* Set caching and queue count in HW */
- rqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_RQS_CFG(nix->lf));
- rqs_cfg.s.caching = 1;
- rqs_cfg.s.max_queuesm1 = nix->rq_cnt - 1;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_RQS_CFG(nix->lf), rqs_cfg.u);
- /* Config NIX SQ HW context and base*/
- nix_af_reg_write(nix_af, NIXX_AF_LFX_SQS_BASE(nix->lf),
(u64)nix->sq_ctx_base);
- sqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_SQS_CFG(nix->lf));
- sqs_cfg.s.caching = 1;
- sqs_cfg.s.max_queuesm1 = nix->sq_cnt - 1;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_SQS_CFG(nix->lf), sqs_cfg.u);
- /* Config NIX CQ HW context and base*/
- nix_af_reg_write(nix_af, NIXX_AF_LFX_CQS_BASE(nix->lf),
(u64)nix->cq_ctx_base);
- cqs_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_CQS_CFG(nix->lf));
- cqs_cfg.s.caching = 1;
- cqs_cfg.s.max_queuesm1 = nix->cq_cnt - 1;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_CQS_CFG(nix->lf), cqs_cfg.u);
- /* Config NIX RSS HW context and base */
- nix_af_reg_write(nix_af, NIXX_AF_LFX_RSS_BASE(nix->lf),
(u64)nix->rss_base);
- rss_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_RSS_CFG(nix->lf));
- rss_cfg.s.ena = 1;
- rss_cfg.s.size = ilog2(nix->rss_sz) / 256;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_RSS_CFG(nix->lf), rss_cfg.u);
- for (index = 0; index < nix->rss_grps; index++) {
rss_grp.u = 0;
rss_grp.s.sizem1 = 0x7;
rss_grp.s.offset = nix->rss_sz * index;
NIXX_AF_LFX_RSS_GRPX(nix->lf, index),
rss_grp.u);
- /* Config CQints HW contexts and base */
- nix_af_reg_write(nix_af, NIXX_AF_LFX_CINTS_BASE(nix->lf),
(u64)nix->cint_base);
- cints_cfg.u = nix_af_reg_read(nix_af,
NIXX_AF_LFX_CINTS_CFG(nix->lf));
- cints_cfg.s.caching = 1;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_CINTS_CFG(nix->lf),
cints_cfg.u);
- /* Config Qints HW context and base */
- nix_af_reg_write(nix_af, NIXX_AF_LFX_QINTS_BASE(nix->lf),
(u64)nix->qint_base);
- qints_cfg.u = nix_af_reg_read(nix_af,
NIXX_AF_LFX_QINTS_CFG(nix->lf));
- qints_cfg.s.caching = 1;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_QINTS_CFG(nix->lf),
qints_cfg.u);
- debug("%s(%p, %d, %d)\n", __func__, nix_af, nix->lf, nix->pf);
- /* Enable LMTST for this NIX LF */
- tx_cfg2.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_TX_CFG2(nix->lf));
- tx_cfg2.s.lmt_ena = 1;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_TX_CFG2(nix->lf), tx_cfg2.u);
- /* Use 16-word XQEs, write the npa pf_func number only */
- lfx_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_LFX_CFG(nix->lf));
- lfx_cfg.s.xqe_size = NIX_XQESZ_E_W16;
- lfx_cfg.s.npa_pf_func = nix->pf_func;
- nix_af_reg_write(nix_af, NIXX_AF_LFX_CFG(nix->lf), lfx_cfg.u);
- nix_af_reg_write(nix_af, NIXX_AF_LFX_RX_CFG(nix->lf), 0);
- for (index = 0; index < nix->cq_cnt; index++) {
err = nix_attach_completion_queue(nix, index);
if (err) {
printf("%s: Error attaching completion queue %d\n",
__func__, index);
return err;
- for (index = 0; index < nix->rq_cnt; index++) {
err = nix_attach_receive_queue(nix_af, nix->lf);
if (err) {
printf("%s: Error attaching receive queue %d\n",
__func__, index);
return err;
- for (index = 0; index < nix->sq_cnt; index++) {
err = nix_attach_send_queue(nix);
if (err) {
printf("%s: Error attaching send queue %d\n",
__func__, index);
return err;
- union nixx_af_rx_sw_sync sw_sync;
- int index, err;
- /* Flush all tx packets */
- sw_sync.u = 0;
- sw_sync.s.ena = 1;
- nix_af_reg_write(nix_af, NIXX_AF_RX_SW_SYNC(), sw_sync.u);
- do {
sw_sync.u = nix_af_reg_read(nix_af, NIXX_AF_RX_SW_SYNC());
WATCHDOG_RESET();
- } while (sw_sync.s.ena);
- for (index = 0; index < rq_count; index++) {
memset((void *)&rq_dis, 0, sizeof(rq_dis));
rq_dis.rq.s.ena = 0; /* Context */
rq_dis.mrq.s.ena = 1; /* Mask */
__iowmb();
NIX_AQ_INSTOP_E_WRITE,
NIX_AQ_CTYPE_E_RQ,
index, &rq_dis.resp);
if (err) {
printf("%s: Error disabling LF %d RQ(%d)\n",
__func__, lf, index);
return err;
debug("%s: LF %d RQ(%d) disabled\n", __func__, lf, index);
- for (index = 0; index < sq_count; index++) {
memset((void *)&sq_dis, 0, sizeof(sq_dis));
sq_dis.sq.s.ena = 0; /* Context */
sq_dis.msq.s.ena = 1; /* Mask */
__iowmb();
NIX_AQ_CTYPE_E_SQ,
index, &sq_dis.resp);
if (err) {
printf("%s: Error disabling LF %d SQ(%d)\n",
return err;
debug("%s: LF %d SQ(%d) disabled\n", __func__, lf, index);
- for (index = 0; index < cq_count; index++) {
memset((void *)&cq_dis, 0, sizeof(cq_dis));
cq_dis.cq.s.ena = 0; /* Context */
cq_dis.mcq.s.ena = 1; /* Mask */
__iowmb();
NIX_AQ_CTYPE_E_CQ,
index, &cq_dis.resp);
if (err) {
printf("%s: Error disabling LF %d CQ(%d)\n",
return err;
debug("%s: LF %d CQ(%d) disabled\n", __func__, lf, index);
- lf_rst.u = 0;
- lf_rst.s.lf = lf;
- do {
WATCHDOG_RESET();
+int npc_lf_admin_setup(struct nix *nix) +{
- union npc_af_const af_const;
- union npc_af_pkindx_action0 action0;
- union npc_af_pkindx_action1 action1;
- union npc_af_intfx_kex_cfg kex_cfg;
- union npc_af_intfx_miss_stat_act intfx_stat_act;
- union npc_af_mcamex_bankx_camx_intf camx_intf;
- union npc_af_mcamex_bankx_camx_w0 camx_w0;
- union npc_af_mcamex_bankx_cfg bankx_cfg;
- union npc_af_mcamex_bankx_stat_act mcamex_stat_act;
- union nix_rx_action_s rx_action;
- union nix_tx_action_s tx_action;
- u32 kpus;
- int pkind = nix->lmac->link_num;
- int index;
- u64 offset;
- debug("%s(%p, pkind 0x%x)\n", __func__, nix_af, pkind);
- af_const.u = npc_af_reg_read(nix_af, NPC_AF_CONST());
- kpus = af_const.s.kpus;
- action0.u = 0;
- action0.s.parse_done = 1;
- npc_af_reg_write(nix_af, NPC_AF_PKINDX_ACTION0(pkind), action0.u);
- action1.u = 0;
- npc_af_reg_write(nix_af, NPC_AF_PKINDX_ACTION1(pkind), action1.u);
- kex_cfg.u = 0;
- kex_cfg.s.keyw = NPC_MCAMKEYW_E_X1;
- kex_cfg.s.parse_nibble_ena = 0x7;
NPC_AF_INTFX_KEX_CFG(NPC_INTF_E_NIXX_RX(0)),
kex_cfg.u);
- /* HW Issue */
- kex_cfg.u = 0;
NPC_AF_INTFX_KEX_CFG(NPC_INTF_E_NIXX_TX(0)),
kex_cfg.u);
- camx_intf.u = 0;
- camx_intf.s.intf = ~NPC_INTF_E_NIXX_RX(0);
NPC_AF_MCAMEX_BANKX_CAMX_INTF(pkind, 0, 0),
camx_intf.u);
- camx_intf.u = 0;
- camx_intf.s.intf = NPC_INTF_E_NIXX_RX(0);
NPC_AF_MCAMEX_BANKX_CAMX_INTF(pkind, 0, 1),
camx_intf.u);
- camx_w0.u = 0;
- camx_w0.s.md = ~(nix->lmac->chan_num) & (~((~0x0ull) << 12));
- debug("NPC LF ADMIN camx_w0.u %llx\n", camx_w0.u);
NPC_AF_MCAMEX_BANKX_CAMX_W0(pkind, 0, 0),
camx_w0.u);
- camx_w0.u = 0;
- camx_w0.s.md = nix->lmac->chan_num;
NPC_AF_MCAMEX_BANKX_CAMX_W0(pkind, 0, 1),
camx_w0.u);
- npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CAMX_W1(pkind, 0, 0),
0);
- npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CAMX_W1(pkind, 0, 1),
0);
- /* Enable stats for NPC INTF RX */
- mcamex_stat_act.u = 0;
- mcamex_stat_act.s.ena = 1;
- mcamex_stat_act.s.stat_sel = pkind;
NPC_AF_MCAMEX_BANKX_STAT_ACT(pkind, 0),
mcamex_stat_act.u);
- intfx_stat_act.u = 0;
- intfx_stat_act.s.ena = 1;
- intfx_stat_act.s.stat_sel = 16;
- offset = NPC_AF_INTFX_MISS_STAT_ACT(NPC_INTF_E_NIXX_RX(0));
- npc_af_reg_write(nix_af, offset, intfx_stat_act.u);
- rx_action.u = 0;
- rx_action.s.pf_func = nix->pf_func;
- rx_action.s.op = NIX_RX_ACTIONOP_E_UCAST;
- npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_ACTION(pkind, 0),
rx_action.u);
- for (index = 0; index < kpus; index++)
npc_af_reg_write(nix_af, NPC_AF_KPUX_CFG(index), 0);
- rx_action.u = 0;
- rx_action.s.op = NIX_RX_ACTIONOP_E_DROP;
NPC_AF_INTFX_MISS_ACT(NPC_INTF_E_NIXX_RX(0)),
rx_action.u);
- bankx_cfg.u = 0;
- bankx_cfg.s.ena = 1;
- npc_af_reg_write(nix_af, NPC_AF_MCAMEX_BANKX_CFG(pkind, 0),
bankx_cfg.u);
- tx_action.u = 0;
- tx_action.s.op = NIX_TX_ACTIONOP_E_UCAST_DEFAULT;
NPC_AF_INTFX_MISS_ACT(NPC_INTF_E_NIXX_TX(0)),
tx_action.u);
+#ifdef DEBUG
- /* Enable debug capture on RX intf */
- npc_af_reg_write(nix_af, NPC_AF_DBG_CTL(), 0x4);
+int npc_af_shutdown(struct nix_af *nix_af) +{
- union npc_af_blk_rst blk_rst;
- blk_rst.u = 0;
- npc_af_reg_write(nix_af, NPC_AF_BLK_RST(), blk_rst.u);
- do {
blk_rst.u = npc_af_reg_read(nix_af, NPC_AF_BLK_RST());
WATCHDOG_RESET();
- debug("%s: npc af reset --\n", __func__);
+int nix_af_setup(struct nix_af *nix_af) +{
- int err;
- union nixx_af_const2 af_const2;
- union nixx_af_const3 af_const3;
- union nixx_af_sq_const sq_const;
- union nixx_af_cfg af_cfg;
- union nixx_af_status af_status;
- union nixx_af_ndc_cfg ndc_cfg;
- union nixx_af_aq_cfg aq_cfg;
- union nixx_af_blk_rst blk_rst;
- err = rvu_aq_alloc(&nix_af->aq, Q_COUNT(AQ_SIZE),
sizeof(union nix_aq_inst_s),
sizeof(union nix_aq_res_s));
- if (err) {
printf("%s: Error allocating nix admin queue\n", __func__);
return err;
- blk_rst.u = 0;
- nix_af_reg_write(nix_af, NIXX_AF_BLK_RST(), blk_rst.u);
- do {
blk_rst.u = nix_af_reg_read(nix_af, NIXX_AF_BLK_RST());
WATCHDOG_RESET();
- /* Put in LE mode */
- af_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_CFG());
- if (af_cfg.s.force_cond_clk_en || af_cfg.s.calibrate_x2p ||
af_cfg.s.force_intf_clk_en) {
printf("%s: Error: Invalid NIX_AF_CFG value 0x%llx\n",
__func__, af_cfg.u);
return -1;
- af_cfg.s.af_be = 0;
- af_cfg.u |= 0x5E; /* HW Issue */
- nix_af_reg_write(nix_af, NIXX_AF_CFG(), af_cfg.u);
- /* Perform Calibration */
- af_cfg.s.calibrate_x2p = 1;
- /* Wait for calibration to complete */
- do {
af_status.u = nix_af_reg_read(nix_af, NIXX_AF_STATUS());
WATCHDOG_RESET();
- } while (af_status.s.calibrate_done == 0);
- af_cfg.s.calibrate_x2p = 0;
- ndc_cfg.u = nix_af_reg_read(nix_af, NIXX_AF_NDC_CFG());
- ndc_cfg.s.ndc_ign_pois = 0;
- ndc_cfg.s.byp_sq = 0;
- ndc_cfg.s.byp_sqb = 0;
- ndc_cfg.s.byp_cqs = 0;
- ndc_cfg.s.byp_cints = 0;
- ndc_cfg.s.byp_dyno = 0;
- ndc_cfg.s.byp_mce = 0;
- ndc_cfg.s.byp_rqc = 0;
- ndc_cfg.s.byp_rsse = 0;
- ndc_cfg.s.byp_mc_data = 0;
- ndc_cfg.s.byp_mc_wqe = 0;
- ndc_cfg.s.byp_mr_data = 0;
- ndc_cfg.s.byp_mr_wqe = 0;
- ndc_cfg.s.byp_qints = 0;
- nix_af_reg_write(nix_af, NIXX_AF_NDC_CFG(), ndc_cfg.u);
- aq_cfg.u = 0;
- nix_af_reg_write(nix_af, NIXX_AF_AQ_CFG(), aq_cfg.u);
- nix_af_reg_write(nix_af, NIXX_AF_AQ_BASE(), nix_af->aq.inst.iova);
- af_const3.u = nix_af_reg_read(nix_af, NIXX_AF_CONST3());
- af_const2.u = nix_af_reg_read(nix_af, NIXX_AF_CONST2());
- sq_const.u = nix_af_reg_read(nix_af, NIXX_AF_SQ_CONST());
- nix_af->rq_ctx_sz = 1ULL << af_const3.s.rq_ctx_log2bytes;
- nix_af->sq_ctx_sz = 1ULL << af_const3.s.sq_ctx_log2bytes;
- nix_af->cq_ctx_sz = 1ULL << af_const3.s.cq_ctx_log2bytes;
- nix_af->rsse_ctx_sz = 1ULL << af_const3.s.rsse_log2bytes;
- nix_af->qints = af_const2.s.qints;
- nix_af->cints = af_const2.s.cints;
- nix_af->cint_ctx_sz = 1ULL << af_const3.s.cint_log2bytes;
- nix_af->qint_ctx_sz = 1ULL << af_const3.s.qint_log2bytes;
- nix_af->sqb_size = sq_const.s.sqb_size;
+int nix_af_shutdown(struct nix_af *nix_af) +{
- blk_rst.u = 0;
- do {
WATCHDOG_RESET();
- rvu_aq_free(&nix_af->aq);
- debug("%s: nix af reset --\n", __func__);
+} diff --git a/drivers/net/octeontx2/npc.h b/drivers/net/octeontx2/npc.h new file mode 100644 index 0000000000..6e645cd32e --- /dev/null +++ b/drivers/net/octeontx2/npc.h @@ -0,0 +1,90 @@ +/* SPDX-License-Identifier: GPL-2.0
- Copyright (C) 2018 Marvell International Ltd.
+#ifndef __NPC_H__ +#define __NPC_H__
+#define RSVD_MCAM_ENTRIES_PER_PF 2 /** Ucast and Bcast */ +#define RSVD_MCAM_ENTRIES_PER_NIXLF 1 /** Ucast for VFs */
+struct npc_kpu_profile_cam {
- u8 state;
- u8 state_mask;
- u16 dp0;
- u16 dp0_mask;
- u16 dp1;
- u16 dp1_mask;
- u16 dp2;
- u16 dp2_mask;
+struct npc_kpu_profile_action {
- u8 errlev;
- u8 errcode;
- u8 dp0_offset;
- u8 dp1_offset;
- u8 dp2_offset;
- u8 bypass_count;
- u8 parse_done;
- u8 next_state;
- u8 ptr_advance;
- u8 cap_ena;
- u8 lid;
- u8 ltype;
- u8 flags;
- u8 offset;
- u8 mask;
- u8 right;
- u8 shift;
+struct npc_kpu_profile {
- int cam_entries;
- int action_entries;
- struct npc_kpu_profile_cam *cam;
- struct npc_kpu_profile_action *action;
+struct npc_pkind {
- struct rsrc_bmap rsrc;
- u32 *pfchan_map;
+struct npc_mcam {
- u16 *pfvf_map;
- u16 total_entries; /* Total number of MCAM entries */
- u16 entries; /* Total - reserved for NIX LFs */
- u8 banks_per_entry; /* Number of keywords in key */
- u8 keysize;
- u8 banks; /* Number of MCAM banks */
- u16 banksize; /* Number of MCAM entries in each bank */
- u16 counters; /* Number of match counters */
- u16 nixlf_offset;
- u16 pf_offset;
+struct nix_af_handle; +struct nix_handle; +struct rvu_hwinfo;
+struct npc_af {
- struct nix_af_handle *nix_af;
- struct npc_pkind pkind;
- u8 npc_kpus; /** Number of parser units */
- struct npc_mcam mcam;
- struct rvu_block block;
- struct rvu_hwinfo *hw;
+struct npc {
- struct npc_af *npc_af;
- struct nix_handle *nix;
+#endif /* __NPC_H__ */
diff --git a/drivers/net/octeontx2/rvu.h b/drivers/net/octeontx2/rvu.h new file mode 100644 index 0000000000..f455260a6f --- /dev/null +++ b/drivers/net/octeontx2/rvu.h @@ -0,0 +1,119 @@ +/* SPDX-License-Identifier: GPL-2.0
+#ifndef __RVU_H__ +#define __RVU_H__
+#include <asm/arch/csrs/csrs-rvu.h>
+#define ALIGNED __aligned(CONFIG_SYS_CACHELINE_SIZE)
+#define Q_SIZE_16 0ULL /* 16 entries */ +#define Q_SIZE_64 1ULL /* 64 entries */ +#define Q_SIZE_256 2ULL +#define Q_SIZE_1K 3ULL +#define Q_SIZE_4K 4ULL +#define Q_SIZE_16K 5ULL +#define Q_SIZE_64K 6ULL +#define Q_SIZE_256K 7ULL +#define Q_SIZE_1M 8ULL /* Million entries */ +#define Q_SIZE_MIN Q_SIZE_16 +#define Q_SIZE_MAX Q_SIZE_1M
+#define Q_COUNT(x) (16ULL << (2 * (x))) +#define Q_SIZE(x, n) ((ilog2(x) - (n)) / 2)
+/* Admin queue info */
+/* Since we intend to add only one instruction at a time,
- keep queue size to it's minimum.
+#define AQ_SIZE Q_SIZE_16 +/* HW head & tail pointer mask */ +#define AQ_PTR_MASK 0xFFFFF
+struct qmem {
- void *base;
- dma_addr_t iova;
- size_t alloc_sz;
- u32 qsize;
- u8 entry_sz;
+struct admin_queue {
- struct qmem inst;
- struct qmem res;
+struct rvu_af {
- struct udevice *dev;
- void __iomem *af_base;
- struct nix_af *nix_af;
+struct rvu_pf {
- struct udevice *afdev;
- void __iomem *pf_base;
- struct nix *nix;
- u8 pfid;
- int nix_lfid;
- int npa_lfid;
- Store 128 bit value
- @param[out] dest pointer to destination address
- @param val0 first 64 bits to write
- @param val1 second 64 bits to write
+static inline void st128(void *dest, u64 val0, u64 val1) +{
- __asm__ __volatile__("stp %x[x0], %x[x1], [%[pm]]" :
: [x0]"r"(val0), [x1]"r"(val1), [pm]"r"(dest)
: "memory");
- Load 128 bit value
- @param[in] source pointer to 128 bits of data to load
- @param[out] val0 first 64 bits of data
- @param[out] val1 second 64 bits of data
+static inline void ld128(const u64 *src, u64 *val0, u64 *val1) +{
- __asm__ __volatile__ ("ldp %x[x0], %x[x1], [%[pm]]" :
: [x0]"r"(*val0), [x1]"r"(*val1), [pm]"r"(src));
+void qmem_free(struct qmem *q); +int qmem_alloc(struct qmem *q, u32 qsize, size_t entry_sz);
- Allocates an admin queue for instructions and results
- @param aq admin queue to allocate for
- @param qsize Number of entries in the queue
- @param inst_size Size of each instruction
- @param res_size Size of each result
- @return -ENOMEM on error, 0 on success
+int rvu_aq_alloc(struct admin_queue *aq, unsigned int qsize,
size_t inst_size, size_t res_size);
- Frees an admin queue
- @param aq Admin queue to free
+void rvu_aq_free(struct admin_queue *aq);
+void rvu_get_lfid_for_pf(int pf, int *nixid, int *npaid);
+#endif /* __RVU_H__ */
diff --git a/drivers/net/octeontx2/rvu_af.c b/drivers/net/octeontx2/rvu_af.c new file mode 100644 index 0000000000..7750089a20 --- /dev/null +++ b/drivers/net/octeontx2/rvu_af.c @@ -0,0 +1,171 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <linux/list.h> +#include <asm/io.h> +#include <asm/arch/board.h> +#include <asm/arch/csrs/csrs-npa.h>
+#include "nix.h"
+struct udevice *rvu_af_dev;
+inline struct rvu_af *get_af(void) +{
- return rvu_af_dev ? dev_get_priv(rvu_af_dev) : NULL;
+void rvu_get_lfid_for_pf(int pf, int *nixid, int *npaid) +{
- union nixx_af_rvu_lf_cfg_debug nix_lf_dbg;
- union npa_af_rvu_lf_cfg_debug npa_lf_dbg;
- struct rvu_af *af = dev_get_priv(rvu_af_dev);
- struct nix_af *nix_af = af->nix_af;
- pf_func.u = 0;
- pf_func.s.pf = pf;
- nix_lf_dbg.u = 0;
- nix_lf_dbg.s.pf_func = pf_func.u & 0xFFFF;
- nix_lf_dbg.s.exec = 1;
- nix_af_reg_write(nix_af, NIXX_AF_RVU_LF_CFG_DEBUG(),
nix_lf_dbg.u);
- do {
nix_lf_dbg.u = nix_af_reg_read(nix_af,
NIXX_AF_RVU_LF_CFG_DEBUG());
- } while (nix_lf_dbg.s.exec);
- if (nix_lf_dbg.s.lf_valid)
*nixid = nix_lf_dbg.s.lf;
- debug("%s: nix lf_valid %d lf %d nixid %d\n", __func__,
nix_lf_dbg.s.lf_valid, nix_lf_dbg.s.lf, *nixid);
- npa_lf_dbg.u = 0;
- npa_lf_dbg.s.pf_func = pf_func.u & 0xFFFF;
- npa_lf_dbg.s.exec = 1;
- npa_af_reg_write(nix_af->npa_af, NPA_AF_RVU_LF_CFG_DEBUG(),
npa_lf_dbg.u);
- do {
npa_lf_dbg.u = npa_af_reg_read(nix_af->npa_af,
NPA_AF_RVU_LF_CFG_DEBUG());
- } while (npa_lf_dbg.s.exec);
- if (npa_lf_dbg.s.lf_valid)
*npaid = npa_lf_dbg.s.lf;
- debug("%s: npa lf_valid %d lf %d npaid %d\n", __func__,
npa_lf_dbg.s.lf_valid, npa_lf_dbg.s.lf, *npaid);
+struct nix_af *rvu_af_init(struct rvu_af *rvu_af) +{
- union rvu_af_addr_s block_addr;
- int err;
- nix_af = (struct nix_af *)calloc(1, sizeof(struct nix_af));
- if (!nix_af) {
printf("%s: out of memory\n", __func__);
goto error;
- nix_af->dev = rvu_af->dev;
- block_addr.u = 0;
- nix_af->nix_af_base = rvu_af->af_base + block_addr.u;
- nix_af->npa_af = (struct npa_af *)calloc(1, sizeof(struct npa_af));
- if (!nix_af->npa_af) {
goto error;
- block_addr.u = 0;
- nix_af->npa_af->npa_af_base = rvu_af->af_base + block_addr.u;
- block_addr.u = 0;
- nix_af->npc_af_base = rvu_af->af_base + block_addr.u;
- debug("%s: Setting up npa admin\n", __func__);
- err = npa_af_setup(nix_af->npa_af);
- if (err) {
printf("%s: Error %d setting up NPA admin\n", __func__, err);
goto error;
- debug("%s: Setting up nix af\n", __func__);
- err = nix_af_setup(nix_af);
- if (err) {
printf("%s: Error %d setting up NIX admin\n", __func__, err);
goto error;
- debug("%s: nix_af: %p\n", __func__, nix_af);
- return nix_af;
+error:
- if (nix_af->npa_af) {
free(nix_af->npa_af);
memset(nix_af, 0, sizeof(*nix_af));
- if (nix_af)
free(nix_af);
- return NULL;
+int rvu_af_probe(struct udevice *dev) +{
- struct rvu_af *af_ptr = dev_get_priv(dev);
- af_ptr->af_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0,
PCI_REGION_MEM);
- debug("%s RVU AF BAR %p\n", __func__, af_ptr->af_base);
- af_ptr->dev = dev;
- rvu_af_dev = dev;
- af_ptr->nix_af = rvu_af_init(af_ptr);
- if (!af_ptr->nix_af) {
printf("%s: Error: could not initialize NIX AF\n", __func__);
return -1;
- debug("%s: Done\n", __func__);
+int rvu_af_remove(struct udevice *dev) +{
- struct rvu_af *rvu_af = dev_get_priv(dev);
- nix_af_shutdown(rvu_af->nix_af);
- npa_af_shutdown(rvu_af->nix_af->npa_af);
- npc_af_shutdown(rvu_af->nix_af);
- debug("%s: rvu af down --\n", __func__);
+U_BOOT_DRIVER(rvu_af) = {
- .name = "rvu_af",
- .id = UCLASS_MISC,
- .probe = rvu_af_probe,
- .remove = rvu_af_remove,
- .priv_auto_alloc_size = sizeof(struct rvu_af),
+static struct pci_device_id rvu_af_supported[] = {
- { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_RVU_AF) },
+U_BOOT_PCI_DEVICE(rvu_af, rvu_af_supported); diff --git a/drivers/net/octeontx2/rvu_common.c b/drivers/net/octeontx2/rvu_common.c new file mode 100644 index 0000000000..173b28ba4b --- /dev/null +++ b/drivers/net/octeontx2/rvu_common.c @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <asm/io.h>
+#include "rvu.h"
+int qmem_alloc(struct qmem *q, u32 qsize, size_t entry_sz) +{
- q->base = memalign(CONFIG_SYS_CACHELINE_SIZE, qsize * entry_sz);
- if (!q->base)
return -ENOMEM;
- q->entry_sz = entry_sz;
- q->qsize = qsize;
- q->alloc_sz = (size_t)qsize * entry_sz;
- q->iova = (dma_addr_t)(q->base);
- debug("NIX: qmem alloc for (%d * %d = %ld bytes) at %p\n",
q->qsize, q->entry_sz, q->alloc_sz, q->base);
+void qmem_free(struct qmem *q) +{
- if (q->base)
free(q->base);
- memset(q, 0, sizeof(*q));
- int err;
- err = qmem_alloc(&aq->inst, qsize, inst_size);
- if (err)
return err;
- err = qmem_alloc(&aq->res, qsize, res_size);
- if (err)
qmem_free(&aq->inst);
- return err;
+void rvu_aq_free(struct admin_queue *aq) +{
- qmem_free(&aq->inst);
- qmem_free(&aq->res);
- memset(aq, 0, sizeof(*aq));
+} diff --git a/drivers/net/octeontx2/rvu_pf.c b/drivers/net/octeontx2/rvu_pf.c new file mode 100644 index 0000000000..201ecf2c16 --- /dev/null +++ b/drivers/net/octeontx2/rvu_pf.c @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <misc.h> +#include <net.h> +#include <pci_ids.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/arch/board.h> +#include "cgx.h" +#include "nix.h"
+extern struct udevice *rvu_af_dev;
+int rvu_pf_init(struct rvu_pf *rvu) +{
- struct nix *nix;
- struct eth_pdata *pdata = dev_get_platdata(rvu->dev);
- debug("%s: Allocating nix lf\n", __func__);
- nix = nix_lf_alloc(rvu->dev);
- if (!nix) {
printf("%s: Error allocating lf for pf %d\n",
__func__, rvu->pfid);
return -1;
- rvu->nix = nix;
- /* to make post_probe happy */
- if (is_valid_ethaddr(nix->lmac->mac_addr)) {
memcpy(pdata->enetaddr, nix->lmac->mac_addr, 6);
eth_env_set_enetaddr_by_index("eth", rvu->dev->seq,
pdata->enetaddr);
+static const struct eth_ops nix_eth_ops = {
- .start = nix_lf_init,
- .send = nix_lf_xmit,
- .recv = nix_lf_recv,
- .free_pkt = nix_lf_free_pkt,
- .stop = nix_lf_halt,
- .write_hwaddr = nix_lf_setup_mac,
+int rvu_pf_probe(struct udevice *dev) +{
- int err;
- char name[16];
- debug("%s: name: %s\n", __func__, dev->name);
- rvu->pf_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_2, PCI_REGION_MEM);
- rvu->pfid = dev->seq + 1; // RVU PF's start from 1;
- rvu->dev = dev;
- if (!rvu_af_dev) {
printf("%s: Error: Could not find RVU AF device\n",
__func__);
return -1;
- rvu->afdev = rvu_af_dev;
- debug("RVU PF %u BAR2 %p\n", rvu->pfid, rvu->pf_base);
- rvu_get_lfid_for_pf(rvu->pfid, &rvu->nix_lfid, &rvu->npa_lfid);
- err = rvu_pf_init(rvu);
- if (err)
printf("%s: Error %d adding nix\n", __func__, err);
* modify device name to include index/sequence number,
* for better readability, this is 1:1 mapping with eth0/1/2.. names.
- sprintf(name, "rvu_pf#%d", dev->seq);
- device_set_name(dev, name);
- return err;
+int rvu_pf_remove(struct udevice *dev) +{
- nix_lf_shutdown(rvu->nix);
- npa_lf_shutdown(rvu->nix);
- debug("%s: rvu pf%d down --\n", __func__, rvu->pfid);
+U_BOOT_DRIVER(rvu_pf) = {
- .name = "rvu_pf",
- .id = UCLASS_ETH,
- .probe = rvu_pf_probe,
- .remove = rvu_pf_remove,
- .ops = &nix_eth_ops,
- .priv_auto_alloc_size = sizeof(struct rvu_pf),
- .platdata_auto_alloc_size = sizeof(struct eth_pdata),
+static struct pci_device_id rvu_pf_supported[] = {
- { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_RVU_PF) },
+U_BOOT_PCI_DEVICE(rvu_pf, rvu_pf_supported);
Viele Grüße, Stefan
Stefan Roese
