[U-Boot] [PATCH v4 0/7] Addition of new board Peach-Pi
Now we are adding a new Peach-Pi board which is a variant of Peach-Pit and is based on Exynos5800. Exynos5800 itself is a variant of Exynos5420, hence, most of the hardware config and settings are reused for this board.
Changes since v1: - Rebased all the patches
Changes since v2: - Rebased all the patches - Added new patch "Enable update mode for DREX controller"
Changes since v3: - Rebased all the patches - Added "Tested-by" and "Acked-by" - In patch 3/7 fixed warning "line over 80 characters"
Akshay Saraswat (5): Exynos5800: Introduce new proid for Exynos5800 Exynos5800: Add DTS for new board Peach-Pi Config: Exynos5800: Enable build for Peach-Pi Config: Exynos5420: Refactor SDRAM Bank and Size Exynos5: ddr3: Choose between single or double channel config
Alim Akhtar (1): DMC: Exynos5: Enable update mode for DREX controller
Vadim Bendebury (1): Peach-Pi: Use the enhanced usb_copy() prototype
arch/arm/cpu/armv7/exynos/Kconfig | 7 +- arch/arm/cpu/armv7/exynos/clock.c | 19 +-- arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 2 +- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 29 +++++ arch/arm/cpu/armv7/exynos/pinmux.c | 2 +- arch/arm/cpu/armv7/exynos/spl_boot.c | 10 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos5800-peach-pi.dts | 157 +++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 10 +- arch/arm/include/asm/arch-exynos/dmc.h | 1 + arch/arm/include/asm/arch-exynos/gpio.h | 4 +- board/samsung/smdk5420/Kconfig | 16 +++ board/samsung/smdk5420/MAINTAINERS | 2 + configs/peach-pi_defconfig | 5 + include/configs/exynos5420-common.h | 9 +- include/configs/peach-pi.h | 50 ++++++++ include/configs/peach-pit.h | 8 +- include/configs/smdk5420.h | 4 + 18 files changed, 313 insertions(+), 25 deletions(-) create mode 100644 arch/arm/dts/exynos5800-peach-pi.dts create mode 100644 configs/peach-pi_defconfig create mode 100644 include/configs/peach-pi.h
This patch intends to add a new proid for Exynos5800 which is a variant of Exynos5420. Product id for Exynos5800 is 0x5422. Both Exynos5420 and Exynos5800 are pin to pin compitable. This gives us an advantage of reusing Exynos5420 clock, pinmux, memory and other settings.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- Changes since v3: - Rebased this patch - Added "Acked-by" and "Tested-by"
Changes since v2: - Rebased this patch
Changes since v1: - Rebased this patch
arch/arm/cpu/armv7/exynos/clock.c | 19 ++++++++++--------- arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 2 +- arch/arm/cpu/armv7/exynos/pinmux.c | 2 +- arch/arm/include/asm/arch-exynos/cpu.h | 10 +++++++++- arch/arm/include/asm/arch-exynos/gpio.h | 4 ++-- 5 files changed, 23 insertions(+), 14 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 7558eff..4ecce44 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -118,7 +118,8 @@ static int exynos_get_pll_clk(int pllreg, unsigned int r, unsigned int k) div = PLL_DIV_1024; else if (proid_is_exynos4412()) div = PLL_DIV_65535; - else if (proid_is_exynos5250() || proid_is_exynos5420()) + else if (proid_is_exynos5250() || proid_is_exynos5420() + || proid_is_exynos5800()) div = PLL_DIV_65536; else return 0; @@ -1581,7 +1582,7 @@ static unsigned long exynos4_get_i2c_clk(void) unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_pll_clk(pllreg); return exynos5_get_pll_clk(pllreg); } else { @@ -1617,7 +1618,7 @@ unsigned long get_i2c_clk(void) unsigned long get_pwm_clk(void) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_pwm_clk(); return clock_get_periph_rate(PERIPH_ID_PWM0); } else { @@ -1630,7 +1631,7 @@ unsigned long get_pwm_clk(void) unsigned long get_uart_clk(int dev_index) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_uart_clk(dev_index); return exynos5_get_uart_clk(dev_index); } else { @@ -1643,7 +1644,7 @@ unsigned long get_uart_clk(int dev_index) unsigned long get_mmc_clk(int dev_index) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_mmc_clk(dev_index); return exynos5_get_mmc_clk(dev_index); } else { @@ -1654,7 +1655,7 @@ unsigned long get_mmc_clk(int dev_index) void set_mmc_clk(int dev_index, unsigned int div) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) exynos5420_set_mmc_clk(dev_index, div); else exynos5_set_mmc_clk(dev_index, div); @@ -1668,7 +1669,7 @@ unsigned long get_lcd_clk(void) if (cpu_is_exynos4()) return exynos4_get_lcd_clk(); else { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_lcd_clk(); else return exynos5_get_lcd_clk(); @@ -1682,7 +1683,7 @@ void set_lcd_clk(void) else { if (proid_is_exynos5250()) exynos5_set_lcd_clk(); - else if (proid_is_exynos5420()) + else if (proid_is_exynos5420() || proid_is_exynos5800()) exynos5420_set_lcd_clk(); } } @@ -1696,7 +1697,7 @@ void set_mipi_clk(void) int set_spi_clk(int periph_id, unsigned int rate) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_set_spi_clk(periph_id, rate); return exynos5_set_spi_clk(periph_id, rate); } else { diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c index b6a9bc1..0aff3d0 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c @@ -971,7 +971,7 @@ static void exynos5420_system_clock_init(void)
void system_clock_init(void) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) exynos5420_system_clock_init(); else exynos5250_system_clock_init(); diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 3d95dc3..94d0297 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -837,7 +837,7 @@ static int exynos4x12_pinmux_config(int peripheral, int flags) int exynos_pinmux_config(int peripheral, int flags) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_pinmux_config(peripheral, flags); else if (proid_is_exynos5250()) return exynos5_pinmux_config(peripheral, flags); diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 78aceef..29674ad 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -227,6 +227,13 @@ static inline void s5p_set_cpu_id(void) /* Exynos5420 */ s5p_cpu_id = 0x5420; break; + case 0x422: + /* + * Exynos5800 is a variant of Exynos5420 + * and has product id 0x5422 + */ + s5p_cpu_id = 0x5800; + break; } }
@@ -255,6 +262,7 @@ IS_EXYNOS_TYPE(exynos4210, 0x4210) IS_EXYNOS_TYPE(exynos4412, 0x4412) IS_EXYNOS_TYPE(exynos5250, 0x5250) IS_EXYNOS_TYPE(exynos5420, 0x5420) +IS_EXYNOS_TYPE(exynos5800, 0x5800)
#define SAMSUNG_BASE(device, base) \ static inline unsigned int __attribute__((no_instrument_function)) \ @@ -265,7 +273,7 @@ static inline unsigned int __attribute__((no_instrument_function)) \ return EXYNOS4X12_##base; \ return EXYNOS4_##base; \ } else if (cpu_is_exynos5()) { \ - if (proid_is_exynos5420()) \ + if (proid_is_exynos5420() || proid_is_exynos5800()) \ return EXYNOS5420_##base; \ return EXYNOS5_##base; \ } \ diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index 02287de..9699954 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -1398,7 +1398,7 @@ static struct gpio_info exynos5420_gpio_data[EXYNOS5420_GPIO_NUM_PARTS] = { static inline struct gpio_info *get_gpio_data(void) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_gpio_data; else return exynos5_gpio_data; @@ -1415,7 +1415,7 @@ static inline struct gpio_info *get_gpio_data(void) static inline unsigned int get_bank_num(void) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) + if (proid_is_exynos5420() || proid_is_exynos5800()) return EXYNOS5420_GPIO_NUM_PARTS; else return EXYNOS5_GPIO_NUM_PARTS;
We have a new board Peach-Pi similar to Peach-Pit. Peach-Pi differs from Peach-Pit in configuration factors like display resolution, memory size, SoC version etc.
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos5800-peach-pi.dts | 157 +++++++++++++++++++++++++++++++++++ 2 files changed, 159 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/exynos5800-peach-pi.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 52f8926..4030220 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -12,7 +12,8 @@ dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ exynos5250-smdk5250.dtb \ exynos5420-smdk5420.dtb \ - exynos5420-peach-pit.dtb + exynos5420-peach-pit.dtb \ + exynos5800-peach-pi.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ tegra20-paz00.dtb \ diff --git a/arch/arm/dts/exynos5800-peach-pi.dts b/arch/arm/dts/exynos5800-peach-pi.dts new file mode 100644 index 0000000..8aedf8e --- /dev/null +++ b/arch/arm/dts/exynos5800-peach-pi.dts @@ -0,0 +1,157 @@ +/* + * SAMSUNG/GOOGLE Peach-Pit board device tree source + * + * Copyright (c) 2013 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "exynos54xx.dtsi" + +/ { + model = "Samsung/Google Peach Pi board based on Exynos5800"; + + compatible = "google,pit-rev#", "google,pit", + "google,peach", "samsung,exynos5800", "samsung,exynos5"; + + config { + google,bad-wake-gpios = <&gpio 0x56 0>; /* gpx0-6 */ + hwid = "PIT TEST A-A 7848"; + lazy-init = <1>; + }; + + aliases { + serial0 = "/serial@12C30000"; + console = "/serial@12C30000"; + pmic = "/i2c@12ca0000"; + }; + + dmc { + mem-manuf = "samsung"; + mem-type = "ddr3"; + clock-frequency = <800000000>; + arm-frequency = <1700000000>; + }; + + tmu@10060000 { + samsung,min-temp = <25>; + samsung,max-temp = <125>; + samsung,start-warning = <95>; + samsung,start-tripping = <105>; + samsung,hw-tripping = <110>; + samsung,efuse-min-value = <40>; + samsung,efuse-value = <55>; + samsung,efuse-max-value = <100>; + samsung,slope = <274761730>; + samsung,dc-value = <25>; + }; + + /* MAX77802 is on i2c bus 4 */ + i2c@12ca0000 { + clock-frequency = <400000>; + power-regulator@9 { + compatible = "maxim,max77802-pmic"; + reg = <0x9>; + }; + }; + + i2c@12cd0000 { /* i2c7 */ + clock-frequency = <100000>; + soundcodec@20 { + reg = <0x20>; + compatible = "maxim,max98090-codec"; + }; + + edp-lvds-bridge@48 { + compatible = "parade,ps8625"; + reg = <0x48>; + }; + }; + + sound@3830000 { + samsung,codec-type = "max98090"; + }; + + i2c@12e10000 { /* i2c9 */ + clock-frequency = <400000>; + tpm@20 { + compatible = "infineon,slb9645-tpm"; + reg = <0x20>; + }; + }; + + spi@12d30000 { /* spi1 */ + spi-max-frequency = <50000000>; + firmware_storage_spi: flash@0 { + reg = <0>; + + /* + * A region for the kernel to store a panic event + * which the firmware will add to the log. + */ + elog-panic-event-offset = <0x01e00000 0x100000>; + + elog-shrink-size = <0x400>; + elog-full-threshold = <0xc00>; + }; + }; + + spi@12d40000 { /* spi2 */ + spi-max-frequency = <4000000>; + spi-deactivate-delay = <200>; + cros-ec@0 { + reg = <0>; + compatible = "google,cros-ec"; + spi-half-duplex; + spi-max-timeout-ms = <1100>; + spi-frame-header = <0xec>; + ec-interrupt = <&gpio 93 1>; /* GPX1_5 */ + + /* + * This describes the flash memory within the EC. Note + * that the STM32L flash erases to 0, not 0xff. + */ + #address-cells = <1>; + #size-cells = <1>; + flash@8000000 { + reg = <0x08000000 0x20000>; + erase-value = <0>; + }; + }; + }; + + xhci@12000000 { + samsung,vbus-gpio = <&gpio 0x40 0>; /* H00 */ + }; + + xhci@12400000 { + samsung,vbus-gpio = <&gpio 0x41 0>; /* H01 */ + }; + + fimd@14400000 { + samsung,vl-freq = <60>; + samsung,vl-col = <1920>; + samsung,vl-row = <1080>; + samsung,vl-width = <1920>; + samsung,vl-height = <1080>; + + samsung,vl-clkp; + samsung,vl-dp; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <80>; + samsung,vl-hbpd = <172>; + samsung,vl-hfpd = <60>; + samsung,vl-vspw = <10>; + samsung,vl-vbpd = <25>; + samsung,vl-vfpd = <10>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <3>; + samsung,interface-mode = <1>; + samsung,dp-enabled = <1>; + samsung,dual-lcd-enabled = <0>; + }; +};
This adds following things : - New config and defconfig for Peach-Pi board. - Alterations in Kconfig and MAINTAINERS. - Addition of CONFIG_EXYNOS5800. - ADdition of exynos5800-peach-pi in dts list.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- Changes since v3: - Rebased this patch - Added "Acked-by" and "Tested-by" - Fixed warning "line over 80 characters" in file include/configs/exynos5420-common.h line # 13 and 42.
arch/arm/cpu/armv7/exynos/Kconfig | 7 +++++- board/samsung/smdk5420/Kconfig | 16 +++++++++++++ board/samsung/smdk5420/MAINTAINERS | 2 ++ configs/peach-pi_defconfig | 5 ++++ include/configs/exynos5420-common.h | 5 +++- include/configs/peach-pi.h | 46 +++++++++++++++++++++++++++++++++++++ include/configs/peach-pit.h | 4 ++-- 7 files changed, 81 insertions(+), 4 deletions(-) create mode 100644 configs/peach-pi_defconfig create mode 100644 include/configs/peach-pi.h
diff --git a/arch/arm/cpu/armv7/exynos/Kconfig b/arch/arm/cpu/armv7/exynos/Kconfig index 090be93..13dbd95 100644 --- a/arch/arm/cpu/armv7/exynos/Kconfig +++ b/arch/arm/cpu/armv7/exynos/Kconfig @@ -44,11 +44,16 @@ config TARGET_SMDK5420 select SUPPORT_SPL select OF_CONTROL if !SPL_BUILD
-config TARGET_PEACH_PIT +config TARGET_PEACH_PI bool "Peach Pi board" select SUPPORT_SPL select OF_CONTROL if !SPL_BUILD
+config TARGET_PEACH_PIT + bool "Peach Pit board" + select SUPPORT_SPL + select OF_CONTROL if !SPL_BUILD + endchoice
config SYS_SOC diff --git a/board/samsung/smdk5420/Kconfig b/board/samsung/smdk5420/Kconfig index d3a5b7f..e7aafe5 100644 --- a/board/samsung/smdk5420/Kconfig +++ b/board/samsung/smdk5420/Kconfig @@ -1,3 +1,19 @@ +if TARGET_PEACH_PI + +config SYS_BOARD + string + default "smdk5420" + +config SYS_VENDOR + string + default "samsung" + +config SYS_CONFIG_NAME + string + default "peach-pi" + +endif + if TARGET_PEACH_PIT
config SYS_BOARD diff --git a/board/samsung/smdk5420/MAINTAINERS b/board/samsung/smdk5420/MAINTAINERS index e0f5c7a..1423f83 100644 --- a/board/samsung/smdk5420/MAINTAINERS +++ b/board/samsung/smdk5420/MAINTAINERS @@ -6,3 +6,5 @@ F: include/configs/peach-pit.h F: configs/peach-pit_defconfig F: include/configs/smdk5420.h F: configs/smdk5420_defconfig +F: include/configs/peach-pi.h +F: configs/peach-pi_defconfig diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig new file mode 100644 index 0000000..8ada0db --- /dev/null +++ b/configs/peach-pi_defconfig @@ -0,0 +1,5 @@ +CONFIG_SPL=y ++S:CONFIG_ARM=y ++S:CONFIG_ARCH_EXYNOS=y ++S:CONFIG_TARGET_PEACH_PI=y +CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" diff --git a/include/configs/exynos5420-common.h b/include/configs/exynos5420-common.h index b0f940c..03f941c 100644 --- a/include/configs/exynos5420-common.h +++ b/include/configs/exynos5420-common.h @@ -10,6 +10,8 @@ #define __CONFIG_EXYNOS5420_H
#define CONFIG_EXYNOS5420 +/* A variant of Exynos5420 (Exynos5 Family) */ +#define CONFIG_EXYNOS5800
#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SPI_FLASH @@ -38,7 +40,8 @@
#define CONFIG_SPL_MAX_FOOTPRINT (30 * 1024)
-#define CONFIG_DEVICE_TREE_LIST "exynos5420-peach-pit exynos5420-smdk5420" +#define CONFIG_DEVICE_TREE_LIST "exynos5800-peach-pi" \ + "exynos5420-peach-pit exynos5420-smdk5420"
#define CONFIG_MAX_I2C_NUM 11
diff --git a/include/configs/peach-pi.h b/include/configs/peach-pi.h new file mode 100644 index 0000000..d8da7ef --- /dev/null +++ b/include/configs/peach-pi.h @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * + * Configuration settings for the SAMSUNG/GOOGLE PEACH-PI board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_PEACH_PI_H +#define __CONFIG_PEACH_PI_H + +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SPI_FLASH +#define CONFIG_ENV_SPI_BASE 0x12D30000 +#define FLASH_SIZE (0x4 << 20) +#define CONFIG_ENV_OFFSET (FLASH_SIZE - CONFIG_BL2_SIZE) + +#include <configs/exynos5420-common.h> +#include <configs/exynos5-dt-common.h> + +#define CONFIG_BOARD_COMMON + +/* select serial console configuration */ +#define CONFIG_SERIAL3 /* use SERIAL 3 */ + +#define CONFIG_SYS_PROMPT "Peach-Pi # " +#define CONFIG_IDENT_STRING " for Peach-Pi" + +#define CONFIG_VIDEO_PARADE + +/* Display */ +#define CONFIG_LCD +#ifdef CONFIG_LCD +#define CONFIG_EXYNOS_FB +#define CONFIG_EXYNOS_DP +#define LCD_BPP LCD_COLOR16 +#endif + +#define CONFIG_POWER_TPS65090_EC +#define CONFIG_CROS_EC_SPI /* Support CROS_EC over SPI */ +#define CONFIG_DM_CROS_EC + +#define CONFIG_USB_XHCI +#define CONFIG_USB_XHCI_EXYNOS + +#endif /* __CONFIG_PEACH_PI_H */ diff --git a/include/configs/peach-pit.h b/include/configs/peach-pit.h index 91bd37d..29a0996 100644 --- a/include/configs/peach-pit.h +++ b/include/configs/peach-pit.h @@ -23,8 +23,8 @@ /* select serial console configuration */ #define CONFIG_SERIAL3 /* use SERIAL 3 */
-#define CONFIG_SYS_PROMPT "Peach # " -#define CONFIG_IDENT_STRING " for Peach" +#define CONFIG_SYS_PROMPT "Peach-Pit # " +#define CONFIG_IDENT_STRING " for Peach-Pit"
As per Exynos5800 UM ver 0.00 section 17.13.2.1 CONCONTROL register bit 3 [update_mode], Exynos5800 does not support the PHY initiated update. And it is recommanded to set this field to 1'b1 during initialization. This patch sets this bit. Applying MC-initiated mode makes DDL tracking ON, that helps in compensate MIF voltage variation.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Doug Anderson dianders@chromium.org Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- Changes since v3: - Rebased this patch - Added "Acked-by" and "Tested-by"
arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 19 +++++++++++++++++++ arch/arm/include/asm/arch-exynos/dmc.h | 1 + 2 files changed, 20 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c index b86dd2d..4d73b45 100644 --- a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c +++ b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c @@ -832,6 +832,25 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, int reset) setbits_le32(&drex0->cgcontrol, DMC_INTERNAL_CG); setbits_le32(&drex1->cgcontrol, DMC_INTERNAL_CG);
+ /* + * As per Exynos5800 UM ver 0.00 section 17.13.2.1 + * CONCONTROL register bit 3 [update_mode], Exynos5800 does not + * support the PHY initiated update. And it is recommended to set + * this field to 1'b1 during initialization + * + * When we apply PHY-initiated mode, DLL lock value is determined + * once at DMC init time and not updated later when we change the MIF + * voltage based on ASV group in kernel. Applying MC-initiated mode + * makes sure that DLL tracing is ON so that silicon is able to + * compensate the voltage variation. + */ + val = readl(&drex0->concontrol); + val |= CONCONTROL_UPDATE_MODE; + writel(val , &drex0->concontrol); + val = readl(&drex1->concontrol); + val |= CONCONTROL_UPDATE_MODE; + writel(val , &drex1->concontrol); + return 0; } #endif diff --git a/arch/arm/include/asm/arch-exynos/dmc.h b/arch/arm/include/asm/arch-exynos/dmc.h index ec3f9b6..4990a1a 100644 --- a/arch/arm/include/asm/arch-exynos/dmc.h +++ b/arch/arm/include/asm/arch-exynos/dmc.h @@ -450,6 +450,7 @@ enum mem_manuf { #define CONCONTROL_RD_FETCH_SHIFT 12 #define CONCONTROL_RD_FETCH_MASK (0x7 << CONCONTROL_RD_FETCH_SHIFT) #define CONCONTROL_AREF_EN_SHIFT 5 +#define CONCONTROL_UPDATE_MODE (1 << 3)
/* PRECHCONFIG register field */ #define PRECHCONFIG_TP_CNT_SHIFT 24
Since, not every board may have all memory channels configured and all available banks of DMC used, we wish to refactor configs for Memory Bank size and numbers as per board memory config. For Example, Peach-Pit has 2GB memory and will be using only 4 banks but Peach-Pi has 3.5GB memory and will be using all 7 available SDRAM banks.
include/configs/exynos5420-common.h | 4 ---- include/configs/peach-pi.h | 4 ++++ include/configs/peach-pit.h | 4 ++++ include/configs/smdk5420.h | 4 ++++ 4 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/include/configs/exynos5420-common.h b/include/configs/exynos5420-common.h index 03f941c..218d2b4 100644 --- a/include/configs/exynos5420-common.h +++ b/include/configs/exynos5420-common.h @@ -57,10 +57,6 @@ */ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_IRAM_TOP - 0x800)
-/* DRAM Memory Banks */ -#define CONFIG_NR_DRAM_BANKS 7 -#define SDRAM_BANK_SIZE (512UL << 20UL) /* 512 MB */ - /* Miscellaneous configurable options */ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
diff --git a/include/configs/peach-pi.h b/include/configs/peach-pi.h index d8da7ef..8a82402 100644 --- a/include/configs/peach-pi.h +++ b/include/configs/peach-pi.h @@ -43,4 +43,8 @@ #define CONFIG_USB_XHCI #define CONFIG_USB_XHCI_EXYNOS
+/* DRAM Memory Banks */ +#define CONFIG_NR_DRAM_BANKS 7 +#define SDRAM_BANK_SIZE (512UL << 20UL) /* 512 MB */ + #endif /* __CONFIG_PEACH_PI_H */ diff --git a/include/configs/peach-pit.h b/include/configs/peach-pit.h index 29a0996..ad5db57 100644 --- a/include/configs/peach-pit.h +++ b/include/configs/peach-pit.h @@ -43,4 +43,8 @@ #define CONFIG_USB_XHCI #define CONFIG_USB_XHCI_EXYNOS
+/* DRAM Memory Banks */ +#define CONFIG_NR_DRAM_BANKS 4 +#define SDRAM_BANK_SIZE (512UL << 20UL) /* 512 MB */ + #endif /* __CONFIG_PEACH_PIT_H */ diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index fd2d482..5c9a3c0 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -23,4 +23,8 @@ #define CONFIG_IDENT_STRING " for SMDK5420" #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
+/* DRAM Memory Banks */ +#define CONFIG_NR_DRAM_BANKS 7 +#define SDRAM_BANK_SIZE (512UL << 20UL) /* 512 MB */ + #endif /* __CONFIG_SMDK5420_H */
Add a 4G configuration and choose it based on the number of banks declared in config file. A board with 4 SDRAM banks declared (as per CONFIG_NR_DRAM_BANKS) will end up with the 2G confiuration.
arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c index 4d73b45..7c0b12a 100644 --- a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c +++ b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c @@ -464,6 +464,16 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, int reset) + DMC_OFFSET); pmu = (struct exynos5_power *)EXYNOS5420_POWER_BASE;
+ if (CONFIG_NR_DRAM_BANKS > 4) { + /* Need both controllers. */ + mem->memcontrol |= DMC_MEMCONTROL_NUM_CHIP_2; + mem->chips_per_channel = 2; + mem->chips_to_configure = 2; + } else { + /* 2GB requires a single controller */ + mem->memcontrol |= DMC_MEMCONTROL_NUM_CHIP_1; + } + /* Enable PAUSE for DREX */ setbits_le32(&clk->pause, ENABLE_BIT);
Exynos5800 IROM has a different, from 5250 and 5420, prototype of the usb_copy() function. Luckily the earlier version did not expect any arguments, which means the same code could be used with old and new SoCs, the old ones just ignoring the arguments.
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- Changes since v3: - Rebased this patch - Added "Acked-by" and "Tested-by"
Changes since v2: - Added in this patch-set.
arch/arm/cpu/armv7/exynos/spl_boot.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/spl_boot.c b/arch/arm/cpu/armv7/exynos/spl_boot.c index 658e4cb..dbd312c 100644 --- a/arch/arm/cpu/armv7/exynos/spl_boot.c +++ b/arch/arm/cpu/armv7/exynos/spl_boot.c @@ -195,10 +195,16 @@ void copy_uboot_to_ram(void) void (*end_bootop_from_emmc)(void); #endif #ifdef CONFIG_USB_BOOTING - u32 (*usb_copy)(void); int is_cr_z_set; unsigned int sec_boot_check;
+ /* + * Note that older hardware (before Exynos5800) does not expect any + * arguments, but it does not hurt to pass them, so a common function + * prototype is used. + */ + u32 (*usb_copy)(u32 num_of_block, u32 *dst); + /* Read iRAM location to check for secondary USB boot mode */ sec_boot_check = readl(EXYNOS_IRAM_SECONDARY_BASE); if (sec_boot_check == EXYNOS_USB_SECONDARY_BOOT) @@ -240,7 +246,7 @@ void copy_uboot_to_ram(void) */ is_cr_z_set = config_branch_prediction(0); usb_copy = get_irom_func(USB_INDEX); - usb_copy(); + usb_copy(0, (u32 *)CONFIG_SYS_TEXT_BASE); config_branch_prediction(is_cr_z_set); break; #endif
Changes since v1:
Changes since v2:
Changes since v3:
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Akshay Saraswat
Minkyu Kang
