[PATCH 0/4] mmc: manage boot area protection
This patch series adds sub-command 'mmc wp' to set the power on boot area protection on eMMC devices and enhances command 'mmc info' to display the boot area protection status.
Heinrich Schuchardt (4): mmc: EXT_CSD registers for write protection mmc: export mmc_send_ext_csd() cmd: mmc: display write protect state of boot partition cmd: mmc: provide boot area protection command
cmd/mmc.c | 46 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/mmc.c | 7 ++++++- include/mmc.h | 23 +++++++++++++++++++++++ 3 files changed, 75 insertions(+), 1 deletion(-)
-- 2.25.1
Add the EXT_CSD register definition related to write protection.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/mmc.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/mmc.h b/include/mmc.h index e83c22423b..4ecd6c744c 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -223,6 +223,9 @@ static inline bool mmc_is_tuning_cmd(uint cmdidx) #define EXT_CSD_WR_REL_PARAM 166 /* R */ #define EXT_CSD_WR_REL_SET 167 /* R/W */ #define EXT_CSD_RPMB_MULT 168 /* RO */ +#define EXT_CSD_USER_WP 171 /* R/W & R/W/C_P & R/W/E_P */ +#define EXT_CSD_BOOT_WP 173 /* R/W & R/W/C_P */ +#define EXT_CSD_BOOT_WP_STATUS 174 /* R */ #define EXT_CSD_ERASE_GROUP_DEF 175 /* R/W */ #define EXT_CSD_BOOT_BUS_WIDTH 177 #define EXT_CSD_PART_CONF 179 /* R/W */ -- 2.25.1
Export function mmc_send_ext_csd() for reading the extended CSD register.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/mmc/mmc.c | 2 +- include/mmc.h | 11 +++++++++++ 2 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 3e36566693..bfcdaa665d 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -718,7 +718,7 @@ static int mmc_complete_op_cond(struct mmc *mmc) }
-static int mmc_send_ext_csd(struct mmc *mmc, u8 *ext_csd) +int mmc_send_ext_csd(struct mmc *mmc, u8 *ext_csd) { struct mmc_cmd cmd; struct mmc_data data; diff --git a/include/mmc.h b/include/mmc.h index 4ecd6c744c..85fc3497a1 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -896,6 +896,17 @@ int mmc_get_env_dev(void); */ struct blk_desc *mmc_get_blk_desc(struct mmc *mmc);
+/** + * mmc_send_ext_csd() - read the extended CSD register + * + * @mmc: MMC device + * @ext_csd a cache aligned buffer of length MMC_MAX_BLOCK_LEN allocated by + * the caller, e.g. using + * ALLOC_CACHE_ALIGN_BUFFER(u8, ext_csd, MMC_MAX_BLOCK_LEN) + * Return: 0 for success + */ +int mmc_send_ext_csd(struct mmc *mmc, u8 *ext_csd); + static inline enum dma_data_direction mmc_get_dma_dir(struct mmc_data *data) { return data->flags & MMC_DATA_WRITE ? DMA_TO_DEVICE : DMA_FROM_DEVICE; -- 2.25.1
Boot partitions of eMMC devices can be power on or permanently write protected. Let the 'mmc info' command display the protection state.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/mmc.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/cmd/mmc.c b/cmd/mmc.c index 6f3cb85cc0..d62c85e439 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -54,6 +54,8 @@ static void print_mmcinfo(struct mmc *mmc) if (!IS_SD(mmc) && mmc->version >= MMC_VERSION_4_41) { bool has_enh = (mmc->part_support & ENHNCD_SUPPORT) != 0; bool usr_enh = has_enh && (mmc->part_attr & EXT_CSD_ENH_USR); + u8 wp, ext_csd[MMC_MAX_BLOCK_LEN]; + int ret;
#if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) puts("HC WP Group Size: "); @@ -90,6 +92,28 @@ static void print_mmcinfo(struct mmc *mmc) putc('\n'); } } + ret = mmc_send_ext_csd(mmc, ext_csd); + if (ret) + return; + wp = ext_csd[EXT_CSD_BOOT_WP_STATUS]; + for (i = 0; i < 2; ++i) { + printf("Boot area %d is ", i); + switch (wp & 3) { + case 0: + printf("not write protected\n"); + break; + case 1: + printf("power on protected\n"); + break; + case 2: + printf("permanently protected\n"); + break; + default: + printf("in reserved protection state\n"); + break; + } + wp >>= 2; + } } } static struct mmc *init_mmc_device(int dev, bool force_init) -- 2.25.1
int ret;
if (ret)
return;
Is it really needed to call mmc_send_ext_csd() at here. ext_csd register value was already read somewhere.
Best Regards, Jaehoon Chung
switch (wp & 3) {
case 0:
break;
case 1:
break;
case 2:
break;
default:
break;
wp >>= 2;
int ret;
if (ret)
return;
struct mmc does not contain the extended CSD. Performancewise it does not make sense to carry a copy which would have to be updated after each command that could potentially update it like SWITCH.
The call to mmc_send_ext_csd() does not lead to any visible performance issue here.
Best regards
Heinrich
switch (wp & 3) {
case 0:
break;
case 1:
break;
case 2:
break;
default:
break;
wp >>= 2;
int ret;
if (ret)
return;
Why doesn't make sense to carry a copy? Its value can be updated whenever it's changed. If someone want to set "write protect", then it has to follow sequence. read ext_csd -> check value -> send_switch command Then it's possible to keep its value..
And some values are one-time programmable. it's not efficient about sending command to read again.
Best regards
Heinrich
switch (wp & 3) {
case 0:
break;
case 1:
break;
case 2:
break;
default:
break;
wp >>= 2;
Provide command 'mmc wp' to power on write protect boot areas on eMMC devices.
The B_PWR_WP_EN bit in the extended CSD register BOOT_WP is set. The boot area are write protected until the next power cycle occurs.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/mmc.c | 22 ++++++++++++++++++++++ drivers/mmc/mmc.c | 5 +++++ include/mmc.h | 9 +++++++++ 3 files changed, 36 insertions(+)
diff --git a/cmd/mmc.c b/cmd/mmc.c index d62c85e439..80a32d9fa9 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -896,9 +896,30 @@ static int do_mmc_bkops_enable(cmd_tbl_t *cmdtp, int flag, } #endif
+static int do_mmc_boot_wp(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + int err; + struct mmc *mmc; + + mmc = init_mmc_device(curr_device, false); + if (!mmc) + return CMD_RET_FAILURE; + if (IS_SD(mmc)) { + printf("It is not an eMMC device\n"); + return CMD_RET_FAILURE; + } + err = mmc_boot_wp(mmc); + if (err) + return CMD_RET_FAILURE; + printf("boot areas protected\n"); + return CMD_RET_SUCCESS; +} + static cmd_tbl_t cmd_mmc[] = { U_BOOT_CMD_MKENT(info, 1, 0, do_mmcinfo, "", ""), U_BOOT_CMD_MKENT(read, 4, 1, do_mmc_read, "", ""), + U_BOOT_CMD_MKENT(wp, 1, 0, do_mmc_boot_wp, "", ""), #if CONFIG_IS_ENABLED(MMC_WRITE) U_BOOT_CMD_MKENT(write, 4, 0, do_mmc_write, "", ""), U_BOOT_CMD_MKENT(erase, 3, 0, do_mmc_erase, "", ""), @@ -968,6 +989,7 @@ U_BOOT_CMD( "mmc part - lists available partition on current mmc device\n" "mmc dev [dev] [part] - show or set current mmc device [partition]\n" "mmc list - lists available devices\n" + "mmc wp - power on write protect booot partitions\n" #if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) "mmc hwpartition [args...] - does hardware partitioning\n" " arguments (sizes in 512-byte blocks):\n" diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index bfcdaa665d..fc3123c3c3 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -810,6 +810,11 @@ int mmc_switch(struct mmc *mmc, u8 set, u8 index, u8 value) return __mmc_switch(mmc, set, index, value, true); }
+int mmc_boot_wp(struct mmc *mmc) +{ + return mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BOOT_WP, 1); +} + #if !CONFIG_IS_ENABLED(MMC_TINY) static int mmc_set_card_speed(struct mmc *mmc, enum bus_mode mode, bool hsdowngrade) diff --git a/include/mmc.h b/include/mmc.h index 85fc3497a1..e92e920560 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -907,6 +907,15 @@ struct blk_desc *mmc_get_blk_desc(struct mmc *mmc); */ int mmc_send_ext_csd(struct mmc *mmc, u8 *ext_csd);
+/** + * mmc_boot_wp() - power on write protect boot partitions + * + * The boot partitions are write protected until the next power cycle. + * + * Return: 0 for success + */ +int mmc_boot_wp(struct mmc *mmc); + static inline enum dma_data_direction mmc_get_dma_dir(struct mmc_data *data) { return data->flags & MMC_DATA_WRITE ? DMA_TO_DEVICE : DMA_FROM_DEVICE; -- 2.25.1
Jaehoon Chung
