[U-Boot] [PULL] [Update] Please pull u-boot-imx
Hi Tom,
as discussed: this contains two fixes that should go into release - thanks !
The following changes since commit 5e62f828256d66e2b28def4f9ef20a2a05c2d04f:
Prepare v2018.03-rc4 (2018-03-05 20:27:08 -0500)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 314d9f7e3eff41873011d9a0687f469680a00074:
imx: syscounter: make sure asm is volatile (2018-03-09 13:06:14 +0100)
---------------------------------------------------------------- Fabio Estevam (1): imximage: Remove failure when no IVT offset is found
Yasushi SHOJI (1): imx: syscounter: make sure asm is volatile
arch/arm/mach-imx/syscounter.c | 4 ++-- tools/imximage.c | 5 ----- 2 files changed, 2 insertions(+), 7 deletions(-)
Stefano
On Fri, Mar 09, 2018 at 01:10:53PM +0100, Stefano Babic wrote:
Hi Tom,
Note that I expect another PR with other fixes that just got posted today, but, applied to u-boot/master, thanks!
Hi Tom,
Hi Tom,
Yes, I saw Brian's post for HAB, and there are a couple from Jagan that I'll pick up. I will send a new PR, then.
Stefano
Hi Stefano,
Patches 1/3 and 2/3 from Bryan look good.
We have some concerns about patch 3/3 and Breno will reply to this patch soon.
Thanks
Fabio Estevam
Stefano Babic
