[U-Boot] [PATCH v4] mtd: fix compiler warnings
- add missing declaration - update debug output format specifiers
Signed-off-by: Steve Rae steve.rae@raedomain.com --- the checkpatch warning: warning: cmd/mtdparts.c,1494: quoted string split across lines is for the existing code; it is not introduced with this change...
Changes in v4: pulled this change out of the "iproc" series, as it had nothing to do with "iproc"
Changes in v3: none
Changes in v2: none
cmd/mtdparts.c | 4 ++-- include/linux/mtd/mtd.h | 5 +++++ 2 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 44b2c3a..ea97415 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -1491,7 +1491,7 @@ static int spread_partitions(void) part = list_entry(pentry, struct part_info, link);
debug("spread_partitions: device = %s%d, partition %d =" - " (%s) 0x%08x@0x%08x\n", + " (%s) 0x%08llx@0x%08llx\n", MTD_DEV_TYPE(dev->id->type), dev->id->num, part_num, part->name, part->size, part->offset); @@ -2009,7 +2009,7 @@ static int do_mtdparts(cmd_tbl_t *cmdtp, int flag, int argc,
if (!strcmp(&argv[1][3], ".spread")) { spread_partition(mtd, p, &next_offset); - debug("increased %s to %d bytes\n", p->name, p->size); + debug("increased %s to %llu bytes\n", p->name, p->size); } #endif
diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index cf20674..779eea0 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -500,5 +500,10 @@ int mtd_arg_off(const char *arg, int *idx, loff_t *off, loff_t *size, int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, loff_t *size, loff_t *maxsize, int devtype, uint64_t chipsize); + +/* drivers/mtd/mtdcore.c */ +void mtd_get_len_incl_bad(struct mtd_info *mtd, uint64_t offset, + const uint64_t length, uint64_t *len_incl_bad, + int *truncated); #endif #endif /* __MTD_MTD_H__ */
Steve Rae
