[PATCH 0/5] x86: Updates to some commands
This series adds a few more features to some x86-specific commands.
Simon Glass (5): x86: hob: Add way to show a single hob entry x86: hob: Try to show a name instead of a GUID x86: Allow showing details about a HOB entry x86: Add support for more than 8 MTRRs x86: video: Show information about each video device
arch/x86/cpu/mtrr.c | 12 ++-- arch/x86/include/asm/fsp/fsp_hob.h | 25 ++++++++ arch/x86/include/asm/mtrr.h | 15 ++++- cmd/bdinfo.c | 26 +++++++- cmd/x86/hob.c | 100 +++++++++++++++++++++++++++-- cmd/x86/mtrr.c | 9 +-- 6 files changed, 167 insertions(+), 20 deletions(-)
The 'hob' command currently lists all HOB entries. Add way to list a single entry, by index.
cmd/x86/hob.c | 16 +++++++++++----- 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/cmd/x86/hob.c b/cmd/x86/hob.c index 6b1f7bda5b8..e3f512beee8 100644 --- a/cmd/x86/hob.c +++ b/cmd/x86/hob.c @@ -34,7 +34,12 @@ static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) int i = 0; efi_guid_t *guid; char uuid[UUID_STR_LEN + 1]; + int seq = -1; /* Show all by default */
+ argc--; + argv++; + if (argc) + seq = simple_strtol(*argv, NULL, 16); hdr = gd->arch.hob_list;
printf("HOB list address: 0x%08x\n\n", (unsigned int)hdr); @@ -43,7 +48,9 @@ static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) printf("%36s\n", "GUID"); printf("---|----------|-----------|------|-"); printf("------------------------------------\n"); - while (!end_of_hob(hdr)) { + for (i = 0; !end_of_hob(hdr); i++, hdr = get_next_hob(hdr)) { + if (seq != -1 && seq != i) + continue; printf("%02x | %08x | ", i, (unsigned int)hdr); type = hdr->type; if (type == HOB_TYPE_UNUSED) @@ -65,14 +72,13 @@ static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) printf("%36s", "Not Available"); } printf("\n"); - hdr = get_next_hob(hdr); - i++; }
return 0; }
-U_BOOT_CMD(hob, 1, 1, do_hob, - "Print Hand-Off Block (HOB) information", +U_BOOT_CMD(hob, 2, 1, do_hob, + "[seq] Print Hand-Off Block (HOB) information" + " seq - Record # to show (all by default)", "" );
GUIDs are one of the seven evils of the computer world. They obfuscate the meaning and require people to look up long hex strings to decode it.
Luckily only a miniscule fraction of the 10^38 possible GUIDs are in use.
Add a way to decode the GUIDs known to U-Boot. Add a few more to the list for good measure.
arch/x86/include/asm/fsp/fsp_hob.h | 25 +++++++++++++++++ cmd/x86/hob.c | 43 ++++++++++++++++++++++++++++-- 2 files changed, 66 insertions(+), 2 deletions(-)
diff --git a/arch/x86/include/asm/fsp/fsp_hob.h b/arch/x86/include/asm/fsp/fsp_hob.h index d248520e972..ea3983e04ff 100644 --- a/arch/x86/include/asm/fsp/fsp_hob.h +++ b/arch/x86/include/asm/fsp/fsp_hob.h @@ -99,4 +99,29 @@ struct __packed hob_graphics_info { EFI_GUID(0x39f62cce, 0x6825, 0x4669, \ 0xbb, 0x56, 0x54, 0x1a, 0xba, 0x75, 0x3a, 0x07)
+/* The following GUIDs are observed with FSP 2.1 / Apollo Lake */ +#define FSP_HOB_RESOURCE_OWNER_SMM_PEI_SMRAM_GUID \ + EFI_GUID(0x6dadf1d1, 0xd4cc, 0x4910, \ + 0xbb, 0x6e, 0x82, 0xb1, 0xfd, 0x80, 0xff, 0x3d) + +#define FSP_HOB_RESOURCE_OWNER_PCD_DATABASE_GUID1 \ + EFI_GUID(0xea296d92, 0x0b69, 0x423c, \ + 0x8c, 0x28, 0x33, 0xb4, 0xe0, 0xa9, 0x12, 0x68) + +#define FSP_HOB_RESOURCE_OWNER_PCD_DATABASE_GUID2 \ + EFI_GUID(0x9b3ada4f, 0xae56, 0x4c24, \ + 0x8d, 0xea, 0xf0, 0x3b, 0x75, 0x58, 0xae, 0x50) + +#define FSP_HOB_RESOURCE_OWNER_PEIM_DXE_GUID \ + EFI_GUID(0x86d70125, 0xbaa3, 0x4296, \ + 0xa6, 0x2f, 0x60, 0x2b, 0xeb, 0xbb, 0x90, 0x81) + +#define FSP_HOB_RESOURCE_OWNER_ALLOC_STACK_GUID \ + EFI_GUID(0x4ed4bf27, 0x4092, 0x42e9, \ + 0x80, 0x7d, 0x52, 0x7b, 0x1d, 0x00, 0xc9, 0xbd) + +#define FSP_HOB_RESOURCE_OWNER_SMBIOS_MEMORY_GUID \ + EFI_GUID(0x01a1108c, 0x9dee, 0x4984, \ + 0x88, 0xc3, 0xee, 0xe8, 0xc4, 0x9e, 0xfb, 0x89) + #endif diff --git a/cmd/x86/hob.c b/cmd/x86/hob.c index e3f512beee8..bbe38bbf20e 100644 --- a/cmd/x86/hob.c +++ b/cmd/x86/hob.c @@ -8,6 +8,7 @@ #include <efi.h> #include <uuid.h> #include <asm/hob.h> +#include <asm/fsp/fsp_hob.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -26,6 +27,37 @@ static char *hob_type[] = { "Capsule", };
+static struct guid_name { + efi_guid_t guid; + const char *name; +} guid_name[] = { + { FSP_HOB_RESOURCE_OWNER_TSEG_GUID, "TSEG" }, + { FSP_HOB_RESOURCE_OWNER_FSP_GUID, "FSP" }, + { FSP_HOB_RESOURCE_OWNER_SMM_PEI_SMRAM_GUID, "SMM PEI SMRAM" }, + { FSP_NON_VOLATILE_STORAGE_HOB_GUID, "NVS" }, + { FSP_VARIABLE_NV_DATA_HOB_GUID, "Variable NVS" }, + { FSP_GRAPHICS_INFO_HOB_GUID, "Graphics info" }, + { FSP_HOB_RESOURCE_OWNER_PCD_DATABASE_GUID1, "PCD database ea" }, + { FSP_HOB_RESOURCE_OWNER_PCD_DATABASE_GUID2, "PCD database 93" }, + { FSP_HOB_RESOURCE_OWNER_PEIM_DXE_GUID, "PEIM Init DXE" }, + { FSP_HOB_RESOURCE_OWNER_ALLOC_STACK_GUID, "Alloc stack" }, + { FSP_HOB_RESOURCE_OWNER_SMBIOS_MEMORY_GUID, "SMBIOS memory" }, + { {}, "zero-guid" }, + {} +}; + +static const char *guid_to_name(const efi_guid_t *guid) +{ + struct guid_name *entry; + + for (entry = guid_name; entry->name; entry++) { + if (!guidcmp(guid, &entry->guid)) + return entry->name; + } + + return NULL; +} + static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { const struct hob_header *hdr; @@ -65,9 +97,16 @@ static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
if (type == HOB_TYPE_MEM_ALLOC || type == HOB_TYPE_RES_DESC || type == HOB_TYPE_GUID_EXT) { + const char *name; + guid = (efi_guid_t *)(hdr + 1); - uuid_bin_to_str(guid->b, uuid, UUID_STR_FORMAT_GUID); - printf("%s", uuid); + name = guid_to_name(guid); + if (!name) { + uuid_bin_to_str(guid->b, uuid, + UUID_STR_FORMAT_GUID); + name = uuid; + } + printf("%36s", name); } else { printf("%36s", "Not Available"); }
Hi Simon,
Agreed :)
efi_guid_t guid;
const char *name;
+} guid_name[] = {
93 should be 9b
return entry->name;
return NULL;
const char *name;
printf("%s", uuid);
if (!name) {
name = uuid;
Regards, Bin
Some HOBs include information that can be decoded. Add a -v option to the hob command, to allow this to be displayed. Add the ability to decode a resource descriptor.
cmd/x86/hob.c | 49 +++++++++++++++++++++++++++++++++++++++++++++---- 1 file changed, 45 insertions(+), 4 deletions(-)
diff --git a/cmd/x86/hob.c b/cmd/x86/hob.c index bbe38bbf20e..2933bc08c76 100644 --- a/cmd/x86/hob.c +++ b/cmd/x86/hob.c @@ -27,6 +27,16 @@ static char *hob_type[] = { "Capsule", };
+static char *res_type[] = { + "system", + "Memory-mapped I/O", + "I/O", + "Firmware device", + "Memory-mapped I/O port", + "Reserved", + "I/O reserved", +}; + static struct guid_name { efi_guid_t guid; const char *name; @@ -58,6 +68,26 @@ static const char *guid_to_name(const efi_guid_t *guid) return NULL; }
+static void show_hob_details(const struct hob_header *hdr) +{ + const void *ptr = hdr; + + switch (hdr->type) { + case HOB_TYPE_RES_DESC: { + const struct hob_res_desc *res = ptr; + const char *typename; + + typename = res->type > 0 && res->type <= RES_MAX_MEM_TYPE ? + res_type[res->type] : "unknown"; + + printf(" base = %08llx, len = %08llx, end = %08llx, type = %d (%s)\n\n", + res->phys_start, res->len, res->phys_start + res->len, + res->type, typename); + break; + } + } +} + static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { const struct hob_header *hdr; @@ -66,12 +96,20 @@ static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) int i = 0; efi_guid_t *guid; char uuid[UUID_STR_LEN + 1]; + bool verbose = false; int seq = -1; /* Show all by default */
argc--; argv++; - if (argc) - seq = simple_strtol(*argv, NULL, 16); + if (argc) { + if (!strcmp("-v", *argv)) { + verbose = true; + argc--; + argv++; + } + if (argc) + seq = simple_strtol(*argv, NULL, 16); + } hdr = gd->arch.hob_list;
printf("HOB list address: 0x%08x\n\n", (unsigned int)hdr); @@ -111,13 +149,16 @@ static int do_hob(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) printf("%36s", "Not Available"); } printf("\n"); + if (verbose) + show_hob_details(hdr); }
return 0; }
-U_BOOT_CMD(hob, 2, 1, do_hob, - "[seq] Print Hand-Off Block (HOB) information" +U_BOOT_CMD(hob, 3, 1, do_hob, + "[-v] [seq] Print Hand-Off Block (HOB) information" + " -v - Show detailed HOB information where available" " seq - Record # to show (all by default)", "" );
"system",
nits: System
"I/O",
"Firmware device",
"Reserved",
"I/O reserved",
break;
bool verbose = false; int seq = -1; /* Show all by default */ argc--; argv++;
if (argc)
if (argc) {
verbose = true;
argc--;
argv++;
if (argc)
} hdr = gd->arch.hob_list; printf("HOB list address: 0x%08x\n\n", (unsigned int)hdr);
if (verbose)
show_hob_details(hdr); } return 0;
At present the mtrr command only support 8 MTRRs. Some SoCs have more than that. Update the implementation to support up to 10. Read the number of MTRRs dynamically instead.
arch/x86/cpu/mtrr.c | 12 +++++++----- arch/x86/include/asm/mtrr.h | 15 ++++++++++++--- cmd/x86/mtrr.c | 9 +++++---- 3 files changed, 24 insertions(+), 12 deletions(-)
diff --git a/arch/x86/cpu/mtrr.c b/arch/x86/cpu/mtrr.c index 2468d88a80a..aed4c411367 100644 --- a/arch/x86/cpu/mtrr.c +++ b/arch/x86/cpu/mtrr.c @@ -66,9 +66,10 @@ static void set_var_mtrr(uint reg, uint type, uint64_t start, uint64_t size)
void mtrr_read_all(struct mtrr_info *info) { + int reg_count = mtrr_get_var_count(); int i;
- for (i = 0; i < MTRR_COUNT; i++) { + for (i = 0; i < reg_count; i++) { info->mtrr[i].base = native_read_msr(MTRR_PHYS_BASE_MSR(i)); info->mtrr[i].mask = native_read_msr(MTRR_PHYS_MASK_MSR(i)); } @@ -76,10 +77,11 @@ void mtrr_read_all(struct mtrr_info *info)
void mtrr_write_all(struct mtrr_info *info) { + int reg_count = mtrr_get_var_count(); struct mtrr_state state; int i;
- for (i = 0; i < MTRR_COUNT; i++) { + for (i = 0; i < reg_count; i++) { mtrr_open(&state, true); wrmsrl(MTRR_PHYS_BASE_MSR(i), info->mtrr[i].base); wrmsrl(MTRR_PHYS_MASK_MSR(i), info->mtrr[i].mask); @@ -144,7 +146,7 @@ int mtrr_commit(bool do_caches)
/* Clear the ones that are unused */ debug("clear\n"); - for (; i < MTRR_COUNT; i++) + for (; i < MTRR_MAX_COUNT; i++) wrmsrl(MTRR_PHYS_MASK_MSR(i), 0); debug("close\n"); mtrr_close(&state, do_caches); @@ -184,7 +186,7 @@ int mtrr_add_request(int type, uint64_t start, uint64_t size) return 0; }
-static int get_var_mtrr_count(void) +int mtrr_get_var_count(void) { return msr_read(MSR_MTRR_CAP_MSR).lo & MSR_MTRR_CAP_VCNT; } @@ -195,7 +197,7 @@ static int get_free_var_mtrr(void) int vcnt; int i;
- vcnt = get_var_mtrr_count(); + vcnt = mtrr_get_var_count();
/* Identify the first var mtrr which is not valid */ for (i = 0; i < vcnt; i++) { diff --git a/arch/x86/include/asm/mtrr.h b/arch/x86/include/asm/mtrr.h index 48db1dd82f7..3a98aacdef5 100644 --- a/arch/x86/include/asm/mtrr.h +++ b/arch/x86/include/asm/mtrr.h @@ -36,8 +36,8 @@
#define MTRR_BASE_TYPE_MASK 0x7
-/* Number of MTRRs supported */ -#define MTRR_COUNT 8 +/* Maximum number of MTRRs supported - see also mtrr_get_var_count() */ +#define MTRR_MAX_COUNT 10
#define NUM_FIXED_MTRRS 11 #define RANGES_PER_FIXED_MTRR 8 @@ -87,7 +87,7 @@ struct mtrr { * @mtrr: Information about each mtrr */ struct mtrr_info { - struct mtrr mtrr[MTRR_COUNT]; + struct mtrr mtrr[MTRR_MAX_COUNT]; };
/** @@ -180,6 +180,15 @@ int mtrr_set_valid(int cpu_select, int reg, bool valid); */ int mtrr_set(int cpu_select, int reg, u64 base, u64 mask);
+/** + * mtrr_get_var_count() - Get the number of variable MTRRs + * + * Some CPUs have more than 8 MTRRs. This function returns the actual number + * + * @return number of variable MTRRs + */ +int mtrr_get_var_count(void); + #endif
#if ((CONFIG_XIP_ROM_SIZE & (CONFIG_XIP_ROM_SIZE - 1)) != 0) diff --git a/cmd/x86/mtrr.c b/cmd/x86/mtrr.c index 99efecb9d8e..fc61a549b02 100644 --- a/cmd/x86/mtrr.c +++ b/cmd/x86/mtrr.c @@ -27,7 +27,7 @@ static void read_mtrrs(void *arg) mtrr_read_all(info); }
-static int do_mtrr_list(int cpu_select) +static int do_mtrr_list(int reg_count, int cpu_select) { struct mtrr_info info; int ret; @@ -39,7 +39,7 @@ static int do_mtrr_list(int cpu_select) ret = mp_run_on_cpus(cpu_select, read_mtrrs, &info); if (ret) return log_msg_ret("run", ret); - for (i = 0; i < MTRR_COUNT; i++) { + for (i = 0; i < reg_count; i++) { const char *type = "Invalid"; uint64_t base, mask, size; bool valid; @@ -98,6 +98,7 @@ static int do_mtrr_set(int cpu_select, uint reg, int argc, char *const argv[]) static int do_mtrr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + int reg_count = mtrr_get_var_count(); int cmd; int cpu_select; uint reg; @@ -126,7 +127,7 @@ static int do_mtrr(struct cmd_tbl *cmdtp, int flag, int argc, if (argc < 2) return CMD_RET_USAGE; reg = simple_strtoul(argv[1], NULL, 16); - if (reg >= MTRR_COUNT) { + if (reg >= reg_count) { printf("Invalid register number\n"); return CMD_RET_USAGE; } @@ -145,7 +146,7 @@ static int do_mtrr(struct cmd_tbl *cmdtp, int flag, int argc, if (!first) printf("\n"); printf("CPU %d:\n", i); - ret = do_mtrr_list(i); + ret = do_mtrr_list(reg_count, i); if (ret) { printf("Failed to read CPU %d (err=%d)\n", i, ret);
At present the 'bdinfo' command shows the framebuffer address, but not the address of the copy framebuffer, if present. Add support for this.
cmd/bdinfo.c | 26 +++++++++++++++++++++++++- 1 file changed, 25 insertions(+), 1 deletion(-)
diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index 9593b345a3d..2d88eb18ba7 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -8,9 +8,11 @@
#include <common.h> #include <command.h> +#include <dm.h> #include <env.h> #include <lmb.h> #include <net.h> +#include <video.h> #include <vsprintf.h> #include <asm/cache.h>
@@ -66,6 +68,26 @@ __weak void arch_print_bdinfo(void) { }
+static void show_video_info(void) +{ + const struct udevice *dev; + struct uclass *uc; + + uclass_id_foreach_dev(UCLASS_VIDEO, dev, uc) { + printf("%-12s= %s %sactive\n", "Video", dev->name, + device_active(dev) ? "" : "in"); + if (device_active(dev)) { + struct video_priv *upriv = dev_get_uclass_priv(dev); + + print_phys_addr("FB base", (ulong)upriv->fb); + if (upriv->copy_fb) + print_phys_addr("FB copy", (ulong)upriv->copy_fb); + printf("%-12s= %dx%dx%d\n", "FB size", upriv->xsize, + upriv->ysize, 1 << upriv->bpix); + } + } +} + int do_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { struct bd_info *bd = gd->bd; @@ -96,7 +118,9 @@ int do_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) bdinfo_print_num("fdt_blob", (ulong)gd->fdt_blob); bdinfo_print_num("new_fdt", (ulong)gd->new_fdt); bdinfo_print_num("fdt_size", (ulong)gd->fdt_size); -#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) || defined(CONFIG_DM_VIDEO) + if (IS_ENABLED(CONFIG_DM_VIDEO)) + show_video_info(); +#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) bdinfo_print_num("FB base ", gd->fb_base); #endif #if CONFIG_IS_ENABLED(MULTI_DTB_FIT)
Bin Meng
