[U-Boot-Users] Unable to compile the U-boot-0.4.8 version for OMAP1610/1510/smdk2410
Hi All, I am not able to compile the new u-boot tar ball i.e. u-boot-0.4.8, u-boot-0.4.7 compiles fine . I got the following error message after make omap1610inn_config make command
"In file included from /home/rahul/omap1610/0-4-8/u-boot-0.4.8/include/common.h:4 0, from uboot_drv.c:26: /usr/lib/gcc-lib/i386-redhat-linux/2.96/include/stdarg.h:43: parse error before `__gnuc_va_list' /usr/lib/gcc-lib/i386-redhat-linux/2.96/include/stdarg.h:43: warning: data defin ition has no type or storage class /usr/lib/gcc-lib/i386-redhat-linux/2.96/include/stdarg.h:110: parse error before `va_list' "
can anybody tell me what is the problem.
Thanks Rahul
Dear Rahul,
This means that your cross compiler is broken. The cross compiler must NEVER reference include files from the native development system.
Wolfgang Denk wrote:
Dear Rahul,
Um, it's not the cross compiler that's doing it in this case. gccincdir is not defined for drivers/sk98lin. Try the attached patch. It WFM/YMMV.
-- Regards, George
--- drivers/sk98lin/Makefile.orig Fri Sep 12 10:15:26 2003 +++ drivers/sk98lin/Makefile Fri Sep 12 10:11:56 2003 @@ -25,6 +25,8 @@ # Makefile for the SysKonnect SK-98xx device driver. #
+include $(TOPDIR)/config.mk + LIB := libsk98lin.a
OBJS := skge.o skaddr.o skgehwt.o skgeinit.o skgepnmi.o skgesirq.o \
Dear George,
Well, gccincdir is not needed for drivers/sk98lin/* - at least not with the compilers used in the ELDK. Also, I seriously doubt if drivers/sk98lin is actually used by the omap1610inn board.
But this patch is OK anyway. Thanks for the hint.
Dear George,
Hm, that's odd. FWIW, I just tested:
ftp://ftp.leo.org/pub/eldk/2.1.0/eldk-arm-linux-x86
and it has the exact same build failure as:
ftp://ftp.arm.linux.org.uk/pub/armlinux/toolchain/cross-2.95.3.tar.bz2
Due to:
make[1]: Entering directory `/Projects/OSS/cvs.sourceforge.net/u-boot/u-boot/drivers/sk98lin' arm-linux-gcc ... -isystem /usr/lib/gcc-lib/i386-redhat-linux/2.96/include ... -c -o skge.o skge.c
W/o the patch. But I'm just being pedantic now. : )
Correct, it's not used for omap1610inn board. But it gets built anyway and causes the build to fail due to "-isystem $(gccincdir)" where gccincdir is not explicitly defined and is probably just picking up a default from some builtin makerules or something?
-- Regards, George
George G. Davis
Rahul Shanbhag
