[U-Boot] [PATCH] am33xx: Enable D-CACHE on !CONFIG_SYS_DCACHE_OFF
Test on Beaglebone white over cpsw, usb ether and SD card (read and write), performance increased, crc32 of data matches.
Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/board.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 2ea3d69..c261af5 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -225,3 +225,11 @@ void s_init(void) sdram_init(); #endif } + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} +#endif /* !CONFIG_SYS_DCACHE_OFF */
Hi Tom,
- /* Enable D-cache. I-cache is already enabled in start.S */
- dcache_enable();
This is fine. Do we have secure devices here ?
If so, we should take care of setting the domains permissions for avoiding prefetch aborts. As it was done for OMAP using arm_init_domains. So that function and the above should be executed on am33xx as well.
Thanks to Lokesh for reminding this.
Regards, Sricharan
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 08/30/2013 12:50 AM, Sricharan R wrote:
Hi Tom,
- dcache_enable();
Yes, but I can't easily test them. I'll see if arm_init_domains just works on non-HS devices (I know I had a failure pulling all the OMAP4 code over, but didn't try hard, just looked again at the "easy" path).
- -- Tom
Hi Tom,
- dcache_enable();
Yeah, that code as-is hangs the boards. So if the HS devices need something, it'll go with the rest of their patches until we're moving it upstream. But good to note a potential problem area!
Hi Tom,
- dcache_enable();
I added the following diff and I am able to boot my BBB over cpsw.
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 2ea3d69..8a1a29a 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -31,6 +31,11 @@ #include <linux/usb/gadget.h> #include <linux/usb/musb.h> #include <asm/omap_musb.h> +#include <asm/cache.h> + +#define ARMV7_DCACHE_WRITEBACK 0xe +#define ARMV7_DOMAIN_CLIENT 1 +#define ARMV7_DOMAIN_MASK (0x3 << 0)
DECLARE_GLOBAL_DATA_PTR;
@@ -225,3 +230,40 @@ void s_init(void) sdram_init(); #endif } + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} + +void dram_bank_mmu_setup(int bank) +{ + bd_t *bd = gd->bd; + int i; + + u32 start = bd->bi_dram[bank].start >> 20; + u32 size = bd->bi_dram[bank].size >> 20; + u32 end = start + size; + + debug("%s: bank: %d\n", __func__, bank); + for (i = start; i < end; i++) + set_section_dcache(i, ARMV7_DCACHE_WRITEBACK); + +} + +void arm_init_domains(void) +{ + u32 reg; + + reg = get_dacr(); + /* + * Set DOMAIN to client access so that all permissions + * set in pagetables are validated by the mmu. + */ + reg &= ~ARMV7_DOMAIN_MASK; + reg |= ARMV7_DOMAIN_CLIENT; + set_dacr(reg); +} +#endif
AM I missing something here ?
Thanks and regards, Lokesh
Hi Tom,
- dcache_enable();
- dcache_enable();
- bd_t *bd = gd->bd;
- int i;
- u32 start = bd->bi_dram[bank].start >> 20;
- u32 size = bd->bi_dram[bank].size >> 20;
- u32 end = start + size;
- debug("%s: bank: %d\n", __func__, bank);
- for (i = start; i < end; i++)
- u32 reg;
- reg = get_dacr();
- Set DOMAIN to client access so that all permissions
- set in pagetables are validated by the mmu.
- reg &= ~ARMV7_DOMAIN_MASK;
- reg |= ARMV7_DOMAIN_CLIENT;
- set_dacr(reg);
+} +#endif
Or I am. That gives me a straight up hang, like I saw before. What toolchain are you using? I'm trying ELDK 5.2 and Linaro 2013.04.
Applied to u-boot-ti/master, thanks!
Lokesh Vutla
Sricharan R
