[U-Boot] [PATCH] powerpc/85xx: add fdt_fixup_dma3
On some SoC(e.g. T2080/T4240) the 3rd DMA is not functional if SRIO2 is chosen. we add fdt_fixup_dma3() to disable the 3rd DMA if SRIO2 is chosen.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- arch/powerpc/cpu/mpc85xx/fdt.c | 47 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 594a9fc..a7e6cc8 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -615,6 +615,51 @@ static void fdt_fixup_usb(void *fdt) #define fdt_fixup_usb(x) #endif
+#if defined(CONFIG_PPC_T2080) || defined(CONFIG_PPC_T4240) || \ + defined(CONFIG_PPC_T4160) || defined(CONFIG_PPC_T4080) +void fdt_fixup_dma3(void *blob) +{ + /* the 3rd DMA is not functional if SRIO2 is chosen */ + int nodeoff; + ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + +#define CONFIG_SYS_ELO3_DMA3 (0xffe000000 + 0x102300) +#if defined(CONFIG_PPC_T2080) + u32 srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + + switch (srds_prtcl_s2) { + case 0x29: + case 0x2d: + case 0x2e: +#elif defined(CONFIG_PPC_T4240) || defined(CONFIG_PPC_T4160) || \ + defined(CONFIG_PPC_T4080) + u32 srds_prtcl_s4 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS4_PRTCL; + srds_prtcl_s4 >>= FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT; + + switch (srds_prtcl_s4) { + case 6: + case 8: + case 14: + case 16: +#endif + nodeoff = fdt_node_offset_by_compat_reg(blob, "fsl,elo3-dma", + CONFIG_SYS_ELO3_DMA3); + if (nodeoff > 0) + fdt_status_disabled(blob, nodeoff); + else + printf("WARNING: unable to disable dma3\n"); + break; + default: + break; + } +} +#else +#define fdt_fixup_dma3(x) +#endif + #if defined(CONFIG_PPC_T1040) static void fdt_fixup_l2_switch(void *blob) { @@ -784,6 +829,8 @@ void ft_cpu_setup(void *blob, bd_t *bd) fdt_fixup_usb(blob);
fdt_fixup_l2_switch(blob); + + fdt_fixup_dma3(blob); }
Shengzhou Liu
