[U-Boot] [v2] armv8/fsl-layerscape: fdt: avoid incorrect fixing with CONFIG_SYS_CLK_FREQ
Current sysclk fixing would fix all clocks with 'fixed-clock' compatible. This patch is to fix sysclk by path to avoid any incorrect fixing.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 762a95b..05c4577 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -373,8 +373,8 @@ void ft_cpu_setup(void *blob, bd_t *bd) "clock-frequency", CONFIG_SYS_NS16550_CLK, 1); #endif
- do_fixup_by_compat_u32(blob, "fixed-clock", - "clock-frequency", CONFIG_SYS_CLK_FREQ, 1); + do_fixup_by_path_u32(blob, "/sysclk", "clock-frequency", + CONFIG_SYS_CLK_FREQ, 1);
#ifdef CONFIG_PCI ft_pci_setup(blob, bd);
Applied to u-boot-fsl-qoriq master, awaiting upstream. Thanks.
York
Yangbo Lu
York Sun
