Re: [U-Boot] Please pull u-boot-marvell master
Hi Tom,
please ignore this pull. For some reason body of commit messages is missing - thanks Stefan for pointing this out. I will fix and resend.
Regards, Luka
On Thu, Jul 23, 2015 at 08:35:10AM +0200, Luka Perkov wrote:
Hi Tom,
can you please pull the mvebu tree? This series contains mvebu DDR training code and couple of bug fixes.
Thanks, Luka
The following changes since commit b217c89e8565ade3aaa9f74c33c93236bf151187:
Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriq (2015-07-20 17:12:52 -0400)
git://git.denx.de/u-boot-marvell.git
for you to fetch changes up to 58048856126ebe932395abaffa8372b66f64d0e1:
arm: mvebu: db-88f6820: Add SPL support with DDR init code (2015-07-23 08:30:59 +0200)
Anton Schubert (1): arm: mvebu: add Armada XP SATA support
Stefan Roese (11): arm: mvebu: Call timer_init early before PHY and DDR init arm: mvebu: Use default reg base address for SPL on A38x arm: mvebu: spl.c: Add call to board_early_init_f() arm: mvebu: Disable MMU before changing register base address Makefile: Fix mvebu build target to use SPL load and exe-address arm: mvebu: serdes: Move Armada XP SERDES / PHY init code into new directory arm: mvebu: Add Armada 38x SERDES / PHY init code from Marvell bin_hdr arm: mvebu: drivers/ddr: Move Armada XP DDR init code into new directory arm: mvebu: Add Armada 38x DDR3 training code from Marvell bin_hdr arm: mvebu: a38x: Use correct PEX register access macros arm: mvebu: db-88f6820: Add SPL support with DDR init code
Makefile | 2 +- arch/arm/mach-mvebu/Makefile | 4 +- arch/arm/mach-mvebu/cpu.c | 18 + arch/arm/mach-mvebu/include/mach/cpu.h | 2 +- arch/arm/mach-mvebu/include/mach/soc.h | 11 + arch/arm/mach-mvebu/serdes/a38x/Makefile | 10 + arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.c | 347 +++ arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h | 86 + .../serdes/a38x/high_speed_env_spec-38x.c | 158 ++ .../mach-mvebu/serdes/a38x/high_speed_env_spec.c | 2228 +++++++++++++++++ .../mach-mvebu/serdes/a38x/high_speed_env_spec.h | 251 ++ .../serdes/a38x/high_speed_topology_spec-38x.c | 1009 ++++++++ .../serdes/a38x/high_speed_topology_spec.h | 124 + arch/arm/mach-mvebu/serdes/a38x/seq_exec.c | 170 ++ arch/arm/mach-mvebu/serdes/a38x/seq_exec.h | 65 + arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c | 388 +++ arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h | 371 +++ arch/arm/mach-mvebu/serdes/{ => axp}/Makefile | 0 .../mach-mvebu/serdes/{ => axp}/board_env_spec.h | 0 .../serdes/{ => axp}/high_speed_env_lib.c | 0 .../serdes/{ => axp}/high_speed_env_spec.c | 0 .../serdes/{ => axp}/high_speed_env_spec.h | 2 +- arch/arm/mach-mvebu/spl.c | 9 + arch/arm/mach-mvebu/timer.c | 7 + board/Marvell/db-88f6820-gp/README | 18 + board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 31 + board/Marvell/db-88f6820-gp/kwbimage.cfg | 2 +- board/maxbcm/maxbcm.c | 4 +- configs/db-88f6820-gp_defconfig | 1 + drivers/block/mvsata_ide.c | 41 + drivers/ddr/marvell/a38x/Makefile | 19 + drivers/ddr/marvell/a38x/ddr3_a38x.c | 741 ++++++ drivers/ddr/marvell/a38x/ddr3_a38x.h | 98 + drivers/ddr/marvell/a38x/ddr3_a38x_mc_static.h | 226 ++ drivers/ddr/marvell/a38x/ddr3_a38x_topology.h | 22 + drivers/ddr/marvell/a38x/ddr3_a38x_training.c | 40 + drivers/ddr/marvell/a38x/ddr3_debug.c | 1551 ++++++++++++ drivers/ddr/marvell/a38x/ddr3_hws_hw_training.c | 148 ++ drivers/ddr/marvell/a38x/ddr3_hws_hw_training.h | 49 + .../ddr/marvell/a38x/ddr3_hws_hw_training_def.h | 467 ++++ drivers/ddr/marvell/a38x/ddr3_hws_sil_training.h | 17 + drivers/ddr/marvell/a38x/ddr3_init.c | 852 +++++++ drivers/ddr/marvell/a38x/ddr3_init.h | 395 +++ drivers/ddr/marvell/a38x/ddr3_logging_def.h | 101 + drivers/ddr/marvell/a38x/ddr3_patterns_64bit.h | 924 +++++++ drivers/ddr/marvell/a38x/ddr3_topology_def.h | 76 + drivers/ddr/marvell/a38x/ddr3_training.c | 2644 ++++++++++++++++++++ drivers/ddr/marvell/a38x/ddr3_training_bist.c | 289 +++ .../marvell/a38x/ddr3_training_centralization.c | 714 ++++++ drivers/ddr/marvell/a38x/ddr3_training_db.c | 652 +++++ drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c | 686 +++++ drivers/ddr/marvell/a38x/ddr3_training_hw_algo.h | 14 + drivers/ddr/marvell/a38x/ddr3_training_ip.h | 180 ++ drivers/ddr/marvell/a38x/ddr3_training_ip_bist.h | 54 + .../marvell/a38x/ddr3_training_ip_centralization.h | 15 + drivers/ddr/marvell/a38x/ddr3_training_ip_db.h | 34 + drivers/ddr/marvell/a38x/ddr3_training_ip_def.h | 173 ++ drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c | 1354 ++++++++++ drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h | 85 + drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h | 349 +++ drivers/ddr/marvell/a38x/ddr3_training_ip_pbs.h | 41 + drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h | 107 + drivers/ddr/marvell/a38x/ddr3_training_ip_static.h | 31 + drivers/ddr/marvell/a38x/ddr3_training_leveling.c | 1836 ++++++++++++++ drivers/ddr/marvell/a38x/ddr3_training_leveling.h | 17 + drivers/ddr/marvell/a38x/ddr3_training_pbs.c | 995 ++++++++ drivers/ddr/marvell/a38x/ddr3_training_static.c | 538 ++++ drivers/ddr/marvell/a38x/ddr_topology_def.h | 112 + drivers/ddr/marvell/a38x/ddr_training_ip_db.h | 16 + drivers/ddr/marvell/a38x/silicon_if.h | 17 + drivers/ddr/marvell/a38x/xor.c | 356 +++ drivers/ddr/marvell/a38x/xor.h | 92 + drivers/ddr/marvell/a38x/xor_regs.h | 236 ++ drivers/ddr/{mvebu => marvell/axp}/Makefile | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_axp.h | 0 .../ddr/{mvebu => marvell/axp}/ddr3_axp_config.h | 0 .../{mvebu => marvell/axp}/ddr3_axp_mc_static.h | 0 .../axp}/ddr3_axp_training_static.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_vars.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_dfs.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_dqs.c | 0 .../ddr/{mvebu => marvell/axp}/ddr3_hw_training.c | 0 .../ddr/{mvebu => marvell/axp}/ddr3_hw_training.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_init.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_init.h | 0 .../{mvebu => marvell/axp}/ddr3_patterns_64bit.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_pbs.c | 0 .../{mvebu => marvell/axp}/ddr3_read_leveling.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_sdram.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_spd.c | 0 .../{mvebu => marvell/axp}/ddr3_write_leveling.c | 0 drivers/ddr/{mvebu => marvell/axp}/xor.c | 0 drivers/ddr/{mvebu => marvell/axp}/xor.h | 0 drivers/ddr/{mvebu => marvell/axp}/xor_regs.h | 0 include/configs/db-88f6820-gp.h | 35 + include/configs/db-mv784mp-gp.h | 31 +- include/configs/maxbcm.h | 2 +- scripts/Makefile.spl | 3 +- 98 files changed, 22783 insertions(+), 10 deletions(-) create mode 100644 arch/arm/mach-mvebu/serdes/a38x/Makefile create mode 100644 arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec-38x.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_topology_spec-38x.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_topology_spec.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/seq_exec.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/seq_exec.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h rename arch/arm/mach-mvebu/serdes/{ => axp}/Makefile (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/board_env_spec.h (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/high_speed_env_lib.c (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/high_speed_env_spec.c (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/high_speed_env_spec.h (97%) create mode 100644 board/Marvell/db-88f6820-gp/README create mode 100644 drivers/ddr/marvell/a38x/Makefile create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x_mc_static.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x_topology.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x_training.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_debug.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_hw_training.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_hw_training.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_hw_training_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_sil_training.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_init.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_init.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_logging_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_patterns_64bit.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_bist.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_centralization.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_db.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_hw_algo.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_bist.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_centralization.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_db.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_pbs.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_static.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_leveling.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_leveling.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_pbs.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_static.c create mode 100644 drivers/ddr/marvell/a38x/ddr_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr_training_ip_db.h create mode 100644 drivers/ddr/marvell/a38x/silicon_if.h create mode 100644 drivers/ddr/marvell/a38x/xor.c create mode 100644 drivers/ddr/marvell/a38x/xor.h create mode 100644 drivers/ddr/marvell/a38x/xor_regs.h rename drivers/ddr/{mvebu => marvell/axp}/Makefile (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_config.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_mc_static.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_training_static.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_vars.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_dfs.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_dqs.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_hw_training.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_hw_training.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_init.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_init.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_patterns_64bit.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_pbs.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_read_leveling.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_sdram.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_spd.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_write_leveling.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/xor.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/xor.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/xor_regs.h (100%)
Luka Perkov
