[U-Boot] [PATCH] bootm: fdt: Use panic() instead of hang() when presented with a bad image
When the image which bootm is given can't be booted, call panic with the error message rather than printf/hang so that we can recover from broken images via a bootcount mechanism. If hang on failure is still required then CONFIG_PANIC_HANG can still be enabled.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
arch/arm/lib/bootm.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index c3c1d2fdfa..a5ed12df74 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -230,8 +230,7 @@ static void boot_prep_linux(bootm_headers_t *images) #ifdef CONFIG_OF_LIBFDT debug("using: FDT\n"); if (image_setup_linux(images)) { - printf("FDT creation failed! hanging..."); - hang(); + panic("FDT creation failed!\n"); } #endif } else if (BOOTM_ENABLE_TAGS) { @@ -264,8 +263,7 @@ static void boot_prep_linux(bootm_headers_t *images) setup_board_tags(¶ms); setup_end_tag(gd->bd); } else { - printf("FDT and ATAGS support not compiled in - hanging\n"); - hang(); + panic("FDT and ATAGS support not compiled in\n"); } }
This sounds plausible to me, but I think you'll want to send this patch To/Cc someone who owns that file. At least Tom Rini (now CC'd hence quoting the entire patch for context).
hang();
} #endif } else if (BOOTM_ENABLE_TAGS) {panic("FDT creation failed!\n");
hang();
} }panic("FDT and ATAGS support not compiled in\n");
Dear Alex,
I wonder if the failing of the FDT creation is a reason to panic / reboot at all? The point of no return is architecture dependent - for example, on Power architecture it is usuallywhen the kernel image gests decompressed/written to RAM, as then the exception vectors get overwritten, so no return to U-Boot is possible.
But the FDT is always (I think ?) just written to an area of RAM that is not critical for the execution of U-Boot itself - so when this fails, why can we not simply return to U-Boot with an eroor indication?
I feel we should use panic/hang only as a last resort, when no other recovery is possible?
On Fri, Sep 21, 2018 at 1:43 PM Wolfgang Denk wd@denx.de wrote:
Dear Alex,
Thinking it through, that sounds reasonable to me... the reason I ended up looking at this code was because I deployed a broken FIT image, then got stuck here. But if bootm had returned with a failure I could have done useful recovery actions without needing a reboot.
Alex Kiernan
Stephen Warren
