[U-Boot] [PATCH v2 00/14] rockchip: Add new rk3399 boards
This series is combination of previous version[1] plus new rk3399 boards addition.
Overall this series add support below rk3399 boards - Orangepi RK3399 - Nanopc T4 - Nanopi M4 - Nanopi NEO4 - Orangepi RK3399 - Rockpro64
All the respective dts(i) files are synced from Linux 5.1-rc2 and few dts(i) from linux-next.
Nanopi NEO4, Rockpro64 are supporting via Rockchip miniloader, and rest support both Rockchip miniloader along with U-Boot SPL.
- Rockpro64, is not possible to boot via U-Boot SPL since it has dependency with LPDDR4 code which is work-in-progress and as soon it arrived in mailing list, will update the same with ddr dtsi. - Nanopi NEO4 has some ddr issue with[2] rk3399-sdram-ddr3-1866.dtsi, will update the same with U-Boot SPL once it is fixed.
patch 1, 2: Sync rk3399 dtsi files from Linux 5.1-rc2
patch 3: Create global rk3399-u-boot.dtsi
patch 4: move default SPL_FIT_GENERATOR to Kconfig
patch 5: Move common rk3399 configs into Kconfig
patch 6: Add Orangepi RK3399 support
patch 7: Sync rk3399-nanopi4.dtsi from Linux
patch 8: Fix for sdmmc CD pin
patch 9: Add 4GB LPDDR3-1866 ddr dtsi
patch 10: Add Nanopi M4 support
patch 11: Add Nanopc T4 support
patch 12: Add Nanopi NEO4 support
patch 13: Add Rockpro64 support
patch 14: Global document for build/flash
[2] https://marc.info/?l=u-boot&m=154671835328469&w=2 [1] https://patchwork.ozlabs.org/patch/1054208/
Any inputs? Jagan.
Jagan Teki (14): rockchip: dts: rk3399: Sync rk3399-opp from Linux rockchip: dts: rk3399: Sync pwm2_pin_pull_down from Linux 5.1-rc2 rockchip: dts: rk3399: Create initial rk3399-u-boot.dtsi Kconfig: Add default SPL_FIT_GENERATOR for rockchip arm: rockchip: rk3399: Move common configs in Kconfig rockchip: rk3399: Add Orangepi RK3399 support rockchip: dts: rk3399: Sync rk3399-nanopi4.dtsi from Linux rockchip: dts: rk3399: nanopi4: Use CD pin as RK_FUNC_1 rockchip: rk3399: Add 4GB LPDDR3-1866 DMC settings rockchip: rk3399: Add Nanopi M4 board support rockchip: rk3399: Add Nanopc T4 board support rockchip: rk3399: Add Nanopi NEO4 board support rockchip: rk3399: Add Rockpro64 board support doc: rockchip: Add global doc for rk3399 build/flash
Kconfig | 1 + arch/arm/dts/Makefile | 5 + arch/arm/dts/rk3399-evb.dts | 1 - arch/arm/dts/rk3399-firefly.dts | 1 - arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi | 7 + arch/arm/dts/rk3399-nanopc-t4.dts | 91 + arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi | 7 + arch/arm/dts/rk3399-nanopi-m4.dts | 66 + arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi | 6 + arch/arm/dts/rk3399-nanopi-neo4.dts | 50 + arch/arm/dts/rk3399-nanopi4.dtsi | 699 ++++++++ arch/arm/dts/rk3399-opp.dtsi | 133 ++ arch/arm/dts/rk3399-orangepi-u-boot.dtsi | 7 + arch/arm/dts/rk3399-orangepi.dts | 771 +++++++++ arch/arm/dts/rk3399-puma.dtsi | 1 - arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 6 + arch/arm/dts/rk3399-rockpro64.dts | 712 ++++++++ .../arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi | 1535 +++++++++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 8 + arch/arm/dts/rk3399.dtsi | 6 + arch/arm/mach-rockchip/Kconfig | 16 + board/rockchip/evb_rk3399/MAINTAINERS | 32 + configs/chromebook_bob_defconfig | 17 - configs/evb-rk3399_defconfig | 17 - configs/ficus-rk3399_defconfig | 17 - configs/firefly-rk3399_defconfig | 17 - configs/nanopc-t4-rk3399_defconfig | 58 + configs/nanopi-m4-rk3399_defconfig | 58 + configs/nanopi-neo4-rk3399_defconfig | 58 + configs/orangepi-rk3399_defconfig | 58 + configs/puma-rk3399_defconfig | 16 - configs/rock960-rk3399_defconfig | 17 - configs/rockpro64-rk3399_defconfig | 58 + doc/README.rockchip | 209 ++- 34 files changed, 4656 insertions(+), 105 deletions(-) create mode 100644 arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopc-t4.dts create mode 100644 arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-m4.dts create mode 100644 arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-neo4.dts create mode 100644 arch/arm/dts/rk3399-nanopi4.dtsi create mode 100644 arch/arm/dts/rk3399-opp.dtsi create mode 100644 arch/arm/dts/rk3399-orangepi-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-orangepi.dts create mode 100644 arch/arm/dts/rk3399-rockpro64-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-rockpro64.dts create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi create mode 100644 arch/arm/dts/rk3399-u-boot.dtsi create mode 100644 configs/nanopc-t4-rk3399_defconfig create mode 100644 configs/nanopi-m4-rk3399_defconfig create mode 100644 configs/nanopi-neo4-rk3399_defconfig create mode 100644 configs/orangepi-rk3399_defconfig create mode 100644 configs/rockpro64-rk3399_defconfig
Sync rk3399-opp.dtsi from Linux.
Linux commit details about the rk3399-opp.dtsi sync: "arm64: dts: rockchip: use SPDX-License-Identifier" (sha1: 4ee99cebd486238ac433da823b95cc5f8d8a6905)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-opp.dtsi | 133 +++++++++++++++++++++++++++++++++++ 1 file changed, 133 insertions(+) create mode 100644 arch/arm/dts/rk3399-opp.dtsi
diff --git a/arch/arm/dts/rk3399-opp.dtsi b/arch/arm/dts/rk3399-opp.dtsi new file mode 100644 index 0000000000..d6f1095abb --- /dev/null +++ b/arch/arm/dts/rk3399-opp.dtsi @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd + */ + +/ { + cluster0_opp: opp-table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp00 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <800000>; + clock-latency-ns = <40000>; + }; + opp01 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <800000>; + }; + opp02 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <850000>; + }; + opp03 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <925000>; + }; + opp04 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1000000>; + }; + opp05 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1125000>; + }; + }; + + cluster1_opp: opp-table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp00 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <800000>; + clock-latency-ns = <40000>; + }; + opp01 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <800000>; + }; + opp02 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <825000>; + }; + opp03 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <875000>; + }; + opp04 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <950000>; + }; + opp05 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1025000>; + }; + opp06 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <1100000>; + }; + opp07 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1200000>; + }; + }; + + gpu_opp_table: opp-table2 { + compatible = "operating-points-v2"; + + opp00 { + opp-hz = /bits/ 64 <200000000>; + opp-microvolt = <800000>; + }; + opp01 { + opp-hz = /bits/ 64 <297000000>; + opp-microvolt = <800000>; + }; + opp02 { + opp-hz = /bits/ 64 <400000000>; + opp-microvolt = <825000>; + }; + opp03 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <875000>; + }; + opp04 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <925000>; + }; + opp05 { + opp-hz = /bits/ 64 <800000000>; + opp-microvolt = <1100000>; + }; + }; +}; + +&cpu_l0 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l1 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l2 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l3 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_b0 { + operating-points-v2 = <&cluster1_opp>; +}; + +&cpu_b1 { + operating-points-v2 = <&cluster1_opp>; +}; + +&gpu { + operating-points-v2 = <&gpu_opp_table>; +};
Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com
Cheers,
Paul
- Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd
- cluster0_opp: opp-table0 {
opp-shared;
opp00 {
opp01 {
opp02 {
opp03 {
opp04 {
opp05 {
- cluster1_opp: opp-table1 {
opp-shared;
opp00 {
opp01 {
opp02 {
opp03 {
opp04 {
opp05 {
opp06 {
opp07 {
- gpu_opp_table: opp-table2 {
opp00 {
opp01 {
opp02 {
opp03 {
opp04 {
opp05 {
+&cpu_l0 {
- operating-points-v2 = <&cluster0_opp>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
- operating-points-v2 = <&cluster1_opp>;
+&cpu_b1 {
+&gpu {
- operating-points-v2 = <&gpu_opp_table>;
To make successful build with dts(i) files syncing from Linux 5.1-rc2 the rk3399.dtsi would require pwm2_pin_pull_down.
So, sync the pwm2_pin_pull_down node from Linux 5.1-rc2. Since this node is strictly not part of any commit alone, I have mentioned Linux 5.1-rc2 tag for future reference of where would this sync coming from.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index b53e41b4dc..99471f6287 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -2495,6 +2495,12 @@ rockchip,pins = <1 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; }; + + + pwm2_pin_pull_down: pwm2-pin-pull-down { + rockchip,pins = + <1 RK_PC3 RK_FUNC_1 &pcfg_pull_down>; + }; };
pwm3a {
Cheers,
Paul
rockchip,pins =
pwm3a {
u-boot,dm-pre-reloc is required for SDMMC booted rk3399 boards and which is U-Boot specific devicetrees binding.
Move it on global rk3399-u-boot.dtsi file and rest of the U-Boot bindings will move it future based on the requirement.
This would help to sync the devicetrees from Linux whenever required instead of adding specific nodes.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-evb.dts | 1 - arch/arm/dts/rk3399-firefly.dts | 1 - arch/arm/dts/rk3399-puma.dtsi | 1 - arch/arm/dts/rk3399-u-boot.dtsi | 8 ++++++++ 4 files changed, 8 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/rk3399-u-boot.dtsi
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index ce004d0d18..9162f3dd50 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -155,7 +155,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; status = "okay"; }; diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index f90e7e88db..46f2ffaf8d 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -592,7 +592,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; status = "okay"; }; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 8304f67192..9049694243 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -492,7 +492,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; clock-frequency = <150000000>; max-frequency = <40000000>; supports-sd; diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi new file mode 100644 index 0000000000..f533ed95eb --- /dev/null +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +&sdmmc { + u-boot,dm-pre-reloc; +};
Cheers,
Paul
&sdmmc {
&sdmmc {
&sdmmc {
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
+&sdmmc {
Add default SPL_FIT_GENERATOR py script for rockchip platforms if specific target enabled SPL_LOAD_FIT.
So, this would help get rid of explicitly mentioning the default SPL FIT generator in defconfigs. however some targets, like puma_rk3399 still require their own FIT generator so in those cases the default will override with defconfig defined generator.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Kconfig | 1 + configs/chromebook_bob_defconfig | 1 - configs/evb-rk3399_defconfig | 1 - configs/ficus-rk3399_defconfig | 1 - configs/firefly-rk3399_defconfig | 1 - configs/rock960-rk3399_defconfig | 1 - 6 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/Kconfig b/Kconfig index 305b265ed7..5679a288ec 100644 --- a/Kconfig +++ b/Kconfig @@ -424,6 +424,7 @@ config SPL_FIT_GENERATOR string ".its file generator script for U-Boot FIT image" depends on SPL_FIT default "board/sunxi/mksunxi_fit_atf.sh" if SPL_LOAD_FIT && ARCH_SUNXI + default "arch/arm/mach-rockchip/make_fit_atf.py" if SPL_LOAD_FIT && ARCH_ROCKCHIP help Specifies a (platform specific) script file to generate the FIT source file used to build the U-Boot FIT image file. This gets diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index ce3deccb8a..04e25e1d4f 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -19,7 +19,6 @@ CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index d98535357a..49b2e2e089 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -13,7 +13,6 @@ CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 94c565efc2..fe3b9964e8 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 6725b48970..914304bb43 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -13,7 +13,6 @@ CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index cb5a35f4f5..5e6778ea20 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y
Cheers,
Paul
- default "arch/arm/mach-rockchip/make_fit_atf.py" if SPL_LOAD_FIT && ARCH_ROCKCHIP help Specifies a (platform specific) script file to generate the FIT source file used to build the U-Boot FIT image file. This gets
Few SPL and U-Boot proper configs are common to all rk3399 target defconfigs, move them and select it from platform kconfig.
Moved configs: - SPL_ATF - SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF - SPL_LOAD_FIT - SPL_CLK if SPL - SPL_PINCTRL if SPL - SPL_RAM if SPL - SPL_REGMAP if SPL - SPL_SYSCON if SPL - CLK - FIT - PINCTRL - RAM - REGMAP - SYSCON - DM_PMIC - DM_REGULATOR_FIXED
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-rockchip/Kconfig | 16 ++++++++++++++++ configs/chromebook_bob_defconfig | 16 ---------------- configs/evb-rk3399_defconfig | 16 ---------------- configs/ficus-rk3399_defconfig | 16 ---------------- configs/firefly-rk3399_defconfig | 16 ---------------- configs/puma-rk3399_defconfig | 16 ---------------- configs/rock960-rk3399_defconfig | 16 ---------------- 7 files changed, 16 insertions(+), 96 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index b9a026abb5..dbe7f11d39 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -132,9 +132,25 @@ config ROCKCHIP_RK3399 select ARM64 select SUPPORT_SPL select SPL + select SPL_ATF + select SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF + select SPL_LOAD_FIT + select SPL_CLK if SPL + select SPL_PINCTRL if SPL + select SPL_RAM if SPL + select SPL_REGMAP if SPL + select SPL_SYSCON if SPL select SPL_SEPARATE_BSS select SPL_SERIAL_SUPPORT select SPL_DRIVERS_MISC_SUPPORT + select CLK + select FIT + select PINCTRL + select RAM + select REGMAP + select SYSCON + select DM_PMIC + select DM_REGULATOR_FIXED select DEBUG_UART_BOARD_INIT select BOARD_LATE_INIT select ROCKCHIP_BROM_HELPER diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 04e25e1d4f..fdcbabf912 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -17,16 +17,12 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_SPI_LOAD=y -CONFIG_SPL_ATF=y -CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -45,12 +41,6 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-gru-bob" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_SYS_I2C_ROCKCHIP=y @@ -70,16 +60,10 @@ CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 49b2e2e089..1ba9dcba62 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -11,15 +11,11 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 -CONFIG_SPL_ATF=y -CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y @@ -32,12 +28,6 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-evb" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -47,16 +37,10 @@ CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index fe3b9964e8..67c62065aa 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -11,14 +11,10 @@ CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART=y -CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 -CONFIG_SPL_ATF=y -CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y @@ -31,12 +27,6 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-ficus" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -48,17 +38,11 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_GMAC_ROCKCHIP=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 914304bb43..1d3a7f2982 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -11,15 +11,11 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 -CONFIG_SPL_ATF=y -CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y @@ -31,12 +27,6 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -47,16 +37,10 @@ CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 3547ec6b27..e5ea2fe0b3 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -15,8 +15,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_SOURCE="board/theobroma-systems/puma_rk3399/fit_spl_atf.its" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_MISC_INIT_R=y @@ -31,8 +29,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_SPL_ATF=y -CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y @@ -51,12 +47,6 @@ CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-ddr1600" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -74,20 +64,14 @@ CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_DM_PMIC=y CONFIG_DM_PMIC_FAN53555=y CONFIG_PMIC_RK8XX=y CONFIG_SPL_DM_REGULATOR=y CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_FIXED=y CONFIG_SPL_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y CONFIG_DM_RTC=y CONFIG_RTC_ISL1208=y CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 5e6778ea20..cc7d6f89b1 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -11,15 +11,11 @@ CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART=y -CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 -CONFIG_SPL_ATF=y -CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_SYS_PROMPT="rock960 => " CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y @@ -32,12 +28,6 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -45,16 +35,10 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SF_DEFAULT_SPEED=20000000 -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y
Moved configs:
- SPL_ATF
- SPL_LOAD_FIT
- SPL_CLK if SPL
- SPL_RAM if SPL
- SPL_REGMAP if SPL
- SPL_SYSCON if SPL
- CLK
- FIT
- PINCTRL
- RAM
- REGMAP
- SYSCON
- DM_PMIC
Cheers,
Paul
- select SPL_ATF
- select SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF
- select SPL_LOAD_FIT
- select SPL_CLK if SPL
- select SPL_PINCTRL if SPL
- select SPL_RAM if SPL
- select SPL_REGMAP if SPL
- select SPL_SYSCON if SPL select SPL_SEPARATE_BSS select SPL_SERIAL_SUPPORT select SPL_DRIVERS_MISC_SUPPORT
- select CLK
- select FIT
- select PINCTRL
- select RAM
- select REGMAP
- select SYSCON
- select DM_PMIC
- select DM_REGULATOR_FIXED select DEBUG_UART_BOARD_INIT select BOARD_LATE_INIT select ROCKCHIP_BROM_HELPER
Add initial support for Orangepi RK3399 board.
Specification - Rockchip RK3399 - 2GB/4GB DDR3 - 16GB eMMC - SD card slot - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI - Mini PCIe - Sensors, Keys etc - DC12V-2A and DC5V-2A
Commit details about Linux DTS sync: "arm64: dts: rockchip: Add support for the Orange Pi RK3399" (sha1: d3e71487a790979057c0fdbf32f85033639c16e6)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-orangepi-u-boot.dtsi | 7 + arch/arm/dts/rk3399-orangepi.dts | 771 +++++++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 7 + configs/orangepi-rk3399_defconfig | 58 ++ 5 files changed, 844 insertions(+) create mode 100644 arch/arm/dts/rk3399-orangepi-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-orangepi.dts create mode 100644 configs/orangepi-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0e2ffdb87f..6d55b0caf8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -87,6 +87,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-evb.dtb \ rk3399-firefly.dtb \ rk3399-gru-bob.dtb \ + rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \ diff --git a/arch/arm/dts/rk3399-orangepi-u-boot.dtsi b/arch/arm/dts/rk3399-orangepi-u-boot.dtsi new file mode 100644 index 0000000000..236b61d78d --- /dev/null +++ b/arch/arm/dts/rk3399-orangepi-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-ddr3-1333.dtsi" diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts new file mode 100644 index 0000000000..cf37b96a6b --- /dev/null +++ b/arch/arm/dts/rk3399-orangepi.dts @@ -0,0 +1,771 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. + */ + +/dts-v1/; + +#include "dt-bindings/pwm/pwm.h" +#include "dt-bindings/input/input.h" +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + model = "Orange Pi RK3399 Board"; + compatible = "rockchip,rk3399-orangepi", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + button-up { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + press-threshold-microvolt = <100000>; + }; + + button-down { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + press-threshold-microvolt = <300000>; + }; + + back { + label = "Back"; + linux,code = <KEY_BACK>; + press-threshold-microvolt = <985000>; + }; + + menu { + label = "Menu"; + linux,code = <KEY_MENU>; + press-threshold-microvolt = <1314000>; + }; + }; + + dc_12v: dc-12v { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + keys: gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + power { + debounce-interval = <100>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Power"; + linux,code = <KEY_POWER>; + linux,input-type = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_btn>; + wakeup-source; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_reg_on_h>; + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8>; + }; + + vcc3v0_sd: vcc3v0-sd { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_pwr_h>; + regulator-boot-on; + regulator-max-microvolt = <3000000>; + regulator-min-microvolt = <3000000>; + regulator-name = "vcc3v0_sd"; + vin-supply = <&vcc3v3_sys>; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_sys>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc5v0_typec0: vcc5v0-typec0-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_typec0_en>; + regulator-name = "vcc5v0_typec0"; + vin-supply = <&vcc_sys>; + }; + + vcc_sys: vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + vin-supply = <&vcc_sys>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc3v3_s3>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + status = "okay"; +}; + +&hdmi_sound { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rtc_clko_soc", "rtc_clko_wifi"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + vcc10-supply = <&vcc3v3_sys>; + vcc11-supply = <&vcc3v3_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_3v0>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v0_tp: LDO_REG2 { + regulator-name = "vcc3v0_tp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmupll: LDO_REG3 { + regulator-name = "vcc1v8_pmupll"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <2500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <2500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-name = "vcca1v8_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <2500000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c1 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; + + ak09911@c { + compatible = "asahi-kasei,ak09911"; + reg = <0x0c>; + vdd-supply = <&vcc3v3_s3>; + }; + + mpu6500@68 { + compatible = "invensense,mpu6500"; + reg = <0x68>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PC6 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&gsensor_int_l>; + vddio-supply = <&vcc3v3_s3>; + }; + + lsm6ds3@6a { + compatible = "st,lsm6ds3"; + reg = <0x6a>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PD0 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&gyr_int_l>; + vdd-supply = <&vcc3v3_s3>; + vddio-supply = <&vcc3v3_s3>; + }; + + cm32181@10 { + compatible = "capella,cm32181"; + reg = <0x10>; + interrupt-parent = <&gpio4>; + interrupts = <RK_PD0 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&light_int_l>; + vdd-supply = <&vcc3v3_s3>; + }; +}; + +&io_domains { + status = "okay"; + bt656-supply = <&vcc_3v0>; + audio-supply = <&vcca1v8_codec>; + sdmmc-supply = <&vcc_sdio>; + gpio1830-supply = <&vcc_3v0>; +}; + +&pmu_io_domains { + status = "okay"; + pmu1830-supply = <&vcc_3v0>; +}; + +&pinctrl { + buttons { + pwr_btn: pwr-btn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sd { + sdmmc0_pwr_h: sdmmc0-pwr-h { + rockchip,pins = + <RK_GPIO0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb2 { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = + <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + vcc5v0_typec0_en: vcc5v0-typec0-en { + rockchip,pins = + <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio-pwrseq { + wifi_reg_on_h: wifi-reg-on-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + wifi { + wifi_host_wake_l: wifi-host-wake-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + bluetooth { + bt_reg_on_h: bt-enable-h { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_l: bt-wake-l { + rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + mpu6500 { + gsensor_int_l: gsensor-int-l { + rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + lsm6ds3 { + gyr_int_l: gyr-int-l { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + cm32181 { + light_int_l: light-int-l { + rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca1v8_s3>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + clock-frequency = <50000000>; + disable-wp; + keep-power-in-suspend; + max-frequency = <50000000>; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; + + brcmf: wifi@1 { + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>; + interrupt-names = "host-wake"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_host_wake_l>; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + clock-frequency = <150000000>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + vmmc-supply = <&vcc3v0_sd>; + vqmmc-supply = <&vcc_sdio>; + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + phy-supply = <&vcc5v0_typec0>; + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_reg_on_h>; + }; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; + dr_mode = "otg"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index caad30641e..07ee8ce92c 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -5,3 +5,10 @@ F: board/rockchip/evb_rk3399 F: include/configs/evb_rk3399.h F: configs/evb-rk3399_defconfig F: configs/firefly-rk3399_defconfig + +ORANGEPI-RK3399 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/orangepi-rk3399_defconfig +F: arch/arm/dts/rk3399-u-boot.dtsi +F: arch/arm/dts/rk3399-orangepi-u-boot.dtsi diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig new file mode 100644 index 0000000000..deb7bc1388 --- /dev/null +++ b/configs/orangepi-rk3399_defconfig @@ -0,0 +1,58 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-orangepi.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-orangepi" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Specification
- Rockchip RK3399
- 2GB/4GB DDR3
- 16GB eMMC
- SD card slot
- RTL8211E 1Gbps
- AP6356S WiFI/BT
- Mini PCIe
- Sensors, Keys etc
I think it would be good to have DRAM configuration eventually exposed to Linux for advanced power management. But that's a separare issue.
Cheers,
Paul
- rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
+/dts-v1/;
- model = "Orange Pi RK3399 Board";
- compatible = "rockchip,rk3399-orangepi", "rockchip,rk3399";
- chosen {
- clkin_gmac: external-gmac-clock {
#clock-cells = <0>;
- adc-keys {
button-up {
button-down {
back {
label = "Back";
menu {
label = "Menu";
- dc_12v: dc-12v {
regulator-boot-on;
- keys: gpio-keys {
autorepeat;
power {
wakeup-source;
- sdio_pwrseq: sdio-pwrseq {
- /* switched by pmic_sleep */
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-boot-on;
- vcc3v0_sd: vcc3v0-sd {
enable-active-high;
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
- vcc5v0_typec0: vcc5v0-typec0-regulator {
enable-active-high;
- vcc_sys: vcc-sys {
regulator-boot-on;
- vdd_log: vdd-log {
regulator-boot-on;
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
+&cpu_b1 {
+&emmc_phy {
- status = "okay";
+&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-supply = <&vcc3v3_s3>;
- phy-mode = "rgmii";
- pinctrl-names = "default";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x28>;
- rx_delay = <0x11>;
- status = "okay";
+&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
+&hdmi {
- ddc-i2c-bus = <&i2c3>;
- status = "okay";
+&hdmi_sound {
- status = "okay";
+&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
reg = <0x40>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
reg = <0x41>;
regulator-boot-on;
+&i2c1 {
- i2c-scl-rising-time-ns = <450>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
+&i2c3 {
- status = "okay";
+&i2c4 {
- status = "okay";
- ak09911@c {
reg = <0x0c>;
- mpu6500@68 {
reg = <0x68>;
- lsm6ds3@6a {
reg = <0x6a>;
- cm32181@10 {
reg = <0x10>;
+&io_domains {
- status = "okay";
- bt656-supply = <&vcc_3v0>;
- audio-supply = <&vcca1v8_codec>;
- sdmmc-supply = <&vcc_sdio>;
- gpio1830-supply = <&vcc_3v0>;
+&pmu_io_domains {
- status = "okay";
- pmu1830-supply = <&vcc_3v0>;
+&pinctrl {
- buttons {
pwr_btn: pwr-btn {
- pmic {
rockchip,pins =
- sd {
rockchip,pins =
- usb2 {
rockchip,pins =
rockchip,pins =
- sdio-pwrseq {
- wifi {
- bluetooth {
- mpu6500 {
- lsm6ds3 {
- cm32181 {
+&pwm0 {
- status = "okay";
+&pwm2 {
- status = "okay";
+&saradc {
- vref-supply = <&vcca1v8_s3>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- non-removable;
- status = "okay";
+&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- clock-frequency = <50000000>;
- disable-wp;
- keep-power-in-suspend;
- max-frequency = <50000000>;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- status = "okay";
- brcmf: wifi@1 {
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- clock-frequency = <150000000>;
- disable-wp;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>;
- vmmc-supply = <&vcc3v0_sd>;
- vqmmc-supply = <&vcc_sdio>;
- status = "okay";
+&tcphy0 {
- status = "okay";
+&tcphy1 {
- status = "okay";
+&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <1>;
- status = "okay";
+&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
status = "okay";
- u2phy0_host: host-port {
status = "okay";
+&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
- u2phy1_host: host-port {
status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
- status = "okay";
- bluetooth {
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usbdrd3_0 {
- status = "okay";
+&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
+&usbdrd3_1 {
- status = "okay";
+&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
Sync rk3399-nanopi4.dtsi from Linux 5.1-rc2 tag.
Linux commit details about the rk3399-nanopi4.dtsi sync: "arm64: dts: rockchip: Add nanopi4 bluetooth" (sha1: 3e2f0bb72be36aa6c14ee7f11ac4dd8014801030)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-nanopi4.dtsi | 703 +++++++++++++++++++++++++++++++ 1 file changed, 703 insertions(+) create mode 100644 arch/arm/dts/rk3399-nanopi4.dtsi
diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi new file mode 100644 index 0000000000..d325e11728 --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi4.dtsi @@ -0,0 +1,703 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * RK3399-based FriendlyElec boards device tree source + * + * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd + * + * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2018 Collabora Ltd. + * Copyright (c) 2019 Arm Ltd. + */ + +/dts-v1/; +#include <dt-bindings/input/linux-event-codes.h> +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc3v3_sys"; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-name = "vcc5v0_sys"; + vin-supply = <&vdd_5v>; + }; + + /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8_s3"; + vin-supply = <&vcc_1v8>; + }; + + vcc3v0_sd: vcc3v0-sd { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_pwr_h>; + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc3v0_sd"; + vin-supply = <&vcc3v3_sys>; + }; + + vbus_typec: vbus-typec { + compatible = "regulator-fixed"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-name = "vbus_typec"; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&power_key>; + + power { + debounce-interval = <100>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Key Power"; + linux,code = <KEY_POWER>; + wakeup-source; + }; + }; + + leds: gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&leds_gpio>; + + status { + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; + label = "status_led"; + linux,default-trigger = "heartbeat"; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_reg_on_h>; + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clock-parents = <&clkin_gmac>; + assigned-clocks = <&cru SCLK_RMII_SRC>; + clock_in_out = "input"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-supply = <&vcc3v3_s3>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c7>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <160>; + i2c-scl-falling-time-ns = <30>; + status = "okay"; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&cpu_b_sleep>; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-name = "vdd_cpu_b"; + regulator-ramp-delay = <1000>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&gpu_sleep>; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-name = "vdd_gpu"; + regulator-ramp-delay = <1000>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + clock-output-names = "xin32k", "rtc_clko_wifi"; + #clock-cells = <1>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + vcc10-supply = <&vcc3v3_sys>; + vcc11-supply = <&vcc3v3_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_3v0>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-name = "vdd_center"; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-name = "vdd_cpu_l"; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_ddr"; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_cam: LDO_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8_cam"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v0_touch: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc3v0_touch"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmupll: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8_pmupll"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-init-microvolt = <3000000>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_sdio"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcca3v0_codec"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc_1v5"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcca1v8_codec"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc_3v0"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc3v3_s3"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc3v3_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&i2c1 { + clock-frequency = <200000>; + i2c-scl-rising-time-ns = <150>; + i2c-scl-falling-time-ns = <30>; + status = "okay"; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c4 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <160>; + i2c-scl-falling-time-ns = <30>; + status = "okay"; + + fusb0: typec-portc@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&fusb0_int>; + vbus-supply = <&vbus_typec>; + }; +}; + +&i2c7 { + status = "okay"; +}; + +&io_domains { + bt656-supply = <&vcc_1v8>; + audio-supply = <&vcca1v8_codec>; + sdmmc-supply = <&vcc_sdio>; + gpio1830-supply = <&vcc_3v0>; + status = "okay"; +}; + +&pcie_phy { + assigned-clock-parents = <&cru SCLK_PCIEPHY_REF100M>; + assigned-clock-rates = <100000000>; + assigned-clocks = <&cru SCLK_PCIEPHY_REF>; + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; + max-link-speed = <2>; + num-lanes = <4>; + status = "okay"; +}; + +&pinctrl { + fusb30x { + fusb0_int: fusb0-int { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + gpio-leds { + leds_gpio: leds-gpio { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + cpu_b_sleep: cpu-b-sleep { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + gpu_sleep: gpu-sleep { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rockchip-key { + power_key: power-key { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sdio { + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_reg_on_h: bt-reg-on-h { + /* external pullup to VCC1V8_PMUPLL */ + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_l: bt-wake-l { + rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wifi_reg_on_h: wifi-reg_on-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdmmc { + sdmmc0_det_l: sdmmc0-det-l { + rockchip,pins = <0 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + sdmmc0_pwr_h: sdmmc0-pwr-h { + rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_3v0>; + status = "okay"; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm1 { + status = "okay"; +}; + +&pwm2 { + pinctrl-names = "active"; + pinctrl-0 = <&pwm2_pin_pull_down>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca1v8_s3>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs200-1_8v; + non-removable; + status = "okay"; +}; + +&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + cap-mmc-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_bus4 &sdmmc_clk &sdmmc_cmd &sdmmc0_det_l>; + sd-uhs-sdr104; + vmmc-supply = <&vcc3v0_sd>; + vqmmc-supply = <&vcc_sdio>; + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-mode = <1>; + /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_host { + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&u2phy1 { + status = "okay"; +}; + +&u2phy1_host { + status = "okay"; +}; + +&u2phy1_otg { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_rts &uart0_cts>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + clocks = <&rk808 1>; + clock-names = "lpo"; + device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; + max-speed = <4000000>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_reg_on_h &bt_host_wake_l &bt_wake_l>; + vbat-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8>; + }; +}; + +&uart2 { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + dr_mode = "host"; + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +};
Cheers,
Paul
- RK3399-based FriendlyElec boards device tree source
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2018 Collabora Ltd.
- Copyright (c) 2019 Arm Ltd.
- chosen {
#clock-cells = <0>;
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
regulator-boot-on;
enable-active-high;
- vbus_typec: vbus-typec {
- gpio-keys {
autorepeat;
power {
wakeup-source;
- leds: gpio-leds {
status {
+&cpu_b0 {
+&cpu_b1 {
+&cpu_l0 {
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&emmc_phy {
- status = "okay";
+&gmac {
- status = "okay";
+&gpu {
- status = "okay";
+&hdmi {
- ddc-i2c-bus = <&i2c7>;
- pinctrl-0 = <&hdmi_cec>;
- status = "okay";
+&i2c0 {
- i2c-scl-rising-time-ns = <160>;
- i2c-scl-falling-time-ns = <30>;
- status = "okay";
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2c1 {
- clock-frequency = <200000>;
- i2c-scl-rising-time-ns = <150>;
- status = "okay";
+&i2c2 {
- status = "okay";
+&i2c4 {
- status = "okay";
- fusb0: typec-portc@22 {
reg = <0x22>;
+&i2c7 {
- status = "okay";
+&io_domains {
- bt656-supply = <&vcc_1v8>;
- status = "okay";
+&pcie_phy {
- assigned-clock-parents = <&cru SCLK_PCIEPHY_REF100M>;
- assigned-clock-rates = <100000000>;
- assigned-clocks = <&cru SCLK_PCIEPHY_REF>;
- status = "okay";
+&pcie0 {
- ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>;
- max-link-speed = <2>;
- num-lanes = <4>;
- status = "okay";
+&pinctrl {
- fusb30x {
- gpio-leds {
- pmic {
- rockchip-key {
- sdio {
- sdmmc {
+&pmu_io_domains {
- status = "okay";
+&pwm0 {
- status = "okay";
+&pwm1 {
- status = "okay";
+&pwm2 {
- pinctrl-names = "active";
- pinctrl-0 = <&pwm2_pin_pull_down>;
- status = "okay";
+&saradc {
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
+&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc_bus4 &sdmmc_clk &sdmmc_cmd &sdmmc0_det_l>;
- sd-uhs-sdr104;
- status = "okay";
+&tcphy0 {
- status = "okay";
+&tcphy1 {
- status = "okay";
+&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- /* tshut polarity 0:LOW 1:HIGH */
- status = "okay";
+&u2phy0 {
- status = "okay";
+&u2phy0_host {
- status = "okay";
+&u2phy0_otg {
- status = "okay";
+&u2phy1 {
- status = "okay";
+&u2phy1_host {
- status = "okay";
+&u2phy1_otg {
- status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_rts &uart0_cts>;
- status = "okay";
- bluetooth {
+&uart2 {
- status = "okay";
+&usbdrd3_0 {
- status = "okay";
+&usbdrd3_1 {
- status = "okay";
+&usbdrd_dwc3_0 {
- status = "okay";
+&usbdrd_dwc3_1 {
- dr_mode = "host";
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
sdmmc cd pin is configured as RK_FUNC_GPIO which is wrong and indeed failed to detect the sdcard on the board with below error
Card did not respond to voltage select!
So, fix it by replacing RK_FUNC_GPIO with RK_FUNC_1 which is already defined in rk3399.dts so make use of same like other boards.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-nanopi4.dtsi | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi index d325e11728..5dc8a8de16 100644 --- a/arch/arm/dts/rk3399-nanopi4.dtsi +++ b/arch/arm/dts/rk3399-nanopi4.dtsi @@ -521,10 +521,6 @@ };
sdmmc { - sdmmc0_det_l: sdmmc0-det-l { - rockchip,pins = <0 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>; - }; - sdmmc0_pwr_h: sdmmc0-pwr-h { rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; }; @@ -582,7 +578,7 @@ cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; disable-wp; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_bus4 &sdmmc_clk &sdmmc_cmd &sdmmc0_det_l>; + pinctrl-0 = <&sdmmc_bus4 &sdmmc_clk &sdmmc_cmd &sdmmc_cd>; sd-uhs-sdr104; vmmc-supply = <&vcc3v0_sd>; vqmmc-supply = <&vcc_sdio>;
I guess the U-Boot dwmmc driver doesn't support using a GPIO? The reason we do this for Linux is that the dedicated function is not compatible with runtime power management - once we see that no card is present and suspend the idle controller, the CD logic is also powered off and thus no longer capable of generating the interrupt necessary to wake everything up again. The GPIO function of the same pin, however, is in an always-on power domain so is able to do the right thing.
So it's not "wrong" as such, but this change should be fine for U-Boot as long as it never turns off PD_SD itself.
Robin.
sdmmc {
- pinctrl-0 = <&sdmmc_bus4 &sdmmc_clk &sdmmc_cmd &sdmmc_cd>; sd-uhs-sdr104; vmmc-supply = <&vcc3v0_sd>; vqmmc-supply = <&vcc_sdio>;
I can see these gpio pins were managed via drivers/pinctrl/rockchip/pinctrl-rk3399.c and drivers/gpio/rk_gpio.c . On the other hand other boards do use RKFUNC_1 for CD pin(even in Linux) but what is different in nanopi4? do other boards are yet to change?
Add sdram dtsi file for 4GB LPDDR3-1866 DMC settings by reverse engineered from the rk3399_ddr_933Mhz_v1.14.bin file.
Full credits to 'Liviu Dudau' who is the real author for this change.
Signed-off-by: Liviu Dudau liviu@dudau.co.uk Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- .../arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi | 1535 +++++++++++++++++ 1 file changed, 1535 insertions(+) create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi
diff --git a/arch/arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi b/arch/arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi new file mode 100644 index 0000000000..1ee08bb0a1 --- /dev/null +++ b/arch/arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi @@ -0,0 +1,1535 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) 2018 Liviu Dudau liviu@dudau.co.uk + */ + +&dmc { + rockchip,sdram-params = < + 0x2 + 0xa + 0x3 + 0x2 + 0x2 + 0x0 + 0xf + 0xf + 1 + 0x801d181e + 0x17050a08 + 0x00000002 + 0x00006426 + 0x0000004c + 0x00000000 + 0x2 + 0xa + 0x3 + 0x2 + 0x2 + 0x0 + 0xf + 0xf + 1 + 0x801d181e + 0x17050a08 + 0x00000002 + 0x00006426 + 0x0000004c + 0x00000000 + 933 + 6 + 2 + 13 + 1 + 0x00000700 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x0000005e + 0x0002d976 + 0x000003a6 + 0x0000247a + 0x0000005e + 0x0002d976 + 0x000003a6 + 0x0000247a + 0x0000005e + 0x0002d976 + 0x000003a6 + 0x0100247a + 0x00000000 + 0x00000101 + 0x00020100 + 0x000000bb + 0x000001d3 + 0x00000000 + 0x081c0000 + 0x00081c00 + 0x0400081c + 0x3b0a0004 + 0x2f110828 + 0x283b0a00 + 0x002f1108 + 0x08283b0a + 0x08002f11 + 0x00000a0a + 0x0800ff4f + 0x0a0a080f + 0x0800ff4f + 0x0a0a080f + 0x0800ff4f + 0x0203000f + 0x110f1100 + 0x040f110f + 0x14000a0a + 0x03030a0a + 0x00010003 + 0x03212121 + 0x00141414 + 0x00000000 + 0x03010000 + 0x0e3100c5 + 0x0e3100c5 + 0x0e3100c5 + 0x00000000 + 0x00080008 + 0x00170008 + 0x00170017 + 0x00111111 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00ce0000 + 0x00ce00ce + 0x00ce00ce + 0x000000ce + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000301 + 0x00000001 + 0x00000000 + 0x00000000 + 0x01000000 + 0x80104002 + 0x00040003 + 0x00040005 + 0x00030000 + 0x00050004 + 0x00000004 + 0x00040003 + 0x00040005 + 0x38c40000 + 0x00001c62 + 0x1c6238c4 + 0x38c40000 + 0x00001c62 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02020200 + 0x00020202 + 0x00030200 + 0x00040700 + 0x00000302 + 0x02000407 + 0x00000003 + 0x00030f04 + 0x00070004 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x20040020 + 0x00200400 + 0x01000400 + 0x00000b80 + 0x00000000 + 0x00000001 + 0x00000002 + 0x0000000e + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00bb0000 + 0x00ea005e + 0x00ea0000 + 0x005e00bb + 0x000000ea + 0x00bb00ea + 0x00ea005e + 0x00ea0000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00c30000 + 0x0000001c + 0x001c00c3 + 0x00c30000 + 0x0000001c + 0x00010001 + 0x07000001 + 0x00000707 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00c30000 + 0x0000001c + 0x001c00c3 + 0x00c30000 + 0x0000001c + 0x00010001 + 0x07000001 + 0x00000707 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00000000 + 0x00000000 + 0x18151100 + 0x0000000c + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x0003a603 + 0x00550151 + 0x00000000 + 0x015103a6 + 0x00000055 + 0x0003a600 + 0x00550151 + 0x00000000 + 0x002f0000 + 0x002f002f + 0x01010100 + 0x01000202 + 0x0a000002 + 0x01000f0f + 0x00000000 + 0x00000000 + 0x00010003 + 0x00000c03 + 0x00000100 + 0x00010000 + 0x01000000 + 0x00010000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x04040401 + 0x01010808 + 0x04040001 + 0x0c0c0c04 + 0x08080808 + 0x08050103 + 0x08050103 + 0x00050103 + 0x00020202 + 0x06030600 + 0x00030603 + 0x00000000 + 0x00000000 + 0x0d000001 + 0x00010028 + 0x00010000 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010100 + 0x01000000 + 0x00000001 + 0x00000303 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x00010300 + 0x03000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00ffff00 + 0x20200000 + 0x08000020 + 0x00001c62 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001c62 + 0x00011bd4 + 0x1c62070c + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001c62 + 0x00011bd4 + 0x1c62070c + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001c62 + 0x00011bd4 + 0x0202070c + 0x03030202 + 0x00000018 + 0x00000000 + 0x00000000 + 0x00001403 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030000 + 0x000f0021 + 0x000f0021 + 0x000f0021 + 0x00000000 + 0x00000000 + 0x01000000 + 0x02090209 + 0x00050209 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000101 + 0x01010101 + 0x01000101 + 0x01000100 + 0x00010001 + 0x00010002 + 0x00020100 + 0x00000002 + 0x00000700 + 0x00000000 + 0x000038c4 + 0x00001c62 + 0x000038c4 + 0x00001c62 + 0x000038c4 + 0x1c621c62 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001c62 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001c62 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00010000 + 0x00000007 + 0x81000001 + 0x0f0003f0 + 0x3fffffff + 0x0f0000a0 + 0x377ff000 + 0x0f000020 + 0x377ff000 + 0x0f000030 + 0x377ff000 + 0x0f0000b0 + 0x377ff000 + 0x0f000100 + 0x377ff000 + 0x0f000110 + 0x377ff000 + 0x0f000010 + 0x377ff000 + 0x03000101 + 0x04323232 + 0x081c0008 + 0x00081c00 + 0x0000001c + 0x0e3100c5 + 0x0e3100c5 + 0x0e3100c5 + 0x00000500 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04040000 + 0x0d000004 + 0x00000128 + 0x00000000 + 0x00030003 + 0x00000018 + 0x00000000 + 0x00000000 + 0x04060002 + 0x04010401 + 0x00080801 + 0x00020001 + 0x00080004 + 0x00000000 + 0x04040000 + 0x0c0c0c04 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030300 + 0x00000014 + 0x00000000 + 0x01010300 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00000101 + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x0c0c0001 + 0x0707000c + 0x02020007 + 0x00000102 + 0x00030000 + 0x17030000 + 0x000f0021 + 0x000f0021 + 0x000f0021 + 0x00000000 + 0x00000000 + 0x00000100 + 0x140a0000 + 0x000a030a + 0x03000a03 + 0x010a000a + 0x00000100 + 0x01000000 + 0x00000000 + 0x00000100 + 0x1e1a0000 + 0x10010204 + 0x07070705 + 0x20000202 + 0x00201000 + 0x00201000 + 0x04041000 + 0x12120100 + 0x00010112 + 0x004b004a + 0x1a030000 + 0x0102041e + 0x34000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x0000c300 + 0x0001001c + 0x004d4d07 + 0x001c00c3 + 0x4d070001 + 0x0000c34d + 0x0001001c + 0x004d4d07 + 0x001c00c3 + 0x4d070001 + 0x0000c34d + 0x0001001c + 0x004d4d07 + 0x001c00c3 + 0x4d070001 + 0x00c3004d + 0x0001001c + 0x004d4d07 + 0x001c00c3 + 0x4d070001 + 0x0000c34d + 0x0001001c + 0x004d4d07 + 0x001c00c3 + 0x4d070001 + 0x0000c34d + 0x0001001c + 0x004d4d07 + 0x001c00c3 + 0x4d070001 + 0x0100004d + 0x00ea00ea + 0x080400ea + 0x0f081114 + 0x2800fcc1 + 0x0a0e2006 + 0x1114080a + 0x00000f08 + 0x2800fcc1 + 0x0a0e2006 + 0x1114080a + 0x00000f08 + 0x2800fcc1 + 0x0a0e2006 + 0x0200020a + 0x02000200 + 0x02000200 + 0x02000200 + 0x02000200 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000300 + 0x001c6200 + 0x00011bd4 + 0x00001c62 + 0x00011bd4 + 0x00001c62 + 0x00011bd4 + 0x08000000 + 0x00000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000002 + 0x76543210 + 0x0004c008 + 0x000001a2 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x06010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01a20080 + 0x00000003 + 0x00000000 + 0x00030000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07064208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000001a2 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x06010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01a20080 + 0x00000003 + 0x00000000 + 0x00030000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07064208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000001a2 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x06010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01a20080 + 0x00000003 + 0x00000000 + 0x00030000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07064208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000001a2 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x06010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01a20080 + 0x00000003 + 0x00000000 + 0x00030000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07064208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00806420 + 0x00917531 + 0x00806420 + 0x01917531 + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x0a418820 + 0x103f0000 + 0x0000003f + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00008eca + 0x00009fdb + 0x00008eca + 0x01009fdb + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x0004a0e6 + 0x080f0000 + 0x0000000f + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00008eca + 0x00009fdb + 0x00008eca + 0x01009fdb + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x1ee6b16a + 0x10000000 + 0x00000000 + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x01000005 + 0x04000f00 + 0x00020040 + 0x00020055 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000050 + 0x00000000 + 0x00010100 + 0x00000601 + 0x00000000 + 0x00006400 + 0x01221102 + 0x00000000 + 0x00051f00 + 0x051f051f + 0x051f051f + 0x00030003 + 0x03000300 + 0x00000300 + 0x01221102 + 0x00000000 + 0x00000000 + 0x04020000 + 0x00000001 + 0x00000011 + 0x00000011 + 0x00000400 + 0x00000000 + 0x00000011 + 0x00000011 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04000000 + 0x00000000 + 0x00000000 + 0x00000508 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0xe4000000 + 0x00000000 + 0x00000000 + 0x01010000 + 0x00000000 + >; +};
Hi Jagan,
Could you use rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi directly? I think it should able to work.
Thanks, - Kever
- (C) 2018 Liviu Dudau liviu@dudau.co.uk
+&dmc {
0x2
0xa
0x3
0x2
0x2
0x0
0xf
0xf
1
0x801d181e
0x17050a08
0x00000002
0x00006426
0x0000004c
0x00000000
0x2
0xa
0x3
0x2
0x2
0x0
0xf
0xf
1
0x801d181e
0x17050a08
0x00000002
0x00006426
0x0000004c
0x00000000
933
6
2
13
1
0x00000700
0x00000000
0x00000000
0x00000000
0x00000000
0x0000005e
0x0002d976
0x000003a6
0x0000247a
0x0000005e
0x0002d976
0x000003a6
0x0000247a
0x0000005e
0x0002d976
0x000003a6
0x0100247a
0x00000000
0x00000101
0x00020100
0x000000bb
0x000001d3
0x00000000
0x081c0000
0x00081c00
0x0400081c
0x3b0a0004
0x2f110828
0x283b0a00
0x002f1108
0x08283b0a
0x08002f11
0x00000a0a
0x0800ff4f
0x0a0a080f
0x0800ff4f
0x0a0a080f
0x0800ff4f
0x0203000f
0x110f1100
0x040f110f
0x14000a0a
0x03030a0a
0x00010003
0x03212121
0x00141414
0x00000000
0x03010000
0x0e3100c5
0x0e3100c5
0x0e3100c5
0x00000000
0x00080008
0x00170008
0x00170017
0x00111111
0x00000000
0x00000000
0x00000000
0x00ce0000
0x00ce00ce
0x00ce00ce
0x000000ce
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000301
0x00000001
0x00000000
0x00000000
0x01000000
0x80104002
0x00040003
0x00040005
0x00030000
0x00050004
0x00000004
0x00040003
0x00040005
0x38c40000
0x00001c62
0x1c6238c4
0x38c40000
0x00001c62
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02020200
0x00020202
0x00030200
0x00040700
0x00000302
0x02000407
0x00000003
0x00030f04
0x00070004
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00010000
0x20040020
0x00200400
0x01000400
0x00000b80
0x00000000
0x00000001
0x00000002
0x0000000e
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00bb0000
0x00ea005e
0x00ea0000
0x005e00bb
0x000000ea
0x00bb00ea
0x00ea005e
0x00ea0000
0x00000000
0x00000000
0x00000000
0x00c30000
0x0000001c
0x001c00c3
0x00c30000
0x0000001c
0x00010001
0x07000001
0x00000707
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00c30000
0x0000001c
0x001c00c3
0x00c30000
0x0000001c
0x00010001
0x07000001
0x00000707
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x01000000
0x00000000
0x00000000
0x18151100
0x0000000c
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x0003a603
0x00550151
0x00000000
0x015103a6
0x00000055
0x0003a600
0x00550151
0x00000000
0x002f0000
0x002f002f
0x01010100
0x01000202
0x0a000002
0x01000f0f
0x00000000
0x00000000
0x00010003
0x00000c03
0x00000100
0x00010000
0x01000000
0x00010000
0x00000001
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00010000
0x04040401
0x01010808
0x04040001
0x0c0c0c04
0x08080808
0x08050103
0x08050103
0x00050103
0x00020202
0x06030600
0x00030603
0x00000000
0x00000000
0x0d000001
0x00010028
0x00010000
0x00000003
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00010100
0x01000000
0x00000001
0x00000303
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x000556aa
0x000aaaaa
0x000aa955
0x00055555
0x000b3133
0x0004cd33
0x0004cecc
0x000b32cc
0x00010300
0x03000100
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00ffff00
0x20200000
0x08000020
0x00001c62
0x00000200
0x00000200
0x00000200
0x00000200
0x00001c62
0x00011bd4
0x1c62070c
0x00000200
0x00000200
0x00000200
0x00000200
0x00001c62
0x00011bd4
0x1c62070c
0x00000200
0x00000200
0x00000200
0x00000200
0x00001c62
0x00011bd4
0x0202070c
0x03030202
0x00000018
0x00000000
0x00000000
0x00001403
0x00000000
0x00000000
0x00000000
0x00030000
0x000f0021
0x000f0021
0x000f0021
0x00000000
0x00000000
0x01000000
0x02090209
0x00050209
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x01000101
0x01010101
0x01000101
0x01000100
0x00010001
0x00010002
0x00020100
0x00000002
0x00000700
0x00000000
0x000038c4
0x00001c62
0x000038c4
0x00001c62
0x000038c4
0x1c621c62
0x00000200
0x00000200
0x00000200
0x00000200
0x00001c62
0x00000200
0x00000200
0x00000200
0x00000200
0x00001c62
0x00000200
0x00000200
0x00000200
0x00000200
0x00010000
0x00000007
0x81000001
0x0f0003f0
0x3fffffff
0x0f0000a0
0x377ff000
0x0f000020
0x377ff000
0x0f000030
0x377ff000
0x0f0000b0
0x377ff000
0x0f000100
0x377ff000
0x0f000110
0x377ff000
0x0f000010
0x377ff000
0x03000101
0x04323232
0x081c0008
0x00081c00
0x0000001c
0x0e3100c5
0x0e3100c5
0x0e3100c5
0x00000500
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04040000
0x0d000004
0x00000128
0x00000000
0x00030003
0x00000018
0x00000000
0x00000000
0x04060002
0x04010401
0x00080801
0x00020001
0x00080004
0x00000000
0x04040000
0x0c0c0c04
0x00000000
0x00000000
0x00000000
0x00030300
0x00000014
0x00000000
0x01010300
0x00000000
0x00000000
0x01000000
0x00000101
0x55555a5a
0x55555a5a
0x55555a5a
0x55555a5a
0x0c0c0001
0x0707000c
0x02020007
0x00000102
0x00030000
0x17030000
0x000f0021
0x000f0021
0x000f0021
0x00000000
0x00000000
0x00000100
0x140a0000
0x000a030a
0x03000a03
0x010a000a
0x00000100
0x01000000
0x00000000
0x00000100
0x1e1a0000
0x10010204
0x07070705
0x20000202
0x00201000
0x00201000
0x04041000
0x12120100
0x00010112
0x004b004a
0x1a030000
0x0102041e
0x34000000
0x00000000
0x00000000
0x00000000
0x0000c300
0x0001001c
0x004d4d07
0x001c00c3
0x4d070001
0x0000c34d
0x0001001c
0x004d4d07
0x001c00c3
0x4d070001
0x0000c34d
0x0001001c
0x004d4d07
0x001c00c3
0x4d070001
0x00c3004d
0x0001001c
0x004d4d07
0x001c00c3
0x4d070001
0x0000c34d
0x0001001c
0x004d4d07
0x001c00c3
0x4d070001
0x0000c34d
0x0001001c
0x004d4d07
0x001c00c3
0x4d070001
0x0100004d
0x00ea00ea
0x080400ea
0x0f081114
0x2800fcc1
0x0a0e2006
0x1114080a
0x00000f08
0x2800fcc1
0x0a0e2006
0x1114080a
0x00000f08
0x2800fcc1
0x0a0e2006
0x0200020a
0x02000200
0x02000200
0x02000200
0x02000200
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x01000300
0x001c6200
0x00011bd4
0x00001c62
0x00011bd4
0x00001c62
0x00011bd4
0x08000000
0x00000100
0x00000000
0x00000000
0x00000000
0x00000000
0x00000002
0x76543210
0x0004c008
0x000001a2
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x06010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x01a20080
0x00000003
0x00000000
0x00030000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07064208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x76543210
0x0004c008
0x000001a2
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x06010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x01a20080
0x00000003
0x00000000
0x00030000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07064208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x76543210
0x0004c008
0x000001a2
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x06010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x01a20080
0x00000003
0x00000000
0x00030000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07064208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x76543210
0x0004c008
0x000001a2
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x06010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x01a20080
0x00000003
0x00000000
0x00030000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07064208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000001
0x00000000
0x00000000
0x00000000
0x00400320
0x00000040
0x00806420
0x00917531
0x00806420
0x01917531
0x00020003
0x00000000
0x00000000
0x00000000
0x000556aa
0x000aaaaa
0x000aa955
0x00055555
0x000b3133
0x0004cd33
0x0004cecc
0x000b32cc
0x0a418820
0x103f0000
0x0000003f
0x00038055
0x03800380
0x03800380
0x00000380
0x42080010
0x00000003
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000001
0x00000000
0x00000000
0x00000000
0x00400320
0x00000040
0x00008eca
0x00009fdb
0x00008eca
0x01009fdb
0x00020003
0x00000000
0x00000000
0x00000000
0x000556aa
0x000aaaaa
0x000aa955
0x00055555
0x000b3133
0x0004cd33
0x0004cecc
0x000b32cc
0x0004a0e6
0x080f0000
0x0000000f
0x00038055
0x03800380
0x03800380
0x00000380
0x42080010
0x00000003
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000001
0x00000000
0x00000000
0x00000000
0x00400320
0x00000040
0x00008eca
0x00009fdb
0x00008eca
0x01009fdb
0x00020003
0x00000000
0x00000000
0x00000000
0x000556aa
0x000aaaaa
0x000aa955
0x00055555
0x000b3133
0x0004cd33
0x0004cecc
0x000b32cc
0x1ee6b16a
0x10000000
0x00000000
0x00038055
0x03800380
0x03800380
0x00000380
0x42080010
0x00000003
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000001
0x00000000
0x01000005
0x04000f00
0x00020040
0x00020055
0x00000000
0x00000000
0x00000000
0x00000050
0x00000000
0x00010100
0x00000601
0x00000000
0x00006400
0x01221102
0x00000000
0x00051f00
0x051f051f
0x051f051f
0x00030003
0x03000300
0x00000300
0x01221102
0x00000000
0x00000000
0x04020000
0x00000001
0x00000011
0x00000011
0x00000400
0x00000000
0x00000011
0x00000011
0x00004410
0x00004410
0x00004410
0x00004410
0x00004410
0x00000011
0x00004410
0x00000011
0x00004410
0x00000011
0x00004410
0x00000000
0x00000000
0x00000000
0x04000000
0x00000000
0x00000000
0x00000508
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0xe4000000
0x00000000
0x00000000
0x01010000
0x00000000
On Wed, Apr 17, 2019 at 1:10 PM Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
I supposed to take the same, but thought that it would be some samsung specific setting. but seems like it is nearly same and it worked. will update to use this. thanks!
Hi Jagan,
Hi Jagan,
I have check with rockchip dram driver owner, this setting is more generic while the -samsung- dtsi is more for dedicate chromebook. So I think we can merge this patch for other boards who using Rockchip reference design.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
On 18.04.2019, at 04:57, Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
Hi Jagan,
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Add initial support for Nanopi M4 board.
Specification - Rockchip RK3399 - Dual-Channel 4GB LPDDR3-1866 - SD card slot - eMMC socket - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI - USB 3.0 x4 - USB Type C power and data - GPIO1, GPIO2 expansion ports - DC5V/3A
Commit details of rk3399-nanopi-m4.dts sync from Linux 5.1-rc2: "arm64: dts: rockchip: Refine nanopi4 differences" (sha1: c62ffaf5026d0b7633e62b2cea8450b5543c349a)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi | 7 +++ arch/arm/dts/rk3399-nanopi-m4.dts | 66 +++++++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 6 +++ configs/nanopi-m4-rk3399_defconfig | 58 ++++++++++++++++++++ 5 files changed, 138 insertions(+) create mode 100644 arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-m4.dts create mode 100644 configs/nanopi-m4-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6d55b0caf8..d2ac26b556 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -87,6 +87,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-evb.dtb \ rk3399-firefly.dtb \ rk3399-gru-bob.dtb \ + rk3399-nanopi-m4.dtb \ rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ diff --git a/arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi b/arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi new file mode 100644 index 0000000000..1173d496ec --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-lpddr3-4GB-1866.dtsi" diff --git a/arch/arm/dts/rk3399-nanopi-m4.dts b/arch/arm/dts/rk3399-nanopi-m4.dts new file mode 100644 index 0000000000..60358ab8c7 --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-m4.dts @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * FriendlyElec NanoPi M4 board device tree source + * + * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2018 Collabora Ltd. + * Copyright (c) 2019 Arm Ltd. + */ + +/dts-v1/; +#include "rk3399-nanopi4.dtsi" + +/ { + model = "FriendlyElec NanoPi M4"; + compatible = "friendlyarm,nanopi-m4", "rockchip,rk3399"; + + vdd_5v: vdd-5v { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v"; + regulator-always-on; + regulator-boot-on; + }; + + vcc5v0_core: vcc5v0-core { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_core"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_5v>; + }; + + vcc5v0_usb1: vcc5v0-usb1 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb1"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb2: vcc5v0-usb2 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb2"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&vcc3v3_sys { + vin-supply = <&vcc5v0_core>; +}; + +&u2phy0_host { + phy-supply = <&vcc5v0_usb1>; +}; + +&u2phy1_host { + phy-supply = <&vcc5v0_usb2>; +}; + +&vbus_typec { + regulator-always-on; + vin-supply = <&vdd_5v>; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index 07ee8ce92c..ae43805a6a 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -6,6 +6,12 @@ F: include/configs/evb_rk3399.h F: configs/evb-rk3399_defconfig F: configs/firefly-rk3399_defconfig
+NANOPI-M4 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/nanopi-m4-rk3399_defconfig +F: arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi + ORANGEPI-RK3399 M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig new file mode 100644 index 0000000000..be36a28315 --- /dev/null +++ b/configs/nanopi-m4-rk3399_defconfig @@ -0,0 +1,58 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-m4" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Specification
- Rockchip RK3399
- SD card slot
- eMMC socket
- RTL8211E 1Gbps
- AP6356S WiFI/BT
- USB 3.0 x4
- DC5V/3A
Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com
Cheers,
Paul
- rk3399-nanopi-m4.dtb \ rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
- FriendlyElec NanoPi M4 board device tree source
- model = "FriendlyElec NanoPi M4";
- compatible = "friendlyarm,nanopi-m4", "rockchip,rk3399";
- vdd_5v: vdd-5v {
regulator-boot-on;
- vcc5v0_core: vcc5v0-core {
regulator-boot-on;
- vcc5v0_usb1: vcc5v0-usb1 {
regulator-boot-on;
- vcc5v0_usb2: vcc5v0-usb2 {
regulator-boot-on;
+&vcc3v3_sys {
- vin-supply = <&vcc5v0_core>;
+&u2phy0_host {
- phy-supply = <&vcc5v0_usb1>;
+&u2phy1_host {
- phy-supply = <&vcc5v0_usb2>;
+&vbus_typec {
- regulator-always-on;
- vin-supply = <&vdd_5v>;
Add initial support for Nanopc T4 board.
Specification - Rockchip RK3399 - Dual-Channel 4GB LPDDR3-1866 - SD card slot - 16GB eMMC - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI, eDP - USB 3.0, 2.0 - USB Type C power and data - GPIO expansion ports - DC 12V/2A
Commit details of rk3399-nanopc-t4.dts sync from Linux 5.1-rc2: "arm64: dts: rockchip: Add NanoPC-T4 IR receiver" (sha1: 95658e21b1707ad7844f873db2fdaa295109a5a3)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Note: Hardware on the way, since it shared same DDR with Nanopi M4 I'm confident it will boot.
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi | 7 ++ arch/arm/dts/rk3399-nanopc-t4.dts | 91 +++++++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 6 ++ configs/nanopc-t4-rk3399_defconfig | 58 +++++++++++++++ 5 files changed, 163 insertions(+) create mode 100644 arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopc-t4.dts create mode 100644 configs/nanopc-t4-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d2ac26b556..e048565bb6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -87,6 +87,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-evb.dtb \ rk3399-firefly.dtb \ rk3399-gru-bob.dtb \ + rk3399-nanopc-t4.dtb \ rk3399-nanopi-m4.dtb \ rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ diff --git a/arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi b/arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi new file mode 100644 index 0000000000..1173d496ec --- /dev/null +++ b/arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-lpddr3-4GB-1866.dtsi" diff --git a/arch/arm/dts/rk3399-nanopc-t4.dts b/arch/arm/dts/rk3399-nanopc-t4.dts new file mode 100644 index 0000000000..84433cf02b --- /dev/null +++ b/arch/arm/dts/rk3399-nanopc-t4.dts @@ -0,0 +1,91 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * FriendlyElec NanoPC-T4 board device tree source + * + * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2018 Collabora Ltd. + */ + +/dts-v1/; +#include "rk3399-nanopi4.dtsi" + +/ { + model = "FriendlyElec NanoPC-T4"; + compatible = "friendlyarm,nanopc-t4", "rockchip,rk3399"; + + vcc12v0_sys: vcc12v0-sys { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <12000000>; + regulator-min-microvolt = <12000000>; + regulator-name = "vcc12v0_sys"; + }; + + vcc5v0_host0: vcc5v0-host0 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc5v0_host0"; + vin-supply = <&vcc5v0_sys>; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <18000>; + }; + }; + + ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ir_rx>; + }; +}; + +&pinctrl { + ir { + ir_rx: ir-rx { + /* external pullup to VCC3V3_SYS, despite being 1.8V :/ */ + rockchip,pins = <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; + }; + }; +}; + +&sdhci { + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; +}; + +&u2phy0_host { + phy-supply = <&vcc5v0_host0>; +}; + +&u2phy1_host { + phy-supply = <&vcc5v0_host0>; +}; + +&vcc5v0_sys { + vin-supply = <&vcc12v0_sys>; +}; + +&vcc3v3_sys { + vin-supply = <&vcc12v0_sys>; +}; + +&vbus_typec { + enable-active-high; + gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; + vin-supply = <&vcc5v0_sys>; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index ae43805a6a..5917abb9c1 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -6,6 +6,12 @@ F: include/configs/evb_rk3399.h F: configs/evb-rk3399_defconfig F: configs/firefly-rk3399_defconfig
+NANOPC-T4 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/nanopic-t4-rk3399_defconfig +F: arch/arm/dts/rk3399-nanopic-t4-u-boot.dtsi + NANOPI-M4 M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig new file mode 100644 index 0000000000..7ba4f85485 --- /dev/null +++ b/configs/nanopc-t4-rk3399_defconfig @@ -0,0 +1,58 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopc-t4.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopc-t4" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Specification
- Rockchip RK3399
- SD card slot
- 16GB eMMC
- RTL8211E 1Gbps
- AP6356S WiFI/BT
- USB 3.0, 2.0
- DC 12V/2A
It would be good to test before pushing this commit.
Cheers,
Paul
- rk3399-nanopc-t4.dtb \ rk3399-nanopi-m4.dtb \ rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \
- FriendlyElec NanoPC-T4 board device tree source
- model = "FriendlyElec NanoPC-T4";
- compatible = "friendlyarm,nanopc-t4", "rockchip,rk3399";
- vcc12v0_sys: vcc12v0-sys {
regulator-boot-on;
- vcc5v0_host0: vcc5v0-host0 {
regulator-boot-on;
- adc-keys {
recovery {
label = "Recovery";
- ir-receiver {
+&pinctrl {
- ir {
ir_rx: ir-rx {
+&sdhci {
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
+&u2phy0_host {
- phy-supply = <&vcc5v0_host0>;
+&u2phy1_host {
+&vcc5v0_sys {
- vin-supply = <&vcc12v0_sys>;
+&vcc3v3_sys {
+&vbus_typec {
- enable-active-high;
- gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
- vin-supply = <&vcc5v0_sys>;
Add initial support for Nanopi NEO4 board.
Specification - Rockchip RK3399 - 1GB DDR3-1866 - SD card slot - eMMC Socket - RTL8211E 1Gbps - AP6212 WiFI/BT - HDMI In/Out, DP, MIPI CSI - USB 3.0, 2.0 - USB Type C power and data - GPIO expansion ports - DC 5V/3A
Commit details of rk3399-nanopi-neo4.dts sync from Linux: "arm64: dts: rockchip: Add Nanopi NEO4 initial support" (sha1: 092470b537f19788d957aed12d835a179b606014)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi | 6 +++ arch/arm/dts/rk3399-nanopi-neo4.dts | 50 ++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 6 +++ configs/nanopi-neo4-rk3399_defconfig | 58 +++++++++++++++++++++ 5 files changed, 121 insertions(+) create mode 100644 arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-neo4.dts create mode 100644 configs/nanopi-neo4-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e048565bb6..ede7da23fb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,6 +89,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-gru-bob.dtb \ rk3399-nanopc-t4.dtb \ rk3399-nanopi-m4.dtb \ + rk3399-nanopi-neo4.dtb \ rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ diff --git a/arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi b/arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi new file mode 100644 index 0000000000..7bddc3acdb --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" diff --git a/arch/arm/dts/rk3399-nanopi-neo4.dts b/arch/arm/dts/rk3399-nanopi-neo4.dts new file mode 100644 index 0000000000..195410b089 --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-neo4.dts @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2019 Amarula Solutions B.V. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +/dts-v1/; + +#include "rk3399-nanopi4.dtsi" + +/ { + model = "FriendlyARM NanoPi NEO4"; + compatible = "friendlyarm,nanopi-neo4", "rockchip,rk3399"; + + vdd_5v: vdd-5v { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v"; + regulator-always-on; + regulator-boot-on; + }; + + vcc5v0_core: vcc5v0-core { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_core"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_5v>; + }; + + vcc5v0_usb1: vcc5v0-usb1 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb1"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&vcc3v3_sys { + vin-supply = <&vcc5v0_core>; +}; + +&u2phy0_host { + phy-supply = <&vcc5v0_usb1>; +}; + +&vbus_typec { + regulator-always-on; + vin-supply = <&vdd_5v>; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index 5917abb9c1..ed58861820 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -18,6 +18,12 @@ S: Maintained F: configs/nanopi-m4-rk3399_defconfig F: arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi
+NANOPI-NEO4 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/nanopi-neo4-rk3399_defconfig +F: arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi + ORANGEPI-RK3399 M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig new file mode 100644 index 0000000000..eb9d81ae87 --- /dev/null +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -0,0 +1,58 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-neo4.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-neo4" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Specification
- Rockchip RK3399
- 1GB DDR3-1866
- SD card slot
- eMMC Socket
- RTL8211E 1Gbps
- AP6212 WiFI/BT
- USB 3.0, 2.0
- DC 5V/3A
I think SPL support should be disabled for this one.
Cheers,
Paul
- rk3399-nanopi-neo4.dtb \ rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \
- Copyright (C) 2019 Amarula Solutions B.V.
- Author: Jagan Teki jagan@amarulasolutions.com
+/dts-v1/;
- model = "FriendlyARM NanoPi NEO4";
- compatible = "friendlyarm,nanopi-neo4", "rockchip,rk3399";
- vdd_5v: vdd-5v {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&vcc3v3_sys {
+&u2phy0_host {
+&vbus_typec {
Add initial support for Rockpro64 board.
Specification - Rockchip RK3399 - 2/4GB Dual-Channel LPDDR3 - SD card slot - eMMC socket - 128Mb SPI Flash - Gigabit ethernet - PCIe 4X slot - WiFI/BT module socket - HDMI In/Out, DP, MIPI DSI/CSI, eDP - USB 3.0, 2.0 - USB Type C power and data - GPIO expansion ports - DC 12V/2A
Commit details of rk3399-rockpro64.dts sync from Linux 5.1-rc2: "arm64: dts: rockchip: rockpro64 dts add usb regulator" (sha1: 6db644c79c8d45d73b56bc389aebd85fc3679beb)
'Akash' has sent an initial patch before, so I keep him as board maintainer and I'm co-maintainer based on our conversation.
Cc: Paul Kocialkowski paul.kocialkowski@bootlin.com Signed-off-by: Akash Gajjar akash@openedev.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 6 + arch/arm/dts/rk3399-rockpro64.dts | 712 ++++++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 7 + configs/rockpro64-rk3399_defconfig | 58 ++ 5 files changed, 784 insertions(+) create mode 100644 arch/arm/dts/rk3399-rockpro64-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-rockpro64.dts create mode 100644 configs/rockpro64-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ede7da23fb..23a9807444 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -95,6 +95,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \ rk3399-rock960.dtb \ + rk3399-rockpro64.dtb \ rv1108-elgin-r1.dtb \ rv1108-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ diff --git a/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi new file mode 100644 index 0000000000..7bddc3acdb --- /dev/null +++ b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" diff --git a/arch/arm/dts/rk3399-rockpro64.dts b/arch/arm/dts/rk3399-rockpro64.dts new file mode 100644 index 0000000000..1f2394e058 --- /dev/null +++ b/arch/arm/dts/rk3399-rockpro64.dts @@ -0,0 +1,712 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. + * Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com + */ + +/dts-v1/; +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/pwm/pwm.h> +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + model = "Pine64 RockPro64"; + compatible = "pine64,rockpro64", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&pwrbtn>; + + power { + debounce-interval = <100>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Key Power"; + linux,code = <KEY_POWER>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>; + + work-led { + label = "work"; + default-state = "on"; + gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + }; + + diy-led { + label = "diy"; + default-state = "off"; + gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + + /* + * On the module itself this is one of these (depending + * on the actual card populated): + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + vcc12v_dcin: vcc12v-dcin { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8>; + }; + + vcc3v3_pcie: vcc3v3-pcie-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pwr_en>; + regulator-name = "vcc3v3_pcie"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc12v_dcin>; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_typec: vcc5v0-typec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_typec_en>; + regulator-name = "vcc5v0_typec"; + regulator-always-on; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_usb: vcc5v0-usb { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc5v0_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcca_1v8>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v0_touch: LDO_REG2 { + regulator-name = "vcc3v0_touch"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca_1v8: LDO_REG3 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-name = "vcca1v8_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: vcc_lan: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel1_gpio>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel2_gpio>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c1 { + i2c-scl-rising-time-ns = <300>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + i2c-scl-rising-time-ns = <600>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + + fusb0: typec-portc@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&fusb0_int>; + vbus-supply = <&vcc5v0_typec>; + status = "okay"; + }; +}; + +&i2s0 { + rockchip,playback-channels = <8>; + rockchip,capture-channels = <8>; + status = "okay"; +}; + +&i2s1 { + rockchip,playback-channels = <2>; + rockchip,capture-channels = <2>; + status = "okay"; +}; + +&i2s2 { + status = "okay"; +}; + +&io_domains { + status = "okay"; + + bt656-supply = <&vcc1v8_dvp>; + audio-supply = <&vcca1v8_codec>; + sdmmc-supply = <&vcc_sdio>; + gpio1830-supply = <&vcc_3v0>; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_3v0>; + status = "okay"; +}; + +&pinctrl { + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + fusb302x { + fusb0_int: fusb0-int { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + leds { + work_led_gpio: work_led-gpio { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + diy_led_gpio: diy_led-gpio { + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie_pwr_en: pcie-pwr-en { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vsel1_gpio: vsel1-gpio { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_gpio: vsel2-gpio { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb-typec { + vcc5v0_typec_en: vcc5v0_typec_en { + rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb2 { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca1v8_s3>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-mode = <1>; + /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; + dr_mode = "otg"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index ed58861820..c724162ef3 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -30,3 +30,10 @@ S: Maintained F: configs/orangepi-rk3399_defconfig F: arch/arm/dts/rk3399-u-boot.dtsi F: arch/arm/dts/rk3399-orangepi-u-boot.dtsi + +ROCKPRO64 +M: Akash Gajjar akash@openedev.com +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/rockpro64-rk3399_defconfig +F: arch/arm/dts/rk3399-rockpro64-u-boot.dtsi diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig new file mode 100644 index 0000000000..3d0c7d0c6d --- /dev/null +++ b/configs/rockpro64-rk3399_defconfig @@ -0,0 +1,58 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-rockpro64" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Specification
- Rockchip RK3399
- SD card slot
- eMMC socket
- 128Mb SPI Flash
- Gigabit ethernet
- PCIe 4X slot
- USB 3.0, 2.0
- DC 12V/2A
I think SPL support should be disabled for this one too.
Cheers,
Paul
- rk3399-rockpro64.dtb \ rv1108-elgin-r1.dtb \ rv1108-evb.dtb
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
- Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com
- model = "Pine64 RockPro64";
- compatible = "pine64,rockpro64", "rockchip,rk3399";
- chosen {
- clkin_gmac: external-gmac-clock {
#clock-cells = <0>;
- gpio-keys {
autorepeat;
power {
wakeup-source;
- leds {
work-led {
label = "work";
diy-led {
label = "diy";
- sdio_pwrseq: sdio-pwrseq {
- vcc12v_dcin: vcc12v-dcin {
regulator-boot-on;
- /* switched by pmic_sleep */
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-boot-on;
- vcc3v3_pcie: vcc3v3-pcie-regulator {
enable-active-high;
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
- /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
- vcc5v0_typec: vcc5v0-typec-regulator {
enable-active-high;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb {
regulator-boot-on;
- vdd_log: vdd-log {
regulator-boot-on;
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
+&cpu_b1 {
+&emmc_phy {
- status = "okay";
+&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-supply = <&vcc_lan>;
- phy-mode = "rgmii";
- pinctrl-names = "default";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x28>;
- rx_delay = <0x11>;
- status = "okay";
+&hdmi {
- ddc-i2c-bus = <&i2c3>;
- pinctrl-0 = <&hdmi_cec>;
- status = "okay";
+&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
+&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
reg = <0x40>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
reg = <0x41>;
regulator-boot-on;
+&i2c1 {
- i2c-scl-rising-time-ns = <300>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
+&i2c3 {
- i2c-scl-rising-time-ns = <450>;
- status = "okay";
+&i2c4 {
- i2c-scl-rising-time-ns = <600>;
- i2c-scl-falling-time-ns = <20>;
- status = "okay";
- fusb0: typec-portc@22 {
reg = <0x22>;
status = "okay";
+&i2s0 {
- rockchip,playback-channels = <8>;
- rockchip,capture-channels = <8>;
- status = "okay";
+&i2s1 {
- rockchip,playback-channels = <2>;
- rockchip,capture-channels = <2>;
- status = "okay";
+&i2s2 {
- status = "okay";
+&io_domains {
- status = "okay";
- bt656-supply = <&vcc1v8_dvp>;
- audio-supply = <&vcca1v8_codec>;
- sdmmc-supply = <&vcc_sdio>;
- gpio1830-supply = <&vcc_3v0>;
+&pmu_io_domains {
- pmu1830-supply = <&vcc_3v0>;
- status = "okay";
+&pinctrl {
- buttons {
pwrbtn: pwrbtn {
- fusb302x {
- leds {
- pcie {
- pmic {
- sdio-pwrseq {
- usb-typec {
- usb2 {
+&pwm0 {
- status = "okay";
+&pwm2 {
- status = "okay";
+&saradc {
- vref-supply = <&vcca1v8_s3>;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
- disable-wp;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
+&tcphy0 {
- status = "okay";
+&tcphy1 {
- status = "okay";
+&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- rockchip,hw-tshut-mode = <1>;
- /* tshut polarity 0:LOW 1:HIGH */
- rockchip,hw-tshut-polarity = <1>;
- status = "okay";
+&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
status = "okay";
- u2phy0_host: host-port {
status = "okay";
+&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
- u2phy1_host: host-port {
status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts>;
- status = "okay";
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usbdrd3_0 {
- status = "okay";
+&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
+&usbdrd3_1 {
- status = "okay";
+&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
Since rockchip have an individual doc/README.rockchip, it would be better to update the same instead of maintaining it separately in board files.
So, add the documentation for rk3399 - procedure to build for Rockchip miniloader and U-Boot SPL options - procedure to boot from SD for Rockchip miniloader and U-Boot SPL options - Add boot logs of each option, so-that it would help for future boards porting
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- doc/README.rockchip | 209 +++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 208 insertions(+), 1 deletion(-)
diff --git a/doc/README.rockchip b/doc/README.rockchip index ec10ebbc26..e8f6a2dfba 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -88,10 +88,68 @@ One RV3188 baord is supported:
For example:
+1. To build RK3288 board: + CROSS_COMPILE=arm-linux-gnueabi- make O=firefly firefly-rk3288_defconfig all
-(or you can use another cross compiler if you prefer) + (or you can use another cross compiler if you prefer) + +2. To build RK3399 board: + + Option 1: Package the image with Rockchip miniloader: + + - Compile U-Boot + + => cd /path/to/u-boot + => make nanopi-neo4-rk3399_defconfig + => make + => make u-boot.itb + + - Get the rkbin + + => git clone https://github.com/rockchip-linux/rkbin.git + + - Create trust.img + + => cd /path/to/rkbin + => ./tools/trust_merger RKTRUST/RK3399TRUST.ini + + - Create uboot.img + + => cd /path/to/rkbin + => ./tools/loaderimage --pack --uboot /path/to/u-boot/u-boot-dtb.bin uboot.img + + (Get trust.img and uboot.img)
+ Option 2: Package the image with SPL: + + - We need the Python elftools.elf.elffile library for make_fit_atf.py to work + + => sudo apt-get install python-pyelftools + + - Export cross compiler path for aarch64 + + - Compile ATF + + => git clone https://github.com/ARM-software/arm-trusted-firmware.git + => cd arm-trusted-firmware + + (export cross compiler path for Cortex-M0 MCU likely arm-none-eabi-) + => make realclean + => make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 + + (copy bl31.elf U-Boot root dir) + => cp build/rk3399/release/bl31/bl31.elf /path/to/u-boot + + - Compile U-Boot + + => cd /path/to/u-boot + => make orangepi-rk3399_defconfig + => make + => make u-boot.itb + + (Get spl/u-boot-spl-dtb.bin, u-boot.itb images and some boards would get + spl/u-boot-spl.bin since it doesn't enable CONFIG_SPL_OF_CONTROL)
Writing to the board with USB ============================= @@ -225,6 +283,153 @@ tools/mkimage -n rk3188 -T rksd -d spl/u-boot-spl.bin out truncate -s %2048 u-boot.bin cat u-boot.bin | split -b 512 --filter='openssl rc4 -K 7C4E0304550509072D2C7B38170D1711' >> out
+Booting from an SD card on RK3399 +================================= + +To write an image that boots from an SD card (assumed to be /dev/sdc): + +Option 1: Package the image with Rockchip miniloader: + + - Create idbloader.img + + => cd /path/to/u-boot + => ./tools/mkimage -n rk3399 -T rksd -d /path/to/rkbin/bin/rk33/rk3399_ddr_800MHz_v1.20.bin idbloader.img + => cat /path/to/rkbin/bin/rk33/rk3399_miniloader_v1.19.bin >> idbloader.img + + - Write idbloader.img at 64 sector + + => sudo dd if=idbloader.img of=/dev/sdc seek=64 + + - Write trust.img at 24576 + + => sudo dd if=trust.img of=/dev/sdc seek=24576 + + - Write uboot.img at 16384 sector + + => sudo dd if=uboot.img of=/dev/sdc seek=16384 + => sync + +Put this SD (or micro-SD) card into your board and reset it. You should see +something like: + +DDR Version 1.20 20190314 +In +Channel 0: DDR3, 933MHz +Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB +no stride +ch 0 ddrconfig = 0x101, ddrsize = 0x20 +pmugrf_os_reg[2] = 0x10006281, stride = 0x17 +OUT +Boot1: 2019-03-14, version: 1.19 +CPUId = 0x0 +ChipType = 0x10, 239 +mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 +mmc: ERROR: Card did not respond to voltage select! +emmc reinit +mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 +mmc: ERROR: Card did not respond to voltage select! +emmc reinit +mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 +mmc: ERROR: Card did not respond to voltage select! +SdmmcInit=2 1 +mmc0:cmd5,20 +SdmmcInit=0 0 +BootCapSize=0 +UserCapSize=60543MB +FwPartOffset=2000 , 0 +StorageInit ok = 45266 +SecureMode = 0 +SecureInit read PBA: 0x4 +SecureInit read PBA: 0x404 +SecureInit read PBA: 0x804 +SecureInit read PBA: 0xc04 +SecureInit read PBA: 0x1004 +SecureInit read PBA: 0x1404 +SecureInit read PBA: 0x1804 +SecureInit read PBA: 0x1c04 +SecureInit ret = 0, SecureMode = 0 +atags_set_bootdev: ret:(0) +GPT 0x3380ec0 signature is wrong +recovery gpt... +GPT 0x3380ec0 signature is wrong +recovery gpt fail! +LoadTrust Addr:0x4000 +No find bl30.bin +Load uboot, ReadLba = 2000 +hdr 0000000003380880 + 0x0:0x88,0x41,0x3e,0x97,0xe6,0x61,0x54,0x23,0xe9,0x5a,0xd1,0x2b,0xdc,0x2f,0xf9,0x35, + +Load OK, addr=0x200000, size=0x9c9c0 +RunBL31 0x10000 +NOTICE: BL31: v1.3(debug):370ab80 +NOTICE: BL31: Built : 09:23:41, Mar 4 2019 +NOTICE: BL31: Rockchip release version: v1.1 +INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 +INFO: Using opteed sec cpu_context! +INFO: boot cpu mask: 0 +INFO: plat_rockchip_pmu_init(1181): pd status 3e +INFO: BL31: Initializing runtime services +INFO: BL31: Initializing BL32 +INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-195-g8f090d20 #6 Fri Dec 7 06:11:20 UTC 2018 aarch64) + +INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 + +INF [0x0] TEE-CORE:init_teecore:83: teecore inits done +INFO: BL31: Preparing for EL3 exit to normal world +INFO: Entry point address = 0x200000 +INFO: SPSR = 0x3c9 + + +U-Boot 2019.04-rc4-00136-gfd121f9641-dirty (Apr 16 2019 - 14:02:47 +0530) + +Model: FriendlyARM NanoPi NEO4 +DRAM: 1022 MiB +MMC: dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0 +Loading Environment from MMC... *** Warning - bad CRC, using default environment + +In: serial@ff1a0000 +Out: serial@ff1a0000 +Err: serial@ff1a0000 +Model: FriendlyARM NanoPi NEO4 +Net: eth0: ethernet@fe300000 +Hit any key to stop autoboot: 0 +=> + +Option 2: Package the image with SPL: + + - Prefix rk3399 header to SPL image + + => cd /path/to/u-boot + => ./tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl-dtb.bin out + + - Write prefixed SPL at 64th sector + + => sudo dd if=out of=/dev/sdc seek=64 + + - Write U-Boot proper at 16384 sector + + => sudo dd if=u-boot.itb of=/dev/sdc seek=16384 + => sync + +Put this SD (or micro-SD) card into your board and reset it. You should see +something like: + +U-Boot SPL board init +Trying to boot from MMC1 + + +U-Boot 2019.01-00004-g14db5ee998 (Mar 11 2019 - 13:18:41 +0530) + +Model: Orange Pi RK3399 Board +DRAM: 2 GiB +MMC: dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0 +Loading Environment from MMC... OK +In: serial@ff1a0000 +Out: serial@ff1a0000 +Err: serial@ff1a0000 +Model: Orange Pi RK3399 Board +Net: eth0: ethernet@fe300000 +Hit any key to stop autoboot: 0 +=>
Using fastboot on rk3288 ======================== @@ -385,5 +590,7 @@ There are some documents about partitions in the links below. http://rockchip.wikidot.com/partitions
-- +Jagan Teki jagan@amarulasolutions.com +11 Mar 2019 Simon Glass sjg@chromium.org 24 June 2015
This series is combination of previous version[1] plus new rk3399 boards addition.
Thanks for following-up on this series!
Overall this series add support below rk3399 boards
- Orangepi RK3399
- Nanopc T4
- Nanopi M4
- Nanopi NEO4
- Orangepi RK3399
- Rockpro64
All the respective dts(i) files are synced from Linux 5.1-rc2 and few dts(i) from linux-next.
Nanopi NEO4, Rockpro64 are supporting via Rockchip miniloader, and rest support both Rockchip miniloader along with U-Boot SPL.
- Rockpro64, is not possible to boot via U-Boot SPL since it has dependency with LPDDR4 code which is work-in-progress and as soon it arrived in mailing list, will update the same with ddr dtsi.
- Nanopi NEO4 has some ddr issue with[2] rk3399-sdram-ddr3-1866.dtsi, will update the same with U-Boot SPL once it is fixed.
Has the status evolved since? It looks like both have SPL enabled in this series. If the SPL doesn't support DRAM configuration yet, it should probably be explicitly disabled.
Cheers,
Paul
patch 1, 2: Sync rk3399 dtsi files from Linux 5.1-rc2
patch 3: Create global rk3399-u-boot.dtsi
patch 4: move default SPL_FIT_GENERATOR to Kconfig
patch 5: Move common rk3399 configs into Kconfig
patch 6: Add Orangepi RK3399 support
patch 7: Sync rk3399-nanopi4.dtsi from Linux
patch 8: Fix for sdmmc CD pin
patch 9: Add 4GB LPDDR3-1866 ddr dtsi
patch 10: Add Nanopi M4 support
patch 11: Add Nanopc T4 support
patch 12: Add Nanopi NEO4 support
patch 13: Add Rockpro64 support
patch 14: Global document for build/flash
[2] https://marc.info/?l=u-boot&m=154671835328469&w=2 [1] https://patchwork.ozlabs.org/patch/1054208/
Any inputs? Jagan.
Jagan Teki (14): rockchip: dts: rk3399: Sync rk3399-opp from Linux rockchip: dts: rk3399: Sync pwm2_pin_pull_down from Linux 5.1-rc2 rockchip: dts: rk3399: Create initial rk3399-u-boot.dtsi Kconfig: Add default SPL_FIT_GENERATOR for rockchip arm: rockchip: rk3399: Move common configs in Kconfig rockchip: rk3399: Add Orangepi RK3399 support rockchip: dts: rk3399: Sync rk3399-nanopi4.dtsi from Linux rockchip: dts: rk3399: nanopi4: Use CD pin as RK_FUNC_1 rockchip: rk3399: Add 4GB LPDDR3-1866 DMC settings rockchip: rk3399: Add Nanopi M4 board support rockchip: rk3399: Add Nanopc T4 board support rockchip: rk3399: Add Nanopi NEO4 board support rockchip: rk3399: Add Rockpro64 board support doc: rockchip: Add global doc for rk3399 build/flash
Kconfig | 1 + arch/arm/dts/Makefile | 5 + arch/arm/dts/rk3399-evb.dts | 1 - arch/arm/dts/rk3399-firefly.dts | 1 - arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi | 7 + arch/arm/dts/rk3399-nanopc-t4.dts | 91 + arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi | 7 + arch/arm/dts/rk3399-nanopi-m4.dts | 66 + arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi | 6 + arch/arm/dts/rk3399-nanopi-neo4.dts | 50 + arch/arm/dts/rk3399-nanopi4.dtsi | 699 ++++++++ arch/arm/dts/rk3399-opp.dtsi | 133 ++ arch/arm/dts/rk3399-orangepi-u-boot.dtsi | 7 + arch/arm/dts/rk3399-orangepi.dts | 771 +++++++++ arch/arm/dts/rk3399-puma.dtsi | 1 - arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 6 + arch/arm/dts/rk3399-rockpro64.dts | 712 ++++++++ .../arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi | 1535 +++++++++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 8 + arch/arm/dts/rk3399.dtsi | 6 + arch/arm/mach-rockchip/Kconfig | 16 + board/rockchip/evb_rk3399/MAINTAINERS | 32 + configs/chromebook_bob_defconfig | 17 - configs/evb-rk3399_defconfig | 17 - configs/ficus-rk3399_defconfig | 17 - configs/firefly-rk3399_defconfig | 17 - configs/nanopc-t4-rk3399_defconfig | 58 + configs/nanopi-m4-rk3399_defconfig | 58 + configs/nanopi-neo4-rk3399_defconfig | 58 + configs/orangepi-rk3399_defconfig | 58 + configs/puma-rk3399_defconfig | 16 - configs/rock960-rk3399_defconfig | 17 - configs/rockpro64-rk3399_defconfig | 58 + doc/README.rockchip | 209 ++- 34 files changed, 4656 insertions(+), 105 deletions(-) create mode 100644 arch/arm/dts/rk3399-nanopc-t4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopc-t4.dts create mode 100644 arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-m4.dts create mode 100644 arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-neo4.dts create mode 100644 arch/arm/dts/rk3399-nanopi4.dtsi create mode 100644 arch/arm/dts/rk3399-opp.dtsi create mode 100644 arch/arm/dts/rk3399-orangepi-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-orangepi.dts create mode 100644 arch/arm/dts/rk3399-rockpro64-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-rockpro64.dts create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-4GB-1866.dtsi create mode 100644 arch/arm/dts/rk3399-u-boot.dtsi create mode 100644 configs/nanopc-t4-rk3399_defconfig create mode 100644 configs/nanopi-m4-rk3399_defconfig create mode 100644 configs/nanopi-neo4-rk3399_defconfig create mode 100644 configs/orangepi-rk3399_defconfig create mode 100644 configs/rockpro64-rk3399_defconfig
Hi Paul,
On Tue, Apr 16, 2019 at 5:29 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
- Orangepi RK3399
- Nanopc T4
- Nanopi M4
- Nanopi NEO4
- Orangepi RK3399
- Rockpro64
Thanks for your time on reviewing the series.
For rockpro64, I'm trying hard to get things up. neo4 I have tried many options to dig into existing rk3399-sdram-ddr3-1866.dtsi to produce 1GB timings but not succeed at the end.
True, indeed I even tried of disabling SPL for these boards but it rather bit hard to manage lot of Kconfig options to rework since rk3399 make the boards do use SPL by default. Since the work for ddr in-progress I mark it as it is.
Jagan.
participants (5)
Jagan Teki
Kever Yang
Paul Kocialkowski
Philipp Tomsich
Robin Murphy
