[U-Boot] [PATCH] vexpress/armv8: Fix incorrect ethernet controller
This patch enables ethernet support in ARMv8 foundation model. The ARMv8 foundation model supports a SMSC91C111 integrated MAC and PHY module which is present at base address 0x01A000000.
The previous implementation had enabled SMSC9115 ethernet controller which is not present on the ARMv8 foundation model.
Tested on ARMv8 foundation model v1 and v2 by running ping/tftp between the foundation model and the host PC via a bridged network.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@freescale.com --- To test the ethernet functionality on a ARMv8 foundation model:
- Launch the model with BRIDGED networking option: --network=bridged
- This will create an ethernet interface (eth0) inside the model and an interface ARM0 on the Host PC.
- Assign appropriate IP addresses: ~ On Host: $ ifconfig ARM0 10.10.10.11 ~ On foundation model: VExpress# setenv ipaddr 10.10.10.10 VExpress# setenv gatewayip 10.10.10.11 VExpress# setenv serverip 10.10.10.11
- Now try out ping/tftp tests.
include/configs/vexpress_aemv8a.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index ce5f384..e851702 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -102,9 +102,9 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024)
-/* SMSC9115 Ethernet from SMSC9118 family */ -#define CONFIG_SMC9111 1 -#define CONFIG_SMC9111_BASE (0x1a000000) +/* SMSC91C111 Ethernet Configuration */ +#define CONFIG_SMC91111 1 +#define CONFIG_SMC91111_BASE (0x01A000000)
/* PL011 Serial Configuration */ #define CONFIG_PL011_SERIAL
Bhupesh Sharma
