[PATCH v2] vbe: Allow probing the VBE bootmeth to fail in OS fixup
This device is created when there are no bootmeths defined in the device tree. But it cannot be probed without a device tree node.
For now, ignore a probe failure.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Karsten Merker merker@debian.org Suggested-by: Heinrich Schuchardt xypron.glpk@gmx.de Fixes: a56f663f0707 ("vbe: Add info about the VBE device to the fwupd node") ---
Changes in v2: - With 'with' typo - Change to a debug message and add a comment
boot/vbe_simple_os.c | 16 ++++++++++++---- 1 file changed, 12 insertions(+), 4 deletions(-)
diff --git a/boot/vbe_simple_os.c b/boot/vbe_simple_os.c index b2041a95a30..8c641ec07e2 100644 --- a/boot/vbe_simple_os.c +++ b/boot/vbe_simple_os.c @@ -72,6 +72,18 @@ static int bootmeth_vbe_simple_ft_fixup(void *ctx, struct event *event) chosen = oftree_path(tree, "/chosen"); if (!ofnode_valid(chosen)) continue; + + ret = device_probe(dev); + if (ret) { + /* + * This should become an error when VBE is updated to + * only bind this device when a node exists + */ + log_debug("VBE device '%s' failed to probe (err=%d)", + dev->name, ret); + return 0; + } + ret = ofnode_add_subnode(chosen, "fwupd", &node); if (ret && ret != -EEXIST) return log_msg_ret("fwu", ret); @@ -80,10 +92,6 @@ static int bootmeth_vbe_simple_ft_fixup(void *ctx, struct event *event) if (ret && ret != -EEXIST) return log_msg_ret("dev", ret);
- ret = device_probe(dev); - if (ret) - return log_msg_ret("probe", ret); - /* Copy over the vbe properties for fwupd */ log_debug("Fixing up: %s\n", dev->name); ret = ofnode_copy_props(dev_ofnode(dev), subnode);
I was able to reproduce the issue using the qemu-riscv64 instructions Karsten provided, and applying the patch fixes it, thanks!
Tested-by: Vagrant Cascadian vagrant@debian.org
live well, vagrant
Changes in v2:
- With 'with' typo
if (ret) {
dev->name, ret);
- ret = ofnode_add_subnode(chosen, "fwupd", &node); if (ret && ret != -EEXIST) return log_msg_ret("fwu", ret);
if (ret)
Tested-by: Karsten Merker merker@debian.org
Hello,
applying this patch fixes the boot failure on the riscv64 qemu virt platform:
U-Boot 2023.01-00001-g5c392f7ced (Jan 15 2023 - 21:34:26 +0100)
CPU: rv64imafdch_zicsr_zifencei_zihintpause_zba_zbb_zbc_zbs_sstc Model: riscv-virtio,qemu DRAM: 8 GiB Core: 31 devices, 15 uclasses, devicetree: board Flash: 32 MiB Loading Environment from nowhere... OK In: serial@10000000 Out: serial@10000000 Err: serial@10000000 Net: eth0: virtio-net#2 Working FDT set to ff7344b0 Hit any key to stop autoboot: 0
Device 0: QEMU VirtIO Block Device Type: Hard Disk Capacity: 102400.0 MB = 100.0 GB (209715200 x 512) ... is now current device Scanning virtio 0:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf U-Boot menu 1: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 2: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 (rescue target) 3: Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 4: Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 (rescue target) 5: Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 6: Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 (rescue target) Enter choice: 1: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 Retrieving file: /boot/initrd.img-6.1.0-1-riscv64 Retrieving file: /boot/vmlinux-6.1.0-1-riscv64 append: root=/dev/vda1 rw noquiet Moving Image from 0x84000000 to 0x80200000, end=815e5000 ## Flattened Device Tree blob at ff7344b0 Booting using the fdt blob at 0xff7344b0 Working FDT set to ff7344b0 Using Device Tree in place at 00000000ff7344b0, end 00000000ff738dea Working FDT set to ff7344b0
Starting kernel ...
[ 0.000000] Linux version 6.1.0-1-riscv64 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-11) 12.2.0, GNU ld (GNU Binutils for Debian) 2.39.90.20221231) #1 SMP Debian 6.1.4-1 (2023-01-07) [ 0.000000] random: crng init done [ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000 [ 0.000000] Machine model: riscv-virtio,qemu [...]
Regards and many thanks, Karsten
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Karsten Merker merker@debian.org Suggested-by: Heinrich Schuchardt xypron.glpk@gmx.de Fixes: a56f663f0707 ("vbe: Add info about the VBE device to the fwupd node") Tested-by: Vagrant Cascadian vagrant@debian.org Tested-by: Karsten Merker merker@debian.org
Karsten Merker
Vagrant Cascadian
