[U-Boot-Users] porting u-boot 1.1.5 to at91sam9260
hello, is there any one working on porting u-boot 1.1.5 to at91sam9260 soc.
i am going to do this activity,if there is anyone who is already working on this please let me know.
thanks & regards vibi sreenivasan
vibi, this project already exists :-)
Getting the AT91 u-boot bootloader --------------------------------------- To get the u-boot bootloader up and running on an AT91 product you have to go through the following steps:
1. identify on which u-boot revision the patches will apply 2. download the corresponding u-boot
# wget ftp://ftp.denx.de/pub/u-boot/u-boot-x.x.x.tar.bz2 # tar xvjf u-boot-x.x.x.tar.bz2 # cd cd u-boot-x.x.x
3. take the AT91 u-boot patch set and apply it on top of the original u-boot:
# wget http://www.at91.com/repFichier/Project-218/u-boot-x.x.x_atmel_y.y.diff.bz2 # bzcat u-boot-x.x.x_atmel_y.y.diff.bz2 | patch -p1
You will now have a fresh copy of the AT91 u-boot.
dear Marco Cavallini, thanks for your support. i will check it out. thanks & regards vibi sreenivasan
u-boot:
# wget
hi, i have tried that patch.but when i compile the source for at91sam9260ek i am getting error that u-boot uses soft floating point where as libgcc.a in my cross-compiler tool chain uses hard floating point . but i compiled a working u-boot for at91rm9200dk using this tool chain, and here also -msoft-float option was given.
has any one faced this kind of problem before?
u-boot:
# wget
Hello vibi,
I have similar problems on the AT91SAM9261-ek, and I use a hack (attached) to be able to compile the code. It is not nice, but it worked for me until I (or someone else) have time to figure it out more deeply.
Maybe you have the same problem?
Kind Regards,
Remy
2007/12/17, vibi vibi_sreenivasan@cms.com:
u-boot:
# wget
SF.Net email is sponsored by: Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
hello Remy, thanks for your support. the error i got is this
arm-linux-ld: ERROR: /usr/local/arm/4.1/bin-ccache/../lib/gcc/arm-linux-uclibc/3.4.6/libgcc.a(_udivdi3.oS) uses hardware FP, whereas u-boot uses software FP arm-linux-ld: failed to merge target specific data of file /usr/local/arm/4.1/bin-ccache/../lib/gcc/arm-linux-uclibc/3.4.6/libgcc.a(_udivdi3.oS) arm-linux-ld: ERROR: /usr/local/arm/4.1/bin-ccache/../lib/gcc/arm-linux-uclibc/3.4.6/libgcc.a(_clz.oS) uses hardware FP, whereas u-boot uses software FP arm-linux-ld: failed to merge target specific data of file /usr/local/arm/4.1/bin-ccache/../lib/gcc/arm-linux-uclibc/3.4.6/libgcc.a(_clz.oS)
and i solved this by commenting the "-msoft-float " option for compiler in cpu/arm926ejs/config.mk & cpu/arm926ejs/at91sam926x/config.mk
but what makes me think is that same flag was given for at91rm9200 and it worked.
thanks & regards
vibi sreenivasan
On Mon, 2007-12-17 at 12:59 +0100, Remy Bohmer wrote:
Hello vibi,
Kind Regards,
Remy
u-boot:
# wget
I'm happily using 1.2.0 on the 9260. Atmel offers both 1.1.5 and 1.2.0, so I chose the latter; I had problems on the 9263 but it runs fine on 9260 (timer management is broken in both versions, though).
The sources are at ftp://at91dist:distrib@81.80.104.162/AT91_Third_Party_Design_Flow/Linux_Host/Source/u-boot-1.2.0-atmel.tar.bz2
BTW: anyone knows why 926x code isn't merged and whether there are plans in that direction?
/alessandro
Alessandro Rubini
Marco Cavallini
Remy Bohmer
vibi
