[U-Boot] [PATCH 1/6] mx6sabresd: Avoid calling setup_display() from SPL code
There is no need call setup_display() from SPL code, so move it to board_init(), which executes only in U-Boot proper.
Reported-by: Stefano Babic sbabic@denx.de Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx6sabresd/mx6sabresd.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 5b50bc8..f14b759 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -620,9 +620,6 @@ int board_ehci_power(int port, int on) int board_early_init_f(void) { setup_iomux_uart(); -#if defined(CONFIG_VIDEO_IPUV3) - setup_display(); -#endif
return 0; } @@ -639,6 +636,9 @@ int board_init(void) setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c_pad_info1); else setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1); +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif #ifdef CONFIG_USB_EHCI_MX6 setup_usb(); #endif
Reported-by: Stefano Babic sbabic@denx.de Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 2ed66d3..d42cc94 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -683,8 +683,6 @@ int overwrite_console(void) int board_early_init_f(void) { setup_iomux_uart(); - setup_display(); - #ifdef CONFIG_MXC_SPI setup_spi(); #endif @@ -702,6 +700,8 @@ int board_init(void) else setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1);
+ setup_display(); + #ifdef CONFIG_SATA setup_sata(); #endif
- setup_display();
- setup_display();
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Reported-by: Stefano Babic sbabic@denx.de Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/wandboard/wandboard.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index adfcf48..dde4988 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -376,9 +376,6 @@ int board_eth_init(bd_t *bis) int board_early_init_f(void) { setup_iomux_uart(); -#if defined(CONFIG_VIDEO_IPUV3) - setup_display(); -#endif #ifdef CONFIG_SATA /* Only mx6q wandboard has SATA */ if (is_cpu_type(MXC_CPU_MX6Q)) @@ -448,6 +445,8 @@ int board_init(void) setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c2_pad_info); else setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c2_pad_info); + + setup_display(); #endif
- setup_display();
- setup_display();
#endif
Reported-by: Stefano Babic sbabic@denx.de Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 1e4da4a..ee9e4f7 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -308,13 +308,8 @@ int board_ehci_hcd_init(int port)
int board_early_init_f(void) { - int ret = 0; setup_iomux_uart();
-#ifdef CONFIG_VIDEO_IPUV3 - ret = setup_display(); -#endif - #ifdef CONFIG_CMD_SATA setup_sata(); #endif @@ -322,15 +317,21 @@ int board_early_init_f(void) #ifdef CONFIG_USB_EHCI_MX6 setup_usb(); #endif - return ret; + return 0; }
int board_init(void) { + int ret = 0; + /* address of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- return 0; +#ifdef CONFIG_VIDEO_IPUV3 + ret = setup_display(); +#endif + + return ret; }
static bool is_hummingboard(void)
-#endif
- return ret;
- int ret = 0;
- /* address of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- return ret;
Reported-by: Stefano Babic sbabic@denx.de Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/toradex/apalis_imx6/apalis_imx6.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 628a61d..b86dde8 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -756,10 +756,6 @@ int board_early_init_f(void) #else setup_iomux_dce_uart(); #endif - -#if defined(CONFIG_VIDEO_IPUV3) - setup_display(); -#endif return 0; }
@@ -781,6 +777,10 @@ int board_init(void) setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info_loc); setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info3);
+#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + #ifdef CONFIG_TDX_CMD_IMX_MFGR (void) pmic_init(); #endif
Hi Fabio,
- setup_display();
-#endif return 0; }
- setup_display();
Max has already fixed apalis / colibri, see for example http://patchwork.ozlabs.org/patch/817053/. I will apply Max's patches and drop 5/6 from your series. Anyway, thanks for having thought to these two boards, too.
Regards, Stefano
Hi Stefano,
Yes, I saw Max's patches too. When I tried the same approach on cgtqmx6eval I got build failures:
board/congatec/cgtqmx6eval/built-in.o: In function `setup_display': /home/fabio/u-boot-imx/board/congatec/cgtqmx6eval/cgtqmx6eval.c:632: undefined reference to `enable_ipu_clock' /home/fabio/u-boot-imx/board/congatec/cgtqmx6eval/cgtqmx6eval.c:633: undefined reference to `imx_setup_hdmi'
It is true that Max's patches fix the warnings for Toradex boards, but if in future someone rework the IPU code like it is done in cgtqmx6eval, then failure would happen.
So I thought that a more robust solution was to simply prevent making explicit calls to setup_display() from SPL like I did here.
This also has the benefit to have the same solution across several mx6 boards.
I am OK with Max's patches, but just wanted to provide a rationale for my proposal.
Thanks,
Fabio Estevam
On Sat, Sep 23, 2017 at 10:01 AM, Fabio Estevam festevam@gmail.com wrote:
Hi Stefano,
One more advantage of my proposal is that it does not rely on adding logic to include/configs/.
This is particularly important when someone moves the IPU related config symbols into Kconfig.
Regards,
Fabio Estevam
Hi Fabio,
Hi Stefano,
You're right, I agree.
+1
Hi Stefano,
On Sat, 23 Sep 2017 10:43:55 +0200 Stefano Babic sbabic@denx.de wrote: ...
I would prefer patch from Fabio, so I applied all them to a build test branch and building with [1] passed now. There is a pull request for them.
Thanks, Anatolij
Hi
I propose to drop my patches in favor of Fabio's solution.
Reviewed-by: Max Krummenacher max.krummenacher@toradex.com
Max
________________________________ Von: Anatolij Gustschin agust@denx.de Gesendet: Samstag, 23. September 2017 21:06:57 An: Stefano Babic Cc: Fabio Estevam; u-boot@lists.denx.de; Max Krummenacher; Fabio Estevam Betreff: Re: [PATCH 5/6] apalis_imx6: Avoid calling setup_display() from SPL code
Hi Stefano,
Thanks, Anatolij
On 24/09/2017 13:27, Max Krummenacher wrote:
Hi
Agree, I will merge them.
Regards, Stefano
Max
*Von:* Anatolij Gustschin agust@denx.de *Gesendet:* Samstag, 23. September 2017 21:06:57 *An:* Stefano Babic *Cc:* Fabio Estevam; u-boot@lists.denx.de; Max Krummenacher; Fabio Estevam *Betreff:* Re: [PATCH 5/6] apalis_imx6: Avoid calling setup_display() from SPL code Hi Stefano,
Thanks, Anatolij
Reported-by: Stefano Babic sbabic@denx.de Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/toradex/colibri_imx6/colibri_imx6.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 756e3f3..a2a4214 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -630,9 +630,6 @@ int board_early_init_f(void) ARRAY_SIZE(pwr_intb_pads)); setup_iomux_uart();
@@ -653,6 +650,10 @@ int board_init(void) setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info_loc);
Hi
I tested this together with Anatolij's patch [1] on a Colibri iMX6. Both with the SPL and non SPL config the behaviour of the graphical output is as expected.
Tested-by: Max Krummenacher max.krummenacher@toradex.com
Thanks Fabio.
Max
[1] http://patchwork.ozlabs.org/patch/806755
________________________________ Von: Fabio Estevam festevam@gmail.com Gesendet: Samstag, 23. September 2017 04:45:33 An: sbabic@denx.de Cc: u-boot@lists.denx.de; agust@denx.de; Max Krummenacher; Fabio Estevam Betreff: [PATCH 6/6] colibri_imx6: Avoid calling setup_display() from SPL code
+#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + #ifdef CONFIG_TDX_CMD_IMX_MFGR (void) pmic_init(); #endif -- 2.7.4
- setup_display();
-#endif
- setup_display();
Anatolij Gustschin
Fabio Estevam
Max Krummenacher
Stefano Babic
