[U-Boot] Please pull u-boot-x86
Hi Tom,
The following changes since commit f7e48c54b246c460503e90315d0cd50ccbd586c6:
Merge tag 'xilinx-for-v2018.09' of git://git.denx.de/u-boot-microblaze (2018-07-19 11:48:33 -0400)
git://git.denx.de/u-boot-x86.git
for you to fetch changes up to 05855fd31a3f7483534aabe69a7030ff38978510:
x86: acpi: Prevent acpi_table.h from being included more than once (2018-07-20 09:33:22 +0800)
---------------------------------------------------------------- Bin Meng (10): x86: quark: acpi: Add full reset bit to the reset register value in FADT dm: sysreset: x86: Add a sysreset driver efi: app: Add a sysreset driver x86: tangier: Add a sysreset driver dm: sysreset: Add a standard message when doing reset x86: fsp: Eliminate the reset_cpu() call x86: Switch to use DM sysreset driver x86: acpi: Move APIs unrelated to ACPI tables generation to a separate library x86: acpi: Don't touch ACPI hardware in write_acpi_tables() x86: acpi: Prevent acpi_table.h from being included more than once
arch/Kconfig | 2 ++ arch/x86/cpu/baytrail/valleyview.c | 6 ------ arch/x86/cpu/braswell/braswell.c | 6 ------ arch/x86/cpu/cpu.c | 48 +++++++++++++++++++----------------------------- arch/x86/cpu/ivybridge/early_me.c | 7 ++++--- arch/x86/cpu/ivybridge/sdram.c | 3 ++- arch/x86/cpu/qemu/qemu.c | 6 ------ arch/x86/cpu/quark/acpi.c | 2 +- arch/x86/cpu/quark/quark.c | 6 ------ arch/x86/cpu/tangier/Makefile | 2 +- arch/x86/cpu/tangier/sysreset.c | 48 ++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/cpu/tangier/tangier.c | 6 ------ arch/x86/dts/bayleybay.dts | 1 + arch/x86/dts/baytrail_som-db5800-som-6867.dts | 1 + arch/x86/dts/broadwell_som-6896.dts | 1 + arch/x86/dts/cherryhill.dts | 1 + arch/x86/dts/chromebook_link.dts | 1 + arch/x86/dts/chromebook_samus.dts | 1 + arch/x86/dts/chromebox_panther.dts | 1 + arch/x86/dts/conga-qeval20-qa3-e3845.dts | 1 + arch/x86/dts/cougarcanyon2.dts | 1 + arch/x86/dts/crownbay.dts | 1 + arch/x86/dts/dfi-bt700.dtsi | 1 + arch/x86/dts/edison.dts | 5 +++++ arch/x86/dts/efi-x86_app.dts | 5 +++++ arch/x86/dts/efi-x86_payload.dts | 1 + arch/x86/dts/galileo.dts | 1 + arch/x86/dts/minnowmax.dts | 1 + arch/x86/dts/qemu-x86_i440fx.dts | 1 + arch/x86/dts/qemu-x86_q35.dts | 1 + arch/x86/dts/reset.dtsi | 6 ++++++ arch/x86/include/asm/acpi.h | 41 +++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/acpi_table.h | 31 ++++--------------------------- arch/x86/include/asm/processor.h | 5 ----- arch/x86/include/asm/u-boot-x86.h | 1 - arch/x86/lib/Makefile | 1 + arch/x86/lib/acpi.c | 108 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/lib/acpi_s3.c | 1 + arch/x86/lib/acpi_table.c | 110 -------------------------------------------------------------------------------------------------------------- arch/x86/lib/fsp/fsp_common.c | 2 +- configs/chromebook_link64_defconfig | 1 + drivers/sysreset/Kconfig | 6 ++++++ drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset-uclass.c | 2 ++ drivers/sysreset/sysreset_x86.c | 49 +++++++++++++++++++++++++++++++++++++++++++++++++ lib/efi/efi_app.c | 28 +++++++++++++++++++++++++++- 46 files changed, 351 insertions(+), 210 deletions(-) create mode 100644 arch/x86/cpu/tangier/sysreset.c create mode 100644 arch/x86/dts/reset.dtsi create mode 100644 arch/x86/include/asm/acpi.h create mode 100644 arch/x86/lib/acpi.c create mode 100644 drivers/sysreset/sysreset_x86.c
Regards, Bin
On Fri, Jul 20, 2018 at 02:01:54PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
