[U-Boot] [PATCH 1/2] video: truetype: Fix a memory leak on error
When the resolution is not supported we should free the memory we don't plan to use.
Reported-by: Coverity (CID: 135127)
drivers/video/console_truetype.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/video/console_truetype.c b/drivers/video/console_truetype.c index c249f04..e16f95a 100644 --- a/drivers/video/console_truetype.c +++ b/drivers/video/console_truetype.c @@ -289,6 +289,7 @@ static int console_truetype_putc_xy(struct udevice *dev, uint x, uint y, } #endif default: + free(data); return -ENOSYS; }
Make sure to free memory used when the scale facture is incorrect.
Reported-by: Coverity (CID: 24068) Signed-off-by: Simon Glass sjg@chromium.org ---
drivers/video/stb_truetype.h | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/video/stb_truetype.h b/drivers/video/stb_truetype.h index 91d8e6f..26e483c 100644 --- a/drivers/video/stb_truetype.h +++ b/drivers/video/stb_truetype.h @@ -2426,7 +2426,10 @@ STBTT_DEF unsigned char *stbtt_GetGlyphBitmapSubpixel(const stbtt_fontinfo *info
if (scale_x == 0) scale_x = scale_y; if (scale_y == 0) { - if (scale_x == 0) return NULL; + if (scale_x == 0) { + STBTT_free(vertices, info->userdata); + return NULL; + } scale_y = scale_x; }
appied to u-boot-video/master, thanks1
-- Anatolij
Hi Simon,
-- Anatolij
Anatolij Gustschin
