[PATCH v7 0/2] arm: imx8m: add support for Advantech RSB-3720
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org
Add initial support for Advantech RSB-3720 board. The initial support includes: - MMC - eMMC - I2C - FEC - Serial console
v2: update dts v3: remove unnecessary code. move board code to board/advantech v4: rebase to latest master branch. v5: fix commit description v6: update dts v7: remove redefined configs for latest master branch.
Ying-Chun Liu (PaulLiu) (2): arm: dts: add imx8mp-rsb3720-a1 dts file arm: imx8m: add support for Advantech RSB-3720
arch/arm/dts/Makefile | 3 + arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 161 ++ arch/arm/dts/imx8mp-rsb3720-a1.dts | 805 +++++++ arch/arm/mach-imx/imx8m/Kconfig | 15 + board/advantech/imx8mp_rsb3720a1/Kconfig | 14 + board/advantech/imx8mp_rsb3720a1/MAINTAINERS | 7 + board/advantech/imx8mp_rsb3720a1/Makefile | 24 + .../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 213 ++ .../imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg | 11 + .../lpddr4_timing_rsb3720a1_4G.c | 1848 ++++++++++++++++ .../lpddr4_timing_rsb3720a1_6G.c | 1875 +++++++++++++++++ board/advantech/imx8mp_rsb3720a1/spl.c | 260 +++ configs/imx8mp_rsb3720a1_4G_defconfig | 167 ++ configs/imx8mp_rsb3720a1_6G_defconfig | 168 ++ include/configs/imx8mp_rsb3720.h | 223 ++ 15 files changed, 5794 insertions(+) create mode 100644 arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mp-rsb3720-a1.dts create mode 100644 board/advantech/imx8mp_rsb3720a1/Kconfig create mode 100644 board/advantech/imx8mp_rsb3720a1/MAINTAINERS create mode 100644 board/advantech/imx8mp_rsb3720a1/Makefile create mode 100644 board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c create mode 100644 board/advantech/imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg create mode 100644 board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_4G.c create mode 100644 board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_6G.c create mode 100644 board/advantech/imx8mp_rsb3720a1/spl.c create mode 100644 configs/imx8mp_rsb3720a1_4G_defconfig create mode 100644 configs/imx8mp_rsb3720a1_6G_defconfig create mode 100644 include/configs/imx8mp_rsb3720.h
Add board dts for Advantech's imx8mp-rsb3720-a1
Signed-off-by: Darren Huang darren.huang@advantech.com.tw Signed-off-by: Kevin12.Chen Kevin12.Chen@advantech.com.tw Signed-off-by: Phill.Liu Phill.Liu@advantech.com.tw Signed-off-by: Tim Liang tim.liang@advantech.com.tw Signed-off-by: wei.zeng wei.zeng@advantech.com.cn Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: uboot-imx uboot-imx@nxp.com --- v2: update dts v4: rebase to latest master branch v5: fix commit description v6: update dts --- arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 161 +++++ arch/arm/dts/imx8mp-rsb3720-a1.dts | 805 +++++++++++++++++++++ 2 files changed, 966 insertions(+) create mode 100644 arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mp-rsb3720-a1.dts
diff --git a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi new file mode 100644 index 0000000000..2848b24f65 --- /dev/null +++ b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * Copyright 2022 Linaro + */ + +#include "imx8mp-u-boot.dtsi" + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +®_usdhc2_vmmc { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&i2c3 { + u-boot,dm-spl; +}; + +&pinctrl_i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_i2c1_gpio { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pca9450@25} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pca9450@25/regulators} { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; + assigned-clocks = <&clk IMX8MP_CLK_USDHC1>; + assigned-clock-rates = <400000000>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_400M>; +}; + +&usdhc2 { + u-boot,dm-spl; + sd-uhs-sdr104; + sd-uhs-ddr50; + assigned-clocks = <&clk IMX8MP_CLK_USDHC2>; + assigned-clock-rates = <400000000>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_400M>; +}; + +&usdhc3 { + u-boot,dm-spl; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + assigned-clocks = <&clk IMX8MP_CLK_USDHC3>; + assigned-clock-rates = <400000000>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_400M>; +}; + +&binman { + itb { + fit { + images { + fip { + description = "Trusted Firmware FIP"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x40310000>; + + fip_blob: blob-ext{ + filename = "fip.bin"; + }; + }; + }; + + configurations { + conf { + loadables = "atf", "fip"; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/imx8mp-rsb3720-a1.dts b/arch/arm/dts/imx8mp-rsb3720-a1.dts new file mode 100644 index 0000000000..1ef1c0c99e --- /dev/null +++ b/arch/arm/dts/imx8mp-rsb3720-a1.dts @@ -0,0 +1,805 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 NXP + * Copyright 2022 Linaro + */ + +/dts-v1/; + +#include <dt-bindings/usb/pd.h> +#include "imx8mp.dtsi" + +/ { + model = "Advantech i.MX8MPlus RSB3720A1 board"; + compatible = "fsl,imx8mp-evk", "fsl,imx8mp"; + + aliases { + rtc0 = &s35390a; + rtc1 = &snvs_rtc; + }; + + chosen { + stdout-path = &uart3; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0xc0000000>, + <0x1 0x00000000 0 0xc0000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + rpmsg_reserved: rpmsg@0x55800000 { + no-map; + reg = <0 0x55800000 0 0x800000>; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_led>; + + user { + label = "user"; + gpios = <&gpio4 27 GPIO_ACTIVE_LOW>; + default-state = "off"; /* LED BLUE */ + }; + }; + + reg_usb1_host_vbus: regulator-usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1_host_vbus"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1_vbus>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + }; + + reg_usdhc1_vmmc: regulator-usdhc1 { + compatible = "regulator-fixed"; + regulator-name = "WLAN_EN"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 10 GPIO_ACTIVE_HIGH>; + enable-active-high; + startup-delay-us = <100>; + off-on-delay-us = <12000>; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + //gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + startup-delay-us = <100>; + off-on-delay-us = <12000>; + }; + + lvds_backlight0: lvds_backlight@0 { + compatible = "pwm-backlight"; + pwms = <&pwm2 0 5000000>; + status = "disabled"; + + brightness-levels = < 0 1 2 3 4 5 6 7 8 9 + 10 11 12 13 14 15 16 17 18 19 + 20 21 22 23 24 25 26 27 28 29 + 30 31 32 33 34 35 36 37 38 39 + 40 41 42 43 44 45 46 47 48 49 + 50 51 52 53 54 55 56 57 58 59 + 60 61 62 63 64 65 66 67 68 69 + 70 71 72 73 74 75 76 77 78 79 + 80 81 82 83 84 85 86 87 88 89 + 90 91 92 93 94 95 96 97 98 99 + 100>; + default-brightness-level = <80>; + }; + + lvds_backlight1: lvds_backlight@1 { + compatible = "pwm-backlight"; + pwms = <&pwm3 0 5000000>; + status = "disabled"; + + brightness-levels = < 0 1 2 3 4 5 6 7 8 9 + 10 11 12 13 14 15 16 17 18 19 + 20 21 22 23 24 25 26 27 28 29 + 30 31 32 33 34 35 36 37 38 39 + 40 41 42 43 44 45 46 47 48 49 + 50 51 52 53 54 55 56 57 58 59 + 60 61 62 63 64 65 66 67 68 69 + 70 71 72 73 74 75 76 77 78 79 + 80 81 82 83 84 85 86 87 88 89 + 90 91 92 93 94 95 96 97 98 99 + 100>; + default-brightness-level = <80>; + }; + + rtl8367 { + compatible = "realtek,rtl8367b"; + pinctrl-names = "default"; + gpio-sda = <&gpio5 10 GPIO_ACTIVE_HIGH>; + gpio-sck = <&gpio5 11 GPIO_ACTIVE_HIGH>; + realtek,extif0 = <1 0 1 1 1 1 1 1 2>; + }; +}; + +&clk { + init-on-array = <IMX8MP_CLK_HSIO_ROOT>; +}; + +&A53_0 { + cpu-supply = <&buck2_reg>; +}; + +&pwm2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm2>; + status = "okay"; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "okay"; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy1>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy1: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <4>; + at803x,eee-disabled; + at803x,vddio-1p8v; + }; + }; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c1>; + pinctrl-1 = <&pinctrl_i2c1_gpio>; + scl-gpios = <&gpio5 14 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio5 15 GPIO_ACTIVE_HIGH>; + status = "okay"; + + pmic: pca9450@25 { + reg = <0x25>; + compatible = "nxp,pca9450c", "nxp,pca9450b", "nxp,pca9450"; + /* PMIC PCA9450 PMIC_nINT GPIO1_IO3 */ + pinctrl-0 = <&pinctrl_pmic>; + gpio_intr = <&gpio1 3 GPIO_ACTIVE_LOW>; + + regulators { + #address-cells = <1>; + #size-cells = <0>; + + pca9450,pmic-buck2-uses-i2c-dvs; + /* Run/Standby voltage */ + pca9450,pmic-buck2-dvs-voltage = <950000>, <850000>; + + buck1_reg: regulator@0 { + reg = <0>; + regulator-compatible = "buck1"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2_reg: regulator@1 { + reg = <1>; + regulator-compatible = "buck2"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck4_reg: regulator@3 { + reg = <3>; + regulator-compatible = "buck4"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5_reg: regulator@4 { + reg = <4>; + regulator-compatible = "buck5"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6_reg: regulator@5 { + reg = <5>; + regulator-compatible = "buck6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: regulator@6 { + reg = <6>; + regulator-compatible = "ldo1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: regulator@7 { + reg = <7>; + regulator-compatible = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: regulator@8 { + reg = <8>; + regulator-compatible = "ldo3"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: regulator@9 { + reg = <9>; + regulator-compatible = "ldo4"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5_reg: regulator@10 { + reg = <10>; + regulator-compatible = "ldo5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + }; + }; + + s35390a: s35390a@30 { + compatible = "sii,s35390a", "sii,s35392a"; + reg = <0x30>; + status = "okay"; + }; + + gpio_exp2: tca9538@71 { + compatible = "nxp,pca9538"; + reg = <0x71>; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio_exp1: tca9538@70 { + compatible = "nxp,pca9538"; + reg = <0x70>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c2>; + pinctrl-1 = <&pinctrl_i2c2_gpio>; + scl-gpios = <&gpio5 16 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio5 17 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c3>; + pinctrl-1 = <&pinctrl_i2c3_gpio>; + scl-gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio5 19 GPIO_ACTIVE_HIGH>; + status = "okay"; + + pca6416: gpio@20 { + compatible = "ti,tca6416"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&i2c4 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c4>; + pinctrl-1 = <&pinctrl_i2c4_gpio>; + scl-gpios = <&gpio5 20 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>; + status = "okay"; + + 24c02@50 { + compatible = "fsl,24c02"; + reg = <0x50>; + }; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&flexcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + status = "okay"; +}; + +&flexcan2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2>; + status = "okay"; +}; + +&uart1 { /* BT */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + assigned-clocks = <&clk IMX8MP_CLK_UART1>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>; + fsl,uart-has-rtscts; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&uart3 { + /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + assigned-clocks = <&clk IMX8MP_CLK_UART3>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>; + fsl,uart-has-rtscts; + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + status = "okay"; +}; + +&usb3_phy0 { + fsl,phy-tx-vref-tune = <6>; + fsl,phy-tx-rise-tune = <0>; + fsl,phy-tx-preemp-amp-tune = <3>; + fsl,phy-comp-dis-tune = <7>; + fsl,pcs-tx-deemph-3p5db = <0x21>; + fsl,phy-pcs-tx-swing-full = <0x7f>; + status = "okay"; +}; + +&usb3_0 { + status = "okay"; +}; + +&usb_dwc3_0 { + dr_mode = "host"; + status = "okay"; +}; + +&usb3_phy1 { + fsl,phy-tx-preemp-amp-tune = <2>; + status = "okay"; +}; + +&usb3_1 { + status = "okay"; +}; + +&usb_dwc3_1 { + dr_mode = "host"; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_usdhc2_vmmc>; + bus-width = <4>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + cqe-disabled; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "disabled"; +}; + +&iomuxc { + pinctrl-names = "default"; + + pinctrl_pwm2: pwm2grp { + fsl,pins = < + MX8MP_IOMUXC_SAI5_RXD0__PWM2_OUT 0x116 + >; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX8MP_IOMUXC_SAI5_RXC__PWM3_OUT 0x116 + >; + }; + + pinctrl_eqos: eqosgrp { + fsl,pins = < + MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3 + MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3 + MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91 + MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91 + MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x91 + MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x91 + MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x91 + MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91 + MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f + MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f + MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x1f + MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x1f + MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f + MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x1f + MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x19 + >; + }; + + pinctrl_fec: fecgrp { + fsl,pins = < + MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3 + MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x3 + MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x91 + MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x91 + MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x91 + MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x91 + MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x91 + MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x91 + MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x1f + MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x1f + MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x1f + MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x1f + MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x1f + MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x1f + MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x19 + >; + }; + + pinctrl_flexcan1: flexcan1grp { + fsl,pins = < + MX8MP_IOMUXC_SPDIF_RX__CAN1_RX 0x154 + MX8MP_IOMUXC_SPDIF_TX__CAN1_TX 0x154 + >; + }; + + pinctrl_flexcan2: flexcan2grp { + fsl,pins = < + MX8MP_IOMUXC_SAI5_MCLK__CAN2_RX 0x154 + MX8MP_IOMUXC_SAI5_RXD3__CAN2_TX 0x154 + >; + }; + + pinctrl_flexspi0: flexspi0grp { + fsl,pins = < + MX8MP_IOMUXC_NAND_ALE__FLEXSPI_A_SCLK 0x1c2 + MX8MP_IOMUXC_NAND_CE0_B__FLEXSPI_A_SS0_B 0x82 + MX8MP_IOMUXC_NAND_DATA00__FLEXSPI_A_DATA00 0x82 + MX8MP_IOMUXC_NAND_DATA01__FLEXSPI_A_DATA01 0x82 + MX8MP_IOMUXC_NAND_DATA02__FLEXSPI_A_DATA02 0x82 + MX8MP_IOMUXC_NAND_DATA03__FLEXSPI_A_DATA03 0x82 + >; + }; + + pinctrl_gpio_led: gpioledgrp { + fsl,pins = < + MX8MP_IOMUXC_SAI2_MCLK__GPIO4_IO27 0x19 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x400001c3 + MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x400001c3 + MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c3 + MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MP_IOMUXC_ECSPI2_MISO__I2C4_SCL 0x400001c3 + MX8MP_IOMUXC_ECSPI2_SS0__I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_i2c1_gpio: i2c1grp-gpio { + fsl,pins = < + MX8MP_IOMUXC_I2C1_SCL__GPIO5_IO14 0x1c3 + MX8MP_IOMUXC_I2C1_SDA__GPIO5_IO15 0x1c3 + >; + }; + + pinctrl_i2c2_gpio: i2c2grp-gpio { + fsl,pins = < + MX8MP_IOMUXC_I2C2_SCL__GPIO5_IO16 0x1c3 + MX8MP_IOMUXC_I2C2_SDA__GPIO5_IO17 0x1c3 + >; + }; + + pinctrl_i2c3_gpio: i2c3grp-gpio { + fsl,pins = < + MX8MP_IOMUXC_I2C3_SCL__GPIO5_IO18 0x1c3 + MX8MP_IOMUXC_I2C3_SDA__GPIO5_IO19 0x1c3 + >; + }; + + pinctrl_i2c4_gpio: i2c4_gpio_grp { + fsl,pins = < + MX8MP_IOMUXC_I2C4_SCL__GPIO5_IO20 0x1c3 + MX8MP_IOMUXC_I2C4_SDA__GPIO5_IO21 0x1c3 + >; + }; + + pinctrl_pmic: pmicirq { + fsl,pins = < + MX8MP_IOMUXC_GPIO1_IO03__GPIO1_IO03 0x41 + >; + }; + + pinctrl_sai2: sai2grp { + fsl,pins = < + MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI2_TX_SYNC 0xd6 + MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_SAI2_TX_BCLK 0xd6 + MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI2_RX_DATA00 0xd6 + MX8MP_IOMUXC_SAI2_TXD0__AUDIOMIX_SAI2_TX_DATA00 0xd6 + >; + }; + + pinctrl_sai3: sai3grp { + fsl,pins = < + MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC 0xd6 + MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK 0xd6 + MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI3_RX_DATA00 0xd6 + MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 0xd6 + MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI3_MCLK 0xd6 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x140 + MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x140 + MX8MP_IOMUXC_UART3_RXD__UART1_DCE_CTS 0x140 + MX8MP_IOMUXC_UART3_TXD__UART1_DCE_RTS 0x140 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x49 + MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x49 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX 0x140 + MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX 0x140 + MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS 0x140 + MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS 0x140 + >; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = < + MX8MP_IOMUXC_UART4_RXD__UART4_DCE_RX 0x49 + MX8MP_IOMUXC_UART4_TXD__UART4_DCE_TX 0x49 + >; + }; + + pinctrl_usb1_vbus: usb1grp { + fsl,pins = < + MX8MP_IOMUXC_GPIO1_IO14__GPIO1_IO14 0x19 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MP_IOMUXC_SD1_CLK__USDHC1_CLK 0x190 + MX8MP_IOMUXC_SD1_CMD__USDHC1_CMD 0x1d0 + MX8MP_IOMUXC_SD1_DATA0__USDHC1_DATA0 0x1d0 + MX8MP_IOMUXC_SD1_DATA1__USDHC1_DATA1 0x1d0 + MX8MP_IOMUXC_SD1_DATA2__USDHC1_DATA2 0x1d0 + MX8MP_IOMUXC_SD1_DATA3__USDHC1_DATA3 0x1d0 + >; + }; + + pinctrl_usdhc1_gpio: usdhc1gpiogrp { + fsl,pins = < + MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10 0x19 + MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11 0x19 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp-100mhz { + fsl,pins = < + MX8MP_IOMUXC_SD1_CLK__USDHC1_CLK 0x194 + MX8MP_IOMUXC_SD1_CMD__USDHC1_CMD 0x1d4 + MX8MP_IOMUXC_SD1_DATA0__USDHC1_DATA0 0x1d4 + MX8MP_IOMUXC_SD1_DATA1__USDHC1_DATA1 0x1d4 + MX8MP_IOMUXC_SD1_DATA2__USDHC1_DATA2 0x1d4 + MX8MP_IOMUXC_SD1_DATA3__USDHC1_DATA3 0x1d4 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp-200mhz { + fsl,pins = < + MX8MP_IOMUXC_SD1_CLK__USDHC1_CLK 0x196 + MX8MP_IOMUXC_SD1_CMD__USDHC1_CMD 0x1d6 + MX8MP_IOMUXC_SD1_DATA0__USDHC1_DATA0 0x1d6 + MX8MP_IOMUXC_SD1_DATA1__USDHC1_DATA1 0x1d6 + MX8MP_IOMUXC_SD1_DATA2__USDHC1_DATA2 0x1d6 + MX8MP_IOMUXC_SD1_DATA3__USDHC1_DATA3 0x1d6 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x190 + MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d0 + MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d0 + MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0 + MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0 + MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp-100mhz { + fsl,pins = < + MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194 + MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4 + MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d4 + MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4 + MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4 + MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp-200mhz { + fsl,pins = < + MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196 + MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6 + MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d6 + MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6 + MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6 + MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grp-gpio { + fsl,pins = < + MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4 + MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x41 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x190 + MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d0 + MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d0 + MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d0 + MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d0 + MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d0 + MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d0 + MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d0 + MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d0 + MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d0 + MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp-100mhz { + fsl,pins = < + MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x194 + MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d4 + MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d4 + MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d4 + MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d4 + MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d4 + MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d4 + MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d4 + MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d4 + MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d4 + MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp-200mhz { + fsl,pins = < + MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x196 + MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d6 + MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d6 + MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d6 + MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d6 + MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d6 + MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d6 + MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d6 + MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d6 + MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d6 + MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0xc6 + >; + }; +};
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org Add board dts for Advantech's imx8mp-rsb3720-a1 Signed-off-by: Darren Huang darren.huang@advantech.com.tw Signed-off-by: Kevin12.Chen Kevin12.Chen@advantech.com.tw Signed-off-by: Phill.Liu Phill.Liu@advantech.com.tw Signed-off-by: Tim Liang tim.liang@advantech.com.tw Signed-off-by: wei.zeng wei.zeng@advantech.com.cn Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: uboot-imx uboot-imx@nxp.com
Best regards, Stefano Babic
Signed-off-by: Darren Huang darren.huang@advantech.com.tw Signed-off-by: Kevin12.Chen Kevin12.Chen@advantech.com.tw Signed-off-by: Phill.Liu Phill.Liu@advantech.com.tw Signed-off-by: Tim Liang tim.liang@advantech.com.tw Signed-off-by: wei.zeng wei.zeng@advantech.com.cn Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: uboot-imx uboot-imx@nxp.com Cc: Peng Fan (OSS) peng.fan@oss.nxp.com --- v3: remove unnecessary code. move board code to board/advantech v4: rebase to latest master branch v7: remove redefined configs for latest master branch. --- arch/arm/dts/Makefile | 3 + arch/arm/mach-imx/imx8m/Kconfig | 15 + board/advantech/imx8mp_rsb3720a1/Kconfig | 14 + board/advantech/imx8mp_rsb3720a1/MAINTAINERS | 7 + board/advantech/imx8mp_rsb3720a1/Makefile | 24 + .../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 213 ++ .../imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg | 11 + .../lpddr4_timing_rsb3720a1_4G.c | 1848 ++++++++++++++++ .../lpddr4_timing_rsb3720a1_6G.c | 1875 +++++++++++++++++ board/advantech/imx8mp_rsb3720a1/spl.c | 260 +++ configs/imx8mp_rsb3720a1_4G_defconfig | 167 ++ configs/imx8mp_rsb3720a1_6G_defconfig | 168 ++ include/configs/imx8mp_rsb3720.h | 223 ++ 13 files changed, 4828 insertions(+) create mode 100644 board/advantech/imx8mp_rsb3720a1/Kconfig create mode 100644 board/advantech/imx8mp_rsb3720a1/MAINTAINERS create mode 100644 board/advantech/imx8mp_rsb3720a1/Makefile create mode 100644 board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c create mode 100644 board/advantech/imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg create mode 100644 board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_4G.c create mode 100644 board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_6G.c create mode 100644 board/advantech/imx8mp_rsb3720a1/spl.c create mode 100644 configs/imx8mp_rsb3720a1_4G_defconfig create mode 100644 configs/imx8mp_rsb3720a1_6G_defconfig create mode 100644 include/configs/imx8mp_rsb3720.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ce332021d8..d572404003 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1174,6 +1174,9 @@ dtb-$(CONFIG_TARGET_DURIAN) += phytium-durian.dtb dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb
dtb-$(CONFIG_TARGET_IMX8MM_CL_IOT_GATE) += imx8mm-cl-iot-gate.dtb +ifneq ($(CONFIG_TARGET_IMX8MP_RSB3720A1_4G)$(CONFIG_TARGET_IMX8MP_RSB3720A1_6G),) +dtb-y += imx8mp-rsb3720-a1.dtb +endif
dtb-$(CONFIG_TARGET_IMX8MM_CL_IOT_GATE_OPTEE) += imx8mm-cl-iot-gate-optee.dtb
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index d6a869068a..f0d3eefa02 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -160,8 +160,23 @@ config TARGET_IMX8MM_CL_IOT_GATE_OPTEE select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 + +config TARGET_IMX8MP_RSB3720A1_4G + bool "Support i.MX8MP RSB3720A1 4G" + select BINMAN + select IMX8MP + select SUPPORT_SPL + select IMX8M_LPDDR4 + +config TARGET_IMX8MP_RSB3720A1_6G + bool "Support i.MX8MP RSB3720A1 6G" + select BINMAN + select IMX8MP + select SUPPORT_SPL + select IMX8M_LPDDR4 endchoice
+source "board/advantech/imx8mp_rsb3720a1/Kconfig" source "board/beacon/imx8mm/Kconfig" source "board/beacon/imx8mn/Kconfig" source "board/compulab/imx8mm-cl-iot-gate/Kconfig" diff --git a/board/advantech/imx8mp_rsb3720a1/Kconfig b/board/advantech/imx8mp_rsb3720a1/Kconfig new file mode 100644 index 0000000000..4486ed6d33 --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/Kconfig @@ -0,0 +1,14 @@ +if TARGET_IMX8MP_RSB3720A1_4G || TARGET_IMX8MP_RSB3720A1_6G + +config SYS_BOARD + default "imx8mp_rsb3720a1" + +config SYS_VENDOR + default "advantech" + +config SYS_CONFIG_NAME + default "imx8mp_rsb3720" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/advantech/imx8mp_rsb3720a1/MAINTAINERS b/board/advantech/imx8mp_rsb3720a1/MAINTAINERS new file mode 100644 index 0000000000..bc967af4f5 --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/MAINTAINERS @@ -0,0 +1,7 @@ +i.MX8MP RSB3720 BOARD +M: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org +S: Maintained +F: board/advantech/imx8mp_rsb3720a1/ +F: include/configs/imx8mp_rsb3720a1.h +F: configs/imx8mp_rsb3720a1_4G_defconfig +F: configs/imx8mp_rsb3720a1_6G_defconfig diff --git a/board/advantech/imx8mp_rsb3720a1/Makefile b/board/advantech/imx8mp_rsb3720a1/Makefile new file mode 100644 index 0000000000..eb6b18b04a --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/Makefile @@ -0,0 +1,24 @@ +# +# Copyright 2019 NXP +# Copyright 2022 Linaro +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifdef CONFIG_TARGET_IMX8MP_RSB3720A1_6G +obj-y += imx8mp_rsb3720a1.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_rsb3720a1_6G.o +endif +endif + +ifdef CONFIG_TARGET_IMX8MP_RSB3720A1_4G +obj-y += imx8mp_rsb3720a1.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_rsb3720a1_4G.o +endif +endif diff --git a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c new file mode 100644 index 0000000000..16566092bd --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c @@ -0,0 +1,213 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * Copyright 2022 Linaro + */ + +#include <common.h> +#include <dwc3-uboot.h> +#include <errno.h> +#include <miiphy.h> +#include <netdev.h> +#include <spl.h> +#include <usb.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <asm/arch/imx8mp_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/dma.h> +#include <linux/delay.h> +#include <power/pmic.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static const iomux_v3_cfg_t uart_pads[] = { + MX8MP_PAD_ECSPI1_SCLK__UART3_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX8MP_PAD_ECSPI1_MOSI__UART3_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static const iomux_v3_cfg_t wdog_pads[] = { + MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +#ifdef CONFIG_NAND_MXS +static void setup_gpmi_nand(void) +{ + init_nand_clk(); +} +#endif + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + init_uart_clk(2); + + return 0; +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, struct bd_info *bd) +{ + return 0; +} +#endif + +#ifdef CONFIG_FEC_MXC +#define FEC_RST_PAD IMX_GPIO_NR(4, 2) +static const iomux_v3_cfg_t fec1_rst_pads[] = { + MX8MP_PAD_SAI1_RXD0__GPIO4_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_rst_pads, + ARRAY_SIZE(fec1_rst_pads)); + + gpio_request(FEC_RST_PAD, "fec1_rst"); + gpio_direction_output(FEC_RST_PAD, 0); + mdelay(15); + gpio_direction_output(FEC_RST_PAD, 1); + mdelay(100); +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_fec(); + + /* Enable RGMII TX clk output */ + setbits_le32(&gpr->gpr[1], BIT(22)); + + return 0; +} +#endif /* CONFIG_FEC_MXC */ + +#ifdef CONFIG_DWC_ETH_QOS +#define EQOS_RST_PAD IMX_GPIO_NR(4, 22) +static const iomux_v3_cfg_t eqos_rst_pads[] = { + MX8MP_PAD_SAI2_RXC__GPIO4_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_eqos(void) +{ + imx_iomux_v3_setup_multiple_pads(eqos_rst_pads, + ARRAY_SIZE(eqos_rst_pads)); + + gpio_request(EQOS_RST_PAD, "eqos_rst"); + gpio_direction_output(EQOS_RST_PAD, 0); + mdelay(15); + gpio_direction_output(EQOS_RST_PAD, 1); + mdelay(100); +} + +static int setup_eqos(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_eqos(); + + /* set INTF as RGMII, enable RGMII TXC clock */ + clrsetbits_le32(&gpr->gpr[1], + IOMUXC_GPR_GPR1_GPR_ENET_QOS_INTF_SEL_MASK, BIT(16)); + setbits_le32(&gpr->gpr[1], BIT(19) | BIT(21)); + + return set_clk_eqos(ENET_125MHZ); +} +#endif /* CONFIG_DWC_ETH_QOS */ + +int board_phy_config(struct phy_device *phydev) +{ + if (IS_ENABLED(CONFIG_FEC_MXC) || IS_ENABLED(CONFIG_DWC_ETH_QOS)) { + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + } + + return 0; +} + +#define DISPMIX 13 +#define MIPI 15 + +#define WDOG_TRIG IMX_GPIO_NR(4, 20) + +static iomux_v3_cfg_t wdt_trig[] = { + MX8MP_PAD_SAI1_MCLK__GPIO4_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_wdt(void) +{ + imx_iomux_v3_setup_multiple_pads(wdt_trig, ARRAY_SIZE(wdt_trig)); + gpio_request(WDOG_TRIG, "wdt_trig"); + gpio_direction_output(WDOG_TRIG, 1); +} + +int board_init(void) +{ +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + +#ifdef CONFIG_DWC_ETH_QOS + /* clock, pin, gpr */ + setup_eqos(); +#endif + +#ifdef CONFIG_NAND_MXS + setup_gpmi_nand(); +#endif + + setup_iomux_wdt(); + + return 0; +} + +int board_late_init(void) +{ + if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) { + env_set("board_name", "RSB3720A1"); + env_set("board_rev", "iMX8MP"); + } + + return 0; +} + +#ifdef CONFIG_SPL_MMC_SUPPORT +#define UBOOT_RAW_SECTOR_OFFSET 0x40 +unsigned long spl_mmc_get_uboot_raw_sector(struct mmc *mmc) +{ + u32 boot_dev = spl_boot_device(); + + switch (boot_dev) { + case BOOT_DEVICE_MMC2: + return CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - UBOOT_RAW_SECTOR_OFFSET; + default: + return CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR; + } +} +#endif /* CONFIG_SPL_MMC_SUPPORT */ diff --git a/board/advantech/imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg b/board/advantech/imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg new file mode 100644 index 0000000000..0789b32b1c --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + * Copyright 2022 NXP + */ + +#define __ASSEMBLY__ + +ROM_VERSION v2 +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x920000 diff --git a/board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_4G.c b/board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_4G.c new file mode 100644 index 0000000000..2744f33492 --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_4G.c @@ -0,0 +1,1848 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 NXP + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa3080020 }, + { 0x3d400020, 0x323 }, + { 0x3d400024, 0x1e84800 }, + { 0x3d400064, 0x7a0118 }, + { 0x3d4000d0, 0xc00307a3 }, + { 0x3d4000d4, 0xc50000 }, + { 0x3d4000dc, 0xf4003f }, + { 0x3d4000e0, 0x330000 }, + { 0x3d4000e8, 0x660048 }, + { 0x3d4000ec, 0x160048 }, + { 0x3d400100, 0x2028222a }, + { 0x3d400104, 0x807bf }, + { 0x3d40010c, 0xe0e000 }, + { 0x3d400110, 0x12040a12 }, + { 0x3d400114, 0x2050f0f }, + { 0x3d400118, 0x1010009 }, + { 0x3d40011c, 0x501 }, + { 0x3d400130, 0x20800 }, + { 0x3d400134, 0xe100002 }, + { 0x3d400138, 0x120 }, + { 0x3d400144, 0xc80064 }, + { 0x3d400180, 0x3e8001e }, + { 0x3d400184, 0x3207a12 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x49f820e }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x1f0e }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x9121c1c }, + { 0x3d400200, 0x17 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d40021c, 0xf07 }, + { 0x3d400250, 0x1f05 }, + { 0x3d400254, 0x1f }, + { 0x3d400264, 0x90003ff }, + { 0x3d40026c, 0x20003ff }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x1000e00 }, + { 0x3d400498, 0x3ff0000 }, + { 0x3d40049c, 0x1000e00 }, + { 0x3d4004a0, 0x3ff0000 }, + { 0x3d402020, 0x21 }, + { 0x3d402024, 0x30d400 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x330000 }, + { 0x3d4020e8, 0x660048 }, + { 0x3d4020ec, 0x160048 }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x21 }, + { 0x3d403024, 0xc3500 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x330000 }, + { 0x3d4030e8, 0x660048 }, + { 0x3d4030ec, 0x160048 }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d4030f4, 0xc99 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x3 }, + { 0x120a3, 0x2 }, + { 0x120a4, 0x5 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x7 }, + { 0x120a7, 0x6 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x1 }, + { 0x130a2, 0x2 }, + { 0x130a3, 0x3 }, + { 0x130a4, 0x4 }, + { 0x130a5, 0x5 }, + { 0x130a6, 0x6 }, + { 0x130a7, 0x7 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x18 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x3e8 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x22007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x22007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x1204a, 0x500 }, + { 0x1304a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xfa0 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x3ff4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x3ff4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xf400 }, + { 0x54033, 0x333f }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xf400 }, + { 0x54039, 0x333f }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xfa0 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x310 }, + { 0x54019, 0x3ff4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x3ff4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xf400 }, + { 0x54033, 0x333f }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xf400 }, + { 0x54039, 0x333f }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x633 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x633 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x633 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x633 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xb }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x1 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a4, 0x0 }, + { 0x900a5, 0x790 }, + { 0x900a6, 0x11a }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7aa }, + { 0x900a9, 0x2a }, + { 0x900aa, 0x10 }, + { 0x900ab, 0x7b2 }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x0 }, + { 0x900ae, 0x7c8 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x10 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x1 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xd }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x448 }, + { 0x90169, 0x109 }, + { 0x9016a, 0xf }, + { 0x9016b, 0x7c0 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x0 }, + { 0x9016e, 0xe8 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x47 }, + { 0x90171, 0x630 }, + { 0x90172, 0x109 }, + { 0x90173, 0x8 }, + { 0x90174, 0x618 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0xe0 }, + { 0x90178, 0x109 }, + { 0x90179, 0x0 }, + { 0x9017a, 0x7c8 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x8140 }, + { 0x9017e, 0x10c }, + { 0x9017f, 0x0 }, + { 0x90180, 0x478 }, + { 0x90181, 0x109 }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x29 }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x7d }, + { 0x2000c, 0xfa }, + { 0x2000d, 0x9c4 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 4000mts 1D */ + .drate = 4000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 4000mts 2D */ + .drate = 4000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 4000, 400, 100, }, +}; + diff --git a/board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_6G.c b/board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_6G.c new file mode 100644 index 0000000000..08c9e906bf --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/lpddr4_timing_rsb3720a1_6G.c @@ -0,0 +1,1875 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 NXP + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa3080020 }, + { 0x3d400020, 0x1323 }, + { 0x3d400024, 0x1e84800 }, + { 0x3d400064, 0x7a0118 }, +#ifdef CONFIG_IMX8M_DRAM_INLINE_ECC + { 0x3d400070, 0x01027f44 }, +#endif + { 0x3d4000d0, 0xc00307a3 }, + { 0x3d4000d4, 0xc50000 }, + { 0x3d4000dc, 0xf4003f }, + { 0x3d4000e0, 0x330000 }, + { 0x3d4000e8, 0x460048 }, + { 0x3d4000ec, 0x150048 }, + { 0x3d400100, 0x2028222a }, + { 0x3d400104, 0x807bf }, + { 0x3d40010c, 0xe0e000 }, + { 0x3d400110, 0x12040a12 }, + { 0x3d400114, 0x2050f0f }, + { 0x3d400118, 0x1010009 }, + { 0x3d40011c, 0x501 }, + { 0x3d400130, 0x20800 }, + { 0x3d400134, 0xe100002 }, + { 0x3d400138, 0x120 }, + { 0x3d400144, 0xc80064 }, + { 0x3d400180, 0x3e8001e }, + { 0x3d400184, 0x3207a12 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x49f820e }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x1f0e }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x9121c1c }, +#ifdef CONFIG_IMX8M_DRAM_INLINE_ECC + { 0x3d400200, 0x13 }, + { 0x3d40020c, 0x13131300 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x50505 }, + { 0x3d400214, 0x4040404 }, + { 0x3d400218, 0x68040404 }, +#else + { 0x3d400200, 0x16 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x68070707 }, +#endif + { 0x3d40021c, 0xf08 }, + { 0x3d400250, 0x00001705 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400404, 0x72ff }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x21 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x21 }, + { 0x3d403024, 0x30d400 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x3 }, + { 0x120a3, 0x2 }, + { 0x120a4, 0x5 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x7 }, + { 0x120a7, 0x6 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x1 }, + { 0x130a2, 0x2 }, + { 0x130a3, 0x3 }, + { 0x130a4, 0x4 }, + { 0x130a5, 0x5 }, + { 0x130a6, 0x6 }, + { 0x130a7, 0x7 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x18 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x3e8 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x22007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x22007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x1204a, 0x500 }, + { 0x1304a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xfa0 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x3ff4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x3ff4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xf400 }, + { 0x54033, 0x333f }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xf400 }, + { 0x54039, 0x333f }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4846 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x15 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4846 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x15 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x4600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1500 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x4600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1500 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4846 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x15 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4846 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x15 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x4600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1500 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x4600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1500 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xfa0 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x310 }, + { 0x54019, 0x3ff4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x3ff4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xf400 }, + { 0x54033, 0x333f }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xf400 }, + { 0x54039, 0x333f }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x633 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x633 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x633 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x633 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xb }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x1 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a4, 0x0 }, + { 0x900a5, 0x790 }, + { 0x900a6, 0x11a }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7aa }, + { 0x900a9, 0x2a }, + { 0x900aa, 0x10 }, + { 0x900ab, 0x7b2 }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x0 }, + { 0x900ae, 0x7c8 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x10 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x1 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xd }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x448 }, + { 0x90169, 0x109 }, + { 0x9016a, 0xf }, + { 0x9016b, 0x7c0 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x0 }, + { 0x9016e, 0xe8 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x47 }, + { 0x90171, 0x630 }, + { 0x90172, 0x109 }, + { 0x90173, 0x8 }, + { 0x90174, 0x618 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0xe0 }, + { 0x90178, 0x109 }, + { 0x90179, 0x0 }, + { 0x9017a, 0x7c8 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x8140 }, + { 0x9017e, 0x10c }, + { 0x9017f, 0x0 }, + { 0x90180, 0x478 }, + { 0x90181, 0x109 }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x29 }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x7d }, + { 0x2000c, 0xfa }, + { 0x2000d, 0x9c4 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 4000mts 1D */ + .drate = 4000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 4000mts 2D */ + .drate = 4000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 4000, 400, 100, }, +}; + +#ifdef CONFIG_IMX8M_DRAM_INLINE_ECC +void board_dram_ecc_scrub(void) +{ + /* add inline scrb function MPlus spcific */ + /* scrub 0-1.75G */ + ddrc_inline_ecc_scrub(0x0, 0x1bffffff); + /* scrub 2-3.75G */ + ddrc_inline_ecc_scrub(0x20000000, 0x3bffffff); + /* scrub 4-5.75G */ + ddrc_inline_ecc_scrub(0x40000000, 0x5bffffff); + /* set scruber read range 0-6G */ + ddrc_inline_ecc_scrub_end(0x0, 0x5fffffff); +} +#endif diff --git a/board/advantech/imx8mp_rsb3720a1/spl.c b/board/advantech/imx8mp_rsb3720a1/spl.c new file mode 100644 index 0000000000..74dd11545f --- /dev/null +++ b/board/advantech/imx8mp_rsb3720a1/spl.c @@ -0,0 +1,260 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018-2019 NXP + * Copyright 2022 Linaro + */ + +#include <common.h> +#include <command.h> +#include <cpu_func.h> +#include <errno.h> +#include <fsl_esdhc_imx.h> +#include <hang.h> +#include <image.h> +#include <init.h> +#include <log.h> +#include <mmc.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mp_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <dm/uclass.h> +#include <linux/delay.h> +#include <power/pmic.h> +#include <power/pca9450.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ +#ifdef CONFIG_SPL_BOOTROM_SUPPORT + return BOOT_DEVICE_BOOTROM; +#else + switch (boot_dev_spl) { + case SD1_BOOT: + case MMC1_BOOT: + case SD2_BOOT: + case MMC2_BOOT: + return BOOT_DEVICE_MMC1; + case SD3_BOOT: + case MMC3_BOOT: + return BOOT_DEVICE_MMC2; + case QSPI_BOOT: + return BOOT_DEVICE_NOR; + case NAND_BOOT: + return BOOT_DEVICE_NAND; + case USB_BOOT: + return BOOT_DEVICE_BOARD; + default: + return BOOT_DEVICE_NONE; + } +#endif +} + +void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX8MP_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = MX8MP_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = MX8MP_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = MX8MP_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 12) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(2, 19) + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \ + PAD_CTL_PE | \ + PAD_CTL_FSEL2) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_DSE1) +#define USDHC_CD_PAD_CTRL (PAD_CTL_PE | PAD_CTL_PUE | PAD_CTL_HYS | \ + PAD_CTL_DSE4) + +static const iomux_v3_cfg_t usdhc3_pads[] = { + MX8MP_PAD_NAND_WE_B__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_WP_B__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA04__USDHC3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA05__USDHC3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA06__USDHC3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA07__USDHC3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_RE_B__USDHC3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_CE2_B__USDHC3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_CE3_B__USDHC3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_CLE__USDHC3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static const iomux_v3_cfg_t usdhc2_pads[] = { + MX8MP_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), + MX8MP_PAD_SD2_CD_B__GPIO2_IO12 | MUX_PAD_CTRL(USDHC_CD_PAD_CTRL), +}; + +#ifndef USDHC3_BASE_ADDR +#define USDHC3_BASE_ADDR 0x30B60000 +#endif + +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC2_BASE_ADDR, 0, 4}, + {USDHC3_BASE_ADDR, 0, 8}, +}; + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + init_clk_usdhc(1); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, + ARRAY_SIZE(usdhc2_pads)); + gpio_request(USDHC2_PWR_GPIO, "usdhc2_reset"); + gpio_direction_output(USDHC2_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC2_PWR_GPIO, 1); + gpio_request(USDHC2_CD_GPIO, "usdhc2 cd"); + gpio_direction_input(USDHC2_CD_GPIO); + break; + case 1: + init_clk_usdhc(2); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, + ARRAY_SIZE(usdhc3_pads)); + break; + default: + printf("Warning: you configured more USDHC controllers"); + printf("(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + default: + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + return ret; + } + + return 1; +} + +int power_init_board(void) +{ + struct udevice *pdev; + int ret; + + ret = pmic_get("pca9450@25", &pdev); + if (ret == -ENODEV) { + printf("No pmic\n"); + return 0; + } + if (ret != 0) + return ret; + + /* BUCKxOUT_DVS0/1 control BUCK123 output */ + pmic_reg_write(pdev, PCA9450_BUCK123_DVS, 0x29); + + /* + * increase VDD_SOC to typical value 0.95V before first + * DRAM access, set DVS1 to 0.85v for suspend. + * Enable DVS control through PMIC_STBY_REQ and + * set B1_ENMODE=1 (ON by PMIC_ON_REQ=H) + */ + pmic_reg_write(pdev, PCA9450_BUCK1OUT_DVS0, 0x1C); + pmic_reg_write(pdev, PCA9450_BUCK1OUT_DVS1, 0x14); + pmic_reg_write(pdev, PCA9450_BUCK1CTRL, 0x59); + + /* Kernel uses OD/OD freq for SOC */ + /* To avoid timing risk from SOC to ARM,increase VDD_ARM to OD voltage 0.95v */ + pmic_reg_write(pdev, PCA9450_BUCK2OUT_DVS0, 0x1C); + + /* set WDOG_B_CFG to cold reset */ + pmic_reg_write(pdev, PCA9450_RESET_CTRL, 0xA1); + + /* Forced enable the I2C level translator*/ + pmic_reg_write(pdev, PCA9450_CONFIG2, 0x03); + + return 0; +} + +void spl_board_init(void) +{ + puts("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + board_early_init_f(); + + timer_init(); + + ret = spl_early_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + preloader_console_init(); + + enable_tzc380(); + + power_init_board(); + + /* DDR initialization */ + spl_dram_init(); +} diff --git a/configs/imx8mp_rsb3720a1_4G_defconfig b/configs/imx8mp_rsb3720a1_4G_defconfig new file mode 100644 index 0000000000..90e1c15bd7 --- /dev/null +++ b/configs/imx8mp_rsb3720a1_4G_defconfig @@ -0,0 +1,167 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x920000 +CONFIG_TARGET_IMX8MP_RSB3720A1_4G=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_DEFAULT_DEVICE_TREE="imx8mp-rsb3720-a1" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_IMX_CONFIG="board/advantech/imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mp-rsb3720-a1.dtb" +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_BOOTEFI_SELFTEST=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SHA1SUM=y +CONFIG_CMD_BIND=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_READ=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_CLK_IMX8MP=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_UDP_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x5000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH_PHY=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_RTC_S35392A=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_SDP_LOADADDR=0x40480000 +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_SHA512_ALGO=y +CONFIG_SHA512=y +CONFIG_SHA384=y +CONFIG_LZO=y +CONFIG_BZIP2=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y +CONFIG_EFI_SECURE_BOOT=y +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_POWER_I2C=y +CONFIG_SPL_DM_I2C=y +CONFIG_SPL_DM_PMIC=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_SPL_POWER=y +CONFIG_SPL_I2C=y +CONFIG_IMX_WATCHDOG=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SPL_SYSRESET=y diff --git a/configs/imx8mp_rsb3720a1_6G_defconfig b/configs/imx8mp_rsb3720a1_6G_defconfig new file mode 100644 index 0000000000..d7e2855f9c --- /dev/null +++ b/configs/imx8mp_rsb3720a1_6G_defconfig @@ -0,0 +1,168 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x920000 +CONFIG_TARGET_IMX8MP_RSB3720A1_6G=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_DEFAULT_DEVICE_TREE="imx8mp-rsb3720-a1" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_IMX_CONFIG="board/advantech/imx8mp_rsb3720a1/imximage-8mp-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mp-rsb3720-a1.dtb" +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_BOOTEFI_SELFTEST=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SHA1SUM=y +CONFIG_CMD_BIND=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_READ=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_CLK_IMX8MP=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_UDP_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x5000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH_PHY=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_RTC_S35392A=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_SDP_LOADADDR=0x40480000 +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_SHA512_ALGO=y +CONFIG_SHA512=y +CONFIG_SHA384=y +CONFIG_LZO=y +CONFIG_BZIP2=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y +CONFIG_EFI_SECURE_BOOT=y +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_POWER_I2C=y +CONFIG_SPL_DM_I2C=y +CONFIG_SPL_DM_PMIC=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_SPL_POWER=y +CONFIG_SPL_I2C=y +CONFIG_IMX_WATCHDOG=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SPL_SYSRESET=y diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h new file mode 100644 index 0000000000..ac4a7d0cb3 --- /dev/null +++ b/include/configs/imx8mp_rsb3720.h @@ -0,0 +1,223 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + * Copyright 2022 Linaro + */ + +#ifndef __IMX8MP_RSB3720_H +#define __IMX8MP_RSB3720_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> +#include <config_distro_bootcmd.h> + +#define CONFIG_HAS_ETH1 + +#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) + +#define CONFIG_SPL_MAX_SIZE (152 * 1024) +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x960000 +#define CONFIG_SPL_BSS_START_ADDR 0x0098FC00 +#define CONFIG_SPL_BSS_MAX_SIZE 0x400 /* 1 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ + +#define CONFIG_MALLOC_F_ADDR 0x184000 /* malloc f used before \ + * GD_FLG_FULL_MALLOC_INIT \ + * set \ + */ + +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#if defined(CONFIG_NAND_BOOT) +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_DMA +#define CONFIG_SPL_NAND_MXS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_IDENT +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x4000000 /* Put the FIT out of \ + * first 64MB boot area \ + */ + +/* Set a redundant offset in nand FIT mtdpart. The new uuu will burn full + * boot image (not only FIT part) to the mtdpart, so we check both two offsets + */ +#define CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND \ + (CONFIG_SYS_NAND_U_BOOT_OFFS + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512 - 0x8400) + +#endif + +#endif + +#define CONFIG_REMAKE_ELF +/* ENET Config */ +/* ENET1 */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_ETHPRIME "eth1" /* Set eqos to primary since we use its MDIO */ + +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 4 +#define FEC_QUIRK_ENET_MAC + +#define DWC_NET_PHYADDR 4 +#ifdef CONFIG_DWC_ETH_QOS +#define CONFIG_SYS_NONCACHED_MEMORY (1 * SZ_1M) /* 1M */ +#endif + +#define PHY_ANEG_TIMEOUT 20000 + +#endif + +#if CONFIG_IS_ENABLED(CMD_MMC) +# define BOOT_TARGET_MMC(func) \ + func(MMC, mmc, 2) \ + func(MMC, mmc, 1) +#else +# define BOOT_TARGET_MMC(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_PXE) +# define BOOT_TARGET_PXE(func) func(PXE, pxe, na) +#else +# define BOOT_TARGET_PXE(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_DHCP) +# define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) +#else +# define BOOT_TARGET_DHCP(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_MMC(func) \ + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + "script=boot.scr\0" \ + "image=Image\0" \ + "splashimage=0x50000000\0" \ + "console=ttymxc2,115200 earlycon=ec_imx6q,0x30880000,115200\0" \ + "fdt_addr=0x43000000\0" \ + "fdt_addr_r=0x43000000\0" \ + "boot_fit=no\0" \ + "dfu_alt_info=mmc 2=flash-bin raw 0 0x1B00 mmcpart 1\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "initrd_addr=0x43800000\0" \ + "bootm_size=0x10000000\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcpart=1\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs ${jh_clk} console=${console} root=${mmcroot}\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "kernel_addr_r=0x40480000\0" \ + "pxefile_addr_r=0x40480000\0" \ + "ramdisk_addr_r=0x43800000\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ + "bootm ${loadaddr}; " \ + "else " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi;\0" \ + "netargs=setenv bootargs ${jh_clk} console=${console} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ + "bootm ${loadaddr}; " \ + "else " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi;\0" + +/* Link Definitions */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ + +/* Totally 6GB or 4G DDR */ +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#if defined(CONFIG_TARGET_IMX8MP_RSB3720A1_6G) +#define PHYS_SDRAM_SIZE 0xC0000000 /* 3 GB */ +#define PHYS_SDRAM_2 0x100000000 +#define PHYS_SDRAM_2_SIZE 0xC0000000 /* 3 GB */ +#elif defined(CONFIG_TARGET_IMX8MP_RSB3720A1_4G) +#define PHYS_SDRAM_SIZE 0x80000000 /* 2 GB */ +#define PHYS_SDRAM_2 0xC0000000 +#define PHYS_SDRAM_2_SIZE 0x80000000 /* 2 GB */ +#endif + +#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_IMX_BOOTAUX + +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#ifdef CONFIG_FSL_FSPI +#define FSL_FSPI_FLASH_SIZE SZ_32M +#define FSL_FSPI_FLASH_NUM 1 +#define FSPI0_BASE_ADDR 0x30bb0000 +#define FSPI0_AMBA_BASE 0x0 +#define CONFIG_FSPI_QUAD_SUPPORT + +#define CONFIG_SYS_FSL_FSPI_AHB +#endif + +#ifdef CONFIG_NAND_MXS + +/* NAND stuff */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x20000000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#endif /* CONFIG_NAND_MXS */ + +#define CONFIG_SYS_I2C_SPEED 100000 + +#endif /* __IMX8MP_RSB3720_H */
sbabic@denx.de
Ying-Chun Liu
