[U-Boot-Users] [PATCH v2] QE IO: Add initial data to pin configuration + read/write functions
On the MPC83xx & MPC85xx architectures that have QE, add initial data to the pin configuration table (qe_iop_conf_tab). QE initialization tables in all relevant boards were also replaced. In addition, add IO pin read & write functions.
Signed-off-by: David Saada david.saada@ecitele.com
diff -purN a/include/ioports.h b/include/ioports.h --- a/include/ioports.h 2008-01-02 13:39:04.000000000 +0200 +++ b/include/ioports.h 2008-01-06 10:20:40.342453000 +0200 @@ -60,6 +60,7 @@ typedef struct { int dir; int open_drain; int assign; + int data; } qe_iop_conf_t;
#define QE_IOP_TAB_END (-1)
diff -purN a/cpu/mpc85xx/cpu_init.c b/cpu/mpc85xx/cpu_init.c --- a/cpu/mpc85xx/cpu_init.c 2008-01-02 13:39:04.000000000 +0200 +++ b/cpu/mpc85xx/cpu_init.c 2008-01-06 10:27:18.963593000 +0200 @@ -37,14 +37,14 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_QE extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, - int open_drain, int assign); + int open_drain, int assign, int data); extern void qe_init(uint qe_base); extern void qe_reset(void);
static void config_qe_ioports(void) { u8 port, pin; - int dir, open_drain, assign; + int dir, open_drain, assign, data; int i;
for (i = 0; qe_iop_conf_tab[i].assign != QE_IOP_TAB_END; i++) { @@ -53,7 +53,8 @@ static void config_qe_ioports(void) dir = qe_iop_conf_tab[i].dir; open_drain = qe_iop_conf_tab[i].open_drain; assign = qe_iop_conf_tab[i].assign; - qe_config_iopin(port, pin, dir, open_drain, assign); + data = qe_iop_conf_tab[i].data; + qe_config_iopin(port, pin, dir, open_drain, assign, data); } } #endif
diff -purN a/cpu/mpc85xx/qe_io.c b/cpu/mpc85xx/qe_io.c --- a/cpu/mpc85xx/qe_io.c 2008-01-02 13:39:04.000000000 +0200 +++ b/cpu/mpc85xx/qe_io.c 2008-01-06 10:54:24.201604000 +0200 @@ -27,7 +27,7 @@
#if defined(CONFIG_QE) #define NUM_OF_PINS 32 -void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) +void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign, int data) { u32 pin_2bit_mask; u32 pin_2bit_dir; @@ -38,6 +38,16 @@ void qe_config_iopin(u8 port, u8 pin, in volatile par_io_t *par_io = (volatile par_io_t *) &(gur->qe_par_io);
+ /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + tmp_val = in_be32(&par_io[port].cpdat); + if (data) + out_be32(&par_io[port].cpdat, pin_1bit_mask | tmp_val); + else + out_be32(&par_io[port].cpdat, ~pin_1bit_mask & tmp_val); + /* Caculate pin location and 2bit mask and dir */ pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); @@ -55,9 +65,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io[port].cpdir1, pin_2bit_dir | tmp_val); }
- /* Calculate pin location for 1bit mask */ - pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); - /* Setup the open drain */ tmp_val = in_be32(&par_io[port].cpodr); if (open_drain) @@ -82,4 +89,39 @@ void qe_config_iopin(u8 port, u8 pin, in } }
+void qe_read_iopin(u8 port, u8 pin, int *data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + volatile par_io_t *par_io = (volatile par_io_t *) + &(gur->qe_par_io); + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Read the data */ + tmp_val = in_be32(&par_io[port].cpdat); + *data = (tmp_val >> (NUM_OF_PINS - (pin+1))) & 0x1; +} + +void qe_write_iopin(u8 port, u8 pin, int data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + volatile par_io_t *par_io = (volatile par_io_t *) + &(gur->qe_par_io); + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Write the data */ + tmp_val = in_be32(&par_io[port].cpdat); + if (data) + out_be32(&par_io[port].cpdat, pin_1bit_mask | tmp_val); + else + out_be32(&par_io[port].cpdat, ~pin_1bit_mask & tmp_val); +} + #endif /* CONFIG_QE */
diff -purN a/cpu/mpc83xx/cpu_init.c b/cpu/mpc83xx/cpu_init.c --- a/cpu/mpc83xx/cpu_init.c 2008-01-16 23:06:52.000000000 +0200 +++ b/cpu/mpc83xx/cpu_init.c 2008-01-17 15:32:37.791769000 +0200 @@ -29,14 +29,14 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_QE extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, - int open_drain, int assign); + int open_drain, int assign, int data); extern void qe_init(uint qe_base); extern void qe_reset(void);
for (i = 0; qe_iop_conf_tab[i].assign != QE_IOP_TAB_END; i++) { @@ -45,7 +45,8 @@ static void config_qe_ioports(void) dir = qe_iop_conf_tab[i].dir; open_drain = qe_iop_conf_tab[i].open_drain; assign = qe_iop_conf_tab[i].assign; - qe_config_iopin(port, pin, dir, open_drain, assign); + data = qe_iop_conf_tab[i].data; + qe_config_iopin(port, pin, dir, open_drain, assign, data); } } #endif
diff -purN a/cpu/mpc83xx/qe_io.c b/cpu/mpc83xx/qe_io.c --- a/cpu/mpc83xx/qe_io.c 2008-01-02 13:39:04.000000000 +0200 +++ b/cpu/mpc83xx/qe_io.c 2008-01-06 10:59:54.410427000 +0200 @@ -27,7 +27,7 @@
#if defined(CONFIG_QE) #define NUM_OF_PINS 32 -void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) +void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign, int data) { u32 pin_2bit_mask; u32 pin_2bit_dir; @@ -37,6 +37,17 @@ void qe_config_iopin(u8 port, u8 pin, in volatile immap_t *im = (volatile immap_t *)CFG_IMMR; volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im->qepio;
+ /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + tmp_val = in_be32(&par_io->ioport[port].pdat); + if (data) { + out_be32(&par_io->ioport[port].pdat, pin_1bit_mask | tmp_val); + } else { + out_be32(&par_io->ioport[port].pdat, ~pin_1bit_mask & tmp_val); + } + /* Caculate pin location and 2bit mask and dir */ pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); @@ -54,9 +65,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io->ioport[port].dir1, pin_2bit_dir | tmp_val); }
- /* Calculate pin location for 1bit mask */ - pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); - /* Setup the open drain */ tmp_val = in_be32(&par_io->ioport[port].podr); if (open_drain) { @@ -82,4 +90,38 @@ void qe_config_iopin(u8 port, u8 pin, in } }
+void qe_read_iopin(u8 port, u8 pin, int *data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile immap_t *im = (volatile immap_t *)CFG_IMMR; + volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im->qepio; + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Read the data */ + tmp_val = in_be32(&par_io->ioport[port].pdat); + *data = (tmp_val >> (NUM_OF_PINS - (pin+1))) & 0x1; +} + +void qe_write_iopin(u8 port, u8 pin, int data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile immap_t *im = (volatile immap_t *)CFG_IMMR; + volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im->qepio; + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + tmp_val = in_be32(&par_io->ioport[port].pdat); + if (data) { + out_be32(&par_io->ioport[port].pdat, pin_1bit_mask | tmp_val); + } else { + out_be32(&par_io->ioport[port].pdat, ~pin_1bit_mask & tmp_val); + } +} + #endif /* CONFIG_QE */
diff -purN a/board/freescale/mpc8360emds/mpc8360emds.c b/board/freescale/mpc8360emds/mpc8360emds.c --- a/board/freescale/mpc8360emds/mpc8360emds.c 2008-01-16 23:06:51.000000000 +0200 +++ b/board/freescale/mpc8360emds/mpc8360emds.c 2008-01-17 16:03:27.428958000 +0200 @@ -34,63 +34,63 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ - {0, 3, 1, 0, 1}, /* TxD0 */ - {0, 4, 1, 0, 1}, /* TxD1 */ - {0, 5, 1, 0, 1}, /* TxD2 */ - {0, 6, 1, 0, 1}, /* TxD3 */ - {1, 6, 1, 0, 3}, /* TxD4 */ - {1, 7, 1, 0, 1}, /* TxD5 */ - {1, 9, 1, 0, 2}, /* TxD6 */ - {1, 10, 1, 0, 2}, /* TxD7 */ - {0, 9, 2, 0, 1}, /* RxD0 */ - {0, 10, 2, 0, 1}, /* RxD1 */ - {0, 11, 2, 0, 1}, /* RxD2 */ - {0, 12, 2, 0, 1}, /* RxD3 */ - {0, 13, 2, 0, 1}, /* RxD4 */ - {1, 1, 2, 0, 2}, /* RxD5 */ - {1, 0, 2, 0, 2}, /* RxD6 */ - {1, 4, 2, 0, 2}, /* RxD7 */ - {0, 7, 1, 0, 1}, /* TX_EN */ - {0, 8, 1, 0, 1}, /* TX_ER */ - {0, 15, 2, 0, 1}, /* RX_DV */ - {0, 16, 2, 0, 1}, /* RX_ER */ - {0, 0, 2, 0, 1}, /* RX_CLK */ - {2, 9, 1, 0, 3}, /* GTX_CLK - CLK10 */ - {2, 8, 2, 0, 1}, /* GTX125 - CLK9 */ + {0, 3, 1, 0, 1, 0}, /* TxD0 */ + {0, 4, 1, 0, 1, 0}, /* TxD1 */ + {0, 5, 1, 0, 1, 0}, /* TxD2 */ + {0, 6, 1, 0, 1, 0}, /* TxD3 */ + {1, 6, 1, 0, 3, 0}, /* TxD4 */ + {1, 7, 1, 0, 1, 0}, /* TxD5 */ + {1, 9, 1, 0, 2, 0}, /* TxD6 */ + {1, 10, 1, 0, 2, 0}, /* TxD7 */ + {0, 9, 2, 0, 1, 0}, /* RxD0 */ + {0, 10, 2, 0, 1, 0}, /* RxD1 */ + {0, 11, 2, 0, 1, 0}, /* RxD2 */ + {0, 12, 2, 0, 1, 0}, /* RxD3 */ + {0, 13, 2, 0, 1, 0}, /* RxD4 */ + {1, 1, 2, 0, 2, 0}, /* RxD5 */ + {1, 0, 2, 0, 2, 0}, /* RxD6 */ + {1, 4, 2, 0, 2, 0}, /* RxD7 */ + {0, 7, 1, 0, 1, 0}, /* TX_EN */ + {0, 8, 1, 0, 1, 0}, /* TX_ER */ + {0, 15, 2, 0, 1, 0}, /* RX_DV */ + {0, 16, 2, 0, 1, 0}, /* RX_ER */ + {0, 0, 2, 0, 1, 0}, /* RX_CLK */ + {2, 9, 1, 0, 3, 0}, /* GTX_CLK - CLK10 */ + {2, 8, 2, 0, 1, 0}, /* GTX125 - CLK9 */ /* GETH2 */ - {0, 17, 1, 0, 1}, /* TxD0 */ - {0, 18, 1, 0, 1}, /* TxD1 */ - {0, 19, 1, 0, 1}, /* TxD2 */ - {0, 20, 1, 0, 1}, /* TxD3 */ - {1, 2, 1, 0, 1}, /* TxD4 */ - {1, 3, 1, 0, 2}, /* TxD5 */ - {1, 5, 1, 0, 3}, /* TxD6 */ - {1, 8, 1, 0, 3}, /* TxD7 */ - {0, 23, 2, 0, 1}, /* RxD0 */ - {0, 24, 2, 0, 1}, /* RxD1 */ - {0, 25, 2, 0, 1}, /* RxD2 */ - {0, 26, 2, 0, 1}, /* RxD3 */ - {0, 27, 2, 0, 1}, /* RxD4 */ - {1, 12, 2, 0, 2}, /* RxD5 */ - {1, 13, 2, 0, 3}, /* RxD6 */ - {1, 11, 2, 0, 2}, /* RxD7 */ - {0, 21, 1, 0, 1}, /* TX_EN */ - {0, 22, 1, 0, 1}, /* TX_ER */ - {0, 29, 2, 0, 1}, /* RX_DV */ - {0, 30, 2, 0, 1}, /* RX_ER */ - {0, 31, 2, 0, 1}, /* RX_CLK */ - {2, 2, 1, 0, 2}, /* GTX_CLK = CLK10 */ - {2, 3, 2, 0, 1}, /* GTX125 - CLK4 */ - - {0, 1, 3, 0, 2}, /* MDIO */ - {0, 2, 1, 0, 1}, /* MDC */ - - {5, 0, 1, 0, 2}, /* UART2_SOUT */ - {5, 1, 2, 0, 3}, /* UART2_CTS */ - {5, 2, 1, 0, 1}, /* UART2_RTS */ - {5, 3, 2, 0, 2}, /* UART2_SIN */ + {0, 17, 1, 0, 1, 0}, /* TxD0 */ + {0, 18, 1, 0, 1, 0}, /* TxD1 */ + {0, 19, 1, 0, 1, 0}, /* TxD2 */ + {0, 20, 1, 0, 1, 0}, /* TxD3 */ + {1, 2, 1, 0, 1, 0}, /* TxD4 */ + {1, 3, 1, 0, 2, 0}, /* TxD5 */ + {1, 5, 1, 0, 3, 0}, /* TxD6 */ + {1, 8, 1, 0, 3, 0}, /* TxD7 */ + {0, 23, 2, 0, 1, 0}, /* RxD0 */ + {0, 24, 2, 0, 1, 0}, /* RxD1 */ + {0, 25, 2, 0, 1, 0}, /* RxD2 */ + {0, 26, 2, 0, 1, 0}, /* RxD3 */ + {0, 27, 2, 0, 1, 0}, /* RxD4 */ + {1, 12, 2, 0, 2, 0}, /* RxD5 */ + {1, 13, 2, 0, 3, 0}, /* RxD6 */ + {1, 11, 2, 0, 2, 0}, /* RxD7 */ + {0, 21, 1, 0, 1, 0}, /* TX_EN */ + {0, 22, 1, 0, 1, 0}, /* TX_ER */ + {0, 29, 2, 0, 1, 0}, /* RX_DV */ + {0, 30, 2, 0, 1, 0}, /* RX_ER */ + {0, 31, 2, 0, 1, 0}, /* RX_CLK */ + {2, 2, 1, 0, 2, 0}, /* GTX_CLK = CLK10 */ + {2, 3, 2, 0, 1, 0}, /* GTX125 - CLK4 */ + + {0, 1, 3, 0, 2, 0}, /* MDIO */ + {0, 2, 1, 0, 1, 0}, /* MDC */ + + {5, 0, 1, 0, 2, 0}, /* UART2_SOUT */ + {5, 1, 2, 0, 3, 0}, /* UART2_CTS */ + {5, 2, 1, 0, 1, 0}, /* UART2_RTS */ + {5, 3, 2, 0, 2, 0}, /* UART2_SIN */
- {0, 0, 0, 0, QE_IOP_TAB_END}, /* END of table */ + {0, 0, 0, 0, QE_IOP_TAB_END, 0}, /* END of table */ };
int board_early_init_f(void)
diff -purN a/board/freescale/mpc8360erdk/mpc8360erdk.c b/board/freescale/mpc8360erdk/mpc8360erdk.c --- a/board/freescale/mpc8360erdk/mpc8360erdk.c 2008-01-16 23:06:52.000000000 +0200 +++ b/board/freescale/mpc8360erdk/mpc8360erdk.c 2008-01-17 16:07:14.451836000 +0200 @@ -27,168 +27,168 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* MDIO */ - {0, 1, 3, 0, 2}, /* MDIO */ - {0, 2, 1, 0, 1}, /* MDC */ + {0, 1, 3, 0, 2, 0}, /* MDIO */ + {0, 2, 1, 0, 1, 0}, /* MDC */
/* UCC1 - UEC (Gigabit) */ - {0, 3, 1, 0, 1}, /* TxD0 */ - {0, 4, 1, 0, 1}, /* TxD1 */ - {0, 5, 1, 0, 1}, /* TxD2 */ - {0, 6, 1, 0, 1}, /* TxD3 */ - {0, 9, 2, 0, 1}, /* RxD0 */ - {0, 10, 2, 0, 1}, /* RxD1 */ - {0, 11, 2, 0, 1}, /* RxD2 */ - {0, 12, 2, 0, 1}, /* RxD3 */ - {0, 7, 1, 0, 1}, /* TX_EN */ - {0, 8, 1, 0, 1}, /* TX_ER */ - {0, 15, 2, 0, 1}, /* RX_DV */ - {0, 0, 2, 0, 1}, /* RX_CLK */ - {2, 9, 1, 0, 3}, /* GTX_CLK - CLK10 */ - {2, 8, 2, 0, 1}, /* GTX125 - CLK9 */ + {0, 3, 1, 0, 1, 0}, /* TxD0 */ + {0, 4, 1, 0, 1, 0}, /* TxD1 */ + {0, 5, 1, 0, 1, 0}, /* TxD2 */ + {0, 6, 1, 0, 1, 0}, /* TxD3 */ + {0, 9, 2, 0, 1, 0}, /* RxD0 */ + {0, 10, 2, 0, 1, 0}, /* RxD1 */ + {0, 11, 2, 0, 1, 0}, /* RxD2 */ + {0, 12, 2, 0, 1, 0}, /* RxD3 */ + {0, 7, 1, 0, 1, 0}, /* TX_EN */ + {0, 8, 1, 0, 1, 0}, /* TX_ER */ + {0, 15, 2, 0, 1, 0}, /* RX_DV */ + {0, 0, 2, 0, 1, 0}, /* RX_CLK */ + {2, 9, 1, 0, 3, 0}, /* GTX_CLK - CLK10 */ + {2, 8, 2, 0, 1, 0}, /* GTX125 - CLK9 */
/* UCC2 - UEC (Gigabit) */ - {0, 17, 1, 0, 1}, /* TxD0 */ - {0, 18, 1, 0, 1}, /* TxD1 */ - {0, 19, 1, 0, 1}, /* TxD2 */ - {0, 20, 1, 0, 1}, /* TxD3 */ - {0, 23, 2, 0, 1}, /* RxD0 */ - {0, 24, 2, 0, 1}, /* RxD1 */ - {0, 25, 2, 0, 1}, /* RxD2 */ - {0, 26, 2, 0, 1}, /* RxD3 */ - {0, 21, 1, 0, 1}, /* TX_EN */ - {0, 22, 1, 0, 1}, /* TX_ER */ - {0, 29, 2, 0, 1}, /* RX_DV */ - {0, 31, 2, 0, 1}, /* RX_CLK */ - {2, 2, 1, 0, 2}, /* GTX_CLK - CLK10 */ - {2, 3, 2, 0, 1}, /* GTX125 - CLK4 */ + {0, 17, 1, 0, 1, 0}, /* TxD0 */ + {0, 18, 1, 0, 1, 0}, /* TxD1 */ + {0, 19, 1, 0, 1, 0}, /* TxD2 */ + {0, 20, 1, 0, 1, 0}, /* TxD3 */ + {0, 23, 2, 0, 1, 0}, /* RxD0 */ + {0, 24, 2, 0, 1, 0}, /* RxD1 */ + {0, 25, 2, 0, 1, 0}, /* RxD2 */ + {0, 26, 2, 0, 1, 0}, /* RxD3 */ + {0, 21, 1, 0, 1, 0}, /* TX_EN */ + {0, 22, 1, 0, 1, 0}, /* TX_ER */ + {0, 29, 2, 0, 1, 0}, /* RX_DV */ + {0, 31, 2, 0, 1, 0}, /* RX_CLK */ + {2, 2, 1, 0, 2, 0}, /* GTX_CLK - CLK10 */ + {2, 3, 2, 0, 1, 0}, /* GTX125 - CLK4 */
/* UCC7 - UEC */ - {4, 0, 1, 0, 1}, /* TxD0 */ - {4, 1, 1, 0, 1}, /* TxD1 */ - {4, 2, 1, 0, 1}, /* TxD2 */ - {4, 3, 1, 0, 1}, /* TxD3 */ - {4, 6, 2, 0, 1}, /* RxD0 */ - {4, 7, 2, 0, 1}, /* RxD1 */ - {4, 8, 2, 0, 1}, /* RxD2 */ - {4, 9, 2, 0, 1}, /* RxD3 */ - {4, 4, 1, 0, 1}, /* TX_EN */ - {4, 5, 1, 0, 1}, /* TX_ER */ - {4, 12, 2, 0, 1}, /* RX_DV */ - {4, 13, 2, 0, 1}, /* RX_ER */ - {4, 10, 2, 0, 1}, /* COL */ - {4, 11, 2, 0, 1}, /* CRS */ - {2, 18, 2, 0, 1}, /* TX_CLK - CLK19 */ - {2, 19, 2, 0, 1}, /* RX_CLK - CLK20 */ + {4, 0, 1, 0, 1, 0}, /* TxD0 */ + {4, 1, 1, 0, 1, 0}, /* TxD1 */ + {4, 2, 1, 0, 1, 0}, /* TxD2 */ + {4, 3, 1, 0, 1, 0}, /* TxD3 */ + {4, 6, 2, 0, 1, 0}, /* RxD0 */ + {4, 7, 2, 0, 1, 0}, /* RxD1 */ + {4, 8, 2, 0, 1, 0}, /* RxD2 */ + {4, 9, 2, 0, 1, 0}, /* RxD3 */ + {4, 4, 1, 0, 1, 0}, /* TX_EN */ + {4, 5, 1, 0, 1, 0}, /* TX_ER */ + {4, 12, 2, 0, 1, 0}, /* RX_DV */ + {4, 13, 2, 0, 1, 0}, /* RX_ER */ + {4, 10, 2, 0, 1, 0}, /* COL */ + {4, 11, 2, 0, 1, 0}, /* CRS */ + {2, 18, 2, 0, 1, 0}, /* TX_CLK - CLK19 */ + {2, 19, 2, 0, 1, 0}, /* RX_CLK - CLK20 */
/* UCC4 - UEC */ - {1, 14, 1, 0, 1}, /* TxD0 */ - {1, 15, 1, 0, 1}, /* TxD1 */ - {1, 16, 1, 0, 1}, /* TxD2 */ - {1, 17, 1, 0, 1}, /* TxD3 */ - {1, 20, 2, 0, 1}, /* RxD0 */ - {1, 21, 2, 0, 1}, /* RxD1 */ - {1, 22, 2, 0, 1}, /* RxD2 */ - {1, 23, 2, 0, 1}, /* RxD3 */ - {1, 18, 1, 0, 1}, /* TX_EN */ - {1, 19, 1, 0, 2}, /* TX_ER */ - {1, 26, 2, 0, 1}, /* RX_DV */ - {1, 27, 2, 0, 1}, /* RX_ER */ - {1, 24, 2, 0, 1}, /* COL */ - {1, 25, 2, 0, 1}, /* CRS */ - {2, 6, 2, 0, 1}, /* TX_CLK - CLK7 */ - {2, 7, 2, 0, 1}, /* RX_CLK - CLK8 */ + {1, 14, 1, 0, 1, 0}, /* TxD0 */ + {1, 15, 1, 0, 1, 0}, /* TxD1 */ + {1, 16, 1, 0, 1, 0}, /* TxD2 */ + {1, 17, 1, 0, 1, 0}, /* TxD3 */ + {1, 20, 2, 0, 1, 0}, /* RxD0 */ + {1, 21, 2, 0, 1, 0}, /* RxD1 */ + {1, 22, 2, 0, 1, 0}, /* RxD2 */ + {1, 23, 2, 0, 1, 0}, /* RxD3 */ + {1, 18, 1, 0, 1, 0}, /* TX_EN */ + {1, 19, 1, 0, 2, 0}, /* TX_ER */ + {1, 26, 2, 0, 1, 0}, /* RX_DV */ + {1, 27, 2, 0, 1, 0}, /* RX_ER */ + {1, 24, 2, 0, 1, 0}, /* COL */ + {1, 25, 2, 0, 1, 0}, /* CRS */ + {2, 6, 2, 0, 1, 0}, /* TX_CLK - CLK7 */ + {2, 7, 2, 0, 1, 0}, /* RX_CLK - CLK8 */
/* PCI1 */ - {5, 4, 2, 0, 3}, /* PCI_M66EN */ - {5, 5, 1, 0, 3}, /* PCI_INTA */ - {5, 6, 1, 0, 3}, /* PCI_RSTO */ - {5, 7, 3, 0, 3}, /* PCI_C_BE0 */ - {5, 8, 3, 0, 3}, /* PCI_C_BE1 */ - {5, 9, 3, 0, 3}, /* PCI_C_BE2 */ - {5, 10, 3, 0, 3}, /* PCI_C_BE3 */ - {5, 11, 3, 0, 3}, /* PCI_PAR */ - {5, 12, 3, 0, 3}, /* PCI_FRAME */ - {5, 13, 3, 0, 3}, /* PCI_TRDY */ - {5, 14, 3, 0, 3}, /* PCI_IRDY */ - {5, 15, 3, 0, 3}, /* PCI_STOP */ - {5, 16, 3, 0, 3}, /* PCI_DEVSEL */ - {5, 17, 0, 0, 0}, /* PCI_IDSEL */ - {5, 18, 3, 0, 3}, /* PCI_SERR */ - {5, 19, 3, 0, 3}, /* PCI_PERR */ - {5, 20, 3, 0, 3}, /* PCI_REQ0 */ - {5, 21, 2, 0, 3}, /* PCI_REQ1 */ - {5, 22, 2, 0, 3}, /* PCI_GNT2 */ - {5, 23, 3, 0, 3}, /* PCI_GNT0 */ - {5, 24, 1, 0, 3}, /* PCI_GNT1 */ - {5, 25, 1, 0, 3}, /* PCI_GNT2 */ - {5, 26, 0, 0, 0}, /* PCI_CLK0 */ - {5, 27, 0, 0, 0}, /* PCI_CLK1 */ - {5, 28, 0, 0, 0}, /* PCI_CLK2 */ - {5, 29, 0, 0, 3}, /* PCI_SYNC_OUT */ - {6, 0, 3, 0, 3}, /* PCI_AD0 */ - {6, 1, 3, 0, 3}, /* PCI_AD1 */ - {6, 2, 3, 0, 3}, /* PCI_AD2 */ - {6, 3, 3, 0, 3}, /* PCI_AD3 */ - {6, 4, 3, 0, 3}, /* PCI_AD4 */ - {6, 5, 3, 0, 3}, /* PCI_AD5 */ - {6, 6, 3, 0, 3}, /* PCI_AD6 */ - {6, 7, 3, 0, 3}, /* PCI_AD7 */ - {6, 8, 3, 0, 3}, /* PCI_AD8 */ - {6, 9, 3, 0, 3}, /* PCI_AD9 */ - {6, 10, 3, 0, 3}, /* PCI_AD10 */ - {6, 11, 3, 0, 3}, /* PCI_AD11 */ - {6, 12, 3, 0, 3}, /* PCI_AD12 */ - {6, 13, 3, 0, 3}, /* PCI_AD13 */ - {6, 14, 3, 0, 3}, /* PCI_AD14 */ - {6, 15, 3, 0, 3}, /* PCI_AD15 */ - {6, 16, 3, 0, 3}, /* PCI_AD16 */ - {6, 17, 3, 0, 3}, /* PCI_AD17 */ - {6, 18, 3, 0, 3}, /* PCI_AD18 */ - {6, 19, 3, 0, 3}, /* PCI_AD19 */ - {6, 20, 3, 0, 3}, /* PCI_AD20 */ - {6, 21, 3, 0, 3}, /* PCI_AD21 */ - {6, 22, 3, 0, 3}, /* PCI_AD22 */ - {6, 23, 3, 0, 3}, /* PCI_AD23 */ - {6, 24, 3, 0, 3}, /* PCI_AD24 */ - {6, 25, 3, 0, 3}, /* PCI_AD25 */ - {6, 26, 3, 0, 3}, /* PCI_AD26 */ - {6, 27, 3, 0, 3}, /* PCI_AD27 */ - {6, 28, 3, 0, 3}, /* PCI_AD28 */ - {6, 29, 3, 0, 3}, /* PCI_AD29 */ - {6, 30, 3, 0, 3}, /* PCI_AD30 */ - {6, 31, 3, 0, 3}, /* PCI_AD31 */ + {5, 4, 2, 0, 3, 0}, /* PCI_M66EN */ + {5, 5, 1, 0, 3, 0}, /* PCI_INTA */ + {5, 6, 1, 0, 3, 0}, /* PCI_RSTO */ + {5, 7, 3, 0, 3, 0}, /* PCI_C_BE0 */ + {5, 8, 3, 0, 3, 0}, /* PCI_C_BE1 */ + {5, 9, 3, 0, 3, 0}, /* PCI_C_BE2 */ + {5, 10, 3, 0, 3, 0}, /* PCI_C_BE3 */ + {5, 11, 3, 0, 3, 0}, /* PCI_PAR */ + {5, 12, 3, 0, 3, 0}, /* PCI_FRAME */ + {5, 13, 3, 0, 3, 0}, /* PCI_TRDY */ + {5, 14, 3, 0, 3, 0}, /* PCI_IRDY */ + {5, 15, 3, 0, 3, 0}, /* PCI_STOP */ + {5, 16, 3, 0, 3, 0}, /* PCI_DEVSEL */ + {5, 17, 0, 0, 0, 0}, /* PCI_IDSEL */ + {5, 18, 3, 0, 3, 0}, /* PCI_SERR */ + {5, 19, 3, 0, 3, 0}, /* PCI_PERR */ + {5, 20, 3, 0, 3, 0}, /* PCI_REQ0 */ + {5, 21, 2, 0, 3, 0}, /* PCI_REQ1 */ + {5, 22, 2, 0, 3, 0}, /* PCI_GNT2 */ + {5, 23, 3, 0, 3, 0}, /* PCI_GNT0 */ + {5, 24, 1, 0, 3, 0}, /* PCI_GNT1 */ + {5, 25, 1, 0, 3, 0}, /* PCI_GNT2 */ + {5, 26, 0, 0, 0, 0}, /* PCI_CLK0 */ + {5, 27, 0, 0, 0, 0}, /* PCI_CLK1 */ + {5, 28, 0, 0, 0, 0}, /* PCI_CLK2 */ + {5, 29, 0, 0, 3, 0}, /* PCI_SYNC_OUT */ + {6, 0, 3, 0, 3, 0}, /* PCI_AD0 */ + {6, 1, 3, 0, 3, 0}, /* PCI_AD1 */ + {6, 2, 3, 0, 3, 0}, /* PCI_AD2 */ + {6, 3, 3, 0, 3, 0}, /* PCI_AD3 */ + {6, 4, 3, 0, 3, 0}, /* PCI_AD4 */ + {6, 5, 3, 0, 3, 0}, /* PCI_AD5 */ + {6, 6, 3, 0, 3, 0}, /* PCI_AD6 */ + {6, 7, 3, 0, 3, 0}, /* PCI_AD7 */ + {6, 8, 3, 0, 3, 0}, /* PCI_AD8 */ + {6, 9, 3, 0, 3, 0}, /* PCI_AD9 */ + {6, 10, 3, 0, 3, 0}, /* PCI_AD10 */ + {6, 11, 3, 0, 3, 0}, /* PCI_AD11 */ + {6, 12, 3, 0, 3, 0}, /* PCI_AD12 */ + {6, 13, 3, 0, 3, 0}, /* PCI_AD13 */ + {6, 14, 3, 0, 3, 0}, /* PCI_AD14 */ + {6, 15, 3, 0, 3, 0}, /* PCI_AD15 */ + {6, 16, 3, 0, 3, 0}, /* PCI_AD16 */ + {6, 17, 3, 0, 3, 0}, /* PCI_AD17 */ + {6, 18, 3, 0, 3, 0}, /* PCI_AD18 */ + {6, 19, 3, 0, 3, 0}, /* PCI_AD19 */ + {6, 20, 3, 0, 3, 0}, /* PCI_AD20 */ + {6, 21, 3, 0, 3, 0}, /* PCI_AD21 */ + {6, 22, 3, 0, 3, 0}, /* PCI_AD22 */ + {6, 23, 3, 0, 3, 0}, /* PCI_AD23 */ + {6, 24, 3, 0, 3, 0}, /* PCI_AD24 */ + {6, 25, 3, 0, 3, 0}, /* PCI_AD25 */ + {6, 26, 3, 0, 3, 0}, /* PCI_AD26 */ + {6, 27, 3, 0, 3, 0}, /* PCI_AD27 */ + {6, 28, 3, 0, 3, 0}, /* PCI_AD28 */ + {6, 29, 3, 0, 3, 0}, /* PCI_AD29 */ + {6, 30, 3, 0, 3, 0}, /* PCI_AD30 */ + {6, 31, 3, 0, 3, 0}, /* PCI_AD31 */
/* NAND */ - {4, 18, 2, 0, 0}, /* NAND_RYnBY */ + {4, 18, 2, 0, 0, 0}, /* NAND_RYnBY */
/* DUART - UART2 */ - {5, 0, 1, 0, 2}, /* UART2_SOUT */ - {5, 2, 1, 0, 1}, /* UART2_RTS */ - {5, 3, 2, 0, 2}, /* UART2_SIN */ - {5, 1, 2, 0, 3}, /* UART2_CTS */ + {5, 0, 1, 0, 2, 0}, /* UART2_SOUT */ + {5, 2, 1, 0, 1, 0}, /* UART2_RTS */ + {5, 3, 2, 0, 2, 0}, /* UART2_SIN */ + {5, 1, 2, 0, 3, 0}, /* UART2_CTS */
/* UCC5 - UART3 */ - {3, 0, 1, 0, 1}, /* UART3_TX */ - {3, 4, 1, 0, 1}, /* UART3_RTS */ - {3, 6, 2, 0, 1}, /* UART3_RX */ - {3, 12, 2, 0, 0}, /* UART3_CTS */ - {3, 13, 2, 0, 0}, /* UCC5_CD */ + {3, 0, 1, 0, 1, 0}, /* UART3_TX */ + {3, 4, 1, 0, 1, 0}, /* UART3_RTS */ + {3, 6, 2, 0, 1, 0}, /* UART3_RX */ + {3, 12, 2, 0, 0, 0}, /* UART3_CTS */ + {3, 13, 2, 0, 0, 0}, /* UCC5_CD */
/* UCC6 - UART4 */ - {3, 14, 1, 0, 1}, /* UART4_TX */ - {3, 18, 1, 0, 1}, /* UART4_RTS */ - {3, 20, 2, 0, 1}, /* UART4_RX */ - {3, 26, 2, 0, 0}, /* UART4_CTS */ - {3, 27, 2, 0, 0}, /* UCC6_CD */ + {3, 14, 1, 0, 1, 0}, /* UART4_TX */ + {3, 18, 1, 0, 1, 0}, /* UART4_RTS */ + {3, 20, 2, 0, 1, 0}, /* UART4_RX */ + {3, 26, 2, 0, 0, 0}, /* UART4_CTS */ + {3, 27, 2, 0, 0, 0}, /* UCC6_CD */
/* Fujitsu MB86277 (MINT) graphics controller */ - {0, 30, 1, 0, 0}, /* nSRESET_GRAPHICS */ - {1, 5, 1, 0, 0}, /* nXRST_GRAPHICS */ - {1, 7, 1, 0, 0}, /* LVDS_BKLT_CTR */ - {2, 16, 1, 0, 0}, /* LVDS_BKLT_EN */ + {0, 30, 1, 0, 0, 0}, /* nSRESET_GRAPHICS */ + {1, 5, 1, 0, 0, 0}, /* nXRST_GRAPHICS */ + {1, 7, 1, 0, 0, 0}, /* LVDS_BKLT_CTR */ + {2, 16, 1, 0, 0, 0}, /* LVDS_BKLT_EN */
/* END of table */ - {0, 0, 0, 0, QE_IOP_TAB_END}, + {0, 0, 0, 0, QE_IOP_TAB_END, 0}, };
diff -purN a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c --- a/board/freescale/mpc8568mds/mpc8568mds.c 2008-01-16 23:06:52.000000000 +0200 +++ b/board/freescale/mpc8568mds/mpc8568mds.c 2008-01-17 16:03:46.708593000 +0200 @@ -37,64 +37,64 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ - {4, 10, 1, 0, 2}, /* TxD0 */ - {4, 9, 1, 0, 2}, /* TxD1 */ - {4, 8, 1, 0, 2}, /* TxD2 */ - {4, 7, 1, 0, 2}, /* TxD3 */ - {4, 23, 1, 0, 2}, /* TxD4 */ - {4, 22, 1, 0, 2}, /* TxD5 */ - {4, 21, 1, 0, 2}, /* TxD6 */ - {4, 20, 1, 0, 2}, /* TxD7 */ - {4, 15, 2, 0, 2}, /* RxD0 */ - {4, 14, 2, 0, 2}, /* RxD1 */ - {4, 13, 2, 0, 2}, /* RxD2 */ - {4, 12, 2, 0, 2}, /* RxD3 */ - {4, 29, 2, 0, 2}, /* RxD4 */ - {4, 28, 2, 0, 2}, /* RxD5 */ - {4, 27, 2, 0, 2}, /* RxD6 */ - {4, 26, 2, 0, 2}, /* RxD7 */ - {4, 11, 1, 0, 2}, /* TX_EN */ - {4, 24, 1, 0, 2}, /* TX_ER */ - {4, 16, 2, 0, 2}, /* RX_DV */ - {4, 30, 2, 0, 2}, /* RX_ER */ - {4, 17, 2, 0, 2}, /* RX_CLK */ - {4, 19, 1, 0, 2}, /* GTX_CLK */ - {1, 31, 2, 0, 3}, /* GTX125 */ + {4, 10, 1, 0, 2, 0}, /* TxD0 */ + {4, 9, 1, 0, 2, 0}, /* TxD1 */ + {4, 8, 1, 0, 2, 0}, /* TxD2 */ + {4, 7, 1, 0, 2, 0}, /* TxD3 */ + {4, 23, 1, 0, 2, 0}, /* TxD4 */ + {4, 22, 1, 0, 2, 0}, /* TxD5 */ + {4, 21, 1, 0, 2, 0}, /* TxD6 */ + {4, 20, 1, 0, 2, 0}, /* TxD7 */ + {4, 15, 2, 0, 2, 0}, /* RxD0 */ + {4, 14, 2, 0, 2, 0}, /* RxD1 */ + {4, 13, 2, 0, 2, 0}, /* RxD2 */ + {4, 12, 2, 0, 2, 0}, /* RxD3 */ + {4, 29, 2, 0, 2, 0}, /* RxD4 */ + {4, 28, 2, 0, 2, 0}, /* RxD5 */ + {4, 27, 2, 0, 2, 0}, /* RxD6 */ + {4, 26, 2, 0, 2, 0}, /* RxD7 */ + {4, 11, 1, 0, 2, 0}, /* TX_EN */ + {4, 24, 1, 0, 2, 0}, /* TX_ER */ + {4, 16, 2, 0, 2, 0}, /* RX_DV */ + {4, 30, 2, 0, 2, 0}, /* RX_ER */ + {4, 17, 2, 0, 2, 0}, /* RX_CLK */ + {4, 19, 1, 0, 2, 0}, /* GTX_CLK */ + {1, 31, 2, 0, 3, 0}, /* GTX125 */
/* GETH2 */ - {5, 10, 1, 0, 2}, /* TxD0 */ - {5, 9, 1, 0, 2}, /* TxD1 */ - {5, 8, 1, 0, 2}, /* TxD2 */ - {5, 7, 1, 0, 2}, /* TxD3 */ - {5, 23, 1, 0, 2}, /* TxD4 */ - {5, 22, 1, 0, 2}, /* TxD5 */ - {5, 21, 1, 0, 2}, /* TxD6 */ - {5, 20, 1, 0, 2}, /* TxD7 */ - {5, 15, 2, 0, 2}, /* RxD0 */ - {5, 14, 2, 0, 2}, /* RxD1 */ - {5, 13, 2, 0, 2}, /* RxD2 */ - {5, 12, 2, 0, 2}, /* RxD3 */ - {5, 29, 2, 0, 2}, /* RxD4 */ - {5, 28, 2, 0, 2}, /* RxD5 */ - {5, 27, 2, 0, 3}, /* RxD6 */ - {5, 26, 2, 0, 2}, /* RxD7 */ - {5, 11, 1, 0, 2}, /* TX_EN */ - {5, 24, 1, 0, 2}, /* TX_ER */ - {5, 16, 2, 0, 2}, /* RX_DV */ - {5, 30, 2, 0, 2}, /* RX_ER */ - {5, 17, 2, 0, 2}, /* RX_CLK */ - {5, 19, 1, 0, 2}, /* GTX_CLK */ - {1, 31, 2, 0, 3}, /* GTX125 */ - {4, 6, 3, 0, 2}, /* MDIO */ - {4, 5, 1, 0, 2}, /* MDC */ + {5, 10, 1, 0, 2, 0}, /* TxD0 */ + {5, 9, 1, 0, 2, 0}, /* TxD1 */ + {5, 8, 1, 0, 2, 0}, /* TxD2 */ + {5, 7, 1, 0, 2, 0}, /* TxD3 */ + {5, 23, 1, 0, 2, 0}, /* TxD4 */ + {5, 22, 1, 0, 2, 0}, /* TxD5 */ + {5, 21, 1, 0, 2, 0}, /* TxD6 */ + {5, 20, 1, 0, 2, 0}, /* TxD7 */ + {5, 15, 2, 0, 2, 0}, /* RxD0 */ + {5, 14, 2, 0, 2, 0}, /* RxD1 */ + {5, 13, 2, 0, 2, 0}, /* RxD2 */ + {5, 12, 2, 0, 2, 0}, /* RxD3 */ + {5, 29, 2, 0, 2, 0}, /* RxD4 */ + {5, 28, 2, 0, 2, 0}, /* RxD5 */ + {5, 27, 2, 0, 3, 0}, /* RxD6 */ + {5, 26, 2, 0, 2, 0}, /* RxD7 */ + {5, 11, 1, 0, 2, 0}, /* TX_EN */ + {5, 24, 1, 0, 2, 0}, /* TX_ER */ + {5, 16, 2, 0, 2, 0}, /* RX_DV */ + {5, 30, 2, 0, 2, 0}, /* RX_ER */ + {5, 17, 2, 0, 2, 0}, /* RX_CLK */ + {5, 19, 1, 0, 2, 0}, /* GTX_CLK */ + {1, 31, 2, 0, 3, 0}, /* GTX125 */ + {4, 6, 3, 0, 2, 0}, /* MDIO */ + {4, 5, 1, 0, 2, 0}, /* MDC */
/* UART1 */ - {2, 0, 1, 0, 2}, /* UART_SOUT1 */ - {2, 1, 1, 0, 2}, /* UART_RTS1 */ - {2, 2, 2, 0, 2}, /* UART_CTS1 */ - {2, 3, 2, 0, 2}, /* UART_SIN1 */ + {2, 0, 1, 0, 2, 0}, /* UART_SOUT1 */ + {2, 1, 1, 0, 2, 0}, /* UART_RTS1 */ + {2, 2, 2, 0, 2, 0}, /* UART_CTS1 */ + {2, 3, 2, 0, 2, 0}, /* UART_SIN1 */
diff -purN a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c --- a/board/freescale/mpc8323erdb/mpc8323erdb.c 2008-01-16 23:06:52.000000000 +0200 +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c 2008-01-17 16:09:44.661841000 +0200 @@ -28,47 +28,47 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* UCC3 */ - {1, 0, 1, 0, 1}, /* TxD0 */ - {1, 1, 1, 0, 1}, /* TxD1 */ - {1, 2, 1, 0, 1}, /* TxD2 */ - {1, 3, 1, 0, 1}, /* TxD3 */ - {1, 9, 1, 0, 1}, /* TxER */ - {1, 12, 1, 0, 1}, /* TxEN */ - {3, 24, 2, 0, 1}, /* TxCLK->CLK10 */ - - {1, 4, 2, 0, 1}, /* RxD0 */ - {1, 5, 2, 0, 1}, /* RxD1 */ - {1, 6, 2, 0, 1}, /* RxD2 */ - {1, 7, 2, 0, 1}, /* RxD3 */ - {1, 8, 2, 0, 1}, /* RxER */ - {1, 10, 2, 0, 1}, /* RxDV */ - {0, 13, 2, 0, 1}, /* RxCLK->CLK9 */ - {1, 11, 2, 0, 1}, /* COL */ - {1, 13, 2, 0, 1}, /* CRS */ + {1, 0, 1, 0, 1, 0}, /* TxD0 */ + {1, 1, 1, 0, 1, 0}, /* TxD1 */ + {1, 2, 1, 0, 1, 0}, /* TxD2 */ + {1, 3, 1, 0, 1, 0}, /* TxD3 */ + {1, 9, 1, 0, 1, 0}, /* TxER */ + {1, 12, 1, 0, 1, 0}, /* TxEN */ + {3, 24, 2, 0, 1, 0}, /* TxCLK->CLK10 */ + + {1, 4, 2, 0, 1, 0}, /* RxD0 */ + {1, 5, 2, 0, 1, 0}, /* RxD1 */ + {1, 6, 2, 0, 1, 0}, /* RxD2 */ + {1, 7, 2, 0, 1, 0}, /* RxD3 */ + {1, 8, 2, 0, 1, 0}, /* RxER */ + {1, 10, 2, 0, 1, 0}, /* RxDV */ + {0, 13, 2, 0, 1, 0}, /* RxCLK->CLK9 */ + {1, 11, 2, 0, 1, 0}, /* COL */ + {1, 13, 2, 0, 1, 0}, /* CRS */
/* UCC2 */ - {0, 18, 1, 0, 1}, /* TxD0 */ - {0, 19, 1, 0, 1}, /* TxD1 */ - {0, 20, 1, 0, 1}, /* TxD2 */ - {0, 21, 1, 0, 1}, /* TxD3 */ - {0, 27, 1, 0, 1}, /* TxER */ - {0, 30, 1, 0, 1}, /* TxEN */ - {3, 23, 2, 0, 1}, /* TxCLK->CLK3 */ - - {0, 22, 2, 0, 1}, /* RxD0 */ - {0, 23, 2, 0, 1}, /* RxD1 */ - {0, 24, 2, 0, 1}, /* RxD2 */ - {0, 25, 2, 0, 1}, /* RxD3 */ - {0, 26, 1, 0, 1}, /* RxER */ - {0, 28, 2, 0, 1}, /* Rx_DV */ - {3, 21, 2, 0, 1}, /* RxCLK->CLK16 */ - {0, 29, 2, 0, 1}, /* COL */ - {0, 31, 2, 0, 1}, /* CRS */ + {0, 18, 1, 0, 1, 0}, /* TxD0 */ + {0, 19, 1, 0, 1, 0}, /* TxD1 */ + {0, 20, 1, 0, 1, 0}, /* TxD2 */ + {0, 21, 1, 0, 1, 0}, /* TxD3 */ + {0, 27, 1, 0, 1, 0}, /* TxER */ + {0, 30, 1, 0, 1, 0}, /* TxEN */ + {3, 23, 2, 0, 1, 0}, /* TxCLK->CLK3 */ + + {0, 22, 2, 0, 1, 0}, /* RxD0 */ + {0, 23, 2, 0, 1, 0}, /* RxD1 */ + {0, 24, 2, 0, 1, 0}, /* RxD2 */ + {0, 25, 2, 0, 1, 0}, /* RxD3 */ + {0, 26, 1, 0, 1, 0}, /* RxER */ + {0, 28, 2, 0, 1, 0}, /* Rx_DV */ + {3, 21, 2, 0, 1, 0}, /* RxCLK->CLK16 */ + {0, 29, 2, 0, 1, 0}, /* COL */ + {0, 31, 2, 0, 1, 0}, /* CRS */
- {3, 4, 3, 0, 2}, /* MDIO */ - {3, 5, 1, 0, 2}, /* MDC */ + {3, 4, 3, 0, 2, 0}, /* MDIO */ + {3, 5, 1, 0, 2, 0}, /* MDC */
diff -purN a/board/freescale/mpc832xemds/mpc832xemds.c b/board/freescale/mpc832xemds/mpc832xemds.c --- a/board/freescale/mpc832xemds/mpc832xemds.c 2008-01-16 23:06:52.000000000 +0200 +++ b/board/freescale/mpc832xemds/mpc832xemds.c 2008-01-17 16:10:52.724934000 +0200 @@ -36,47 +36,47 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* ETH3 */ - {1, 0, 1, 0, 1}, /* TxD0 */ - {1, 1, 1, 0, 1}, /* TxD1 */ - {1, 2, 1, 0, 1}, /* TxD2 */ - {1, 3, 1, 0, 1}, /* TxD3 */ - {1, 9, 1, 0, 1}, /* TxER */ - {1, 12, 1, 0, 1}, /* TxEN */ - {3, 24, 2, 0, 1}, /* TxCLK->CLK10 */ - - {1, 4, 2, 0, 1}, /* RxD0 */ - {1, 5, 2, 0, 1}, /* RxD1 */ - {1, 6, 2, 0, 1}, /* RxD2 */ - {1, 7, 2, 0, 1}, /* RxD3 */ - {1, 8, 2, 0, 1}, /* RxER */ - {1, 10, 2, 0, 1}, /* RxDV */ - {0, 13, 2, 0, 1}, /* RxCLK->CLK9 */ - {1, 11, 2, 0, 1}, /* COL */ - {1, 13, 2, 0, 1}, /* CRS */ + {1, 0, 1, 0, 1, 0}, /* TxD0 */ + {1, 1, 1, 0, 1, 0}, /* TxD1 */ + {1, 2, 1, 0, 1, 0}, /* TxD2 */ + {1, 3, 1, 0, 1, 0}, /* TxD3 */ + {1, 9, 1, 0, 1, 0}, /* TxER */ + {1, 12, 1, 0, 1, 0}, /* TxEN */ + {3, 24, 2, 0, 1, 0}, /* TxCLK->CLK10 */ + + {1, 4, 2, 0, 1, 0}, /* RxD0 */ + {1, 5, 2, 0, 1, 0}, /* RxD1 */ + {1, 6, 2, 0, 1, 0}, /* RxD2 */ + {1, 7, 2, 0, 1, 0}, /* RxD3 */ + {1, 8, 2, 0, 1, 0}, /* RxER */ + {1, 10, 2, 0, 1, 0}, /* RxDV */ + {0, 13, 2, 0, 1, 0}, /* RxCLK->CLK9 */ + {1, 11, 2, 0, 1, 0}, /* COL */ + {1, 13, 2, 0, 1, 0}, /* CRS */
/* ETH4 */ - {1, 18, 1, 0, 1}, /* TxD0 */ - {1, 19, 1, 0, 1}, /* TxD1 */ - {1, 20, 1, 0, 1}, /* TxD2 */ - {1, 21, 1, 0, 1}, /* TxD3 */ - {1, 27, 1, 0, 1}, /* TxER */ - {1, 30, 1, 0, 1}, /* TxEN */ - {3, 6, 2, 0, 1}, /* TxCLK->CLK8 */ - - {1, 22, 2, 0, 1}, /* RxD0 */ - {1, 23, 2, 0, 1}, /* RxD1 */ - {1, 24, 2, 0, 1}, /* RxD2 */ - {1, 25, 2, 0, 1}, /* RxD3 */ - {1, 26, 1, 0, 1}, /* RxER */ - {1, 28, 2, 0, 1}, /* Rx_DV */ - {3, 31, 2, 0, 1}, /* RxCLK->CLK7 */ - {1, 29, 2, 0, 1}, /* COL */ - {1, 31, 2, 0, 1}, /* CRS */ + {1, 18, 1, 0, 1, 0}, /* TxD0 */ + {1, 19, 1, 0, 1, 0}, /* TxD1 */ + {1, 20, 1, 0, 1, 0}, /* TxD2 */ + {1, 21, 1, 0, 1, 0}, /* TxD3 */ + {1, 27, 1, 0, 1, 0}, /* TxER */ + {1, 30, 1, 0, 1, 0}, /* TxEN */ + {3, 6, 2, 0, 1, 0}, /* TxCLK->CLK8 */ + + {1, 22, 2, 0, 1, 0}, /* RxD0 */ + {1, 23, 2, 0, 1, 0}, /* RxD1 */ + {1, 24, 2, 0, 1, 0}, /* RxD2 */ + {1, 25, 2, 0, 1, 0}, /* RxD3 */ + {1, 26, 1, 0, 1, 0}, /* RxER */ + {1, 28, 2, 0, 1, 0}, /* Rx_DV */ + {3, 31, 2, 0, 1, 0}, /* RxCLK->CLK7 */ + {1, 29, 2, 0, 1, 0}, /* COL */ + {1, 31, 2, 0, 1, 0}, /* CRS */
Looks okay at first glance, but I couldn't apply the patch:
$ git-am "/home/b04825/.mozilla/default/2ir4ayuy.slt/Mail/Local Folders/patches"
Applying QE IO: Add initial data to pin configuration + read/write functions
fatal: corrupt patch at line 40 Patch failed at 0001.
Looks like you have a line wrapping problem in your emailer. Try using git-send-email.
- /* Setup the data */
- tmp_val = in_be32(&par_io[port].cpdat);
- if (data)
- else
I see that qe_config_iopin() will always write a 0 or 1 now, ignoring the current value. Are you sure this is a good idea? What if I don't want U-Boot to change the current pin value?
Plus, doesn't this assume that the pin is set to output? Shouldn't you check to see if the pin is output or input/output, and only write cpdat if it is? Also, I believe that cpdat is used only if the pin is configured as a GPIO. If so, I don't see you check for that, either.
Well, not sure how important this is, as this function is typically used for port initialization. This was also the case in the CPM2 initialization tables. Anyway, I can add a value of 2 which would stand for don't care.
Good points. Will add these checks and repost the patch. Will also try to post in a different mailer to overcome the line wrapping problem. David.
On the MPC83xx & MPC85xx architectures that have QE, add initial data to the pin configuration table (qe_iop_conf_tab). This is relevant for GPIO pins defined as output. One can setup a value of 2 to leave the value unchanged. QE initialization tables in all relevant boards were also replaced. In addition, add IO pin read & write functions.
diff -purN a/cpu/mpc85xx/qe_io.c b/cpu/mpc85xx/qe_io.c --- a/cpu/mpc85xx/qe_io.c 2008-01-02 13:39:04.000000000 +0200 +++ b/cpu/mpc85xx/qe_io.c 2008-01-06 10:54:24.201604000 +0200 @@ -27,7 +27,8 @@
#if defined(CONFIG_QE) #define NUM_OF_PINS 32 -void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) +void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign, + int data) { u32 pin_2bit_mask; u32 pin_2bit_dir; @@ -38,6 +39,20 @@ void qe_config_iopin(u8 port, u8 pin, in volatile par_io_t *par_io = (volatile par_io_t *) &(gur->qe_par_io);
+ /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + if ((data != 2) && /* Don't leave unchanged */ + (assign == 0) && /* GPIO */ + (dir & 1)) { /* Has output */ + tmp_val = in_be32(&par_io[port].cpdat); + if (data) + out_be32(&par_io[port].cpdat, pin_1bit_mask | tmp_val); + else + out_be32(&par_io[port].cpdat, ~pin_1bit_mask & tmp_val); + } + /* Caculate pin location and 2bit mask and dir */ pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); @@ -55,9 +70,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io[port].cpdir1, pin_2bit_dir | tmp_val); }
- /* Calculate pin location for 1bit mask */ - pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); - /* Setup the open drain */ tmp_val = in_be32(&par_io[port].cpodr); if (open_drain) @@ -82,4 +94,39 @@ void qe_config_iopin(u8 port, u8 pin, in } }
diff -purN a/cpu/mpc83xx/qe_io.c b/cpu/mpc83xx/qe_io.c --- a/cpu/mpc83xx/qe_io.c 2008-01-02 13:39:04.000000000 +0200 +++ b/cpu/mpc83xx/qe_io.c 2008-01-06 10:59:54.410427000 +0200 @@ -27,7 +27,8 @@
#if defined(CONFIG_QE) #define NUM_OF_PINS 32 -void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) +void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign, + int data) { u32 pin_2bit_mask; u32 pin_2bit_dir; @@ -37,6 +38,20 @@ void qe_config_iopin(u8 port, u8 pin, in volatile immap_t *im = (volatile immap_t *)CFG_IMMR; volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im->qepio;
+ /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + if ((data != 2) && /* Don't leave unchanged */ + (assign == 0) && /* GPIO */ + (dir & 1)) { /* Has output */ + tmp_val = in_be32(&par_io->ioport[port].pdat); + if (data) + out_be32(&par_io->ioport[port].pdat, pin_1bit_mask | tmp_val); + else + out_be32(&par_io->ioport[port].pdat, ~pin_1bit_mask & tmp_val); + } + /* Caculate pin location and 2bit mask and dir */ pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); @@ -54,9 +69,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io->ioport[port].dir1, pin_2bit_dir | tmp_val); }
- /* Calculate pin location for 1bit mask */ - pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); - /* Setup the open drain */ tmp_val = in_be32(&par_io->ioport[port].podr); if (open_drain) { @@ -82,4 +94,38 @@ void qe_config_iopin(u8 port, u8 pin, in } }
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ - {0, 3, 1, 0, 1}, /* TxD0 */ - {0, 4, 1, 0, 1}, /* TxD1 */ - {0, 5, 1, 0, 1}, /* TxD2 */ - {0, 6, 1, 0, 1}, /* TxD3 */ - {1, 6, 1, 0, 3}, /* TxD4 */ - {1, 7, 1, 0, 1}, /* TxD5 */ - {1, 9, 1, 0, 2}, /* TxD6 */ - {1, 10, 1, 0, 2}, /* TxD7 */ - {0, 9, 2, 0, 1}, /* RxD0 */ - {0, 10, 2, 0, 1}, /* RxD1 */ - {0, 11, 2, 0, 1}, /* RxD2 */ - {0, 12, 2, 0, 1}, /* RxD3 */ - {0, 13, 2, 0, 1}, /* RxD4 */ - {1, 1, 2, 0, 2}, /* RxD5 */ - {1, 0, 2, 0, 2}, /* RxD6 */ - {1, 4, 2, 0, 2}, /* RxD7 */ - {0, 7, 1, 0, 1}, /* TX_EN */ - {0, 8, 1, 0, 1}, /* TX_ER */ - {0, 15, 2, 0, 1}, /* RX_DV */ - {0, 16, 2, 0, 1}, /* RX_ER */ - {0, 0, 2, 0, 1}, /* RX_CLK */ - {2, 9, 1, 0, 3}, /* GTX_CLK - CLK10 */ - {2, 8, 2, 0, 1}, /* GTX125 - CLK9 */ + {0, 3, 1, 0, 1, 2}, /* TxD0 */ + {0, 4, 1, 0, 1, 2}, /* TxD1 */ + {0, 5, 1, 0, 1, 2}, /* TxD2 */ + {0, 6, 1, 0, 1, 2}, /* TxD3 */ + {1, 6, 1, 0, 3, 2}, /* TxD4 */ + {1, 7, 1, 0, 1, 2}, /* TxD5 */ + {1, 9, 1, 0, 2, 2}, /* TxD6 */ + {1, 10, 1, 0, 2, 2}, /* TxD7 */ + {0, 9, 2, 0, 1, 2}, /* RxD0 */ + {0, 10, 2, 0, 1, 2}, /* RxD1 */ + {0, 11, 2, 0, 1, 2}, /* RxD2 */ + {0, 12, 2, 0, 1, 2}, /* RxD3 */ + {0, 13, 2, 0, 1, 2}, /* RxD4 */ + {1, 1, 2, 0, 2, 2}, /* RxD5 */ + {1, 0, 2, 0, 2, 2}, /* RxD6 */ + {1, 4, 2, 0, 2, 2}, /* RxD7 */ + {0, 7, 1, 0, 1, 2}, /* TX_EN */ + {0, 8, 1, 0, 1, 2}, /* TX_ER */ + {0, 15, 2, 0, 1, 2}, /* RX_DV */ + {0, 16, 2, 0, 1, 2}, /* RX_ER */ + {0, 0, 2, 0, 1, 2}, /* RX_CLK */ + {2, 9, 1, 0, 3, 2}, /* GTX_CLK - CLK10 */ + {2, 8, 2, 0, 1, 2}, /* GTX125 - CLK9 */ /* GETH2 */ - {0, 17, 1, 0, 1}, /* TxD0 */ - {0, 18, 1, 0, 1}, /* TxD1 */ - {0, 19, 1, 0, 1}, /* TxD2 */ - {0, 20, 1, 0, 1}, /* TxD3 */ - {1, 2, 1, 0, 1}, /* TxD4 */ - {1, 3, 1, 0, 2}, /* TxD5 */ - {1, 5, 1, 0, 3}, /* TxD6 */ - {1, 8, 1, 0, 3}, /* TxD7 */ - {0, 23, 2, 0, 1}, /* RxD0 */ - {0, 24, 2, 0, 1}, /* RxD1 */ - {0, 25, 2, 0, 1}, /* RxD2 */ - {0, 26, 2, 0, 1}, /* RxD3 */ - {0, 27, 2, 0, 1}, /* RxD4 */ - {1, 12, 2, 0, 2}, /* RxD5 */ - {1, 13, 2, 0, 3}, /* RxD6 */ - {1, 11, 2, 0, 2}, /* RxD7 */ - {0, 21, 1, 0, 1}, /* TX_EN */ - {0, 22, 1, 0, 1}, /* TX_ER */ - {0, 29, 2, 0, 1}, /* RX_DV */ - {0, 30, 2, 0, 1}, /* RX_ER */ - {0, 31, 2, 0, 1}, /* RX_CLK */ - {2, 2, 1, 0, 2}, /* GTX_CLK = CLK10 */ - {2, 3, 2, 0, 1}, /* GTX125 - CLK4 */ - - {0, 1, 3, 0, 2}, /* MDIO */ - {0, 2, 1, 0, 1}, /* MDC */ - - {5, 0, 1, 0, 2}, /* UART2_SOUT */ - {5, 1, 2, 0, 3}, /* UART2_CTS */ - {5, 2, 1, 0, 1}, /* UART2_RTS */ - {5, 3, 2, 0, 2}, /* UART2_SIN */ + {0, 17, 1, 0, 1, 2}, /* TxD0 */ + {0, 18, 1, 0, 1, 2}, /* TxD1 */ + {0, 19, 1, 0, 1, 2}, /* TxD2 */ + {0, 20, 1, 0, 1, 2}, /* TxD3 */ + {1, 2, 1, 0, 1, 2}, /* TxD4 */ + {1, 3, 1, 0, 2, 2}, /* TxD5 */ + {1, 5, 1, 0, 3, 2}, /* TxD6 */ + {1, 8, 1, 0, 3, 2}, /* TxD7 */ + {0, 23, 2, 0, 1, 2}, /* RxD0 */ + {0, 24, 2, 0, 1, 2}, /* RxD1 */ + {0, 25, 2, 0, 1, 2}, /* RxD2 */ + {0, 26, 2, 0, 1, 2}, /* RxD3 */ + {0, 27, 2, 0, 1, 2}, /* RxD4 */ + {1, 12, 2, 0, 2, 2}, /* RxD5 */ + {1, 13, 2, 0, 3, 2}, /* RxD6 */ + {1, 11, 2, 0, 2, 2}, /* RxD7 */ + {0, 21, 1, 0, 1, 2}, /* TX_EN */ + {0, 22, 1, 0, 1, 2}, /* TX_ER */ + {0, 29, 2, 0, 1, 2}, /* RX_DV */ + {0, 30, 2, 0, 1, 2}, /* RX_ER */ + {0, 31, 2, 0, 1, 2}, /* RX_CLK */ + {2, 2, 1, 0, 2, 2}, /* GTX_CLK = CLK10 */ + {2, 3, 2, 0, 1, 2}, /* GTX125 - CLK4 */ + + {0, 1, 3, 0, 2, 2}, /* MDIO */ + {0, 2, 1, 0, 1, 2}, /* MDC */ + + {5, 0, 1, 0, 2, 2}, /* UART2_SOUT */ + {5, 1, 2, 0, 3, 2}, /* UART2_CTS */ + {5, 2, 1, 0, 1, 2}, /* UART2_RTS */ + {5, 3, 2, 0, 2, 2}, /* UART2_SIN */
- {0, 0, 0, 0, QE_IOP_TAB_END}, /* END of table */ + {0, 0, 0, 0, QE_IOP_TAB_END, 2}, /* END of table */ };
const qe_iop_conf_t qe_iop_conf_tab[] = { /* MDIO */ - {0, 1, 3, 0, 2}, /* MDIO */ - {0, 2, 1, 0, 1}, /* MDC */ + {0, 1, 3, 0, 2, 2}, /* MDIO */ + {0, 2, 1, 0, 1, 2}, /* MDC */
/* UCC1 - UEC (Gigabit) */ - {0, 3, 1, 0, 1}, /* TxD0 */ - {0, 4, 1, 0, 1}, /* TxD1 */ - {0, 5, 1, 0, 1}, /* TxD2 */ - {0, 6, 1, 0, 1}, /* TxD3 */ - {0, 9, 2, 0, 1}, /* RxD0 */ - {0, 10, 2, 0, 1}, /* RxD1 */ - {0, 11, 2, 0, 1}, /* RxD2 */ - {0, 12, 2, 0, 1}, /* RxD3 */ - {0, 7, 1, 0, 1}, /* TX_EN */ - {0, 8, 1, 0, 1}, /* TX_ER */ - {0, 15, 2, 0, 1}, /* RX_DV */ - {0, 0, 2, 0, 1}, /* RX_CLK */ - {2, 9, 1, 0, 3}, /* GTX_CLK - CLK10 */ - {2, 8, 2, 0, 1}, /* GTX125 - CLK9 */ + {0, 3, 1, 0, 1, 2}, /* TxD0 */ + {0, 4, 1, 0, 1, 2}, /* TxD1 */ + {0, 5, 1, 0, 1, 2}, /* TxD2 */ + {0, 6, 1, 0, 1, 2}, /* TxD3 */ + {0, 9, 2, 0, 1, 2}, /* RxD0 */ + {0, 10, 2, 0, 1, 2}, /* RxD1 */ + {0, 11, 2, 0, 1, 2}, /* RxD2 */ + {0, 12, 2, 0, 1, 2}, /* RxD3 */ + {0, 7, 1, 0, 1, 2}, /* TX_EN */ + {0, 8, 1, 0, 1, 2}, /* TX_ER */ + {0, 15, 2, 0, 1, 2}, /* RX_DV */ + {0, 0, 2, 0, 1, 2}, /* RX_CLK */ + {2, 9, 1, 0, 3, 2}, /* GTX_CLK - CLK10 */ + {2, 8, 2, 0, 1, 2}, /* GTX125 - CLK9 */
/* UCC2 - UEC (Gigabit) */ - {0, 17, 1, 0, 1}, /* TxD0 */ - {0, 18, 1, 0, 1}, /* TxD1 */ - {0, 19, 1, 0, 1}, /* TxD2 */ - {0, 20, 1, 0, 1}, /* TxD3 */ - {0, 23, 2, 0, 1}, /* RxD0 */ - {0, 24, 2, 0, 1}, /* RxD1 */ - {0, 25, 2, 0, 1}, /* RxD2 */ - {0, 26, 2, 0, 1}, /* RxD3 */ - {0, 21, 1, 0, 1}, /* TX_EN */ - {0, 22, 1, 0, 1}, /* TX_ER */ - {0, 29, 2, 0, 1}, /* RX_DV */ - {0, 31, 2, 0, 1}, /* RX_CLK */ - {2, 2, 1, 0, 2}, /* GTX_CLK - CLK10 */ - {2, 3, 2, 0, 1}, /* GTX125 - CLK4 */ + {0, 17, 1, 0, 1, 2}, /* TxD0 */ + {0, 18, 1, 0, 1, 2}, /* TxD1 */ + {0, 19, 1, 0, 1, 2}, /* TxD2 */ + {0, 20, 1, 0, 1, 2}, /* TxD3 */ + {0, 23, 2, 0, 1, 2}, /* RxD0 */ + {0, 24, 2, 0, 1, 2}, /* RxD1 */ + {0, 25, 2, 0, 1, 2}, /* RxD2 */ + {0, 26, 2, 0, 1, 2}, /* RxD3 */ + {0, 21, 1, 0, 1, 2}, /* TX_EN */ + {0, 22, 1, 0, 1, 2}, /* TX_ER */ + {0, 29, 2, 0, 1, 2}, /* RX_DV */ + {0, 31, 2, 0, 1, 2}, /* RX_CLK */ + {2, 2, 1, 0, 2, 2}, /* GTX_CLK - CLK10 */ + {2, 3, 2, 0, 1, 2}, /* GTX125 - CLK4 */
/* UCC7 - UEC */ - {4, 0, 1, 0, 1}, /* TxD0 */ - {4, 1, 1, 0, 1}, /* TxD1 */ - {4, 2, 1, 0, 1}, /* TxD2 */ - {4, 3, 1, 0, 1}, /* TxD3 */ - {4, 6, 2, 0, 1}, /* RxD0 */ - {4, 7, 2, 0, 1}, /* RxD1 */ - {4, 8, 2, 0, 1}, /* RxD2 */ - {4, 9, 2, 0, 1}, /* RxD3 */ - {4, 4, 1, 0, 1}, /* TX_EN */ - {4, 5, 1, 0, 1}, /* TX_ER */ - {4, 12, 2, 0, 1}, /* RX_DV */ - {4, 13, 2, 0, 1}, /* RX_ER */ - {4, 10, 2, 0, 1}, /* COL */ - {4, 11, 2, 0, 1}, /* CRS */ - {2, 18, 2, 0, 1}, /* TX_CLK - CLK19 */ - {2, 19, 2, 0, 1}, /* RX_CLK - CLK20 */ + {4, 0, 1, 0, 1, 2}, /* TxD0 */ + {4, 1, 1, 0, 1, 2}, /* TxD1 */ + {4, 2, 1, 0, 1, 2}, /* TxD2 */ + {4, 3, 1, 0, 1, 2}, /* TxD3 */ + {4, 6, 2, 0, 1, 2}, /* RxD0 */ + {4, 7, 2, 0, 1, 2}, /* RxD1 */ + {4, 8, 2, 0, 1, 2}, /* RxD2 */ + {4, 9, 2, 0, 1, 2}, /* RxD3 */ + {4, 4, 1, 0, 1, 2}, /* TX_EN */ + {4, 5, 1, 0, 1, 2}, /* TX_ER */ + {4, 12, 2, 0, 1, 2}, /* RX_DV */ + {4, 13, 2, 0, 1, 2}, /* RX_ER */ + {4, 10, 2, 0, 1, 2}, /* COL */ + {4, 11, 2, 0, 1, 2}, /* CRS */ + {2, 18, 2, 0, 1, 2}, /* TX_CLK - CLK19 */ + {2, 19, 2, 0, 1, 2}, /* RX_CLK - CLK20 */
/* UCC4 - UEC */ - {1, 14, 1, 0, 1}, /* TxD0 */ - {1, 15, 1, 0, 1}, /* TxD1 */ - {1, 16, 1, 0, 1}, /* TxD2 */ - {1, 17, 1, 0, 1}, /* TxD3 */ - {1, 20, 2, 0, 1}, /* RxD0 */ - {1, 21, 2, 0, 1}, /* RxD1 */ - {1, 22, 2, 0, 1}, /* RxD2 */ - {1, 23, 2, 0, 1}, /* RxD3 */ - {1, 18, 1, 0, 1}, /* TX_EN */ - {1, 19, 1, 0, 2}, /* TX_ER */ - {1, 26, 2, 0, 1}, /* RX_DV */ - {1, 27, 2, 0, 1}, /* RX_ER */ - {1, 24, 2, 0, 1}, /* COL */ - {1, 25, 2, 0, 1}, /* CRS */ - {2, 6, 2, 0, 1}, /* TX_CLK - CLK7 */ - {2, 7, 2, 0, 1}, /* RX_CLK - CLK8 */ + {1, 14, 1, 0, 1, 2}, /* TxD0 */ + {1, 15, 1, 0, 1, 2}, /* TxD1 */ + {1, 16, 1, 0, 1, 2}, /* TxD2 */ + {1, 17, 1, 0, 1, 2}, /* TxD3 */ + {1, 20, 2, 0, 1, 2}, /* RxD0 */ + {1, 21, 2, 0, 1, 2}, /* RxD1 */ + {1, 22, 2, 0, 1, 2}, /* RxD2 */ + {1, 23, 2, 0, 1, 2}, /* RxD3 */ + {1, 18, 1, 0, 1, 2}, /* TX_EN */ + {1, 19, 1, 0, 2, 2}, /* TX_ER */ + {1, 26, 2, 0, 1, 2}, /* RX_DV */ + {1, 27, 2, 0, 1, 2}, /* RX_ER */ + {1, 24, 2, 0, 1, 2}, /* COL */ + {1, 25, 2, 0, 1, 2}, /* CRS */ + {2, 6, 2, 0, 1, 2}, /* TX_CLK - CLK7 */ + {2, 7, 2, 0, 1, 2}, /* RX_CLK - CLK8 */
/* PCI1 */ - {5, 4, 2, 0, 3}, /* PCI_M66EN */ - {5, 5, 1, 0, 3}, /* PCI_INTA */ - {5, 6, 1, 0, 3}, /* PCI_RSTO */ - {5, 7, 3, 0, 3}, /* PCI_C_BE0 */ - {5, 8, 3, 0, 3}, /* PCI_C_BE1 */ - {5, 9, 3, 0, 3}, /* PCI_C_BE2 */ - {5, 10, 3, 0, 3}, /* PCI_C_BE3 */ - {5, 11, 3, 0, 3}, /* PCI_PAR */ - {5, 12, 3, 0, 3}, /* PCI_FRAME */ - {5, 13, 3, 0, 3}, /* PCI_TRDY */ - {5, 14, 3, 0, 3}, /* PCI_IRDY */ - {5, 15, 3, 0, 3}, /* PCI_STOP */ - {5, 16, 3, 0, 3}, /* PCI_DEVSEL */ - {5, 17, 0, 0, 0}, /* PCI_IDSEL */ - {5, 18, 3, 0, 3}, /* PCI_SERR */ - {5, 19, 3, 0, 3}, /* PCI_PERR */ - {5, 20, 3, 0, 3}, /* PCI_REQ0 */ - {5, 21, 2, 0, 3}, /* PCI_REQ1 */ - {5, 22, 2, 0, 3}, /* PCI_GNT2 */ - {5, 23, 3, 0, 3}, /* PCI_GNT0 */ - {5, 24, 1, 0, 3}, /* PCI_GNT1 */ - {5, 25, 1, 0, 3}, /* PCI_GNT2 */ - {5, 26, 0, 0, 0}, /* PCI_CLK0 */ - {5, 27, 0, 0, 0}, /* PCI_CLK1 */ - {5, 28, 0, 0, 0}, /* PCI_CLK2 */ - {5, 29, 0, 0, 3}, /* PCI_SYNC_OUT */ - {6, 0, 3, 0, 3}, /* PCI_AD0 */ - {6, 1, 3, 0, 3}, /* PCI_AD1 */ - {6, 2, 3, 0, 3}, /* PCI_AD2 */ - {6, 3, 3, 0, 3}, /* PCI_AD3 */ - {6, 4, 3, 0, 3}, /* PCI_AD4 */ - {6, 5, 3, 0, 3}, /* PCI_AD5 */ - {6, 6, 3, 0, 3}, /* PCI_AD6 */ - {6, 7, 3, 0, 3}, /* PCI_AD7 */ - {6, 8, 3, 0, 3}, /* PCI_AD8 */ - {6, 9, 3, 0, 3}, /* PCI_AD9 */ - {6, 10, 3, 0, 3}, /* PCI_AD10 */ - {6, 11, 3, 0, 3}, /* PCI_AD11 */ - {6, 12, 3, 0, 3}, /* PCI_AD12 */ - {6, 13, 3, 0, 3}, /* PCI_AD13 */ - {6, 14, 3, 0, 3}, /* PCI_AD14 */ - {6, 15, 3, 0, 3}, /* PCI_AD15 */ - {6, 16, 3, 0, 3}, /* PCI_AD16 */ - {6, 17, 3, 0, 3}, /* PCI_AD17 */ - {6, 18, 3, 0, 3}, /* PCI_AD18 */ - {6, 19, 3, 0, 3}, /* PCI_AD19 */ - {6, 20, 3, 0, 3}, /* PCI_AD20 */ - {6, 21, 3, 0, 3}, /* PCI_AD21 */ - {6, 22, 3, 0, 3}, /* PCI_AD22 */ - {6, 23, 3, 0, 3}, /* PCI_AD23 */ - {6, 24, 3, 0, 3}, /* PCI_AD24 */ - {6, 25, 3, 0, 3}, /* PCI_AD25 */ - {6, 26, 3, 0, 3}, /* PCI_AD26 */ - {6, 27, 3, 0, 3}, /* PCI_AD27 */ - {6, 28, 3, 0, 3}, /* PCI_AD28 */ - {6, 29, 3, 0, 3}, /* PCI_AD29 */ - {6, 30, 3, 0, 3}, /* PCI_AD30 */ - {6, 31, 3, 0, 3}, /* PCI_AD31 */ + {5, 4, 2, 0, 3, 2}, /* PCI_M66EN */ + {5, 5, 1, 0, 3, 2}, /* PCI_INTA */ + {5, 6, 1, 0, 3, 2}, /* PCI_RSTO */ + {5, 7, 3, 0, 3, 2}, /* PCI_C_BE0 */ + {5, 8, 3, 0, 3, 2}, /* PCI_C_BE1 */ + {5, 9, 3, 0, 3, 2}, /* PCI_C_BE2 */ + {5, 10, 3, 0, 3, 2}, /* PCI_C_BE3 */ + {5, 11, 3, 0, 3, 2}, /* PCI_PAR */ + {5, 12, 3, 0, 3, 2}, /* PCI_FRAME */ + {5, 13, 3, 0, 3, 2}, /* PCI_TRDY */ + {5, 14, 3, 0, 3, 2}, /* PCI_IRDY */ + {5, 15, 3, 0, 3, 2}, /* PCI_STOP */ + {5, 16, 3, 0, 3, 2}, /* PCI_DEVSEL */ + {5, 17, 0, 0, 0, 2}, /* PCI_IDSEL */ + {5, 18, 3, 0, 3, 2}, /* PCI_SERR */ + {5, 19, 3, 0, 3, 2}, /* PCI_PERR */ + {5, 20, 3, 0, 3, 2}, /* PCI_REQ0 */ + {5, 21, 2, 0, 3, 2}, /* PCI_REQ1 */ + {5, 22, 2, 0, 3, 2}, /* PCI_GNT2 */ + {5, 23, 3, 0, 3, 2}, /* PCI_GNT0 */ + {5, 24, 1, 0, 3, 2}, /* PCI_GNT1 */ + {5, 25, 1, 0, 3, 2}, /* PCI_GNT2 */ + {5, 26, 0, 0, 0, 2}, /* PCI_CLK0 */ + {5, 27, 0, 0, 0, 2}, /* PCI_CLK1 */ + {5, 28, 0, 0, 0, 2}, /* PCI_CLK2 */ + {5, 29, 0, 0, 3, 2}, /* PCI_SYNC_OUT */ + {6, 0, 3, 0, 3, 2}, /* PCI_AD0 */ + {6, 1, 3, 0, 3, 2}, /* PCI_AD1 */ + {6, 2, 3, 0, 3, 2}, /* PCI_AD2 */ + {6, 3, 3, 0, 3, 2}, /* PCI_AD3 */ + {6, 4, 3, 0, 3, 2}, /* PCI_AD4 */ + {6, 5, 3, 0, 3, 2}, /* PCI_AD5 */ + {6, 6, 3, 0, 3, 2}, /* PCI_AD6 */ + {6, 7, 3, 0, 3, 2}, /* PCI_AD7 */ + {6, 8, 3, 0, 3, 2}, /* PCI_AD8 */ + {6, 9, 3, 0, 3, 2}, /* PCI_AD9 */ + {6, 10, 3, 0, 3, 2}, /* PCI_AD10 */ + {6, 11, 3, 0, 3, 2}, /* PCI_AD11 */ + {6, 12, 3, 0, 3, 2}, /* PCI_AD12 */ + {6, 13, 3, 0, 3, 2}, /* PCI_AD13 */ + {6, 14, 3, 0, 3, 2}, /* PCI_AD14 */ + {6, 15, 3, 0, 3, 2}, /* PCI_AD15 */ + {6, 16, 3, 0, 3, 2}, /* PCI_AD16 */ + {6, 17, 3, 0, 3, 2}, /* PCI_AD17 */ + {6, 18, 3, 0, 3, 2}, /* PCI_AD18 */ + {6, 19, 3, 0, 3, 2}, /* PCI_AD19 */ + {6, 20, 3, 0, 3, 2}, /* PCI_AD20 */ + {6, 21, 3, 0, 3, 2}, /* PCI_AD21 */ + {6, 22, 3, 0, 3, 2}, /* PCI_AD22 */ + {6, 23, 3, 0, 3, 2}, /* PCI_AD23 */ + {6, 24, 3, 0, 3, 2}, /* PCI_AD24 */ + {6, 25, 3, 0, 3, 2}, /* PCI_AD25 */ + {6, 26, 3, 0, 3, 2}, /* PCI_AD26 */ + {6, 27, 3, 0, 3, 2}, /* PCI_AD27 */ + {6, 28, 3, 0, 3, 2}, /* PCI_AD28 */ + {6, 29, 3, 0, 3, 2}, /* PCI_AD29 */ + {6, 30, 3, 0, 3, 2}, /* PCI_AD30 */ + {6, 31, 3, 0, 3, 2}, /* PCI_AD31 */
/* NAND */ - {4, 18, 2, 0, 0}, /* NAND_RYnBY */ + {4, 18, 2, 0, 0, 2}, /* NAND_RYnBY */
/* DUART - UART2 */ - {5, 0, 1, 0, 2}, /* UART2_SOUT */ - {5, 2, 1, 0, 1}, /* UART2_RTS */ - {5, 3, 2, 0, 2}, /* UART2_SIN */ - {5, 1, 2, 0, 3}, /* UART2_CTS */ + {5, 0, 1, 0, 2, 2}, /* UART2_SOUT */ + {5, 2, 1, 0, 1, 2}, /* UART2_RTS */ + {5, 3, 2, 0, 2, 2}, /* UART2_SIN */ + {5, 1, 2, 0, 3, 2}, /* UART2_CTS */
/* UCC5 - UART3 */ - {3, 0, 1, 0, 1}, /* UART3_TX */ - {3, 4, 1, 0, 1}, /* UART3_RTS */ - {3, 6, 2, 0, 1}, /* UART3_RX */ - {3, 12, 2, 0, 0}, /* UART3_CTS */ - {3, 13, 2, 0, 0}, /* UCC5_CD */ + {3, 0, 1, 0, 1, 2}, /* UART3_TX */ + {3, 4, 1, 0, 1, 2}, /* UART3_RTS */ + {3, 6, 2, 0, 1, 2}, /* UART3_RX */ + {3, 12, 2, 0, 0, 2}, /* UART3_CTS */ + {3, 13, 2, 0, 0, 2}, /* UCC5_CD */
/* UCC6 - UART4 */ - {3, 14, 1, 0, 1}, /* UART4_TX */ - {3, 18, 1, 0, 1}, /* UART4_RTS */ - {3, 20, 2, 0, 1}, /* UART4_RX */ - {3, 26, 2, 0, 0}, /* UART4_CTS */ - {3, 27, 2, 0, 0}, /* UCC6_CD */ + {3, 14, 1, 0, 1, 2}, /* UART4_TX */ + {3, 18, 1, 0, 1, 2}, /* UART4_RTS */ + {3, 20, 2, 0, 1, 2}, /* UART4_RX */ + {3, 26, 2, 0, 0, 2}, /* UART4_CTS */ + {3, 27, 2, 0, 0, 2}, /* UCC6_CD */
/* Fujitsu MB86277 (MINT) graphics controller */ - {0, 30, 1, 0, 0}, /* nSRESET_GRAPHICS */ - {1, 5, 1, 0, 0}, /* nXRST_GRAPHICS */ - {1, 7, 1, 0, 0}, /* LVDS_BKLT_CTR */ - {2, 16, 1, 0, 0}, /* LVDS_BKLT_EN */ + {0, 30, 1, 0, 0, 2}, /* nSRESET_GRAPHICS */ + {1, 5, 1, 0, 0, 2}, /* nXRST_GRAPHICS */ + {1, 7, 1, 0, 0, 2}, /* LVDS_BKLT_CTR */ + {2, 16, 1, 0, 0, 2}, /* LVDS_BKLT_EN */
/* END of table */ - {0, 0, 0, 0, QE_IOP_TAB_END}, + {0, 0, 0, 0, QE_IOP_TAB_END, 2}, };
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ - {4, 10, 1, 0, 2}, /* TxD0 */ - {4, 9, 1, 0, 2}, /* TxD1 */ - {4, 8, 1, 0, 2}, /* TxD2 */ - {4, 7, 1, 0, 2}, /* TxD3 */ - {4, 23, 1, 0, 2}, /* TxD4 */ - {4, 22, 1, 0, 2}, /* TxD5 */ - {4, 21, 1, 0, 2}, /* TxD6 */ - {4, 20, 1, 0, 2}, /* TxD7 */ - {4, 15, 2, 0, 2}, /* RxD0 */ - {4, 14, 2, 0, 2}, /* RxD1 */ - {4, 13, 2, 0, 2}, /* RxD2 */ - {4, 12, 2, 0, 2}, /* RxD3 */ - {4, 29, 2, 0, 2}, /* RxD4 */ - {4, 28, 2, 0, 2}, /* RxD5 */ - {4, 27, 2, 0, 2}, /* RxD6 */ - {4, 26, 2, 0, 2}, /* RxD7 */ - {4, 11, 1, 0, 2}, /* TX_EN */ - {4, 24, 1, 0, 2}, /* TX_ER */ - {4, 16, 2, 0, 2}, /* RX_DV */ - {4, 30, 2, 0, 2}, /* RX_ER */ - {4, 17, 2, 0, 2}, /* RX_CLK */ - {4, 19, 1, 0, 2}, /* GTX_CLK */ - {1, 31, 2, 0, 3}, /* GTX125 */ + {4, 10, 1, 0, 2, 2}, /* TxD0 */ + {4, 9, 1, 0, 2, 2}, /* TxD1 */ + {4, 8, 1, 0, 2, 2}, /* TxD2 */ + {4, 7, 1, 0, 2, 2}, /* TxD3 */ + {4, 23, 1, 0, 2, 2}, /* TxD4 */ + {4, 22, 1, 0, 2, 2}, /* TxD5 */ + {4, 21, 1, 0, 2, 2}, /* TxD6 */ + {4, 20, 1, 0, 2, 2}, /* TxD7 */ + {4, 15, 2, 0, 2, 2}, /* RxD0 */ + {4, 14, 2, 0, 2, 2}, /* RxD1 */ + {4, 13, 2, 0, 2, 2}, /* RxD2 */ + {4, 12, 2, 0, 2, 2}, /* RxD3 */ + {4, 29, 2, 0, 2, 2}, /* RxD4 */ + {4, 28, 2, 0, 2, 2}, /* RxD5 */ + {4, 27, 2, 0, 2, 2}, /* RxD6 */ + {4, 26, 2, 0, 2, 2}, /* RxD7 */ + {4, 11, 1, 0, 2, 2}, /* TX_EN */ + {4, 24, 1, 0, 2, 2}, /* TX_ER */ + {4, 16, 2, 0, 2, 2}, /* RX_DV */ + {4, 30, 2, 0, 2, 2}, /* RX_ER */ + {4, 17, 2, 0, 2, 2}, /* RX_CLK */ + {4, 19, 1, 0, 2, 2}, /* GTX_CLK */ + {1, 31, 2, 0, 3, 2}, /* GTX125 */
/* GETH2 */ - {5, 10, 1, 0, 2}, /* TxD0 */ - {5, 9, 1, 0, 2}, /* TxD1 */ - {5, 8, 1, 0, 2}, /* TxD2 */ - {5, 7, 1, 0, 2}, /* TxD3 */ - {5, 23, 1, 0, 2}, /* TxD4 */ - {5, 22, 1, 0, 2}, /* TxD5 */ - {5, 21, 1, 0, 2}, /* TxD6 */ - {5, 20, 1, 0, 2}, /* TxD7 */ - {5, 15, 2, 0, 2}, /* RxD0 */ - {5, 14, 2, 0, 2}, /* RxD1 */ - {5, 13, 2, 0, 2}, /* RxD2 */ - {5, 12, 2, 0, 2}, /* RxD3 */ - {5, 29, 2, 0, 2}, /* RxD4 */ - {5, 28, 2, 0, 2}, /* RxD5 */ - {5, 27, 2, 0, 3}, /* RxD6 */ - {5, 26, 2, 0, 2}, /* RxD7 */ - {5, 11, 1, 0, 2}, /* TX_EN */ - {5, 24, 1, 0, 2}, /* TX_ER */ - {5, 16, 2, 0, 2}, /* RX_DV */ - {5, 30, 2, 0, 2}, /* RX_ER */ - {5, 17, 2, 0, 2}, /* RX_CLK */ - {5, 19, 1, 0, 2}, /* GTX_CLK */ - {1, 31, 2, 0, 3}, /* GTX125 */ - {4, 6, 3, 0, 2}, /* MDIO */ - {4, 5, 1, 0, 2}, /* MDC */ + {5, 10, 1, 0, 2, 2}, /* TxD0 */ + {5, 9, 1, 0, 2, 2}, /* TxD1 */ + {5, 8, 1, 0, 2, 2}, /* TxD2 */ + {5, 7, 1, 0, 2, 2}, /* TxD3 */ + {5, 23, 1, 0, 2, 2}, /* TxD4 */ + {5, 22, 1, 0, 2, 2}, /* TxD5 */ + {5, 21, 1, 0, 2, 2}, /* TxD6 */ + {5, 20, 1, 0, 2, 2}, /* TxD7 */ + {5, 15, 2, 0, 2, 2}, /* RxD0 */ + {5, 14, 2, 0, 2, 2}, /* RxD1 */ + {5, 13, 2, 0, 2, 2}, /* RxD2 */ + {5, 12, 2, 0, 2, 2}, /* RxD3 */ + {5, 29, 2, 0, 2, 2}, /* RxD4 */ + {5, 28, 2, 0, 2, 2}, /* RxD5 */ + {5, 27, 2, 0, 3, 2}, /* RxD6 */ + {5, 26, 2, 0, 2, 2}, /* RxD7 */ + {5, 11, 1, 0, 2, 2}, /* TX_EN */ + {5, 24, 1, 0, 2, 2}, /* TX_ER */ + {5, 16, 2, 0, 2, 2}, /* RX_DV */ + {5, 30, 2, 0, 2, 2}, /* RX_ER */ + {5, 17, 2, 0, 2, 2}, /* RX_CLK */ + {5, 19, 1, 0, 2, 2}, /* GTX_CLK */ + {1, 31, 2, 0, 3, 2}, /* GTX125 */ + {4, 6, 3, 0, 2, 2}, /* MDIO */ + {4, 5, 1, 0, 2, 2}, /* MDC */
/* UART1 */ - {2, 0, 1, 0, 2}, /* UART_SOUT1 */ - {2, 1, 1, 0, 2}, /* UART_RTS1 */ - {2, 2, 2, 0, 2}, /* UART_CTS1 */ - {2, 3, 2, 0, 2}, /* UART_SIN1 */ + {2, 0, 1, 0, 2, 2}, /* UART_SOUT1 */ + {2, 1, 1, 0, 2, 2}, /* UART_RTS1 */ + {2, 2, 2, 0, 2, 2}, /* UART_CTS1 */ + {2, 3, 2, 0, 2, 2}, /* UART_SIN1 */
const qe_iop_conf_t qe_iop_conf_tab[] = { /* UCC3 */ - {1, 0, 1, 0, 1}, /* TxD0 */ - {1, 1, 1, 0, 1}, /* TxD1 */ - {1, 2, 1, 0, 1}, /* TxD2 */ - {1, 3, 1, 0, 1}, /* TxD3 */ - {1, 9, 1, 0, 1}, /* TxER */ - {1, 12, 1, 0, 1}, /* TxEN */ - {3, 24, 2, 0, 1}, /* TxCLK->CLK10 */ - - {1, 4, 2, 0, 1}, /* RxD0 */ - {1, 5, 2, 0, 1}, /* RxD1 */ - {1, 6, 2, 0, 1}, /* RxD2 */ - {1, 7, 2, 0, 1}, /* RxD3 */ - {1, 8, 2, 0, 1}, /* RxER */ - {1, 10, 2, 0, 1}, /* RxDV */ - {0, 13, 2, 0, 1}, /* RxCLK->CLK9 */ - {1, 11, 2, 0, 1}, /* COL */ - {1, 13, 2, 0, 1}, /* CRS */ + {1, 0, 1, 0, 1, 2}, /* TxD0 */ + {1, 1, 1, 0, 1, 2}, /* TxD1 */ + {1, 2, 1, 0, 1, 2}, /* TxD2 */ + {1, 3, 1, 0, 1, 2}, /* TxD3 */ + {1, 9, 1, 0, 1, 2}, /* TxER */ + {1, 12, 1, 0, 1, 2}, /* TxEN */ + {3, 24, 2, 0, 1, 2}, /* TxCLK->CLK10 */ + + {1, 4, 2, 0, 1, 2}, /* RxD0 */ + {1, 5, 2, 0, 1, 2}, /* RxD1 */ + {1, 6, 2, 0, 1, 2}, /* RxD2 */ + {1, 7, 2, 0, 1, 2}, /* RxD3 */ + {1, 8, 2, 0, 1, 2}, /* RxER */ + {1, 10, 2, 0, 1, 2}, /* RxDV */ + {0, 13, 2, 0, 1, 2}, /* RxCLK->CLK9 */ + {1, 11, 2, 0, 1, 2}, /* COL */ + {1, 13, 2, 0, 1, 2}, /* CRS */
/* UCC2 */ - {0, 18, 1, 0, 1}, /* TxD0 */ - {0, 19, 1, 0, 1}, /* TxD1 */ - {0, 20, 1, 0, 1}, /* TxD2 */ - {0, 21, 1, 0, 1}, /* TxD3 */ - {0, 27, 1, 0, 1}, /* TxER */ - {0, 30, 1, 0, 1}, /* TxEN */ - {3, 23, 2, 0, 1}, /* TxCLK->CLK3 */ - - {0, 22, 2, 0, 1}, /* RxD0 */ - {0, 23, 2, 0, 1}, /* RxD1 */ - {0, 24, 2, 0, 1}, /* RxD2 */ - {0, 25, 2, 0, 1}, /* RxD3 */ - {0, 26, 1, 0, 1}, /* RxER */ - {0, 28, 2, 0, 1}, /* Rx_DV */ - {3, 21, 2, 0, 1}, /* RxCLK->CLK16 */ - {0, 29, 2, 0, 1}, /* COL */ - {0, 31, 2, 0, 1}, /* CRS */ + {0, 18, 1, 0, 1, 2}, /* TxD0 */ + {0, 19, 1, 0, 1, 2}, /* TxD1 */ + {0, 20, 1, 0, 1, 2}, /* TxD2 */ + {0, 21, 1, 0, 1, 2}, /* TxD3 */ + {0, 27, 1, 0, 1, 2}, /* TxER */ + {0, 30, 1, 0, 1, 2}, /* TxEN */ + {3, 23, 2, 0, 1, 2}, /* TxCLK->CLK3 */ + + {0, 22, 2, 0, 1, 2}, /* RxD0 */ + {0, 23, 2, 0, 1, 2}, /* RxD1 */ + {0, 24, 2, 0, 1, 2}, /* RxD2 */ + {0, 25, 2, 0, 1, 2}, /* RxD3 */ + {0, 26, 1, 0, 1, 2}, /* RxER */ + {0, 28, 2, 0, 1, 2}, /* Rx_DV */ + {3, 21, 2, 0, 1, 2}, /* RxCLK->CLK16 */ + {0, 29, 2, 0, 1, 2}, /* COL */ + {0, 31, 2, 0, 1, 2}, /* CRS */
- {3, 4, 3, 0, 2}, /* MDIO */ - {3, 5, 1, 0, 2}, /* MDC */ + {3, 4, 3, 0, 2, 2}, /* MDIO */ + {3, 5, 1, 0, 2, 2}, /* MDC */
const qe_iop_conf_t qe_iop_conf_tab[] = { /* ETH3 */ - {1, 0, 1, 0, 1}, /* TxD0 */ - {1, 1, 1, 0, 1}, /* TxD1 */ - {1, 2, 1, 0, 1}, /* TxD2 */ - {1, 3, 1, 0, 1}, /* TxD3 */ - {1, 9, 1, 0, 1}, /* TxER */ - {1, 12, 1, 0, 1}, /* TxEN */ - {3, 24, 2, 0, 1}, /* TxCLK->CLK10 */ - - {1, 4, 2, 0, 1}, /* RxD0 */ - {1, 5, 2, 0, 1}, /* RxD1 */ - {1, 6, 2, 0, 1}, /* RxD2 */ - {1, 7, 2, 0, 1}, /* RxD3 */ - {1, 8, 2, 0, 1}, /* RxER */ - {1, 10, 2, 0, 1}, /* RxDV */ - {0, 13, 2, 0, 1}, /* RxCLK->CLK9 */ - {1, 11, 2, 0, 1}, /* COL */ - {1, 13, 2, 0, 1}, /* CRS */ + {1, 0, 1, 0, 1, 2}, /* TxD0 */ + {1, 1, 1, 0, 1, 2}, /* TxD1 */ + {1, 2, 1, 0, 1, 2}, /* TxD2 */ + {1, 3, 1, 0, 1, 2}, /* TxD3 */ + {1, 9, 1, 0, 1, 2}, /* TxER */ + {1, 12, 1, 0, 1, 2}, /* TxEN */ + {3, 24, 2, 0, 1, 2}, /* TxCLK->CLK10 */ + + {1, 4, 2, 0, 1, 2}, /* RxD0 */ + {1, 5, 2, 0, 1, 2}, /* RxD1 */ + {1, 6, 2, 0, 1, 2}, /* RxD2 */ + {1, 7, 2, 0, 1, 2}, /* RxD3 */ + {1, 8, 2, 0, 1, 2}, /* RxER */ + {1, 10, 2, 0, 1, 2}, /* RxDV */ + {0, 13, 2, 0, 1, 2}, /* RxCLK->CLK9 */ + {1, 11, 2, 0, 1, 2}, /* COL */ + {1, 13, 2, 0, 1, 2}, /* CRS */
/* ETH4 */ - {1, 18, 1, 0, 1}, /* TxD0 */ - {1, 19, 1, 0, 1}, /* TxD1 */ - {1, 20, 1, 0, 1}, /* TxD2 */ - {1, 21, 1, 0, 1}, /* TxD3 */ - {1, 27, 1, 0, 1}, /* TxER */ - {1, 30, 1, 0, 1}, /* TxEN */ - {3, 6, 2, 0, 1}, /* TxCLK->CLK8 */ - - {1, 22, 2, 0, 1}, /* RxD0 */ - {1, 23, 2, 0, 1}, /* RxD1 */ - {1, 24, 2, 0, 1}, /* RxD2 */ - {1, 25, 2, 0, 1}, /* RxD3 */ - {1, 26, 1, 0, 1}, /* RxER */ - {1, 28, 2, 0, 1}, /* Rx_DV */ - {3, 31, 2, 0, 1}, /* RxCLK->CLK7 */ - {1, 29, 2, 0, 1}, /* COL */ - {1, 31, 2, 0, 1}, /* CRS */ + {1, 18, 1, 0, 1, 2}, /* TxD0 */ + {1, 19, 1, 0, 1, 2}, /* TxD1 */ + {1, 20, 1, 0, 1, 2}, /* TxD2 */ + {1, 21, 1, 0, 1, 2}, /* TxD3 */ + {1, 27, 1, 0, 1, 2}, /* TxER */ + {1, 30, 1, 0, 1, 2}, /* TxEN */ + {3, 6, 2, 0, 1, 2}, /* TxCLK->CLK8 */ + + {1, 22, 2, 0, 1, 2}, /* RxD0 */ + {1, 23, 2, 0, 1, 2}, /* RxD1 */ + {1, 24, 2, 0, 1, 2}, /* RxD2 */ + {1, 25, 2, 0, 1, 2}, /* RxD3 */ + {1, 26, 1, 0, 1, 2}, /* RxER */ + {1, 28, 2, 0, 1, 2}, /* Rx_DV */ + {3, 31, 2, 0, 1, 2}, /* RxCLK->CLK7 */ + {1, 29, 2, 0, 1, 2}, /* COL */ + {1, 31, 2, 0, 1, 2}, /* CRS */
Any feedback on this patch? Timur? Regards, David.
-----Original Message----- From: David Saada Sent: Sunday, January 20, 2008 11:37 AM To: u-boot-users@lists.sourceforge.net Cc: 'Timur Tabi' Subject: [PATCH v3] QE IO: Add initial data to pin configuration + read/write functions
to
GPIO
- int data;
} qe_iop_conf_t;
data);
} } #endif
int data)
- if ((data != 2) && /* Don't leave unchanged */
if (data)
tmp_val);
else
tmp_val);
- /* Caculate pin location and 2bit mask and dir */ pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-
(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS- (pin%(NUM_OF_PINS/2)+1)*2)); @@ -55,9 +70,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io[port].cpdir1, pin_2bit_dir | tmp_val); }
- u32 pin_1bit_mask;
- u32 tmp_val;
- volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR);
- volatile par_io_t *par_io = (volatile par_io_t *)
&(gur->qe_par_io);
- /* Read the data */
- *data = (tmp_val >> (NUM_OF_PINS - (pin+1))) & 0x1;
- u32 tmp_val;
&(gur->qe_par_io);
- /* Write the data */
- if (data)
- else
data);
} } #endif
int data)
qepio;
if (data)
pin_1bit_mask |
tmp_val);
else
~pin_1bit_mask &
tmp_val);
(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS- (pin%(NUM_OF_PINS/2)+1)*2)); @@ -54,9 +69,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io->ioport[port].dir1, pin_2bit_dir |
tmp_val);
- u32 tmp_val;
- volatile immap_t *im = (volatile immap_t *)CFG_IMMR;
- volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im-
qepio;
- tmp_val = in_be32(&par_io->ioport[port].pdat);
- u32 tmp_val;
qepio;
- if (data) {
tmp_val);
- } else {
tmp_val);
- {0, 3, 1, 0, 1, 2}, /* TxD0 */
- {0, 4, 1, 0, 1, 2}, /* TxD1 */
- {0, 5, 1, 0, 1, 2}, /* TxD2 */
- {0, 6, 1, 0, 1, 2}, /* TxD3 */
- {1, 6, 1, 0, 3, 2}, /* TxD4 */
- {1, 7, 1, 0, 1, 2}, /* TxD5 */
- {1, 9, 1, 0, 2, 2}, /* TxD6 */
- {1, 10, 1, 0, 2, 2}, /* TxD7 */
- {0, 9, 2, 0, 1, 2}, /* RxD0 */
- {0, 10, 2, 0, 1, 2}, /* RxD1 */
- {0, 11, 2, 0, 1, 2}, /* RxD2 */
- {0, 12, 2, 0, 1, 2}, /* RxD3 */
- {0, 13, 2, 0, 1, 2}, /* RxD4 */
- {1, 1, 2, 0, 2, 2}, /* RxD5 */
- {1, 0, 2, 0, 2, 2}, /* RxD6 */
- {1, 4, 2, 0, 2, 2}, /* RxD7 */
- {0, 7, 1, 0, 1, 2}, /* TX_EN */
- {0, 8, 1, 0, 1, 2}, /* TX_ER */
- {0, 15, 2, 0, 1, 2}, /* RX_DV */
- {0, 16, 2, 0, 1, 2}, /* RX_ER */
- {0, 0, 2, 0, 1, 2}, /* RX_CLK */
- {2, 9, 1, 0, 3, 2}, /* GTX_CLK - CLK10 */
- {2, 8, 2, 0, 1, 2}, /* GTX125 - CLK9 */ /* GETH2 */
- {0, 17, 1, 0, 1, 2}, /* TxD0 */
- {0, 18, 1, 0, 1, 2}, /* TxD1 */
- {0, 19, 1, 0, 1, 2}, /* TxD2 */
- {0, 20, 1, 0, 1, 2}, /* TxD3 */
- {1, 2, 1, 0, 1, 2}, /* TxD4 */
- {1, 3, 1, 0, 2, 2}, /* TxD5 */
- {1, 5, 1, 0, 3, 2}, /* TxD6 */
- {1, 8, 1, 0, 3, 2}, /* TxD7 */
- {0, 23, 2, 0, 1, 2}, /* RxD0 */
- {0, 24, 2, 0, 1, 2}, /* RxD1 */
- {0, 25, 2, 0, 1, 2}, /* RxD2 */
- {0, 26, 2, 0, 1, 2}, /* RxD3 */
- {0, 27, 2, 0, 1, 2}, /* RxD4 */
- {1, 12, 2, 0, 2, 2}, /* RxD5 */
- {1, 13, 2, 0, 3, 2}, /* RxD6 */
- {1, 11, 2, 0, 2, 2}, /* RxD7 */
- {0, 21, 1, 0, 1, 2}, /* TX_EN */
- {0, 22, 1, 0, 1, 2}, /* TX_ER */
- {0, 29, 2, 0, 1, 2}, /* RX_DV */
- {0, 30, 2, 0, 1, 2}, /* RX_ER */
- {0, 31, 2, 0, 1, 2}, /* RX_CLK */
- {2, 2, 1, 0, 2, 2}, /* GTX_CLK = CLK10 */
- {2, 3, 2, 0, 1, 2}, /* GTX125 - CLK4 */
- {0, 1, 3, 0, 2, 2}, /* MDIO */
- {0, 2, 1, 0, 1, 2}, /* MDC */
- {5, 0, 1, 0, 2, 2}, /* UART2_SOUT */
- {5, 1, 2, 0, 3, 2}, /* UART2_CTS */
- {5, 2, 1, 0, 1, 2}, /* UART2_RTS */
- {5, 3, 2, 0, 2, 2}, /* UART2_SIN */
- {0, 0, 0, 0, QE_IOP_TAB_END, 2}, /* END of table */
/* UCC7 - UEC */
/* UCC4 - UEC */
/* PCI1 */
/* NAND */
/* DUART - UART2 */
/* UCC5 - UART3 */
/* UCC6 - UART4 */
/* END of table */
/* GETH2 */
/* UART1 */
- {2, 0, 1, 0, 2, 2}, /* UART_SOUT1 */
- {2, 1, 1, 0, 2, 2}, /* UART_RTS1 */
- {2, 2, 2, 0, 2, 2}, /* UART_CTS1 */
- {2, 3, 2, 0, 2, 2}, /* UART_SIN1 */
/* UCC2 */
- {0, 18, 1, 0, 1, 2}, /* TxD0 */
- {0, 19, 1, 0, 1, 2}, /* TxD1 */
- {0, 20, 1, 0, 1, 2}, /* TxD2 */
- {0, 21, 1, 0, 1, 2}, /* TxD3 */
- {0, 27, 1, 0, 1, 2}, /* TxER */
- {0, 30, 1, 0, 1, 2}, /* TxEN */
- {3, 23, 2, 0, 1, 2}, /* TxCLK->CLK3 */
- {0, 22, 2, 0, 1, 2}, /* RxD0 */
- {0, 23, 2, 0, 1, 2}, /* RxD1 */
- {0, 24, 2, 0, 1, 2}, /* RxD2 */
- {0, 25, 2, 0, 1, 2}, /* RxD3 */
- {0, 26, 1, 0, 1, 2}, /* RxER */
- {0, 28, 2, 0, 1, 2}, /* Rx_DV */
- {3, 21, 2, 0, 1, 2}, /* RxCLK->CLK16 */
- {0, 29, 2, 0, 1, 2}, /* COL */
- {0, 31, 2, 0, 1, 2}, /* CRS */
- {3, 4, 3, 0, 2, 2}, /* MDIO */
- {3, 5, 1, 0, 2, 2}, /* MDC */
/* ETH4 */
- {1, 18, 1, 0, 1, 2}, /* TxD0 */
- {1, 19, 1, 0, 1, 2}, /* TxD1 */
- {1, 20, 1, 0, 1, 2}, /* TxD2 */
- {1, 21, 1, 0, 1, 2}, /* TxD3 */
- {1, 27, 1, 0, 1, 2}, /* TxER */
- {1, 30, 1, 0, 1, 2}, /* TxEN */
- {3, 6, 2, 0, 1, 2}, /* TxCLK->CLK8 */
- {1, 22, 2, 0, 1, 2}, /* RxD0 */
- {1, 23, 2, 0, 1, 2}, /* RxD1 */
- {1, 24, 2, 0, 1, 2}, /* RxD2 */
- {1, 25, 2, 0, 1, 2}, /* RxD3 */
- {1, 26, 1, 0, 1, 2}, /* RxER */
- {1, 28, 2, 0, 1, 2}, /* Rx_DV */
- {3, 31, 2, 0, 1, 2}, /* RxCLK->CLK7 */
- {1, 29, 2, 0, 1, 2}, /* COL */
- {1, 31, 2, 0, 1, 2}, /* CRS */
It looks okay, but I haven't had a chance to review it thoroughly.
I don't like the value of "2" for "ignore". Since that type is an 'int', how about using "-1" instead?
'int',
No problem. If there's nothing else, I'll repost the patch with this change (hopefully the last time). I also implemented commands for reading and writing parallel I/O (pario read/write), but I'll post this as a separate patch. David.
I still can't apply the patch:
fatal: corrupt patch at line 40 Patch failed at 0001. When you have resolved this problem run "git-am --resolved". If you would prefer to skip this patch, instead run "git-am --skip".
I see these in the message body:
+ int data; } qe_iop_conf_t; =20 #define QE_IOP_TAB_END (-1)
The "=20" is the problem. Have you tried using git-send-email?
No, I think that's the only issue I have. Well, that and the fact that I can never apply your patches because git-am doesn't like them.
that I
Yes, sorry about that. Wasn't too well in the last couple of days, so didn't have the time to handle it. Will try to rediff and repost. Don't think it's a mail problem though (as the problematic line is quite short). David.
that I
David, any word on this? I'm trying to aggressively stay on top of patches for 1.3.3
Andy
On the MPC83xx & MPC85xx architectures that have QE, add initial data to the pin configuration table (qe_iop_conf_tab). This is relevant for GPIO pins defined as output. One can setup a value of -1 to leave the value unchanged. QE initialization tables in all relevant boards were also replaced. In addition, add IO pin read & write functions. This patch also includes commands for reading and writing parallel I/O ports (pario command).
Signed-off-by: David Saada david.saada@ecitele.com
--- a/include/ioports.h 2008-01-23 15:41:38.000000000 +0200 +++ b/include/ioports.h 2008-01-06 10:20:40.000000000 +0200 @@ -60,6 +60,7 @@ typedef struct { int dir; int open_drain; int assign; + int data; } qe_iop_conf_t;
#define QE_IOP_TAB_END (-1) --- a/cpu/mpc85xx/cpu_init.c 2008-01-23 15:41:38.000000000 +0200 +++ b/cpu/mpc85xx/cpu_init.c 2008-02-07 10:10:59.932817000 +0200 @@ -39,14 +39,14 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_QE extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, - int open_drain, int assign); + int open_drain, int assign, int data); extern void qe_init(uint qe_base); extern void qe_reset(void);
static void config_qe_ioports(void) { u8 port, pin; - int dir, open_drain, assign; + int dir, open_drain, assign, data; int i;
for (i = 0; qe_iop_conf_tab[i].assign != QE_IOP_TAB_END; i++) { @@ -55,7 +55,8 @@ static void config_qe_ioports(void) dir = qe_iop_conf_tab[i].dir; open_drain = qe_iop_conf_tab[i].open_drain; assign = qe_iop_conf_tab[i].assign; - qe_config_iopin(port, pin, dir, open_drain, assign); + data = qe_iop_conf_tab[i].data; + qe_config_iopin(port, pin, dir, open_drain, assign, data); } } #endif --- a/cpu/mpc85xx/qe_io.c 2008-01-23 15:41:38.000000000 +0200 +++ b/cpu/mpc85xx/qe_io.c 2008-02-07 10:10:03.810635000 +0200 @@ -27,7 +27,8 @@
+ /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + if ((data != -1) && /* Don't leave unchanged */ + (assign == 0) && /* GPIO */ + (dir & 1)) { /* Has output */ + tmp_val = in_be32(&par_io[port].cpdat); + if (data) + out_be32(&par_io[port].cpdat, pin_1bit_mask | tmp_val); + else + out_be32(&par_io[port].cpdat, ~pin_1bit_mask & tmp_val); + } + /* Caculate pin location and 2bit mask and dir */ pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); @@ -55,9 +70,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io[port].cpdir1, pin_2bit_dir | tmp_val); }
+void qe_read_iopin(u8 port, u8 pin, int *data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + volatile par_io_t *par_io = (volatile par_io_t *) + &(gur->qe_par_io); + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Read the data */ + tmp_val = in_be32(&par_io[port].cpdat); + *data = (tmp_val >> (NUM_OF_PINS - (pin+1))) & 0x1; +} + +void qe_write_iopin(u8 port, u8 pin, int data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + volatile par_io_t *par_io = (volatile par_io_t *) + &(gur->qe_par_io); + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Write the data */ + tmp_val = in_be32(&par_io[port].cpdat); + if (data) + out_be32(&par_io[port].cpdat, pin_1bit_mask | tmp_val); + else + out_be32(&par_io[port].cpdat, ~pin_1bit_mask & tmp_val); +} + #endif /* CONFIG_QE */ --- a/cpu/mpc83xx/cpu_init.c 2008-01-23 15:41:38.000000000 +0200 +++ b/cpu/mpc83xx/cpu_init.c 2008-02-07 10:11:55.678997000 +0200 @@ -29,14 +29,14 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_QE extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, - int open_drain, int assign); + int open_drain, int assign, int data); extern void qe_init(uint qe_base); extern void qe_reset(void);
for (i = 0; qe_iop_conf_tab[i].assign != QE_IOP_TAB_END; i++) { @@ -45,7 +45,8 @@ static void config_qe_ioports(void) dir = qe_iop_conf_tab[i].dir; open_drain = qe_iop_conf_tab[i].open_drain; assign = qe_iop_conf_tab[i].assign; - qe_config_iopin(port, pin, dir, open_drain, assign); + data = qe_iop_conf_tab[i].data; + qe_config_iopin(port, pin, dir, open_drain, assign, data); } } #endif --- a/cpu/mpc83xx/qe_io.c 2008-02-07 12:11:27.589731000 +0200 +++ b/cpu/mpc83xx/qe_io.c 2008-02-07 12:13:57.860982000 +0200 @@ -27,7 +27,8 @@
+ /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + if ((data != -1) && /* Don't leave unchanged */ + (assign == 0) && /* GPIO */ + (dir & 1)) { /* Has output */ + tmp_val = in_be32(&par_io->ioport[port].pdat); + if (data) + out_be32(&par_io->ioport[port].pdat, pin_1bit_mask | tmp_val); + else + out_be32(&par_io->ioport[port].pdat, ~pin_1bit_mask & tmp_val); + } + /* Caculate pin location and 2bit mask and dir */ pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); pin_2bit_dir = (u32)(dir << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); @@ -54,9 +69,6 @@ void qe_config_iopin(u8 port, u8 pin, in out_be32(&par_io->ioport[port].dir1, pin_2bit_dir | tmp_val); }
+void qe_read_iopin(u8 port, u8 pin, int *data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile immap_t *im = (volatile immap_t *)CFG_IMMR; + volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im->qepio; + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Read the data */ + tmp_val = in_be32(&par_io->ioport[port].pdat); + *data = (tmp_val >> (NUM_OF_PINS - (pin+1))) & 0x1; +} + +void qe_write_iopin(u8 port, u8 pin, int data) +{ + u32 pin_1bit_mask; + u32 tmp_val; + volatile immap_t *im = (volatile immap_t *)CFG_IMMR; + volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im->qepio; + + /* Calculate pin location for 1bit mask */ + pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + + /* Setup the data */ + tmp_val = in_be32(&par_io->ioport[port].pdat); + if (data) { + out_be32(&par_io->ioport[port].pdat, pin_1bit_mask | tmp_val); + } else { + out_be32(&par_io->ioport[port].pdat, ~pin_1bit_mask & tmp_val); + } +} + #endif /* CONFIG_QE */ --- a/board/freescale/mpc8323erdb/mpc8323erdb.c 2008-01-23 15:41:38.000000000 +0200 +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c 2008-02-06 18:36:28.335683000 +0200 @@ -28,47 +28,47 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* UCC3 */ - {1, 0, 1, 0, 1}, /* TxD0 */ - {1, 1, 1, 0, 1}, /* TxD1 */ - {1, 2, 1, 0, 1}, /* TxD2 */ - {1, 3, 1, 0, 1}, /* TxD3 */ - {1, 9, 1, 0, 1}, /* TxER */ - {1, 12, 1, 0, 1}, /* TxEN */ - {3, 24, 2, 0, 1}, /* TxCLK->CLK10 */ - - {1, 4, 2, 0, 1}, /* RxD0 */ - {1, 5, 2, 0, 1}, /* RxD1 */ - {1, 6, 2, 0, 1}, /* RxD2 */ - {1, 7, 2, 0, 1}, /* RxD3 */ - {1, 8, 2, 0, 1}, /* RxER */ - {1, 10, 2, 0, 1}, /* RxDV */ - {0, 13, 2, 0, 1}, /* RxCLK->CLK9 */ - {1, 11, 2, 0, 1}, /* COL */ - {1, 13, 2, 0, 1}, /* CRS */ + {1, 0, 1, 0, 1, -1}, /* TxD0 */ + {1, 1, 1, 0, 1, -1}, /* TxD1 */ + {1, 2, 1, 0, 1, -1}, /* TxD2 */ + {1, 3, 1, 0, 1, -1}, /* TxD3 */ + {1, 9, 1, 0, 1, -1}, /* TxER */ + {1, 12, 1, 0, 1, -1}, /* TxEN */ + {3, 24, 2, 0, 1, -1}, /* TxCLK->CLK10 */ + + {1, 4, 2, 0, 1, -1}, /* RxD0 */ + {1, 5, 2, 0, 1, -1}, /* RxD1 */ + {1, 6, 2, 0, 1, -1}, /* RxD2 */ + {1, 7, 2, 0, 1, -1}, /* RxD3 */ + {1, 8, 2, 0, 1, -1}, /* RxER */ + {1, 10, 2, 0, 1, -1}, /* RxDV */ + {0, 13, 2, 0, 1, -1}, /* RxCLK->CLK9 */ + {1, 11, 2, 0, 1, -1}, /* COL */ + {1, 13, 2, 0, 1, -1}, /* CRS */
/* UCC2 */ - {0, 18, 1, 0, 1}, /* TxD0 */ - {0, 19, 1, 0, 1}, /* TxD1 */ - {0, 20, 1, 0, 1}, /* TxD2 */ - {0, 21, 1, 0, 1}, /* TxD3 */ - {0, 27, 1, 0, 1}, /* TxER */ - {0, 30, 1, 0, 1}, /* TxEN */ - {3, 23, 2, 0, 1}, /* TxCLK->CLK3 */ - - {0, 22, 2, 0, 1}, /* RxD0 */ - {0, 23, 2, 0, 1}, /* RxD1 */ - {0, 24, 2, 0, 1}, /* RxD2 */ - {0, 25, 2, 0, 1}, /* RxD3 */ - {0, 26, 1, 0, 1}, /* RxER */ - {0, 28, 2, 0, 1}, /* Rx_DV */ - {3, 21, 2, 0, 1}, /* RxCLK->CLK16 */ - {0, 29, 2, 0, 1}, /* COL */ - {0, 31, 2, 0, 1}, /* CRS */ + {0, 18, 1, 0, 1, -1}, /* TxD0 */ + {0, 19, 1, 0, 1, -1}, /* TxD1 */ + {0, 20, 1, 0, 1, -1}, /* TxD2 */ + {0, 21, 1, 0, 1, -1}, /* TxD3 */ + {0, 27, 1, 0, 1, -1}, /* TxER */ + {0, 30, 1, 0, 1, -1}, /* TxEN */ + {3, 23, 2, 0, 1, -1}, /* TxCLK->CLK3 */ + + {0, 22, 2, 0, 1, -1}, /* RxD0 */ + {0, 23, 2, 0, 1, -1}, /* RxD1 */ + {0, 24, 2, 0, 1, -1}, /* RxD2 */ + {0, 25, 2, 0, 1, -1}, /* RxD3 */ + {0, 26, 1, 0, 1, -1}, /* RxER */ + {0, 28, 2, 0, 1, -1}, /* Rx_DV */ + {3, 21, 2, 0, 1, -1}, /* RxCLK->CLK16 */ + {0, 29, 2, 0, 1, -1}, /* COL */ + {0, 31, 2, 0, 1, -1}, /* CRS */
- {3, 4, 3, 0, 2}, /* MDIO */ - {3, 5, 1, 0, 2}, /* MDC */ + {3, 4, 3, 0, 2, -1}, /* MDIO */ + {3, 5, 1, 0, 2, -1}, /* MDC */
- {0, 0, 0, 0, QE_IOP_TAB_END}, /* END of table */ + {0, 0, 0, 0, QE_IOP_TAB_END, -1}, /* END of table */ };
int board_early_init_f(void) --- a/board/freescale/mpc832xemds/mpc832xemds.c 2008-01-23 15:41:38.000000000 +0200 +++ b/board/freescale/mpc832xemds/mpc832xemds.c 2008-02-06 18:37:24.166091000 +0200 @@ -36,47 +36,47 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* ETH3 */ - {1, 0, 1, 0, 1}, /* TxD0 */ - {1, 1, 1, 0, 1}, /* TxD1 */ - {1, 2, 1, 0, 1}, /* TxD2 */ - {1, 3, 1, 0, 1}, /* TxD3 */ - {1, 9, 1, 0, 1}, /* TxER */ - {1, 12, 1, 0, 1}, /* TxEN */ - {3, 24, 2, 0, 1}, /* TxCLK->CLK10 */ - - {1, 4, 2, 0, 1}, /* RxD0 */ - {1, 5, 2, 0, 1}, /* RxD1 */ - {1, 6, 2, 0, 1}, /* RxD2 */ - {1, 7, 2, 0, 1}, /* RxD3 */ - {1, 8, 2, 0, 1}, /* RxER */ - {1, 10, 2, 0, 1}, /* RxDV */ - {0, 13, 2, 0, 1}, /* RxCLK->CLK9 */ - {1, 11, 2, 0, 1}, /* COL */ - {1, 13, 2, 0, 1}, /* CRS */ + {1, 0, 1, 0, 1, -1}, /* TxD0 */ + {1, 1, 1, 0, 1, -1}, /* TxD1 */ + {1, 2, 1, 0, 1, -1}, /* TxD2 */ + {1, 3, 1, 0, 1, -1}, /* TxD3 */ + {1, 9, 1, 0, 1, -1}, /* TxER */ + {1, 12, 1, 0, 1, -1}, /* TxEN */ + {3, 24, 2, 0, 1, -1}, /* TxCLK->CLK10 */ + + {1, 4, 2, 0, 1, -1}, /* RxD0 */ + {1, 5, 2, 0, 1, -1}, /* RxD1 */ + {1, 6, 2, 0, 1, -1}, /* RxD2 */ + {1, 7, 2, 0, 1, -1}, /* RxD3 */ + {1, 8, 2, 0, 1, -1}, /* RxER */ + {1, 10, 2, 0, 1, -1}, /* RxDV */ + {0, 13, 2, 0, 1, -1}, /* RxCLK->CLK9 */ + {1, 11, 2, 0, 1, -1}, /* COL */ + {1, 13, 2, 0, 1, -1}, /* CRS */
/* ETH4 */ - {1, 18, 1, 0, 1}, /* TxD0 */ - {1, 19, 1, 0, 1}, /* TxD1 */ - {1, 20, 1, 0, 1}, /* TxD2 */ - {1, 21, 1, 0, 1}, /* TxD3 */ - {1, 27, 1, 0, 1}, /* TxER */ - {1, 30, 1, 0, 1}, /* TxEN */ - {3, 6, 2, 0, 1}, /* TxCLK->CLK8 */ - - {1, 22, 2, 0, 1}, /* RxD0 */ - {1, 23, 2, 0, 1}, /* RxD1 */ - {1, 24, 2, 0, 1}, /* RxD2 */ - {1, 25, 2, 0, 1}, /* RxD3 */ - {1, 26, 1, 0, 1}, /* RxER */ - {1, 28, 2, 0, 1}, /* Rx_DV */ - {3, 31, 2, 0, 1}, /* RxCLK->CLK7 */ - {1, 29, 2, 0, 1}, /* COL */ - {1, 31, 2, 0, 1}, /* CRS */ + {1, 18, 1, 0, 1, -1}, /* TxD0 */ + {1, 19, 1, 0, 1, -1}, /* TxD1 */ + {1, 20, 1, 0, 1, -1}, /* TxD2 */ + {1, 21, 1, 0, 1, -1}, /* TxD3 */ + {1, 27, 1, 0, 1, -1}, /* TxER */ + {1, 30, 1, 0, 1, -1}, /* TxEN */ + {3, 6, 2, 0, 1, -1}, /* TxCLK->CLK8 */ + + {1, 22, 2, 0, 1, -1}, /* RxD0 */ + {1, 23, 2, 0, 1, -1}, /* RxD1 */ + {1, 24, 2, 0, 1, -1}, /* RxD2 */ + {1, 25, 2, 0, 1, -1}, /* RxD3 */ + {1, 26, 1, 0, 1, -1}, /* RxER */ + {1, 28, 2, 0, 1, -1}, /* Rx_DV */ + {3, 31, 2, 0, 1, -1}, /* RxCLK->CLK7 */ + {1, 29, 2, 0, 1, -1}, /* COL */ + {1, 31, 2, 0, 1, -1}, /* CRS */
int board_early_init_f(void) --- a/board/freescale/mpc8360emds/mpc8360emds.c 2008-01-23 15:41:38.000000000 +0200 +++ b/board/freescale/mpc8360emds/mpc8360emds.c 2008-02-06 18:37:49.149044000 +0200 @@ -34,63 +34,63 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ - {0, 3, 1, 0, 1}, /* TxD0 */ - {0, 4, 1, 0, 1}, /* TxD1 */ - {0, 5, 1, 0, 1}, /* TxD2 */ - {0, 6, 1, 0, 1}, /* TxD3 */ - {1, 6, 1, 0, 3}, /* TxD4 */ - {1, 7, 1, 0, 1}, /* TxD5 */ - {1, 9, 1, 0, 2}, /* TxD6 */ - {1, 10, 1, 0, 2}, /* TxD7 */ - {0, 9, 2, 0, 1}, /* RxD0 */ - {0, 10, 2, 0, 1}, /* RxD1 */ - {0, 11, 2, 0, 1}, /* RxD2 */ - {0, 12, 2, 0, 1}, /* RxD3 */ - {0, 13, 2, 0, 1}, /* RxD4 */ - {1, 1, 2, 0, 2}, /* RxD5 */ - {1, 0, 2, 0, 2}, /* RxD6 */ - {1, 4, 2, 0, 2}, /* RxD7 */ - {0, 7, 1, 0, 1}, /* TX_EN */ - {0, 8, 1, 0, 1}, /* TX_ER */ - {0, 15, 2, 0, 1}, /* RX_DV */ - {0, 16, 2, 0, 1}, /* RX_ER */ - {0, 0, 2, 0, 1}, /* RX_CLK */ - {2, 9, 1, 0, 3}, /* GTX_CLK - CLK10 */ - {2, 8, 2, 0, 1}, /* GTX125 - CLK9 */ + {0, 3, 1, 0, 1, -1}, /* TxD0 */ + {0, 4, 1, 0, 1, -1}, /* TxD1 */ + {0, 5, 1, 0, 1, -1}, /* TxD2 */ + {0, 6, 1, 0, 1, -1}, /* TxD3 */ + {1, 6, 1, 0, 3, -1}, /* TxD4 */ + {1, 7, 1, 0, 1, -1}, /* TxD5 */ + {1, 9, 1, 0, 2, -1}, /* TxD6 */ + {1, 10, 1, 0, 2, -1}, /* TxD7 */ + {0, 9, 2, 0, 1, -1}, /* RxD0 */ + {0, 10, 2, 0, 1, -1}, /* RxD1 */ + {0, 11, 2, 0, 1, -1}, /* RxD2 */ + {0, 12, 2, 0, 1, -1}, /* RxD3 */ + {0, 13, 2, 0, 1, -1}, /* RxD4 */ + {1, 1, 2, 0, 2, -1}, /* RxD5 */ + {1, 0, 2, 0, 2, -1}, /* RxD6 */ + {1, 4, 2, 0, 2, -1}, /* RxD7 */ + {0, 7, 1, 0, 1, -1}, /* TX_EN */ + {0, 8, 1, 0, 1, -1}, /* TX_ER */ + {0, 15, 2, 0, 1, -1}, /* RX_DV */ + {0, 16, 2, 0, 1, -1}, /* RX_ER */ + {0, 0, 2, 0, 1, -1}, /* RX_CLK */ + {2, 9, 1, 0, 3, -1}, /* GTX_CLK - CLK10 */ + {2, 8, 2, 0, 1, -1}, /* GTX125 - CLK9 */ /* GETH2 */ - {0, 17, 1, 0, 1}, /* TxD0 */ - {0, 18, 1, 0, 1}, /* TxD1 */ - {0, 19, 1, 0, 1}, /* TxD2 */ - {0, 20, 1, 0, 1}, /* TxD3 */ - {1, 2, 1, 0, 1}, /* TxD4 */ - {1, 3, 1, 0, 2}, /* TxD5 */ - {1, 5, 1, 0, 3}, /* TxD6 */ - {1, 8, 1, 0, 3}, /* TxD7 */ - {0, 23, 2, 0, 1}, /* RxD0 */ - {0, 24, 2, 0, 1}, /* RxD1 */ - {0, 25, 2, 0, 1}, /* RxD2 */ - {0, 26, 2, 0, 1}, /* RxD3 */ - {0, 27, 2, 0, 1}, /* RxD4 */ - {1, 12, 2, 0, 2}, /* RxD5 */ - {1, 13, 2, 0, 3}, /* RxD6 */ - {1, 11, 2, 0, 2}, /* RxD7 */ - {0, 21, 1, 0, 1}, /* TX_EN */ - {0, 22, 1, 0, 1}, /* TX_ER */ - {0, 29, 2, 0, 1}, /* RX_DV */ - {0, 30, 2, 0, 1}, /* RX_ER */ - {0, 31, 2, 0, 1}, /* RX_CLK */ - {2, 2, 1, 0, 2}, /* GTX_CLK = CLK10 */ - {2, 3, 2, 0, 1}, /* GTX125 - CLK4 */ - - {0, 1, 3, 0, 2}, /* MDIO */ - {0, 2, 1, 0, 1}, /* MDC */ - - {5, 0, 1, 0, 2}, /* UART2_SOUT */ - {5, 1, 2, 0, 3}, /* UART2_CTS */ - {5, 2, 1, 0, 1}, /* UART2_RTS */ - {5, 3, 2, 0, 2}, /* UART2_SIN */ + {0, 17, 1, 0, 1, -1}, /* TxD0 */ + {0, 18, 1, 0, 1, -1}, /* TxD1 */ + {0, 19, 1, 0, 1, -1}, /* TxD2 */ + {0, 20, 1, 0, 1, -1}, /* TxD3 */ + {1, 2, 1, 0, 1, -1}, /* TxD4 */ + {1, 3, 1, 0, 2, -1}, /* TxD5 */ + {1, 5, 1, 0, 3, -1}, /* TxD6 */ + {1, 8, 1, 0, 3, -1}, /* TxD7 */ + {0, 23, 2, 0, 1, -1}, /* RxD0 */ + {0, 24, 2, 0, 1, -1}, /* RxD1 */ + {0, 25, 2, 0, 1, -1}, /* RxD2 */ + {0, 26, 2, 0, 1, -1}, /* RxD3 */ + {0, 27, 2, 0, 1, -1}, /* RxD4 */ + {1, 12, 2, 0, 2, -1}, /* RxD5 */ + {1, 13, 2, 0, 3, -1}, /* RxD6 */ + {1, 11, 2, 0, 2, -1}, /* RxD7 */ + {0, 21, 1, 0, 1, -1}, /* TX_EN */ + {0, 22, 1, 0, 1, -1}, /* TX_ER */ + {0, 29, 2, 0, 1, -1}, /* RX_DV */ + {0, 30, 2, 0, 1, -1}, /* RX_ER */ + {0, 31, 2, 0, 1, -1}, /* RX_CLK */ + {2, 2, 1, 0, 2, -1}, /* GTX_CLK = CLK10 */ + {2, 3, 2, 0, 1, -1}, /* GTX125 - CLK4 */ + + {0, 1, 3, 0, 2, -1}, /* MDIO */ + {0, 2, 1, 0, 1, -1}, /* MDC */ + + {5, 0, 1, 0, 2, -1}, /* UART2_SOUT */ + {5, 1, 2, 0, 3, -1}, /* UART2_CTS */ + {5, 2, 1, 0, 1, -1}, /* UART2_RTS */ + {5, 3, 2, 0, 2, -1}, /* UART2_SIN */
int board_early_init_f(void) --- a/board/freescale/mpc8360erdk/mpc8360erdk.c 2008-01-23 15:41:38.000000000 +0200 +++ b/board/freescale/mpc8360erdk/mpc8360erdk.c 2008-02-06 18:38:21.396417000 +0200 @@ -27,168 +27,168 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* MDIO */ - {0, 1, 3, 0, 2}, /* MDIO */ - {0, 2, 1, 0, 1}, /* MDC */ + {0, 1, 3, 0, 2, -1}, /* MDIO */ + {0, 2, 1, 0, 1, -1}, /* MDC */
/* UCC1 - UEC (Gigabit) */ - {0, 3, 1, 0, 1}, /* TxD0 */ - {0, 4, 1, 0, 1}, /* TxD1 */ - {0, 5, 1, 0, 1}, /* TxD2 */ - {0, 6, 1, 0, 1}, /* TxD3 */ - {0, 9, 2, 0, 1}, /* RxD0 */ - {0, 10, 2, 0, 1}, /* RxD1 */ - {0, 11, 2, 0, 1}, /* RxD2 */ - {0, 12, 2, 0, 1}, /* RxD3 */ - {0, 7, 1, 0, 1}, /* TX_EN */ - {0, 8, 1, 0, 1}, /* TX_ER */ - {0, 15, 2, 0, 1}, /* RX_DV */ - {0, 0, 2, 0, 1}, /* RX_CLK */ - {2, 9, 1, 0, 3}, /* GTX_CLK - CLK10 */ - {2, 8, 2, 0, 1}, /* GTX125 - CLK9 */ + {0, 3, 1, 0, 1, -1}, /* TxD0 */ + {0, 4, 1, 0, 1, -1}, /* TxD1 */ + {0, 5, 1, 0, 1, -1}, /* TxD2 */ + {0, 6, 1, 0, 1, -1}, /* TxD3 */ + {0, 9, 2, 0, 1, -1}, /* RxD0 */ + {0, 10, 2, 0, 1, -1}, /* RxD1 */ + {0, 11, 2, 0, 1, -1}, /* RxD2 */ + {0, 12, 2, 0, 1, -1}, /* RxD3 */ + {0, 7, 1, 0, 1, -1}, /* TX_EN */ + {0, 8, 1, 0, 1, -1}, /* TX_ER */ + {0, 15, 2, 0, 1, -1}, /* RX_DV */ + {0, 0, 2, 0, 1, -1}, /* RX_CLK */ + {2, 9, 1, 0, 3, -1}, /* GTX_CLK - CLK10 */ + {2, 8, 2, 0, 1, -1}, /* GTX125 - CLK9 */
/* UCC2 - UEC (Gigabit) */ - {0, 17, 1, 0, 1}, /* TxD0 */ - {0, 18, 1, 0, 1}, /* TxD1 */ - {0, 19, 1, 0, 1}, /* TxD2 */ - {0, 20, 1, 0, 1}, /* TxD3 */ - {0, 23, 2, 0, 1}, /* RxD0 */ - {0, 24, 2, 0, 1}, /* RxD1 */ - {0, 25, 2, 0, 1}, /* RxD2 */ - {0, 26, 2, 0, 1}, /* RxD3 */ - {0, 21, 1, 0, 1}, /* TX_EN */ - {0, 22, 1, 0, 1}, /* TX_ER */ - {0, 29, 2, 0, 1}, /* RX_DV */ - {0, 31, 2, 0, 1}, /* RX_CLK */ - {2, 2, 1, 0, 2}, /* GTX_CLK - CLK10 */ - {2, 3, 2, 0, 1}, /* GTX125 - CLK4 */ + {0, 17, 1, 0, 1, -1}, /* TxD0 */ + {0, 18, 1, 0, 1, -1}, /* TxD1 */ + {0, 19, 1, 0, 1, -1}, /* TxD2 */ + {0, 20, 1, 0, 1, -1}, /* TxD3 */ + {0, 23, 2, 0, 1, -1}, /* RxD0 */ + {0, 24, 2, 0, 1, -1}, /* RxD1 */ + {0, 25, 2, 0, 1, -1}, /* RxD2 */ + {0, 26, 2, 0, 1, -1}, /* RxD3 */ + {0, 21, 1, 0, 1, -1}, /* TX_EN */ + {0, 22, 1, 0, 1, -1}, /* TX_ER */ + {0, 29, 2, 0, 1, -1}, /* RX_DV */ + {0, 31, 2, 0, 1, -1}, /* RX_CLK */ + {2, 2, 1, 0, 2, -1}, /* GTX_CLK - CLK10 */ + {2, 3, 2, 0, 1, -1}, /* GTX125 - CLK4 */
/* UCC7 - UEC */ - {4, 0, 1, 0, 1}, /* TxD0 */ - {4, 1, 1, 0, 1}, /* TxD1 */ - {4, 2, 1, 0, 1}, /* TxD2 */ - {4, 3, 1, 0, 1}, /* TxD3 */ - {4, 6, 2, 0, 1}, /* RxD0 */ - {4, 7, 2, 0, 1}, /* RxD1 */ - {4, 8, 2, 0, 1}, /* RxD2 */ - {4, 9, 2, 0, 1}, /* RxD3 */ - {4, 4, 1, 0, 1}, /* TX_EN */ - {4, 5, 1, 0, 1}, /* TX_ER */ - {4, 12, 2, 0, 1}, /* RX_DV */ - {4, 13, 2, 0, 1}, /* RX_ER */ - {4, 10, 2, 0, 1}, /* COL */ - {4, 11, 2, 0, 1}, /* CRS */ - {2, 18, 2, 0, 1}, /* TX_CLK - CLK19 */ - {2, 19, 2, 0, 1}, /* RX_CLK - CLK20 */ + {4, 0, 1, 0, 1, -1}, /* TxD0 */ + {4, 1, 1, 0, 1, -1}, /* TxD1 */ + {4, 2, 1, 0, 1, -1}, /* TxD2 */ + {4, 3, 1, 0, 1, -1}, /* TxD3 */ + {4, 6, 2, 0, 1, -1}, /* RxD0 */ + {4, 7, 2, 0, 1, -1}, /* RxD1 */ + {4, 8, 2, 0, 1, -1}, /* RxD2 */ + {4, 9, 2, 0, 1, -1}, /* RxD3 */ + {4, 4, 1, 0, 1, -1}, /* TX_EN */ + {4, 5, 1, 0, 1, -1}, /* TX_ER */ + {4, 12, 2, 0, 1, -1}, /* RX_DV */ + {4, 13, 2, 0, 1, -1}, /* RX_ER */ + {4, 10, 2, 0, 1, -1}, /* COL */ + {4, 11, 2, 0, 1, -1}, /* CRS */ + {2, 18, 2, 0, 1, -1}, /* TX_CLK - CLK19 */ + {2, 19, 2, 0, 1, -1}, /* RX_CLK - CLK20 */
/* UCC4 - UEC */ - {1, 14, 1, 0, 1}, /* TxD0 */ - {1, 15, 1, 0, 1}, /* TxD1 */ - {1, 16, 1, 0, 1}, /* TxD2 */ - {1, 17, 1, 0, 1}, /* TxD3 */ - {1, 20, 2, 0, 1}, /* RxD0 */ - {1, 21, 2, 0, 1}, /* RxD1 */ - {1, 22, 2, 0, 1}, /* RxD2 */ - {1, 23, 2, 0, 1}, /* RxD3 */ - {1, 18, 1, 0, 1}, /* TX_EN */ - {1, 19, 1, 0, 2}, /* TX_ER */ - {1, 26, 2, 0, 1}, /* RX_DV */ - {1, 27, 2, 0, 1}, /* RX_ER */ - {1, 24, 2, 0, 1}, /* COL */ - {1, 25, 2, 0, 1}, /* CRS */ - {2, 6, 2, 0, 1}, /* TX_CLK - CLK7 */ - {2, 7, 2, 0, 1}, /* RX_CLK - CLK8 */ + {1, 14, 1, 0, 1, -1}, /* TxD0 */ + {1, 15, 1, 0, 1, -1}, /* TxD1 */ + {1, 16, 1, 0, 1, -1}, /* TxD2 */ + {1, 17, 1, 0, 1, -1}, /* TxD3 */ + {1, 20, 2, 0, 1, -1}, /* RxD0 */ + {1, 21, 2, 0, 1, -1}, /* RxD1 */ + {1, 22, 2, 0, 1, -1}, /* RxD2 */ + {1, 23, 2, 0, 1, -1}, /* RxD3 */ + {1, 18, 1, 0, 1, -1}, /* TX_EN */ + {1, 19, 1, 0, 2, -1}, /* TX_ER */ + {1, 26, 2, 0, 1, -1}, /* RX_DV */ + {1, 27, 2, 0, 1, -1}, /* RX_ER */ + {1, 24, 2, 0, 1, -1}, /* COL */ + {1, 25, 2, 0, 1, -1}, /* CRS */ + {2, 6, 2, 0, 1, -1}, /* TX_CLK - CLK7 */ + {2, 7, 2, 0, 1, -1}, /* RX_CLK - CLK8 */
/* PCI1 */ - {5, 4, 2, 0, 3}, /* PCI_M66EN */ - {5, 5, 1, 0, 3}, /* PCI_INTA */ - {5, 6, 1, 0, 3}, /* PCI_RSTO */ - {5, 7, 3, 0, 3}, /* PCI_C_BE0 */ - {5, 8, 3, 0, 3}, /* PCI_C_BE1 */ - {5, 9, 3, 0, 3}, /* PCI_C_BE2 */ - {5, 10, 3, 0, 3}, /* PCI_C_BE3 */ - {5, 11, 3, 0, 3}, /* PCI_PAR */ - {5, 12, 3, 0, 3}, /* PCI_FRAME */ - {5, 13, 3, 0, 3}, /* PCI_TRDY */ - {5, 14, 3, 0, 3}, /* PCI_IRDY */ - {5, 15, 3, 0, 3}, /* PCI_STOP */ - {5, 16, 3, 0, 3}, /* PCI_DEVSEL */ - {5, 17, 0, 0, 0}, /* PCI_IDSEL */ - {5, 18, 3, 0, 3}, /* PCI_SERR */ - {5, 19, 3, 0, 3}, /* PCI_PERR */ - {5, 20, 3, 0, 3}, /* PCI_REQ0 */ - {5, 21, 2, 0, 3}, /* PCI_REQ1 */ - {5, 22, 2, 0, 3}, /* PCI_GNT2 */ - {5, 23, 3, 0, 3}, /* PCI_GNT0 */ - {5, 24, 1, 0, 3}, /* PCI_GNT1 */ - {5, 25, 1, 0, 3}, /* PCI_GNT2 */ - {5, 26, 0, 0, 0}, /* PCI_CLK0 */ - {5, 27, 0, 0, 0}, /* PCI_CLK1 */ - {5, 28, 0, 0, 0}, /* PCI_CLK2 */ - {5, 29, 0, 0, 3}, /* PCI_SYNC_OUT */ - {6, 0, 3, 0, 3}, /* PCI_AD0 */ - {6, 1, 3, 0, 3}, /* PCI_AD1 */ - {6, 2, 3, 0, 3}, /* PCI_AD2 */ - {6, 3, 3, 0, 3}, /* PCI_AD3 */ - {6, 4, 3, 0, 3}, /* PCI_AD4 */ - {6, 5, 3, 0, 3}, /* PCI_AD5 */ - {6, 6, 3, 0, 3}, /* PCI_AD6 */ - {6, 7, 3, 0, 3}, /* PCI_AD7 */ - {6, 8, 3, 0, 3}, /* PCI_AD8 */ - {6, 9, 3, 0, 3}, /* PCI_AD9 */ - {6, 10, 3, 0, 3}, /* PCI_AD10 */ - {6, 11, 3, 0, 3}, /* PCI_AD11 */ - {6, 12, 3, 0, 3}, /* PCI_AD12 */ - {6, 13, 3, 0, 3}, /* PCI_AD13 */ - {6, 14, 3, 0, 3}, /* PCI_AD14 */ - {6, 15, 3, 0, 3}, /* PCI_AD15 */ - {6, 16, 3, 0, 3}, /* PCI_AD16 */ - {6, 17, 3, 0, 3}, /* PCI_AD17 */ - {6, 18, 3, 0, 3}, /* PCI_AD18 */ - {6, 19, 3, 0, 3}, /* PCI_AD19 */ - {6, 20, 3, 0, 3}, /* PCI_AD20 */ - {6, 21, 3, 0, 3}, /* PCI_AD21 */ - {6, 22, 3, 0, 3}, /* PCI_AD22 */ - {6, 23, 3, 0, 3}, /* PCI_AD23 */ - {6, 24, 3, 0, 3}, /* PCI_AD24 */ - {6, 25, 3, 0, 3}, /* PCI_AD25 */ - {6, 26, 3, 0, 3}, /* PCI_AD26 */ - {6, 27, 3, 0, 3}, /* PCI_AD27 */ - {6, 28, 3, 0, 3}, /* PCI_AD28 */ - {6, 29, 3, 0, 3}, /* PCI_AD29 */ - {6, 30, 3, 0, 3}, /* PCI_AD30 */ - {6, 31, 3, 0, 3}, /* PCI_AD31 */ + {5, 4, 2, 0, 3, -1}, /* PCI_M66EN */ + {5, 5, 1, 0, 3, -1}, /* PCI_INTA */ + {5, 6, 1, 0, 3, -1}, /* PCI_RSTO */ + {5, 7, 3, 0, 3, -1}, /* PCI_C_BE0 */ + {5, 8, 3, 0, 3, -1}, /* PCI_C_BE1 */ + {5, 9, 3, 0, 3, -1}, /* PCI_C_BE2 */ + {5, 10, 3, 0, 3, -1}, /* PCI_C_BE3 */ + {5, 11, 3, 0, 3, -1}, /* PCI_PAR */ + {5, 12, 3, 0, 3, -1}, /* PCI_FRAME */ + {5, 13, 3, 0, 3, -1}, /* PCI_TRDY */ + {5, 14, 3, 0, 3, -1}, /* PCI_IRDY */ + {5, 15, 3, 0, 3, -1}, /* PCI_STOP */ + {5, 16, 3, 0, 3, -1}, /* PCI_DEVSEL */ + {5, 17, 0, 0, 0, -1}, /* PCI_IDSEL */ + {5, 18, 3, 0, 3, -1}, /* PCI_SERR */ + {5, 19, 3, 0, 3, -1}, /* PCI_PERR */ + {5, 20, 3, 0, 3, -1}, /* PCI_REQ0 */ + {5, 21, 2, 0, 3, -1}, /* PCI_REQ1 */ + {5, 22, 2, 0, 3, -1}, /* PCI_GNT2 */ + {5, 23, 3, 0, 3, -1}, /* PCI_GNT0 */ + {5, 24, 1, 0, 3, -1}, /* PCI_GNT1 */ + {5, 25, 1, 0, 3, -1}, /* PCI_GNT2 */ + {5, 26, 0, 0, 0, -1}, /* PCI_CLK0 */ + {5, 27, 0, 0, 0, -1}, /* PCI_CLK1 */ + {5, 28, 0, 0, 0, -1}, /* PCI_CLK2 */ + {5, 29, 0, 0, 3, -1}, /* PCI_SYNC_OUT */ + {6, 0, 3, 0, 3, -1}, /* PCI_AD0 */ + {6, 1, 3, 0, 3, -1}, /* PCI_AD1 */ + {6, 2, 3, 0, 3, -1}, /* PCI_AD2 */ + {6, 3, 3, 0, 3, -1}, /* PCI_AD3 */ + {6, 4, 3, 0, 3, -1}, /* PCI_AD4 */ + {6, 5, 3, 0, 3, -1}, /* PCI_AD5 */ + {6, 6, 3, 0, 3, -1}, /* PCI_AD6 */ + {6, 7, 3, 0, 3, -1}, /* PCI_AD7 */ + {6, 8, 3, 0, 3, -1}, /* PCI_AD8 */ + {6, 9, 3, 0, 3, -1}, /* PCI_AD9 */ + {6, 10, 3, 0, 3, -1}, /* PCI_AD10 */ + {6, 11, 3, 0, 3, -1}, /* PCI_AD11 */ + {6, 12, 3, 0, 3, -1}, /* PCI_AD12 */ + {6, 13, 3, 0, 3, -1}, /* PCI_AD13 */ + {6, 14, 3, 0, 3, -1}, /* PCI_AD14 */ + {6, 15, 3, 0, 3, -1}, /* PCI_AD15 */ + {6, 16, 3, 0, 3, -1}, /* PCI_AD16 */ + {6, 17, 3, 0, 3, -1}, /* PCI_AD17 */ + {6, 18, 3, 0, 3, -1}, /* PCI_AD18 */ + {6, 19, 3, 0, 3, -1}, /* PCI_AD19 */ + {6, 20, 3, 0, 3, -1}, /* PCI_AD20 */ + {6, 21, 3, 0, 3, -1}, /* PCI_AD21 */ + {6, 22, 3, 0, 3, -1}, /* PCI_AD22 */ + {6, 23, 3, 0, 3, -1}, /* PCI_AD23 */ + {6, 24, 3, 0, 3, -1}, /* PCI_AD24 */ + {6, 25, 3, 0, 3, -1}, /* PCI_AD25 */ + {6, 26, 3, 0, 3, -1}, /* PCI_AD26 */ + {6, 27, 3, 0, 3, -1}, /* PCI_AD27 */ + {6, 28, 3, 0, 3, -1}, /* PCI_AD28 */ + {6, 29, 3, 0, 3, -1}, /* PCI_AD29 */ + {6, 30, 3, 0, 3, -1}, /* PCI_AD30 */ + {6, 31, 3, 0, 3, -1}, /* PCI_AD31 */
/* NAND */ - {4, 18, 2, 0, 0}, /* NAND_RYnBY */ + {4, 18, 2, 0, 0, -1}, /* NAND_RYnBY */
/* DUART - UART2 */ - {5, 0, 1, 0, 2}, /* UART2_SOUT */ - {5, 2, 1, 0, 1}, /* UART2_RTS */ - {5, 3, 2, 0, 2}, /* UART2_SIN */ - {5, 1, 2, 0, 3}, /* UART2_CTS */ + {5, 0, 1, 0, 2, -1}, /* UART2_SOUT */ + {5, 2, 1, 0, 1, -1}, /* UART2_RTS */ + {5, 3, 2, 0, 2, -1}, /* UART2_SIN */ + {5, 1, 2, 0, 3, -1}, /* UART2_CTS */
/* UCC5 - UART3 */ - {3, 0, 1, 0, 1}, /* UART3_TX */ - {3, 4, 1, 0, 1}, /* UART3_RTS */ - {3, 6, 2, 0, 1}, /* UART3_RX */ - {3, 12, 2, 0, 0}, /* UART3_CTS */ - {3, 13, 2, 0, 0}, /* UCC5_CD */ + {3, 0, 1, 0, 1, -1}, /* UART3_TX */ + {3, 4, 1, 0, 1, -1}, /* UART3_RTS */ + {3, 6, 2, 0, 1, -1}, /* UART3_RX */ + {3, 12, 2, 0, 0, -1}, /* UART3_CTS */ + {3, 13, 2, 0, 0, -1}, /* UCC5_CD */
/* UCC6 - UART4 */ - {3, 14, 1, 0, 1}, /* UART4_TX */ - {3, 18, 1, 0, 1}, /* UART4_RTS */ - {3, 20, 2, 0, 1}, /* UART4_RX */ - {3, 26, 2, 0, 0}, /* UART4_CTS */ - {3, 27, 2, 0, 0}, /* UCC6_CD */ + {3, 14, 1, 0, 1, -1}, /* UART4_TX */ + {3, 18, 1, 0, 1, -1}, /* UART4_RTS */ + {3, 20, 2, 0, 1, -1}, /* UART4_RX */ + {3, 26, 2, 0, 0, -1}, /* UART4_CTS */ + {3, 27, 2, 0, 0, -1}, /* UCC6_CD */
/* Fujitsu MB86277 (MINT) graphics controller */ - {0, 30, 1, 0, 0}, /* nSRESET_GRAPHICS */ - {1, 5, 1, 0, 0}, /* nXRST_GRAPHICS */ - {1, 7, 1, 0, 0}, /* LVDS_BKLT_CTR */ - {2, 16, 1, 0, 0}, /* LVDS_BKLT_EN */ + {0, 30, 1, 0, 0, -1}, /* nSRESET_GRAPHICS */ + {1, 5, 1, 0, 0, -1}, /* nXRST_GRAPHICS */ + {1, 7, 1, 0, 0, -1}, /* LVDS_BKLT_CTR */ + {2, 16, 1, 0, 0, -1}, /* LVDS_BKLT_EN */
/* END of table */ - {0, 0, 0, 0, QE_IOP_TAB_END}, + {0, 0, 0, 0, QE_IOP_TAB_END, -1}, };
int board_early_init_f(void) --- a/board/freescale/mpc8568mds/mpc8568mds.c 2008-01-23 15:41:38.000000000 +0200 +++ b/board/freescale/mpc8568mds/mpc8568mds.c 2008-02-06 18:38:51.399967000 +0200 @@ -37,64 +37,64 @@
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ - {4, 10, 1, 0, 2}, /* TxD0 */ - {4, 9, 1, 0, 2}, /* TxD1 */ - {4, 8, 1, 0, 2}, /* TxD2 */ - {4, 7, 1, 0, 2}, /* TxD3 */ - {4, 23, 1, 0, 2}, /* TxD4 */ - {4, 22, 1, 0, 2}, /* TxD5 */ - {4, 21, 1, 0, 2}, /* TxD6 */ - {4, 20, 1, 0, 2}, /* TxD7 */ - {4, 15, 2, 0, 2}, /* RxD0 */ - {4, 14, 2, 0, 2}, /* RxD1 */ - {4, 13, 2, 0, 2}, /* RxD2 */ - {4, 12, 2, 0, 2}, /* RxD3 */ - {4, 29, 2, 0, 2}, /* RxD4 */ - {4, 28, 2, 0, 2}, /* RxD5 */ - {4, 27, 2, 0, 2}, /* RxD6 */ - {4, 26, 2, 0, 2}, /* RxD7 */ - {4, 11, 1, 0, 2}, /* TX_EN */ - {4, 24, 1, 0, 2}, /* TX_ER */ - {4, 16, 2, 0, 2}, /* RX_DV */ - {4, 30, 2, 0, 2}, /* RX_ER */ - {4, 17, 2, 0, 2}, /* RX_CLK */ - {4, 19, 1, 0, 2}, /* GTX_CLK */ - {1, 31, 2, 0, 3}, /* GTX125 */ + {4, 10, 1, 0, 2, -1}, /* TxD0 */ + {4, 9, 1, 0, 2, -1}, /* TxD1 */ + {4, 8, 1, 0, 2, -1}, /* TxD2 */ + {4, 7, 1, 0, 2, -1}, /* TxD3 */ + {4, 23, 1, 0, 2, -1}, /* TxD4 */ + {4, 22, 1, 0, 2, -1}, /* TxD5 */ + {4, 21, 1, 0, 2, -1}, /* TxD6 */ + {4, 20, 1, 0, 2, -1}, /* TxD7 */ + {4, 15, 2, 0, 2, -1}, /* RxD0 */ + {4, 14, 2, 0, 2, -1}, /* RxD1 */ + {4, 13, 2, 0, 2, -1}, /* RxD2 */ + {4, 12, 2, 0, 2, -1}, /* RxD3 */ + {4, 29, 2, 0, 2, -1}, /* RxD4 */ + {4, 28, 2, 0, 2, -1}, /* RxD5 */ + {4, 27, 2, 0, 2, -1}, /* RxD6 */ + {4, 26, 2, 0, 2, -1}, /* RxD7 */ + {4, 11, 1, 0, 2, -1}, /* TX_EN */ + {4, 24, 1, 0, 2, -1}, /* TX_ER */ + {4, 16, 2, 0, 2, -1}, /* RX_DV */ + {4, 30, 2, 0, 2, -1}, /* RX_ER */ + {4, 17, 2, 0, 2, -1}, /* RX_CLK */ + {4, 19, 1, 0, 2, -1}, /* GTX_CLK */ + {1, 31, 2, 0, 3, -1}, /* GTX125 */
/* GETH2 */ - {5, 10, 1, 0, 2}, /* TxD0 */ - {5, 9, 1, 0, 2}, /* TxD1 */ - {5, 8, 1, 0, 2}, /* TxD2 */ - {5, 7, 1, 0, 2}, /* TxD3 */ - {5, 23, 1, 0, 2}, /* TxD4 */ - {5, 22, 1, 0, 2}, /* TxD5 */ - {5, 21, 1, 0, 2}, /* TxD6 */ - {5, 20, 1, 0, 2}, /* TxD7 */ - {5, 15, 2, 0, 2}, /* RxD0 */ - {5, 14, 2, 0, 2}, /* RxD1 */ - {5, 13, 2, 0, 2}, /* RxD2 */ - {5, 12, 2, 0, 2}, /* RxD3 */ - {5, 29, 2, 0, 2}, /* RxD4 */ - {5, 28, 2, 0, 2}, /* RxD5 */ - {5, 27, 2, 0, 3}, /* RxD6 */ - {5, 26, 2, 0, 2}, /* RxD7 */ - {5, 11, 1, 0, 2}, /* TX_EN */ - {5, 24, 1, 0, 2}, /* TX_ER */ - {5, 16, 2, 0, 2}, /* RX_DV */ - {5, 30, 2, 0, 2}, /* RX_ER */ - {5, 17, 2, 0, 2}, /* RX_CLK */ - {5, 19, 1, 0, 2}, /* GTX_CLK */ - {1, 31, 2, 0, 3}, /* GTX125 */ - {4, 6, 3, 0, 2}, /* MDIO */ - {4, 5, 1, 0, 2}, /* MDC */ + {5, 10, 1, 0, 2, -1}, /* TxD0 */ + {5, 9, 1, 0, 2, -1}, /* TxD1 */ + {5, 8, 1, 0, 2, -1}, /* TxD2 */ + {5, 7, 1, 0, 2, -1}, /* TxD3 */ + {5, 23, 1, 0, 2, -1}, /* TxD4 */ + {5, 22, 1, 0, 2, -1}, /* TxD5 */ + {5, 21, 1, 0, 2, -1}, /* TxD6 */ + {5, 20, 1, 0, 2, -1}, /* TxD7 */ + {5, 15, 2, 0, 2, -1}, /* RxD0 */ + {5, 14, 2, 0, 2, -1}, /* RxD1 */ + {5, 13, 2, 0, 2, -1}, /* RxD2 */ + {5, 12, 2, 0, 2, -1}, /* RxD3 */ + {5, 29, 2, 0, 2, -1}, /* RxD4 */ + {5, 28, 2, 0, 2, -1}, /* RxD5 */ + {5, 27, 2, 0, 3, -1}, /* RxD6 */ + {5, 26, 2, 0, 2, -1}, /* RxD7 */ + {5, 11, 1, 0, 2, -1}, /* TX_EN */ + {5, 24, 1, 0, 2, -1}, /* TX_ER */ + {5, 16, 2, 0, 2, -1}, /* RX_DV */ + {5, 30, 2, 0, 2, -1}, /* RX_ER */ + {5, 17, 2, 0, 2, -1}, /* RX_CLK */ + {5, 19, 1, 0, 2, -1}, /* GTX_CLK */ + {1, 31, 2, 0, 3, -1}, /* GTX125 */ + {4, 6, 3, 0, 2, -1}, /* MDIO */ + {4, 5, 1, 0, 2, -1}, /* MDC */
/* UART1 */ - {2, 0, 1, 0, 2}, /* UART_SOUT1 */ - {2, 1, 1, 0, 2}, /* UART_RTS1 */ - {2, 2, 2, 0, 2}, /* UART_CTS1 */ - {2, 3, 2, 0, 2}, /* UART_SIN1 */ + {2, 0, 1, 0, 2, -1}, /* UART_SOUT1 */ + {2, 1, 1, 0, 2, -1}, /* UART_RTS1 */ + {2, 2, 2, 0, 2, -1}, /* UART_CTS1 */ + {2, 3, 2, 0, 2, -1}, /* UART_SIN1 */
--- a/common/Makefile 2008-01-23 15:41:38.000000000 +0200 +++ b/common/Makefile 2008-02-07 11:09:18.087398000 +0200 @@ -76,6 +76,7 @@ COBJS-y += cmd_nand.o COBJS-$(CONFIG_CMD_NET) += cmd_net.o COBJS-y += cmd_nvedit.o COBJS-y += cmd_onenand.o +COBJS-$(CONFIG_CMD_PARIO) += cmd_pario.o ifdef CONFIG_PCI COBJS-$(CONFIG_CMD_PCI) += cmd_pci.o endif --- /dev/null 2008-02-04 11:16:39.378100988 +0200 +++ b/common/cmd_pario.c 2008-02-07 10:49:33.000000000 +0200 @@ -0,0 +1,87 @@ +/* + * Copyright 2007 ECI Telecommunication. + * + * (C) Copyright 2002 David Saada david.saada@ecitele.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> + +void qe_read_iopin(u8 port, u8 pin, int *data); +void qe_write_iopin(u8 port, u8 pin, int data); + +int do_pario (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + char op; + int port, pin, data; + static char last_op; + static int last_port, last_pin, last_data; + + /* + * We use the last specified parameters, unless new ones are + * entered. + */ + op = last_op; + port = last_port; + pin = last_pin; + data = last_data; + + if ((flag & CMD_FLAG_REPEAT) == 0) { + op = argv[1][0]; + + if (argc >= 3) + port = simple_strtoul (argv[2], NULL, 10); + if (argc >= 4) + pin = simple_strtoul (argv[3], NULL, 10); + if (argc >= 5) + data = simple_strtoul (argv[4], NULL, 10); + } + + if (op == 'r') { + qe_read_iopin(port ,pin ,&data); + printf("%d\n", data); + } else if (op == 'w') { + qe_write_iopin(port ,pin ,data); + } else { + printf("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + /* + * Save the parameters for repeats. + */ + last_op = op; + last_port = port; + last_pin = pin; + last_data = data; + + return 0; +} + +/***************************************************/ + +U_BOOT_CMD( + pario, 5, 1, do_pario, + "pario - Parallel I/O utility commands\n", + "read <port> <pin> - read from port <port> <pin> \n" + "pario write <port> <pin> <data> - write to port <port> <pin> \n" +); +
- u32 tmp_val;
Don't use volatile. Use the accessor functions: in_be32 and out_be32.
- Copyright 2007 ECI Telecommunication.
Did you mean 2008?
- (C) Copyright 2002 David Saada david.saada@ecitele.com
And here
- project.
- MA 02111-1307 USA
Put these in a header file.
- u32 tmp_val;
This was copied from the qe_config_iopin function, which still used the volatile directive. I can fix it there as well, but I see that it's used everywhere. Maybe this needs a thorough change, but I'm not sure it should be in my humble patch.
Did you mean 2008?
And here
Hehe - will change.
Will change as well. I think ioports.h is good enough for this purpose. So far, qe_config_iopin wasn't there as well, so it will also be moved there.
David.
Yeah, and it's wrong everywhere, too.
Well, we may not have the time to fix all the wrong usages, but we shouldn't make it worse. All new code should use the accessors.
I'm okay with that.
Andy Fleming
David Saada
Timur Tabi
