[PATCH 1/2] mtd: spi-nor: Respect flash's hwcaps in spi_nor_adjust_hwcaps()
The smart spi_nor_adjust_hwcaps() does not respect the SPI flash's hwcaps, and only looks to the controller on what can be supported.
The flash's hwcaps needs to be AND'ed before checking.
Fixes: 71025f013ccb ("mtd: spi-nor-core: Rework hwcaps selection") Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/mtd/spi/spi-nor-core.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 99e2f16349..2883d092fc 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -2861,7 +2861,7 @@ spi_nor_adjust_hwcaps(struct spi_nor *nor, * Enable all caps by default. We will mask them after checking what's * really supported using spi_mem_supports_op(). */ - *hwcaps = SNOR_HWCAPS_ALL; + *hwcaps = SNOR_HWCAPS_ALL & params->hwcaps.mask;
/* X-X-X modes are not supported yet, mask them all. */ *hwcaps &= ~SNOR_HWCAPS_X_X_X;
The DT bindings of "jedec,spi-nor" [1] defines "m25p,fast-read" property to indicate that "fast read" opcode can be used to read data from the chip instead of the usual "read" opcode.
If this property is not present in DT, mask out fast read in spi_nor_init_params(). This change mirrors the same logic in spi_nor_info_init_params() in drivers/mtd/spi-nor/core.c in the Linux kernel v5.14-rc3.
[1] Documentation/devicetree/bindings/mtd/jedec,spi-nor.yaml in the kernel tree
drivers/mtd/spi/spi-nor-core.c | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 2883d092fc..d6a0ed39c5 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -2597,6 +2597,8 @@ static int spi_nor_init_params(struct spi_nor *nor, const struct flash_info *info, struct spi_nor_flash_parameter *params) { + struct spi_slave *spi = nor->spi; + /* Set legacy flash parameters as default. */ memset(params, 0, sizeof(*params));
@@ -2604,18 +2606,25 @@ static int spi_nor_init_params(struct spi_nor *nor, params->size = info->sector_size * info->n_sectors; params->page_size = info->page_size;
+ if (!(info->flags & SPI_NOR_NO_FR)) { + /* Default to Fast Read for DT and non-DT platform devices. */ + params->hwcaps.mask |= SNOR_HWCAPS_READ_FAST; + + /* Mask out Fast Read if not requested at DT instantiation. */ + if (!ofnode_read_bool(dev_ofnode(spi->dev), "m25p,fast-read")) + params->hwcaps.mask &= ~SNOR_HWCAPS_READ_FAST; + } + /* (Fast) Read settings. */ params->hwcaps.mask |= SNOR_HWCAPS_READ; spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ], 0, 0, SPINOR_OP_READ, SNOR_PROTO_1_1_1);
- if (!(info->flags & SPI_NOR_NO_FR)) { - params->hwcaps.mask |= SNOR_HWCAPS_READ_FAST; + if (params->hwcaps.mask & SNOR_HWCAPS_READ_FAST) spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_FAST], 0, 8, SPINOR_OP_READ_FAST, SNOR_PROTO_1_1_1); - }
if (info->flags & SPI_NOR_DUAL_READ) { params->hwcaps.mask |= SNOR_HWCAPS_READ_1_1_2;
Hi Bin,
- struct spi_slave *spi = nor->spi;
- /* Set legacy flash parameters as default. */ memset(params, 0, sizeof(*params));
Do you need to check if dev_ofnode() is valid? Can spi-nor be instantiated from a non-DT platform (like platdata maybe)? I am not very familiar with DT/platdata stuff, other than the basics.
- /* (Fast) Read settings. */ params->hwcaps.mask |= SNOR_HWCAPS_READ; spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ], 0, 0, SPINOR_OP_READ, SNOR_PROTO_1_1_1);
- if (params->hwcaps.mask & SNOR_HWCAPS_READ_FAST) spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_FAST], 0, 8, SPINOR_OP_READ_FAST, SNOR_PROTO_1_1_1);
The patch looks good to me other than the point above.
if (info->flags & SPI_NOR_DUAL_READ) { params->hwcaps.mask |= SNOR_HWCAPS_READ_1_1_2; -- 2.25.1
Hi Bin,
Please update the comment above. Maybe:
Start by assuming the controller supports every cap. We will mask them...
- *hwcaps = SNOR_HWCAPS_ALL & params->hwcaps.mask;
This is practically equivalent to *hwcaps = params->hwcaps.mask but I think having SNOR_HWCAPS_ALL here to signify that we are assuming controller supports everything is not a bad idea IMO.
With the above comment updated,
Reviewed-by: Pratyush Yadav p.yadav@ti.com
Thanks.
2.25.1
Hi Pratyush,
On Thu, Jul 29, 2021 at 8:08 PM Pratyush Yadav p.yadav@ti.com wrote:
Hi Bin,
Thanks for the review! Will update comments in v2.
Regards, Bin
Bin Meng
Pratyush Yadav
