[U-Boot] [PATCH] omap3: cm-t3517: add board specific get_board_rev()
CM-T3517 has several HW revisions. Add board specific get_board_rev() callback to retrieve revision number.
Signed-off-by: Dmitry Lifshitz lifshitz@compulab.co.il --- board/compulab/cm_t3517/cm_t3517.c | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/board/compulab/cm_t3517/cm_t3517.c b/board/compulab/cm_t3517/cm_t3517.c index 03b2bad..bf7dec2 100644 --- a/board/compulab/cm_t3517/cm_t3517.c +++ b/board/compulab/cm_t3517/cm_t3517.c @@ -98,6 +98,15 @@ int board_init(void) return 0; }
+/* + * Routine: get_board_rev + * Description: read system revision + */ +u32 get_board_rev(void) +{ + return cl_eeprom_get_board_rev(); +}; + int misc_init_r(void) { cl_print_pcb_info();
Hi Dima,
- Routine: get_board_rev
- Description: read system revision
- return cl_eeprom_get_board_rev();
will this compile on the recent U-Boot?
Igor, Tom
I forgot to add a mailing list address in send-email. Resending the patch.
v2: Make proper use of cl_eeprom_get_board_rev() parameter.
board/compulab/cm_t3517/cm_t3517.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/board/compulab/cm_t3517/cm_t3517.c b/board/compulab/cm_t3517/cm_t3517.c index d1c74db..8aae248 100644 --- a/board/compulab/cm_t3517/cm_t3517.c +++ b/board/compulab/cm_t3517/cm_t3517.c @@ -98,6 +98,15 @@ int board_init(void) return 0; }
+/* + * Routine: get_board_rev + * Description: read system revision + */ +u32 get_board_rev(void) +{ + return cl_eeprom_get_board_rev(CONFIG_SYS_I2C_EEPROM_BUS); +}; + int misc_init_r(void) { cl_print_pcb_info();
Reviewed-by: Igor Grinberg grinberg@compulab.co.il
Igor, Tom
you may want to use aliases to simplify the stuff, check out doc/git-mailrc.
- return cl_eeprom_get_board_rev(CONFIG_SYS_I2C_EEPROM_BUS);
Signed-off-by: Dmitry Lifshitz lifshitz@compulab.co.il Reviewed-by: Igor Grinberg grinberg@compulab.co.il
Dmitry Lifshitz
Igor Grinberg
