[PATCH] arm: mvebu : sata_mv should probe all ports
While a board could have multiple SATA ports, some of the ports might not have a disk attached to them. So while probing for disks, sata_mv_probe() should continue probing all ports, and skip one with no disk attached.
Tests with:
- Seagate Goflex Net (Marvell Kirkwood 88F6281) out-of-tree u-boot. - Zyxel NSA325 (Marvell Kirkwood 88F6282 out-of-tree u-boot.
Observation:
If a board has 2 or more SATA ports, and there is only one disk attached to one of the ports, sata_mv_probe() does not return a successful probe status. And if only one disk is attached to the 2nd port (i.e. port 1), it is not probed at all.
Patch Description:
Let sata_mv_probe() continues probing all ports, even if there is error in probing a given port, and then return a successful status if there is at least one port was probed successfully.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
drivers/ata/sata_mv.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c index dadb2c7c2e..003222d47b 100644 --- a/drivers/ata/sata_mv.c +++ b/drivers/ata/sata_mv.c @@ -1068,6 +1068,7 @@ static int sata_mv_probe(struct udevice *dev) int nr_ports; int ret; int i; + int status = -ENODEV; /* If the probe fails to detected any SATA port */
/* Get number of ports of this SATA controller */ nr_ports = min(fdtdec_get_int(blob, node, "nr-ports", -1), @@ -1078,7 +1079,7 @@ static int sata_mv_probe(struct udevice *dev) IF_TYPE_SATA, -1, 512, 0, &blk); if (ret) { debug("Can't create device\n"); - return ret; + continue; }
priv = dev_get_plat(blk); @@ -1088,18 +1089,23 @@ static int sata_mv_probe(struct udevice *dev) ret = sata_mv_init_sata(blk, i); if (ret) { debug("%s: Failed to init bus\n", __func__); - return ret; + continue; }
/* Scan SATA port */ ret = sata_mv_scan_sata(blk, i); if (ret) { debug("%s: Failed to scan bus\n", __func__); - return ret; + continue; } + + /* If we got here, the current SATA port was probed + * successfully, so set the probe status to successful. + */ + status = 0; }
- return 0; + return status; }
static int sata_mv_scan(struct udevice *dev)
Tests with:
Observation:
Patch Description:
Thanks, Stefan
return ret;
continue;
return ret;
continue;
return ret;
}continue;
}status = 0;
return status; }
Viele Grüße, Stefan
Stefan Roese
Tony Dinh
