[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit 3c99166441bf3ea325af2da83cfe65430b49c066:
Prepare v2019.04 (2019-04-08 21:40:40 -0400)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to ef8679b24ec6226b7198e06747ff047a16030ca4:
arm: dts: Stratix10: Add QSPI node (2019-04-09 13:11:06 +0200)
---------------------------------------------------------------- Ley Foon Tan (7): ddr: altera: stratix10: Move SDRAM size check to SDRAM driver ddr: altera: Stratix10: Add multi-banks DRAM size check configs: stratix10: Change CONFIG_NR_DRAM_BANKS to 2 arm: dts: Stratix10: Modify stratix10 socdk memory node arm: socfpga: stratix10: Add cpu_has_been_warmreset() ddr: altera: Stratix10: Add ECC memory scrubbing arm: dts: Stratix10: Add QSPI node
Simon Goldschmidt (9): arm: socfpga: gen5: sync devicetrees to Linux arm: socfpga: gen5: add reset & sdr node to SPL devicetrees reset: socfpga: rename membase ptr to modrst_base arm: socfpga: gen5: deassert peripheral reset by default reset: socfpga: add reset handling for old kernels arm: socfpga: move gen5 SDR driver to DM mtd: rawnand: denali: add reset handling spi: cadence_qspi: add reset handling arm: socfpga: implement proper peripheral reset
arch/arm/Kconfig | 2 ++ arch/arm/dts/socfpga-common-u-boot.dtsi | 19 ++++++++++++++++++ arch/arm/dts/socfpga.dtsi | 23 ++++++++++++++++++---- arch/arm/dts/socfpga_arria5_socdk-u-boot.dtsi | 6 ++---- arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts | 5 +---- arch/arm/dts/socfpga_cyclone5_de0_nano_soc-u-boot.dtsi | 6 ++---- arch/arm/dts/socfpga_cyclone5_de10_nano.dts | 5 +---- arch/arm/dts/socfpga_cyclone5_de1_soc.dts | 5 +---- arch/arm/dts/socfpga_cyclone5_is1.dts | 5 +---- arch/arm/dts/socfpga_cyclone5_socdk-u-boot.dtsi | 6 ++---- arch/arm/dts/socfpga_cyclone5_sockit-u-boot.dtsi | 6 ++---- arch/arm/dts/socfpga_cyclone5_socrates-u-boot.dtsi | 6 ++---- arch/arm/dts/socfpga_cyclone5_socrates.dts | 2 -- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 5 +---- arch/arm/dts/socfpga_cyclone5_vining_fpga-u-boot.dtsi | 6 ++---- arch/arm/dts/socfpga_stratix10.dtsi | 13 ++++++++++++ arch/arm/dts/socfpga_stratix10_socdk-u-boot.dtsi | 25 +++++++++++++++++++++++ arch/arm/dts/socfpga_stratix10_socdk.dts | 39 +++++++++++++++++++++++++++++++++++- arch/arm/mach-socfpga/include/mach/reset_manager_s10.h | 3 +++ arch/arm/mach-socfpga/include/mach/sdram_gen5.h | 4 ---- arch/arm/mach-socfpga/include/mach/sdram_s10.h | 9 +++++++++ arch/arm/mach-socfpga/misc_gen5.c | 10 ---------- arch/arm/mach-socfpga/reset_manager_s10.c | 9 +++++++++ arch/arm/mach-socfpga/spl_gen5.c | 38 ++++++++++------------------------- arch/arm/mach-socfpga/spl_s10.c | 11 ----------- configs/socfpga_stratix10_defconfig | 2 +- drivers/ddr/altera/Kconfig | 1 + drivers/ddr/altera/sdram_gen5.c | 143 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------- drivers/ddr/altera/sdram_s10.c | 136 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-- drivers/ddr/altera/sequencer.c | 9 ++++++++- drivers/ddr/altera/sequencer.h | 35 +++++++++++++++++++++++++++++++++ drivers/mtd/nand/raw/denali.h | 2 ++ drivers/mtd/nand/raw/denali_dt.c | 15 ++++++++++++++ drivers/reset/reset-socfpga.c | 55 ++++++++++++++++++++++++++++++++++++++++++++++----- drivers/spi/cadence_qspi.c | 17 ++++++++++++++++ drivers/spi/cadence_qspi.h | 4 ++++ include/configs/socfpga_common.h | 1 + 37 files changed, 560 insertions(+), 128 deletions(-) create mode 100644 arch/arm/dts/socfpga-common-u-boot.dtsi mode change 100644 => 100755 arch/arm/dts/socfpga_stratix10.dtsi create mode 100755 arch/arm/dts/socfpga_stratix10_socdk-u-boot.dtsi mode change 100644 => 100755 arch/arm/dts/socfpga_stratix10_socdk.dts
Arg, sorry I didn't see this sooner: arm: w+ socfpga_arria10 +(socfpga_arria10) +(socfpga_arria10) WARNING: unmet direct dependencies detected for ALTERA_SDRAM +(socfpga_arria10) Depends on [n]: RAM [=n] && (TARGET_SOCFPGA_GEN5 [=n] || TARGET_SOCFPGA_ARRIA10 [=y]) +(socfpga_arria10) Selected by [y]: +(socfpga_arria10) - TARGET_SOCFPGA_ARRIA10 [=y] && ARM [=y] && ARCH_SOCFPGA [=y]
Is this coming from this PR or not ?
Yes, this PR. Top of tree + this PR only.
It's not only top of tree + this PR, it also fails for pure u-boot-socfpga/master.
Seems like this bug has been introduced when I made the gen5 driver depend on RAM. Unfortunately, all the drivers use one Kconfig item (although these are totally different drivers) but now only gen5 depends on RAM. Is there any Kconfig magic to fix this without duplicating the config item entries?
I think you may want something more like: diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 04a207c9403e..4a23e327dfb4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -821,14 +821,12 @@ config ARCH_SOCFPGA select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select OF_CONTROL - select RAM if TARGET_SOCFPGA_GEN5 select SPL_DM_RESET if DM_RESET select SPL_DM_SERIAL select SPL_LIBCOMMON_SUPPORT select SPL_LIBGENERIC_SUPPORT select SPL_NAND_SUPPORT if SPL_NAND_DENALI select SPL_OF_CONTROL - select SPL_RAM if TARGET_SOCFPGA_GEN5 select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10 select SPL_SERIAL_SUPPORT select SPL_WATCHDOG_SUPPORT diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig index 7370d4133a67..8f60b56eb848 100644 --- a/drivers/ddr/altera/Kconfig +++ b/drivers/ddr/altera/Kconfig @@ -1,6 +1,7 @@ config ALTERA_SDRAM bool "SoCFPGA DDR SDRAM driver" - depends on RAM depends on TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 + select RAM if TARGET_SOCFPGA_GEN5 + select SPL_RAM if TARGET_SOCFPGA_GEN5 help Enable DDR SDRAM controller for the SoCFPGA devices.
But I didn't test anything other than socfpga_arria10/arria5 as building.
- select SPL_RAM if TARGET_SOCFPGA_GEN5 help Enable DDR SDRAM controller for the SoCFPGA devices.
Tom, Thanks for the hint. I did just that and it works for me (cyclone5). As only this platform is affected by this patch, it should be fine.
Marek, how should we proceed? I pushed the change as suggested by Tom to:
https://github.com/goldsimon/u-boot.git
or I could send v5 of the series that broke arria10...?
> The following changes since commit > 3c99166441bf3ea325af2da83cfe65430b49c066: > > Prepare v2019.04 (2019-04-08 21:40:40 -0400) > > are available in the Git repository at: > > git://git.denx.de/u-boot-socfpga.git master > > for you to fetch changes up to > ef8679b24ec6226b7198e06747ff047a16030ca4: > > arm: dts: Stratix10: Add QSPI node (2019-04-09 13:11:06 +0200) >
Send me a single patch on top of u-boot-socfpga/master, I'll add it and that should take care of it. It would also make things well documented for other people who run into this.
Marek Vasut marex@denx.de schrieb am Do., 11. Apr. 2019, 21:59:
On 4/11/19 8:17 PM, Tom Rini wrote: > On Wed, Apr 10, 2019 at 04:46:28PM +0200, Marek Vasut wrote: > >> The following changes since commit >> 3c99166441bf3ea325af2da83cfe65430b49c066: >> >> Prepare v2019.04 (2019-04-08 21:40:40 -0400) >> >> are available in the Git repository at: >> >> git://git.denx.de/u-boot-socfpga.git master >> >> for you to fetch changes up to >> ef8679b24ec6226b7198e06747ff047a16030ca4: >> >> arm: dts: Stratix10: Add QSPI node (2019-04-09 13:11:06 +0200) >> > > Arg, sorry I didn't see this sooner: > arm: w+ socfpga_arria10 > +(socfpga_arria10) > +(socfpga_arria10) WARNING: unmet direct dependencies detected for > ALTERA_SDRAM > +(socfpga_arria10) Depends on [n]: RAM [=n] && > (TARGET_SOCFPGA_GEN5 [=n] || TARGET_SOCFPGA_ARRIA10 [=y]) > +(socfpga_arria10) Selected by [y]: > +(socfpga_arria10) - TARGET_SOCFPGA_ARRIA10 [=y] && ARM [=y] && > ARCH_SOCFPGA [=y]
To make it clear, patch 6/12 of this PR is ok for gen5 but breaks arria10. This is not something anyone could run into as it's new. I'd rather fix the patches before merging them to master (keep things bisectable for a10).
Unfortunately, I'll be more or less offline until Tuesday. If my github branch isn't enough, I'll send something when I'm back with PC access.
Regards, Simo,
On 4/11/19 10:07 PM, Simon Goldschmidt wrote:
Marek Vasut <marex@denx.de mailto:marex@denx.de> schrieb am Do., 11. Apr. 2019, 21:59:
On 4/11/19 9:30 PM, Simon Goldschmidt wrote: > > > On 11.04.19 21:03, Tom Rini wrote: >> On Thu, Apr 11, 2019 at 08:49:38PM +0200, Simon Goldschmidt wrote: >>> >>> >>> On 11.04.19 20:20, Tom Rini wrote: >>>> On Thu, Apr 11, 2019 at 08:19:38PM +0200, Marek Vasut wrote: >>>>> On 4/11/19 8:17 PM, Tom Rini wrote: >>>>>> On Wed, Apr 10, 2019 at 04:46:28PM +0200, Marek Vasut wrote: >>>>>> >>>>>>> The following changes since commit >>>>>>> 3c99166441bf3ea325af2da83cfe65430b49c066: >>>>>>> >>>>>>> Prepare v2019.04 (2019-04-08 21:40:40 -0400) >>>>>>> >>>>>>> are available in the Git repository at: >>>>>>> >>>>>>> git://git.denx.de/u-boot-socfpga.git <http://git.denx.de/u-boot-socfpga.git> master >>>>>>> >>>>>>> for you to fetch changes up to >>>>>>> ef8679b24ec6226b7198e06747ff047a16030ca4: >>>>>>> >>>>>>> arm: dts: Stratix10: Add QSPI node (2019-04-09 13:11:06 +0200) >>>>>>> >>>>>> >>>>>> Arg, sorry I didn't see this sooner: >>>>>> arm: w+ socfpga_arria10 >>>>>> +(socfpga_arria10) >>>>>> +(socfpga_arria10) WARNING: unmet direct dependencies detected for >>>>>> ALTERA_SDRAM >>>>>> +(socfpga_arria10) Depends on [n]: RAM [=n] && >>>>>> (TARGET_SOCFPGA_GEN5 [=n] || TARGET_SOCFPGA_ARRIA10 [=y]) >>>>>> +(socfpga_arria10) Selected by [y]: >>>>>> +(socfpga_arria10) - TARGET_SOCFPGA_ARRIA10 [=y] && ARM [=y] && >>>>>> ARCH_SOCFPGA [=y] >>>>> >>>>> Is this coming from this PR or not ? >>>> >>>> Yes, this PR. Top of tree + this PR only. >>> >>> It's not only top of tree + this PR, it also fails for pure >>> u-boot-socfpga/master. >>> >>> Seems like this bug has been introduced when I made the gen5 driver >>> depend >>> on RAM. Unfortunately, all the drivers use one Kconfig item (although >>> these >>> are totally different drivers) but now only gen5 depends on RAM. Is >>> there >>> any Kconfig magic to fix this without duplicating the config item >>> entries? >> >> I think you may want something more like: >> diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig >> index 04a207c9403e..4a23e327dfb4 100644 >> --- a/arch/arm/Kconfig >> +++ b/arch/arm/Kconfig >> @@ -821,14 +821,12 @@ config ARCH_SOCFPGA >> select DM_SERIAL >> select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || >> TARGET_SOCFPGA_ARRIA10 >> select OF_CONTROL >> - select RAM if TARGET_SOCFPGA_GEN5 >> select SPL_DM_RESET if DM_RESET >> select SPL_DM_SERIAL >> select SPL_LIBCOMMON_SUPPORT >> select SPL_LIBGENERIC_SUPPORT >> select SPL_NAND_SUPPORT if SPL_NAND_DENALI >> select SPL_OF_CONTROL >> - select SPL_RAM if TARGET_SOCFPGA_GEN5 >> select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10 >> select SPL_SERIAL_SUPPORT >> select SPL_WATCHDOG_SUPPORT >> diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig >> index 7370d4133a67..8f60b56eb848 100644 >> --- a/drivers/ddr/altera/Kconfig >> +++ b/drivers/ddr/altera/Kconfig >> @@ -1,6 +1,7 @@ >> config ALTERA_SDRAM >> bool "SoCFPGA DDR SDRAM driver" >> - depends on RAM >> depends on TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 >> + select RAM if TARGET_SOCFPGA_GEN5 >> + select SPL_RAM if TARGET_SOCFPGA_GEN5 >> help >> Enable DDR SDRAM controller for the SoCFPGA devices. >> >> But I didn't test anything other than socfpga_arria10/arria5 as >> building. > > Tom, > Thanks for the hint. I did just that and it works for me (cyclone5). > As only this platform is affected by this patch, it should be fine. > > Marek, > how should we proceed? I pushed the change as suggested by Tom to: > > https://github.com/goldsimon/u-boot.git > > or I could send v5 of the series that broke arria10...? Send me a single patch on top of u-boot-socfpga/master, I'll add it and that should take care of it. It would also make things well documented for other people who run into this.
I can squash the patch(es), that's fine. I just need the patch posted to the ML.
Hi Marek,
Am 12.04.2019 um 12:31 schrieb Marek Vasut:
Ok, I'm back online. I've just sent the updated patch to fix the build issue to the ML (see https://patchwork.ozlabs.org/patch/1086623/). This one is meant as replacement for 82b40a096410 in current u-boot-socfpga/master.
Let me know if there's anything else missing. Once this is applied, I'll prepare a PR for the next batch.
On 4/16/19 10:08 PM, Simon Goldschmidt wrote:
Hi Marek,
On 4/11/19 9:30 PM, Simon Goldschmidt wrote: > > > On 11.04.19 21:03, Tom Rini wrote: >> On Thu, Apr 11, 2019 at 08:49:38PM +0200, Simon Goldschmidt wrote: >>> >>> >>> On 11.04.19 20:20, Tom Rini wrote: >>>> On Thu, Apr 11, 2019 at 08:19:38PM +0200, Marek Vasut wrote: >>>>> On 4/11/19 8:17 PM, Tom Rini wrote: >>>>>> On Wed, Apr 10, 2019 at 04:46:28PM +0200, Marek Vasut wrote: >>>>>> >>>>>>> The following changes since commit >>>>>>> 3c99166441bf3ea325af2da83cfe65430b49c066: >>>>>>> >>>>>>> Prepare v2019.04 (2019-04-08 21:40:40 -0400) >>>>>>> >>>>>>> are available in the Git repository at: >>>>>>> >>>>>>> git://git.denx.de/u-boot-socfpga.git http://git.denx.de/u-boot-socfpga.git master >>>>>>> >>>>>>> for you to fetch changes up to >>>>>>> ef8679b24ec6226b7198e06747ff047a16030ca4: >>>>>>> >>>>>>> arm: dts: Stratix10: Add QSPI node (2019-04-09 13:11:06 +0200) >>>>>>> >>>>>> >>>>>> Arg, sorry I didn't see this sooner: >>>>>> arm: w+ socfpga_arria10 >>>>>> +(socfpga_arria10) >>>>>> +(socfpga_arria10) WARNING: unmet direct dependencies detected for >>>>>> ALTERA_SDRAM >>>>>> +(socfpga_arria10) Depends on [n]: RAM [=n] && >>>>>> (TARGET_SOCFPGA_GEN5 [=n] || TARGET_SOCFPGA_ARRIA10 [=y]) >>>>>> +(socfpga_arria10) Selected by [y]: >>>>>> +(socfpga_arria10) - TARGET_SOCFPGA_ARRIA10 [=y] && ARM [=y] && >>>>>> ARCH_SOCFPGA [=y] >>>>> >>>>> Is this coming from this PR or not ? >>>> >>>> Yes, this PR. Top of tree + this PR only. >>> >>> It's not only top of tree + this PR, it also fails for pure >>> u-boot-socfpga/master. >>> >>> Seems like this bug has been introduced when I made the gen5 driver >>> depend >>> on RAM. Unfortunately, all the drivers use one Kconfig item (although >>> these >>> are totally different drivers) but now only gen5 depends on RAM. Is >>> there >>> any Kconfig magic to fix this without duplicating the config item >>> entries? >> >> I think you may want something more like: >> diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig >> index 04a207c9403e..4a23e327dfb4 100644 >> --- a/arch/arm/Kconfig >> +++ b/arch/arm/Kconfig >> @@ -821,14 +821,12 @@ config ARCH_SOCFPGA >> select DM_SERIAL >> select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || >> TARGET_SOCFPGA_ARRIA10 >> select OF_CONTROL >> - select RAM if TARGET_SOCFPGA_GEN5 >> select SPL_DM_RESET if DM_RESET >> select SPL_DM_SERIAL >> select SPL_LIBCOMMON_SUPPORT >> select SPL_LIBGENERIC_SUPPORT >> select SPL_NAND_SUPPORT if SPL_NAND_DENALI >> select SPL_OF_CONTROL >> - select SPL_RAM if TARGET_SOCFPGA_GEN5 >> select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10 >> select SPL_SERIAL_SUPPORT >> select SPL_WATCHDOG_SUPPORT >> diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig >> index 7370d4133a67..8f60b56eb848 100644 >> --- a/drivers/ddr/altera/Kconfig >> +++ b/drivers/ddr/altera/Kconfig >> @@ -1,6 +1,7 @@ >> config ALTERA_SDRAM >> bool "SoCFPGA DDR SDRAM driver" >> - depends on RAM >> depends on TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 >> + select RAM if TARGET_SOCFPGA_GEN5 >> + select SPL_RAM if TARGET_SOCFPGA_GEN5 >> help >> Enable DDR SDRAM controller for the SoCFPGA devices. >> >> But I didn't test anything other than socfpga_arria10/arria5 as >> building. > > Tom, > Thanks for the hint. I did just that and it works for me (cyclone5). > As only this platform is affected by this patch, it should be fine. > > Marek, > how should we proceed? I pushed the change as suggested by Tom to: > > https://github.com/goldsimon/u-boot.git > > or I could send v5 of the series that broke arria10...?
I was hoping for a patch I can squash into the previous one, so the diff would be easily visible. Oh well, applied, let's see what CI has to say now.
Marek Vasut marex@denx.de schrieb am Di., 16. Apr. 2019, 23:14:
Hi Marek,
Ok, thanks. So did CI complain? All I saw seemed good. Should I send my pending patches on top of master once this PR is through or on top of u-boot-socfpga?
On 4/19/19 10:47 PM, Simon Goldschmidt wrote:
Marek Vasut <marex@denx.de mailto:marex@denx.de> schrieb am Di., 16. Apr. 2019, 23:14:
On 4/16/19 10:08 PM, Simon Goldschmidt wrote: > Hi Marek, > > Am 12.04.2019 um 12:31 schrieb Marek Vasut: >> On 4/11/19 10:07 PM, Simon Goldschmidt wrote: >>> >>> >>> Marek Vasut <marex@denx.de <mailto:marex@denx.de> <mailto:marex@denx.de <mailto:marex@denx.de>>> schrieb am Do., 11. >>> Apr. 2019, 21:59: >>> >>> On 4/11/19 9:30 PM, Simon Goldschmidt wrote: >>> > >>> > >>> > On 11.04.19 21:03, Tom Rini wrote: >>> >> On Thu, Apr 11, 2019 at 08:49:38PM +0200, Simon Goldschmidt >>> wrote: >>> >>> >>> >>> >>> >>> On 11.04.19 20:20, Tom Rini wrote: >>> >>>> On Thu, Apr 11, 2019 at 08:19:38PM +0200, Marek Vasut wrote: >>> >>>>> On 4/11/19 8:17 PM, Tom Rini wrote: >>> >>>>>> On Wed, Apr 10, 2019 at 04:46:28PM +0200, Marek Vasut wrote: >>> >>>>>> >>> >>>>>>> The following changes since commit >>> >>>>>>> 3c99166441bf3ea325af2da83cfe65430b49c066: >>> >>>>>>> >>> >>>>>>> Prepare v2019.04 (2019-04-08 21:40:40 -0400) >>> >>>>>>> >>> >>>>>>> are available in the Git repository at: >>> >>>>>>> >>> >>>>>>> git://git.denx.de/u-boot-socfpga.git <http://git.denx.de/u-boot-socfpga.git> >>> <http://git.denx.de/u-boot-socfpga.git> master >>> >>>>>>> >>> >>>>>>> for you to fetch changes up to >>> >>>>>>> ef8679b24ec6226b7198e06747ff047a16030ca4: >>> >>>>>>> >>> >>>>>>> arm: dts: Stratix10: Add QSPI node (2019-04-09 13:11:06 >>> +0200) >>> >>>>>>> >>> >>>>>> >>> >>>>>> Arg, sorry I didn't see this sooner: >>> >>>>>> arm: w+ socfpga_arria10 >>> >>>>>> +(socfpga_arria10) >>> >>>>>> +(socfpga_arria10) WARNING: unmet direct dependencies >>> detected for >>> >>>>>> ALTERA_SDRAM >>> >>>>>> +(socfpga_arria10) Depends on [n]: RAM [=n] && >>> >>>>>> (TARGET_SOCFPGA_GEN5 [=n] || TARGET_SOCFPGA_ARRIA10 [=y]) >>> >>>>>> +(socfpga_arria10) Selected by [y]: >>> >>>>>> +(socfpga_arria10) - TARGET_SOCFPGA_ARRIA10 [=y] && ARM >>> [=y] && >>> >>>>>> ARCH_SOCFPGA [=y] >>> >>>>> >>> >>>>> Is this coming from this PR or not ? >>> >>>> >>> >>>> Yes, this PR. Top of tree + this PR only. >>> >>> >>> >>> It's not only top of tree + this PR, it also fails for pure >>> >>> u-boot-socfpga/master. >>> >>> >>> >>> Seems like this bug has been introduced when I made the gen5 >>> driver >>> >>> depend >>> >>> on RAM. Unfortunately, all the drivers use one Kconfig item >>> (although >>> >>> these >>> >>> are totally different drivers) but now only gen5 depends on >>> RAM. Is >>> >>> there >>> >>> any Kconfig magic to fix this without duplicating the config >>> item >>> >>> entries? >>> >> >>> >> I think you may want something more like: >>> >> diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig >>> >> index 04a207c9403e..4a23e327dfb4 100644 >>> >> --- a/arch/arm/Kconfig >>> >> +++ b/arch/arm/Kconfig >>> >> @@ -821,14 +821,12 @@ config ARCH_SOCFPGA >>> >> select DM_SERIAL >>> >> select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || >>> >> TARGET_SOCFPGA_ARRIA10 >>> >> select OF_CONTROL >>> >> - select RAM if TARGET_SOCFPGA_GEN5 >>> >> select SPL_DM_RESET if DM_RESET >>> >> select SPL_DM_SERIAL >>> >> select SPL_LIBCOMMON_SUPPORT >>> >> select SPL_LIBGENERIC_SUPPORT >>> >> select SPL_NAND_SUPPORT if SPL_NAND_DENALI >>> >> select SPL_OF_CONTROL >>> >> - select SPL_RAM if TARGET_SOCFPGA_GEN5 >>> >> select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10 >>> >> select SPL_SERIAL_SUPPORT >>> >> select SPL_WATCHDOG_SUPPORT >>> >> diff --git a/drivers/ddr/altera/Kconfig >>> b/drivers/ddr/altera/Kconfig >>> >> index 7370d4133a67..8f60b56eb848 100644 >>> >> --- a/drivers/ddr/altera/Kconfig >>> >> +++ b/drivers/ddr/altera/Kconfig >>> >> @@ -1,6 +1,7 @@ >>> >> config ALTERA_SDRAM >>> >> bool "SoCFPGA DDR SDRAM driver" >>> >> - depends on RAM >>> >> depends on TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 >>> >> + select RAM if TARGET_SOCFPGA_GEN5 >>> >> + select SPL_RAM if TARGET_SOCFPGA_GEN5 >>> >> help >>> >> Enable DDR SDRAM controller for the SoCFPGA devices. >>> >> >>> >> But I didn't test anything other than socfpga_arria10/arria5 as >>> >> building. >>> > >>> > Tom, >>> > Thanks for the hint. I did just that and it works for me >>> (cyclone5). >>> > As only this platform is affected by this patch, it should be >>> fine. >>> > >>> > Marek, >>> > how should we proceed? I pushed the change as suggested by Tom >>> to: >>> > >>> > https://github.com/goldsimon/u-boot.git >>> > >>> > or I could send v5 of the series that broke arria10...? >>> >>> Send me a single patch on top of u-boot-socfpga/master, I'll add >>> it and >>> that should take care of it. It would also make things well >>> documented >>> for other people who run into this. >>> >>> >>> To make it clear, patch 6/12 of this PR is ok for gen5 but breaks >>> arria10. This is not something anyone could run into as it's new. I'd >>> rather fix the patches before merging them to master (keep things >>> bisectable for a10). >>> >>> Unfortunately, I'll be more or less offline until Tuesday. If my github >>> branch isn't enough, I'll send something when I'm back with PC access. >> >> I can squash the patch(es), that's fine. I just need the patch posted to >> the ML. > > Ok, I'm back online. I've just sent the updated patch to fix the build > issue to the ML (see https://patchwork.ozlabs.org/patch/1086623/). This > one is meant as replacement for 82b40a096410 in current > u-boot-socfpga/master. > > Let me know if there's anything else missing. Once this is applied, I'll > prepare a PR for the next batch. I was hoping for a patch I can squash into the previous one, so the diff would be easily visible. Oh well, applied, let's see what CI has to say now.
Travis crashed once, so I had to restart it. Now it succeeded.
Feel free to send me a PR on top of u-boot-socfpga/master .
Simon Goldschmidt
