[U-Boot] [PATCH 1/3] fdt: Add board specific dts inclusion
Some architectures, for example Microblaze, doesn't need a splitted device tree because every Microblaze hw design is different. The individuell Microblaze device tree will be auto generated by FPGA design tools and could be used directly with dtc.
The auto generated dts for Microblaze can not processed by CPP. Unfortunately that is the default procedure in U-Boot to merge a splitted device tree (substitution of ARCH_CPU_DTS).
Microblaze will never use the ARCH_CPU_DTS substitution and we introduce the new board specific substitution variable BOARD_DTS that points into vendor/board/dts subdir with the file name of CONFIG_DEFAULT_DEVICE_TREE. The common dts file in vendor/dts subdir (defined by CONFIG_DEFAULT_DEVICE_TREE) contain a single include line that can processed by CPP:
/include/ BOARD_DTS
Signed-off-by: Stephan Linz linz@li-pro.net --- dts/Makefile | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/dts/Makefile b/dts/Makefile index 914e479..b1f47a1 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -36,7 +36,8 @@ $(error Your architecture does not have device tree support enabled. \ Please define CONFIG_ARCH_DEVICE_TREE))
# We preprocess the device tree file provide a useful define -DTS_CPPFLAGS := -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi" +DTS_CPPFLAGS := -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi" \ + -DBOARD_DTS="$(SRCTREE)/board/$(VENDOR)/$(BOARD)/dts/$(DEVICE_TREE).dts"
all: $(obj).depend $(LIB)
- enable OF control and embedded OF - set default device tree file name to 'microblaze' - add CPP to dtc proxy: board/xilinx/dts/microblaze.dts - add an empty but processable dts for microblaze-generic
Signed-off-by: Stephan Linz linz@li-pro.net --- board/xilinx/dts/microblaze.dts | 1 + board/xilinx/microblaze-generic/dts/microblaze.dts | 7 +++++++ include/configs/microblaze-generic.h | 5 +++++ 3 files changed, 13 insertions(+), 0 deletions(-) create mode 100644 board/xilinx/dts/microblaze.dts create mode 100644 board/xilinx/microblaze-generic/dts/microblaze.dts
diff --git a/board/xilinx/dts/microblaze.dts b/board/xilinx/dts/microblaze.dts new file mode 100644 index 0000000..bf984b0 --- /dev/null +++ b/board/xilinx/dts/microblaze.dts @@ -0,0 +1 @@ +/include/ BOARD_DTS diff --git a/board/xilinx/microblaze-generic/dts/microblaze.dts b/board/xilinx/microblaze-generic/dts/microblaze.dts new file mode 100644 index 0000000..2033309 --- /dev/null +++ b/board/xilinx/microblaze-generic/dts/microblaze.dts @@ -0,0 +1,7 @@ +/dts-v1/; +/ { + #address-cells = <1>; + #size-cells = <1>; + aliases { + } ; +} ; diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 2fd2279..386189f 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -31,6 +31,11 @@ #define CONFIG_MICROBLAZE 1 #define MICROBLAZE_V5 1
+/* Open Firmware DTS */ +#define CONFIG_OF_CONTROL 1 +#define CONFIG_OF_EMBED 1 +#define CONFIG_DEFAULT_DEVICE_TREE microblaze + /* linear flash memory */ #ifdef XILINX_FLASH_START #define FLASH
Signed-off-by: Stephan Linzlinz@li-pro.net
- #address-cells =<1>;
- #size-cells =<1>;
- aliases {
- /* linear flash memory */ #ifdef XILINX_FLASH_START #define FLASH
Applied to microblaze custodian tree.
Thanks, Michal
- expand the condition with CONFIG_OF_CONTROL
Signed-off-by: Stephan Linz linz@li-pro.net --- include/configs/microblaze-generic.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 386189f..01e3421 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -79,7 +79,7 @@
/* ethernet */ #undef CONFIG_SYS_ENET -#if defined(XILINX_EMACLITE_BASEADDR) +#if defined(XILINX_EMACLITE_BASEADDR) || defined(CONFIG_OF_CONTROL) # define CONFIG_XILINX_EMACLITE 1 # define CONFIG_SYS_ENET #endif
#endif
1.7.0.4
On 07/09/2012 11:42 PM, Simon Glass wrote:
On Wed, Jul 4, 2012 at 1:25 PM, Stephan Linz <linz@li-pro.net mailto:linz@li-pro.net> wrote:
- expand the condition with CONFIG_OF_CONTROL Signed-off-by: Stephan Linz <linz@li-pro.net <mailto:linz@li-pro.net>>
Acked-by: Simon Glass <sjg@chromium.org mailto:sjg@chromium.org>
Will be added to Microblaze tree when emaclite dts patch is applied.
Thanks, Michal
/include/ BOARD_DTS
-DBOARD_DTS=\"$(SRCTREE)/board/$(VENDOR)/$(BOARD)/dts/$(DEVICE_TREE).dts\"
Ok. Have tested this. Simon can you give your ACK for this patch?
Tested-by: Michal Simek monstr@monstr.eu
I think I can add this one to my microblaze custodian tree.
Thanks, Michal
/include/ BOARD_DTS
# We preprocess the device tree file provide a useful define -DTS_CPPFLAGS := -DARCH_CPU_DTS="$(SRCTREE)/**arch/$(ARCH)/dts/$(CONFIG_ **ARCH_DEVICE_TREE).dtsi" +DTS_CPPFLAGS := -DARCH_CPU_DTS="$(SRCTREE)/**arch/$(ARCH)/dts/$(CONFIG_ **ARCH_DEVICE_TREE).dtsi" \
-DBOARD_DTS=\"$(SRCTREE)/**board/$(VENDOR)/$(BOARD)/dts/$
**(DEVICE_TREE).dts"
Weill I think for now it is reasonable.
Thanks, Michal
-- Michal Simek, Ing. (M.Eng) w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel 2.6 Microblaze Linux - http://www.monstr.eu/fdt/ Microblaze U-BOOT custodian
On 07/09/2012 11:37 PM, Simon Glass wrote:
On Mon, Jul 9, 2012 at 12:42 AM, Michal Simek <monstr@monstr.eu mailto:monstr@monstr.eu> wrote:
On 07/04/2012 10:25 PM, Stephan Linz wrote: Some architectures, for example Microblaze, doesn't need a splitted device tree because every Microblaze hw design is different. The individuell Microblaze device tree will be auto generated by FPGA design tools and could be used directly with dtc. The auto generated dts for Microblaze can not processed by CPP. Unfortunately that is the default procedure in U-Boot to merge a splitted device tree (substitution of ARCH_CPU_DTS). Microblaze will never use the ARCH_CPU_DTS substitution and we introduce the new board specific substitution variable BOARD_DTS that points into vendor/board/dts subdir with the file name of CONFIG_DEFAULT_DEVICE_TREE. The common dts file in vendor/dts subdir (defined by CONFIG_DEFAULT_DEVICE_TREE) contain a single include line that can processed by CPP: /include/ BOARD_DTS Signed-off-by: Stephan Linz<linz@li-pro.net <mailto:linz@li-pro.net>> --- dts/Makefile | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-) diff --git a/dts/Makefile b/dts/Makefile index 914e479..b1f47a1 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -36,7 +36,8 @@ $(error Your architecture does not have device tree support enabled. \ Please define CONFIG_ARCH_DEVICE_TREE)) # We preprocess the device tree file provide a useful define -DTS_CPPFLAGS := -DARCH_CPU_DTS=\"$(SRCTREE)/__arch/$(ARCH)/dts/$(CONFIG___ARCH_DEVICE_TREE).dtsi\" +DTS_CPPFLAGS := -DARCH_CPU_DTS=\"$(SRCTREE)/__arch/$(ARCH)/dts/$(CONFIG___ARCH_DEVICE_TREE).dtsi\" \ + -DBOARD_DTS=\"$(SRCTREE)/__board/$(VENDOR)/$(BOARD)/dts/$__(DEVICE_TREE).dts\" all: $(obj).depend $(LIB) Ok. Have tested this. Simon can you give your ACK for this patch?
Thanks. Applied to microblaze custodian tree.
Michal
Michal Simek
Stephan Linz
