[U-Boot] [PATCH v2] FIT: delete unnecessary casts
Becuase fdt_check_header function takes (const void *) type argument, the argument should be passed to it without being casted to (char *).
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes for v2: - fix commit log (purely cosmetic) (s/img_addr/the argument/)
common/image-fdt.c | 2 +- common/image-fit.c | 2 +- common/image.c | 6 +----- tools/fit_image.c | 2 +- 4 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 2e22cca..6f9ce7d 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -55,7 +55,7 @@ static const image_header_t *image_get_fdt(ulong fdt_addr) fdt_error("uImage is compressed"); return NULL; } - if (fdt_check_header((char *)image_get_data(fdt_hdr)) != 0) { + if (fdt_check_header((void *)image_get_data(fdt_hdr)) != 0) { fdt_error("uImage data is not a fdt"); return NULL; } diff --git a/common/image-fit.c b/common/image-fit.c index 1c2ef31..a657c13 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1596,7 +1596,7 @@ int fit_image_load(bootm_headers_t *images, const char *prop_name, ulong addr, len = (ulong)size;
/* verify that image data is a proper FDT blob */ - if (image_type == IH_TYPE_FLATDT && fdt_check_header((char *)buf)) { + if (image_type == IH_TYPE_FLATDT && fdt_check_header(buf)) { puts("Subimage data is not a FDT"); return -ENOEXEC; } diff --git a/common/image.c b/common/image.c index 2c88091..e0a4c12 100644 --- a/common/image.c +++ b/common/image.c @@ -652,17 +652,13 @@ int genimg_get_format(const void *img_addr) { ulong format = IMAGE_FORMAT_INVALID; const image_header_t *hdr; -#if defined(CONFIG_FIT) || defined(CONFIG_OF_LIBFDT) - char *fit_hdr; -#endif
hdr = (const image_header_t *)img_addr; if (image_check_magic(hdr)) format = IMAGE_FORMAT_LEGACY; #if defined(CONFIG_FIT) || defined(CONFIG_OF_LIBFDT) else { - fit_hdr = (char *)img_addr; - if (fdt_check_header(fit_hdr) == 0) + if (fdt_check_header(img_addr) == 0) format = IMAGE_FORMAT_FIT; } #endif diff --git a/tools/fit_image.c b/tools/fit_image.c index 47beaaf..0400a60 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -23,7 +23,7 @@ static image_header_t header; static int fit_verify_header (unsigned char *ptr, int image_size, struct mkimage_params *params) { - return fdt_check_header ((void *)ptr); + return fdt_check_header(ptr); }
static int fit_check_image_types (uint8_t type)
- if (fdt_check_header((void *)image_get_data(fdt_hdr)) != 0) { fdt_error("uImage data is not a fdt"); return NULL; }
Not that I care, this is fine with me. Was just wondering if this cast is needed at all. AFAIK it is a cpp thing (and MSVC?) to require it.
Regards, Jeroen
On Wed, Sep 18, 2013 at 9:10 PM, Masahiro Yamada yamada.m@jp.panasonic.comwrote:
Jeroen Hofstee
Masahiro Yamada
