[U-Boot] [PATCH 10/10] arm: socfpga: arria10: Added Arria10 critical HW initialization to spl
This patch adding the Arria10 critical hardware initialization before enabling console print out in spl.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/spl.c | 86 +++++++++++++++++++++++++++++++++++++++++- 1 files changed, 83 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl.c index fec4c7a..9375514 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -1,7 +1,7 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2016 Altera Corporation <www.altera.com> * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0 */
#include <common.h> @@ -19,22 +19,32 @@ #include <asm/arch/sdram.h> #include <asm/arch/scu.h> #include <asm/arch/nic301.h> +#include <asm/sections.h> +#include <watchdog.h> +#include <fdtdec.h> +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/pinmux.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = +#endif + +static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
u32 spl_boot_device(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo);
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) switch (bsel & 0x7) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ return BOOT_DEVICE_RAM; @@ -55,6 +65,24 @@ u32 spl_boot_device(void) printf("Invalid boot device (bsel=%08x)!\n", bsel); hang(); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + switch ((bsel>>12) & 0x7) { + case 0x1: /* FPGA (HPS2FPGA Bridge) */ + return BOOT_DEVICE_RAM; + case 0x2: /* NAND Flash (1.8V) */ + case 0x3: /* NAND Flash (3.0V) */ + return BOOT_DEVICE_NAND; + case 0x4: /* SD/MMC External Transceiver (1.8V) */ + case 0x5: /* SD/MMC Internal Transceiver (3.0V) */ + return BOOT_DEVICE_MMC1; + case 0x6: /* QSPI Flash (1.8V) */ + case 0x7: /* QSPI Flash (3.0V) */ + return BOOT_DEVICE_SPI; + default: + printf("Invalid boot device (bsel=%08x)!\n", bsel); + hang(); + } +#endif }
#ifdef CONFIG_SPL_MMC_SUPPORT @@ -68,6 +96,7 @@ u32 spl_boot_mode(const u32 boot_device) } #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { writel(0x1, &nic301_regs->lwhps2fpgaregs); @@ -182,3 +211,54 @@ void board_init_f(ulong dummy) /* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +void board_init_f(ulong dummy) +{ + memset(__bss_start, 0, __bss_end - __bss_start); + /* + * Configure Clock Manager to use intosc clock instead external osc to + * ensure success watchdog operation. We do it as early as possible. + */ + cm_use_intosc(); + + watchdog_disable(); + + arch_early_init_r(); + +#ifdef CONFIG_HW_WATCHDOG + /* release osc1 watchdog timer 0 from reset */ + reset_deassert_osc1wd0(); + + /* reconfigure and enable the watchdog */ + hw_watchdog_init(); + WATCHDOG_RESET(); +#endif /* CONFIG_HW_WATCHDOG */ + +#ifdef CONFIG_OF_CONTROL + /* We need to access to FDT as this stage */ + /* FDT is at end of image */ + gd->fdt_blob = (void *)(__bss_end); + /* Check whether we have a valid FDT or not. */ + if (fdtdec_prepare_fdt()) { + panic("** CONFIG_OF_CONTROL defined but no FDT - please see " + "doc/README.fdt-control"); + } +#endif /* CONFIG_OF_CONTROL */ + + /* Initialize the timer */ + timer_init(); + + /* configuring the clock based on handoff */ + cm_basic_init(gd->fdt_blob); + WATCHDOG_RESET(); + + config_dedicated_pins(gd->fdt_blob); + WATCHDOG_RESET(); + + /* configure the Reset Manager */ + reset_deassert_dedicated_peripherals(); + + /* enable console uart printing */ + preloader_console_init(); +} +#endif
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach- socfpga/spl.c index fec4c7a..9375514 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c
Any comments on this patch before i start the version 2?
@@ -1,7 +1,7 @@ /*
- * Copyright (C) 2012-2016 Altera Corporation <www.altera.com>
*/ #include <common.h> @@ -19,22 +19,32 @@ #include <asm/arch/sdram.h> #include <asm/arch/scu.h> #include <asm/arch/nic301.h> +#include <asm/sections.h> +#include <watchdog.h> +#include <fdtdec.h> +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/pinmux.h> +#endif DECLARE_GLOBAL_DATA_PTR; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = +#endif
+static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; u32 spl_boot_device(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo); +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) switch (bsel & 0x7) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ return BOOT_DEVICE_RAM; @@ -55,6 +65,24 @@ u32 spl_boot_device(void) printf("Invalid boot device (bsel=%08x)!\n", bsel); hang(); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10)
- switch ((bsel>>12) & 0x7) {
- case 0x1: /* FPGA (HPS2FPGA Bridge) */
- case 0x2: /* NAND Flash (1.8V) */
- case 0x3: /* NAND Flash (3.0V) */
- case 0x4: /* SD/MMC External Transceiver (1.8V) */
- case 0x5: /* SD/MMC Internal Transceiver (3.0V) */
- case 0x6: /* QSPI Flash (1.8V) */
- case 0x7: /* QSPI Flash (3.0V) */
- default:
hang();
+#endif } #ifdef CONFIG_SPL_MMC_SUPPORT @@ -68,6 +96,7 @@ u32 spl_boot_mode(const u32 boot_device) } #endif +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { writel(0x1, &nic301_regs->lwhps2fpgaregs); @@ -182,3 +211,54 @@ void board_init_f(ulong dummy) /* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +void board_init_f(ulong dummy) +{
- memset(__bss_start, 0, __bss_end - __bss_start);
- * Configure Clock Manager to use intosc clock instead
external osc to
- * ensure success watchdog operation. We do it as early as
possible.
- cm_use_intosc();
- watchdog_disable();
- arch_early_init_r();
- /* release osc1 watchdog timer 0 from reset */
- reset_deassert_osc1wd0();
- /* reconfigure and enable the watchdog */
- hw_watchdog_init();
- WATCHDOG_RESET();
- /* We need to access to FDT as this stage */
- /* FDT is at end of image */
- gd->fdt_blob = (void *)(__bss_end);
- /* Check whether we have a valid FDT or not. */
- if (fdtdec_prepare_fdt()) {
please see "
- /* Initialize the timer */
- timer_init();
- /* configuring the clock based on handoff */
- cm_basic_init(gd->fdt_blob);
- WATCHDOG_RESET();
- config_dedicated_pins(gd->fdt_blob);
- WATCHDOG_RESET();
- /* configure the Reset Manager */
- reset_deassert_dedicated_peripherals();
- /* enable console uart printing */
- preloader_console_init();
+} +#endif
This patch will probably need changes to work with v2, so I'll review it then.
I know that the license change will need to be reverted, but let me review it again.
Dinh
- Copyright (C) 2012 Altera Corporation <www.altera.com>
- Copyright (C) 2012-2016 Altera Corporation <www.altera.com>
Shouldn't be changing the license.
I don't know about all these includes, do you really need them? I don't see where you would need pinmux.h in this patch.
- default:
hang();
+#endif }
You should just do a shift define here, so you don't have to add all this extra code here. Something like
switch ((bsel >> BOOTINFO_BSEL_SHIFT) & 0x7)
- cm_use_intosc();
Why?
I don't think you should be calling this here.
- WATCHDOG_RESET();
Do you really need all these WATCHDOG_RESET()'s?
There's no need for this #ifdef. If you build for ARCH_SOCFPGA is OF_CONTROL selected.
Why?
Dinh
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach- socfpga/spl.c index fec4c7a..9375514 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -1,7 +1,7 @@ /*
Yeah, i will revert it.
Yeah, we those header, otherwise compilation failed. we need pinmux.h also, because there is a function config_dedicated_pins(gd->fdt_blob); in void board_init_f(ulong dummy). This function would configure the dedicated IO such as UART IO before enable print console.
- default:
bsel);
hang();
+#endif }
external osc to
possible.
- cm_use_intosc();
Why?
Disabled watchdog for watchdog configuration, this cater for scenario watchdog already starting running such as warm reset.
This function contains security policies initialization(before accessing any slaves), asserting reset to all timers(L4) before HW configuration. This is to ensure no firewall blocking on slave, timer in idle state after power up/warm reset.
- WATCHDOG_RESET();
Why?
we have dedicated IO configuration and clock configuration based on handoff data in FDT.
Dinh
Chee Tien Fong
Chee, Tien Fong
Dinh Nguyen
