Re: [U-Boot] Missing ethernet
On 2012-04-19 07:53, Andy Pont wrote:
Gary wrote...
I'm trying to update U-boot on my board from v2011.06 to v2011.12 It's an OMAP 3530, much like the BeagleBoard, with SMSC911x networking.
So not a BeagleBoard then but something different.
Is the board you are using one of the boards supported in the mainline U-Boot tree or is it an out-of-tree port? If it is in mainline then have you chosen the correct configuration to use?
It's my own board, not in the mainline.
I've looked through the 'bootm' path and I can't see what might have changed that would cause such behaviour. As far as I can tell, everything else is working in Linux with the new U-Boot, just not the SMSC device.
If you try to use TFTP in U-Boot does that work? If not then I would guess there is a configuration issue with the devices that you have enabled in U-Boot rather than it being an issue with the bootm command.
As I said, U-Boot works fine. The problem comes when Linux boots.
I've bisected it down to this change: commit 81bdc155c72ef9e093b388b90c58d8134d870976 Author: Sanjeev Premi premi@ti.com Date: Thu Sep 8 10:47:25 2011 -0400
omap: gpio: Use generic API
That let me figure out the problem - I had to modify my board code for the new GPIO functions and somehow that's where the problem is. Still working out the details, but now I know where to look.
Thanks for the help
Gary Thomas
