[U-Boot] [PATCH][v3] ls102x: configs - Add hash command in freescale LS1 platforms
Hardware accelerated support for SHA-1 and SHA-256 has been added. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com --- Changed from v2: Incorporated Denx comments Rearranged config options in order sec_init call modified
Changes from v1: Rebased to HEAD of uboot Compilation warning fixed in ls1021atwr build
arch/arm/include/asm/arch-ls102xa/config.h | 8 ++++++++ board/freescale/ls1021aqds/ls1021aqds.c | 8 ++++++++ board/freescale/ls1021atwr/ls1021atwr.c | 8 ++++++++ include/configs/ls1021aqds.h | 6 ++++++ include/configs/ls1021atwr.h | 6 ++++++ 5 files changed, 36 insertions(+)
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index a500b5b..d12038f 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -19,6 +19,8 @@ #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x00560000) #define CONFIG_SYS_FSL_SCFG_ADDR (CONFIG_SYS_IMMR + 0x00570000) +#define CONFIG_SYS_FSL_SEC_ADDR (CONFIG_SYS_IMMR + 0x700000) +#define CONFIG_SYS_FSL_JR0_ADDR (CONFIG_SYS_IMMR + 0x710000) #define CONFIG_SYS_FSL_SERDES_ADDR (CONFIG_SYS_IMMR + 0x00ea0000) #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) #define CONFIG_SYS_FSL_LS1_CLK_ADDR (CONFIG_SYS_IMMR + 0x00ee1000) @@ -66,6 +68,7 @@ #define CONFIG_SYS_FSL_DSPI_BE #define CONFIG_SYS_FSL_QSPI_BE #define CONFIG_SYS_FSL_DCU_BE +#define CONFIG_SYS_FSL_SEC_LE
#define DCU_LAYER_MAX_NUM 16
@@ -76,8 +79,13 @@ #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 +#define CONFIG_SYS_FSL_SEC_COMPAT 5 #else #error SoC not defined #endif
+#if CONFIG_SYS_FSL_SEC_COMPAT >= 4 +#define CONFIG_FSL_CAAM +#endif + #endif /* _ASM_ARMV7_LS102XA_CONFIG_ */ diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 12e83f7..ea5f884 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -13,6 +13,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> +#include <fsl_sec.h>
#include "../common/qixis.h" #include "ls1021aqds_qixis.h" @@ -213,6 +214,13 @@ int config_serdes_mux(void) return 0; }
+#if defined(CONFIG_MISC_INIT_R) +int misc_init_r(void) +{ + return sec_init(); +} +#endif + int board_init(void) { struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index b522ff2..6f841c4 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -16,6 +16,7 @@ #include <netdev.h> #include <fsl_mdio.h> #include <tsec.h> +#include <fsl_sec.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -280,6 +281,13 @@ int board_init(void) return 0; }
+#if defined(CONFIG_MISC_INIT_R) +int misc_init_r(void) +{ + return sec_init(); +} +#endif + void ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd); diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index bb47813..e1ca78a 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -388,4 +388,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_OF_BOARD_SETUP #define CONFIG_CMD_BOOTZ
+#define CONFIG_MISC_INIT_R + +/* Hash command with SHA acceleration supported in hardware */ +#define CONFIG_CMD_HASH +#define CONFIG_SHA_HW_ACCEL + #endif diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 45b2272..7199c92 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -288,4 +288,10 @@ #define CONFIG_OF_BOARD_SETUP #define CONFIG_CMD_BOOTZ
Ruchika Gupta
