[U-Boot] [PATCH 3/3][v4] board/c29xpcie: Add support of 8K page size NAND flash
Defines constants required to support 8K page size NAND flash.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2:Sending as it is Changes for v3:Sending as it is Changes for v4:Sending as it is
include/configs/C29XPCIE.h | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 83779ef..6a1e145 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -189,13 +189,14 @@ | CSPR_MSEL_NAND \ | CSPR_V) #define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) +#define CONFIG_SYS_NAND_OOBSIZE 0x00000280 /* 640b */ #define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ - | CSOR_NAND_RAL_2 /* RAL = 2 Bytes */ \ - | CSOR_NAND_PGS_2K /* Page Size = 2k */ \ - | CSOR_NAND_SPRZ_64 /* Spare size = 64 */ \ - | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ + | CSOR_NAND_RAL_3 /* RAL = 3 Bytes */ \ + | CSOR_NAND_PGS_8K /* Page Size = 8K */ \ + | CSOR_NAND_SPRZ_CSOR_EXT /*oob in csor_ext*/\ + | CSOR_NAND_PB(128)) /*128 Pages Per Block*/ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x01) | \ FTIM0_NAND_TWP(0x0c) | \ FTIM0_NAND_TWCHT(0x08) | \ @@ -222,6 +223,7 @@ #define CONFIG_SYS_CSPR1 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK1 CONFIG_SYS_NAND_AMASK #define CONFIG_SYS_CSOR1 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CSOR1_EXT CONFIG_SYS_NAND_OOBSIZE #define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NAND_FTIM0 #define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 #define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2
Prabhakar Kushwaha
